    4. [gelöst] Backitup Adapter spielt keine Sicherung ein
    SOLVED [gelöst] Backitup Adapter spielt keine Sicherung ein
    • simatec
      simatec Developer Most Active @Mc23 last edited by
      @Mc23
      Nach der Auswahl des Wiederherstellungstyps erst speichern der Config
        Mc23 last edited by
        Ok dann ist das schon mal abgehakt.
          Mc23 last edited by
          So hier der log wenn ich Wiederherstellung machen will
          2019-02-18 21:57:18.705 - error: backitup.0 uncaught exception: log is not defined
          2019-02-18 21:57:18.705 - error: backitup.0 ReferenceError: log is not defined
          at child_process.exec (/opt/iobroker/node_modules/iobroker.backitup/lib/restore.js:71:13)
          at ChildProcess.exithandler (child_process.js:268:7)
          at emitTwo (events.js:126:13)
          at ChildProcess.emit (events.js:214:7)
          at maybeClose (internal/child_process.js:915:16)
          at Socket.stream.socket.on (internal/child_process.js:336:11)
          at emitOne (events.js:116:13)
          at Socket.emit (events.js:211:7)
          at Pipe._handle.close [as _onclose] (net.js:561:12)
          2019-02-18 21:57:19.211 - info: backitup.0 terminating
          2019-02-18 21:57:19.225 - error: Caught by controller[0]: ReferenceError: log is not defined
          2019-02-18 21:57:19.226 - error: Caught by controller[0]: at child_process.exec (/opt/iobroker/node_modules/iobroker.backitup/lib/restore.js:71:13)
          2019-02-18 21:57:19.226 - error: Caught by controller[0]: at ChildProcess.exithandler (child_process.js:268:7)
          2019-02-18 21:57:19.226 - error: Caught by controller[0]: at emitTwo (events.js:126:13)
          2019-02-18 21:57:19.226 - error: Caught by controller[0]: at ChildProcess.emit (events.js:214:7)
          2019-02-18 21:57:19.226 - error: Caught by controller[0]: at maybeClose (internal/child_process.js:915:16)
          2019-02-18 21:57:19.226 - error: Caught by controller[0]: at Socket.stream.socket.on (internal/child_process.js:336:11)
          2019-02-18 21:57:19.226 - error: Caught by controller[0]: at emitOne (events.js:116:13)
          2019-02-18 21:57:19.226 - error: Caught by controller[0]: at Socket.emit (events.js:211:7)
          2019-02-18 21:57:19.226 - error: Caught by controller[0]: at Pipe._handle.close [as _onclose] (net.js:561:12)
          2019-02-18 21:57:19.226 - error: host.debianiobroker instance system.adapter.backitup.0 terminated with code 0 (OK)```
          • simatec
            @Mc23
            Ahhh ich habe dein Problem gefunden ...
            Installiere mal die Version 1.1.2 aus dem Github.
            Da wurde der Fehler bereits behoben.
            Unter dem Tab Adapter auf den Button oben mit der Katze gehen und dort in der Liste Backitup auswählen.
            Danach noch mit dem Pfeil nach oben Button ein Upload und backitup neu starten.
            Dann ist der Fehler weg.
              Mc23 last edited by
              Super vielen Dank für deine Hilfe
              • simatec
                @Mc23
                Hat es funktioniert nach dem Update auf 1.1.2?
                  Mc23 last edited by
                  Leider nicht jetzt kommt der Fehler
                  2019-02-19 13:56:42.305 - error: backitup.0 Error: Command failed: mount -t cifs -o username=marc,password=******,rw,file_mode=0777,dir_mode=0777 //DISKSTATION/home/iobroker/komplett /opt/iobroker/backups
                  mount error(16): Device or resource busy
                  Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
                  2019-02-19 13:57:06.941 - error: backitup.0 Error: Command failed: mount -t cifs -o username=marc,password=*****,rw,file_mode=0777,dir_mode=0777 //DISKSTATION/home/iobroker/komplett /opt/iobroker/backups
                  • simatec
                    @Mc23
                    Dein Laufwerk ist noch eingehängt.
                    Führe „sudo umount /opt/iobroker/backups“ aus.
                      Mc23 last edited by Mc23
                      @simatec
                      Heisst es "umount" oder fehlt ein N für "unmount"? Dann iobroker neustarten oder so? Oder einfach den Befehl über putty eingeben und dann nochmal probieren?
                        Mc23 last edited by
                        Habe den Befehl ausgeführt und nochmal probiert aber immer noch das gleiche. Restore Fenster geht auf und das wars.
                        • simatec
                          @Mc23
                          Was sagt denn jetzt der Log?
                            Mc23 last edited by
                            Habe gerade nochmal ne andere blöde Frage. Wenn ich ein Backup wieder einspiele von gestern und heute einen neuen Adapter hinzugefügt habe ist der dann wieder weg? Normalerweise ja oder?
                            • simatec
                              Ja dann ist er weg ...
                                Mc23 last edited by
                                Ok dann funktioniert es alles wirklich nicht. Dachte jetzt gerade schon ich hab irgendwie einen Denkfehler. Log kommt gleich.
                                  Mc23 last edited by
                                  Jetzt steht im log gar nix mehr wenn ich eine Wiederherstellung starte nur noch das hier
                                  2019-02-19 22:48:00.114 - info: backitup.0 starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v8.13.0
                                  2019-02-19 22:48:00.149 - info: backitup.0 [minimal] backup was activated at 02:00 every 1 day(s)
                                  2019-02-19 22:48:00.158 - info: backitup.0 [total] backup was activated at 03:00 every 3 day(s)
                                  • simatec
                                    @Mc23
                                    Die Instanz von backitup muss auf debug gestellt werden.
                                      Mc23 last edited by
                                      • simatec
                                        @Mc23
                                        Nein in dem Tab Instanzen den Adapter backitup von info auf debug schalten
                                          Mc23 last edited by
                                          Achso sorry
                                          2019-02-19 23:16:43.824 - debug: backitup.0 objectDB connected
                                          2019-02-19 23:16:43.837 - debug: backitup.0 statesDB connected
                                          2019-02-19 23:16:43.877 - info: backitup.0 starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v8.13.0
                                          2019-02-19 23:16:43.911 - info: backitup.0 [minimal] backup was activated at 02:00 every 1 day(s)
                                          2019-02-19 23:16:43.922 - debug: backitup.0 [minimal] 10 00 02 */1 * *
                                          2019-02-19 23:16:43.922 - info: backitup.0 [total] backup was activated at 03:00 every 3 day(s)
                                          2019-02-19 23:16:43.923 - debug: backitup.0 [total] 10 00 03 */3 * *
                                          2019-02-19 23:16:43.931 - debug: backitup.0 mount activ... umount in 10 Seconds!!
                                          2019-02-19 23:16:47.023 - debug: backitup.0 sendTo "getTelegramUser" to system.adapter.admin.0 from system.adapter.backitup.0: {"721762841":"Marc","761570028":"Fatma"}
                                          2019-02-19 23:16:56.985 - debug: backitup.0 sendTo "list" to system.adapter.admin.0 from system.adapter.backitup.0
                                          2019-02-19 23:17:12.902 - debug: backitup.0 sendTo "restore" to system.adapter.admin.0 from system.adapter.backitup.0```
                                          • simatec
                                            @Mc23
                                            Das ist der Start von backitup... da gibt es keinen Fehler.
                                            Wie ist der Log bei einem Restore?
                                            Da liegt doch dein Problem oder?
                                            backitup
                                            5571
