    4. Uninstall - install problem
    • derAuge
      derAuge last edited by
      @smiling-Jack:
      Hallo
      ich habe die neue version vom js-controller zurückgezogen
      Eine Installation sollte wieder ganz normal funktioniren. Wichtig ist ein
      npm cache clean
      vorweg zumachen.
      Zur info es wird jetzt wieder Version 0.5.15 installiert
      Steffen `
      OK. Getestet
      root@VMioBrokerMaster:/opt/iobroker# npm cache clean
      root@VMioBrokerMaster:/opt/iobroker# npm install iobroker
      npm ERR! not a package /tmp/npm-2534-cP-PEs+a/1427660539077-0.291726277442649/tmp.tgz
      > iobroker@0.5.1 install /opt/iobroker/node_modules/iobroker
      > node lib/setup.js
      npm install iobroker.js-controller --production --silent --prefix "/opt/iobroker/node_modules/iobroker/lib/../../../"
      npm install iobroker.admin --production --silent --prefix "/opt/iobroker/node_modules/iobroker/lib/../../../"
      Write "./iobroker start" to start the ioBroker
      Auto-start was enabled. Write "update-rc.d -f iobroker.sh remove" to disable auto-start
      iobroker is started. Go to "http://ip-addr:8081" to open the admin UI.
      iobroker@0.5.1 node_modules/iobroker
       yargs@1.2.6 (minimist@0.1.0)
      root@VMioBrokerMaster:/opt/iobroker# ps -A |grep io
           6 ?        00:00:00 migration/0
         170 ?        00:00:00 ext4-dio-unwrit
        1679 ?        00:00:00 rpciod
        1681 ?        00:00:00 nfsiod
        2641 ?        00:00:00 io.js-controlle
      Leider wird admin nicht gestartet.
      Manuell kann man auch nicht starten.
      root@VMioBrokerMaster:/opt/iobroker# iobroker update
      Cannot get version of "virtual".
      Cannot get version of "geofency".
      update done
      Adapter    "zwave"         : 0.1.0
      Adapter    "yr"            : 0.1.5
      Adapter    "web"           : 0.2.6
      Adapter    "vis"           : 0.2.11
      Adapter    "virtual"
      Adapter    "sonos"         : 0.1.6
      Adapter    "rickshaw"      : 0.2.2
      Adapter    "pushover"      : 0.1.0
      Adapter    "onkyo"         : 0.1.0
      Adapter    "telnet"        : 0.0.0
      Adapter    "socketio"      : 0.2.3
      Adapter    "simple-api"    : 0.0.4
      Adapter    "sayit"         : 0.3.6
      Adapter    "ping"          : 0.1.3
      Adapter    "node-red"      : 0.1.9
      Adapter    "mqtt"          : 0.1.7
      Adapter    "mobile"        : 0.0.2
      Adapter    "legacy"        : 0.1.12
      Adapter    "knx"           : 0.0.1
      Controller "js-controller" : 0.5.15   , installed 0.5.15
      Adapter    "javascript"    : 0.3.0
      Adapter    "ical"          : 0.1.0
      Adapter    "hmm"           : 0.0.17
      Adapter    "hue"           : 0.2.0
      Adapter    "hm-rpc"        : 0.4.0
      Adapter    "hm-rega"       : 0.2.1
      Adapter    "history"       : 0.1.3
      Adapter    "highcharts"    : 0.0.0
      Adapter    "graphite"      : 0.1.0
      Adapter    "geofency"
      Adapter    "example"       : 0.1.1    , installed 0.1.1
      Adapter    "email"         : 0.1.0
      Adapter    "dwd"           : 0.1.7
      Adapter    "cul"           : 0.0.2
      Adapter    "b-control-em"  : 0.1.1
      Adapter    "artnet"        : 0.0.3
      Adapter    "admin"         : 0.3.26   , installed 0.3.26
      root@VMioBrokerMaster:/opt/iobroker# iobroker start admin
      Please enter instance of adapter, e.g. "web.0"
      root@VMioBrokerMaster:/opt/iobroker# iobroker start admin.0
      Adapter "admin.0 does not exist.
        smiling_Jack last edited by
        Komish kannst du mal den web einzelt nachinstalliren (npm install iobroker.web )
        • derAuge
          @smiling-Jack:
          Komish kannst du mal den web einzelt nachinstalliren (npm install iobroker.web ) `
          keine Änderung
          root@VMioBrokerMaster:/opt/iobroker# npm install iobroker.web
          npm WARN deprecated object-keys@0.2.0: Please update to the latest object-keys
          > ws@0.4.31 install /opt/iobroker/node_modules/iobroker.web/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/engine.io/node_modules/ws
          > (node-gyp rebuild 2> builderror.log) || (exit 0)
          > ws@0.4.31 install /opt/iobroker/node_modules/iobroker.web/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws
          iobroker.web@0.2.6 node_modules/iobroker.web
          ├── connect-flash@0.1.1
          ├── iobroker.simple-api@0.0.4
          ├── passport-local@1.0.0 (passport-strategy@1.0.0)
          ├── cookie-parser@1.3.4 (cookie@0.1.2, cookie-signature@1.0.6)
          ├── passport@0.2.1 (pause@0.0.1, passport-strategy@1.0.0)
          ├── xtend@2.0.6 (is-object@0.1.2, object-keys@0.2.0)
          ├── body-parser@1.5.2 (qs@0.6.6, media-typer@0.2.0, bytes@1.0.0, raw-body@1.3.0, depd@0.4.4, type-is@1.3.2, iconv-lite@0.4.4)
          ├── express-session@1.7.6 (utils-merge@1.0.0, cookie@0.1.2, cookie-signature@1.0.4, on-headers@1.0.0, parseurl@1.3.0, buffer-crc32@0.2.3, depd@0.4.4, debug@1.0.4, uid-safe@1.0.1)
          ├── express@4.4.5 (parseurl@1.0.1, utils-merge@1.0.0, merge-descriptors@0.0.2, cookie@0.1.2, cookie-signature@1.0.4, escape-html@1.0.1, range-parser@1.0.0, fresh@0.2.2, vary@0.1.0, qs@0.6.6, methods@1.0.1, serve-static@1.2.3, buffer-crc32@0.2.3, path-to-regexp@0.1.2, debug@1.0.2, type-is@1.2.1, accepts@1.0.7, proxy-addr@1.0.1, send@0.4.3)
          ├── request@2.38.0 (json-stringify-safe@5.0.0, aws-sign2@0.5.0, forever-agent@0.5.2, oauth-sign@0.3.0, stringstream@0.0.4, tunnel-agent@0.4.0, qs@0.6.6, node-uuid@1.4.3, mime-types@1.0.2, tough-cookie@0.12.1, http-signature@0.10.1, form-data@0.1.4, hawk@1.1.1)
          └── iobroker.socketio@0.2.3 (request@2.51.0, socket.io@1.1.0)
             204 ?        00:00:00 ext4-dio-unwrit
            1711 ?        00:00:00 rpciod
            1713 ?        00:00:00 nfsiod
          root@VMioBrokerMaster:/opt/iobroker# iobroker restart
          ioBroker controller daemon is not running
          Starting ioBroker controller daemon...
          ioBroker controller daemon started. PID: 2596
            2596 ?        00:00:00 io.js-controlle
            starfish last edited by
            nur zur Info, der workaround funktioniert nun grösstenteils.
            ausser hm-rega - lässt sich nicht als instanz installieren. auch nicht bei manueller neu-installation (npm install iobroker.hm-rega)
            vielleicht wäre grundsätzlich eine npm-repo (heisst das hier auch so?) mit der Vor-Version nicht schlecht - oder sonst eine Möglichkeit, Vor-Versionen zu installieren.
            Wie auch immer , habe mich auf warten eingestellt.
              gibts news - läuft die Installation wieder?
              • Bluefox
                Bluefox last edited by
                Also. Ich will immer noch nicht auf npm hoch legen, bis ich eine Bestätigung bekomme, dass es noch bei jemandem geht.
                Es gibt aktuelle ioBroker.js-controller version 0.6.1. Die kann man mit
                npm install https://github.com/ioBroker/ioBroker.js-controller/tarball/master
                installieren.
                Für die Neuinstallation, dann:
                Kann jemand ausprobieren? Ich habe Windows, Debian und Ubuntu getestet. Update und Neuinstallation. Node.js 0.10.29/0.10.35/0.12.2
                  Habe eben mal schnell drüberinstalliert.
                  Keine Fehlermeldungen während des install.
                  Nach anschließendem reboot auch keine Fehlermeldungen im log beim Hochfahren!
                  RPi2 mit Raspian, nodejs 10.22.
                  Rainer
                    akamia last edited by
                    Neuinstallation auf CubieTruck funktioniert auch gut –> Restart ist erforderlich
                      Hallo Bluefox,
                      Ist doch wohl noch irgendetwas im Argen
                      Habe heute morgen auf dem PC den admin geöffnet:
                      Habe es gestern nur vom Handy aus gemacht - habe da evtl. die unteren Zeilen nicht gesehen!
                      Weder ./iobroker restart noch reboot haben geholfen.
                      Auch ein erneutes
                      brachte nichts, weder mit restart noch mit reboot
                      Jedoch keine Fehler während des Install oder nach dem reboot im log.
                      EDIT:
                      nach mehrmaligem reboot ist es jetzt auf einmal (ohne weiteren reboot) wieder ok !???
                      Im Vorfeld hatte ich Browsercache mehrfach gelöscht - ohne Änderungen ?!!???
                      Dafür fielen mir folgende Meldungen im log auf:
                      history-0	2015-04-15 10:43:02	info	moved 18 history datapoints from Redis history.hm-rpc.0.JEQ0267518.1.HUMIDITY to CouchDB history.hm-rpc.0.JEQ0267518.1.HUMIDITY.20150415
                      history-0	2015-04-15 10:43:02	info	moved 52 history datapoints from Redis history.hm-rpc.0.JEQ0267518.1.HUMIDITY to CouchDB history.hm-rpc.0.JEQ0267518.1.HUMIDITY.20150414
                      history-0	2015-04-15 10:43:02	info	18 remaining datapoints of history.hm-rpc.0.JEQ0267518.1.HUMIDITY
                      history-0	2015-04-15 10:43:02	info	moved 146 history datapoints from Redis history.hm-rpc.0.JEQ0267518.1.HUMIDITY to CouchDB history.hm-rpc.0.JEQ0267518.1.HUMIDITY.20150413
                      history-0	2015-04-15 10:43:02	info	52 remaining datapoints of history.hm-rpc.0.JEQ0267518.1.HUMIDITY
                      history-0	2015-04-15 10:43:02	info	moved 183 history datapoints from Redis history.hm-rpc.0.JEQ0267518.1.HUMIDITY to CouchDB history.hm-rpc.0.JEQ0267518.1.HUMIDITY.20150412
                      history-0	2015-04-15 10:43:02	info	146 remaining datapoints of history.hm-rpc.0.JEQ0267518.1.HUMIDITY
                      history-0	2015-04-15 10:43:02	info	moved 213 history datapoints from Redis history.hm-rpc.0.JEQ0267518.1.HUMIDITY to CouchDB history.hm-rpc.0.JEQ0267518.1.HUMIDITY.20150411
                      history-0	2015-04-15 10:43:02	info	183 remaining datapoints of history.hm-rpc.0.JEQ0267518.1.HUMIDITY
                      history-0	2015-04-15 10:43:02	info	moved 239 history datapoints from Redis history.hm-rpc.0.JEQ0267518.1.HUMIDITY to CouchDB history.hm-rpc.0.JEQ0267518.1.HUMIDITY.20150410
                      history-0	2015-04-15 10:43:02	info	213 remaining datapoints of history.hm-rpc.0.JEQ0267518.1.HUMIDITY
                      history-0	2015-04-15 10:43:02	info	moved 258 history datapoints from Redis history.hm-rpc.0.JEQ0267518.1.HUMIDITY to CouchDB history.hm-rpc.0.JEQ0267518.1.HUMIDITY.20150409
                      history-0	2015-04-15 10:43:02	info	239 remaining datapoints of history.hm-rpc.0.JEQ0267518.1.HUMIDITY
                      history-0	2015-04-15 10:43:02	info	moved 294 history datapoints from Redis history.hm-rpc.0.JEQ0267518.1.HUMIDITY to CouchDB history.hm-rpc.0.JEQ0267518.1.HUMIDITY.20150408
                      history-0	2015-04-15 10:43:02	info	258 remaining datapoints of history.hm-rpc.0.JEQ0267518.1.HUMIDITY
                      history-0	2015-04-15 10:43:02	info	moved 331 history datapoints from Redis history.hm-rpc.0.JEQ0267518.1.HUMIDITY to CouchDB history.hm-rpc.0.JEQ0267518.1.HUMIDITY.20150407
                      history-0	2015-04-15 10:43:02	info	294 remaining datapoints of history.hm-rpc.0.JEQ0267518.1.HUMIDITY
                      history-0	2015-04-15 10:43:02	info	moved 413 history datapoints from Redis history.hm-rpc.0.JEQ0267518.1.HUMIDITY to CouchDB history.hm-rpc.0.JEQ0267518.1.HUMIDITY.20150406
                      history-0	2015-04-15 10:43:02	info	331 remaining datapoints of history.hm-rpc.0.JEQ0267518.1.HUMIDITY
                      history-0	2015-04-15 10:43:02	info	[color]moved 445 history datapoints [b]from Redis[/b] history.hm-rpc.0.JEQ0267518.1.HUMIDITY [b]to CouchDB[/b][/color] history.hm-rpc.0.JEQ0267518.1.HUMIDITY.20150405
                      history-0	2015-04-15 10:43:02	info	413 remaining datapoints of history.hm-rpc.0.JEQ0267518.1.HUMIDITY
                      history-0	2015-04-15 10:43:02	info	moved 480 history datapoints from Redis history.hm-rpc.0.JEQ0267518.1.HUMIDITY to CouchDB history.hm-rpc.0.JEQ0267518.1.HUMIDITY.20150404
                      history-0	2015-04-15 10:43:02	info	445 remaining datapoints of history.hm-rpc.0.JEQ0267518.1.HUMIDITY
                      moved … datapoints from Redis history.hm-rpc.0.JEQ0267518.1.HUMIDITY to CouchDB
                      Rainer
                        Konnte gestern keinen Adapter installieren.
                          Bei mir kommt jetzt - nach längerer Laufzeit - alle paar minuten von hmm und node-red Adaptern:
                          quad-pi	2015-04-15 14:02:44	error	host.quad-pi instance system.adapter.node-red.0 terminated with code 7 (Adapter already running)
                          auch die folgende Meldung nach ./iobroker update über putty ist recht amüsant:
                          Controller "js-controller" : 0.5.15   , installed 0.6.1 [Updateable]
                          Rainer
                          • derAuge
                            @Bluefox:
                            installieren.
                            Kann jemand ausprobieren? Ich habe Windows, Debian und Ubuntu getestet. Update und Neuinstallation. Node.js 0.10.29/0.10.35/0.12.2 `
                            Neuinstall auf einer VM
                            root@VMioBrokerMaster:~# cd /opt/iobroker/
                            root@VMioBrokerMaster:/opt/iobroker# npm install https://github.com/ioBroker/ioBroker.js-controller/tarball/master
                            > ws@0.5.0 install /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io/node_modules/engine.io/node_modules/ws
                            > ws@0.4.31 install /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws
                            > iobroker.js-controller@0.6.1 install /opt/iobroker/node_modules/iobroker.js-controller
                            > node lib/setup.js setup first
                            creating conf/iobroker.json
                            object system.certificates created
                            object system.repositories created
                            object system.config created
                            object enum.rooms created
                            object system.group.user created
                            object system.group.administrator created
                            object _design/system created
                            object system.user.admin created
                            object system.meta.uuid created
                            install adapter admin
                            got /opt/iobroker/node_modules/iobroker.js-controller/node_modules/iobroker.admin/admin
                            upload admin.admin /opt/iobroker/node_modules/iobroker.js-controller/node_modules/iobroker.admin/admin/index.html index.html text/html
                            upload admin.admin /opt/iobroker/node_modules/iobroker.js-controller/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                            object system.adapter.admin created
                            create instance admin
                            object system.adapter.admin.0.uptime created
                            object system.adapter.admin.0.memRss created
                            object system.adapter.admin.0.memHeapTotal created
                            object system.adapter.admin.0.memHeapUsed created
                            object system.adapter.admin.0.connected created
                            object system.adapter.admin.0.alive created
                            object system.adapter.admin.0 created
                            iobroker.js-controller@0.6.1 node_modules/iobroker.js-controller
                            ├── daemonize2@0.4.2
                            ├── mime@1.3.4
                            ├── node-schedule@0.1.13
                            ├── ncp@2.0.0
                            ├── adm-zip@0.4.7
                            ├── node.extend@1.1.3 (is@2.1.0)
                            ├── yargs@3.7.2 (camelcase@1.0.2, decamelize@1.0.0, window-size@0.1.0, wordwrap@0.0.2)
                            ├── npm@2.7.6
                            ├── winston@1.0.0 (cycle@1.0.3, stack-trace@0.0.9, eyes@0.1.8, isstream@0.1.2, pkginfo@0.3.0, async@0.9.0, colors@1.0.3)
                            ├── socket.io@1.3.5 (debug@2.1.0, has-binary-data@0.1.3, socket.io-adapter@0.3.1, socket.io-parser@2.2.4, engine.io@1.5.1)
                            ├── tar.gz@0.1.1 (commander@1.1.1, tar@0.1.20, fstream@0.1.31)
                            ├── request@2.55.0 (caseless@0.9.0, json-stringify-safe@5.0.0, aws-sign2@0.5.0, forever-agent@0.6.1, stringstream@0.0.4, oauth-sign@0.6.0, tunnel-agent@0.4.0, isstream@0.1.2, node-uuid@1.4.3, qs@2.4.1, combined-stream@0.0.7, mime-types@2.0.10, form-data@0.2.0, http-signature@0.10.1, hawk@2.3.1, bl@0.9.4, tough-cookie@0.12.1, har-validator@1.6.1)
                            ├── socket.io-client@1.3.5 (to-array@0.1.3, indexof@0.0.1, component-bind@1.0.0, debug@0.7.4, backo2@1.0.2, object-component@0.0.3, component-emitter@1.1.2, has-binary@0.1.6, socket.io-parser@2.2.4, parseuri@0.0.2, engine.io-client@1.5.1)
                            └── iobroker.admin@0.3.27 (connect-flash@0.1.1, xtend@4.0.0, passport-local@1.0.0, passport@0.2.1, cookie-parser@1.3.4, express-session@1.11.1, body-parser@1.12.2, express@4.12.3)
                            > node lib/setup.js
                            └── yargs@1.2.6 (minimist@0.1.0)
                            ├── mime@1.3.4
                            ├── ncp@2.0.0
                            ├── adm-zip@0.4.7
                            ├── yargs@3.7.2 (decamelize@1.0.0, camelcase@1.0.2, window-size@0.1.0, wordwrap@0.0.2)
                            ├── socket.io@1.3.5 (debug@2.1.0, has-binary-data@0.1.3, socket.io-adapter@0.3.1, engine.io@1.5.1, socket.io-parser@2.2.4)
                            ├── request@2.55.0 (caseless@0.9.0, json-stringify-safe@5.0.0, aws-sign2@0.5.0, forever-agent@0.6.1, stringstream@0.0.4, oauth-sign@0.6.0, tunnel-agent@0.4.0, isstream@0.1.2, node-uuid@1.4.3, qs@2.4.1, combined-stream@0.0.7, form-data@0.2.0, mime-types@2.0.10, http-signature@0.10.1, bl@0.9.4, tough-cookie@0.12.1, hawk@2.3.1, har-validator@1.6.1)
                            ├── socket.io-client@1.3.5 (to-array@0.1.3, indexof@0.0.1, component-bind@1.0.0, debug@0.7.4, backo2@1.0.2, object-component@0.0.3, component-emitter@1.1.2, has-binary@0.1.6, parseuri@0.0.2, socket.io-parser@2.2.4, engine.io-client@1.5.1)
                            └── npm@2.7.6
                            controller = 0.6.1(Running: 0.5.15)
                            root@VMioBrokerMaster:/opt/iobroker# node -v
                            v0.10.38
                            Die Adapter wurden erst nach 2maligem Update angezeigt
                            Install VIS
                            iobroker	2015-04-15 18:25:27	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.zwave/master/io-package.json. Error: Error: ETIMEDOUT
                            iobroker	2015-04-15 18:25:27	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.yr/master/io-package.json. Error: Error: ETIMEDOUT
                            iobroker	2015-04-15 18:25:27	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.onkyo/master/io-package.json. Error: Error: ETIMEDOUT
                            iobroker	2015-04-15 18:25:27	info	npm install iobroker.vis --production --prefix "/opt/iobroker" (System call)
                            iobroker	2015-04-15 18:25:22	info	add vis
                            nach der Installation von YR wurde auch vis noch mit installiert
                            VMioBrokerMaster	2015-04-15 18:27:55	info	iobroker object-keys@0.2.0: Please update to the latest object-keys
                            VMioBrokerMaster	2015-04-15 18:27:55	info	iobroker deprecated
                            VMioBrokerMaster	2015-04-15 18:27:55	info	iobroker WARN
                            VMioBrokerMaster	2015-04-15 18:27:55	info	iobroker npm
                            VMioBrokerMaster	2015-04-15 18:27:52	info	iobroker npm install iobroker.web --production --prefix "/opt/iobroker" (System call)
                            VMioBrokerMaster	2015-04-15 18:27:47	info	iobroker install adapter web
                            Anschließen konnte vis aufgerufen werden
                            derAuge
                            (Man sieht sich Samstag 😉 )
                            • Bluefox
                              @Homoran:
                              EDIT:
                              Im Vorfeld hatte ich Browsercache mehrfach gelöscht - ohne Änderungen ?!!??? `
                              Es liegt an Timeout beim Zugang zu npmjs.org. Vielleicht war der WebServer gestern überlastet. Trotzdem habe ich Timeout erhöht.
                                Irgend etwas läuft da nicht sauber.
                                Habe eben über den admin nach updates suchen wollen. Dabei zeigt das log mir auf einmal an, dass er alle möglichen Adapter killt und auf terminating geht.
                                Nach dem wieder hochfahren gibt es wieder den Error 7, dass mindestens zwei Adapter doppelt laufen.
                                host-quad-pi 2015-04-16 15:45:23 info Restart adapter system.adapter.hmm.0 because enabled
                                host-quad-pi 2015-04-16 15:45:23 error instance system.adapter.hmm.0 terminated with code 7 (Adapter already running)
                                host-quad-pi 2015-04-16 15:45:21 info instance system.adapter.hmm.0 started with pid 1554
                                host-quad-pi 2015-04-16 15:45:17 info Restart adapter system.adapter.node-red.0 because enabled
                                host-quad-pi 2015-04-16 15:45:17 error instance system.adapter.node-red.0 terminated with code 7 (Adapter already running)
                                host-quad-pi 2015-04-16 15:45:15 info instance system.adapter.node-red.0 started with pid 1548
                                host-quad-pi 2015-04-16 15:44:58 info Update repository "default" under "conf/sources-dist.json"
                                host-quad-pi 2015-04-16 15:44:51 info Restart adapter system.adapter.hmm.0 because enabled
                                host-quad-pi 2015-04-16 15:44:51 error instance system.adapter.hmm.0 terminated with code 7 (Adapter already running)
                                host-quad-pi 2015-04-16 15:44:49 info instance system.adapter.hmm.0 started with pid 1510
                                host-quad-pi 2015-04-16 15:44:45 info Restart adapter system.adapter.node-red.0 because enabled
                                host-quad-pi 2015-04-16 15:44:45 error instance system.adapter.node-red.0 terminated with code 7 (Adapter already running)
                                host-quad-pi 2015-04-16 15:44:41 info instance system.adapter.node-red.0 started with pid 1493
                                javascript-0 2015-04-16 15:44:40 info received all states
                                javascript-0 2015-04-16 15:44:40 info received all objects
                                javascript-0 2015-04-16 15:44:37 info requesting all objects
                                javascript-0 2015-04-16 15:44:37 info requesting all states
                                javascript-0 2015-04-16 15:44:37 info starting. Version 0.3.0 in /opt/iobroker/node_modules/iobroker.javascript
                                host-quad-pi 2015-04-16 15:44:35 info instance system.adapter.yr.0 terminated with code 0 (OK)
                                host-quad-pi 2015-04-16 15:44:34 info instance system.adapter.javascript.0 started with pid 1485
                                email-0 2015-04-16 15:44:31 info starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.email
                                yr-0 2015-04-16 15:44:30 info got weather data from yr.no
                                host-quad-pi 2015-04-16 15:44:29 info instance system.adapter.email.0 started with pid 1470
                                yr-0 2015-04-16 15:44:28 info starting. Version 0.1.5 in /opt/iobroker/node_modules/iobroker.yr
                                host-quad-pi 2015-04-16 15:44:26 info instance system.adapter.ical.0 terminated with code 0 (OK)
                                host-quad-pi 2015-04-16 15:44:25 info instance system.adapter.yr.0 started with pid 1464
                                host-quad-pi 2015-04-16 15:44:25 info instance scheduled system.adapter.yr.0 0 * * * *
                                ical-0 2015-04-16 15:44:19 info processing URL: calendar1 http://192.168.2.225:5000/fbsharing/IQExBXbr
                                host-quad-pi 2015-04-16 15:44:19 info Restart adapter system.adapter.hmm.0 because enabled
                                host-quad-pi 2015-04-16 15:44:19 error instance system.adapter.hmm.0 terminated with code 7 (Adapter already running)
                                host-quad-pi 2015-04-16 15:44:17 info instance system.adapter.hmm.0 started with pid 1449
                                ical-0 2015-04-16 15:44:17 info starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.ical
                                host-quad-pi 2015-04-16 15:44:14 info instance system.adapter.ical.0 started with pid 1443
                                host-quad-pi 2015-04-16 15:44:13 info instance scheduled system.adapter.ical.0 0,30 * * * *
                                host-quad-pi 2015-04-16 15:44:11 info Restart adapter system.adapter.node-red.0 because enabled
                                host-quad-pi 2015-04-16 15:44:11 error instance system.adapter.node-red.0 terminated with code 7 (Adapter already running)
                                host-quad-pi 2015-04-16 15:44:10 info instance system.adapter.dwd.0 terminated with code 0 (OK)
                                host-quad-pi 2015-04-16 15:44:10 info instance system.adapter.node-red.0 started with pid 1428
                                ping-0 2015-04-16 15:44:07 info starting. Version 0.1.4 in /opt/iobroker/node_modules/iobroker.ping
                                host-quad-pi 2015-04-16 15:44:05 info instance system.adapter.ping.0 started with pid 1418
                                dwd-0 2015-04-16 15:44:04 info setting states
                                dwd-0 2015-04-16 15:44:04 info starting. Version 0.1.7 in /opt/iobroker/node_modules/iobroker.dwd
                                web-0 2015-04-16 15:44:02 info http server listening on port 8082
                                web-0 2015-04-16 15:44:02 info socket.io server listening on port 8082
                                host-quad-pi 2015-04-16 15:44:01 info instance system.adapter.dwd.0 started with pid 1403
                                host-quad-pi 2015-04-16 15:44:01 info instance scheduled system.adapter.dwd.0 5,20,35,50 * * * *
                                web-0 2015-04-16 15:44:01 info starting. Version 0.2.6 in /opt/iobroker/node_modules/iobroker.web
                                hm-rega-0 2015-04-16 15:43:57 info got state values
                                hm-rega-0 2015-04-16 15:43:56 info request state values
                                hm-rega-0 2015-04-16 15:43:56 info deleted 0 variables
                                hm-rega-0 2015-04-16 15:43:56 info added/updated 64 variables
                                hm-rega-0 2015-04-16 15:43:56 info got 64 variables
                                hm-rega-0 2015-04-16 15:43:55 info deleted 0 programs
                                hm-rega-0 2015-04-16 15:43:55 info added/updated 56 programs
                                hm-rega-0 2015-04-16 15:43:54 info got 56 programs
                                host-quad-pi 2015-04-16 15:43:53 info instance system.adapter.web.0 started with pid 1396
                                hm-rega-0 2015-04-16 15:43:53 info added/updated rooms to enum.rooms
                                hm-rega-0 2015-04-16 15:43:53 info added/updated functions to enum.functions
                                hm-rega-0 2015-04-16 15:43:53 info added/updated 6 favorites to enum.favorites
                                hm-rega-0 2015-04-16 15:43:53 info time difference local-ccu 0s
                                hm-rega-0 2015-04-16 15:43:53 info ReGaHSS 192.168.2.186 up
                                history-0 2015-04-16 15:43:53 info enabled logging of ping.0.quad-pi.192_168_2_120
                                history-0 2015-04-16 15:43:53 info enabled logging of ping.0.quad-pi.192_168_2_7
                                history-0 2015-04-16 15:43:53 info enabled logging of ping.0.quad-pi.192_168_2_142
                                history-0 2015-04-16 15:43:53 info enabled logging of ping.0.quad-pi.192_168_2_75
                                history-0 2015-04-16 15:43:53 info enabled logging of dwd.0.warning.severity
                                history-0 2015-04-16 15:43:53 info enabled logging of hm-rpc.0.LEQ0081020.1.TEMPERATURE
                                history-0 2015-04-16 15:43:53 info enabled logging of hm-rpc.0.LEQ0081020.1.HUMIDITY
                                history-0 2015-04-16 15:43:53 info enabled logging of hm-rpc.0.KEQ0963067.1.TEMPERATURE
                                history-0 2015-04-16 15:43:53 info enabled logging of hm-rpc.0.JEQ0459186.1.MOTION
                                history-0 2015-04-16 15:43:53 info enabled logging of hm-rpc.0.JEQ0267518.1.TEMPERATURE
                                history-0 2015-04-16 15:43:53 info enabled logging of hm-rpc.0.JEQ0267518.1.HUMIDITY
                                history-0 2015-04-16 15:43:53 info enabled logging of hm-rpc.0.JEQ0140901.1.TEMPERATURE
                                history-0 2015-04-16 15:43:53 info enabled logging of hm-rpc.0.JEQ0140901.1.HUMIDITY
                                history-0 2015-04-16 15:43:53 info enabled logging of system.host.quad-pi.load
                                history-0 2015-04-16 15:43:53 info enabled logging of system.host.quad-pi.mem
                                hm-rega-0 2015-04-16 15:43:51 info subscribe hm-rpc.0.BidCoS-RF:50.PRESS_SHORT
                                hm-rega-0 2015-04-16 15:43:51 info starting. Version 0.2.1 in /opt/iobroker/node_modules/iobroker.hm-rega
                                history-0 2015-04-16 15:43:53 info starting. Version 0.1.3 in /opt/iobroker/node_modules/iobroker.history
                                hm-rpc-0 2015-04-16 15:43:51 info xmlrpc -> 327 devices
                                hm-rpc-0 2015-04-16 15:43:51 info xmlrpc <- listDevices ["hm-rpc.0"]
                                hm-rpc-0 2015-04-16 15:43:51 info xmlrpc <- system.listMethods ["hm-rpc.0"]
                                hm-rpc-0 2015-04-16 15:43:51 info xmlrpc -> 192.168.2.186:2001 init ["http://192.168.2.190:2001","hm-rpc.0"]
                                hm-rpc-0 2015-04-16 15:43:51 info xmlrpc server is trying to listen on 192.168.2.190:2001
                                hm-rpc-0 2015-04-16 15:43:50 info starting. Version 0.4.0 in /opt/iobroker/node_modules/iobroker.hm-rpc
                                host-quad-pi 2015-04-16 15:43:50 info instance system.adapter.history.0 started with pid 1377
                                hm-rpc-0 2015-04-16 15:43:48 error no connection to objects DB
                                host-quad-pi 2015-04-16 15:43:46 info Update repository "default" under "conf/sources-dist.json"
                                host-quad-pi 2015-04-16 15:43:46 info instance system.adapter.hm-rega.0 started with pid 1371
                                admin-0 2015-04-16 15:43:45 info received all states
                                admin-0 2015-04-16 15:43:45 info received all objects
                                admin-0 2015-04-16 15:43:42 info Use link "http://localhost:8081" to configure.
                                admin-0 2015-04-16 15:43:42 info http server listening on port 8081
                                admin-0 2015-04-16 15:43:42 info requesting all objects
                                admin-0 2015-04-16 15:43:42 info requesting all states
                                admin-0 2015-04-16 15:43:42 info starting. Version 0.3.27 in /opt/iobroker/node_modules/iobroker.admin
                                hmm-0 2015-04-16 15:43:42 warn Reconnection to DB.
                                hmm-0 2015-04-16 15:43:41 warn Reconnection to DB.
                                host-quad-pi 2015-04-16 15:43:41 info instance system.adapter.hm-rpc.0 started with pid 1356
                                host-quad-pi 2015-04-16 15:43:37 info instance system.adapter.admin.0 started with pid 1354
                                host-quad-pi 2015-04-16 15:43:37 info starting 15 instances
                                host-quad-pi 2015-04-16 15:43:37 info 18 instances found
                                host-quad-pi 2015-04-16 15:43:37 info InMemoryDB connected
                                node-red-0 2015-04-16 15:43:38 warn Reconnection to DB.
                                inMem-objects 2015-04-16 15:43:37 info listening on port 9001
                                inMem-states 2015-04-16 15:43:37 info listening on port 9000
                                host-quad-pi 2015-04-16 15:43:37 info ip addresses: 192.168.2.190
                                host-quad-pi 2015-04-16 15:43:37 info hostname: quad-pi
                                host-quad-pi 2015-04-16 15:43:37 info Copyright (c) 2014-2015 bluefox, hobbyquaker
                                host-quad-pi 2015-04-16 15:43:37 info ioBroker.js-controller version 0.6.1 js-controller starting
                                hmm-0 2015-04-16 15:43:36 info hmm exited with 0
                                node-red-0 2015-04-16 15:43:35 info node-red exited with 0
                                email-0 2015-04-16 15:43:35 info terminating with timeout
                                ping-0 2015-04-16 15:43:35 info terminating with timeout
                                javascript-0 2015-04-16 15:43:34 info terminating
                                admin-0 2015-04-16 15:43:34 info terminating
                                web-0 2015-04-16 15:43:34 info terminating
                                hm-rega-0 2015-04-16 15:43:34 info terminating
                                history-0 2015-04-16 15:43:34 info terminating
                                TypeError: 2015-04-16 15:43:33 error at Timer.listOnTimeout [as ontimeout] (timers.js:110:15)
                                TypeError: 2015-04-16 15:43:33 error at null._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/statesInMemServer.js:464:25)
                                TypeError: 2015-04-16 15:43:33 error at States.change (/opt/iobroker/node_modules/iobroker.js-controller/controller.js:142:48)
                                TypeError: 2015-04-16 15:43:33 error Cannot read property 'time' of undefined
                                hm-rpc-0 2015-04-16 15:43:34 info terminating
                                hmm-0 2015-04-16 15:43:33 info kill hmm task
                                node-red-0 2015-04-16 15:43:33 info kill node-red task
                                web-0 2015-04-16 15:43:33 info terminated http server on port 8082
                                web-0 2015-04-16 15:43:33 info terminating http server on port 8082
                                hm-rpc-0 2015-04-16 15:43:33 info xmlrpc -> 192.168.2.186:2001 init ["http://192.168.2.190:2001",""]
                                admin-0 2015-04-16 15:43:33 info terminating http server on port 8081
                                uncaught 2015-04-16 15:43:33 error exception: Cannot read property 'time' of undefined
                                Daraufhin habe ich über den Reiter hosts einen restart des RPi2 ausgelöst.
                                jetzt beschwert er sich beim runterfahren, dass diverse Adapetr immer noch laufen.
                                entsprechend taucht da auch der error code 7 wieder auf
                                quad-pi	2015-04-16 15:45:48	info	host.quad-pi Restart adapter system.adapter.admin.0 because enabled
                                quad-pi	2015-04-16 15:45:48	error	host.quad-pi instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
                                history.0	2015-04-16 15:45:43	warn	history.0 Reconnection to DB.
                                web.0	2015-04-16 15:45:45	warn	web.0 Reconnection to DB.
                                javascript.0	2015-04-16 15:45:45	warn	javascript.0 Reconnection to DB.
                                history.0	2015-04-16 15:45:42	warn	history.0 Reconnection to DB.
                                hm-rpc.0	2015-04-16 15:45:47	warn	hm-rpc.0 Reconnection to DB.
                                hm-rega.0	2015-04-16 15:45:43	warn	hm-rega.0 Reconnection to DB.
                                ping.0	2015-04-16 15:45:47	warn	ping.0 Reconnection to DB.
                                email.0	2015-04-16 15:45:47	warn	email.0 Reconnection to DB.
                                quad-pi	2015-04-16 15:45:47	info	host.quad-pi instance system.adapter.hm-rpc.0 started with pid 1599
                                admin.0	2015-04-16 15:45:43	warn	admin.0 Reconnection to DB.
                                quad-pi	2015-04-16 15:45:37	info	Adapter javascript still running
                                quad-pi	2015-04-16 15:45:37	info	Adapter email still running
                                quad-pi	2015-04-16 15:45:37	info	Adapter ping still running
                                quad-pi	2015-04-16 15:45:37	info	Adapter web still running
                                quad-pi	2015-04-16 15:45:37	info	Adapter history still running
                                quad-pi	2015-04-16 15:45:37	info	Adapter hm-rega still running
                                quad-pi	2015-04-16 15:45:37	info	Adapter hm-rpc still running
                                quad-pi	2015-04-16 15:45:37	info	Adapter admin still running
                                quad-pi	2015-04-16 15:45:37	info	host.quad-pi force terminated after 10s
                                quad-pi	2015-04-16 15:45:37	info	host.quad-pi received SIGTERM
                                quad-pi	2015-04-16 15:45:36	info	host.quad-pi received SIGTERM
                                quad-pi	2015-04-16 15:45:35	info	host.quad-pi received SIGTERM
                                quad-pi	2015-04-16 15:45:34	info	host.quad-pi received SIGTERM
                                quad-pi	2015-04-16 15:45:33	info	host.quad-pi received SIGTERM
                                host-quad-pi	2015-04-16 15:45:32	info	received SIGTERM
                                host-quad-pi	2015-04-16 15:45:31	info	received SIGTERM
                                host-quad-pi	2015-04-16 15:45:30	info	received SIGTERM
                                host-quad-pi	2015-04-16 15:45:29	info	received SIGTERM
                                host-quad-pi	2015-04-16 15:45:28	info	received SIGTERM
                                host-quad-pi	2015-04-16 15:45:27	info	received SIGTERM
                                iobroker	2015-04-16 15:45:26	info	exit 0
                                iobroker	2015-04-16 15:45:26	info	Starting node restart.js
                                iobroker	2015-04-16 15:45:26	info	_restart
                                ich wollte eigentlich nicht wieder rebooten. Dann läuft er meistens stabil.
                                in den rechten Spalten wechselt es dauern von rot nach grün 😞
                                jetzt ist doch reboot angesagt 😞
                                Rainer
                                • Bluefox
                                  Es hat sich irgendwas verhackt. Da hilft nur reboot.
                                  Es gibt 0.6.3, wo update wieder funktionieren soll.
                                    kann ich bestätigen
                                    > in den rechten Spalten wechselt es dauern von rot nach grün :(
                                    wie auch die Logeinträge sehen bei mir gleich aus.
                                    • derAuge
                                      @Bluefox:
                                      Es gibt 0.6.3, wo update wieder funktionieren soll. `
                                      Was ist nun zu tun?
                                      root@pi2:/mnt/ioBroker/iobroker# iobroker restart
                                      module.js:340
                                          throw err;
                                      Error: Cannot find module '/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/iobroker.js'
                                          at Function.Module._resolveFilename (module.js:338:15)
                                          at Function.Module._load (module.js:280:25)
                                          at Function.Module.runMain (module.js:497:10)
                                          at startup (node.js:119:16)
                                          at node.js:935:3
                                      • Bluefox
                                        cd /mnt/ioBroker/iobroker.Pi2/
                                        ./iobroker start
                                        • Bluefox
                                          @starfish:
                                          kann ich bestätigen
                                          wie auch die Logeinträge sehen bei mir gleich aus. `
                                          Reboot
                                            Auch bei controller 0.6.3 und neuem admin bleibt es dabei, dass bei einem ./iobroker restart einzelne Adapter nicht beendet werden (erst mal nur node-red und hmm) und nach dem restart doppelt laufen.
                                            Dadurch kommt es andauernd zu terminating code 7
                                            Nach reboot ist gut!
                                            Gesendet von meinem LIFETAB_S785X mit Tapatalk
                                            16367
