    5. Überhaupt kein Skript wird bei mir ausgeführt.
      kilolima last edited by
      on({id: "Bel. [1-1] Flur EG | 13 - Stufen [E/A]", change: "ne"}, function (obj) {
        var value = obj.state.val;
        setState("Bel. [1-4] Arbeitsz. | 9 Hue - Decke [E/A-SA]", getState("Bel. [1-1] Flur EG | 13 - Stufen [E/A]").val);
      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
      thewhobox 1 Reply Last reply Reply Quote 0
        So habe ich es jetzt eingerichtet
        • thewhobox
          thewhobox @kilolima last edited by
          @kilolima sagte in Überhaupt kein Skript wird bei mir ausgeführt.:
          Das ist dein Problem. Hier müsste eig die ID stehen (zum Beispiel zigbee.0.00019384hb.state).
          Bei mir hat es geholfen die Version 4.1.7 zu installieren und dann die Objekt IDs neu zuzuweisen.
          Die Version ist allerdings nicht im stable repo, also müsstest die per npm installieren.
          MyzerAT 1 Reply Last reply Reply Quote 0
          • MyzerAT
            MyzerAT @thewhobox last edited by
            @thewhobox sagte in Überhaupt kein Skript wird bei mir ausgeführt.:
            darum habe ich ihn auf die Version 3.6.4 verwiesen, die ist Stable!
            • thewhobox
              thewhobox @MyzerAT last edited by
              @MyzerAT Wenn er damit aber immernoch das gleiche Problem hat?
                Vielleicht liegt es an den Datenpunkten? Habe hier jetzt KNX-Objekte genutzt.
                • thewhobox
                  Das denke ich nicht, da das gleiche Problem bei mir auch auftrat.
                  Hast du schonmal einen Neustart versucht und dann die Datenpunkte neuzugewiesen?
                      kilolima @thewhobox last edited by
                      Du meinst, den JS-Adapter neu starten und dann im Skript die Datenpunkte neu zuweisen?
                      • thewhobox
                        @kilolima Am besten mal das gesamte Betriebssystem.
                        Genau und danach im Skript die Datenpunkte neuzuweisen und dann wieder in der Javascript ansicht naschschauen ob da jetzt die IDs drin stehe und nicht die Namen.
                          Funktioniert noch immer nicht. Code sieht nun so aus:
                          on({id: "knx.0.Beleuchtung.Erdgeschoss.Bel___1-1__Flur_EG_|_13_-_Stufen__E_A_"/*Bel. [1-1] Flur EG | 13 - Stufen [E/A]*/, change: "ne"}, function (obj) {
                            setState("knx.0.Beleuchtung.Philips_Hue_EG.Bel___1-4__Arbeitsz__|_9_Hue_-_Decke__E_A-SA_"/*Bel. [1-4] Arbeitsz. | 9 Hue - Decke [E/A-SA]*/, getState("knx.0.Beleuchtung.Erdgeschoss.Bel___1-1__Flur_EG_|_13_-_Stufen__E_A_").val);
                          console.log('zeige mir, was los ist ');
                          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
                          • thewhobox
                            @kilolima Das sieht aber schon deutlich besser aus.
                            Läuft das Skript auch?
                            Oben auf dem Screenshot hast du es nämlich gestopt.
                              Der debug muss in den Trigger (vor oder nach dem "steuere" Block) - nicht unter den Trigger
                                Ich denke, es läuft. Zumindest steht es auf grün.
                                Hier mal das Log. Was will mir der broker damit sagen ... hmm
                                  Homoran Global Moderator Administrators @kilolima last edited by
                                  @kilolima
                                  Dein Datenpunkt ist Bool, der Wert anscheinend number
                                    Hier nochmal das LOG. Debug habe ich verschoben. Werte checke ich. Das muss unbedingt konsistentent sein?
                                    carsten04 1 Reply Last reply Reply Quote 0
                                      kilolima @Homoran last edited by
                                      @Homoran sagte in Überhaupt kein Skript wird bei mir ausgeführt.:
                                      @kilolima
                                      Das deckt sich mit der Zeile 3 im LOG. Was müsste ich jetzt tun um das lauffähig zu bekommen, Hormoran?
                                      Danke für eure Geduld hier mit mir.
                                      • carsten04
                                        carsten04 Developer @kilolima last edited by carsten04
                                        Das Problem ist mit der v4.1.7 behoben worden. Siehe dahzu auch hier:
                                        issue #343
                                        und hier:
                                        issue #344
                                        Nach Umstellung auf die v4.1.7 bei allen Blocklys die id's überprüfen. Kann man z.B. gut sehen, wenn man sich das Javascript zum Blockly anzeigen läßt. Ggf. noch einmal die id im Blockly neu auswählen.
                                          Das ist nur eine Warnung, dass es in späteren Versionen nicht mehr laufen wird.
                                          Daran liegt es nicht, dass das Skript nicht läuft.
                                          Hast du den debug-Block verschoben und noch mal getestet?
                                          (Nachdem du auf 4.1.7 upgedatet hattest?)
                                            Jungs! Es funktioniert!
                                            Ich kam ja vorhin von der 4.17. Aber es lag offensichtlich daran, dass die ID's nochmal sauber einzufügen waren. Auerdem hatte ich den Debug-Mode im Skriptadapter eingeschaltet. Ist dies der Fall, werden die Aktionen des Skripts ja nicht ausgeführt. Dazu gibt es eine Meldung im Skripteditor.
                                            Sauber und besten Dank euch für die schnelle Hilfe.
                                            Nochmal eine Frage zum Debug Block. Wo sehe ich denn die Ausgabe dazu? Im Log?
                                            1876
