    4. Uninstall - install problem
      Irgend etwas läuft da nicht sauber.
      Habe eben über den admin nach updates suchen wollen. Dabei zeigt das log mir auf einmal an, dass er alle möglichen Adapter killt und auf terminating geht.
      Nach dem wieder hochfahren gibt es wieder den Error 7, dass mindestens zwei Adapter doppelt laufen.
      host-quad-pi 2015-04-16 15:45:23 info Restart adapter system.adapter.hmm.0 because enabled
      host-quad-pi 2015-04-16 15:45:23 error instance system.adapter.hmm.0 terminated with code 7 (Adapter already running)
      host-quad-pi 2015-04-16 15:45:21 info instance system.adapter.hmm.0 started with pid 1554
      host-quad-pi 2015-04-16 15:45:17 info Restart adapter system.adapter.node-red.0 because enabled
      host-quad-pi 2015-04-16 15:45:17 error instance system.adapter.node-red.0 terminated with code 7 (Adapter already running)
      host-quad-pi 2015-04-16 15:45:15 info instance system.adapter.node-red.0 started with pid 1548
      host-quad-pi 2015-04-16 15:44:58 info Update repository "default" under "conf/sources-dist.json"
      host-quad-pi 2015-04-16 15:44:51 info Restart adapter system.adapter.hmm.0 because enabled
      host-quad-pi 2015-04-16 15:44:51 error instance system.adapter.hmm.0 terminated with code 7 (Adapter already running)
      host-quad-pi 2015-04-16 15:44:49 info instance system.adapter.hmm.0 started with pid 1510
      host-quad-pi 2015-04-16 15:44:45 info Restart adapter system.adapter.node-red.0 because enabled
      host-quad-pi 2015-04-16 15:44:45 error instance system.adapter.node-red.0 terminated with code 7 (Adapter already running)
      host-quad-pi 2015-04-16 15:44:41 info instance system.adapter.node-red.0 started with pid 1493
      javascript-0 2015-04-16 15:44:40 info received all states
      javascript-0 2015-04-16 15:44:40 info received all objects
      javascript-0 2015-04-16 15:44:37 info requesting all objects
      javascript-0 2015-04-16 15:44:37 info requesting all states
      javascript-0 2015-04-16 15:44:37 info starting. Version 0.3.0 in /opt/iobroker/node_modules/iobroker.javascript
      host-quad-pi 2015-04-16 15:44:35 info instance system.adapter.yr.0 terminated with code 0 (OK)
      host-quad-pi 2015-04-16 15:44:34 info instance system.adapter.javascript.0 started with pid 1485
      email-0 2015-04-16 15:44:31 info starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.email
      yr-0 2015-04-16 15:44:30 info got weather data from yr.no
      host-quad-pi 2015-04-16 15:44:29 info instance system.adapter.email.0 started with pid 1470
      yr-0 2015-04-16 15:44:28 info starting. Version 0.1.5 in /opt/iobroker/node_modules/iobroker.yr
      host-quad-pi 2015-04-16 15:44:26 info instance system.adapter.ical.0 terminated with code 0 (OK)
      host-quad-pi 2015-04-16 15:44:25 info instance system.adapter.yr.0 started with pid 1464
      host-quad-pi 2015-04-16 15:44:25 info instance scheduled system.adapter.yr.0 0 * * * *
      ical-0 2015-04-16 15:44:19 info processing URL: calendar1 http://192.168.2.225:5000/fbsharing/IQExBXbr
      host-quad-pi 2015-04-16 15:44:19 info Restart adapter system.adapter.hmm.0 because enabled
      host-quad-pi 2015-04-16 15:44:19 error instance system.adapter.hmm.0 terminated with code 7 (Adapter already running)
      host-quad-pi 2015-04-16 15:44:17 info instance system.adapter.hmm.0 started with pid 1449
      ical-0 2015-04-16 15:44:17 info starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.ical
      host-quad-pi 2015-04-16 15:44:14 info instance system.adapter.ical.0 started with pid 1443
      host-quad-pi 2015-04-16 15:44:13 info instance scheduled system.adapter.ical.0 0,30 * * * *
      host-quad-pi 2015-04-16 15:44:11 info Restart adapter system.adapter.node-red.0 because enabled
      host-quad-pi 2015-04-16 15:44:11 error instance system.adapter.node-red.0 terminated with code 7 (Adapter already running)
      host-quad-pi 2015-04-16 15:44:10 info instance system.adapter.dwd.0 terminated with code 0 (OK)
      host-quad-pi 2015-04-16 15:44:10 info instance system.adapter.node-red.0 started with pid 1428
      ping-0 2015-04-16 15:44:07 info starting. Version 0.1.4 in /opt/iobroker/node_modules/iobroker.ping
      host-quad-pi 2015-04-16 15:44:05 info instance system.adapter.ping.0 started with pid 1418
      dwd-0 2015-04-16 15:44:04 info setting states
      dwd-0 2015-04-16 15:44:04 info starting. Version 0.1.7 in /opt/iobroker/node_modules/iobroker.dwd
      web-0 2015-04-16 15:44:02 info http server listening on port 8082
      web-0 2015-04-16 15:44:02 info socket.io server listening on port 8082
      host-quad-pi 2015-04-16 15:44:01 info instance system.adapter.dwd.0 started with pid 1403
      host-quad-pi 2015-04-16 15:44:01 info instance scheduled system.adapter.dwd.0 5,20,35,50 * * * *
      web-0 2015-04-16 15:44:01 info starting. Version 0.2.6 in /opt/iobroker/node_modules/iobroker.web
      hm-rega-0 2015-04-16 15:43:57 info got state values
      hm-rega-0 2015-04-16 15:43:56 info request state values
      hm-rega-0 2015-04-16 15:43:56 info deleted 0 variables
      hm-rega-0 2015-04-16 15:43:56 info added/updated 64 variables
      hm-rega-0 2015-04-16 15:43:56 info got 64 variables
      hm-rega-0 2015-04-16 15:43:55 info deleted 0 programs
      hm-rega-0 2015-04-16 15:43:55 info added/updated 56 programs
      hm-rega-0 2015-04-16 15:43:54 info got 56 programs
      host-quad-pi 2015-04-16 15:43:53 info instance system.adapter.web.0 started with pid 1396
      hm-rega-0 2015-04-16 15:43:53 info added/updated rooms to enum.rooms
      hm-rega-0 2015-04-16 15:43:53 info added/updated functions to enum.functions
      hm-rega-0 2015-04-16 15:43:53 info added/updated 6 favorites to enum.favorites
      hm-rega-0 2015-04-16 15:43:53 info time difference local-ccu 0s
      hm-rega-0 2015-04-16 15:43:53 info ReGaHSS 192.168.2.186 up
      history-0 2015-04-16 15:43:53 info enabled logging of ping.0.quad-pi.192_168_2_120
      history-0 2015-04-16 15:43:53 info enabled logging of ping.0.quad-pi.192_168_2_7
      history-0 2015-04-16 15:43:53 info enabled logging of ping.0.quad-pi.192_168_2_142
      history-0 2015-04-16 15:43:53 info enabled logging of ping.0.quad-pi.192_168_2_75
      history-0 2015-04-16 15:43:53 info enabled logging of dwd.0.warning.severity
      history-0 2015-04-16 15:43:53 info enabled logging of hm-rpc.0.LEQ0081020.1.TEMPERATURE
      history-0 2015-04-16 15:43:53 info enabled logging of hm-rpc.0.LEQ0081020.1.HUMIDITY
      history-0 2015-04-16 15:43:53 info enabled logging of hm-rpc.0.KEQ0963067.1.TEMPERATURE
      history-0 2015-04-16 15:43:53 info enabled logging of hm-rpc.0.JEQ0459186.1.MOTION
      history-0 2015-04-16 15:43:53 info enabled logging of hm-rpc.0.JEQ0267518.1.TEMPERATURE
      history-0 2015-04-16 15:43:53 info enabled logging of hm-rpc.0.JEQ0267518.1.HUMIDITY
      history-0 2015-04-16 15:43:53 info enabled logging of hm-rpc.0.JEQ0140901.1.TEMPERATURE
      history-0 2015-04-16 15:43:53 info enabled logging of hm-rpc.0.JEQ0140901.1.HUMIDITY
      history-0 2015-04-16 15:43:53 info enabled logging of system.host.quad-pi.load
      history-0 2015-04-16 15:43:53 info enabled logging of system.host.quad-pi.mem
      hm-rega-0 2015-04-16 15:43:51 info subscribe hm-rpc.0.BidCoS-RF:50.PRESS_SHORT
      hm-rega-0 2015-04-16 15:43:51 info starting. Version 0.2.1 in /opt/iobroker/node_modules/iobroker.hm-rega
      history-0 2015-04-16 15:43:53 info starting. Version 0.1.3 in /opt/iobroker/node_modules/iobroker.history
      hm-rpc-0 2015-04-16 15:43:51 info xmlrpc -> 327 devices
      hm-rpc-0 2015-04-16 15:43:51 info xmlrpc <- listDevices ["hm-rpc.0"]
      hm-rpc-0 2015-04-16 15:43:51 info xmlrpc <- system.listMethods ["hm-rpc.0"]
      hm-rpc-0 2015-04-16 15:43:51 info xmlrpc -> 192.168.2.186:2001 init ["http://192.168.2.190:2001","hm-rpc.0"]
      hm-rpc-0 2015-04-16 15:43:51 info xmlrpc server is trying to listen on 192.168.2.190:2001
      hm-rpc-0 2015-04-16 15:43:50 info starting. Version 0.4.0 in /opt/iobroker/node_modules/iobroker.hm-rpc
      host-quad-pi 2015-04-16 15:43:50 info instance system.adapter.history.0 started with pid 1377
      hm-rpc-0 2015-04-16 15:43:48 error no connection to objects DB
      host-quad-pi 2015-04-16 15:43:46 info Update repository "default" under "conf/sources-dist.json"
      host-quad-pi 2015-04-16 15:43:46 info instance system.adapter.hm-rega.0 started with pid 1371
      admin-0 2015-04-16 15:43:45 info received all states
      admin-0 2015-04-16 15:43:45 info received all objects
      admin-0 2015-04-16 15:43:42 info Use link "http://localhost:8081" to configure.
      admin-0 2015-04-16 15:43:42 info http server listening on port 8081
      admin-0 2015-04-16 15:43:42 info requesting all objects
      admin-0 2015-04-16 15:43:42 info requesting all states
      admin-0 2015-04-16 15:43:42 info starting. Version 0.3.27 in /opt/iobroker/node_modules/iobroker.admin
      hmm-0 2015-04-16 15:43:42 warn Reconnection to DB.
      hmm-0 2015-04-16 15:43:41 warn Reconnection to DB.
      host-quad-pi 2015-04-16 15:43:41 info instance system.adapter.hm-rpc.0 started with pid 1356
      host-quad-pi 2015-04-16 15:43:37 info instance system.adapter.admin.0 started with pid 1354
      host-quad-pi 2015-04-16 15:43:37 info starting 15 instances
      host-quad-pi 2015-04-16 15:43:37 info 18 instances found
      host-quad-pi 2015-04-16 15:43:37 info InMemoryDB connected
      node-red-0 2015-04-16 15:43:38 warn Reconnection to DB.
      inMem-objects 2015-04-16 15:43:37 info listening on port 9001
      inMem-states 2015-04-16 15:43:37 info listening on port 9000
      host-quad-pi 2015-04-16 15:43:37 info ip addresses: 192.168.2.190
      host-quad-pi 2015-04-16 15:43:37 info hostname: quad-pi
      host-quad-pi 2015-04-16 15:43:37 info Copyright (c) 2014-2015 bluefox, hobbyquaker
      host-quad-pi 2015-04-16 15:43:37 info ioBroker.js-controller version 0.6.1 js-controller starting
      hmm-0 2015-04-16 15:43:36 info hmm exited with 0
      node-red-0 2015-04-16 15:43:35 info node-red exited with 0
      email-0 2015-04-16 15:43:35 info terminating with timeout
      ping-0 2015-04-16 15:43:35 info terminating with timeout
      javascript-0 2015-04-16 15:43:34 info terminating
      admin-0 2015-04-16 15:43:34 info terminating
      web-0 2015-04-16 15:43:34 info terminating
      hm-rega-0 2015-04-16 15:43:34 info terminating
      history-0 2015-04-16 15:43:34 info terminating
      TypeError: 2015-04-16 15:43:33 error at Timer.listOnTimeout [as ontimeout] (timers.js:110:15)
      TypeError: 2015-04-16 15:43:33 error at null._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/statesInMemServer.js:464:25)
      TypeError: 2015-04-16 15:43:33 error at States.change (/opt/iobroker/node_modules/iobroker.js-controller/controller.js:142:48)
      TypeError: 2015-04-16 15:43:33 error Cannot read property 'time' of undefined
      hm-rpc-0 2015-04-16 15:43:34 info terminating
      hmm-0 2015-04-16 15:43:33 info kill hmm task
      node-red-0 2015-04-16 15:43:33 info kill node-red task
      web-0 2015-04-16 15:43:33 info terminated http server on port 8082
      web-0 2015-04-16 15:43:33 info terminating http server on port 8082
      hm-rpc-0 2015-04-16 15:43:33 info xmlrpc -> 192.168.2.186:2001 init ["http://192.168.2.190:2001",""]
      admin-0 2015-04-16 15:43:33 info terminating http server on port 8081
      uncaught 2015-04-16 15:43:33 error exception: Cannot read property 'time' of undefined
      Daraufhin habe ich über den Reiter hosts einen restart des RPi2 ausgelöst.
      jetzt beschwert er sich beim runterfahren, dass diverse Adapetr immer noch laufen.
      entsprechend taucht da auch der error code 7 wieder auf
      quad-pi	2015-04-16 15:45:48	info	host.quad-pi Restart adapter system.adapter.admin.0 because enabled
      quad-pi	2015-04-16 15:45:48	error	host.quad-pi instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
      history.0	2015-04-16 15:45:43	warn	history.0 Reconnection to DB.
      web.0	2015-04-16 15:45:45	warn	web.0 Reconnection to DB.
      javascript.0	2015-04-16 15:45:45	warn	javascript.0 Reconnection to DB.
      history.0	2015-04-16 15:45:42	warn	history.0 Reconnection to DB.
      hm-rpc.0	2015-04-16 15:45:47	warn	hm-rpc.0 Reconnection to DB.
      hm-rega.0	2015-04-16 15:45:43	warn	hm-rega.0 Reconnection to DB.
      ping.0	2015-04-16 15:45:47	warn	ping.0 Reconnection to DB.
      email.0	2015-04-16 15:45:47	warn	email.0 Reconnection to DB.
      quad-pi	2015-04-16 15:45:47	info	host.quad-pi instance system.adapter.hm-rpc.0 started with pid 1599
      admin.0	2015-04-16 15:45:43	warn	admin.0 Reconnection to DB.
      quad-pi	2015-04-16 15:45:37	info	Adapter javascript still running
      quad-pi	2015-04-16 15:45:37	info	Adapter email still running
      quad-pi	2015-04-16 15:45:37	info	Adapter ping still running
      quad-pi	2015-04-16 15:45:37	info	Adapter web still running
      quad-pi	2015-04-16 15:45:37	info	Adapter history still running
      quad-pi	2015-04-16 15:45:37	info	Adapter hm-rega still running
      quad-pi	2015-04-16 15:45:37	info	Adapter hm-rpc still running
      quad-pi	2015-04-16 15:45:37	info	Adapter admin still running
      quad-pi	2015-04-16 15:45:37	info	host.quad-pi force terminated after 10s
      quad-pi	2015-04-16 15:45:37	info	host.quad-pi received SIGTERM
      quad-pi	2015-04-16 15:45:36	info	host.quad-pi received SIGTERM
      quad-pi	2015-04-16 15:45:35	info	host.quad-pi received SIGTERM
      quad-pi	2015-04-16 15:45:34	info	host.quad-pi received SIGTERM
      quad-pi	2015-04-16 15:45:33	info	host.quad-pi received SIGTERM
      host-quad-pi	2015-04-16 15:45:32	info	received SIGTERM
      host-quad-pi	2015-04-16 15:45:31	info	received SIGTERM
      host-quad-pi	2015-04-16 15:45:30	info	received SIGTERM
      host-quad-pi	2015-04-16 15:45:29	info	received SIGTERM
      host-quad-pi	2015-04-16 15:45:28	info	received SIGTERM
      host-quad-pi	2015-04-16 15:45:27	info	received SIGTERM
      iobroker	2015-04-16 15:45:26	info	exit 0
      iobroker	2015-04-16 15:45:26	info	Starting node restart.js
      iobroker	2015-04-16 15:45:26	info	_restart
      ich wollte eigentlich nicht wieder rebooten. Dann läuft er meistens stabil.
      in den rechten Spalten wechselt es dauern von rot nach grün 😞
      jetzt ist doch reboot angesagt 😞
      Rainer
      • Bluefox
        Bluefox last edited by
        Es hat sich irgendwas verhackt. Da hilft nur reboot.
        Es gibt 0.6.3, wo update wieder funktionieren soll.
          starfish last edited by
          kann ich bestätigen
          > in den rechten Spalten wechselt es dauern von rot nach grün :(
          wie auch die Logeinträge sehen bei mir gleich aus.
          • derAuge
            derAuge last edited by
            @Bluefox:
            Es gibt 0.6.3, wo update wieder funktionieren soll. `
            Was ist nun zu tun?
            root@pi2:/mnt/ioBroker/iobroker# iobroker restart
            module.js:340
                throw err;
            Error: Cannot find module '/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/iobroker.js'
                at Function.Module._resolveFilename (module.js:338:15)
                at Function.Module._load (module.js:280:25)
                at Function.Module.runMain (module.js:497:10)
                at startup (node.js:119:16)
                at node.js:935:3
            • Bluefox
              cd /mnt/ioBroker/iobroker.Pi2/
              npm install iobroker.js-controller
              ./iobroker start
              • Bluefox
                @starfish:
                kann ich bestätigen
                wie auch die Logeinträge sehen bei mir gleich aus. `
                Reboot
                  Auch bei controller 0.6.3 und neuem admin bleibt es dabei, dass bei einem ./iobroker restart einzelne Adapter nicht beendet werden (erst mal nur node-red und hmm) und nach dem restart doppelt laufen.
                  Dadurch kommt es andauernd zu terminating code 7
                  Nach reboot ist gut!
                  Gesendet von meinem LIFETAB_S785X mit Tapatalk
                  • derAuge
                    INSTALL lief durch
                    root@pi2:/mnt/ioBroker/iobroker# npm install iobroker.js-controller
                    > ws@0.5.0 install /mnt/ioBroker/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io/node_m                                           odules/engine.io/node_modules/ws
                    > (node-gyp rebuild 2> builderror.log) || (exit 0)
                    make: Entering directory '/mnt/ioBroker/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io                                           /node_modules/engine.io/node_modules/ws/build'
                      CXX(target) Release/obj.target/bufferutil/src/bufferutil.o
                      SOLINK_MODULE(target) Release/obj.target/bufferutil.node
                      SOLINK_MODULE(target) Release/obj.target/bufferutil.node: Finished
                      COPY Release/bufferutil.node
                      CXX(target) Release/obj.target/validation/src/validation.o
                      SOLINK_MODULE(target) Release/obj.target/validation.node
                      SOLINK_MODULE(target) Release/obj.target/validation.node: Finished
                      COPY Release/validation.node
                    make: Leaving directory '/mnt/ioBroker/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io/                                           node_modules/engine.io/node_modules/ws/build'
                    > ws@0.4.31 install /mnt/ioBroker/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-clien                                           t/node_modules/engine.io-client/node_modules/ws
                    make: Entering directory '/mnt/ioBroker/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io                                           -client/node_modules/engine.io-client/node_modules/ws/build'
                    make: Leaving directory '/mnt/ioBroker/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-cl           ient/node_modules/ws/build'
                    > iobroker.js-controller@0.6.3 install /mnt/ioBroker/iobroker/node_modules/iobroker.js-controller
                    > node lib/setup.js setup first
                    iobroker.js-controller@0.6.3 node_modules/iobroker.js-controller
                    ├── mime@1.3.4
                    ├── daemonize2@0.4.2
                    ├── node-schedule@0.1.13
                    ├── ncp@2.0.0
                    ├── adm-zip@0.4.7
                    ├── node.extend@1.1.3 (is@2.1.0)
                    ├── yargs@3.7.2 (camelcase@1.0.2, decamelize@1.0.0, window-size@0.1.0, wordwrap@0.0.2)
                    ├── winston@1.0.0 (cycle@1.0.3, stack-trace@0.0.9, eyes@0.1.8, isstream@0.1.2, pkginfo@0.3.0, async@0.9.0, colors@1.0.3)
                    ├── tar.gz@0.1.1 (commander@1.1.1, tar@0.1.20, fstream@0.1.31)
                    ├── request@2.55.0 (caseless@0.9.0, json-stringify-safe@5.0.0, aws-sign2@0.5.0, forever-agent@0.6.1, stringstream@0.0.4, tunnel-agent@0.4.0, oauth-sign@0.6.0, isstream@0.1.2, node-uuid@1.4.3, qs@2.4.1, combined-stream@0.0.7, form-data@0.2.0, mime-types@2.0.10, http-signature@0.10.1, bl@0.9.4, tough-cookie@0.12.1, hawk@2.3.1, har-validator@1.6.1)
                    ├── socket.io@1.3.5 (debug@2.1.0, has-binary-data@0.1.3, socket.io-adapter@0.3.1, socket.io-parser@2.2.4, engine.io@1.5.1)
                    ├── socket.io-client@1.3.5 (to-array@0.1.3, indexof@0.0.1, component-bind@1.0.0, debug@0.7.4, object-component@0.0.3, backo2@1.0.2, component-emitter@1.1.2, has-binary@0.1.6, parseuri@0.0.2, socket.io-parser@2.2.4, engine.io-client@1.5.1)
                    └── npm@2.7.6
                    Jedoch ist etwas mit dem symLink
                    root@pi2:/mnt/ioBroker/iobroker# iobroker start
                    module.js:340
                        throw err;
                        at node.js:935:3
                    so startet der controler
                    root@pi2:/mnt/ioBroker/iobroker# ./iobroker start
                    Starting ioBroker controller daemon...
                    ioBroker controller daemon started. PID: 2821
                    aber Admin wird nicht gestartet
                    root@pi2:/mnt/ioBroker/iobroker# ps -A |grep io
                       10 ?        00:00:00 migration/0
                       11 ?        00:00:00 migration/1
                       15 ?        00:00:00 migration/2
                       19 ?        00:00:00 migration/3
                       30 ?        00:00:00 bioset
                       33 ?        00:00:00 rpciod
                       37 ?        00:00:00 nfsiod
                       49 ?        00:00:00 DWC Notificatio
                     2821 ?        00:00:03 io.js-controlle
                    • Bluefox
                      @derAuge:
                      INSTALL lief durch
                      ├── mime@1.3.4
                      ├── ncp@2.0.0
                      ├── adm-zip@0.4.7
                      └── npm@2.7.6
                      module.js:340
                          throw err;
                          at node.js:935:3
                      Bei dir ist je etwas schiff:
                      installiert nach: /mnt/ioBroker/iobroker
                      Gestartet wird aber aus: /mnt/ioBroker/iobroker.Pi2/
                      • derAuge
                        ` > Bei dir ist je etwas schiff:
                        Gestartet wird aber aus: /mnt/ioBroker/iobroker.Pi2/ `
                        Jau …. DANK 😉
                        mann sollte doch alle Gedanken dabei haben.
                        Nun läuft es 🙂
                        dann mach ich mich mal ans Update der Adapter
                        • derAuge
                          • derAuge
                            und auf 0.4.2
                            iobroker	2015-04-17 22:40:10	info	exit 8
                            iobroker	2015-04-17 22:40:10	error	at Timer.listOnTimeout [as ontimeout] (timers.js:112:15)
                            iobroker	2015-04-17 22:40:10	error	at null._onTimeout (/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/lib/setup.js:1530:27)
                            iobroker	2015-04-17 22:40:10	error	at new ObjectsInMemServer (/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/lib/objectsInMemServer.js:146:7)
                            iobroker	2015-04-17 22:40:10	error	at /mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/lib/objectsInMemServer.js:139:9
                            iobroker	2015-04-17 22:40:10	error	at _initWebServer (/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/lib/objectsInMemServer.js:958:24)
                            iobroker	2015-04-17 22:40:10	error	at Server.listen (net.js:1139:5)
                            iobroker	2015-04-17 22:40:10	error	at listen (net.js:1065:10)
                            iobroker	2015-04-17 22:40:10	error	at Server._listen2 (net.js:1043:14)
                            iobroker	2015-04-17 22:40:10	error	at errnoException (net.js:905:11)
                            iobroker	2015-04-17 22:40:10	error	Error: listen EADDRINUSE
                            iobroker	2015-04-17 22:40:10	error	^
                            iobroker	2015-04-17 22:40:10	error	throw er; // Unhandled 'error' event
                            iobroker	2015-04-17 22:40:10	error	events.js:72
                            iobroker	2015-04-17 22:39:58	info	upgrade admin
                            kann das auch an meiner Installation liegen?
                              @Homoran:
                              Nach reboot ist gut! `
                              reboot tut gut - hier auch. Danke.
                                push!
                                @Homoran:
                                Gesendet von meinem LIFETAB_S785X mit Tapatalk `
                                  akamia last edited by
                                  Mit 0.6.4 läuft es perfekt. Keine Fehlermeldungen mehr bei der Installation eines Adapters. Vielen Dank.
                                  16367
