    4. FHEM Adapter
    FHEM Adapter
      Einklaus last edited by
      Hallo
      habe es installiert (von Git) und es gab Probleme. Adapter wollte nicht mehr starten.
      Caught 2019-01-31 19:02:05.459 error by controller[0]: at TCP.onStreamRead [as onread] (internal/stream_base_commons.js:94:17)
      Caught 2019-01-31 19:02:05.459 error by controller[0]: at Socket.Readable.push (_stream_readable.js:219:10)
      Caught 2019-01-31 19:02:05.459 error by controller[0]: at readableAddChunk (_stream_readable.js:264:11)
      Caught 2019-01-31 19:02:05.459 error by controller[0]: at addChunk (_stream_readable.js:283:12)
      Caught 2019-01-31 19:02:05.459 error by controller[0]: at Socket.emit (events.js:182:13)
      Caught 2019-01-31 19:02:05.459 error by controller[0]: at Socket.telnetSocket.on.data (D:\ioBroker\node_modules\iobroker.fhem\lib\telnet.js:136:30)
      Caught 2019-01-31 19:02:05.459 error by controller[0]: at Telnet.telnetOut.send [as requestCB] (D:\ioBroker\node_modules\iobroker.fhem\main.js:855:17)
      Caught 2019-01-31 19:02:05.459 error by controller[0]: at checkSubscribe (D:\ioBroker\node_modules\iobroker.fhem\main.js:918:15)
      Caught 2019-01-31 19:02:05.459 error by controller[0]: at checkSubscribe (D:\ioBroker\node_modules\iobroker.fhem\main.js:856:21)
      Caught 2019-01-31 19:02:05.458 error by controller[0]: at parseObjects (D:\ioBroker\node_modules\iobroker.fhem\main.js:1003:22)
      Caught 2019-01-31 19:02:05.458 error by controller[0]: TypeError: Cannot read property 'length' of undefined
      fhem.0 2019-01-31 19:02:05.429 error at TCP.onStreamRead [as onread] (internal/stream_base_commons.js:94:17)
      fhem.0 2019-01-31 19:02:05.429 error at Socket.Readable.push (_stream_readable.js:219:10)
      fhem.0 2019-01-31 19:02:05.429 error at readableAddChunk (_stream_readable.js:264:11)
      fhem.0 2019-01-31 19:02:05.429 error at addChunk (_stream_readable.js:283:12)
      fhem.0 2019-01-31 19:02:05.429 error at Socket.emit (events.js:182:13)
      Habe anschließend über IObroker 1.1.0. und dann 1.1.1. Installiert und es lief dann wieder.
      Klaus
      • LausiD
        LausiD last edited by
        Hallo Klaus,
        vielen Dank für Deinen Einsatz und die Rückmeldung 🙂
        Du hast mit einer neuen Instanz getestet,oder?
        Konnte den Fehler jedenfalls nur bei Anlage einer neuen Instanz nachvollziehen.
        Sorry hatte ich nicht getestet 😞
        LausiD
        • LausiD
          Hallo Klaus,
          Fehler sollten weg sein.
          Falls du Zeit und Lust hast darfst es gerne nochmal über github testen…...
          Danke und Gruß
          LausiD
            Hallo LausiD,
            Danke für deine Arbeit und das du es den Adapter immer weiter entwickelst.
            Bisschen testen und dann rummaulen ist nicht der große Einsatz 😉
            Einen Adapter zu entwickeln dürfte da deutlich mehr Einsatz bedeuten (und es zeigt auch das du deutlich mehr Ahnung hast).
            Werde es morgen erst testen können, hatte nebenbei nicht mit einer Neuen Instanz getestet.
            Gruß und noch einen schönen Abend
            Klaus
            • LausiD
              kein Übertrag von readingsGroup 😞
              viewtopic.php?f=30&t=21655&p=228934#p228934
              Brauch das noch jemand?
              Danke und Gruß
              LausiD
              • LausiD
                Nabend zusammen,
                auf github zum Testen bereit.
                1. FHEM readingsGroup werden jetzt auch übertragen
                2. In FHEM Raum ioB_System wird fhem.x.alive automatisch angelegt -> on = FHEM Adapter OK; off = FHEM Adapter keine Verbindung
                LausiD
                • LausiD
                  hat wirklich niemand Zeit und Lust den Adapter über GitHub zu aktualisieren und kurz zu testen ?
                  LausiD
                    Hallo LausiD,
                    installiert habe ich ihn. Fhem zeigt mir allerdings in ioB_System kein fhem.x.alive an
                    Habe dort:......
                    dummy
                    send2ioB ???
                    ......stehen.
                    Klaus
                    • LausiD
                      LausiD last edited by LausiD
                      Hallo Klaus,
                      auf Dich ist halt Verlass.....Danke:-)
                      Was steht unter Step 10 beim Start?
                      Kannst du mal noch fhem.x.info.Configurations.autoConfigFHEM auf true setzen und nochmal probieren?
                      Mit send2ioB kann aus FHEM ein Objekt/State in ioBroker direkt beschrieben werden.
                      zB alexa2.0.Echo-Devices.xxxxxx.Commands.speak .Text aus FHEM
                      Ab sofort sollte auch ein dummy mit fhem.x.send2ioB angelegt werden
                      Danke und Gruß
                      LausiD
                        Hallo LausiD,
                        Adapter sicherheitshalber nochmal Neu installiert (über GIT)
                        Adapter lief nicht mehr hoch. Nach Step3 gab es Probleme
                        fhem.0 2019-02-15 11:29:35.385 debug statesDB connected
                        fhem.0 2019-02-15 11:29:34.711 silly transport error
                        fhem.0 2019-02-15 11:29:34.711 error Error: server error at Socket.onPacket (D:\ioBroker\node_modules\iobroker.js-controller\node_modules\engine.io-client\lib\socket.js:450:19) at WS.<anonymous> (D:\ioBroker\node_modules\iobroker
                        fhem.0 2019-02-15 11:29:34.711 error server error
                        fhem.0 2019-02-15 11:29:34.711 error TypeError: Cannot read property 'write' of null at Timeout.setTimeout [as _onTimeout] (D:\ioBroker\node_modules\iobroker.fhem\lib\telnet.js:128:60) at ontimeout (timers.js:436:11) at tryOn
                        fhem.0 2019-02-15 11:29:34.711 error uncaught exception: Cannot read property 'write' of null
                        fhem.0 2019-02-15 11:29:34.695 error uncaught exception: Cannot read property 'split' of undefined
                        fhem.0 2019-02-15 11:29:34.695 info > FUNCTION delete unused objects automatically - info.Configurations.deleteUnusedObjects (true)
                        fhem.0 2019-02-15 11:29:34.695 info > FUNCTION if fhem.0 set smartName automatically (Adapter Cloud) - info.Configurations.autoSmartName (true)
                        fhem.0 2019-02-15 11:29:34.695 info > FUNCTION allow special configurations FHEM - info.Configurations.autoConfigFHEM (true)
                        fhem.0 2019-02-15 11:29:34.677 debug [getConfig] info.Configurations.onlySyncRoomioBroker,ioB_OUT
                        fhem.0 2019-02-15 11:29:34.677 debug [getConfig] info.Configurations.onlySyncNAME
                        fhem.0 2019-02-15 11:29:34.677 debug [getConfig] info.Configurations.ignorePossibleSetsgetConfig,etRegRaw,egBulk,regSet,deviceMsg,CommandAccepted
                        fhem.0 2019-02-15 11:29:34.677 debug [getConfig] info.Configurations.ignoreReadingscurrentTrackPositionSimulated,currentTrackPositionSimulatedSec
                        fhem.0 2019-02-15 11:29:34.677 debug [getConfig] info.Configurations.allowedInternalsTYPE,NAME
                        fhem.0 2019-02-15 11:29:34.677 debug [getConfig] info.Configurations.allowedAttributesroom,alias,comment
                        fhem.0 2019-02-15 11:29:34.677 debug [getConfig] info.Configurations.ignoreObjectsInternalsTYPE
                        fhem.0 2019-02-15 11:29:34.677 debug [getConfig] info.Configurations.ignoreObjectsInternalsNAMEinfo
                        fhem.0 2019-02-15 11:29:34.677 debug [getConfig] info.Configurations.ignoreObjectsAttributesroom
                        fhem.0 2019-02-15 11:29:34.677 debug [getConfig] info.Configurations.allowedIOBin
                        fhem.0 2019-02-15 11:29:34.677 debug [getSetting] info.Configurations.oldState false
                        fhem.0 2019-02-15 11:29:34.677 debug [getSetting] info.Configurations.deleteUnusedObjects true
                        fhem.0 2019-02-15 11:29:34.677 debug [getSetting] info.Configurations.autoSmartName true
                        fhem.0 2019-02-15 11:29:34.676 debug [getSetting] info.Configurations.autoConfigFHEM false
                        fhem.0 2019-02-15 11:29:34.676 debug [getSetting] info.Configurations.autoFunction false
                        fhem.0 2019-02-15 11:29:34.676 debug [getSetting] info.Configurations.autoRole false
                        fhem.0 2019-02-15 11:29:34.676 debug [getConfigurations] start
                        fhem.0 2019-02-15 11:29:34.676 info STEP 03 ===== select function of Adapter (FUNCTION) and Devices to sync (SYNC) - check fhem.0.info.Configurations (true or value)
                          Habe ihn Neu installiert und die autoconfFHEM auf true gesetzt
                          Denke mal so soll es auch sein
                          • LausiD
                            Genau so soll es aussehen 🙂
                            Vielleicht kann am WE noch Version 1.2 an den Start gehen
                            Vielen Dank Klaus für deine Mitarbeit
                            LausiD
                              Einklaus last edited by Einklaus
                              Hallo LausiD
                              habe noch folgende Meldung im Log (Debug = Info Meldung) die alle paar Sekunden wieder kommt..
                              event ioBroker "fhem.0.info.Commands.sendFHEM set fhem.0.alive on-for-timer 70" > set fhem.0.alive on-for-timer 70
                              Sieht so aus, als ob das so sein soll (nehme an ein Lebensbit das gesendet wird) .
                              Schreibe es nur sicherheitshalber, falls nicht so sein sollte.
                              Klaus
                              • LausiD
                                Hallo Klaus,
                                vielen Dank für den Hinweis.
                                Stimmt genau was du schreibst, alle 60 Sek wird "set fhem.x.alive on-for-timer 70" an FHEM geschickt.
                                Falls dies ausbleibt wechselt fhem.x.alive spätestens nach 70 Sek auf off.
                                Somit kann in FHEM die Funktion FHEM Adapter/iobroker überwacht werden.
                                Eigentlich kann die Zeit auf 5 Min verlängert werden, oder ?
                                Unter fhem.x.info.Settings können die gewünschten Meldungen mit true/false ausgewählt werden.
                                Keine Meldungen "event ioBroker ......"
                                fhem.0.info.Settings.logEventIOB= false
                                Gruß und Danke
                                LausiD
                                • LausiD
                                  Nabend zusammen,
                                  auf github steht Version 1.2.0 zum Testen bereit.
                                  Bei entsprechenden Rückmeldungen kann Version in latest übernommen werden.
                                  Vielen Dank und Gruß
                                  LausiD
                                    Scheint alles i.O. zu sein
                                      Domoe last edited by
                                      Moin zusammen,
                                      ich habe ein kleines Problem vielleicht ist es aber auch nur eine Einstellungssache.
                                      Ich habe an Fhem nur EnOcean Geräte. Diese über den Adapter in ioBroker.
                                      Wenn ich ioBroker Neustarte dann reagieren diverse Schalter als ob man selber auf den Schalter gedrückt hat.
                                      Beispiel:
                                      Fernseher an Z-Wave Steckdose.
                                      Enocean Wandschalter.
                                      Beide über ein Blockly Script verbunden.
                                      Wenn der Fernseher an ist und ich ioBroker neu starte geht der Fernseher aus.
                                      Im Logbuch sind keine Fehler zu finden.
                                      Hatte jemand schonmal dieses Problem?
                                      Vielen Dank im voraus.
                                      • LausiD
                                        Hallo ﹰDomoe,
                                        ﹰﹰbei einem ﹰNeustart ioBroker wird natürlich auch der FHEM Adapter neu gestartet.
                                        Dabei werden alle Devices aus FHEM neu eingelesen und die jeweiligen States im ioBroker neu gesetzt.
                                        Vermutlich tritt das Verhalten auch nur bei einem Neustart FHEM Adapter auf, oder?
                                        Daher vermute ich den Fehler eher im Blocky Script.....
                                        LausiD
                                          Moin Lausi,
                                          ja bis jetzt konnte ich das verhalten nur beim Neustart feststellen.
                                          Ich guck mir meine Scripte nochmal an vielleicht habe ich da ja ein Fehler gemacht.
                                          Danke für deine Antwort
                                            hippoo last edited by
                                            Hallo ich habe seit dem Update auf 1.20, alle 60 sek. folgende warning im iobroker:
                                            warn	detect detect: missing "set fhem.0.alive on-for-timer 70" > set manuelly in FHEM or automatically with "fhem.0.info.Configuration.autoConfigFhem" = true | more info README.md
                                            Der room "IoB_System" wird wohl korrekt angelegt in fhem.
                                            Was ist da los?!
                                            1.2k
                                            81.1k
                                            adapter fhem
                                            82
                                            676
                                            194191
