    4. Uninstall - install problem
      starfish last edited by
      .. also bananapi neu aufgesetzt. iobroker gem handbuch installiert.
      ! root@bananapi:~# wget http://download.iobroker.org/nodejs_0.10.22-1_armhf.deb
      ! –2015-03-27 23:12:47-- http://download.iobroker.org/nodejs_0.10.22-1_armhf.deb
      ! Resolving download.iobroker.org (download.iobroker.org)... 134.0.27.32
      ! Connecting to download.iobroker.org (download.iobroker.org)|134.0.27.32|:80... connected.
      ! HTTP request sent, awaiting response... 200 OK
      ! Length: 4865442 (4.6M) [application/x-debian-package]
      ! Saving to: nodejs_0.10.22-1_armhf.deb' ! 100%[======================================>] 4,865,442 2.68M/s in 1.7s ! 2015-03-27 23:12:49 (2.68 MB/s) - nodejs_0.10.22-1_armhf.deb' saved [4865442/4865442]
      ! root@bananapi:~# dpkg -i nodejs_0.10.22-1_armhf.deb
      ! Selecting previously unselected package nodejs.
      ! (Reading database … 38383 files and directories currently installed.)
      ! Unpacking nodejs (from nodejs_0.10.22-1_armhf.deb) ...
      ! Setting up nodejs (0.10.22) ...
      ! Processing triggers for man-db ...
      ! root@bananapi:~# mkdir /opt/iobroker
      ! root@bananapi:~# cd /opt/iobroker
      ! root@bananapi:/opt/iobroker# npm install iobroker
      ! npm http GET https://registry.npmjs.org/iobroker
      ! npm http 200 https://registry.npmjs.org/iobroker
      ! npm http GET https://registry.npmjs.org/iobroker/-/i ... -0.5.1.tgz
      ! npm http 200 https://registry.npmjs.org/iobroker/-/i ... -0.5.1.tgz
      ! npm http GET https://registry.npmjs.org/yargs
      ! npm http 200 https://registry.npmjs.org/yargs
      ! npm http GET https://registry.npmjs.org/yargs/-/yargs-1.2.6.tgz
      ! npm http 200 https://registry.npmjs.org/yargs/-/yargs-1.2.6.tgz
      ! npm http GET https://registry.npmjs.org/minimist
      ! npm http 200 https://registry.npmjs.org/minimist
      ! npm http GET https://registry.npmjs.org/minimist/-/m ... -0.1.0.tgz
      ! npm http 200 https://registry.npmjs.org/minimist/-/m ... -0.1.0.tgz
      ! > iobroker@0.5.1 install /opt/iobroker/node_modules/iobroker
      ! > node lib/setup.js
      ! npm install iobroker.js-controller --production --silent --prefix "/opt/iobroker/node_modules/iobroker/lib/../../../"
      ! /opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:452
      ! if (adapter.substring(0, 'iobroker.'.length) == 'iobroker.') adapter = ada
      ! TypeError: Cannot call method 'substring' of undefined
      ! at Object.getAdapterDir (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:452:17)
      ! at uploadAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:1615:28)
      ! at installAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2054:9)
      ! at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2080:13
      ! at null._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/objectsInMemServer.js:337:21)
      ! at Timer.listOnTimeout [as ontimeout] (timers.js:110:15)
      ! npm install iobroker.admin –production --silent --prefix "/opt/iobroker/node_modules/iobroker/lib/../../../"
      ! Write "./iobroker start" to start the ioBroker
      ! Non-critical error: ENOENT, no such file or directory '/opt/iobroker/node_modules/iobroker/lib/../../iobroker.js-controller/iobroker'
      ! iobroker@0.5.1 node_modules/iobroker
      ! └── yargs@1.2.6 (minimist@0.1.0)
      ! root@bananapi:
      Resultat:
      root@bananapi:/opt/iobroker#  ./iobroker start
      module.js:340
          throw err;
      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
          at Function.Module._resolveFilename (module.js:338:15)
          at Function.Module._load (module.js:280:25)
          at Function.Module.runMain (module.js:497:10)
          at startup (node.js:119:16)
          at node.js:901:3
      in /node_modules/ fehlen sämtliche verzeichnisse ausser /iobroker.admin und /iobroker
        Hast du du Karte getauscht?
        Gesendet von meinem Cynus T7 mit Tapatalk
          @Homoran:
          Hast du du Karte getauscht? `
          nicht direkt, ich hatte vorher Debian auf der Festplatte aber nun habe ich beides SD und HDD getestet. Aber OK ich kann auch noch eine frische SD-Karte testen.
            Mal langsam,
            -Bananapi,
            -igors image
            -HDD
            /root/hdinstall.sh ausgeführt?
            Nodejs installiert?
            mkdir /opt/iobroker?
            cd /opt/iobroker?
            npm install iobroker?
            …und dann die Fehlermeldung?
              ok, der Reihe nach. iobroker lief ja bereits auf dem bananapi mit hdd. dann habe ich aus bestimmten Gründen neu aufgesetzt,
              igor neu auf sd-karte geflasht, und neu auf hdd installiert (heisst neu: nand-sata-install.sh), dann gem. Handbuch weiter
              update/upgrade
              nodejs
              mkdir /opt/iobroker
              cd /opt/iobroker
              (wie oben eingefügt)
              dann dasselbe testweise nochmals aber ohne hdd, nur auf der sd-karte, aber mit demselben Resultat.
              ich greife nur über putty zu, aber das ist hier wohl ohne belang.
              Bis jetzt habe ich (wie Du wohl auch) schon unzählige male debian, iobroker etc aufgesetzt, aber noch nie gabs solche Probleme. irgendwas hat sich verändert, aber was?
              Etwas fällt auf: die Installation ist nicht vollständig. Ich habe grad eben die Verzeichnisse von einer laufenden Installation auf den Bananapi über die unvollständige Installation kopiert, und nun kann ich schon mal auf ip:8081 zugreifen.
                Ich fürchte dann läuft ggf. etwas mit npm schief.
                Da habe ich keine Ahnung und Bluefox ist in Urlaub.
                Ich liege mit Lungenentzündung im Bett. Vielleicht schaffe ich es n den nächsten Tagen das mal selbst mit den aktuellen Gegebenheiten zu testen.
                Es gibt einen vergleichbaren Thread auf den cubietruck
                Rainer
                  smiling_Jack last edited by
                  Ich habe gerade die selben Probleme unter lubuntu mit node 12.1 😮
                  edit: ich habe es jetzt ersmal wieder mit:
                  sudo npm cache clean
                  sudo npm install iobroker.js-controller@0.5.15
                  gemacht. So kann man sich erstmal behälfen. Ich kann da grade leider nichts dran machen
                    danke an alle. git clone läuft irgendwie auch nicht, bzw. ich mach da wohl was falsch.
                    und das workaround läuft hier leider auch nicht durch. aber macht nichts, dann warten wir eben, bis der grosse Meister wieder zurück ist. er hat seinen Urlaub mehr als verdient … 😄
                      Ich habe es erst auch nicht hinbekommen.
                      Aber wenn smiling-jack sagt, dass es geht…
                      Also:
                      Gemäß Anleitung deinstallieren
                      Dann npm cache clean
                      Dann npm install iobroker.js-controller@0.5.15
                      Jetzt kommen die alten Pfade wieder!
                      cd /opt/iobroker/node_modules/iobroker.js-controller.
                      Dann chmod +x iobroker
                      Zuletzt ./iobroker restart
                      Dann läuft es.
                      Aber ich halte es nur für ein Provisorium.
                      Ich weiss nicht ob der autostart implementiert ist. Auf jeden Fall ist der symlink auf iobroker in /opt/iobroker nicht vorhanden.
                      Ob das durch updates später korrigiert wird, wage ich zu bezweifeln.
                      Ich würde diese Installation nur nutzen wenn ich bereit bin sie wieder platt zu machen
                      Rainer
                      PS ich hoffe, dass alles richtig getippt ist und die mini handytastatur da nicht mist daraus gemacht hat.
                        akamia last edited by
                        Hallo Rainer,
                        danke Dir für die Anleitung. Funktioniert einwandfrei. Jetzt kann ich mich der MQTT-"Forschung" weiter widmen. Ein Update auf "js-controller" von 0.5.15 auf 0.6 verkneife ich mir auf jeden Fall.
                        akamia
                          Das solltest du (und alle anderen) dir auch verkneifen!
                          Es wird angeboten, läuft auch irgendwie, aber dann stürzt der Adapter admin andauernd ab.
                          Dann viel Spaß bei mqtt
                          Rainer
                          • derAuge
                            derAuge last edited by
                            nachdem nun bei mit einige Testinstallationen "zerschossen" sind habe ich eine neue VM aufgesetzt
                            nach der installation von nodejs
                            root@VMioBrokerMaster:~# node -v
                            v0.10.38
                            kommt
                            root@VMioBrokerMaster:~# npm install iobroker
                            > iobroker@0.5.1 install /root/node_modules/iobroker
                            > node lib/setup.js
                            npm install iobroker.js-controller --production --silent --prefix "/root/node_modules/iobroker/lib/../../../"
                            /root/node_modules/iobroker.js-controller/lib/tools.js:452
                                at Object.getAdapterDir (/root/node_modules/iobroker.js-controller/lib/tools.js:452:17)
                                at uploadAdapter (/root/node_modules/iobroker.js-controller/lib/setup.js:1615:28)
                                at installAdapter (/root/node_modules/iobroker.js-controller/lib/setup.js:2054:9)
                                at Socket. <anonymous>(/root/node_modules/iobroker.js-controller/lib/setup.js:2080:13)
                                at Socket.onack (/root/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:294:6)
                                at Socket.onpacket (/root/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:219:12)
                                at Manager. <anonymous>(/root/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                                at Manager.Emitter.emit (/root/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
                                at Manager.ondecoded (/root/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:274:8)
                                at Decoder. <anonymous>(/root/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                            npm install iobroker.admin --production --silent --prefix "/root/node_modules/iobroker/lib/../../../"
                            Non-critical error: ENOENT, no such file or directory '/root/node_modules/iobroker/lib/../../iobroker.js-controller/iobroker'
                            root@VMioBrokerMaster:~#</anonymous></anonymous></anonymous>
                            auch der beschriebene WorkAround klappt nicht ganz
                            der js.controller kann zwar gestartet werden
                            jedoch läuft io.admin nicht. somit auch keine Möglichkeit aid das UI zuzugreifen
                            root@VMioBrokerMaster:~# cd /opt/iobroker/node_modules/iobroker.js-controller
                            root@VMioBrokerMaster:/opt/iobroker/node_modules/iobroker.js-controller# ./iobroker restart
                            Stopping ioBroker controller daemon...
                            ioBroker controller daemon stopped.
                            Starting ioBroker controller daemon...
                            ioBroker controller daemon started. PID: 2686
                            root@VMioBrokerMaster:/opt/iobroker/node_modules/iobroker.js-controller# ps -A |grep io
                                 6 ?        00:00:00 migration/0
                               191 ?        00:00:00 ext4-dio-unwrit
                              1691 ?        00:00:00 rpciod
                              1693 ?        00:00:00 nfsiod
                              2686 ?        00:00:00 io.js-controlle
                            Also heist es nun wohl: Warten bis der Urlauber zurück ist
                              Hast du es so:
                              http://forum.iobroker.org/viewtopic.php?p=3933#p3933
                              Versucht?
                                Hallo
                                ich habe die neue version vom js-controller zurückgezogen
                                Eine Installation sollte wieder ganz normal funktioniren. Wichtig ist ein
                                npm cache clean
                                vorweg zumachen.
                                Zur info es wird jetzt wieder Version 0.5.15 installiert
                                Steffen
                                • derAuge
                                  @smiling-Jack:
                                  Hallo
                                  npm cache clean
                                  vorweg zumachen.
                                  Steffen `
                                  OK. Getestet
                                  root@VMioBrokerMaster:/opt/iobroker# npm cache clean
                                  root@VMioBrokerMaster:/opt/iobroker# npm install iobroker
                                  npm ERR! not a package /tmp/npm-2534-cP-PEs+a/1427660539077-0.291726277442649/tmp.tgz
                                  > node lib/setup.js
                                  npm install iobroker.admin --production --silent --prefix "/opt/iobroker/node_modules/iobroker/lib/../../../"
                                  Auto-start was enabled. Write "update-rc.d -f iobroker.sh remove" to disable auto-start
                                  iobroker is started. Go to "http://ip-addr:8081" to open the admin UI.
                                  root@VMioBrokerMaster:/opt/iobroker# ps -A |grep io
                                     170 ?        00:00:00 ext4-dio-unwrit
                                    1679 ?        00:00:00 rpciod
                                    1681 ?        00:00:00 nfsiod
                                    2641 ?        00:00:00 io.js-controlle
                                  Leider wird admin nicht gestartet.
                                  Manuell kann man auch nicht starten.
                                  root@VMioBrokerMaster:/opt/iobroker# iobroker update
                                  Cannot get version of "virtual".
                                  Cannot get version of "geofency".
                                  update done
                                  Adapter    "zwave"         : 0.1.0
                                  Adapter    "yr"            : 0.1.5
                                  Adapter    "web"           : 0.2.6
                                  Adapter    "vis"           : 0.2.11
                                  Adapter    "virtual"
                                  Adapter    "sonos"         : 0.1.6
                                  Adapter    "rickshaw"      : 0.2.2
                                  Adapter    "pushover"      : 0.1.0
                                  Adapter    "onkyo"         : 0.1.0
                                  Adapter    "telnet"        : 0.0.0
                                  Adapter    "socketio"      : 0.2.3
                                  Adapter    "simple-api"    : 0.0.4
                                  Adapter    "sayit"         : 0.3.6
                                  Adapter    "ping"          : 0.1.3
                                  Adapter    "node-red"      : 0.1.9
                                  Adapter    "mqtt"          : 0.1.7
                                  Adapter    "mobile"        : 0.0.2
                                  Adapter    "legacy"        : 0.1.12
                                  Adapter    "knx"           : 0.0.1
                                  Controller "js-controller" : 0.5.15   , installed 0.5.15
                                  Adapter    "javascript"    : 0.3.0
                                  Adapter    "ical"          : 0.1.0
                                  Adapter    "hmm"           : 0.0.17
                                  Adapter    "hue"           : 0.2.0
                                  Adapter    "hm-rpc"        : 0.4.0
                                  Adapter    "hm-rega"       : 0.2.1
                                  Adapter    "history"       : 0.1.3
                                  Adapter    "highcharts"    : 0.0.0
                                  Adapter    "graphite"      : 0.1.0
                                  Adapter    "geofency"
                                  Adapter    "example"       : 0.1.1    , installed 0.1.1
                                  Adapter    "email"         : 0.1.0
                                  Adapter    "dwd"           : 0.1.7
                                  Adapter    "cul"           : 0.0.2
                                  Adapter    "b-control-em"  : 0.1.1
                                  Adapter    "artnet"        : 0.0.3
                                  Adapter    "admin"         : 0.3.26   , installed 0.3.26
                                  root@VMioBrokerMaster:/opt/iobroker# iobroker start admin
                                  Please enter instance of adapter, e.g. "web.0"
                                  root@VMioBrokerMaster:/opt/iobroker# iobroker start admin.0
                                  Adapter "admin.0 does not exist.
                                    Komish kannst du mal den web einzelt nachinstalliren (npm install iobroker.web )
                                    • derAuge
                                      @smiling-Jack:
                                      Komish kannst du mal den web einzelt nachinstalliren (npm install iobroker.web ) `
                                      keine Änderung
                                      root@VMioBrokerMaster:/opt/iobroker# npm install iobroker.web
                                      npm WARN deprecated object-keys@0.2.0: Please update to the latest object-keys
                                      > ws@0.4.31 install /opt/iobroker/node_modules/iobroker.web/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/engine.io/node_modules/ws
                                      > (node-gyp rebuild 2> builderror.log) || (exit 0)
                                      > ws@0.4.31 install /opt/iobroker/node_modules/iobroker.web/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws
                                      iobroker.web@0.2.6 node_modules/iobroker.web
                                      ├── connect-flash@0.1.1
                                      ├── iobroker.simple-api@0.0.4
                                      ├── passport-local@1.0.0 (passport-strategy@1.0.0)
                                      ├── cookie-parser@1.3.4 (cookie@0.1.2, cookie-signature@1.0.6)
                                      ├── passport@0.2.1 (pause@0.0.1, passport-strategy@1.0.0)
                                      ├── xtend@2.0.6 (is-object@0.1.2, object-keys@0.2.0)
                                      ├── body-parser@1.5.2 (qs@0.6.6, media-typer@0.2.0, bytes@1.0.0, raw-body@1.3.0, depd@0.4.4, type-is@1.3.2, iconv-lite@0.4.4)
                                      ├── express-session@1.7.6 (utils-merge@1.0.0, cookie@0.1.2, cookie-signature@1.0.4, on-headers@1.0.0, parseurl@1.3.0, buffer-crc32@0.2.3, depd@0.4.4, debug@1.0.4, uid-safe@1.0.1)
                                      ├── express@4.4.5 (parseurl@1.0.1, utils-merge@1.0.0, merge-descriptors@0.0.2, cookie@0.1.2, cookie-signature@1.0.4, escape-html@1.0.1, range-parser@1.0.0, fresh@0.2.2, vary@0.1.0, qs@0.6.6, methods@1.0.1, serve-static@1.2.3, buffer-crc32@0.2.3, path-to-regexp@0.1.2, debug@1.0.2, type-is@1.2.1, accepts@1.0.7, proxy-addr@1.0.1, send@0.4.3)
                                      ├── request@2.38.0 (json-stringify-safe@5.0.0, aws-sign2@0.5.0, forever-agent@0.5.2, oauth-sign@0.3.0, stringstream@0.0.4, tunnel-agent@0.4.0, qs@0.6.6, node-uuid@1.4.3, mime-types@1.0.2, tough-cookie@0.12.1, http-signature@0.10.1, form-data@0.1.4, hawk@1.1.1)
                                      └── iobroker.socketio@0.2.3 (request@2.51.0, socket.io@1.1.0)
                                         204 ?        00:00:00 ext4-dio-unwrit
                                        1711 ?        00:00:00 rpciod
                                        1713 ?        00:00:00 nfsiod
                                      root@VMioBrokerMaster:/opt/iobroker# iobroker restart
                                      ioBroker controller daemon is not running
                                      ioBroker controller daemon started. PID: 2596
                                        2596 ?        00:00:00 io.js-controlle
                                        nur zur Info, der workaround funktioniert nun grösstenteils.
                                        ausser hm-rega - lässt sich nicht als instanz installieren. auch nicht bei manueller neu-installation (npm install iobroker.hm-rega)
                                        vielleicht wäre grundsätzlich eine npm-repo (heisst das hier auch so?) mit der Vor-Version nicht schlecht - oder sonst eine Möglichkeit, Vor-Versionen zu installieren.
                                        Wie auch immer , habe mich auf warten eingestellt.
                                          gibts news - läuft die Installation wieder?
                                          • Bluefox
                                            Bluefox last edited by
                                            Also. Ich will immer noch nicht auf npm hoch legen, bis ich eine Bestätigung bekomme, dass es noch bei jemandem geht.
                                            Es gibt aktuelle ioBroker.js-controller version 0.6.1. Die kann man mit
                                            npm install https://github.com/ioBroker/ioBroker.js-controller/tarball/master
                                            installieren.
                                            Für die Neuinstallation, dann:
                                            Kann jemand ausprobieren? Ich habe Windows, Debian und Ubuntu getestet. Update und Neuinstallation. Node.js 0.10.29/0.10.35/0.12.2
                                            16367
