    4. ioBroker.js-controller 1.5.6
    • Matzebhv
      Matzebhv @Bluefox last edited by wendy2702
      @Bluefox ah, ok. Frage falsch verstanden. Das hatte ich oben schon einmal geschrieben. IOBroker hat ca. alle 30 sec. mit:
      host.raspberry	2019-02-13 18:19:05.539	error	RangeError: Maximum call stack size exceeded at Buffer.write (buffer.js:855:34) at fromString (buffer.js:319:20) at Function.Buffer.from (buffer.js:177:12) at new Buffer (buffer.js:158
      host.raspberry	2019-02-13 18:19:05.538	error	uncaught exception: Maximum call stack size exceeded
      iot.0	2019-02-13 18:19:04.819	info	Connection changed: connect
      neu gestartet,
      • Homer.J.
        Homer.J. @Bluefox last edited by
        @Bluefox Hallo Bluefox,
        hab mal direkt von Git installiert nach kurzer Zeit dieser Fehler.
        daswetter.0	2019-02-14 10:50:02.959	error	at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
        daswetter.0	2019-02-14 10:50:02.959	error	at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
        daswetter.0	2019-02-14 10:50:02.959	error	at WS.<anonymous> (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
        daswetter.0	2019-02-14 10:50:02.959	error	at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
        daswetter.0	2019-02-14 10:50:02.959	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
        daswetter.0	2019-02-14 10:50:02.959	error	at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
        daswetter.0	2019-02-14 10:50:02.959	error	at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
        daswetter.0	2019-02-14 10:50:02.959	error	at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:237:14)
        daswetter.0	2019-02-14 10:50:02.959	error	at decodeString (/opt/iobroker/node_modules/socket.io-parser/index.js:325:9)
        daswetter.0	2019-02-14 10:50:02.959	error	at tryParse (/opt/iobroker/node_modules/socket.io-parser/index.js:336:12)
        daswetter.0	2019-02-14 10:50:02.959	error	RangeError: Maximum call stack size exceeded
        daswetter.0	2019-02-14 10:50:02.958	error	uncaught exception: Maximum call stack size exceeded
          PrinzEisenherz1 last edited by
          Hi @Bluefox
          Bei mir läuft seit gestern die 1.5.6 und bis jetzt läuft alles.
          Ausser die Warnmeldung vom dasWetter-Adapter.
          host.ioBroker-VM	2019-02-14 11:32:07.105	error	instance system.adapter.daswetter.0 terminated with code 11 (Desired termination)
          Die war bei der 1.4.2 nicht. Die kommt zeitlich so wie ich den Schedule vom Adapter eingestellt habe.
          Ansonsten sehe ich derzeit keine Auffälligkeiten.
          Johnny
          System:
          ioBroker in VM (Proxmox) noch alte Installationsart.
          node: 8.15.0
          nodejs: 8.15.0
          npm: 6.5.0
          JS: 3.6.5
          JS-Controller: 1.5.6
          dasWetter: 2.6.1
          Bluefox 1 Reply Last reply Reply Quote 0
          • Bluefox
            Bluefox @PrinzEisenherz1 last edited by
            @PrinzEisenherz1 Dafür gibt es jetzt 1.5.7
            • simatec
              simatec Developer Most Active @apollon77 last edited by
              @apollon77 sagte in ioBroker.js-controller 1.5.6:
              @simatec Nach Rücksprache mit @AlCalzone ist das nicht ganz korrek t- zumindestens nicht mit den Installern seit 20.1. glaube ich.
              Dafpr ind die Default ACLs da die vom Instller gesetzt werden
              Dann gehören die Dateien zwar dem aktuellen user, iobroker behält trotzdem die Berechtigungen
              Ich habe heute nochmal ein debian testsystem eingerichtet und mit
              npm i iobroker.js-controller@1.5.7
              ein Update angestossen. Geht leider nicht mit neuem Installer.
              Es fehlen danach Rechte.
              host.debian	2019-02-14 18:04:18.844	error	Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/pids.txt' at Object.fs.openSync (fs.js:646:18) at Object.fs.writeFileSync (fs.js:1299:33) at Timeo
              host.debian	2019-02-14 18:04:18.844	error	uncaught exception: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/pids.txt'
              Ich muss mit chmod die Rechte per Konsole dann manuell vergeben, damit es läuft.
              • Matzebhv
                Matzebhv last edited by Matzebhv
                @Bluefox : ich habe jetzt noch einmal deine aktuelle Version probiert.
                IOBroker startet sich wieder nach ca. 30sec. neu.
                iobroker.inst@1.3.1 /opt/iobroker
                ├─┬ iobroker.admin@3.6.0
                │ └── socket.io@1.7.2
                └─┬ iobroker.js-controller@1.5.7
                  └── socket.io@1.7.2
                   │       New minor version of npm available! 6.5.0 → 6.8.0       │
                   │   Changelog: https://github.com/npm/cli/releases/tag/v6.8.0   │
                   │               Run npm install -g npm to update!               │
                Problem bei mir scheint der UPNP-Adapter zu sein. Damit fangen die Fehler an, das schaukelt sich dann bis zum Neustart hoch.
                Mit deaktiviertem Adapter läuft das System ( bis auf meine Cron-Probleme )
                pberry	2019-02-14 19:59:53.347	error	instance system.adapter.upnp.0 terminated with code 0 (OK)
                Caught	2019-02-14 19:59:53.347	error	by controller[0]: at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10)
                Caught	2019-02-14 19:59:53.347	error	by controller[0]: at WebSocket.emit (events.js:214:7)
                Caught	2019-02-14 19:59:53.347	error	by controller[0]: at emitTwo (events.js:126:13)
                Caught	2019-02-14 19:59:53.347	error	by controller[0]: at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14)
                Caught	2019-02-14 19:59:53.347	error	by controller[0]: at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
                Caught	2019-02-14 19:59:53.347	error	by controller[0]: at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8)
                Caught	2019-02-14 19:59:53.347	error	by controller[0]: at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
                Caught	2019-02-14 19:59:53.347	error	by controller[0]: at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
                Caught	2019-02-14 19:59:53.346	error	by controller[0]: at WS.<anonymous> (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
                Caught	2019-02-14 19:59:53.346	error	by controller[0]: at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
                Caught	2019-02-14 19:59:53.346	error	by controller[0]: at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
                Caught	2019-02-14 19:59:53.346	error	by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                Caught	2019-02-14 19:59:53.346	error	by controller[0]: at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
                Caught	2019-02-14 19:59:53.346	error	by controller[0]: at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:237:14)
                Caught	2019-02-14 19:59:53.346	error	by controller[0]: at decodeString (/opt/iobroker/node_modules/socket.io-parser/index.js:325:9)
                Caught	2019-02-14 19:59:53.346	error	by controller[0]: at tryParse (/opt/iobroker/node_modules/socket.io-parser/index.js:336:12)
                Caught	2019-02-14 19:59:53.346	error	by controller[0]: RangeError: Maximum call stack size exceeded
                upnp.0	2019-02-14 19:59:53.160	error	at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10)
                upnp.0	2019-02-14 19:59:53.160	error	at WebSocket.emit (events.js:214:7)
                upnp.0	2019-02-14 19:59:53.160	error	at emitTwo (events.js:126:13)
                upnp.0	2019-02-14 19:59:53.160	error	at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14)
                upnp.0	2019-02-14 19:59:53.160	error	at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
                upnp.0	2019-02-14 19:59:53.160	error	at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8)
                upnp.0	2019-02-14 19:59:53.160	error	at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
                upnp.0	2019-02-14 19:59:53.160	error	at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
                upnp.0	2019-02-14 19:59:53.160	error	at WS.<anonymous> (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
                upnp.0	2019-02-14 19:59:53.160	error	at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
                upnp.0	2019-02-14 19:59:53.160	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
                upnp.0	2019-02-14 19:59:53.160	error	at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                upnp.0	2019-02-14 19:59:53.160	error	at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
                upnp.0	2019-02-14 19:59:53.160	error	at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:237:14)
                upnp.0	2019-02-14 19:59:53.160	error	at decodeString (/opt/iobroker/node_modules/socket.io-parser/index.js:325:9)
                upnp.0	2019-02-14 19:59:53.160	error	at tryParse (/opt/iobroker/node_modules/socket.io-parser/index.js:336:12)
                upnp.0	2019-02-14 19:59:53.160	error	RangeError: Maximum call stack size exceeded
                upnp.0	2019-02-14 19:59:53.160	error	uncaught exception: Maximum call stack size exceeded
                upnp.0	2019-02-14 19:59:52.372	info	Auto discover: true
                upnp.0	2019-02-14 19:59:52.357	info	starting. Version 0.3.9 in /opt/iobroker/node_modules/iobroker.upnp, node: v8.15.0
                Repository ist latest, alle Adapter aktuell.
                Matze
                P.S. Grade gesehen, das Wetter kommt auch.
                daswetter.0	2019-02-14 20:15:01.880	error	RangeError: Maximum call stack size exceeded at tryParse (/opt/iobroker/node_modules/socket.io-parser/index.js:336:12) at decodeString (/opt/iobroker/node_modules/socket.io-parser/index.js:325
                daswetter.0	2019-02-14 20:15:01.880	error	uncaught exception: Maximum call stack size exceeded
                • Holger76
                  Holger76 @cvidal last edited by Holger76
                  @cvidal
                  bei mir steht nun permanent "admin" drin.. schon 1.5.7 probiert ? ist es da weg ?
                    sigi234 Forum Testing Most Active @Holger76 last edited by sigi234
                    @Holger76 sagte in ioBroker.js-controller 1.5.6:
                    @cvidal
                    Bei mir auch, nicht weg........☹
                      sigi234 Forum Testing Most Active @cvidal last edited by
                      @cvidal
                      Hast du den Fehler noch?
                      Holger76 cvidal 2 Replies Last reply Reply Quote 0
                      • Bluefox
                        Bluefox @Matzebhv last edited by
                        Участник @Matzebhv написал в ioBroker.js-controller 1.5.6:
                        ioBroker komplett oder nur upnp und dasWetter?=
                        Matzebhv 1 Reply Last reply Reply Quote 0
                        • Bluefox
                          Ich kann den Fehler mit "max callstack" nicht reproduzieren.
                          Wir müssen einkreisen:
                          Bitte, die Leute, die diesen Fehler beobachten, ausfühlen:
                          • node.js version ?
                          • states in redis / memory ?
                          • js-controller version ?
                          • windows/linux ?
                          • RAM ?
                          • daswetter version?
                          • Holger76
                            Holger76 @sigi234 last edited by Holger76
                            @sigi234 habe seit 15min die 1.5.7 installiert.. bisher nicht aufgetreten. Vorher war es eigentlich sofort und andauernd..
                            nur das hier habe ich seit der letzten Version auch:
                              sigi234 Forum Testing Most Active @Bluefox last edited by Bluefox
                              @Bluefox sagte in ioBroker.js-controller 1.5.6:
                              • node.js version ? v8.15.0
                              • states in redis / memory ? RAM-Nutzung: 1786 MB
                              • js-controller version ? 1.5.7
                              • windows/linux ? Windows
                              • RAM ? 8 GB
                              • daswetter version? 2.6.1
                              sigi234
                                Hi @Bluefox
                                Hab jetzt auch auf 1.5.7 geupdated.
                                Bis jetzt keine Auffälligkeiten.
                                die warning vom dasWetter hat sich jetzt auf info geändert
                                host.ioBroker-VM	2019-02-14 23:00:09.303	info	instance system.adapter.daswetter.0 terminated with code 11 (Desired termination)
                                ansonsten läuft es bis jetzt ganz unauffällig.
                                Meine Daten
                                node: 8.15.0
                                nodejs: 8.15.0
                                npm: 6.5.0
                                js-controller: 1.5.7
                                redis: ja
                                debian9 in VM auf Proxmox
                                dasWetter: 2.6.1
                                Johnny
                                • Bluefox
                                  Bluefox @sigi234 last edited by
                                  Участник @sigi234 написал в ioBroker.js-controller 1.5.6:
                                  Hast du states in redis oder default in memory?
                                    default
                                    default
                                      apollon77 @PrinzEisenherz1 last edited by
                                      @PrinzEisenherz1 cool. Damit es wir vorher nur der erwartete andere Return Code.
                                        Also nochmal kurze Rückmeldung. bis jetzt läuft es ohne Probleme bei mir.
                                        Top.
                                        Ich bleib bei 1.5.7
                                        Danke euch
                                          So, nochmal kurze Rückinfo.
                                          Bis jetzt läuft alles top.
                                          Auch meine Schedules machen das was sie sollen.
                                          Johnny
                                          P.S. Danke für die tolle Arbeit und danke für das klasse Forum ( incl. dem neuen Design) mir gefällts.
                                          • cvidal
                                            cvidal Forum Testing @sigi234 last edited by
                                            @sigi234 Felher ist unter 1.5.7 verschwunden.
                                            Cache geleert, danach wurde nicht mehr gefiltert.
                                            call for action test
                                            31
                                            150
                                            19841
