    4. KNX Adapter überholt
      sound31 last edited by
      Hallo Chefkoch!
      Nach dem Update des Adapters auf die Version 1.0.19 startet dieser nun alle 30 sec. neu.
      undefined2019-01-25 07:17:06.541 - error: host.Visu-Beelink instance system.adapter.knx.0 terminated with code 7 (Adapter already running)
      2019-01-25 07:17:06.541 - info: host.Visu-Beelink Restart adapter system.adapter.knx.0 because enabled
      2019-01-25 07:17:36.563 - info: host.Visu-Beelink instance system.adapter.knx.0 started with pid 22190
      2019-01-25 07:17:37.707 - error: host.Visu-Beelink instance system.adapter.knx.0 terminated with code 7 (Adapter already running)
      2019-01-25 07:17:37.707 - info: host.Visu-Beelink Restart adapter system.adapter.knx.0 because enabled
      2019-01-25 07:18:07.741 - info: host.Visu-Beelink instance system.adapter.knx.0 started with pid 22221
      2019-01-25 07:18:08.910 - error: host.Visu-Beelink instance system.adapter.knx.0 terminated with code 7 (Adapter already running)
      2019-01-25 07:18:08.910 - info: host.Visu-Beelink Restart adapter system.adapter.knx.0 because enabled
      2019-01-25 07:18:38.947 - info: host.Visu-Beelink instance system.adapter.knx.0 started with pid 22231
      2019-01-25 07:18:40.219 - error: host.Visu-Beelink instance system.adapter.knx.0 terminated with code 7 (Adapter already running)
      2019-01-25 07:18:40.220 - info: host.Visu-Beelink Restart adapter system.adapter.knx.0 because enabled
      2019-01-25 07:19:10.256 - info: host.Visu-Beelink instance system.adapter.knx.0 started with pid 22261
      2019-01-25 07:19:11.392 - error: host.Visu-Beelink instance system.adapter.knx.0 terminated with code 7 (Adapter already running)
      2019-01-25 07:19:11.393 - info: host.Visu-Beelink Restart adapter system.adapter.knx.0 because enabled
      2019-01-25 07:19:41.428 - info: host.Visu-Beelink instance system.adapter.knx.0 started with pid 22271
      2019-01-25 07:19:42.576 - error: host.Visu-Beelink instance system.adapter.knx.0 terminated with code 7 (Adapter already running)
      2019-01-25 07:19:42.576 - info: host.Visu-Beelink Restart adapter system.adapter.knx.0 because enabled
      2019-01-25 07:20:12.603 - info: host.Visu-Beelink instance system.adapter.knx.0 started with pid 22301
      2019-01-25 07:20:13.739 - error: host.Visu-Beelink instance system.adapter.knx.0 terminated with code 7 (Adapter already running)
      2019-01-25 07:20:13.740 - info: host.Visu-Beelink Restart adapter system.adapter.knx.0 because enabled
      2019-01-25 07:20:43.773 - info: host.Visu-Beelink instance system.adapter.knx.0 started with pid 22311
      2019-01-25 07:20:44.914 - error: host.Visu-Beelink instance system.adapter.knx.0 terminated with code 7 (Adapter already running)
      2019-01-25 07:20:44.914 - info: host.Visu-Beelink Restart adapter system.adapter.knx.0 because enabled
      2019-01-25 07:21:14.949 - info: host.Visu-Beelink instance system.adapter.knx.0 started with pid 22341
      2019-01-25 07:21:16.096 - error: host.Visu-Beelink instance system.adapter.knx.0 terminated with code 7 (Adapter already running)
      2019-01-25 07:21:16.096 - info: host.Visu-Beelink Restart adapter system.adapter.knx.0 because enabled
      2019-01-25 07:21:46.131 - info: host.Visu-Beelink instance system.adapter.knx.0 started with pid 22351
      2019-01-25 07:21:47.275 - error: host.Visu-Beelink instance system.adapter.knx.0 terminated with code 7 (Adapter already running)
      2019-01-25 07:21:47.275 - info: host.Visu-Beelink Restart adapter system.adapter.knx.0 because enabled
      2019-01-25 07:22:17.302 - info: host.Visu-Beelink instance system.adapter.knx.0 started with pid 22363
      2019-01-25 07:22:18.424 - error: host.Visu-Beelink instance system.adapter.knx.0 terminated with code 7 (Adapter already running)
      2019-01-25 07:22:18.425 - info: host.Visu-Beelink Restart adapter system.adapter.knx.0 because enabled
      2019-01-25 07:22:48.458 - info: host.Visu-Beelink instance system.adapter.knx.0 started with pid 22393
      2019-01-25 07:22:49.631 - error: host.Visu-Beelink instance system.adapter.knx.0 terminated with code 7 (Adapter already running)
      2019-01-25 07:22:49.631 - info: host.Visu-Beelink Restart adapter system.adapter.knx.0 because enabled
      2019-01-25 07:23:19.665 - info: host.Visu-Beelink instance system.adapter.knx.0 started with pid 22403
      2019-01-25 07:23:20.802 - error: host.Visu-Beelink instance system.adapter.knx.0 terminated with code 7 (Adapter already running)
      2019-01-25 07:23:20.802 - info: host.Visu-Beelink Restart adapter system.adapter.knx.0 because enabled
      Was kann ich dagegen tun?
      Grüße, Andy
      • Garfonso
        Garfonso Developer last edited by
        @sound31:
        Hallo Chefkoch!
        Grüße, Andy ` Da steht "Adapter already running". Vermutlich läuft da noch ein Zombie. Das einfachste dürfte sein den ganzen Rechner mal neuzustarten.
        Gesendet von meinem LYA-L29 mit Tapatalk
          Das habe ich versucht -> keine Wirkung.
          Nachdem ich nun den Adapter Deinstalliert habe und Neu Installiert funktioniert das richtig,
          alle Schalter und Status-Objekte werden richtig dargestellt.
          Kleines Problem am Rande - kann den Adapter nicht Einstellen.
          chefkoch009 1 Reply Last reply Reply Quote 0
            cadmando last edited by
            ich habe gerade frisch mit IO-Broker begonnen und mir die Version 1.0.19 des KNX-Adapters installiert.
            Der Import meines Projektfiles hat soweit erst einmal gut funktioniert und ich kann alle Schaltzustände und Temperaturen der Objekte sehen und auch protokollieren. Das Funktioniert schon mal super.
            Wo ich auf ein Problem gestoßen bin, von dem ich die Ursache noch nicht gefunden habe, ist das - bisher nur bei einem von drei getesteten - Aktoren, ich den Schaltzustand nicht zuverlässig ändern kann.
            Ich habe bei mir im Keller drei Lampen, zwei kann ich ohne Probleme verändern, eine will manchmal - manchmal nicht.
            Dietmar
            PS: Gibt es eine Möglichkeit Eigenschaften der Objekte im Paket zu verändern - Beispielsweise ob schreib bar? Erscheint mir auf Dauer etwas mühselig.
            • chefkoch009
              chefkoch009 Developer @sound31 last edited by
              @sound31 führe Mal bitte in deiner Konsole im iobroker installationsverzeichnis folgendes aus: "iobroker u knx".
              Anschließend sollte der konfigurationsdialog korrekt erscheinen Punkt
              VG
              Chefkoch009
              • Merlin123
                Merlin123 @tombox last edited by Merlin123
                @tombox sagte in KNX Adapter überholt:
                Die GAs die ein Status anzeigen sollte wie die GAs heißen mit denen ein Zustand gesetzt nur mit „ status“ am Ende dann verknüpft der knx Adapter die beiden Adressen automatisch.
                Wie kann ich die manuell sauber verknüpfen? Oder alternativ: Wenn ich die in der ETS umbenenne und das ganze neu einlese: Wird es dann sauber verknüpft?
                  tombox @Merlin123 last edited by
                  @Merlin123 ja müssten dann automatisch verknüpft werden
                  • chefkoch009
                    chefkoch009 Developer last edited by
                    Hallo @all,
                    willkommen zurück in einem niegelnagelneuem Forum. 👍
                    Ich habe die Version 1.0.20 online gestellt. In dieser wurde ein Bug in der Process-queue beseitigt, welcher für mitunter häufige re-connects gesorgt hat. Weiterhin wurde die upload Routine für knxproj Dateien optimiert.
                    Viel Spass beim Testen.....und schon vielen Dank im Vorraus für euer Feedback.
                    VG
                    chefkoch009
                    S 1 Reply Last reply Reply Quote 2
                    • Merlin123
                      Werd ihn heute abend mal installieren. Danke für Deine Arbeit 🙂
                      • Merlin123
                        Installation war problemlos, läuft bisher unauffällig.
                        • Merlin123
                          So.. Hatte endlich mal Zeit das zu testen. Hab die Status Objekte in der ETS umbenannt, in iobroker die Status Objekte gelöscht und neu importiert.
                          Hat geklappt. Sind sauber verknüpft 🙂
                          Danke!
                          • cvidal
                            Auch hier keine Probleme, hatte ein paar Kleinigkeiten mit der ETS verändert,
                            Projektdatei hochgeladen, wurde auch alles sauber importiert.
                            Gruß Christian
                              axel.rathey last edited by
                              Hallo Chefkoch,
                              auch bei der 1.0.20 habe ich leider weiterhin Probleme meine KNX-Projekt-Datei einzulesen. Habe die 1.0.20 installiert, dann die KNX-Objekte in eine json Datei gesichert. Dann habe ich mal den Zweig für meine KNX-Außenobjekte gelöscht. Beim Einlesen der knx.proj Datei (nur neuere Objekte) kommt dann kurz eine Meldung "Handling devices finished". Der rollende Wartebalken läuft aber weiter bis in alle Ewigkeit, ich muss dann wieder mit Speichern und schließen abbrechen.
                              Der erhoffte Erstellen des Zweiges mit den Außenobjekten hat nicht geklappt. Habe diese dann aus der json-Datei wiederhergestellt.
                              Alle anderen Teile von iobroker sind soweit aktuell, habe vorher alle Updates eingespielt. Kann ich eventuell dir die proj-Datei mal zukommen lassen, damit du das Einlesen testen kannst?
                              Viele Grüße
                              Axel
                                excalibur270 last edited by
                                Hallo. Wie bekomme ich zb die Außentemperatur von HM auf den Bus damit mein glastaster diese anzeigen kann?
                                Adapter läuft knxproj ist eingelesen.
                                Habe es mit blockly versucht. Der datenpunkt wird auch befüllt in knx.0. Aber der taster zeigt nichts an. Gehe ich falsch ran?
                                  tombox @excalibur270 last edited by
                                  @excalibur270 zeig mal ein Bild von Dateninhalt und ko im ets
                                    excalibur270 @tombox last edited by excalibur270
                                    @tombox Danke für deine Antwort. Läuft jetzt. Hatte im blockly aktualisiere anstatt steuere angewählt. Schäm.
                                    Edit. Jetzt wieder nicht. Nur einmal die busspannung weg.
                                      adsid last edited by
                                      Hallo Zusammen
                                      Bin neu im IO Broker.
                                      Habe die ETS Datei importiert habe es schon hingekriegt das die Lampen ein und ausschalten und ich sie dimmen kann inkl. Rückmeldung.
                                      Soweit so gut. Leider kriege ich die Jalousien nicht hin. Welches Widget muss ich in der Viso nehmen ud welche Werte muss ich vom KNX Adapter verwenden. Jalousien Aktor ist ABB jas 4.230.
                                      Fogende Werte habe ich zur Auswahl:
                                      Habe in den Widgets auch keine Möglichkeit die Lamellenstellung anzuwählen.
                                      Bitte um Hilfe oder einen Ansatz.
                                      Gruss Adsid
                                        excalibur270 last edited by excalibur270
                                        Hallo. Ich brauche mal Hilfe. Projekt ist angelegt und eingelesen. Die dp werden auch angelegt. Ich habe bislang nur einen glastaster 2smart von mdt im Einsatz. Damit wollte ich ganz gerne ein paar steuerfunktionen realisieren. Ich habe zb für taste 1 die grp adr angelegt und in meinem Fall mit bodenstrahler benannt. Für die Statusanzeige am Taster eine weitere die da heißt bodenstrahler Status. Ich kann mittlerweile vom Taster aus via blockly die Strahler ansteuern. Nur das mit dem Status will nicht hinhauen.
                                        Ist denn das Projekt richtig Parametriert mit den Adressen bzw namen?
                                        Wo liegt mein Denkfehler.
                                          loverz last edited by
                                          Weiß nicht, ob das hier her gehört, aber mir ist aufgefallen, dass umbenannte oder alte Gruppenadressen in ioBroker weiterhin dargestellt werden.
                                          Bei mir hilft nur das Löschen des Adapters und neu einlesen der knxproj-Datei.
                                          Gibt es da vielleicht auch eine sauberere Lösung?
                                            schmid_no1 last edited by
                                            @loverz GA s die es in deinem knx Projekt jetzt nicht mehr gibt werden nicht automatisch gelöscht entweder die raus suchen die du nicht mehr hast oder alle GA s löschen und projekt neu laden
                                            1043
                                            338865
