    4. ioBroker.upnp - please test
    • Neuschwansteini
      Neuschwansteini @Bluefox last edited by
      @Bluefox ja, der ist hier im Büro, bei den anderen müsste ich jetzt in den Keller laufen.. sind ja aus.. 😉
      XML:
      <root><specVersion><major>1</major><minor>0</minor></specVersion><device><deviceType>urn:schemas-upnp-org:device:Basic:1</deviceType><friendlyName>OctoPrint instance "Octopi"</friendlyName><manufacturer>The OctoPrint Project</manufacturer><manufacturerURL>http://www.octoprint.org/</manufacturerURL><modelName>1.3.10</modelName><UDN>uuid:9a974f73-d481-44d5-8f93-088c35bd0dcd</UDN><serviceList>
              </serviceList><presentationURL>http://192.168.178.28/</presentationURL></device></root>
      Source:
      http://www.w3.org/1999/xhtml" id="top"><link rel="stylesheet" href="chrome://global/content/xml/XMLPrettyPrint.css" /><div id="header" dir="ltr"><p>
                This XML file does not appear to have any style information associated with it. The document tree is shown below.
              </p></div><main id="tree" class="highlight"><div><details open="" class="expandable-body"><summary class="expandable-opening">&lt;<span class="start-tag">root</span>&gt;</summary><div class="expandable-children"><div><details open="" class="expandable-body"><summary class="expandable-opening">&lt;<span class="start-tag">specVersion</span>&gt;</summary><div class="expandable-children"><div>&lt;<span class="start-tag">major</span>&gt;<span class="text">1</span>&lt;/<span class="end-tag">major</span>&gt;</div><div>&lt;<span class="start-tag">minor</span>&gt;<span class="text">0</span>&lt;/<span class="end-tag">minor</span>&gt;</div></div></details><span class="expandable-closing">&lt;/<span class="end-tag">specVersion</span>&gt;</span></div><div><details open="" class="expandable-body"><summary class="expandable-opening">&lt;<span class="start-tag">device</span>&gt;</summary><div class="expandable-children"><div>&lt;<span class="start-tag">deviceType</span>&gt;<span class="text">urn:schemas-upnp-org:device:Basic:1</span>&lt;/<span class="end-tag">deviceType</span>&gt;</div><div>&lt;<span class="start-tag">friendlyName</span>&gt;<span class="text">OctoPrint instance "Octopi"</span>&lt;/<span class="end-tag">friendlyName</span>&gt;</div><div>&lt;<span class="start-tag">manufacturer</span>&gt;<span class="text">The OctoPrint Project</span>&lt;/<span class="end-tag">manufacturer</span>&gt;</div><div>&lt;<span class="start-tag">manufacturerURL</span>&gt;<span class="text">http://www.octoprint.org/</span>&lt;/<span class="end-tag">manufacturerURL</span>&gt;</div><div>&lt;<span class="start-tag">modelName</span>&gt;<span class="text">1.3.10</span>&lt;/<span class="end-tag">modelName</span>&gt;</div><div>&lt;<span class="start-tag">UDN</span>&gt;<span class="text">uuid:9a974f73-d481-44d5-8f93-088c35bd0dcd</span>&lt;/<span class="end-tag">UDN</span>&gt;</div><div>&lt;<span class="start-tag">serviceList</span>&gt;<span class="text">
              </span>&lt;/<span class="end-tag">serviceList</span>&gt;</div><div>&lt;<span class="start-tag">presentationURL</span>&gt;<span class="text">http://192.168.178.28/</span>&lt;/<span class="end-tag">presentationURL</span>&gt;</div></div></details><span class="expandable-closing">&lt;/<span class="end-tag">device</span>&gt;</span></div></div></details><span class="expandable-closing">&lt;/<span class="end-tag">root</span>&gt;</span></div></main></div>
      Screenshot:
      • SBorg
        SBorg Forum Testing Most Active @Bluefox last edited by
        @Bluefox sagte in ioBroker.upnp - please test:
        @SBorg UNd bitte noch mal vom git testen.
        👍 funktioniert supi, call stack ist weg und UPNP läuft wieder ohne Probleme, Danke 🙂
        Neuschwansteini 1 Reply Last reply Reply Quote 0
        • Neuschwansteini
          Neuschwansteini @SBorg last edited by
          @SBorg hast du es gut.. bei mir nicht.. 3 Systeme, überall das Gleiche.. muss an meinen Devices liegen.. 😞 vor allem werden die Datenpunkte nicht beschrieben, sind zwar da, aber steht nix drin..
          • SBorg
            SBorg Forum Testing Most Active @Neuschwansteini last edited by SBorg
            @ilovegym sagte in ioBroker.upnp - please test:
            @SBorg ...sind zwar da, aber steht nix drin..
            Sollte da überhaupt was drin stehen? IMHO schickt UPNP von Hause aus doch nix von selbst? Ich schick per UPNP eine Anfrage an das Device, dann schickt es mir die gewünschten Daten.
            Soll heißen, starte ich UPNP sind z.B. bei meiner FritzBox auch alle DPs leer, schick ich dann ein "send", bekomme ich die gewünschten Daten in die entsprechenden DPs übermittelt.
            EDIT auch richtig zitieren will gelernt sein...
              sigi234 Forum Testing Most Active @SBorg last edited by sigi234
              @SBorg sagte in ioBroker.upnp - please test:
              So ist es, habe ein Skrip laufen das mir die Werte holt.......von der Fritz Box
              schedule("*/10 * * * * *",  function () {
                 setState( "upnp.0.FRITZ!Box_6590_Cable.WANDevice.WANCommonInterfaceConfig.GetCommonLinkProperties"/*GetCommonLinkProperties*/,'send');
                 setState( "upnp.0.FRITZ!Box_6590_Cable.WANDevice.WANCommonInterfaceConfig.GetAddonInfos"/*GetAddonInfos*/,'send');
              Neuschwansteini 1 Reply Last reply Reply Quote 1
              • Neuschwansteini
                Neuschwansteini @sigi234 last edited by
                @sigi234 🤦 danke, ich hatte zwar ein Script, aber auf dem Testsystem war der Javascriptadapter deaktiviert, damit mir die Scripte keinen durcheinander machen... und ohne das Script geht ja nix.. oh Mann..
                • opossum
                  opossum last edited by
                  jetzt läuft das bei mir mit Version 1.0.3, alle Werte, die ich brauche, sind aus meiner Fritzbox wieder da, vielen Dank.
                  opossum
                  • Neuschwansteini
                    Hab den upnp seit ein paar Stunden im Produktivsystem laufen, und bis auf die Fehler mit den Octopi's funktioniert er auch ( Daten werden auch eingetragen, da läuft ja mein Javascriptadapter ;-))
                    Hat noch irgendeiner hier OctoPi's im Netzwerk und kann das nachvollziehen?
                    • Bluefox
                      Ich habe noch mal upnp upgedatet (für den Octopus fall)
                      ABER: Da ich bemerkt habe, dass Object Tree total falsch war, habe ich die Struktur geändert.
                      Dazu habe ich schedule Funktionalität eingebaut, so dass man bei "request" variablen CRON Regel setzen kann und man braucht kein JScript mehr um die Variable zu pollen.
                      Bitte Beachten: Dabei alte JS Scripte werden nicht funktionieren!
                      • Bluefox
                        • Bluefox
                          Kann jemand bei upnp ja/nein sagen? Das ist einzige was js-controller 1.5.7 vom Release abhält...
                          sigi234 Neuschwansteini 2 Replies Last reply Reply Quote 0
                          • SBorg
                            Eben getestet, will bei mir nicht, kommen keine Daten.
                            Habe zwar "upnp.0 2019-02-24 10:29:51.958 info enabled polling of upnp.0.WANDevice_-FRITZ!Box_7490(UI).WANDevice.WANCommonInterfaceConfig.GetCommonLinkProperties.request with schedule */20 * * * * *" im Log, kommen aber keine Daten. Auch beim druck auf den Button kommt nix.
                            Sicherheitshalber hatte ich alle Datenpunkte gelöscht und Broker neu gestartet.
                              sigi234 Forum Testing Most Active @Bluefox last edited by sigi234
                              @Bluefox
                              es kommen keine Daten.............
                              Ich bin wieder auf die Alte Version umgestiegen.....da funktioniert es.
                              • Neuschwansteini
                                @Bluefox Hi, Danke fürs Update, keine Fehler im Log, gute Idee mit dem Cron da!
                                Leider holt der Adapter keine Werte, auch wenn der request button manuell ausgeführt wird.
                                Die Schleife new device... bei den Octopis ist behoben, super!
                                Hier mein Log ( debug 😞
                                logfile.txt
                                • Neuschwansteini
                                  Neuschwansteini @Neuschwansteini last edited by Neuschwansteini
                                  wenn man den request button betätigt, kommt im Log nur das hier:
                                  2019-02-24 17:36:15.516 - debug: upnp.0 Send Command for upnp.0.WANDevice_-_FRITZ!Box_7590.WANDevice.WANCommonInterfaceConfig.GetAddonInfos.request
                                  2019-02-24 17:36:15.743 - debug: upnp.0 response
                                  • Bluefox
                                    Ich habe einen Fehler bei request gefunden.
                                    Bitte noch mal probieren, jetzt aber direkt vom master und nicht vom Branch:
                                    cd /<dein Verzeichnis>/iobroker
                                    iobroker upnp stop
                                    npm i https://github.com/iobroker-community-adapters/ioBroker.upnp/tarball/master --production
                                    iobroker u upnp
                                    iobroker upnp restart
                                    • Neuschwansteini
                                      Super, läuft, Werte kommen jetzt. Keine Fehler im Log. Werte werden auch automatisch aktualisiert ganz ohne Script!
                                      Danke!
                                        sigi234 Forum Testing Most Active @Neuschwansteini last edited by sigi234
                                        Danke!
                                        Ja, funktioniert auch bei mir! V 1.0.5
                                        Danke👍
                                          sigi234 Forum Testing Most Active @sigi234 last edited by
                                          @sigi234 sagte in ioBroker.upnp - please test:
                                          Danke!
                                          Danke👍
                                          Ok, bekomme noch ständig folgende Info:
                                          upnp.0	2019-02-25 11:01:12.827	info	Found new device: http://192.168.178.23:49152/nasdevice.xml
                                          <root xmlns="urn:schemas-upnp-org:device-1-0">
                                          <specVersion>
                                          <major>1</major>
                                          <minor>0</minor>
                                          </specVersion>
                                          <device>
                                          <pnpx:X_hardwareId xmlns:pnpx="http://schemas.microsoft.com/windows/pnpx/2005/11">VEN_011A&DEV_0064&REV_01</pnpx:X_hardwareId>
                                          <pnpx:X_deviceCategory xmlns:pnpx="http://schemas.microsoft.com/windows/pnpx/2005/11">Storage.NAS</pnpx:X_deviceCategory>
                                          <pnpx:X_compatibleId xmlns:pnpx="http://schemas.microsoft.com/windows/pnpx/2005/11">urn:www-wdc-com:device:NetworkAttachedStorage</pnpx:X_compatibleId>
                                          <df:X_modelId xmlns:df="http://schemas.microsoft.com/windows/2008/09/devicefoundation">{02BF98D2-1B50-4a1f-83D9-A85402782702}</df:X_modelId>
                                          <df:X_containerId xmlns:df="http://schemas.microsoft.com/windows/2008/09/devicefoundation">{73656761-7465-7375-636b-0090a9f64500}</df:X_containerId>
                                          <modelURL>http://www.wdc.com/wdmycloud</modelURL>
                                          <deviceType>urn:schemas-wd-com:device:WdNAS-DEV_0064:1</deviceType>
                                          <friendlyName>WDMyCloud</friendlyName>
                                          <manufacturer>Western Digital Corporation</manufacturer>
                                          <manufacturerURL>http://www.wdc.com</manufacturerURL>
                                          <modelDescription>WD My Cloud</modelDescription>
                                          <modelName>WDMyCloud</modelName>
                                          <modelNumber>sq</modelNumber>
                                          <serialNumber>xxxxxxxxx</serialNumber>
                                          <UDN>uuid:xxxxx-7465-7375-636b-0090a9d57f26</UDN>
                                          <serviceList>
                                          <service>
                                          <serviceType>urn:schemas-microsoft-com:service:NULL:1</serviceType>
                                          <serviceId>urn:microsoft-com:serviceId:NULL</serviceId>
                                          <SCPDURL>/empty.xml</SCPDURL>
                                          <controlURL>/UD/?0</controlURL>
                                          <eventSubURL/>
                                          </service>
                                          </serviceList>
                                          <presentationURL>http://192.168.178.23</presentationURL>
                                          </device>
                                          </root>
                                          Ist eine Nas von WD, ich glaube das hat was mit der Anmeldung an der Nas zu tun.
                                          • SBorg
                                            Läuft jetzt soweit wieder, Danke, nur findet er im 10 Minuten-Raster neue Geräte (Sat-Receiver, eine VM mit Win7) bei mir, unter anderem sogar Teile der FritzBox doppelt:
                                            upnp.0	2019-02-25 11:29:02.309	info	Found new device: http://192.168.1.1:49000/avmnexusdesc.xml
                                            upnp.0	2019-02-25 11:29:02.289	info	Found new device: http://192.168.1.1:49000/avmnexusdesc.xml
                                            upnp.0	2019-02-25 11:28:57.754	info	Found new device: http://192.168.1.1:49000/igd2desc.xml
                                            upnp.0	2019-02-25 11:28:57.279	info	Found new device: http://192.168.1.1:49000/l2tpv3.xml
                                            upnp.0	2019-02-25 11:28:55.808	info	Found new device: http://192.168.1.1:49000/fboxdesc.xml
                                            upnp.0	2019-02-25 11:28:55.718	info	Found new device: http://192.168.1.1:49000/igddesc.xml
                                            upnp.0	2019-02-25 11:28:55.695	info	Found new device: http://192.168.1.1:49000/igddesc.xml
                                            upnp.0	2019-02-25 11:28:51.454	info	Found new device: http://192.168.1.1:49000/MediaServerDevDesc.xml
                                            upnp.0	2019-02-25 11:28:51.371	info	Found new device: http://192.168.1.1:49000/MediaServerDevDesc.xml
                                            31.7k
                                            79.8k
                                            adapter test
                                            18
                                            196
                                            19476
