    4. Javascript-Adapter 4.1.2 macht noch Probleme
    UNSOLVED Javascript-Adapter 4.1.2 macht noch Probleme
      PrinzEisenherz1 last edited by PrinzEisenherz1
      Hi zusammen.
      Habe testweise mal mein System ein Update das Javascriptadapters gegönnt und muss leider feststellen das da plötzlich einige meiner Scripte nicht mehr rund laufen.
      Hab mal von Version 3.6.5 auf 4.1.2 geupdated und folgendes ist mir aufgefallen.
      Ausgabe update auf 4.1.2
      $ ./iobroker upgrade javascript
      Update javascript from @3.6.5 to @4.1.2
      NPM version: 6.5.0
      npm install iobroker.javascript@4.1.2 --unsafe-perm --production --save --prefix "/opt/iobroker" (System call)
      npm WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
      npm WARN
       svg-inline-react@1.0.3 requires a peer of react@^0.14.0 || ^15.0.0 but none is installed. You must install peer dependencies yourself.npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.7 (node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"ia32"})
      npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.javascript"
      npm WARN deprecated gulp-util@3.0.8: gulp-util is deprecated - replace it, following the guidelines at https://medium.com/gulpjs/gulp-util-ca3b1f9f9ac5
      npm
      WARN deprecated graceful-fs@3.0.11: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
      npm
      WARN deprecated minimatch@2.0.10: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
      npm WARN deprecated circular-json@0.3.3: CircularJSON is in maintenance only, flatted is its successor.
      npm WARN
      deprecated minimatch@0.2.14: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
      npm WARN deprecated graceful-fs@1.2.3: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
      npm WARN lifecycle iobroker.javascript@4.1.2~postinstall: cannot run in wd iobroker.javascript@4.1.2 node ./install/installTypings.js (wd=/opt/iobroker/node_modules/iobroker.javascript)
      Update "system.adapter.javascript.0"
      Update "system.adapter.javascript.1"Update "system.adapter.javascript.3"
      got /opt/iobroker/node_modules/iobroker.javascript/admin
      upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/razor/razor.js vs/basic-languages/razor/razor.js application/javascript
      upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/msdax/msdax.js vs/basic-languages/msdax/msdax.js application/javascript
      upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/dockerfile/dockerfile.js vs/basic-languages/dockerfile/dockerfile.js application/javascript
      upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/copy-content.770c7d5d.svg static/media/copy-content.770c7d5d.svg image/svg+xml
      upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/precache-manifest.6ed852f7c0b4f4f32b73028311f5b20e.js precache-manifest.6ed852f7c0b4f4f32b73028311f5b20e.js application/javascript
      upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/msg/fr.js google-blockly/own/msg/fr.js application/javascript
      upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/blocks_time.js google-blockly/own/blocks_time.js application/javascript
      upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/msg/js/pl.js google-blockly/msg/js/pl.js application/javascript
      upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/quote0.png google-blockly/media/quote0.png image/png
      upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handopen.cur google-blockly/media/handopen.cur application/octet-stream
      upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handdelete.cur google-blockly/media/handdelete.cur application/octet-stream
      upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handclosed.cur google-blockly/media/handclosed.cur application/octet-stream
      upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.wav google-blockly/media/disconnect.wav audio/x-wav
      upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.ogg google-blockly/media/disconnect.ogg audio/ogg
      upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.mp3 google-blockly/media/disconnect.mp3 audio/mpeg
      upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.wav google-blockly/media/delete.wav audio/x-wav
      upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.ogg google-blockly/media/delete.ogg audio/ogg
      upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.mp3 google-blockly/media/delete.mp3 audio/mpeg
      upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.wav google-blockly/media/click.wav audio/x-wav
      upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.ogg google-blockly/media/click.ogg audio/ogg
      upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.mp3 google-blockly/media/click.mp3 audio/mpeg
      upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/1x1.gif google-blockly/media/1x1.gif image/gif
      upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/javascript_compressed.js google-blockly/javascript_compressed.js application/javascript
      upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blocks_compressed.js google-blockly/blocks_compressed.js application/javascript
      upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blockly_compressed.js google-blockly/blockly_compressed.js application/javascript
      upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/LICENSE google-blockly/LICENSE application/octet-stream
      upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/favicon.ico favicon.ico image/x-icon
      upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/asset-manifest.json asset-manifest.json application/json
      upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
      Adapter "javascript" updated
      process exited with code 0
      1. Ich habe ein Kamerascript am laufen wo mittels folgender Funtion gearbeitet wird:
          request.get({url: source_url, encoding: 'binary'}, function (err, response, body) {
                      fs.writeFile(dest_path_tmp + 'Haustuer-2.jpg', body, 'binary', function(err) {
              		fs.createReadStream(dest_path_tmp + 'Haustuer-2.jpg').pipe(fs.createWriteStream(dest_path + timeLastData() +"_Haustuer.jpg"));
                      exec('bash /usr/local/bin/haustuer-motion.sh');
                      if (err) {
                      if (logging) log('Fehler beim Bild speichern: ' + err, 'warn');
                      } else {
                      if (logging) log('Webcam Bild Nr.2 gespeichert');
              		    if ((AlarmAussen === false) || (AlarmAussen === 'false') || (AlarmAussen === 0) || (AlarmInnen === false) || (AlarmInnen === 'false') || (AlarmInnen === 0)) {
              				sendImage(dest_path_tmp + 'Haustuer-2.jpg',  getState('javascript.0.Kameraaufnahmen.EventMessage').val, false);
              		    } else {
                              sendImage(dest_path_tmp + 'Haustuer-2.jpg','', true);
      Mit dem neuen Javascript adapter bekomme ich folgende Fehlermeldung:
      javascript.0	2019-02-22 00:30:46.193	error	at FSReqWrap.oncomplete (fs.js:135:15)
      javascript.0	2019-02-22 00:30:46.193	error	at script.js.Kameras.Kamera_Haustuer_Motion:126:6
      javascript.0	2019-02-22 00:30:46.193	error	script.js.Kameras.Kamera_Haustuer_Motion: TypeError: fs.createReadStream is not a function
      javascript.0	2019-02-22 00:30:41.193	error	at FSReqWrap.oncomplete (fs.js:135:15)
      javascript.0	2019-02-22 00:30:41.193	error	at script.js.Kameras.Kamera_Haustuer_Motion:111:6
      javascript.0	2019-02-22 00:30:41.193	error	script.js.Kameras.Kamera_Haustuer_Motion: TypeError: fs.createReadStream is not a function
      javascript.0	2019-02-22 00:30:38.744	error	at FSReqWrap.oncomplete (fs.js:135:15)
      javascript.0	2019-02-22 00:30:38.743	error	at script.js.Kameras.Kamera_Haustuer_Motion:99:6
      javascript.0	2019-02-22 00:30:38.743	error	script.js.Kameras.Kamera_Haustuer_Motion: TypeError: fs.createReadStream is not a function
      javascript.0	2019-02-22 00:30:37.254	error	at FSReqWrap.oncomplete (fs.js:135:15)
      javascript.0	2019-02-22 00:30:37.253	error	at script.js.Kameras.Kamera_Haustuer_Motion:84:6
      javascript.0	2019-02-22 00:30:37.253	error	script.js.Kameras.Kamera_Haustuer_Motion: TypeError: fs.createReadStream is not a function
      javascript.0	2019-02-22 00:30:35.705	error	at FSReqWrap.oncomplete (fs.js:135:15)
      javascript.0	2019-02-22 00:30:35.705	error	at script.js.Kameras.Kamera_Haustuer_Motion:66:6
      javascript.0	2019-02-22 00:30:35.704	error	script.js.Kameras.Kamera_Haustuer_Motion: TypeError: fs.createReadStream is not a function
      javascript.0	2019-02-22 00:30:34.396	error	at FSReqWrap.oncomplete (fs.js:135:15)
      javascript.0	2019-02-22 00:30:34.396	error	at script.js.Kameras.Kamera_Haustuer_Motion:52:6
      javascript.0	2019-02-22 00:30:34.396	error	script.js.Kameras.Kamera_Haustuer_Motion: TypeError: fs.createReadStream is not a function
      Desweiteren habe ich plötzlich unter scriptEnabled bei jeder Instanz alle Scripte stehen was vorher nicht der Fall war.
      Also unter instanz 1 auch die Scripte von instanz 0 und 3 usw.
      Hier vor dem update:
      und hier nach dem update auf 4.1.2
      Wenn ich den Adapter dann downgrade verbleiben aber die ganzen scriptEnabled Einträge und die Instanzen spinnen rum.
      Desweiteren erkennt JS-Adapter plötzlich die Funktion aus einem Typescript-Script nicht mehr:
      import request = require("request");
      Also derzeit ist für mich das neue JS nicht nutzbar.
      Johnny
      Ach ja:
      node: 8.15.0
      npm: 6.5
      VM mit Debian 9
      • SRo769
        SRo769 last edited by
        bei mir funktionieren alle Scripte soweit erst mal ohne Fehlermeldung. Hatte schon gedacht, dass ich diesmal Glück habe. Leider lassen sich aber meine 6 größten Scripte (Blockly - Rolladensteuerung zur Beschattung) nicht mehr editieren. Die Fehlermeldung lautet "Cannot extract Blockly code!". Auf vorhergehenden 4. -Javascript-Versionen hatte ich diesen Fehler auch ein paar mal gesehen. Der ist jedoch immer spät. nach dem 2. Aufruf des Scriptes verschwunden. Mit der 4.1.2-Version gehr das nun nicht mehr weg. Das Bearbeitungsfeld bleibt bis auf 2 kleinere Bausteine leer.
        Um den Fehler einzugrenzen habe ich einfach mal ein neues Script entwurfen. Schon nach kurzer Zeit gab es kurz einen "Freeze" des Bildschirminhaltes - danach kam die Fehlermeldung "Cannot extract Blockly code!" wieder. Das Script kann ab dann nicht mehr editiert werden.
        Mein System:
        VM Debian 9
        Node 8.15.0
        Nodejs 8.15.0
        NPM 6.4.1
        Hab das dann nochmal auf einem 2. unabhängigen System getestet, auch hier kommt die gleiche Fehlemeldung und gleiches Problem,
        NUC Debian 9
        Node 8.15.0
        Nodejs 8.15.0
        NPM 6.80
        Scheint also ein Systemunabhängiges und reproduzierbares Problem zu sein.
        Grüße SRo769
          apollon77 last edited by
          @PrinzEisenherz1 sagte in Javascript-Adapter 4.1.2 macht noch Probleme:
          createReadStream
          Dann bitte im Github ein Issue anlegen
          • SRo769
            Hi, hab jetzt mal auf V4.1.3 upgedate und den Expertenmodus an- und wieder ausgeschaltet - jetzt kann ich alle meine Scripte editieren. Damit läuft jetzt alles wieder rund.
              PrinzEisenherz1 @apollon77 last edited by
              @apollon77 sagte in Javascript-Adapter 4.1.2 macht noch Probleme:
              createReadStream
              Erledigt. Hab Issue angelegt
              81.1k
              javascript script engine
