    4. ioBroker.upnp - please test
    • Neuschwansteini
      Neuschwansteini last edited by
      yep, hier auch, machmal alle 30min, manchmal 10min... unterschiedlich..
      • Neuschwansteini
        @Bluefox
        das ist eben im Log erschienen... kam nach den error: in lookupservice...
        2019-02-26 18:30:00.833  - warn: upnp.0 Unexpected answer from upnp service: {"statusCode":500,"body":"<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s:Body>\n<s:Fault>\n<faultcode>s:Client</faultcode>\n<faultstring>UPnPError</faultstring>\n<detail>\n<UPnPError xmlns=\"urn:schemas-upnp-org:control-1-0\">\n<errorCode>401</errorCode>\n<errorDescription>invalid action</errorDescription>\n</UPnPError>\n</detail>\n</s:Fault>\n</s:Body>\n</s:Envelope>","headers":{"date":"Tue, 26 Feb 2019 17:30:00 GMT","server":"FRITZ!Box 7590 UPnP/1.0 AVM FRITZ!Box 7590 154.07.01","connection":"close","content-length":"433","content-type":"text/xml; charset=\"utf-8\""},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"192.168.178.1:49000","port":"49000","hostname":"192.168.178.1","hash":null,"search":null,"query":null,"pathname":"/MediaServer/ServerStatus/Control","path":"/MediaServer/ServerStatus/Control","href":"http://192.168.178.1:49000/MediaServer/ServerStatus/Control"},"method":"POST","headers":{"Content-Type":"text/xml; charset=\"utf-8\"","SOAPAction":"\"urn:avm.de:service:AVM_ServerStatus:1#ScanInfo\"","USER-AGENT":"UPnP/1.0, ioBroker.upnp","content-length":234}}}
         Sent message: {"uri":"http://192.168.178.1:49000/MediaServer/ServerStatus/Control","headers":{"Content-Type":"text/xml; charset=\"utf-8\"","SOAPAction":"\"urn:avm.de:service:AVM_ServerStatus:1#ScanInfo\"","USER-AGENT":"UPnP/1.0, ioBroker.upnp"},"method":"POST","body":"\n<s:Envelope s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\" xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\">\n    <s:Body><u:ScanInfo xmlns:u=\"urn:avm.de:service:AVM_ServerStatus:1\"></u:ScanInfo></s:Body>\n</s:Envelope>"}
        2019-02-26 18:30:01.061  - warn: upnp.0 Unexpected answer from upnp service: {"statusCode":500,"body":"<?xml version=\"1.0\" encoding=\"utf-8\"?><s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns=\"urn:schemas-upnp-org:control-1-0\"><errorCode>402</errorCode><errorDescription>Invalid Args</errorDescription></UPnPError></detail></s:Fault></s:Body></s:Envelope>\r\n","headers":{"content-length":"436","content-type":"text/xml; charset=\"utf-8\"","connection":"close","ext":"","server":"Canon IJ-UPnP/1.0 UPnP/1.0 UPnP-Device-Host/1.0"},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"192.168.178.29:80","port":"80","hostname":"192.168.178.29","hash":null,"search":null,"query":null,"pathname":"/upnp/control/DPSConnectionManager","path":"/upnp/control/DPSConnectionManager","href":"http://192.168.178.29:80/upnp/control/DPSConnectionManager"},"method":"POST","headers":{"Content-Type":"text/xml; charset=\"utf-8\"","SOAPAction":"\"urn:schemas-cipa-jp:service:DPSConnectionManager:1#ConnectionRequest\"","USER-AGENT":"UPnP/1.0, ioBroker.upnp","content-length":265}}}
         Sent message: {"uri":"http://192.168.178.29:80/upnp/control/DPSConnectionManager","headers":{"Content-Type":"text/xml; charset=\"utf-8\"","SOAPAction":"\"urn:schemas-cipa-jp:service:DPSConnectionManager:1#ConnectionRequest\"","USER-AGENT":"UPnP/1.0, ioBroker.upnp"},"method":"POST","body":"\n<s:Envelope s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\" xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\">\n    <s:Body><u:ConnectionRequest xmlns:u=\"urn:schemas-cipa-jp:service:DPSConnectionManager:1\"></u:ConnectionRequest></s:Body>\n</s:Envelope>"}
          MyMeyer last edited by MyMeyer
          Hi, ich habe das Problem das mir der Adapter die externe IP von Router nicht in die Objekte schreibt. Nutze die letzte Version direkt vom Git. Sende alle 60 Sekunden die Abfrage der IP, aber unter Objekte erscheint sie nicht.
          Habt Ihr eine Idee?
          upnp.0 2019-02-27 20:47:52.331 debug All tasks processed
          upnp.0 2019-02-27 20:47:52.316 debug Started processTasks with 8 tasks
          upnp.0 2019-02-27 20:47:47.132 debug All tasks processed
          upnp.0 2019-02-27 20:47:47.130 debug firstDevLookup for http://0.0.0.0/upnp/basic_dev.cgi
          upnp.0 2019-02-27 20:47:47.129 debug Started processTasks with 1 tasks
          upnp.0 2019-02-27 20:47:47.129 info Found new device: http://0.0.0.0/upnp/basic_dev.cgi
          upnp.0 2019-02-27 20:47:15.283 debug All tasks processed
          upnp.0 2019-02-27 20:47:15.162 debug response: <?xml version="1.0" encoding="utf-8"?> <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"> <s:Body> <u:GetAddonInfosR
          upnp.0 2019-02-27 20:47:15.004 debug Send Command for upnp.0.WANDevice_-FRITZ!Box_7490.WANDevice.WANCommonInterfaceConfig.GetAddonInfos.request
          upnp.0 2019-02-27 20:47:15.003 debug Started processTasks with 1 tasks
          upnp.0 2019-02-27 20:46:15.386 debug All tasks processed
          upnp.0 2019-02-27 20:46:15.271 debug response: <?xml version="1.0" encoding="utf-8"?> <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"> <s:Body> <u:GetAddonInfosR
          upnp.0 2019-02-27 20:46:15.004 debug Send Command for upnp.0.WANDevice
          -_FRITZ!Box_7490.WANDevice.WANCommonInterfaceConfig.GetAddonInfos.request
          upnp.0 2019-02-27 20:46:15.003 debug Started processTasks with 1 tasks
          upnp.0 2019-02-27 20:45:29.865 debug system.adapter.admin.0: logging true
          upnp.0 2019-02-27 20:45:15.463 debug All tasks processed
            sigi234 Forum Testing Most Active @MyMeyer last edited by sigi234
            @MyMeyer
            Die bekommst du ja eh automatisch mit request?
            Ist bei mir unter :
              MyMeyer @sigi234 last edited by
              @sigi234 sagte in ioBroker.upnp - please test:
              @MyMeyer
              Ist bei mir unter :
              Ja DNS bekomme ich auch das läuft, aber ich die externe IP haben.
                @MyMeyer
                Aha, du meinst die IPv4-Adresse...........
                  MyMeyer @sigi234 last edited by MyMeyer
                  @sigi234
                  Ja 😀
                  upnp.0.WANConnectionDevice_-_FRITZ!Box_7490.WANDevice.WANConnectionDevice.WANIPConnection.GetExternalIPAddress
                  Hier Frage ich an...
                    @MyMeyer
                      EddieFAF last edited by
                      Ich habe das gleiche Problem. Die anderen Datenpunkte lassen sich abrufen, ExternalIP nicht ;(
                      • Neuschwansteini
                        hmm bei mir funktionierts... wenn Ihr den request-butten betaetigt, was steht dann im logfile? ( vorher auf debug stellen )
                          sigi234 Forum Testing Most Active @Neuschwansteini last edited by
                          @ilovegym sagte in ioBroker.upnp - please test:
                          Geht bei mir auch.....
                            @Bluefox
                            Kann man diese Meldungen nicht deaktivieren? Kommen regelmäßig und eine Menge davon.
                            upnp.0	2019-02-28 13:05:15.879	error	Error in lookupService: No object dummy
                            upnp.0	2019-02-28 13:05:15.877	error	Error in lookupService: No object dummy
                            upnp.0	2019-02-28 13:05:15.876	error	Error in lookupService: No object upnp.0._TV__UE40JU6450.dialreceiver.dial.sid
                            Neuschwansteini sigi234 2 Replies Last reply Reply Quote 0
                            • Neuschwansteini
                              Neuschwansteini @sigi234 last edited by
                              @sigi234 das hat er doch extra eingebaut, um noch Fehler zu finden 🙂 das kommt, wenn alles geht, wieder raus..
                              Lass Dich dadurch nicht verwirren.. sieht halt nicht schoen aus im Log.
                                MyMeyer @EddieFAF last edited by
                                @EddieFAF sagte in ioBroker.upnp - please test:
                                Jetzt geht es bei mir auch.
                                Ich habe den Adapter pausiert. Objekt "GetExternalIPAddress" komplett gelöscht. Und Adapter wieder gestartet. Dann den Button gedrückt und nun steht die IP auch drinnen.
                                • Asgothian
                                  Asgothian Developer last edited by
                                  Nur mal kurz als Status - ich hab mir den Adapter vor ein paar Tagen herunter geladen - nutze den aber ausschliesslich mit meiner FritzBox um die Internet Verbindung zu loggen. Er funktioniert bei mir ohne auffälligkeiten.
                                  A.
                                    helfi9999 @Bluefox last edited by
                                    @Bluefox
                                    also bei mir läuft es
                                      @Bluefox
                                      bekomme heute folgende Meldung:
                                      host.rock64 2019-03-01 09:32:43.337 info instance system.adapter.upnp.0 started with pid 29788
                                      host.rock64 2019-03-01 09:32:13.278 info Restart adapter system.adapter.upnp.0 because enabled
                                      host.rock64 2019-03-01 09:32:13.277 error instance system.adapter.upnp.0 terminated with code 0 (OK)
                                      Caught 2019-03-01 09:32:13.277 error by controller[0]: at TCP.onread (net.js:601:20)
                                      Caught 2019-03-01 09:32:13.276 error by controller[0]: at Socket.Readable.push (_stream_readable.js:208:10)
                                      Caught 2019-03-01 09:32:13.276 error by controller[0]: at readableAddChunk (_stream_readable.js:250:11)
                                      Caught 2019-03-01 09:32:13.276 error by controller[0]: at addChunk (_stream_readable.js:263:12)
                                      Caught 2019-03-01 09:32:13.275 error by controller[0]: at Socket.emit (events.js:211:7)
                                      Caught 2019-03-01 09:32:13.275 error by controller[0]: at emitOne (events.js:116:13)
                                      Caught 2019-03-01 09:32:13.275 error by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/redis/index.js:274:27)
                                      Caught 2019-03-01 09:32:13.274 error by controller[0]: at JavascriptRedisParser.execute (/opt/iobroker/node_modules/redis-parser/lib/parser.js:574:12)
                                      Caught 2019-03-01 09:32:13.274 error by controller[0]: at JavascriptRedisParser.returnReply (/opt/iobroker/node_modules/redis/index.js:192:18)
                                      Caught 2019-03-01 09:32:13.274 error by controller[0]: at RedisClient.return_reply (/opt/iobroker/node_modules/redis/index.js:824:9)
                                      Caught 2019-03-01 09:32:13.273 error by controller[0]: at normal_reply (/opt/iobroker/node_modules/redis/index.js:726:21)
                                      Caught 2019-03-01 09:32:13.273 error by controller[0]: at Command.callback (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:238:17)
                                      Caught 2019-03-01 09:32:13.273 error by controller[0]: at adapter.getState (/opt/iobroker/node_modules/iobroker.upnp/main.js:1333:17)
                                      Caught 2019-03-01 09:32:13.272 error by controller[0]: at setNewState (/opt/iobroker/node_modules/iobroker.upnp/main.js:1415:37)
                                      Caught 2019-03-01 09:32:13.271 error by controller[0]: TypeError: Cannot read property 'length' of null
                                      upnp.0 2019-03-01 09:32:13.174 error at TCP.onread (net.js:601:20)
                                      upnp.0 2019-03-01 09:32:13.174 error at Socket.Readable.push (_stream_readable.js:208:10)
                                      upnp.0 2019-03-01 09:32:13.174 error at readableAddChunk (_stream_readable.js:250:11)
                                      upnp.0 2019-03-01 09:32:13.174 error at addChunk (_stream_readable.js:263:12)
                                      upnp.0 2019-03-01 09:32:13.174 error at Socket.emit (events.js:211:7)
                                      upnp.0 2019-03-01 09:32:13.174 error at emitOne (events.js:116:13)
                                      upnp.0 2019-03-01 09:32:13.174 error at Socket.<anonymous> (/opt/iobroker/node_modules/redis/index.js:274:27)
                                      upnp.0 2019-03-01 09:32:13.174 error at JavascriptRedisParser.execute (/opt/iobroker/node_modules/redis-parser/lib/parser.js:574:12)
                                      upnp.0 2019-03-01 09:32:13.174 error at JavascriptRedisParser.returnReply (/opt/iobroker/node_modules/redis/index.js:192:18)
                                      upnp.0 2019-03-01 09:32:13.174 error at RedisClient.return_reply (/opt/iobroker/node_modules/redis/index.js:824:9)
                                      upnp.0 2019-03-01 09:32:13.174 error at normal_reply (/opt/iobroker/node_modules/redis/index.js:726:21)
                                      upnp.0 2019-03-01 09:32:13.174 error at Command.callback (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:238:17)
                                      upnp.0 2019-03-01 09:32:13.174 error at adapter.getState (/opt/iobroker/node_modules/iobroker.upnp/main.js:1333:17)
                                      upnp.0 2019-03-01 09:32:13.174 error at setNewState (/opt/iobroker/node_modules/iobroker.upnp/main.js:1415:37)
                                      upnp.0 2019-03-01 09:32:13.174 error TypeError: Cannot read property 'length' of null
                                      upnp.0 2019-03-01 09:32:13.174 error uncaught exception: Cannot read property 'length' of nul
                                      • Bluefox
                                        Bitte 1.0.7 testen
                                        Neuschwansteini 1 Reply Last reply Reply Quote 2
                                        • Neuschwansteini
                                          Neuschwansteini @Bluefox last edited by
                                          @Bluefox 🙂 Danke fürs Update, bist ja megafleissig ! passt auch gerade.. brauch keine Fastnacht, hab das ganze Jahr genug Narren um mich 🙂
                                          Bis jetzt keine Fehler, loglevel debug... hab nix zu meckern... 👍 👌
                                            sigi234 Forum Testing Most Active @sigi234 last edited by sigi234
                                            @Bluefox
                                            Danke Bluefox, Fehler sind weg mit Version 1.0.7☺
                                            31.7k
                                            79.8k
                                            adapter test
                                            18
                                            196
                                            19480
