    4. Adapter: iobroker.backitup (stable Release)
    • Segway
      Segway last edited by
      auch beim Downgrade gleiches Bild. Hier mal was da alles kam beim install
      Update backitup from @1.1.1 to @1.0.9
      NPM version: 6.4.1
      npm install iobroker.backitup@1.0.9 --production --save --prefix "/opt/iobroker" (System call)
      gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/8.15.0"
      gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/epoll/.node-gyp"
      gyp WARN install got an error, rolling back install
      gyp ERR! configure error
      gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/epoll/.node-gyp'
      gyp ERR! System Linux 4.9.0-8-amd64
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd /opt/iobroker/node_modules/epoll
      gyp ERR! node -v v8.15.0
      gyp ERR! node-gyp -v v3.8.0
      gyp ERR! not ok
      gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/unix-dgram/.node-gyp"
      gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/unix-dgram/.node-gyp'
      gyp ERR! cwd /opt/iobroker/node_modules/unix-dgram
      gyp ERR! not ok
      node-pre-gyp WARN Using request for node-pre-gyp https download
      node-pre-gyp WARN Tried to download(404): https://github.com/tessel/node-usb/releases/download/1.5.0/usb_bindings-v1.5.0-node-v57-linux-x64.tar.gz
      node-pre-gyp WARN Pre-built binaries not found for usb@1.5.0 and node@8.15.0 (node-v57 ABI, glibc) (falling back to source compile with node-gyp)
      gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/usb/.node-gyp"
      gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/usb/.node-gyp'
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/usb/src/binding/usb_bindings.node" "--module_name=usb_bindings" "--module_path=/opt/iobroker/node_modules/usb/src/binding" "--napi_version=3" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v57"
      gyp ERR! cwd /opt/iobroker/node_modules/usb
      gyp ERR! not ok
      node-pre-gyp ERR! build error
      node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/usb/src/binding/usb_bindings.node --module_name=usb_bindings --module_path=/opt/iobroker/node_modules/usb/src/binding --napi_version=3 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v57' (1)
      node-pre-gyp ERR! stack at ChildProcess.<anonymous> (/opt/iobroker/node_modules/usb/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
      node-pre-gyp ERR! stack at emitTwo (events.js:126:13)
      node-pre-gyp ERR! stack at ChildProcess.emit (events.js:214:7)
      node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:915:16)
      node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:209:5)
      node-pre-gyp ERR! System Linux 4.9.0-8-amd64
      node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/usb/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
      node-pre-gyp ERR! cwd /opt/iobroker/node_modules/usb
      node-pre-gyp ERR! node -v v8.15.0
      node-pre-gyp ERR! node-pre-gyp -v v0.11.0
      node-pre-gyp ERR! not ok
      gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/bluetooth-hci-socket/.node-gyp"
      gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/bluetooth-hci-socket/.node-gyp'
      gyp ERR! cwd /opt/iobroker/node_modules/bluetooth-hci-socket
      gyp ERR! not ok
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: epoll@0.1.22 (node_modules/epoll):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: epoll@0.1.22 install: node-gyp rebuild
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 (node_modules/unix-dgram):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 install: node-gyp rebuild
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.5.0 (node_modules/usb):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.5.0 install: node-pre-gyp install --fallback-to-build
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bluetooth-hci-socket@0.5.1 (node_modules/bluetooth-hci-socket):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bluetooth-hci-socket@0.5.1 install: node-gyp rebuild
      npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.backitup"
      npm WARN deprecated gulp-util@3.0.8: gulp-util is deprecated - replace it, following the guidelines at https://medium.com/gulpjs/gulp-util-ca3b1f9f9ac5
      npm WARN deprecated graceful-fs@3.0.11: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
      npm WARN deprecated minimatch@2.0.10: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
      npm WARN deprecated minimatch@0.2.14: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
      npm WARN deprecated graceful-fs@1.2.3: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
      npm notice created a lockfile as package-lock.json. You should commit this file.
      got /opt/iobroker/node_modules/iobroker.backitup/admin
      upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
      Update "system.adapter.backitup.0"
      upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
      upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
      upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
      Adapter "backitup" updated
      • simatec
        Dein Problem liegt definitiv nicht an backitup.
        Hast du js-controller 1.5.7 laufen?
        Dein System hat ein Problem.
        • Segway
          Segway @simatec last edited by
          @simatec
          jscontroller 1.4.2
          BEVOR ich das update gemacht hatte lief hier alles ohne ERROR in den Logs.
          • simatec
            Starte mal komplett neu und mache das Update erneut.
            • Segway
              @simatec sagte in Adapter: iobroker.backitup (stable Release):
              also ich habe downgrade auf 1.0.8 gemacht dann ging es wieder.
              Also dann folgendes gemacht:
              • IoB korrekt gestoppt
              • Host runtergefahren
              • VM runtergefahren
              • wieder gestartet alles OHNE Fehler im LOG
              • auf 1.1.1 upgedatet
              Bisher läufts........das erklär mir mal einer 😒
              • simatec
                Da hing irgendwas an deiner IOB Installation.
                • simatec
                  Ab sofort ist die Version 1.1.2 im Github und ab heute Nacht im latest verfügbar.
                  1.1.2 (21.02.2019)
                  • (simatec) exec Start for iobroker
                  • (simatec) Fix umount before Restore
                  Hier an dieser Stelle auch noch einmal der Hinweis, dass es für den neuen Installerscript von iobroker jetzt einen Fix gibt, für alle, die Probleme mit der Rechtevergabe haben und dadurch backitup und auch andere Adapter nur eingeschränkt nutzen können.
                  1. Wenn euer iobroker System mit dem neuen Installer Script installiert wurde, kann es vorkommen, dass ihr nicht alle Rechte für den neuen User iobroker habt.
                    Dies betrifft dann leider auch backitup, da backitup einige systemrelevante Befehle benutzt.
                    Um das Problem mit fehlenden Rechten zu beheben, gibt es inzwischen einen Fix für den Installerscript von iobroker.
                    Führt bitte folgende Befehle auf eure Iobrokerumgebung in der Konsole aus:
                    curl -sL https://raw.githubusercontent.com/ioBroker/ioBroker/master/fix_installation.sh | bash
                    sudo reboot
                  2. Solltet Ihr eine Fehlermeldung beim erstellen der Redis Datenbank bekommen, prüft bitte, ob euer User iobroker die Rechte hat und ob er in der User-Gruppe Redis vorhanden ist.
                    Wenn dies nicht der Fall ist, könnt ihr das mit folgenden Befehl in der Konsole beheben.
                    sudo usermod -a -G redis iobroker
                    sudo reboot
                    Wenn ihr nicht mit dem Installerscript eure Iobroker Installation aufgesetzt habt und euer User einen anderen Namen hat, bitte in dem Befehl "iobroker" durch euren User ersetzen.
                  • AlCalzone
                    AlCalzone Developer @simatec last edited by
                    Zur Info: Dies sollte nicht die neueste Version von Ende Januar betreffen. Bei ganz alten Installationen, bei denen noch viel mit sudo npm gearbeitet wurde, kann das Fix-Skript auch nötig sein.
                    • simatec
                      simatec Developer Most Active @AlCalzone last edited by
                      @AlCalzone
                      Maximal der Fix, dass der User iobroker der Redis Gruppe hinzugefügt wird sollte mit dem Fix auch die Installationen ab Ende Januar betreffen.
                      Alles andere ist dort bereits im Installerscript gefixt.
                        pix @AlCalzone last edited by
                        @AlCalzone sagte in Adapter: iobroker.backitup (stable Release):
                        Gibt es auch einen Befehl für OS X Terminal? Dort existiert usermod nicht.
                        Pix
                          pix last edited by
                          Etwa so?
                          sudo chown iobroker:redis FILENAME
                          Aber welche Datei?
                          • simatec
                            Unter Linux sieht das wie folgt aus ...
                            @iobroker-dev:~$ sudo ls /var/lib/redis
                            dump.rdb
                            • AlCalzone
                              AlCalzone Developer @pix last edited by
                              @pix sagte in Adapter: iobroker.backitup (stable Release):
                              http://lmgtfy.com/?q=osx+add+user+to+group
                              Auf OSX wird ioBroker derzeit noch unter dem Account des Users ausgeführt, der es installiert hat. Im Zweifel muss also der eigene Account zur Redis-Gruppe hinzugefügt werden.
                                pix last edited by
                                Also kurz zum Nachmachen
                                Terminal Befehle für OS X
                                • Listenpunktredis Datenbank finden
                                mdfind dump.rdb
                                • Den Pfad ohne dump.rdb in den Adapter-Einstellungen unter "Redis Backup" als Pfad eintragen
                                • In das Verzeichnis von dump.rdb wechseln oder Pfad verwenden und den eigenen OS X Benutzernamen der Rechteliste der Redis Datenbank hinzufügen
                                sudo chown osxusername dump.rdb
                                • Dann manuell ein Standard Backup manuell starten und in der Ausgabe müsste sowas erscheinen
                                [DEBUG] [redis] start with {"type":"creator","path":"/Users/pix/"}
                                [DEBUG] [redis] - Packed 66MB so far...
                                [DEBUG] [redis] - Packed 135MB so far...
                                [DEBUG] [redis] - Packed 178MB so far...
                                [DEBUG] [redis] - Packed 218MB so far...
                                [DEBUG] [redis] - Packed 266MB so far...
                                [DEBUG] [redis] - Packed 327MB so far...
                                [DEBUG] [redis] - Packed 377MB so far...
                                [DEBUG] [redis] - Packed 476MB so far...
                                [DEBUG] [redis] - Packed 524MB so far...
                                [DEBUG] [redis] - Packed 577MB so far...
                                Dann klappt's auch wieder mit dem OS X Redis Backup 👍
                                Pix
                                AlCalzone 1 Reply Last reply Reply Quote 2
                                • AlCalzone
                                  Kann danach redis selbst noch darauf zugreifen?
                                    pix last edited by
                                    Denke schon. Konsole sagt
                                    1882:M 21 Feb 18:13:37.503 * Background saving started by pid 90133
                                    90133:C 21 Feb 18:13:37.616 * DB saved on disk
                                    1882:M 21 Feb 18:13:37.705 * Background saving terminated with success
                                      Saschag last edited by
                                      ich habe das Problem das ab und an ☹ das Backup (hier z.B. miniaml) nicht beendet wird. Der Datenpunkt oneclick bleibt auf true stehen.
                                      Wenn ich den Butten im Vis drücke (obwohl das Backup gerade erstellt wird wird) wird das Backup ordnungsgemäß gemacht.
                                      Hat einer eine Idee??
                                      Danke und Grüße
                                      [DEBUG] [minimal] - undefined Error: websocket error    at WS.Transport.onError (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:64:13)    at WebSocket.ws.onerror (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:150:10)    at WebSocket.onError (/opt/iobroker/node_modules/ws/lib/EventTarget.js:109:16)    at emitOne (events.js:116:13)    at WebSocket.emit (events.js:211:7)    at WebSocket.finalize (/opt/iobroker/node_modules/ws/lib/WebSocket.js:182:41)    at emitOne (events.js:116:13)    at Socket.emit (events.js:211:7)    at emitErrorNT (internal/streams/destroy.js:66:8)    at _combinedTickCallback (internal/process/next_tick.js:139:11)
                                      ![Bild Text]Vis.JPG Admin.JPG (Bild Link)
                                      • simatec
                                        Tritt der Fehler sporadisch auf und wenn ja nur beim minimal?
                                          Leider ja. Sporadisch! ☹ bis jetzt nur beim minimal
                                          • simatec
                                            Poste hier mal bitte den Log, wenn es auftritt.
                                            adapter backitup backup iobroker backup iobroker.backitup
                                            185
                                            2335
                                            1198777
