    4. Bitte Hilfe Harmony Hub
    UNSOLVED Bitte Hilfe Harmony Hub
      Bockwurst19 last edited by
      Habe seit gestern probleme mit IoBroker und Harmony Hub.
      [definition='20','0']Alexa[/definition] sagt zu befehle ok aber hab regiert leider nicht darauf . Hier mal meine Log von IoBroker
      2019-02-19 16:06:45.979 - info: alexa2.0 Device-type:A2C8J6UHV0KFCV (PEONY,VOLUME_SETTING,KINDLE_BOOKS,AMAZON_MUSIC,TIMERS_AND_ALARMS,TUNE_IN,MICROPHONE,DEREGISTER_DEVICE,GOLDFISH,MUSIC_SKILL,CHANGE_NAME,DREAM_TRAINING,AUDIO_PLAYER,AUDIBLE,SLEEP,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,PERSISTENT_CONNECTION,I_HEART_RADIO)
      Danke für Tipps und Hilfe
      MFG
      2019-02-19 16:06:00.501 - info: harmony.0 starting. Version 1.1.5 in /opt/iobroker/node_modules/iobroker.harmony, node: v8.14.1
      2019-02-19 16:06:01.840 - info: harmony.0 [DISCOVER] Discovered Harmony Hub (192.168.1.5) and will try to connect
      2019-02-19 16:06:02.220 - info: host.All-In-One_RasPi instance system.adapter.scenes.0 started with pid 1180
      2019-02-19 16:06:06.230 - info: host.All-In-One_RasPi instance system.adapter.socketio.0 started with pid 1190
      2019-02-19 16:06:07.952 - info: socketio.0 socket.io server listening on port 8084
      2019-02-19 16:06:23.405 - info: vis-google-fonts.0 starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.vis-google-fonts, node: v8.14.1
      2019-02-19 16:06:30.225 - info: host.All-In-One_RasPi instance system.adapter.[definition='84','0']sonoff[/definition].0 started with pid 1210
      2019-02-19 16:06:32.212 - info: [definition='84','0']sonoff[/definition].0 Starting MQTT authenticated server on port 1883
      2019-02-19 16:06:34.226 - info: host.All-In-One_RasPi instance system.adapter.zigbee.0 started with pid 1220
      2019-02-19 16:06:36.632 - info: zigbee.0 Start on port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E1A7E2-if00 with panID 6754 channel 11
      2019-02-19 16:06:38.055 - info: zigbee.0 zigbee-shepherd ready. version: 2.6.3 rev 20180507
      2019-02-19 16:06:38.225 - info: host.All-In-One_RasPi instance system.adapter.alexa2.0 started with pid 1230
      2019-02-19 16:06:39.699 - info: alexa2.0 starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.alexa2, node: v8.14.1
      2019-02-19 16:06:40.289 - info: [definition='84','0']sonoff[/definition].0 Client [DVES_86E1EC] connected with secret 1550588800287_952
      2019-02-19 16:06:40.355 - info: [definition='84','0']sonoff[/definition].0 Client [DVES_07AD17] connected with secret 1550588800351_4684
      2019-02-19 16:06:40.586 - info: [definition='84','0']sonoff[/definition].0 Client [DVES_580B35] connected with secret 1550588800585_984
      2019-02-19 16:06:40.756 - info: [definition='84','0']sonoff[/definition].0 Client [DVES_1166D8] connected with secret 1550588800755_2951
      2019-02-19 16:06:40.822 - info: [definition='84','0']sonoff[/definition].0 Client [DVES_578B9090] connected with secret 1550588800820_48
      2019-02-19 16:06:42.226 - info: host.All-In-One_RasPi instance system.adapter.iot.0 started with pid 1240
      2019-02-19 16:06:45.768 - info: iot.0 starting. Version 0.4.0 in /opt/iobroker/node_modules/iobroker.iot, node: v8.14.1
      2019-02-19 16:06:45.978 - info: alexa2.0 Disabling some commands for device because of unknown type. Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
      2019-02-19 16:06:49.769 - error: iot.0 [GHOME] Cannot report device state: null
      2019-02-19 16:06:52.729 - info: [definition='84','0']sonoff[/definition].0 Client [DVES_84248D] connection closed: closed
      2019-02-19 16:08:04.550 - info: [definition='84','0']sonoff[/definition].0 Client [DVES_84248D] connection closed: closed
      2019-02-19 16:08:18.594 - info: harmony.0 hub busy, stateChange delayed: harmony.0.Harmony_Hub.LG_50PK550.PowerOn=1
      2019-02-19 16:08:18.602 - warn: harmony.0 error sending command, client offline
      2019-02-19 16:08:18.696 - warn: harmony.0 error sending command, client offline
      2019-02-19 16:08:19.587 - info: harmony.0 hub busy, stateChange delayed: harmony.0.Harmony_Hub.Vu+-DVR.Select=1
      2019-02-19 16:08:19.595 - warn: harmony.0 error sending command, client offline
      2019-02-19 16:09:15.304 - info: [definition='84','0']sonoff[/definition].0 Client [DVES_84248D] connected with secret 1550588955303_3508
      2019-02-19 16:10:16.877 - info: [definition='84','0']sonoff[/definition].0 Client [DVES_84248D] connected with secret 1550589016875_2608
      • Bertilax
        Bertilax last edited by
        Suche benutzen 😉
        https://forum.iobroker.net/topic/20082/und-wieder-einmal-harmony-firmware-4-15-250
          Michaelnorge last edited by
          Hatte letztes Wochenende alle Infrarotbefehle vom Broadlink Adapter zum Harmony Adapter umprogrammiert (Broadlink macht bei mir Abweichungen beim Speichern von IR-Signale) und war froh, daß alles lief... genau ein Tag!
          Denn seit gestern steht das Objekt "hubConnected" auf "false".
          Komisch nur, das der Adapter sich nicht beschwert, sogar die Instanz zeigt "grün".
          Der Adapter versucht zu connecten, bekommt aber keine Antwort und verstummt...
          2019-02-19 16:54:30.343 - info: harmony.0 States connected to redis: 127.0.0.1:6379
          2019-02-19 16:54:30.498 - info: harmony.0 starting. Version 1.1.5 in /opt/iobroker/node_modules/iobroker.harmony, node: v8.11.1
          2019-02-19 16:54:30.526 - info: harmony.0 [DISCOVER] Searching for Harmony Hubs on 255.255.255.255
          2019-02-19 16:54:31.769 - info: harmony.0 [DISCOVER] Discovered Harmony Hub (192.168.178.138) and will try to connect
          2019-02-19 16:54:31.857 - info: harmony.0 [CONNECT] Connecting to Harmony Hub (192.168.178.138)
          Komisch.... haben die bei Harmony wieder heimlich ein Update draufgespielt??
          Bertilax 1 Reply Last reply Reply Quote 0
          • Bertilax
            Bertilax @Michaelnorge last edited by
            @Michaelnorge https://forum.iobroker.net/topic/20082/und-wieder-einmal-harmony-firmware-4-15-250
              harmony.0 2019-02-19 18:16:29.588 warn could not connect to Harmony Hub: Error: Timed out after 5000 ms
              alexa2.0 2019-02-19 18:16:27.218 info Deleting the following states: ["Smart-Home-Devices.e8cdd115-d5fe-4e12-b79b-923c149dedb7","Smart-Home-Devices.e8cdd115-d5fe-4e12-b79b-923c149dedb7.#delete","Smart-Home-Devices.e8cdd115-d5fe-4e12-b79b-
              harmony.0 2019-02-19 18:16:22.555 info connecting to Harmony Hub
              harmony.0 2019-02-19 18:16:22.551 info discovered Harmony Hub
              harmony.0 2019-02-19 18:16:21.268 info searching for Harmony Hubs...
              harmony.0 2019-02-19 18:16:21.230 info starting. Version 0.9.3 in /opt/iobroker/node_modules/iobroker.harmony, node: v8.14.1
              • dslraser
                dslraser Forum Testing Most Active @Bockwurst19 last edited by dslraser
                @Bockwurst19
                Die Lösung mit Verweis auf einen Beitrag steht hier schon zwei mal drinn...(z.B. ein Beitrag über Deinem)
                einfach hier lesen😉
                  Bin auf 0.9.3 aber jetzt kommt dieser Fehler 🙂
                  dslraser Homoran 2 Replies Last reply Reply Quote 0
                  • dslraser
                    @Bockwurst19
                    XMPP aktiviert ?
                      Homoran Global Moderator Administrators @Bockwurst19 last edited by
                      @Bockwurst19
                      Und xmpp ist aktiv?
                        Könnte einer sage was ich auf der App klicken muss damit ic zu XMPP komme. drücke schon ganze zeit durch finde aber nix 🙂
                        • dslraser
                          @Bockwurst19
                          stand auch im anderen Beitrag, aber egal...
                          unterm Bild steht es.
                            Vielen Lieben Dank euch 🙂
                              Also Harmony funktioniert wieder wenn Ich direkt über Pfad Objekte schalte.
                              Aber meine Szenen schalten nicht. Kann es sein das jetzt der Dateipfad wieder anders ist .
                              Weiss das Ich vor 3 monate so alle Pfade neu eingeben musste wegen Punkt und Leerzeichen in der Pfaddatei bei der Szene.
                              Ist das jetzt wieder der Fall 😞
                              Habe über 100 Szenen mit mehrere Pfade für Harmony 🙂
                              MFG
                                MartyBr last edited by
                                Ich kann Harmony nicht auf die 0.93 downgraden: es kommen immer wieder Fehler:
                                iobroker	2019-02-20 07:02:11.447	info	exit 0
                                iobroker	2019-02-20 07:02:11.443	info	Adapter "harmony" updated
                                iobroker	2019-02-20 07:02:11.388	info	upload [0] harmony.admin /opt/iobroker/node_modules/iobroker.harmony/admin/harmony.png harmony.png image/png
                                iobroker	2019-02-20 07:02:11.334	info	upload [1] harmony.admin /opt/iobroker/node_modules/iobroker.harmony/admin/index.html index.html text/html
                                iobroker	2019-02-20 07:02:11.280	info	upload [2] harmony.admin /opt/iobroker/node_modules/iobroker.harmony/admin/index_m.html index_m.html text/html
                                iobroker	2019-02-20 07:02:11.224	info	upload [3] harmony.admin /opt/iobroker/node_modules/iobroker.harmony/admin/words.js words.js application/javascript
                                iobroker	2019-02-20 07:02:11.199	info	got /opt/iobroker/node_modules/iobroker.harmony/admin
                                iobroker	2019-02-20 07:02:11.152	info	created a lockfile as package-lock.json. You should commit this file.
                                iobroker	2019-02-20 07:02:11.152	info	npm notice
                                iobroker	2019-02-20 07:02:04.122	info	npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.harmony"
                                iobroker	2019-02-20 07:02:04.114	info	npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2019-02-20T06_02_04_106Z-debug.log
                                iobroker	2019-02-20 07:02:04.113	info
                                iobroker	2019-02-20 07:02:04.105	info	npm ERR! enoent
                                iobroker	2019-02-20 07:02:04.105	info	npm ERR! enoent This is related to npm not being able to find a file.
                                iobroker	2019-02-20 07:02:04.105	info	npm ERR! enoent spawn git ENOENT
                                iobroker	2019-02-20 07:02:04.105	info	enoent npm ERR! enoent
                                iobroker	2019-02-20 07:02:04.104	info	npm ERR!
                                iobroker	2019-02-20 07:02:04.104	info	ERR! enoent Error while executing:npm ERR! enoent undefined ls-remote -h -t https://github.com/swissmanu/ltx.git
                                iobroker	2019-02-20 07:02:04.103	info	npm
                                iobroker	2019-02-20 07:02:04.103	info	npm ERR! syscall spawn git
                                iobroker	2019-02-20 07:02:04.103	info	npm ERR! errno ENOENT
                                iobroker	2019-02-20 07:02:04.103	info	path gitnpm ERR! code ENOENT
                                iobroker	2019-02-20 07:02:04.102	info	npm ERR!
                                iobroker	2019-02-20 07:02:03.093	info	deprecated node-xmpp-stanza@1.1.0: use @xmpp/xml package <https://www.npmjs.com/package/@xmpp/xml>
                                iobroker	2019-02-20 07:02:03.093	info	npm WARN
                                iobroker	2019-02-20 07:01:56.967	info	npm install iobroker.harmony@0.9.3 --production --save --prefix "/opt/iobroker" (System call)
                                iobroker	2019-02-20 07:01:56.811	info	NPM version: 6.7.0
                                iobroker	2019-02-20 07:01:56.656	info	Update harmony from @1.2.0 to @0.9.3
                                Ich hatte vorher die 1.15 in Betrieb, auch diese konnte ich nicht downgraden.
                                Kann mir Jemand helfen? Oder kommt bald ein Update?
                                Martin
                                1.3k
                                81.1k
                                bitte hilfe harmony hub
                                960
