    4. [Tutorial] VIS Fritzbox Status & Up/Downloadanzeige
      schittl last edited by
      Kleines Problem. Seid ca. Update der FritzBox auf Version 7.01 bekomme ichbeim Ausführen folgender Zeilen lt Tutorial:
          setState('upnp.0.FRITZ!Boxxxxx.WANDevice.WANCommonInterfaceConfig.GetAddonInfos','send');
          setState('upnp.0.FRITZ!Boxxxxx.WANDevice.WANCommonInterfaceConfig.GetCommonLinkProperties','send');
          setState('upnp.0.FRITZ!Boxxxxx.WANDevice.WANConnectionDevice.WANIPConnection.GetExternalIPAddress','send');
          setState('upnp.0.FRITZ!Boxxxxx.WANDevice.WANConnectionDevice.WANIPConnection.GetStatusInfo','send');
      folgende Fehler:
      ! host.rock64 2019-01-22 16:16:07.732 error instance system.adapter.upnp.0 terminated with code 0 (OK)
      ! Caught 2019-01-22 16:16:07.731 error by controller[0]: at WebSocket.ws.onmessage (/opt/iobroker/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/websocket.js:147:10)
      ! Caught 2019-01-22 16:16:07.730 error by controller[0]: at WS.Transport.onData (/opt/iobroker/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:137:8)
      ! Caught 2019-01-22 16:16:07.730 error by controller[0]: at WS.Transport.onPacket (/opt/iobroker/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:145:8)
      ! Caught 2019-01-22 16:16:07.729 error by controller[0]: at WS.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      ! Caught 2019-01-22 16:16:07.729 error by controller[0]: at WS. <anonymous>(/opt/iobroker/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:273:10)
      ! Caught 2019-01-22 16:16:07.728 error by controller[0]: at Socket.onPacket (/opt/iobroker/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:456:14)
      ! Caught 2019-01-22 16:16:07.728 error by controller[0]: at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      ! Caught 2019-01-22 16:16:07.727 error by controller[0]: at Socket. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
      ! Caught 2019-01-22 16:16:07.727 error by controller[0]: at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:335:16)
      ! Caught 2019-01-22 16:16:07.726 error by controller[0]: at Decoder.add (/opt/iobroker/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:251:12)
      ! Caught 2019-01-22 16:16:07.724 error by controller[0]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      ! Caught 2019-01-22 16:16:07.723 error by controller[0]: at Decoder. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
      ! Caught 2019-01-22 16:16:07.722 error by controller[0]: at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:345:8)
      ! Caught 2019-01-22 16:16:07.722 error by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      ! Caught 2019-01-22 16:16:07.721 error by controller[0]: at Manager. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
      ! Caught 2019-01-22 16:16:07.721 error by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:244:12)
      ! Caught 2019-01-22 16:16:07.720 error by controller[0]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:319:9)
      ! Caught 2019-01-22 16:16:07.718 error by controller[0]: at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.upnp/main.js:1703:47)
      ! Caught 2019-01-22 16:16:07.703 error by controller[0]: TypeError: Cannot read property 'native' of null
      ! upnp.0 2019-01-22 16:16:07.607 info terminating
      ! upnp.0 2019-01-22 16:16:07.445 info cleaned everything up…
      ! upnp.0 2019-01-22 16:16:07.444 info Alive and sid states cleared
      ! upnp.0 2019-01-22 16:16:07.434 error at WebSocket.ws.onmessage (/opt/iobroker/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/websocket.js:147:10)
      ! upnp.0 2019-01-22 16:16:07.434 error at WS.Transport.onData (/opt/iobroker/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:137:8)
      ! upnp.0 2019-01-22 16:16:07.434 error at WS.Transport.onPacket (/opt/iobroker/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:145:8)
      ! upnp.0 2019-01-22 16:16:07.434 error at WS.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      ! upnp.0 2019-01-22 16:16:07.434 error at WS. <anonymous>(/opt/iobroker/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:273:10)
      ! upnp.0 2019-01-22 16:16:07.434 error at Socket.onPacket (/opt/iobroker/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:456:14)
      ! upnp.0 2019-01-22 16:16:07.434 error at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      ! upnp.0 2019-01-22 16:16:07.434 error at Socket. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
      ! upnp.0 2019-01-22 16:16:07.434 error at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:335:16)
      ! upnp.0 2019-01-22 16:16:07.434 error at Decoder.add (/opt/iobroker/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:251:12)
      ! upnp.0 2019-01-22 16:16:07.434 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      ! upnp.0 2019-01-22 16:16:07.434 error at Decoder. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
      ! upnp.0 2019-01-22 16:16:07.434 error at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:345:8)
      ! upnp.0 2019-01-22 16:16:07.434 error at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      ! upnp.0 2019-01-22 16:16:07.434 error at Manager. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
      ! upnp.0 2019-01-22 16:16:07.434 error at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:244:12)
      ! upnp.0 2019-01-22 16:16:07.434 error at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:319:9)
      ! upnp.0 2019-01-22 16:16:07.434 error at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.upnp/main.js:1703:47)
      ! upnp.0 2019-01-22 16:16:07.434 error TypeError: Cannot read property 'native' of null
      ! upnp.0 2019-01-22 16:16:07.416 error uncaught exception: Cannot read property 'native' of null
      ! javascript.0 2019-01-22 16:16:06.101 info script.js.XSkripte.FritzBox: registered 7 subscriptions and 2 schedules</anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous>
      Kann mir eventuell jemand helfen? Bzw. was ist die Ursache? UpNp benutze ich in Version 0.3.9.
      vg
      Falk
        JavaMafia last edited by
        das TUT ist super es klappt auch alles bei mir, nur leider nicht die Umrechnung der Download Today.
        Laut der Statistik meine FB sollen das für heute 18954 MB sein. Nach dem Script sind es ab nur etwas mit 3400 MB.
        Habe auch schon die anderen Umrechnungsfaktoren versuche die hier gepostet wurden, im Netz bin ich auch nicht fündig geworden.
        Der NewUptime Eintrag denke ich ist der Zeitstempel, seid wann die FB die Verbindung hat, sehe ich das richtig. Wenn das so ist würde ich dies gerne umrechnen.
          lars10 last edited by
          Betreffs der falschen Anzeige des Download Today Volumens kann ich mich nur anschließen...
          • opossum
            opossum last edited by
            danke für das DIY. Hat bei mir lange gedauert, bis es funktionierte. Es lag bei mir einfach an meinem Script:
            original steht da drin:
            … upnp.0.FRITZ!Box_7560_(UI) ...
            habe ich dann geändert auf
            upnp.0.FRITZ!Box_7590_(UI)…
            es kamen aber immer noch keine Werte von der Box. Ja, dann noch mal richtig geschaut. Meine Fritzbox ist unter upnp.0 mit Fritz!Box_7590 benannt. Das Script geändert und schon funktionierte es. Kaum macht mans richtig, dann funktionierts.😁
            Egbert
              DerKiLLa last edited by
              Klappt bei mir nicht ...
              UPNP Adapter ist installiert, FritzBox wird gefunden (als
              alt text
              UPNP in der FritzBox ist aktiviert:
              alt text
              Script sieht wie folgt aus:
              schedule("*/10 * * * * *",  function () {
                 setState( "upnp.0.FRITZ!Box_7580_(UI).WANDevice.WANCommonInterfaceConfig.GetAddonInfos",'send');
                 setState( "upnp.0.FRITZ!Box_7580_(UI).WANDevice.WANCommonInterfaceConfig.GetCommonLinkProperties",'send');
                 setState( "upnp.0.FRITZ!Box_7580_(UI).WANDevice.WANConnectionDevice.WANIPConnection.GetExternalIPAddress",'send');
                 setState( "upnp.0.FRITZ!Box_7580_(UI).WANDevice.WANConnectionDevice.WANIPConnection.GetStatusInfo",'send');
              Im Log kommt:
              javascript.0	2019-02-20 11:13:04.209	info	received all objects
              javascript.0	2019-02-20 11:13:03.288	info	received all states
              javascript.0	2019-02-20 11:13:02.634	info	requesting all objects
              javascript.0	2019-02-20 11:13:02.633	info	requesting all states
              javascript.0	2019-02-20 11:13:02.626	info	starting. Version 3.6.5 in C:/iobroker/node_modules/iobroker.javascript, node: v10.15.1
              Es erscheinen aber keine Werte im Objekt ... was mache ich falsch?
                crunchip Forum Testing Most Active @DerKiLLa last edited by
                @DerKiLLa dauert 10 min
                  DerKiLLa last edited by DerKiLLa
                  Ich warte seit gestern 🙂
                  Hab aber anscheinend den Fehler gefunden ... in den Objekten war mein Objekt "Fritz" unter "javascript.0" auf state false. Hab es auf true gesetzt und danach ging es.
                  Also Objekt "scriptEnabled.global.Fritz".
                  Edit: Okay, bringt nicht die erhoffte Wirkung. Er führt das Script dann einmalig aus, aber nicht jede 10 Minuten.
                  Edit2: Geht jetzt, warum auch immer 😄
                    WernerS last edited by
                    Hallo
                    also ich habe die beiden Adapter installiert und UPNP in der Fritzbox aktiviert. Ich habe jetzt bei den Objekten ein FritzBox.0 da sind aber nur Telefondaten drin. Bei UPNP steht gar nichts.
                    Was kann das sein?
                    Werner
                    W A 2 Replies Last reply Reply Quote 0
                      liv-in-sky last edited by liv-in-sky
                      hi - fand das projekt gut
                      wollte das auch einrichten - klappt auch aber leider gibt es ein anderes problem - mein anschluss (ländlich) sieht so aus:
                      nur download:
                      • vertrag 50000
                      • realer anschluss 25000 (wird - warum auch immer - von vodafone gedrosselt)
                      • fritzbox verbindet sich mit 80000
                      somit bekomme ich immer den wert 80000 angezeigt, welcher nicht stimmt - ich nehme an, dass ich somit keine für mich richtige anzeige erstellen kann - oder weiß jmd rat
                        crunchip Forum Testing Most Active @liv-in-sky last edited by
                        @liv-in-sky mein Anschluß ist auch ein 50.000er Leitung
                        Fritzbox zeigt an...max möglich 80.000, abhängig von den Störfaktoren der Leitung
                        Istverbindung unter upnp.0.VIRUS.WANDevice.WANCommonInterfaceConfig.GetCommonLinkProperties.NewLayer1DownstreamMaxBitRate
                        bei mir 61.800, was auch den Wert der Fritzbox wieder spiegelt
                          @crunchip
                          ich habe kein ...g.GetCommonLinkProperties.NewLayer1DownstreamMaxBitRate
                          muss ich da im script was dazufügen ?
                          crunchip G 2 Replies Last reply Reply Quote 0
                            crunchip Forum Testing Most Active @liv-in-sky last edited by crunchip
                            @liv-in-sky nein, eigentlich nicht
                              Also ich habe es so gemacht mit upnp Adapter:
                              Views noch nicht fertig.
                              S D 2 Replies Last reply Reply Quote 0
                                @crunchip
                                ich bin heut wohl etwas verwirrt - natürlich habe ich diese datenpunkte - aber diese zeigen eben die rein möglichen werte an - nicht das tatsächliche ! mehr wie 25000 geht bei mir nicht - es gibt ja noch das dsl speed script - dann muss ich eben das verwenden - da kommt nämlich die richtige bzw. momentan mögliche speed an.
                                  sigi234 Forum Testing Most Active @liv-in-sky last edited by
                                  @liv-in-sky sagte in [Tutorial] VIS Fritzbox Status & Up/Downloadanzeige:
                                  @crunchip
                                  Also ich hole mir die Daten von hier:
                                    @sigi234
                                    hi sigi - fantastisch wie immer - würdest du mir verraten , wie du die pfeile so sichtbar gemacht hast - im "aktueller datenverkehr" diagramm - ich habe das guage-basic widget genommen
                                    wenn ich das benutze ist der pfeil kaum sichtabar (dreieck) setze ich linie geht es - aber ist "häßlicher" - zeigerfarbe ist aber sher hell gewählt
                                      WernerS @WernerS last edited by
                                      @WernerS said in [Tutorial] VIS Fritzbox Status & Up/Downloadanzeige:
                                      Hallo
                                      Was kann das sein?
                                      Werner
                                      Niemand eine Idee was das sein kann?
                                        @sigi234
                                          @sigi234
                                          ich habe das falsche widget - wie heißt deines
                                            @sigi234
                                            canvas-gauges-radial
                                            504
                                            130479
