    4. Test Adapter SourceAnalytix v0.2.x
      cyberax last edited by cyberax
      bei mir läuft der Adapter irgendwie erst gar nicht (0.2.26):
      host.castle	2019-02-25 10:32:42.334	info	Restart adapter system.adapter.sourceanalytix.0 because enabled
      host.castle	2019-02-25 10:32:42.334	error	instance system.adapter.sourceanalytix.0 terminated with code 0 (OK)
      host.castle	2019-02-25 10:32:42.334	error	Caught by controller[0]: at Decoder.add (/home/iob/node_modules/iobroker.js-controller/node_modules/socket.io-parser/index.js:251:12)
      host.castle	2019-02-25 10:32:42.334	error	Caught by controller[0]: at Decoder.Emitter.emit (/home/iob/node_modules/component-emitter/index.js:133:20)
      host.castle	2019-02-25 10:32:42.334	error	Caught by controller[0]: at Decoder.<anonymous> (/home/iob/node_modules/component-bind/index.js:21:15)
      host.castle	2019-02-25 10:32:42.334	error	Caught by controller[0]: at Manager.ondecoded (/home/iob/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
      host.castle	2019-02-25 10:32:42.334	error	Caught by controller[0]: at Manager.Emitter.emit (/home/iob/node_modules/component-emitter/index.js:133:20)
      host.castle	2019-02-25 10:32:42.334	error	Caught by controller[0]: at Manager.<anonymous> (/home/iob/node_modules/component-bind/index.js:21:15)
      host.castle	2019-02-25 10:32:42.334	error	Caught by controller[0]: at Socket.onpacket (/home/iob/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
      host.castle	2019-02-25 10:32:42.334	error	Caught by controller[0]: at Socket.onack (/home/iob/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
      host.castle	2019-02-25 10:32:42.334	error	Caught by controller[0]: at Socket.<anonymous> (/home/iob/node_modules/iobroker.sourceanalytix/main.js:150:9)
      host.castle	2019-02-25 10:32:42.334	error	Caught by controller[0]: at initialize (/home/iob/node_modules/iobroker.sourceanalytix/main.js:171:29)
      host.castle	2019-02-25 10:32:42.333	error	Caught by controller[0]: TypeError: Cannot read property 'toLowerCase' of undefined
      Das Ganze auf
      Node.js: v8.11.2
      NPM: 6.5.0-next.0
      JS adapter "Skriptausführung" 4.1.4
      Typ: js-controller Verfügbar: 1.5.7
      Titel: JS controller Eingerichtet: 1.4.2
      OS: linux
      Hat jemand ne idee?
      Viele Grüsse
      sigi234 A 2 Replies Last reply Reply Quote 0
        sigi234 Forum Testing Most Active @cyberax last edited by
        @cyberax sagte in [Neuer Adapter Beta 0.2.21] SourceAnalytix (Verbrauch Protokollierung von Strom/Gas/Flüssigkeiten):
        js-controller
        Welche Version von js-controller hast du?
          ist das der JS adapter "Skriptausführung"? ---> 4.1.4
              OS: linux
              • cvidal
                Um den Zählerstand bei "0" beginnend ab Start des Zählens vom Adapter Einzustellen muss ich meinen aktuellem Zählerstand angeben, Tag/Woche/Monat/Quartal/Jahr.
                Ist es nicht sinnvoller einen einmaligen Eintrag tätigen zu können damit er komplett bei "0" anfängt. Natürlich kenne ich meinen Zählerstand nicht am Anfang des Tag/Woche/Monat/Quartal/Jahr. Irgenwie macht die Einstellung für mich wenig Sinn.
                Gruß Christian
                  cyberax @cyberax last edited by
                  Noch irgendwelche ideen?
                    crunchip Forum Testing Most Active @cvidal last edited by
                    @cvidal berichtigt mich falls ich falsch liege, aber du trägst deinen Zählerstand "Tag" ein, der natürlich nicht ganz korrekt ist für diesen Tag (ausser du machst dies genau um 0Uhr nachts)
                    Die anderen lässt du leer. Diese werden dann automatisch gefüllt, wenn das Ereignis eingetroffen ist
                    gruss
                    cvidal 1 Reply Last reply Reply Quote 0
                    • cvidal
                      cvidal Forum Testing @crunchip last edited by
                      @crunchip
                      Richtig ist das ich den Tag nicht passen angebe, was aber auch nicht schlimm ist denn am nächsten Tag passt es ja wieder.
                      Wenn ich das bei Jahr mache müsste ich ja jetzt noch 10 Monate warten damit er ab 0 zählt.
                      Ich hätte es aber gerne das ich ab start des Adapters komplett bei null Anfangen kann.
                      dann müsste ich ja in jeder Spalte den aktuellen Stand eingeben. Ist halt etwas umständlich.
                      Gruß Christian
                      • cvidal
                        Ich würde mir gerne Daten von gestern, letzte Woche und letzten Monat wünschen damit man das als vergleich nehmen kann. Aktuell habe ich das in meiner Vis mit dem BSZ Skript gelöst.
                        • porty
                          porty @a200 last edited by
                          @a200
                          könntest du mir evtl kurz mitteilen wie du das mit den Repos gemacht hast? Ich habe die gleichen Fehlermeldungen die du am Anfang auch hattest.
                          a200 1 Reply Last reply Reply Quote 0
                          • a200
                            a200 @porty last edited by
                            @porty sagte in [Neuer Adapter Beta 0.2.21] SourceAnalytix (Verbrauch Protokollierung von Strom/Gas/Flüssigkeiten):
                            @a200
                            gerne.
                            Unter Einstellungen (Maulschlüssel oben) -> Verwahrungsorte die namen latest und default vertauschen! Danach analytix installieren und danach den Tausch wieder rückgängig machen.
                            viel Erfolg.
                            • porty
                              hat geklappt, vielen dank @a200
                                Hallo Dutchman,
                                wird daran noch gearbeitet?
                                  CyberMicha last edited by
                                  Würde mich auch interessieren. Nutze aktuell noch das Script.
                                  LG Micha
                                    Creator last edited by
                                    Bei mir läuft der Adapter für Strom sehr gut.
                                    Sobald ich aber Gas mit protokollieren möchte, bekomme ich den selben Fehler wie cyberax .
                                    sourceanalytix.0	2019-03-04 14:44:30.931	info	terminating
                                    sourceanalytix.0	2019-03-04 14:44:30.928	warn	Adapter SourceAnalytix stopped !
                                    sourceanalytix.0	2019-03-04 14:44:30.927	error	at processImmediate [as _immediateCallback] (timers.js:745:5)
                                    sourceanalytix.0	2019-03-04 14:44:30.927	error	at tryOnImmediate (timers.js:768:5)
                                    sourceanalytix.0	2019-03-04 14:44:30.927	error	at runCallback (timers.js:810:20)
                                    sourceanalytix.0	2019-03-04 14:44:30.927	error	at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:892:81)
                                    sourceanalytix.0	2019-03-04 14:44:30.927	error	at Object.objectChange (/opt/iobroker/node_modules/iobroker.sourceanalytix/main.js:67:5)
                                    sourceanalytix.0	2019-03-04 14:44:30.927	error	at initialize (/opt/iobroker/node_modules/iobroker.sourceanalytix/main.js:171:29)
                                    sourceanalytix.0	2019-03-04 14:44:30.927	error	TypeError: Cannot read property 'toLowerCase' of undefined
                                    sourceanalytix.0	2019-03-04 14:44:30.927	error	uncaught exception: Cannot read property 'toLowerCase' of undefined
                                    Installiert ist Version 0.2.26
                                      Stormbringer last edited by Stormbringer
                                      Hallo Dutchman,
                                      erst mal vielen lieben Dank, für die Arbeit die du in den neuen Adapter gesteckt hast .
                                      Leider lässt er sich bei mir erst gar nicht installieren:
                                      npm 4.6.1
                                      node 8.12.0
                                      js controller 1.4.2
                                      unter Ubuntu
                                      Was will mir die Fehlermeldung vermitteln, sowas hatte ich noch nie 😉
                                      porty Peoples 2 Replies Last reply Reply Quote 0
                                      • porty
                                        porty @Stormbringer last edited by
                                        @Stormbringer
                                        versuch es mal nach der Anleitung von @a200 , die Fehlermeldungen sind zwar etwas anders aber ein Versuch wäre es wert.
                                        https://forum.iobroker.net/post/233229
                                        • Peoples
                                          Peoples @Stormbringer last edited by
                                          @Stormbringer sagte in [Neuer Adapter Beta 0.2.21] SourceAnalytix (Verbrauch Protokollierung von Strom/Gas/Flüssigkeiten):
                                          Hallo Dutchman,
                                          npm 4.6.1
                                          node 8.12.0
                                          js controller 1.4.2
                                          unter Ubuntu
                                          Lässt sich bei mir auch nicht installieren, leider auch nach Anleitung nicht. Issued auf Git habe ich erstellt
                                            Camuri last edited by
                                            Hier geht auch nichts.
                                            adapter test
                                            103
                                            958
                                            284950
