    4. Node-Red
    5. Node Red startet nicht mehr nach Update auf 1.7
    • Ti He
      Ti He last edited by
      Moin hoffe um schnelle Hilfe da mein smart home drüber läuft.
      Folgende log wird ausgegeben:
      node-red.0 2019-02-24 12:15:57.086 info Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
      node-red.0 2019-02-24 12:15:52.071 info node-red exited with 1
      node-red.0 2019-02-24 12:15:52.065 warn at Function.Module._load (module.js:497:3)
      node-red.0 2019-02-24 12:15:52.065 warn at tryModuleLoad (module.js:505:12)
      node-red.0 2019-02-24 12:15:52.065 warn at Module.load (module.js:565:32)
      node-red.0 2019-02-24 12:15:52.065 warn at Object.Module._extensions..js (module.js:663:10)
      node-red.0 2019-02-24 12:15:52.065 warn at Module._compile (module.js:652:30)
      node-red.0 2019-02-24 12:15:52.065 warn at Object.<anonymous> (/opt/iobroker/node_modules/node-red/node_modules/fs-extra/lib/fs/index.js:3:11)
      node-red.0 2019-02-24 12:15:52.065 warn at require (internal/module.js:11:18)
      node-red.0 2019-02-24 12:15:52.065 warn at Module.require (module.js:596:17)
      node-red.0 2019-02-24 12:15:52.065 warn at Function.Module._load (module.js:474:25)
      node-red.0 2019-02-24 12:15:52.065 warn at Function.Module._resolveFilename (module.js:547:15)
      node-red.0 2019-02-24 12:15:52.065 warn Error: Cannot find module 'universalify'
      node-red.0 2019-02-24 12:15:52.065 warn ^
      node-red.0 2019-02-24 12:15:52.065 warn throw err;
      node-red.0 2019-02-24 12:15:52.065 warn module.js:549
      node-red.0 2019-02-24 12:15:51.054 info Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
      dieser widerholt sich andauernd.
        liv-in-sky last edited by liv-in-sky
        hast du mal überprüft was mit diesem module ist : universalify am besten deinstallieren und adapter neu starten
        Ti He 1 Reply Last reply Reply Quote 0
        • Ti He
          Ti He @liv-in-sky last edited by
          @liv-in-sky hab ein downgrade auf 1.6 durchgeführt dann lief es. Danach erneut update auf 1.7.1. Jetzt läuft es. danke
          81.1k
