    4. ZWAVE adapter funkt auf BEELINK Gemini X nicht
    UNSOLVED ZWAVE adapter funkt auf BEELINK Gemini X nicht
      geka79 last edited by
      Hallo
      Ich bräuchte Eure Hilfe.
      Bin von RPI3 auf BEELINK Gemini x umgestiegen.
      Der ZWAVE Adapter startet nach einem Neustart leider nicht.
      Hab den Adapter schon manuell installiert, dann läuft er.
      Jem eine Idee?
      Gerhard
      Fehlermeldung:
      undefined2019-02-20 17:51:11.437 - info: host.geka-Gemini-X instance system.adapter.zwave.0 started with pid 3567
      2019-02-20 17:51:11.935 - info: zwave.0 starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.zwave, node: v8.15.0
      2019-02-20 17:51:12.006 - error: zwave.0 uncaught exception: libopenzwave.so.1.4: cannot open shared object file: No such file or directory
      2019-02-20 17:51:12.007 - error: zwave.0 Error: libopenzwave.so.1.4: cannot open shared object file: No such file or directory
      at Object.Module._extensions..node (module.js:682:18)
      at Module.load (module.js:566:32)
      at tryModuleLoad (module.js:506:12)
      at Function.Module._load (module.js:498:3)
      at Module.require (module.js:597:17)
      at require (internal/module.js:11:18)
      at Object. (/opt/iobroker/node_modules/openzwave-shared/lib/openzwave-shared.js:24:22)
      at Module._compile (module.js:653:30)
      at Object.Module._extensions..js (module.js:664:10)
      2019-02-20 17:51:12.014 - info: zwave.0 terminating
      2019-02-20 17:51:12.025 - error: Caught by controller[0]: Error: libopenzwave.so.1.4: cannot open shared object file: No such file or directory
      2019-02-20 17:51:12.026 - error: Caught by controller[0]: at Object.Module._extensions..node (module.js:682:18)
      2019-02-20 17:51:12.026 - error: Caught by controller[0]: at Module.load (module.js:566:32)
      2019-02-20 17:51:12.026 - error: Caught by controller[0]: at tryModuleLoad (module.js:506:12)
      2019-02-20 17:51:12.026 - error: Caught by controller[0]: at Function.Module._load (module.js:498:3)
      2019-02-20 17:51:12.026 - error: Caught by controller[0]: at Module.require (module.js:597:17)
      2019-02-20 17:51:12.026 - error: Caught by controller[0]: at require (internal/module.js:11:18)
      2019-02-20 17:51:12.026 - error: Caught by controller[0]: at Object. (/opt/iobroker/node_modules/openzwave-shared/lib/openzwave-shared.js:24:22)
      2019-02-20 17:51:12.026 - error: Caught by controller[0]: at Module._compile (module.js:653:30)
      2019-02-20 17:51:12.026 - error: Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
      2019-02-20 17:51:12.026 - error: host.geka-Gemini-X instance system.adapter.zwave.0 terminated with code 0 (OK)
      2019-02-20 17:51:12.026 - info: host.geka-Gemini-X Restart adapter system.adapter.zwave.0 because enabled
        gelöst nach kompletter Neuinstallation mit Hilfe von Beitrag:
        https://forum.iobroker.net/topic/6607/gelöst-problem-mit-der-installation-des-zwave-adapters/7
        kann ich dass irgendwie automatisieren?
        muss bei jeden Neustart gemacht werde. 😞
        1.2k
        81.1k
        zwave adapter
