    4. Node-Red
    5. Node-red: Spritpreise einlesen
    • ruhr70
      ruhr70 last edited by
      Was kommt denn, wenn Du die URL, die Du im http response node eingetragen hast, direkt im Browser eingibst?
      Kannst Du das Ergebnis hier posten.
      stations[1] ist die zweite Tankstelle.
      Vielleicht ergibt Dein eingestellter Radius ja weniger als eine Tankstelle.
      • derAuge
        derAuge last edited by
        {"license":"CC BY 4.0 -  http:\/\/creativecommons.tankerkoenig.de","data":"MTS-K","stations":[{"name":"JET BORKEN NORDRING 46-48","lat":51.84667,"lng":6.84642,"brand":"JET","dist":1.7,"price":1.189,"id":"XXXX","street":"NORDRING 46-48","houseNumber":null,"postCode":46325,"place":"BORKEN"},{"name":"AVIA Tankstelle","lat":51.852592,"lng":6.864203,"brand":"AVIA","dist":0.4,"price":1.199,"id":"11652441-f3fc-4fc9-a87a-664db366b5af","street":"Ahauser Stra\u00dfe","houseNumber":"21","postCode":46325,"place":"Borken"},{"name":"AVIA Tankstelle","lat":51.85873,"lng":6.8657813,"brand":"AVIA","dist":0.8,"price":1.199,"id":"XXXX","street":"Ahauser Stra\u00dfe","houseNumber":"84","postCode":46325,"place":"Borken"},{"name":"A. Kuenstler GmbH","lat":51.86033,"lng":6.87505,"brand":"A. Kuenstler GmbH","dist":1,"price":1.199,"id":"XXXX","street":"Landwehr","houseNumber":"27","postCode":46325,"place":"Borken"},{"name":"AVIA Service Station","lat":51.857345,"lng":6.875487,"brand":"Freie Tankstelle","dist":0.8,"price":1.239,"id":"XXXX","street":"Otto-Hahn-Str.","houseNumber":"35","postCode":46325,"place":"Borken"},{"name":"Autozentrum Ebber GmbH & Co.KG","lat":51.83871,"lng":6.85797,"brand":"Westfalen","dist":1.6,"price":1.239,"id":"XXXX","street":"Raesfelder Str.","houseNumber":"24","postCode":46325,"place":"Borken"},{"name":"Aral Tankstelle","lat":51.844696,"lng":6.843055,"brand":"ARAL","dist":2,"price":1.239,"id":"XXXX","street":"Nordring","houseNumber":"178","postCode":46325,"place":"Borken"}]}
        1620_betriebsstundenzaehler_097.js
        • ruhr70
          Um Deine zweite Frage zu beantworten… es funktioniert wunderbar.
          Deine URL ermittelt sieben Tankstellen.
          Deine Funktion müsste den Preis der 2. Tankstelle ermitteln (derzeit AVIA), 1,199 EUR.
          Ich würde jetzt ein Debug node direkt hinter dem http response node setzen. Dann müsste die Ausgabe rauskommen, die Du vorhin gepostet hattest.
          • derAuge
            @ruhr70:
            Ich würde jetzt ein Debug node direkt hinter dem http response node setzen. Dann müsste die Ausgabe rauskommen, die Du vorhin gepostet hattest. `
            genau das habe ich ja gemacht
            ich schreich ja auch in eine Datei
            Da kann ich ja sehen was abgeholt wurde
            aber die Funktion (Station 1) bringt nur die Fehlermeldung
            msg.payload = msg.payload.stations[1].price;
            return msg;
            • ruhr70
              der Returntyp aus der http Abfrage ist falsch.
              Du nutzt noch Text aus dem ersten Beispiel ganz oben.
              Um JSON mit dem Script auszugeben muss der Returntyp auf Objekt stehen.
              D.h. Deine erste Funktion wird dann nicht mehr korrekt funktionieren.
              • derAuge
                Super
                Danke für den Tipp
                Wenn es als Objekt übergeben wird
                dann funktioniert es
                derAuge
                • derAuge
                  @ruhr70:
                  Hallo Rainer,
                  schöner flow 🙂
                  Wenn Du gezielt Tankstellen abfragen willst, dann kannst Du das über die ID der Tankstelle und der Detailabfrage machen.
                  Beispiel, Abfrage der Tankstelle mit der ID 646a461e-2341-4b5f-8f8b-09edc8f7d22c
                  https://creativecommons.tankerkoenig.de … 5552056644
                  (funktioniert ohne den API-Key)
                  Dort findest Du dann auch die Öffnungszeiten der Tankstelle.
                  Folgende Datenfelder werden ausgegeben:
                  filename="2015-04-23 Tankerkönig Detailabfrage.jpg" index="0">~~
                  Viele Grüße nach Godorf 😉
                  Michael `
                  Hallo Michael,
                  das möchte ich auch umsetzen.
                  nutze ein GET mit "https://creativecommons.tankerkoenig.de/json/detail.php + id + Key"
                  wird als JSON- Objekt übergeben
                  Das speichen in deiner Datei ergibt folgenden Inhalt:
                  	"license" : "CC BY 4.0 -  http://creativecommons.tankerkoenig.de",
                  	"data" : "MTS-K",
                  	"station" : {
                  		"id" : "51d4b6b0-a095-1aa0-e100-80009459e03a",
                  		"name" : "JET BORKEN NORDRING 46-48",
                  		"brand" : "JET",
                  		"street" : "NORDRING 46-48",
                  		"houseNumber" : null,
                  		"postCode" : 46325,
                  		"place" : "BORKEN",
                  		"overrides" : [],
                  		"openUntil" : 1430172000,
                  		"isOpen" : true,
                  		"e5" : 1.509,
                  		"e10" : 1.489,
                  		"diesel" : 1.279,
                  		"lat" : 51.84667,
                  		"lng" : 6.84642,
                  		"state" : null,
                  		"openingTimes" : [{
                  				"text" : "Montag, Dienstag, Mittwoch, Donnerstag",
                  				"start" : "05:00:00",
                  				"end" : "00:00:00"
                  				"text" : "Freitag, Sonntag",
                  				"start" : "07:00:00",
                  				"end" : "00:00:00"
                  				"text" : "Samstag",
                  				"start" : "06:00:00",
                  				"end" : "00:00:00"
                  nun möchte ich über eine Funktion ein einige Daten heraus filtern
                  z.B.:
                  msg1 = {};
                  msg1.payload = msg.payload.station[0].name;
                  msg2 = {};
                  msg2.payload = msg.payload.station[0].diesel;
                  msg3 = {};
                  msg3.payload = msg.payload.station[0].isOpen;
                  msg4 = {};
                  msg4.payload = msg.payload.station[0].openUntil;
                  return [msg1,msg2,msg3,msg4];
                  das funktioniert leider nicht. :oops: Ich habe da wohl noch einiges nicht verstanden
                  folgende Fehlermeldung:
                  • TypeError: Cannot read property '0' of undefined (line 1, col 39
                  • node-red-0 2015-04-26 13:12:57 error 26 Apr 13:12:57 - [error] [function:(detail) Daten extrahieren] TypeError: Cannot read property '0' of undefined (line 1, col 39)
                  Was mache ich falsch?
                  derAuge
                  • ruhr70
                    bin unterwegs
                    nimm mal bitte das [0] weg.
                    • derAuge
                      @ruhr70:
                      bin unterwegs
                      nimm mal bitte das [0] weg. `
                      Danke für den Tipp.
                      So geht es:
                      msg1 = {};
                      msg1.payload = msg.payload.station.name;
                      msg2 = {};
                      msg2.payload = msg.payload.station.diesel;
                      msg3 = {};
                      msg3.payload = msg.payload.station.isOpen;
                      msg4 = {};
                      msg4.payload = msg.payload.station.openUntil;
                      Dann kann ich nun weiter testen (lernen)
                      derAuge
                      • ruhr70
                        na, dann sind wir da ähnlich weit.
                        hab mit dem Thema auch gerade erst angefangen.
                        wie ich das verstanden habe hängt es von der Struktur des JSON ab, Ob du [] brauchst oder nicht.
                        wenn es mehrere Werte geben kann ist der Teil als Array (?) strukturiert. dann brauchst du die Klammern. Das erkennt man an der Baumstruktur
                        sorry für den chaotischer Text. Er ist per Spracheingabe diktiert.
                          pix last edited by
                          mich hat bei der Ausgabe der Spritpreise die dritte Stelle nach dem Komma (Hoch 9) gestört. In Deutschland wird sie zur Berechnung herangezogen,im Sprachgebrauch aber nie genannt. Zur Anzeige in VIS habe ich deshalb ein kleines Skript geschrieben, dass den Preis auf zwei Nachkommastellen setzt, ohne zu runden.
                          /* System VIS Spritpreis
                          Skript kürzt Spritpreis aus Node Red um eine Stelle (von drei auf zwei Stellen nach dem Komma)
                          in Vis Widget wird die Entität ⁹ (hoch 9) bzw mit <sup>9</sup> angehängt.
                          (aus 1.119 wird 1.11hoch9)
                          erstellt: 28.04.2015 von pix
                          // Erstellen der Variablen
                          createState('Sprit_Preis_kurz');
                          var idPreis = "node-red.0.sprit_preis"/*sprit_preis*/
                              idPreis_kurz = "javascript.0.Sprit_Preis_kurz";
                          // Preis kürzen
                          on( {
                              valGt: 0
                          }, function (data) {
                              var rechenwert = data.newState.val * 100; // 100facher Preis jetzt mit einer Nachkommastelle
                              rechenwert = Math.floor(rechenwert); // Nachkommastelle (.9) wird abgeschnitten
                              rechenwert = rechenwert/100; // es bleiben zwei Nachkommastellen
                              setState(idPreis_kurz, rechenwert);
                          Voranstellen HTML:````
                          Diesel
                          HTML anhängen:````
                          <sup>9</sup> €
                          Font-Size: 30px
                          Pix
                            Das ist eine gute Idee. Die Optik ist super, aber….
                            Es gibt tatsächlich Tankstellen, die mit halben cent arbeiten und z.b. den Diesel dann für 1.184 anbieten.
                            Rainer
                            Gesendet von meinem Cynus T7 mit Tapatalk
                            • ruhr70
                              @Homoran:
                              Es gibt tatsächlich Tankstellen, die mit halben cent arbeiten und z.b. den Diesel dann für 1.184 anbieten. `
                              Da würde ich mir das Leben dann sehr einfach machen…
                              Prüfen, ob der Preis auf 4 oder 9 endet.
                              Dementsprechend in eine Steuervariable eine 4 oder 9 schreiben.
                              Zwei Widgets übereinander legen (eins mit hoch 4 und eins mit hoch 9).
                              Das entsprechende Widget anzeigen, je nach dem Wert der Steuervariable (Sichtbarkeit).
                              • ruhr70
                                So, die super Idee von pix geklaut und umgearbeitet. :roll:
                                • alles in Node-red, benötigt kein Script im Javascript Adapter
                                • node kann einfach hinter weiteren Preisen kopiert werden
                                • berücksichtigt 3. Nachkommastelle mit 4 oder 9
                                Einfach hinter der function node für den ermittelten Spritpreis eine weitere function node (mit zwei Ausgängen) mit folgenden Code einsetzen:
                                // Preis kürzen
                                    var rechenwert = msg.payload * 100;   // 100facher Preis jetzt mit einer Nachkommastelle
                                    var rechenwert2 = msg.payload * 1000; // 1000facher Preis ohne Nachkommastelle
                                    rechenwert = Math.floor(rechenwert);  // Nachkommastelle (.x) wird abgeschnitten
                                    msg1 = {};
                                    msg1.payload = rechenwert;            // Preis mit 2 Nachkommastellen ausgeben (abgeschnitten)
                                    msg2 = {};
                                    msg2.payload = rechenwert2 - (rechenwert * 1000); // Dritte Nachommastelle einzeln ermitteln
                                return [msg1,msg2];
                                Node hinter dem Spritpreis, um diesen zu zerlegen.
                                Ausgang 1 enthält den Spritpreis mit zwei Nachkommastellen (abgeschnitten, nicht gerundet), z.B. 1,19
                                Ausgang 2 enthält die dritte Nachkommestellen (z.B. 4 oder 9), z.B. 9
                                Beide Ausgänge einer Node-red Variable zuweisen (die blaue ioBroker out node).
                                In VIS nun zwei Widgets übereinanderlegen.
                                1. Widget, wie von pix beschrieben, mit der Endung hoch 4
                                2. Widget, wie von pix beschrieben, mit der Endung hoch 9
                                Die Variable mit der 3. Nachkommastelle wird nun für die Sichtbarkeit verwendet.
                                Steht dort eine 4, wird das erste Widget angezeigt. Bei eine 9 das 2. Widget.
                                • ruhr70
                                  Kleine Aufgabe ist noch drin…
                                  Wenn ein Spritpreis an der zweiten Stelle nach dem Komma eine 0 hat, wird diese als Zahl nicht dargestellt (das dürfte beim Script von pix auch der Fall sein).
                                  D.h. 1,409 wird als 1,4 und 9 ausgegeben.
                                  [EDIT] -gelöst-
                                  Kleine Anpassung im Script. Der auf zwei Stellen gerundete Spritpreis wird nun als String ausgegeben.
                                  Für Rickshaw usw. verwende ich weiterhin den originalen Spritpreis mir drei Nachkommastellen.
                                  Für die VIS Ausgabe von pix nehme ich die zwei Nachkomatellen als String
                                  // Preis kürzen
                                      msg1 = {};
                                      msg1.payload = rechenwert.toFixed(2); // Preis mit 2 Nachkommastellen ausgeben (abgeschnitten)
                                      msg2 = {};
                                  return [msg1,msg2];
                                  • ruhr70
                                    Tankstellen per Detailabfrage.
                                    Design der Preisangaben von pix.
                                    Dritte Stelle hinter Komma nach Angaben von von Homoran berücksichtigt (4 und 9).
                                    Script für zwei Stellen hinterm Komma und separate dritte Stelle von pix angepasst.
                                      Super Design!
                                      Haben wollen 😉 flow, script und view! Als sorglospaket:-)
                                      Das sind jetzt aber fixe Tankstellen, oder ändert sich das Logo etwa auch?
                                      Rainer
                                      PS oder direkt als Adapter.
                                        pix last edited by
                                        Hallo ruhr70,
                                        sieht spitze aus. Da muss ich bei mir definitiv noch nacharbeiten.
                                        @ruhr70:
                                        Wenn ein Spritpreis an der zweiten Stelle nach dem Komma eine 0 hat, wird diese als Zahl nicht dargestellt (das dürfte beim Script von pix auch der Fall sein). ` Habe ich heute erst gemerkt. Schön, dass du das schon verbessert hast (rechenwert.toFixed(2);)
                                        Viele Grüße
                                        pix
                                        • ruhr70
                                          @Homoran:
                                          Haben wollen 😉 flow, script und view! Als sorglospaket:-) `
                                          Die Berechnung zur Aufteilung der beiden Nachkommastellen und der dritten Nachkommastelle mit 4 oder 9 ist wirklich nur eine Funktion hinter der Funktion, in der der Preis ermittelt wird. Das kurze Script in der Funktion steht oben beschrieben. Alles in Node-red. Ein JavaScript im JavaScript-Adapter wird nicht benötigt.
                                          Das Styling in VIS basiert auf der Beschreibung von pix oben. Hier wüsste ich gar nicht, wie ich die zur Verfügung stellen sollte. Wobei… es ist echt nur dreimal die Preisanzeige von pix, ein paar Zusatzinfos aus der Detailabfrage und ein Widget als Hintergrund.
                                          @Homoran:
                                          Das sind jetzt aber fixe Tankstellen, oder ändert sich das Logo etwa auch? `
                                          Ja, das sind fixe Tankstellen. Dynamisch geht aber auch. Wenn Du die Infos "geöffnet, Text zu den Öffnungszeiten und von/bis" nicht benötigst, dann ist es recht einfach möglich auch dynamisch die drei Tankstellen mit dem besten Preis, inkl. Logo anzuzeigen. Solltest Du die Infos auch benötigen, wäre das ein Thema für eine Javascript Profi (anhand der Tankstellen ID, die richtige Detailabfrage zuzuordnen) oder für ganz viel übereinanderliegende Widgets.
                                          Das Logo bekommt man dynmamisch hin, indem man eine Varibale mir dem Inhalt des Felds stations[x].name für die Sichtbarkeit des Logos verwendet. Einfach alle Logos als Widget übereinanderlegen. Die Sichtbarkeit wird über den Inhalt einer Variable (z.B. TankstellenLogo), Inhalt z.B. "Esso Tankstelle" gesteuert.
                                          @Homoran:
                                          PS oder direkt als Adapter. `
                                          Für mich… keine Chance. Ich stehe ganz am Anfang. Ich kann nur Beispiele adaptieren und anpassen. Lerne hier aber unheimlich viel 😉 Danke dafür!
                                          @pix: danke für Deine hervorragende Beschreibung!
                                          @homoran: eigentlich ist im Threat alles beschrieben. Was kann ich für Dich genau tun?
                                            Danke,
                                            Du hast schon alles gesagt.
                                            Werde mich mal nächste Woche selbst hinsetzen.
                                            Rainer
                                            81.1k
                                            125
                                            37252
