    4. [Problem] Dream btw. Enigma2 Adapter
    • Matten Matten
      Matten Matten last edited by
      @Piwie:
      Habe ich gerade gemacht… Trotzdem weiterhin diese Fehler, sobald die VU+ Solo4k in den Standby geschickt wird:
      host.Rasperry	2019-01-31 21:15:05.109	error	instance system.adapter.enigma2.0 terminated with code 0 (OK)
      host.Rasperry	2019-01-31 21:15:05.109	error	Caught by controller[0]: at Parser.exports.Parser.Parser.parseString (/opt/iobroker/node_modules/iobroker.enigma2/node_modules/xml2js/lib/parser.js:322:31)
      host.Rasperry	2019-01-31 21:15:05.109	error	Caught by controller[0]: at SAXParser.write (/opt/iobroker/node_modules/iobroker.enigma2/node_modules/sax/lib/sax.js:1436:13)
      host.Rasperry	2019-01-31 21:15:05.109	error	Caught by controller[0]: at closeTag (/opt/iobroker/node_modules/iobroker.enigma2/node_modules/sax/lib/sax.js:889:7)
      host.Rasperry	2019-01-31 21:15:05.109	error	Caught by controller[0]: at emitNode (/opt/iobroker/node_modules/iobroker.enigma2/node_modules/sax/lib/sax.js:629:5)
      host.Rasperry	2019-01-31 21:15:05.108	error	Caught by controller[0]: at emit (/opt/iobroker/node_modules/iobroker.enigma2/node_modules/sax/lib/sax.js:624:35)
      host.Rasperry	2019-01-31 21:15:05.108	error	Caught by controller[0]: at SAXParser.onclosetag (/opt/iobroker/node_modules/iobroker.enigma2/node_modules/xml2js/lib/parser.js:261:26)
      host.Rasperry	2019-01-31 21:15:05.108	error	Caught by controller[0]: at Parser.emit (events.js:188:13)
      host.Rasperry	2019-01-31 21:15:05.108	error	Caught by controller[0]: at Parser. <anonymous>(/opt/iobroker/node_modules/iobroker.enigma2/node_modules/xml2js/lib/parser.js:303:18)
      host.Rasperry	2019-01-31 21:15:05.108	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:314:7
      host.Rasperry	2019-01-31 21:15:05.108	error	Caught by controller[0]: at evaluateCommandResponse (/opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:410:95)
      host.Rasperry	2019-01-31 21:15:05.106	error	Caught by controller[0]: TypeError: Cannot read property 'e2eventlist' of undefined
      enigma2.0	2019-01-31 21:15:04.588	error	TypeError: Cannot read property 'e2eventlist' of undefined at evaluateCommandResponse (/opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:410:95) at /opt/iobroker/node_modules/iobroker.eni
      enigma2.0	2019-01-31 21:15:04.587	error	uncaught exception: Cannot read property 'e2eventlist' of undefined</anonymous>
      -Piwie- `
      Ich habe da vielleicht eine Idee wie ich das Problem ausblenden kann. Damit es nicht zu diesen Fehlern kommt.
      Ich melde mich sobald ich Erfolg hab.
      Matten Matten
      • Matten Matten
        Version 1.1.9 auf GitHub
        https://github.com/Matten-Matten/ioBrok … /README.md
        (Matten-Matten) (#14) add enigma2.EVENTDURATION_MIN in Minute
        (Matten-Matten) (#14) add enigma2.EVENTREMAINING_MIN in Minute
        (Matten-Matten) Troubleshooting in standby toggle
        (Matten-Matten) Troubleshooting in the "eventlist" query
        Bitte testen und Feedback geben! Danke.
        Matten Matten
        • Steff
          Steff last edited by
          @Matten Matten:
          Bitte testen und Feedback geben! Danke. `
          Läuft bei mir! 😄
          Gruß Steffen
            dos1973 last edited by
            @Matten Matten:
            Start und endzeiten sind lange zahlen, kann ich aber auch noch Mal mit einpflegen. Das scheint ein "Unix Timecode" zu sein. Ich weiß aber noch nicht wie ich
            den umcodiert bekomme. Hat jemand eine Idee?
            Matten Matten `
            du hast es ja inzwischen erfolgreich geschafft :lol:
            hast du ggfs dafür ein script, oder Blocky. Ich habe an anderer Stelle jetzt einen Unit Timestamp und würde den gerne in H:m ausgeben - und dann fiel mir dieser Thread ein.
            Matten Matten Stabilostick 2 Replies Last reply Reply Quote 0
            • Matten Matten
              Matten Matten @dos1973 last edited by Matten Matten
              @dos1973 said in [Problem] Dream btw. Enigma2 Adapter:
              @Matten Matten:
              Matten Matten `
              function sec2HMS(sec) {
              	if (sec  === 0) {
                      return '0';
                  const sec_num = parseInt(sec, 10);
                  let hours   = Math.floor(sec_num / 3600);
                  let minutes = Math.floor((sec_num - (hours * 3600)) / 60);
                  let seconds = sec_num - (hours * 3600) - (minutes * 60);
                  if (minutes < 10) {minutes = '0' + minutes;}
                  if (seconds < 10) {seconds = '0' + seconds;}
                  if (hours === 0) {
                      return minutes + ':' + seconds;
                  if (hours < 10) {hours = '0' + hours;}
                  return hours + ':' + minutes + ':' + seconds;
              Das ist aus Apollon77's alexa2 adapter. hab ich auch nur von ihm abgeschaut.😌
                was mach ich jetzt nur damit 🙂 das hatte ich mir in meinem naiven Kopfbild anders vorgestellt
                ich habe einen DP
                javascript.0.wetterimport.recordtime
                und brauch den wert in
                javascript.0.wetterimport.uhrzeit
                Matten Matten 1 Reply Last reply Reply Quote 0
                • Stabilostick
                  Stabilostick @dos1973 last edited by Stabilostick
                  @dos1973 sagte in [Problem] Dream btw. Enigma2 Adapter:
                  Unit Timestamp
                  Meinst Du Unix Timestamp?
                  Also so etwas wie
                  var s = new Date(meineUnixZeit).toLocaleDateString("de-DE")
                  für das Datum. Und für den Zeitanteil:
                  var s = new Date(meineUnixZeit).toLocaleTimeString("de-DE")
                  Anleitung zu toLocaleTimeString:
                  https://developer.mozilla.org/de/docs/Web/JavaScript/Reference/Global_Objects/Date/toLocaleDateString
                    Ich habs anders gelöst.
                    Ich sende ja unix timecode von einer php website, dort habe ich den formatieren können und schreiben den via simpleapi. Php verstehe ich irgendwie einfacher. In js verstehe leider nix
                    • Stabilostick
                      Stabilostick last edited by
                      Prima, dass Du eine Lösung gefunden hast.
                      Viele Grüße
                      Thomas
                      • Matten Matten
                        ich habe einen DP
                        on({id: "javascript.0.wetterimport.recordtime", change: "ne"}, function (obj) {
                          var value = obj.state.val;
                          setStateDelayed('javascript.0.wetterimport.uhrzeit', sec2HMS((obj.state ? obj.state.val : "")), true, parseInt(0, 10), false);
                        	if (sec  === 0) {
                                return '0';
                            if (hours === 0) {
                        könnte so aussehen.
                        Matten Matten
                          hi,
                          kurze Frage, ich habe in Vis auch die sender logos visualisiert... also der aktuelle Kanal wird mir als Logo in Vis dargestellt mittels Servicereferenz
                          enigma2.0.enigma2.CHANNEL_SERVICEREFERENCE =
                          1:0:1:B:2:85:FFFF0000:0:0:0: (Sky Cinema +1)
                          wenn ich allerdings eine Film von der Festplatte schaue dann habe ich unter dem DP z.B folgendes:
                          1:0:0:0:0:0:0:0:0:0:/media/net/DS218/Rampage - Big Meets Bigger.ts
                          darauf kann ich nicht reagieren, wie macht ihr das mit dem Symbol bei einer Aufnahme?
                          Für eine Idee oder Hinweis Vielen Danke
                          • SBorg
                            ich müsste endlich mal ein passendes Picon erstellen...
                            Da ich externe Picons vom Web-Server nutze, brauche ich die SIDs ohne Doppelpunkte. Deswegen wandele ich sie mittels Javascript sowieso um. Da braucht es nur:
                            if ( PICON == "1:0:0:0:0:0:0:0:0:0:" ) { PICON="&nbsp;" }
                            Da könnte jetzt natürlich auch einfach ein Bild einer HDD rein 🙂
                              meine Referenz ändert sich ja immer abhängig von dem Video was abgespielt wird...
                              in dem Fall hängt das noch dran :/media/net/DS218/Rampage - Big Meets Bigger.ts
                              • SBorg
                                JS kann doch fast alles 🙂
                                Brauchst halt noch ein "split" und schneidest einfach alle Zeichen nach "/" ab, schon hast du nur die SID.
                                ...oder du prüfst einfach nur ob die "1:0:0:....." enthalten ist.
                                  eMd last edited by eMd
                                  wie nutze ich das zap command im blockly?
                                  Will auf folgenden Sender umschalten :
                                  1:0:19:2B98:3F2:1:C00000:0:0:0::KI.KA HD
                                  PS: Hat sich erledigt, musste hinter der letzten Null alles löschen, das war schon der zaubertrick 😉
                                  MfG
                                  eMd
                                  • SBorg
                                    Ich könnte ganz gut noch den "Recordstatus" gebrauchen 🙂
                                    Bekomme ich mit meinen JS-Kenntnissen aber nicht im Adapter gebacken. Also fülle ich den bereits existierenden state RECORDING extern. Dazu nutze ich den e2state in der Timerliste. Dieser ist bei einer laufenden Aufnahme "2".
                                    z.B. als bash: wget -O- -q http://localhost/web/timerlist | grep 'e2state' | grep -c '>2<'
                                    Noch ein "if" drumherum und per Simpel-API und Minuten-Cron getriggert/übertragen.
                                      Kaiman55 last edited by
                                      ich habe jetzt mal den Enigma2 Adapter installiert. Hatte sonst nur den VU Adapter für meine Duo2
                                      Vielleicht kann mir jemand da ne Frage beantworten:
                                      Da gibt es den Bereich "Timer Prüfung". Den habe ich mal eingeschaltet und auf 30 Min gestellt.
                                      Es wird aber kein Objekt mit meinen Timern angezeigt, bzw erstellt.
                                      Wäre halt toll, wenn ich die aktuellen Timer in meiner ViS angezeigt bekomme.
                                      Nun habe ich im Changelog gelesen, dass die Timer entfernt wurden.
                                      Dann ist die o.g. Einstellung sozusagen "ohne Funktion"?
                                      Vielen Dank für die Antwort.
                                        Holly76 last edited by
                                        vorab mal ein Lob, die Möglichkeiten sind schon echt geil ! Leider komme ich nur langsam voran...
                                        Ich habe jetzt auch erst mal den Enigma2 Adapter installiert und habe eine Frage zum Visualisieren der Picons.
                                        Wie bekomme ich das jew. Senderlogo in VIS visualisiert ?
                                        Könnte mir jemand ein Screenshot hochladen wie ich dort was aufrufen und eintragen muss ?
                                        Ich bin noch ziemlich frisch dabei und mache gerade meine ersten Sprünge im VIS.
                                        Ich versuche erst mal alle Adapter zu installieren die ich benötige bzw. die mich Interessieren...
                                        Vielen Dank
                                          el_malto @Holly76 last edited by
                                          @Holly76 lies mal ein paar Beiträge weiter oben, da ist die Lösung.
                                          Deine Picons in das VIS Verzeichnis kopieren und dann mittels den Datenpunkt von oben das passende Picon anzeigen lassen.
                                          • Matten Matten
                                            Matten Matten @Kaiman55 last edited by
                                            @Kaiman55 sagte in [Problem] Dream btw. Enigma2 Adapter:
                                            Ja Timer auslesen ist immer noch ohne Funktion.
                                            Matten Matten
                                            739
                                            189576
