    4. [gelöst] Backitup macht keine Backups mehr.
    UNSOLVED [gelöst] Backitup macht keine Backups mehr.
      der-eine last edited by
      @simatec, sorry für die späte Rückmeldung.
      Hier das Log von Heute Nacht. Habe inzwischen den Adapter gelöscht und neu installiert sowie das System neu gestartet.
      2019-02-22 03:00:10.082 - debug: backitup.0 [total] exec: done
      2019-02-22 03:00:10.599 - error: backitup.0 uncaught exception: Cannot read property 'val' of null
      2019-02-22 03:00:10.600 - error: backitup.0 TypeError: Cannot read property 'val' of null
      at Socket.adapter.getState (/opt/iobroker/node_modules/iobroker.backitup/main.js:208:39)
      at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
      at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
      at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
      at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
      at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
      at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
      2019-02-22 03:00:11.676 - error: Caught by controller[0]: TypeError: Cannot read property 'val' of null
      2019-02-22 03:00:11.678 - error: Caught by controller[0]: at Socket.adapter.getState (/opt/iobroker/node_modules/iobroker.backitup/main.js:208:39)
      2019-02-22 03:00:11.678 - error: Caught by controller[0]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
      2019-02-22 03:00:11.678 - error: Caught by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
      2019-02-22 03:00:11.678 - error: Caught by controller[0]: at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      2019-02-22 03:00:11.678 - error: Caught by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      2019-02-22 03:00:11.679 - error: Caught by controller[0]: at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
      2019-02-22 03:00:11.679 - error: Caught by controller[0]: at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      2019-02-22 03:00:11.679 - error: Caught by controller[0]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
      2019-02-22 03:00:11.679 - error: Caught by controller[0]: at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
      2019-02-22 03:00:11.679 - error: Caught by controller[0]: at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
      2019-02-22 03:00:11.680 - error: host.ioBroker-Master instance system.adapter.backitup.0 terminated with code 6 (uncaught exception)
      2019-02-22 03:00:11.680 - info: host.ioBroker-Master Restart adapter system.adapter.backitup.0 because enabled
      2019-02-22 03:00:41.712 - info: host.ioBroker-Master instance system.adapter.backitup.0 started with pid 27000
      2019-02-22 03:00:44.287 - debug: backitup.0 objectDB connected
      2019-02-22 03:00:44.337 - debug: backitup.0 statesDB connected
      2019-02-22 03:00:44.452 - info: backitup.0 starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v8.14.0
      2019-02-22 03:00:44.665 - info: backitup.0 [total] backup was activated at 03:00 every 1 day(s)
      2019-02-22 03:00:44.712 - debug: backitup.0 [total] 10 00 03 */1 * *
      Nodejs = 0.8.15
      NPM 6.8.0
      Backitup 1.1.2
      • simatec
        simatec Developer Most Active @der-eine last edited by
        @der-eine
        Welche js-Controller Version ist installiert?
          der-eine last edited by der-eine
          js-Controller v1.5.7
          • simatec
            @der-eine
            Hast du mal den Adapter neu gestartet.
            Ich kann diesen Fehler nich rekonstruieren.
            Hast du nach der Installation einen Upload gemacht?
            Die Version 1.1.2 ist inzwischen auch in der latest repro.
            Installiere es mal neu aus der repro
              der-eine @simatec last edited by
              @simatec
              so nochmal gelöscht und neu installiert. Jetzt macht er das Backup unter /opt/ioBroker/backups 👍🏻
              Leider funktioniert es nicht mehr mit Dropbox...
              werde mir den Access Token nochmal anschauen. Ist eigentlich der gleiche wie am Anfang...
              • simatec
                An der dropbox wurde nix geändert ... Füge den Token noch einmal ein ... eventuell ist da was schief gelaufen.
                Was sagt der Log?
                  @simatec hab ich schon gemacht. Musste ich ja nach der neu Installation. Werde es heute Nacht nochmal über die Dropbox laufen lassen und poste das Log.
                    der-eine @der-eine last edited by
                    Hallo @simatec , jetzt funktioniert alles. Habe es mit dem Standrad Ordnerstruktur probiert. 👍🏻
                    Die Struktur kann ich ja ändern solange die Ordner auf Dropbox vorhanden sind?
                    Danke für deine Unterstützung!
                    • simatec
                      Kannst du das Thema dann bitte auf gelöst setzen 😉
                        @simatec klar mach ich.
                        81.1k
                        backitup fehlermeldung kein backup vorhanden
                        1955
