    4. Neuer admin-Adapter
    Neuer admin-Adapter
    • derAuge
      derAuge last edited by
      hi,
      ich denke das passt hier rein….
      Habe heute morgen mal auf einer VM eine neuinstallation durchgeführt und auch einige Adappter installiert.
      Problem macht nun der "node-red"
      node-red.0	2015-04-18 06:57:09	warn	node-red.0 18 Apr 06:57:09 - [warn] [redisout] Error: Cannot find module 'redis' 18 Apr 06:57:09 - [warn] ------------------------------------------ 18 Apr 06:57:09 - [info] User Directory : /opt/iobr
      node-red.0	2015-04-18 06:57:09	warn	node-red.0 18 Apr 06:57:09 - [warn] [rpi-gpio] Info : Ignoring Raspberry Pi specific node.
      node-red.0	2015-04-18 06:57:09	warn	node-red.0 18 Apr 06:57:09 - [warn] [arduino] Error: Cannot find module 'arduino-firmata'
      node-red.0	2015-04-18 06:57:09	warn	node-red.0 18 Apr 06:57:09 - [warn] ------------------------------------------
      node-red.0	2015-04-18 06:57:08	warn	node-red.0 js-bson: Failed to load c++ bson extension, using pure JS version
      node-red.0	2015-04-18 06:57:07	warn	node-red.0 js-bson: Failed to load c++ bson extension, using pure JS version
      node-red-0	2015-04-18 06:56:55	info	Starting node-red: /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/node_modules/iobroker.node-red/userdata/settings.js
      node-red-0	2015-04-18 06:56:55	info	starting. Version 0.1.9 in /opt/iobroker/node_modules/iobroker.node-red
      iobroker	2015-04-18 06:56:53	info	exit 0
      iobroker	2015-04-18 06:56:53	info	object system.adapter.node-red.0 created
      host-VMioBrokerMaster	2015-04-18 06:56:53	info	instance system.adapter.node-red.0 started with pid 3629
      host-VMioBrokerMaster	2015-04-18 06:56:53	info	object change system.adapter.node-red.0
      iobroker	2015-04-18 06:56:53	info	object system.adapter.node-red.0.alive created
      iobroker	2015-04-18 06:56:53	info	object system.adapter.node-red.0.connected created
      iobroker	2015-04-18 06:56:53	info	object system.adapter.node-red.0.memHeapUsed created
      iobroker	2015-04-18 06:56:53	info	object system.adapter.node-red.0.memHeapTotal created
      iobroker	2015-04-18 06:56:53	info	object system.adapter.node-red.0.memRss created
      iobroker	2015-04-18 06:56:53	info	object system.adapter.node-red.0.uptime created
      iobroker	2015-04-18 06:56:53	info	object node-red.0 created
      iobroker	2015-04-18 06:56:53	info	create instance node-red
      iobroker	2015-04-18 06:56:53	info	object system.adapter.node-red created
      iobroker	2015-04-18 06:56:53	info	upload node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/index.html index.html text/html
      iobroker	2015-04-18 06:56:53	info	upload node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/node-red.png node-red.png image/png
      iobroker	2015-04-18 06:56:53	info	got /opt/iobroker/node_modules/iobroker.node-red/admin
      iobroker	2015-04-18 06:56:53	info	install adapter node-red
      iobroker	2015-04-18 06:56:37	info	npm WARN optional dep failed, continuing iconv@2.1.6
      iobroker	2015-04-18 06:56:37	info	gyp ERR! not ok
      iobroker	2015-04-18 06:56:37	info	gyp ERR! node-gyp -v v1.0.1
      iobroker	2015-04-18 06:56:37	info	gyp ERR! node -v v0.10.38
      iobroker	2015-04-18 06:56:37	info	command "node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/irc/node_modules
      iobroker	2015-04-18 06:56:37	info	ERR! System Linux 3.2.0-4-amd64gyp ERR!
      iobroker	2015-04-18 06:56:37	info	ERR! stack at /usr/lib/node_modules/npm/node_modules/which/which.js:57:16gyp ERR! stack at Object.oncomplete (evalmachine.:108:15)
      iobroker	2015-04-18 06:56:37	info	ERR! stack at E (/usr/lib/node_modules/npm/node_modules/which/which.js:46:29)gyp
      iobroker	2015-04-18 06:56:37	info	at F (/usr/lib/node_modules/npm/node_modules/which/which.js:43:28)gyp
      iobroker	2015-04-18 06:56:37	info	stack Error: not found: makegyp ERR! stack
      iobroker	2015-04-18 06:56:37	info	build error
      iobroker	2015-04-18 06:56:27	info	npm WARN optional dep failed, continuing bufferutil@1.0.1
      iobroker	2015-04-18 06:56:27	info	gyp ERR! not ok
      iobroker	2015-04-18 06:56:27	info	gyp ERR! node-gyp -v v1.0.1
      iobroker	2015-04-18 06:56:27	info	gyp ERR! node -v v0.10.38
      iobroker	2015-04-18 06:56:27	info	gyp ERR! cwd /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/ws/node_modules/bufferutil
      iobroker	2015-04-18 06:56:27	info	gyp ERR! command "node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      iobroker	2015-04-18 06:56:27	info	gyp ERR! System Linux 3.2.0-4-amd64
      iobroker	2015-04-18 06:56:27	info	gyp ERR! stack at Object.oncomplete (evalmachine.:108:15)
      iobroker	2015-04-18 06:56:27	info	gyp ERR! stack at /usr/lib/node_modules/npm/node_modules/which/which.js:57:16
      iobroker	2015-04-18 06:56:27	info	gyp ERR! stack at E (/usr/lib/node_modules/npm/node_modules/which/which.js:46:29)
      iobroker	2015-04-18 06:56:27	info	gyp ERR! stack at F (/usr/lib/node_modules/npm/node_modules/which/which.js:43:28)
      iobroker	2015-04-18 06:56:27	info	ERR! build error gyp ERR! stack Error: not found: make
      iobroker	2015-04-18 06:56:24	info	utf-8-validate@1.0.1
      iobroker	2015-04-18 06:56:24	info	optional dep failed, continuing
      iobroker	2015-04-18 06:56:24	info	WARN
      iobroker	2015-04-18 06:56:24	info	npm
      iobroker	2015-04-18 06:56:24	info	not ok
      iobroker	2015-04-18 06:56:24	info	gyp ERR! node-gyp -v v1.0.1gyp ERR!
      iobroker	2015-04-18 06:56:24	info	gyp ERR! node -v v0.10.38
      iobroker	2015-04-18 06:56:24	info	ERR! command "node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/ws/node_mo
      iobroker	2015-04-18 06:56:24	info	gyp ERR! stack at Object.oncomplete (evalmachine.:108:15)gyp ERR! System Linux 3.2.0-4-amd64
      iobroker	2015-04-18 06:56:24	info	gyp ERR! stack at E (/usr/lib/node_modules/npm/node_modules/which/which.js:46:29)gyp ERR! stack at /usr/lib/node_modules/npm/node_modules/which/which.js:57:16
      iobroker	2015-04-18 06:56:24	info	ERR! stack Error: not found: makegyp ERR! stack at F (/usr/lib/node_modules/npm/node_modules/which/which.js:43:28)
      iobroker	2015-04-18 06:56:24	info	build error
      iobroker	2015-04-18 06:56:23	info	npm WARN optional dep failed, continuing bcrypt@0.8.1
      iobroker	2015-04-18 06:56:23	info	gyp ERR! not ok
      iobroker	2015-04-18 06:56:23	info	gyp ERR! node-gyp -v v1.0.1
      iobroker	2015-04-18 06:56:23	info	gyp ERR! node -v v0.10.38
      iobroker	2015-04-18 06:56:23	info	gyp ERR! cwd /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/bcrypt
      iobroker	2015-04-18 06:56:23	info	gyp ERR! command "node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      iobroker	2015-04-18 06:56:23	info	gyp ERR! System Linux 3.2.0-4-amd64
      iobroker	2015-04-18 06:56:23	info	stack at /usr/lib/node_modules/npm/node_modules/which/which.js:57:16gyp ERR! stack at Object.oncomplete (evalmachine.:108:15)
      iobroker	2015-04-18 06:56:23	info	gyp ERR! stack at E (/usr/lib/node_modules/npm/node_modules/which/which.js:46:29)
      iobroker	2015-04-18 06:56:23	info	stack Error: not found: makegyp ERR! stack at F (/usr/lib/node_modules/npm/node_modules/which/which.js:43:28)
      iobroker	2015-04-18 06:56:23	info	ERR!
      iobroker	2015-04-18 06:56:23	info	build error
      iobroker	2015-04-18 06:56:17	info	optional dep failed, continuing node-icu-charset-detector@0.0.7
      iobroker	2015-04-18 06:56:17	info	WARN
      iobroker	2015-04-18 06:56:17	info	npm
      iobroker	2015-04-18 06:56:17	info	gyp ERR! not ok
      iobroker	2015-04-18 06:56:17	info	gyp ERR! node-gyp -v v1.0.1
      iobroker	2015-04-18 06:56:17	info	gyp ERR! node -v v0.10.38
      iobroker	2015-04-18 06:56:17	info	gyp ERR! cwd /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/irc/node_modules/node-icu-charset-detector
      iobroker	2015-04-18 06:56:17	info	gyp ERR! command "node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      iobroker	2015-04-18 06:56:17	info	gyp ERR! System Linux 3.2.0-4-amd64
      iobroker	2015-04-18 06:56:17	info	gyp ERR! stack at Object.oncomplete (evalmachine.:108:15)
      iobroker	2015-04-18 06:56:17	info	gyp ERR! stack at /usr/lib/node_modules/npm/node_modules/which/which.js:57:16
      iobroker	2015-04-18 06:56:17	info	gyp ERR! stack at E (/usr/lib/node_modules/npm/node_modules/which/which.js:46:29)
      iobroker	2015-04-18 06:56:17	info	gyp ERR! stack at F (/usr/lib/node_modules/npm/node_modules/which/which.js:43:28)
      iobroker	2015-04-18 06:56:17	info	gyp ERR! build error gyp ERR! stack Error: not found: make
      iobroker	2015-04-18 06:55:56	info	npm install iobroker.node-red --production --prefix "/opt/iobroker" (System call)
      iobroker	2015-04-18 06:55:51	info	add node-red
      • derAuge
        Hallo bluefox,
        das admin-Interface sieht nun sehr aufgeräumt aus. Super
        ist es vielleicht möglich in der "tree"-Ansicht eine Überschrift für "Installierte Adapter" zu machen?
        Ja ich habe gesehen, das es auch einen Filter gibt.
        Jedoch vermischen wir aktuell das angebot von adaptern
        Nach der Installation eines Adapters aus einer anderen Kategorie wird diese dann in "Allgemein" geführt
        Ist nur so eine Idee
        derAuge
        'Mann' sieht sich gleich
        • derAuge
          Hi Bluefox,
          habe zwischendurch mein VM-System auf den Stand gebracht
          Update Admin:
          host-VMioBrokerMaster	2015-04-19 13:05:41	info	Restart adapter system.adapter.admin.0 because enabled
          host-VMioBrokerMaster	2015-04-19 13:05:41	error	instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
          host-VMioBrokerMaster	2015-04-19 13:05:40	info	instance system.adapter.admin.0 started with pid 2694
          iobroker	2015-04-19 13:05:35	info	exit 0
          iobroker	2015-04-19 13:05:29	info	Cannot parse filehttps://raw.githubusercontent.com/ioBroker/ioBroker.admin/master/io-package.json
          iobroker	2015-04-19 13:05:29	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.admin/master/io-package.json. Error: Error: ETIMEDOUT
          iobroker	2015-04-19 13:05:24	info	Timeout by read all package.json (33) seconds
          iobroker	2015-04-19 13:05:19	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.zwave/master/package.json. Error: Error: ETIMEDOUT
          iobroker	2015-04-19 13:05:19	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.web/master/package.json. Error: Error: ETIMEDOUTCannot download json from https://raw.githubusercontent.com/ioBroker/ioBr
          iobroker	2015-04-19 13:05:19	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.vis/master/package.json. Error: Error: ETIMEDOUT
          iobroker	2015-04-19 13:05:19	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.sonos/master/package.json. Error: Error: ETIMEDOUT
          iobroker	2015-04-19 13:05:19	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.rickshaw/master/package.json. Error: Error: ETIMEDOUT
          iobroker	2015-04-19 13:05:19	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.owfs/master/package.json. Error: Error: ETIMEDOUTCannot download json from https://raw.githubusercontent.com/ioBroker/ioB
          iobroker	2015-04-19 13:05:19	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.onkyo/master/package.json. Error: Error: ETIMEDOUT
          iobroker	2015-04-19 13:05:19	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.socketio/master/package.json. Error: Error: ETIMEDOUT
          iobroker	2015-04-19 13:05:19	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.simple-api/master/package.json. Error: Error: ETIMEDOUT
          iobroker	2015-04-19 13:05:19	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.ping/master/package.json. Error: Error: ETIMEDOUTCannot download json from https://raw.githubusercontent.com/ioBroker/ioB
          iobroker	2015-04-19 13:05:19	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.node-red/master/package.json. Error: Error: ETIMEDOUT
          iobroker	2015-04-19 13:05:19	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.megad/master/package.json. Error: Error: ETIMEDOUTCannot download json from https://raw.githubusercontent.com/ioBroker/io
          iobroker	2015-04-19 13:05:19	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.legacy/master/package.json. Error: Error: ETIMEDOUT
          iobroker	2015-04-19 13:05:19	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.knx/master/package.json. Error: Error: ETIMEDOUT
          iobroker	2015-04-19 13:05:19	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.js-controller/master/package.json. Error: Error: ETIMEDOUT
          iobroker	2015-04-19 13:05:19	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.javascript/master/package.json. Error: Error: ETIMEDOUT
          iobroker	2015-04-19 13:05:19	info	Cannot download json from https://raw.githubusercontent.com/husky-koglhof/ioBroker.hmm/master/package.json. Error: Error: ETIMEDOUTCannot download json from https://raw.githubusercontent.com/ioBroker
          iobroker	2015-04-19 13:05:19	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.hue/master/package.json. Error: Error: ETIMEDOUT
          iobroker	2015-04-19 13:05:19	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.hm-rpc/master/package.json. Error: Error: ETIMEDOUT
          iobroker	2015-04-19 13:05:19	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.hm-rega/master/package.json. Error: Error: ETIMEDOUT
          iobroker	2015-04-19 13:05:19	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.history/master/package.json. Error: Error: ETIMEDOUT
          iobroker	2015-04-19 13:05:19	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.email/master/package.json. Error: Error: ETIMEDOUT
          iobroker	2015-04-19 13:05:19	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.cul/master/package.json. Error: Error: ESOCKETTIMEDOUTCannot download json from https://raw.githubusercontent.com/ioBroke
          iobroker	2015-04-19 13:05:19	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.b-control-em/master/package.json. Error: Error: ESOCKETTIMEDOUT
          iobroker	2015-04-19 13:05:19	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.artnet/master/package.json. Error: Error: ESOCKETTIMEDOUT
          iobroker	2015-04-19 13:05:18	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.admin/master/package.json. Error: Error: ETIMEDOUT
          iobroker	2015-04-19 13:05:13	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.yr/master/io-package.json. Error: Error: ETIMEDOUTCannot download json from https://raw.githubusercontent.com/ioBroker/io
          iobroker	2015-04-19 13:05:13	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.vis/master/io-package.json. Error: Error: ETIMEDOUTCannot download json from https://raw.githubusercontent.com/ioBroker/i
          iobroker	2015-04-19 13:05:13	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.sonos/master/io-package.json. Error: Error: ETIMEDOUT
          iobroker	2015-04-19 13:05:13	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.rickshaw/master/io-package.json. Error: Error: ETIMEDOUT
          iobroker	2015-04-19 13:05:13	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.pushover/master/io-package.json. Error: Error: ETIMEDOUT
          iobroker	2015-04-19 13:05:13	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.owfs/master/io-package.json. Error: Error: ETIMEDOUT
          iobroker	2015-04-19 13:05:13	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.socketio/master/io-package.json. Error: Error: ETIMEDOUTCannot download json from https://raw.githubusercontent.com/ioBro
          iobroker	2015-04-19 13:05:13	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.sayit/master/io-package.json. Error: Error: ETIMEDOUTCannot download json from https://raw.githubusercontent.com/ioBroker
          iobroker	2015-04-19 13:05:13	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.ping/master/io-package.json. Error: Error: ETIMEDOUT
          iobroker	2015-04-19 13:05:13	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.mqtt/master/io-package.json. Error: Error: ETIMEDOUTCannot download json from https://raw.githubusercontent.com/ioBroker/
          iobroker	2015-04-19 13:05:13	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.legacy/master/io-package.json. Error: Error: ETIMEDOUTCannot download json from https://raw.githubusercontent.com/ioBroke
          iobroker	2015-04-19 13:05:13	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.knx/master/io-package.json. Error: Error: ETIMEDOUT
          iobroker	2015-04-19 13:05:12	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.javascript/master/io-package.json. Error: Error: ETIMEDOUTCannot download json from https://raw.githubusercontent.com/ioB
          iobroker	2015-04-19 13:05:12	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.ical/master/io-package.json. Error: Error: ETIMEDOUT
          iobroker	2015-04-19 13:05:12	info	Cannot download json from https://raw.githubusercontent.com/husky-koglhof/ioBroker.hmm/master/io-package.json. Error: Error: ETIMEDOUT
          iobroker	2015-04-19 13:05:12	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.hue/master/io-package.json. Error: Error: ETIMEDOUT
          iobroker	2015-04-19 13:05:12	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.hm-rpc/master/io-package.json. Error: Error: ETIMEDOUT
          iobroker	2015-04-19 13:05:12	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.hm-rega/master/io-package.json. Error: Error: ETIMEDOUT
          iobroker	2015-04-19 13:05:12	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.history/master/io-package.json. Error: Error: ETIMEDOUT
          iobroker	2015-04-19 13:05:12	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.email/master/io-package.json. Error: Error: ETIMEDOUT
          iobroker	2015-04-19 13:05:12	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.dwd/master/io-package.json. Error: Error: ESOCKETTIMEDOUT
          iobroker	2015-04-19 13:05:12	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.cul/master/io-package.json. Error: Error: ESOCKETTIMEDOUT
          iobroker	2015-04-19 13:05:12	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.b-control-em/master/io-package.json. Error: Error: ESOCKETTIMEDOUT
          iobroker	2015-04-19 13:05:12	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.artnet/master/io-package.json. Error: Error: ESOCKETTIMEDOUT
          iobroker	2015-04-19 13:05:12	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.admin/master/io-package.json. Error: Error: ETIMEDOUT
          host-VMioBrokerMaster	2015-04-19 13:05:10	info	Restart adapter system.adapter.admin.0 because enabled
          host-VMioBrokerMaster	2015-04-19 13:05:10	error	instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
          host-VMioBrokerMaster	2015-04-19 13:05:09	info	instance system.adapter.admin.0 started with pid 2688
          iobroker	2015-04-19 13:05:05	info	upgrade admin
          derAuge
          PS: Hoffe die Heimfahrt war Stressfrei
          EDIT: Zweiter Versuch
          admin-0	2015-04-19 13:28:21	info	received all states
          admin-0	2015-04-19 13:28:21	info	received all objects
          admin-0	2015-04-19 13:28:21	info	Use link "http://localhost:8081" to configure.
          admin-0	2015-04-19 13:28:21	info	http server listening on port 8081
          admin-0	2015-04-19 13:28:21	info	requesting all objects
          admin-0	2015-04-19 13:28:21	info	requesting all states
          admin-0	2015-04-19 13:28:20	info	starting. Version 0.4.3 in /opt/iobroker/node_modules/iobroker.admin
          host-VMioBrokerMaster	2015-04-19 13:28:15	info	instance system.adapter.admin.0 terminated with code 0 (OK)
          host-VMioBrokerMaster	2015-04-19 13:28:14	info	instance system.adapter.admin.0 started with pid 2669
          admin-0	2015-04-19 13:28:14	info	terminating
          admin-0	2015-04-19 13:28:13	info	terminating http server on port 8081
          iobroker	2015-04-19 13:28:12	info	exit 0
          iobroker	2015-04-19 13:28:12	info	Adapter "admin" updated
          host-VMioBrokerMaster	2015-04-19 13:28:12	info	stopInstance system.adapter.admin.0 killing pid 2562
          host-VMioBrokerMaster	2015-04-19 13:28:12	info	object change system.adapter.admin.0
          iobroker	2015-04-19 13:28:12	info	upload admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
          iobroker	2015-04-19 13:28:11	info	got /opt/iobroker/node_modules/iobroker.admin/adminupload admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
          iobroker	2015-04-19 13:28:03	info	npm install --production --prefix "/opt/iobroker/node_modules/iobroker.admin" (System call)
          host-VMioBrokerMaster	2015-04-19 13:27:37	error	instance system.adapter.yr.0 terminated with code 1 ()
          yr-0	2015-04-19 13:27:36	error	force terminate
          iobroker	2015-04-19 13:26:15	info	npm install iobroker.admin --production --prefix "/opt/iobroker" (System call)
          iobroker	2015-04-19 13:26:07	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.zwave/master/package.json. Error: Error: ETIMEDOUT
          iobroker	2015-04-19 13:26:06	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.onkyo/master/package.json. Error: Error: ETIMEDOUT
          iobroker	2015-04-19 13:26:06	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.socketio/master/package.json. Error: Error: ETIMEDOUT
          iobroker	2015-04-19 13:26:03	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.dwd/master/io-package.json. Error: Error: ESOCKETTIMEDOUT
          iobroker	2015-04-19 13:26:03	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.cul/master/io-package.json. Error: Error: ESOCKETTIMEDOUT
          iobroker	2015-04-19 13:26:03	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.b-control-em/master/io-package.json. Error: Error: ETIMEDOUT
          iobroker	2015-04-19 13:26:03	info	Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.artnet/master/io-package.json. Error: Error: ETIMEDOUT
          iobroker	2015-04-19 13:25:58	info	upgrade admin
          • Bluefox
            Bluefox last edited by
            admin Adapter wurde schon upgedated.
            wenn du in /opt/iobroker
            npm install https://github.com/ioBroker/ioBroker.js-controller/tarball/master
            ./iobroker restart
            Es sollte dann besser sein 😉
              mimquadrat last edited by
              Hallo Jungs,
              ich habe 2 ioBrokers im Mutierst (beide mit gleichem Setup, aber eben einen als "slave").
              Update am "Master" läuft einwandfrei durch.
              Beim Slave:
              $ ./iobroker upgrade admin
              Cannot download json from https://raw.githubusercontent.com/ioBro … ckage.json. Error: Error: ETIMEDOUT
              Cannot download json from https://raw.githubusercontent.com/ioBro ... ckage.json. Error: Error: ETIMEDOUT
              Cannot download json from https://raw.githubusercontent.com/ioBro ... ckage.json. Error: Error: ETIMEDOUTCannot download json from https://raw.githubusercontent.com/ioBro ... ckage.json. Error: Error: ETIMEDOUT
              npm
              http GET
              https://registry.npmjs.org/iobroker.admin
              npm
              http 200 https://registry.npmjs.org/iobroker.admin
              npm
              http GET https://registry.npmjs.org/iobroker.adm ... -0.4.4.tgz
              npm
              Auch der Node.red hat eine ähnliches Problem bei der Installation mit ETIMEDOUT errors...
              könnte Ihr mir weiterhelfen? DANKE! Hoffe Kassel war erfolgreich...
              • Bluefox
                Update hat geklappt. Ich denke, dass du doch 0.4.4 admin hast.
                Die Meldungen werden in der nächste Version nicht mehr erscheinen. Du kannst die ausprobieren mit:
                cd /opt/iobroker
                ./iobroker stop
                ./iobroker start
                Falls paar Leute das ausprobieren und hier darüber schreiben, dann mache ich npm packet.
                  Habe eben den js-adapter wie empfohlen upgedated:
                  cd /opt/iobroker
                  ./iobroker stop
                  ./iobroker start
                  Im log auf der Console keine Fehler,
                  aber nach dem neustart im log:
                  quad-pi	2015-04-20 10:14:33	error	host.quad-pi instance system.adapter.hmm.0 terminated with code 7 (Adapter already running)
                  quad-pi	2015-04-20 10:14:33	info	host.quad-pi Restart adapter system.adapter.hmm.0 because enabled
                  host-quad-pi	2015-04-20 10:14:31	error	instance system.adapter.ical.0 terminated with code 7 (Adapter already running)
                  host-quad-pi	2015-04-20 10:14:31	info	instance system.adapter.hmm.0 started with pid 12071
                  host-quad-pi	2015-04-20 10:14:27	info	instance system.adapter.ical.0 started with pid 12069
                  host-quad-pi	2015-04-20 10:14:27	info	instance scheduled system.adapter.ical.0 0,30 * * * *
                  host-quad-pi	2015-04-20 10:14:25	info	instance system.adapter.dwd.0 terminated with code 0 (OK)
                  host-quad-pi	2015-04-20 10:14:25	info	Restart adapter system.adapter.node-red.0 because enabled
                  host-quad-pi	2015-04-20 10:14:25	error	instance system.adapter.node-red.0 terminated with code 7 (Adapter already running)
                  Auch stand die Version des controllers unter hosts noch auf 0.6.4
                  Momentan läuft reboot 😉
                  Rainer
                    Bei der aktuellen Version sind ja schon einige Adapter in Kategorien eingeteilt.
                    für den Rest hätte ich folgende Vorschläge:
                    Hardware
                    -KNX
                    -ZWave
                    -(MegaD)
                    -(Siemens S7)
                    Visualistaion
                    -vis !
                    -legacy
                    Zeitplanung
                    -occ
                    Skripte und Logik
                    -Javascript
                    Kommunikation
                    diese Kategorie würde ich für Dinge wie
                    -email
                    -pushover
                    -Fritzbox (wenn es die mal gibt)
                    Wie die jetzige Kategorie heissen könnte ????
                    Media
                    -Onkyo
                    Wetter
                    -DWD
                    und eine neue Kategorie:
                    Beleuchtung
                    -artnet
                    -hue
                    für die restlichen habe ich auch keine Ahnung
                    Rainer
                    • derAuge
                      ` > Wetter
                      -DWD `
                      • yr
                        @derAuge:
                        ` > Wetter
                        -DWD `
                        • yr `
                        ist doch schon drin :shock:
                        ich habe nur die noch nicht verteilten aufgezählt.
                        Rainer
                          @Homoran:
                          cd /opt/iobroker
                          ./iobroker stop
                          ./iobroker start
                          Rainer `
                          inzwischen werden es immer mehr:
                          host-quad-pi	2015-04-20 20:39:36	info	instance system.adapter.cul.0 started with pid 11818
                          host-quad-pi	2015-04-20 20:39:28	info	Restart adapter system.adapter.ping.0 because enabled
                          host-quad-pi	2015-04-20 20:39:28	error	instance system.adapter.ping.0 terminated with code 7 (Adapter already running)
                          host-quad-pi	2015-04-20 20:39:27	info	Restart adapter system.adapter.pushover.0 because enabled
                          host-quad-pi	2015-04-20 20:39:27	error	instance system.adapter.pushover.0 terminated with code 7 (Adapter already running)
                          host-quad-pi	2015-04-20 20:39:25	info	instance system.adapter.ping.0 started with pid 11794
                          host-quad-pi	2015-04-20 20:39:25	info	instance system.adapter.pushover.0 started with pid 11792
                          host-quad-pi	2015-04-20 20:39:23	info	Restart adapter system.adapter.admin.0 because enabled
                          host-quad-pi	2015-04-20 20:39:23	error	instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
                          inMem	2015-04-20 20:39:23	debug	message *.logging system.adapter.admin.0.logging val=false, ack=true, ts=1429555164, from=system.host.quad-pi, lc=1429554380
                          host-quad-pi	2015-04-20 20:39:22	info	Restart adapter system.adapter.javascript.0 because enabled
                          host-quad-pi	2015-04-20 20:39:22	error	instance system.adapter.javascript.0 terminated with code 7 (Adapter already running)
                          host-quad-pi	2015-04-20 20:39:18	info	instance system.adapter.admin.0 started with pid 11782
                          host-quad-pi	2015-04-20 20:39:18	info	instance system.adapter.javascript.0 started with pid 11780
                          host-quad-pi	2015-04-20 20:39:17	info	Restart adapter system.adapter.web.0 because enabled
                          host-quad-pi	2015-04-20 20:39:17	error	instance system.adapter.web.0 terminated with code 7 (Adapter already running)
                          Rainer
                          2738
