    4. [Projekt] Smappee - Adapter
    • TheDuke
      TheDuke last edited by
      @forelleblau:
      v004 `
      mappee.0	2019-02-07 22:42:05.388	error	at Timer.listOnTimeout (timers.js:290:5)
      smappee.0	2019-02-07 22:42:05.388	error	at tryOnTimeout (timers.js:323:5)
      smappee.0	2019-02-07 22:42:05.388	error	at ontimeout (timers.js:498:11)
      smappee.0	2019-02-07 22:42:05.388	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.smappee/main.js:122:13)
      smappee.0	2019-02-07 22:42:05.388	error	ReferenceError: getsmappeeconfig is not defined
      smappee.0	2019-02-07 22:42:05.387	error	uncaught exception: getsmappeeconfig is not defined
      smappee.0	2019-02-07 22:42:03.367	warn	Fehler, noch nicht alle OBjekte angelegt, starte mqtt-client neu
      smappee.0	2019-02-07 22:42:03.367	warn	Noch nicht alle Objekte angelegt
      smappee.0	2019-02-07 22:42:00.364	warn	Noch nicht alle Objekte angelegt
      smappee.0	2019-02-07 22:41:57.363	warn	Noch nicht alle Objekte angelegt
      smappee.0	2019-02-07 22:41:54.360	warn	Noch nicht alle Objekte angelegt
      smappee.0	2019-02-07 22:41:51.400	warn	Objektsetup - JSON-parse-Fehler Message: Unexpected end of JSON input
      smappee.0	2019-02-07 22:41:51.350	info	MQTT connected
      smappee.0	2019-02-07 22:41:51.108	info	starting. Version 0.0.4 in /opt/iobroker/node_modules/iobroker.smappee, node: v8.15.0
      smappee.0	2019-02-07 22:41:19.536	info	terminating
      smappee.0	2019-02-07 22:41:19.511	info	[END] Stopping smappee adapter...
      smappee.0	2019-02-07 22:41:19.508	error	at Timer.listOnTimeout (timers.js:290:5)
      smappee.0	2019-02-07 22:41:19.508	error	at tryOnTimeout (timers.js:323:5)
      smappee.0	2019-02-07 22:41:19.508	error	at ontimeout (timers.js:498:11)
      smappee.0	2019-02-07 22:41:19.508	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.smappee/main.js:122:13)
      smappee.0	2019-02-07 22:41:19.508	error	ReferenceError: getsmappeeconfig is not defined
      smappee.0	2019-02-07 22:41:19.507	error	uncaught exception: getsmappeeconfig is not defined
      smappee.0	2019-02-07 22:41:17.489	warn	Fehler, noch nicht alle OBjekte angelegt, starte mqtt-client neu
      smappee.0	2019-02-07 22:41:17.488	warn	Noch nicht alle Objekte angelegt
      smappee.0	2019-02-07 22:41:14.487	warn	Noch nicht alle Objekte angelegt
      smappee.0	2019-02-07 22:41:11.485	warn	Noch nicht alle Objekte angelegt
      smappee.0	2019-02-07 22:41:08.484	warn	Noch nicht alle Objekte angelegt
      smappee.0	2019-02-07 22:41:05.503	warn	Objektsetup - JSON-parse-Fehler Message: Unexpected end of JSON input
      smappee.0	2019-02-07 22:41:05.474	info	MQTT connected
      smappee.0	2019-02-07 22:41:05.242	info	starting. Version 0.0.4 in /opt/iobroker/node_modules/iobroker.smappee, node: v8.15.0
      smappee.0	2019-02-07 22:40:37.049	info	terminating
      smappee.0	2019-02-07 22:40:37.019	info	[END] Stopping smappee adapter...
      smappee.0	2019-02-07 22:40:37.016	error	at Timer.listOnTimeout (timers.js:290:5)
      smappee.0	2019-02-07 22:40:37.016	error	at tryOnTimeout (timers.js:323:5)
      smappee.0	2019-02-07 22:40:37.016	error	at ontimeout (timers.js:498:11)
      smappee.0	2019-02-07 22:40:37.016	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.smappee/main.js:122:13)
      smappee.0	2019-02-07 22:40:37.016	error	ReferenceError: getsmappeeconfig is not defined
      smappee.0	2019-02-07 22:40:37.015	error	uncaught exception: getsmappeeconfig is not defined
      smappee.0	2019-02-07 22:40:34.996	warn	Fehler, noch nicht alle OBjekte angelegt, starte mqtt-client neu
      smappee.0	2019-02-07 22:40:34.996	warn	Noch nicht alle Objekte angelegt
      smappee.0	2019-02-07 22:40:31.995	warn	Noch nicht alle Objekte angelegt
      smappee.0	2019-02-07 22:40:28.994	warn	Noch nicht alle Objekte angelegt
      smappee.0	2019-02-07 22:40:25.992	warn	Noch nicht alle Objekte angelegt
      smappee.0	2019-02-07 22:40:23.014	warn	Objektsetup - JSON-parse-Fehler Message: Unexpected end of JSON input
      smappee.0	2019-02-07 22:40:22.984	info	MQTT connected
      smappee.0	2019-02-07 22:40:22.747	info	starting. Version 0.0.4 in /opt/iobroker/node_modules/iobroker.smappee, node: v8.15.0
      smappee.0	2019-02-07 22:40:18.844	info	[END] Stopping smappee adapter...
      smappee.0	2019-02-07 22:40:18.813	info	[END] Stopping smappee adapter...
      smappee.0	2019-02-07 22:40:18.120	warn	Noch nicht alle Objekte angelegt
      smappee.0	2019-02-07 22:40:15.144	warn	Objektsetup - JSON-parse-Fehler Message: Unexpected end of JSON input
      smappee.0	2019-02-07 22:40:15.110	info	MQTT connected
      smappee.0	2019-02-07 22:40:14.883	info	starting. Version 0.0.4 in /opt/iobroker/node_modules/iobroker.smappee, node: v8.15.0
      smappee.0	2019-02-07 22:39:43.208	info	[END] Stopping smappee adapter...
      smappee.0	2019-02-07 22:39:43.205	error	at Timer.listOnTimeout (timers.js:290:5)
      smappee.0	2019-02-07 22:39:43.205	error	at tryOnTimeout (timers.js:323:5)
      smappee.0	2019-02-07 22:39:43.205	error	at ontimeout (timers.js:498:11)
      smappee.0	2019-02-07 22:39:43.205	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.smappee/main.js:122:13)
      smappee.0	2019-02-07 22:39:43.205	error	ReferenceError: getsmappeeconfig is not defined
      smappee.0	2019-02-07 22:39:43.205	error	uncaught exception: getsmappeeconfig is not defined
      smappee.0	2019-02-07 22:39:41.185	warn	Fehler, noch nicht alle OBjekte angelegt, starte mqtt-client neu
      smappee.0	2019-02-07 22:39:41.185	warn	Noch nicht alle Objekte angelegt
      smappee.0	2019-02-07 22:39:38.183	warn	Noch nicht alle Objekte angelegt
      smappee.0	2019-02-07 22:39:35.180	warn	Noch nicht alle Objekte angelegt
      smappee.0	2019-02-07 22:39:32.178	warn	Noch nicht alle Objekte angelegt
      smappee.0	2019-02-07 22:39:29.198	warn	Objektsetup - JSON-parse-Fehler Message: Unexpected end of JSON input
      smappee.0	2019-02-07 22:39:29.169	info	MQTT connected
      smappee.0	2019-02-07 22:39:28.880	info	starting. Version 0.0.4 in /opt/iobroker/node_modules/iobroker.smappee, node: v8.15.0
      smappee.0	2019-02-07 22:38:57.296	info	[END] Stopping smappee adapter...
      smappee.0	2019-02-07 22:38:57.293	error	at Timer.listOnTimeout (timers.js:290:5)
      smappee.0	2019-02-07 22:38:57.293	error	at tryOnTimeout (timers.js:323:5)
      smappee.0	2019-02-07 22:38:57.293	error	at ontimeout (timers.js:498:11)
      smappee.0	2019-02-07 22:38:57.293	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.smappee/main.js:122:13)
      smappee.0	2019-02-07 22:38:57.293	error	ReferenceError: getsmappeeconfig is not defined
      smappee.0	2019-02-07 22:38:57.291	error	uncaught exception: getsmappeeconfig is not defined
      smappee.0	2019-02-07 22:38:55.273	warn	Fehler, noch nicht alle OBjekte angelegt, starte mqtt-client neu
      smappee.0	2019-02-07 22:38:55.272	warn	Noch nicht alle Objekte angelegt
      smappee.0	2019-02-07 22:38:52.271	warn	Noch nicht alle Objekte angelegt
      smappee.0	2019-02-07 22:38:49.270	warn	Noch nicht alle Objekte angelegt
      smappee.0	2019-02-07 22:38:46.267	warn	Noch nicht alle Objekte angelegt
      smappee.0	2019-02-07 22:38:43.288	warn	Objektsetup - JSON-parse-Fehler Message: Unexpected end of JSON input
      smappee.0	2019-02-07 22:38:43.258	info	MQTT connected
      smappee.0	2019-02-07 22:38:43.004	info	starting. Version 0.0.4 in /opt/iobroker/node_modules/iobroker.smappee, node: v8.15.0
      smappee.0	2019-02-07 22:38:11.454	info	terminating
      smappee.0	2019-02-07 22:38:11.441	info	[END] Stopping smappee adapter...
      smappee.0	2019-02-07 22:38:11.439	error	at Timer.listOnTimeout (timers.js:290:5)
      smappee.0	2019-02-07 22:38:11.439	error	at tryOnTimeout (timers.js:323:5)
      smappee.0	2019-02-07 22:38:11.439	error	at ontimeout (timers.js:498:11)
      smappee.0	2019-02-07 22:38:11.439	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.smappee/main.js:122:13)
      smappee.0	2019-02-07 22:38:11.439	error	ReferenceError: getsmappeeconfig is not defined
      smappee.0	2019-02-07 22:38:11.439	error	uncaught exception: getsmappeeconfig is not defined
      smappee.0	2019-02-07 22:38:09.425	warn	Fehler, noch nicht alle OBjekte angelegt, starte mqtt-client neu
      smappee.0	2019-02-07 22:38:09.424	warn	Noch nicht alle Objekte angelegt
      smappee.0	2019-02-07 22:38:06.423	warn	Noch nicht alle Objekte angelegt
      smappee.0	2019-02-07 22:38:03.421	warn	Noch nicht alle Objekte angelegt
      smappee.0	2019-02-07 22:38:00.419	warn	Noch nicht alle Objekte angelegt
      smappee.0	2019-02-07 22:37:57.440	warn	Objektsetup - JSON-parse-Fehler Message: Unexpected end of JSON input
      smappee.0	2019-02-07 22:37:57.409	info	MQTT connected
      smappee.0	2019-02-07 22:37:57.160	info	starting. Version 0.0.4 in /opt/iobroker/node_modules/iobroker.smappee, node: v8.15.0
      smappee.0	2019-02-07 22:37:25.638	info	terminating
      smappee.0	2019-02-07 22:37:25.625	info	[END] Stopping smappee adapter...
      smappee.0	2019-02-07 22:37:25.624	error	at Timer.listOnTimeout (timers.js:290:5)
      smappee.0	2019-02-07 22:37:25.624	error	at tryOnTimeout (timers.js:323:5)
      smappee.0	2019-02-07 22:37:25.624	error	at ontimeout (timers.js:498:11)
      smappee.0	2019-02-07 22:37:25.624	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.smappee/main.js:122:13)
      smappee.0	2019-02-07 22:37:25.624	error	ReferenceError: getsmappeeconfig is not defined
      smappee.0	2019-02-07 22:37:25.623	error	uncaught exception: getsmappeeconfig is not defined
      smappee.0	2019-02-07 22:37:23.610	warn	Fehler, noch nicht alle OBjekte angelegt, starte mqtt-client neu
      smappee.0	2019-02-07 22:37:23.609	warn	Noch nicht alle Objekte angelegt
      smappee.0	2019-02-07 22:37:20.608	warn	Noch nicht alle Objekte angelegt
      smappee.0	2019-02-07 22:37:17.607	warn	Noch nicht alle Objekte angelegt
      smappee.0	2019-02-07 22:37:14.606	warn	Noch nicht alle Objekte angelegt
      smappee.0	2019-02-07 22:37:11.628	warn	Objektsetup - JSON-parse-Fehler Message: Unexpected end of JSON input
      smappee.0	2019-02-07 22:37:11.598	info	MQTT connected
      smappee.0	2019-02-07 22:37:11.362	info	starting. Version 0.0.4 in /opt/iobroker/node_modules/iobroker.smappee, node: v8.15.0
      smappee.0	2019-02-07 22:36:39.744	info	terminating
      smappee.0	2019-02-07 22:36:39.721	info	[END] Stopping smappee adapter...
      smappee.0	2019-02-07 22:36:39.718	error	at Timer.listOnTimeout (timers.js:290:5)
      smappee.0	2019-02-07 22:36:39.718	error	at tryOnTimeout (timers.js:323:5)
      smappee.0	2019-02-07 22:36:39.718	error	at ontimeout (timers.js:498:11)
      smappee.0	2019-02-07 22:36:39.718	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.smappee/main.js:122:13)
      smappee.0	2019-02-07 22:36:39.718	error	ReferenceError: getsmappeeconfig is not defined
      smappee.0	2019-02-07 22:36:39.717	error	uncaught exception: getsmappeeconfig is not defined
      smappee.0	2019-02-07 22:36:37.699	warn	Fehler, noch nicht alle OBjekte angelegt, starte mqtt-client neu
      smappee.0	2019-02-07 22:36:37.698	warn	Noch nicht alle Objekte angelegt
      smappee.0	2019-02-07 22:36:34.697	warn	Noch nicht alle Objekte angelegt
      smappee.0	2019-02-07 22:36:31.696	warn	Noch nicht alle Objekte angelegt
      smappee.0	2019-02-07 22:36:28.694	warn	Noch nicht alle Objekte angelegt
      smappee.0	2019-02-07 22:36:25.717	warn	Objektsetup - JSON-parse-Fehler Message: Unexpected end of JSON input
      smappee.0	2019-02-07 22:36:25.685	info	MQTT connected
      smappee.0	2019-02-07 22:36:25.453	info	starting. Version 0.0.4 in /opt/iobroker/node_modules/iobroker.smappee, node: v8.15.0
      Hmm, sieht nicht gut aus …... lasse es mal die Nacht durchlaufen. Berichte dann morgen wieder .
        forelleblau last edited by
        Hallo TheDuke
        Sorry, wenn ich deine Geduld einmal mehr strapaziere. Also: die error-Meldungen kommen von einem mir unterdessen korrigierten Schreibfehler. Die sind hier aber nicht das Problem (tritt erst auf, wenn sich der Adapter selbst beenden sollte). Scheinbar kommt zwar eine Verbindung zum MQTT-Broker zu Stande, aber dann kommen keine Nachrichten oder diese werde nicht gelesen. Hattest du das LOG auf debug gestellt? Kannst du mir das entweder bestätigen oder noch ein debug-log einstellen (einmal vom Start bis zu den error-Meldungen reicht).
        Danke und Gruss
        forelleblau
        • TheDuke
          host.ioBroker-RasPi	2019-02-08 12:00:47.258	info	Restart adapter system.adapter.smappee.0 because enabled
          host.ioBroker-RasPi	2019-02-08 12:00:47.258	error	instance system.adapter.smappee.0 terminated with code 0 (OK)
          host.ioBroker-RasPi	2019-02-08 12:00:47.258	error	Caught by controller[0]: at Timer.listOnTimeout (timers.js:290:5)
          host.ioBroker-RasPi	2019-02-08 12:00:47.258	error	Caught by controller[0]: at tryOnTimeout (timers.js:323:5)
          host.ioBroker-RasPi	2019-02-08 12:00:47.258	error	Caught by controller[0]: at ontimeout (timers.js:498:11)
          host.ioBroker-RasPi	2019-02-08 12:00:47.257	error	Caught by controller[0]: at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.smappee/main.js:122:13)
          host.ioBroker-RasPi	2019-02-08 12:00:47.257	error	Caught by controller[0]: ReferenceError: getsmappeeconfig is not defined
          smappee.0	2019-02-08 12:00:45.181	warn	Fehler, noch nicht alle OBjekte angelegt, starte mqtt-client neu
          mqtt.0	2019-02-08 12:00:45.182	info	Client [mqttjs_3a1ec4a4] connection closed: disconnected
          smappee.0	2019-02-08 12:00:45.179	warn	Noch nicht alle Objekte angelegt
          smappee.0	2019-02-08 12:00:44.193	debug	Topic: realtime
          smappee.0	2019-02-08 12:00:44.188	debug	Topic: realtime
          smappee.0	2019-02-08 12:00:43.207	debug	Topic: realtime
          smappee.0	2019-02-08 12:00:43.189	debug	Topic: realtime
          smappee.0	2019-02-08 12:00:42.205	debug	Topic: realtime
          smappee.0	2019-02-08 12:00:42.192	debug	Topic: realtime
          smappee.0	2019-02-08 12:00:42.171	warn	Noch nicht alle Objekte angelegt
          smappee.0	2019-02-08 12:00:41.215	debug	Topic: realtime
          smappee.0	2019-02-08 12:00:41.205	debug	Topic: realtime
          smappee.0	2019-02-08 12:00:40.193	debug	Topic: realtime
          smappee.0	2019-02-08 12:00:40.187	debug	Topic: realtime
          smappee.0	2019-02-08 12:00:39.198	debug	Topic: realtime
          smappee.0	2019-02-08 12:00:39.191	debug	Topic: realtime
          smappee.0	2019-02-08 12:00:39.169	warn	Noch nicht alle Objekte angelegt
          smappee.0	2019-02-08 12:00:38.711	debug	system.adapter.admin.0: logging true
          smappee.0	2019-02-08 12:00:38.196	debug	Topic: realtime
          smappee.0	2019-02-08 12:00:38.190	debug	Topic: realtime
          smappee.0	2019-02-08 12:00:37.191	debug	Topic: realtime
          smappee.0	2019-02-08 12:00:37.187	debug	Topic: realtime
          smappee.0	2019-02-08 12:00:36.192	debug	Topic: realtime
          smappee.0	2019-02-08 12:00:36.188	debug	Topic: realtime
          smappee.0	2019-02-08 12:00:36.166	warn	Noch nicht alle Objekte angelegt
          smappee.0	2019-02-08 12:00:35.937	debug	system.adapter.admin.0: logging false
          smappee.0	2019-02-08 12:00:35.191	debug	Topic: realtime
          smappee.0	2019-02-08 12:00:35.188	debug	Topic: realtime
          smappee.0	2019-02-08 12:00:34.193	debug	Topic: realtime
          smappee.0	2019-02-08 12:00:34.187	debug	Topic: realtime
          smappee.0	2019-02-08 12:00:33.241	debug	Topic: realtime
          smappee.0	2019-02-08 12:00:33.196	debug	Topic: realtime
          smappee.0	2019-02-08 12:00:33.191	debug	Topic: plug
          smappee.0	2019-02-08 12:00:33.191	warn	Objektsetup - JSON-parse-Fehler Message: Unexpected end of JSON input
          smappee.0	2019-02-08 12:00:33.190	debug	Anzahl Topics bearbeitet: 1
          smappee.0	2019-02-08 12:00:33.187	debug	Topic: realtime
          smappee.0	2019-02-08 12:00:33.186	debug	Topic: aggregatedSwitch
          smappee.0	2019-02-08 12:00:33.185	debug	Anzahl Topics bearbeitet: 1
          smappee.0	2019-02-08 12:00:33.184	debug	Topic aggregated to be developed
          smappee.0	2019-02-08 12:00:33.184	debug	Topic: aggregated
          mqtt.0	2019-02-08 12:00:33.168	info	Client [mqttjs_3a1ec4a4] publishOnSubscribe send all known states
          mqtt.0	2019-02-08 12:00:33.167	info	Client [mqttjs_3a1ec4a4] subscribes on "servicelocation/#" with regex /^mqtt\.0\.servicelocation\..*/
          mqtt.0	2019-02-08 12:00:33.167	info	Client [mqttjs_3a1ec4a4] subscribes on "servicelocation/#" with regex /^servicelocation\..*/
          smappee.0	2019-02-08 12:00:33.157	info	MQTT connected
          mqtt.0	2019-02-08 12:00:33.129	info	Client [mqttjs_3a1ec4a4] connected with secret 1549623633017_1332
          smappee.0	2019-02-08 12:00:32.781	info	starting. Version 0.0.4 in /opt/iobroker/node_modules/iobroker.smappee, node: v8.15.0
          smappee.0	2019-02-08 12:00:32.655	debug	statesDB connected
          smappee.0	2019-02-08 12:00:32.590	debug	objectDB connected
          host.ioBroker-RasPi	2019-02-08 12:00:31.250	info	instance system.adapter.smappee.0 started with pid 18199
          host.ioBroker-RasPi	2019-02-08 12:00:28.738	info	instance system.adapter.smappee.0 terminated with code 0 (OK)
          smappee.0	2019-02-08 12:00:28.712	debug	stateChange smappee.0.info.connection {"val":false,"ack":true,"ts":1549623628706,"q":0,"from":"system.adapter.smappee.0","lc":1549623628706}
          host.ioBroker-RasPi	2019-02-08 12:00:28.699	info	stopInstance system.adapter.smappee.0 killing pid 18187
          smappee.0	2019-02-08 12:00:28.701	info	[END] Stopping smappee adapter...
          host.ioBroker-RasPi	2019-02-08 12:00:28.696	info	object change system.adapter.smappee.0
          mqtt.0	2019-02-08 12:00:27.182	info	Client [mqttjs_95a928f9] connection closed: disconnected
          smappee.0	2019-02-08 12:00:27.176	warn	Fehler, noch nicht alle OBjekte angelegt, starte mqtt-client neu
          smappee.0	2019-02-08 12:00:27.175	warn	Noch nicht alle Objekte angelegt
          smappee.0	2019-02-08 12:00:26.248	debug	Topic: realtime
          smappee.0	2019-02-08 12:00:26.243	debug	Topic: realtime
          smappee.0	2019-02-08 12:00:25.203	debug	Topic: realtime
          smappee.0	2019-02-08 12:00:25.192	debug	Topic: realtime
          smappee.0	2019-02-08 12:00:24.270	debug	Topic: realtime
          smappee.0	2019-02-08 12:00:24.191	debug	Topic: realtime
          smappee.0	2019-02-08 12:00:24.173	warn	Noch nicht alle Objekte angelegt
          smappee.0	2019-02-08 12:00:23.198	debug	Topic: realtime
          Bitte schön .
            Hallo TheDuke
            Vielen Dank für das Log. Es hat mir gezeigt, dass offensichtlich nicht alle Smappees nach dem selben Muster übermitteln, weshalb mein Design nicht funktioniert hat. Ich hab jetzt ein paar Sachen umgestellt, und auf Github und npm publiziert. Möglicherweise wird es einen Moment gehen, bis alle Objekte angelegt sind, je nachdem in welchem Abstand welche Topics vom Smappee gesendet werden.
            Also: https://github.com/forelleblau/ioBroker.smappee
            Viel Erfolg, hoffe dass ich nun auf der richtigen Spur bin.
            forelleblau
            • TheDuke
              @forelleblau:
              forelleblau `
              Jo, sieht gut aus. Nur dauert das einlesen , ich meine bis die Daten die ich brauche, Phase 0 1 2 und realpower da sind .
              Aber wenn da dann geil 8-)
              Cool wäre jetzt noch ein Kanal der anzeigt was eingespeist wird. Also die kw/h die jetzt als minus angezeigt werden wenn genug Solarstrom da ist.
              2280_log_005.txt
                Danke für die Rückmeldung.
                Habe eben Version 0.1.0 publiziert (Github/npm/repo_latest). Das sollte nun eine stabil funktionierende Version, die die zentralen Werte vom Smappee abruft (Strom Verbrauch und Produktion, Dauerverbrauch, Gas/Wasserverbräuche) und in Kombination mit dem ioBroker.statistics - Adapter ansprechende Auswertungen über fast beliebige Zeitperioden zulässt. Die Werte erscheinen jeweils, sobald das entsprechende Topic das zweite Mal vom Smappee gesendet wurde (beim ersten werden die Objekte angelegt).
                Die Objekte werden nun soweit möglich vom "realtime" Topic angelegt, so, dass rasch viele Daten zur Verfügung stehen. Beim Wasserverbrauch kann es aber einige Minuten dauern (je nach Wasserverbrauch), bis die Daten das erste Mal da sind.
                Sobald ich Feedback (von hoffentlich verschiedenen Usern) habe, werde ich die Version für's stable-Repo eintragen.
                @TheDuke : Der Smappee wäre eigentlich gemacht, um Verbrauch und Produktion zu erfassen, jedoch mit separaten CT's. Wenn du negetive Werte erhälst, wenn eingespiesen ist das die eingespiesene Leistung (W). Wenn du wissen willst, wieviel Energie du eingespeisen hast, musst du mal schauen, wie sich in dieser Zeit der "importEnergy" Wert verändert:
                • geht er zurück, dann ist importEnergy dein Nettoverbrauch
                • bleibt er gleich, dann ist importEnergie dein gesamter Netzbezug
                • geht er hoch, wär das unschön und wahrscheinlich nur über eine Umplatzierung der Klemmen vom Smappee resp. vom Einspeisepunkt der PV-Anlage zu korrigieren. Der Einspeisepunkt sollte eigentlich zwischen dem Zähler und den Klemmen vom Smappee liegen. Am Adapter selbst möchte ich das nicht vorsehen, da dieser Fall eigentlich nicht auftreten sollte und ja alle Werte die angezeigt werden, direkt vom Smappee kommen und nicht umgerechnet sind.
                • TheDuke
                  Hallo forelleblau ,
                  die neue Version 0.1.0 rennt wie Sau ! Keine Beanstandung. Respekt !!
                  Die Daten kommen jetzt wirklich in Echtzeit .👍
                  Die Daten "importEnergy" schaue ich mir dann mal genau an wenn die 🌞 scheint . Werde berichten.
                  Danke für den tollen Adapter .
                    Danke, hab den Adapber eben für das stable-Repo angemeldet.
                    Grüsse forelleblau.
                      Hallo
                      Hab dem Smappee - Adapter eine Erweiterung spendiert. Er zeigt in der aktuell verfügbaren Version 0.1.1 nun auch die Anzahl, die Namen und den Schaltzustand der mit dem Smappee verbundenen Schaltsteckdosen - sofern solech im Einsatz sind. Und man kann die Schalter natürlich auch im ioBroker bedienen - Ein und Aus.
                      Mit dem Smappee lassen sich übrigens nicht nur die Steckerschalter aus dem Smappee-Zubehörshop steuern sondern auch normal 433Mhz RF- Schaltsteckdosen, ich hab z.B. Intertechno IT 1500 im Einsatz. Einfach in der Smappee-App koppeln und bezeichnen und den Adapter neu starten.
                      Für Feedback von Testern bin ich dankbar, die sind Grundlage für einen Eintrag im "stable" Repo und somit für eine breite Verfügbarkeit des Adapter.
                      Viel Spass und herzliche Grüsse
                      forelleblau
                      • TheDuke
                        Funktioniert wie erwartet gut . Dankeschön.
                        Nur ab und zu sehe ich im log :
                        smappee.0	2019-02-25 22:43:45.057	warn	MAIN: JSON-parse-Fehler Message: Unexpected end of JSON input
                        Ansonsten top Job.
                        Habe aber leider nur die eine original Erweiterung aber das sollte zum Test ja ausreichen.
                        Kommt auch noch die Leistungsmessung dieser Schaltsteckdosen ?
                        • TheDuke
                          Hmmm, habe jetzt mal einen Schalter mit on / off eingerichtet.
                          Die Befehle kommen an unter Objekte aber schalten nicht.
                          Der geschaltete Befehl wird angezeigt und wird dann rot.
                          Mach ich da was falsch ?
                            Moin TheDuke
                            Vielen Dank für den raschen Test, super Service. Zur warn-Meldung: die erhalte ich auch ab und zu, meistens beim Starten des Adapters einmal. Das ist eine Meldung aus dem eingebauten Fehlerhandling und zeigt, das dieses funktioniert 😉 wenn mal etwas reinkommt, dass nicht gelesen werden kann. Aus Meiner Sicht 'gehört das dazu', wenns nicht zu häufig (jede Minute oder so) auftritt.
                            Zum Schalter Test: Das Verhalten bei dir ist erklärbar, was ich gemacht habe ist nämlich für die anderen Schalter, für die ohne Leistungsmessung. Darum hast du auch kein 'switchON' - Objekt, das du zum Schalten bräuchtest. Dein State bleibt rot, weil das nicht vorgesehen ist, dass du den von Hand anpasst - eigentlich solltest du das gar nicht tun können. Deine 'Datenlage' ist aber für mich absolut nachvollziehbar. Sorry für die Enttäuschung.
                            Nach einem kurzen Blick in die Doku glaube ich aber, dass ich das mit dem Schalten deiner Geräte und auch die Leistungsmessung (nur 5-Minuten Verbrauchsmessung, mehr ist nicht verfügbar) hinkriegen sollte - bräuchte dich dann aber einmal mehr als versierten Tester mit wohl noch mehr Geduld als bisher, da ich das Funktionieren in dem Fall nicht selber ausprobieren kann. OK?
                            morgengruss
                            forelleblau
                            • TheDuke
                              Ja kein Problem. Bin bereit. 🙂
                                Ok, sehr für, danke. Dann legen wir los.
                                Damit ich mit ˋechtenˋ Daten arbeiten kann, wäre ich froh, wenn du mir folgende Messages aus dem mqtt-Adapter (das was in der Spalte ´Wert´ in geschweiften Klammern steht) zur Verfügung stellen könntet. Und zwar von folgenden Objekten (Spalte ID):
                                • SensorConfig
                                  -HomeComtrolConfig
                                  -aggregatedSwitch
                                Danke und Gruss
                                Forelleblau
                                • TheDuke
                                  @forelleblau sagte in [Projekt] Smappee - Adapter:
                                  SensorConfig
                                  -HomeComtrolConfig
                                  -aggregatedSwitch
                                  {"utcTimeStamp":1551130959544,"gwSensors":[],"switchSensors":[{"name":"Kellerbass ","serialNumber":"4006002384","sensorId":2}]}
                                  {"utcTimeStamp":1551132067778,"switchActuators":[{"nodeId":1,"name":"Kellerbass ","serialNumber":"4006002384"}],"smartplugActuators":[]}
                                  {"switchIntervalDatas":[{"utcEndtime":1551205200000,"activePower":0,"reactivePower":0,"version":1,"sensorId":2}]}
                                  Dann hoffe ich mal das das die Daten sind .
                                    Das sind genau die richtigen, danke
                                      Ok, Version 0.1.2 ist als Testverion auf Github verfügbar - du kannst auf der Adapterseite mit dem Github-Symbol smappee "von Github aktualisieren".
                                      Sollte im Bereich "SwitchSensors" die 5-minuten Verbräuche liefern und im Bereich "plug" über das SwitchON-Objekt das Schalten ermöglichen
                                      Viel Spass beim testen! Würd mich freuen wenn ichs getroffen habe.
                                      Gruss forelleblau
                                      • TheDuke
                                        TheDuke last edited by TheDuke
                                        Danke, aber ich denke da hängt noch was .
                                        Schalten kann ich noch nicht.
                                        Sieht aber schon nach mehr aus 🙂
                                        012log.txt.gz
                                        • TheDuke
                                          richtig hin geschaut und den anderen Schalter benutzt ..... geht aber auch nicht.
                                            Hallo The Duke
                                            Danke für den schnellen Test. Ja, einiges scheint zu funktionieren, einiges anders als geplant, da ist mir aber klar wieso (z.B. .state einmal ON und einmal CONNECTED) und offensichtlich einiges nicht. Im angehängten Log sieht eigentlich alles gut aus.
                                            Folgende Bitten:
                                            • Objektansicht einmal 'aktualisieren' (Rundpfeilsymbo oben) und schauen ob bei SwitchSensors.2 immer noch nichts steht.
                                            • falls Objekte, diese sollten es sein :
                                              2681f732-fbf6-4d62-a9e8-5b334b7336c7-image.png ![alt text](image url)
                                              bitte einmal einen Verbrauch auf dem Switch erzeugen und in den nächsten 5 Minuten schauen, ob die Werte aktualisiert werden (da kommt alle 5 Minuten ein Wert mit dem Verbrauch der letzten 5 min rein). Wenn der Wert kommt, wird er noch etwas gross sind, da fehlt noch die Korrektur von Ws auf kWh
                                            • bei plug.1.switchOn - da wo du schalten können solltest - frage ich mich etwas, wieso da bei dir 'off' steht. Ich hab da eine checkbox für true oder false. Kannst du mir das erklären? sonst bitte mal mit true und false probieren. Wenn das schalten funktioniert, sollte der .state mit dem Schaltvorgang aktualisiert werden. Wenn's nach wie vor nicht geht, bitte ein debug-log mit switchON - Schaltvorgängen drin (Ein und aus).
                                            • Kannst du mir erklären, wieso du 2 plug. - Objekte hast. Gemäss den Daten 'homeControlConfig' die du eingestellt hast, solltest du nur 1 Schalter haben.
                                              Kannst du dazu auch die mqtt.0.plug Objekte prüfen, ob da 2 oder 1 drin sind?
                                            Danke und gruss
                                            forelleblau
                                            TheDuke 1 Reply Last reply Reply Quote 0
                                            79.9k
                                            134
                                            11141
