    3. Entwicklung
    4. Adapter: Worx Landroid v2.x.x
    • unltdnetworx
      unltdnetworx Developer last edited by
      probier mal folgendes Blockly-Skript zu importieren.
       <xml xmlns="http://www.w3.org/1999/xhtml"><block type="procedures_defcustomnoreturn" id="ORmhM@AO~Vbt~j|cDEnt" x="-463" y="-237"><mutation statements="false"><arg name="ID"></arg>
            <arg name="Init"></arg>
            <arg name="Name"></arg>
            <arg name="Einheit"></arg>
            <arg name="Min"></arg>
            <arg name="Max"></arg></mutation>
          <field name="NAME">newNumberDP</field>
          <field name="SCRIPT">Y3JlYXRlU3RhdGUoSUQsIEluaXQsIHsKICAgIHR5cGU6ICdudW1iZXInLAogICAgbmFtZTogTmFtZSwKICAgIHVuaXQ6IEVpbmhlaXQsCiAgICBtaW46IE1pbiwKICAgIG1heDogTWF4Cn0pOw==</field>
          <comment pinned="false" h="80" w="160">Datenpunkt Typ Zahl erzeugen</comment></block>
        <block type="procedures_callcustomnoreturn" id="Y]V[@NuL;Rok_d|laA52" x="-463" y="-187"><mutation name="newNumberDP"><arg name="ID"></arg>
          <value name="ARG0"><block type="text" id="PRN1198~0C{:.--DP:D;"><field name="TEXT">RasenmaeherJahresleistung</field></block></value>
          <value name="ARG1"><block type="math_number" id="Nq;1gp%XrBr@~Rg|cM:b"><field name="NUM">0</field></block></value>
          <value name="ARG2"><block type="text" id="GuiWt[BA{]N|b,zQI9PV"><field name="TEXT">RasenmaeherJahresleistung</field></block></value>
          <value name="ARG3"><block type="text" id="[;iM6O6hEOK7O;xyxi=/"><field name="TEXT">m</field></block></value>
          <value name="ARG4"><block type="math_number" id="kl,rbTpLzq0iRmV(l`]b"><field name="NUM">0</field></block></value>
          <value name="ARG5"><block type="math_number" id="gpYeG9D,;8c+tA.h#.0@"><field name="NUM">1e+22</field></block></value>
          <next><block type="on_ext" id="/pg`o*VOrF@{UzybLS[j"><mutation items="1"></mutation>
              <value name="OID0"><shadow type="field_oid" id="~36EpE-Dh.%aRy]0dL{w"><field name="oid">landroid-s.0.mower.totalDistance</field></shadow></value>
              <statement name="STATEMENT"><block type="update" id="S,-y@#Ej9~m=utF99EPw"><mutation delay_input="false"></mutation>
                  <field name="OID">javascript.0.RasenmaeherJahresleistung</field>
                  <value name="VALUE"><block type="math_arithmetic" id="07JQ6A7r)S3;gICtpvHI"><field name="OP">MINUS</field>
                      <value name="A"><shadow type="math_number" id="lVEVi9L8HtNmh_swO3HM"><field name="NUM">1</field></shadow>
                        <block type="get_value" id="2n}GZzT21;^JMGj6}zz]"><field name="ATTR">val</field>
                          <field name="OID">landroid-s.0.mower.totalDistance</field></block></value>
                      <value name="B"><shadow type="math_number" id="5_]u:s|;/t#^2C8NPg^*"><field name="NUM">5000</field></shadow></value></block></value></block></statement></block></next></block></xml>
      Dadurch wird ein Javascript DP mit Namen "RasenmäherJahresleistung" generiert und bei jeder Änderung der Gesamtstrecke aktualisiert. Den abzuziehenden Wert musst du nur noch anpassen. Steht probehalber auf 5000m.
        m76 @tombox last edited by
        @ldittmar Funktioniert die Landroid App noch, wenn man den Adapter aktiviert?
        ldittmar 1 Reply Last reply Reply Quote 0
        • ldittmar
          ldittmar Developer @m76 last edited by
          @m76 klar doch... Also es ging die ganze Zeit. Leider habe ich kein Mähroboter mehr und kann es nicht testen.
            m76 @ldittmar last edited by
            @ldittmar danke ich teste es und update - hatte gefragt, da bei dem neato botvac adapter das leider nicht möglich ist 😞
              m76 @m76 last edited by
              @m76 said in Adapter: Worx Landroid:
              Sorry, muss mich korrigieren, es geht auch mit Neato Botvac, anscheinend lag das noch an der alten Firmware!
                m76 last edited by
                Hallo, habe heute den landroid adapter auch installiert, über die Admin webUI von iobroker, leider bekam ich diese Fehlermeldung und keine Daten außer, dass er connected=true ist:
                landroid.0 2019-02-26 15:32:43.832 info starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.landroid, node: v8.15.0
                landroid.0 2019-02-26 15:32:43.701 error : message handler implemented, but messagebox not enabled. Define common.messagebox in io-package.json for adapter or delete message han...
                Wie kann ich das fixen?
                thewhobox 1 Reply Last reply Reply Quote 0
                • thewhobox
                  thewhobox @m76 last edited by
                  @m76 laut dem Log fehlt im Adapter die Einstellung, dass er Messages versenden darf.
                  Du kannst mal probieren es selbst lokal hinzuzufügen.
                  Unter "/opt/iobroker/node_modules/iobroker.landroid/io-package.json" musst du den Eintrag messagebox ergänzen:
                  "compact": true,
                  "messagebox": true,
                  "subscribe": "messagebox"
                  "license": "MIT",
                  Das 'subscribe' musst du glaube ich auch hinzufügen, da es sonst auch nicht funktioniert und danach mal den Adapter neu starten.
                    m76 @thewhobox last edited by
                    @thewhobox said in Adapter: Worx Landroid:
                    "compact": true,
                    "messagebox": true,
                    danke, das "subscribe" wusste ich nicht, ohne hatte ich schonprobiert :} - die Fehlermeldung ist weg, bekomme aber keine Daten rein außer connected.
                    • thewhobox
                      @m76 Werden denn alle Objeket korrekt angelegt?
                      Ändert sich der state "info.lastsync" nach dem eingestellten Interval in Sekunden?
                        objekte sind da, lastsync ist nicht beschrieben, es klappt nur der ping
                        Hab im Code rumgewühlt, hier wird ja versucht auf port 80 der IP des landroid L zu connecten, aber laut nmap ist hier kein einziger Port offen? Huch? Hatte ich was übersehen?
                        • thewhobox
                          thewhobox @m76 last edited by thewhobox
                          @m76 Hmm. Du könntest dir ja mal die Response ins Log schieben lassen. Also:
                          request(getOptions, function (error, response, body) {
                           adapter.log.info(response.statusCode);
                           adapter.log.info(response);
                           adapter.log.info(body);
                            if (!error && response.statusCode == 200) {
                              try {
                                data = JSON.parse(body);
                                evaluateResponse();
                              } catch (e) {
                               adapter.log.warn(e);
                          Ich denke mal, dass der StatusCode nicht 200 ist und er deswegen evaluateResponse nicht ausführen kann.
                          Edit: Was passiert wenn du die URL im Browser aufrufst? (http://" + ip + ":80/jsondata.cgi)
                            @thewhobox
                            ja, aber ich sehe ja schon über nmap dass der port nicht offen ist, ein wget auf:
                            http://<ip>/jsondata.cgi
                            Connecting to <ip>:80... failed: Connection timed out.
                            Retrying.
                            Ist das im Landroid L nicht mehr möglich? 😞
                            • thewhobox
                              @m76 Hmm dann hat er den Port nicht offen bzw unterstützt es nicht mehr.
                              Evtl gibt es ja auch in der APp ne Einstellung, aber ich kann das ohne Gerät nur vermuten.
                                @thewhobox
                                Jupp, danke dir für all die Hilfe, ich hab den Support mal angeschrieben... bestimmt geschlossen in der neuen Firmware... grummel
                                  Modjo last edited by
                                  Hey Leute,
                                  ich habe mir heute den neuen WORX Landroid M500 (WR141E) bestellt. Das ist das 2019er Modell.
                                  Ist dieser auch mit dem Adapter kompatibel?
                                  VG
                                  Modjo
                                  Meistertr 1 Reply Last reply Reply Quote 0
                                  • Meistertr
                                    Meistertr Developer @Modjo last edited by
                                    @Modjo sagte in Adapter: Worx Landroid:
                                    Hey Leute,
                                    VG
                                    Modjo
                                    ich schätze dass der schon die 5.X SW Version drauf hat dann musst du den Landroid-S adapter nehmen
                                      Einklaus last edited by
                                      der WORX Landroid M500 (WR141E) funktioniert mit dem Adapter.
                                      Aktuelle SW(Firmware?) ist allerdings 2.74
                                        locito09 last edited by
                                        Hallo
                                        Ich habe den Landroid L WR155E
                                        Welchen adapter muss ich nehmen?
                                        Habe beide versucht ohne erfolg FW: 2.74
                                        Adapter für den M ist grün bekommt aber keine Daten.
                                        Adapter für den S ist gelb und keine Verbindung/Daten
                                          Hast du ihn bei Worx (MyLandroid) angemeldet ? Falls ja ...
                                          Die Mail Adresse und das Passwort mit dem er dort angemeldet ist für die Instanz nehmen.
                                          Dann habe ich die App(Handy) Installiert.
                                          Wenn die App Verbindung mit ihm hat, sollte auch IoBroker Daten bekommen (ist ein sicheres Zeichen, dass WLAN i.O. ist).
                                          Bei mir hat er Schwierigkeiten, wenn er zulange "nichts" macht, dann habe ich auch über die App keine Verbindung mit ihm. Muss dann den Robbi am Gerät einschalten und dann den Code eingeben. Dann hat er wieder Verbindung (oder warten bis er laut Zeitprogramm startet).
                                          Gehe davon aus, dass der WR155E nicht anders ist.
                                          • X
                                            Xanon last edited by
                                            gibt es eigentlich eine Möglichkeit den Landroid direkt zu einem Rasenkanten-Schnitt zu überreden?
                                            Ich kann dies zur Zeit nur über den Zeitplan steuern.
                                            Habe versucht ihn über den rawResponse {"cmd":4} loszuschicken.
                                            Er Fährt auch dem Kabel entlang aber in der app steht nur "Zonentraining"
                                            Ich glaube hier wird nicht geschnitten (sieht zumindest nicht so aus)
                                            Über {"cmd":1} startet er normal.
                                            Kennt einer von euch noch einen Befehl für "nur Kantenschnitt" oder geht das gar nicht?
                                            1194
                                            451951
