    4. Adapter: iobroker.backitup (stable Release)
      passuff @Homoran last edited by passuff
      @Homoran @simatec
      Läuft nun wieder,
      Danke!
        Saschag @simatec last edited by
        @simatec
        Danke für die Geduld!! Habe jetzt das Log richtig eingestellt 😌
        Gestern hatten wieder alle drei geklappt, heute nicht und auch nicht per Hand (im Vis per oneclick)
        backitup.0	2019-03-02 09:03:34.446	debug	system.adapter.admin.0: logging true
        backitup.0	2019-03-02 09:03:34.445	debug	redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":true,"ack":true,"ts":1551513814439,"q":0,"from":"system.adapter.admin.0","lc":1551513814439}
        host.ioBroker-RasPi	2019-03-02 08:49:02.758	info	instance system.adapter.tvspielfilm.0 terminated with code 0 (OK)
        tvspielfilm.0	2019-03-02 08:49:02.229	info	force terminating adapter after 1 minute
        backitup.0	2019-03-02 08:48:43.891	debug	system.adapter.admin.0: logging true
        backitup.0	2019-03-02 08:48:43.890	debug	redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":true,"ack":true,"ts":1551512923883,"q":0,"from":"system.adapter.admin.0","lc":1551512923883}
        web.0	2019-03-02 08:46:57.918	info	==>Connected system.user.admin from ::ffff:192.168.0.150
        web.0	2019-03-02 08:46:44.953	info	<==Disconnect system.user.admin from ::ffff:192.168.0.150 vis.0
        web.0	2019-03-02 08:45:59.067	info	<==Disconnect system.user.admin from ::ffff:192.168.0.206 vis.0
        web.0	2019-03-02 08:45:51.768	info	==>Connected system.user.admin from ::ffff:192.168.0.206
        backitup.0	2019-03-02 08:45:13.554	debug	[total] 10 00 03 */3 * *
        backitup.0	2019-03-02 08:45:13.554	info	[total] backup was activated at 03:00 every 3 day(s)
        backitup.0	2019-03-02 08:45:13.554	debug	[ccu] 10 30 01 */3 * *
        backitup.0	2019-03-02 08:45:13.553	info	[ccu] backup was activated at 01:30 every 3 day(s)
        backitup.0	2019-03-02 08:45:13.553	debug	[minimal] 10 00 02 */1 * *
        backitup.0	2019-03-02 08:45:13.553	info	[minimal] backup was activated at 02:00 every 1 day(s)
        backitup.0	2019-03-02 08:45:13.477	info	starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v8.15.0
        host.ioBroker-RasPi	2019-03-02 08:45:11.814	info	instance system.adapter.backitup.0 started with pid 9692
        host.ioBroker-RasPi	2019-03-02 08:45:04.263	info	instance system.adapter.dwd.0 terminated with code 0 (OK)
        dwd.0	2019-03-02 08:45:03.353	info	starting. Version 2.4.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v8.15.0
        javascript.0	2019-03-02 08:45:00.554	info	script.js.Homematic.Sevicemeldungen: Anzahl Homematic-Servicemeldungen: 0
        javascript.0	2019-03-02 08:45:00.554	info	script.js.Homematic.Sevicemeldungen: Homematic-Servicemeldungen:
        host.ioBroker-RasPi	2019-03-02 08:45:00.118	info	instance system.adapter.dwd.0 started with pid 9680
        web.0	2019-03-02 08:44:58.922	info	<==Disconnect system.user.admin from ::ffff:192.168.0.206 vis.0
        web.0	2019-03-02 08:44:50.985	info	<==Disconnect system.user.admin from ::ffff:192.168.0.206 vis.0
        host.ioBroker-RasPi	2019-03-02 08:44:41.743	info	Restart adapter system.adapter.backitup.0 because enabled
        host.ioBroker-RasPi	2019-03-02 08:44:41.743	error	instance system.adapter.backitup.0 terminated with code null ()
        host.ioBroker-RasPi	2019-03-02 08:44:41.736	warn	instance system.adapter.backitup.0 terminated due to SIGKILL
        backitup.0	2019-03-02 08:44:38.955	debug	[total/total] Packed 92MB so far...
        web.0	2019-03-02 08:44:37.100	info	==>Connected system.user.admin from ::ffff:192.168.0.206
        web.0	2019-03-02 08:44:34.597	info	<==Disconnect system.user.admin from ::ffff:192.168.0.206 vis.0
        web.0	2019-03-02 08:44:32.070	info	==>Connected system.user.admin from ::ffff:192.168.0.206
        backitup.0	2019-03-02 08:44:28.826	debug	[total/total] Packed 86MB so far...
        backitup.0	2019-03-02 08:44:18.825	debug	[total/total] Packed 83MB so far...
        backitup.0	2019-03-02 08:44:08.823	debug	[total/total] Packed 79MB so far...
        backitup.0	2019-03-02 08:43:58.821	debug	[total/total] Packed 76MB so far...
        backitup.0	2019-03-02 08:43:48.734	debug	[total/total] Packed 74MB so far...
        backitup.0	2019-03-02 08:43:38.731	debug	[total/total] Packed 66MB so far...
        backitup.0	2019-03-02 08:43:28.730	debug	[total/total] Packed 58MB so far...
        backitup.0	2019-03-02 08:43:18.728	debug	[total/total] Packed 53MB so far...
        backitup.0	2019-03-02 08:43:08.726	debug	[total/total] Packed 48MB so far...
        backitup.0	2019-03-02 08:42:58.723	debug	[total/total] Packed 41MB so far...
        backitup.0	2019-03-02 08:42:53.183	debug	redis pmessage io.backitup.0.oneClick.* io.backitup.0.oneClick.minimal {"val":true,"ack":false,"ts":1551512573179,"q":0,"from":"system.adapter.web.0","lc":1551512573179}
        backitup.0	2019-03-02 08:42:48.721	debug	[total/total] Packed 30MB so far...
        web.0	2019-03-02 08:42:43.891	info	==>Connected system.user.admin from ::ffff:192.168.0.206
        backitup.0	2019-03-02 08:42:38.719	debug	[total/total] Packed 24MB so far...
        backitup.0	2019-03-02 08:42:28.715	debug	[total/total] Packed 21MB so far...
        backitup.0	2019-03-02 08:42:25.078	debug	redis pmessage io.backitup.0.oneClick.* io.backitup.0.oneClick.total {"val":false,"ack":true,"ts":1551512545076,"q":0,"from":"system.adapter.admin.0","lc":1551512545076}
        backitup.0	2019-03-02 08:42:18.713	debug	[total/total] Packed 14MB so far...
        backitup.0	2019-03-02 08:42:10.586	debug	redis pmessage io.backitup.0.oneClick.* io.backitup.0.oneClick.total {"val":true,"ack":false,"ts":1551512530581,"q":0,"from":"system.adapter.admin.0","lc":1551405610034}
        backitup.0	2019-03-02 08:42:08.713	debug	[total/total] Ignore dir: /opt/iobroker/backups
        backitup.0	2019-03-02 08:42:08.712	debug	[total/total] TAR started...
        backitup.0	2019-03-02 08:42:07.598	debug	redis pmessage io.backitup.0.oneClick.* io.backitup.0.oneClick.total {"val":true,"ack":false,"ts":1551512527596,"q":0,"from":"system.adapter.admin.0","lc":1551405610034}
        backitup.0	2019-03-02 08:41:54.116	debug	redis pmessage io.backitup.0.oneClick.* io.backitup.0.oneClick.minimal {"val":false,"ack":true,"ts":1551512514113,"q":0,"from":"system.adapter.admin.0","lc":1551512514113}
        backitup.0	2019-03-02 08:41:09.077	debug	[total] 10 00 03 */3 * *
        backitup.0	2019-03-02 08:41:09.073	info	[total] backup was activated at 03:00 every 3 day(s)
        backitup.0	2019-03-02 08:41:09.073	debug	[ccu] 10 30 01 */3 * *
        backitup.0	2019-03-02 08:41:09.064	info	[ccu] backup was activated at 01:30 every 3 day(s)
        backitup.0	2019-03-02 08:41:09.064	debug	[minimal] 10 00 02 */1 * *
        backitup.0	2019-03-02 08:41:09.034	info	[minimal] backup was activated at 02:00 every 1 day(s)
        backitup.0	2019-03-02 08:41:09.004	info	starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v8.15.0
        backitup.0	2019-03-02 08:41:08.799	info	States connected to redis: 127.0.0.1:6379
        backitup.0	2019-03-02 08:41:08.792	debug	statesDB connected
        backitup.0	2019-03-02 08:41:08.748	debug	objectDB connected
        host.ioBroker-RasPi	2019-03-02 08:41:07.254	info	instance system.adapter.backitup.0 started with pid 9417
        host.ioBroker-RasPi	2019-03-02 08:41:05.240	info	instance system.adapter.backitup.0 terminated with code 0 (OK)
        host.ioBroker-RasPi	2019-03-02 08:41:04.700	info	stopInstance system.adapter.backitup.0 killing pid 843
        host.ioBroker-RasPi	2019-03-02 08:41:04.699	info	stopInstance system.adapter.backitup.0
        host.ioBroker-RasPi	2019-03-02 08:41:04.698	info	object change system.adapter.backitup.
        Vielen vielen Dank schon mal
        • simatec
          simatec Developer Most Active @Saschag last edited by
          @Saschag
          Hast du iobroker gestoppt vor dem backup?
          Falls nicht, probiere es damit mal ...
            @simatec
            nein, habe es mal über die Konsole gemacht
            • simatec
              @Saschag
              Aber das ist ein minimal Backup und kein total ... also nicht vergleichbar
                @simatec
                Okay, aber das minimal hatte ja auch nicht geklappt. Irgendwie Steig ich nicht mehr durch😢
                • simatec
                  @Saschag sagte in Adapter: iobroker.backitup (stable Release):
                  @simatec
                  Hast du dein System bzw. deine SD mal geprüft?
                  Du hattest geschrieben, dass da irgendwas defekt ist.
                  Wenn backitup auf die sd nicht schreiben kann, kann solch ein Fehler auch auftreten
                    Saschag @simatec last edited by Saschag
                    @simatec
                    Soweit konnte ich keine Probleme mehr finden. Die Bachups sollen in Dropbox gespeichert werden. Und ab und an funktionieren die 3 Backups auf automatisch.
                    Über Admin kann ich das minimal machen
                      Stoni last edited by
                      ich hatte die Version 0.2.7 installiert und nach langem hin und her wurde monatlich ein automatisches Backup auf meiner FB erstellt. Jetzt dachte ich, ich könnte mal auf 1.1.2. updaten. und prompt kommt es zu Fehlermeldungen. Der Adapter wird ständig gestoppt und neu gestartet. Im Log kommt irgendwas mit terminating Code 7, Adapter already running.
                      Ich habe dann versucht, ein Standard Backup zu machen. Das wird aber nicht mehr auf meiner FB gespeichert sondern auf dem Raspi.
                      Ich habe das Häckchen bei NAS/Copy gesetzt und die Daten und Pfade der FB eingegeben. Verbindungstyp CIFS etc alles korrekt eingegeben. Irgendwie funktioniert das alles nicht.
                      Kann mir jemand helfen??
                      • I
                        intruder7 last edited by
                        entweder stehe ich irgendwie auf dem Schlauch oder die Funktion ist nicht eingebaut.
                        Ich lasse jedesmal bei Standard und Komplett Backup meine SQL Datenbank mitsichern. Ich habe bei Standard und Komplett eingestellt dass er alle bis auf die letzten 5 löschen soll. Nun häufen sich aber meine SQL Sicherungen. Von allen anderen sind sauber die letzten 5 Backups vorhanden.
                        Besteht die Möglichkeit auch von SQL Sicherungen nur die letzten 5 zu behalten?
                        • simatec
                          simatec Developer Most Active @Stoni last edited by
                          @Stoni sagte in Adapter: iobroker.backitup (stable Release):
                          Version 0.2.7 war noch shell.
                          Ohne Log im Debug kann dir keiner helfen ...
                          • simatec
                            simatec Developer Most Active @intruder7 last edited by
                            @intruder7 sagte in Adapter: iobroker.backitup (stable Release):
                            Auch hier bitte den Log im Debugmodus posten und angeben, welche Version von backitup installiert ist.
                            Node, nodejs und npm wären auch wichtig.
                            • tripper
                              tripper last edited by tripper
                              Bei mir sind die minimal Backups seit einigen Wochen von ~1500KB auf ~200KB geschrumpft, woran könnte das liegen? Das Log meckert soweit nichts, jedoch habe ich bedenken das da nicht alles enthalten ist.
                              Hab nun zum testen auf einem anderen Rechner ioBroker installiert, dort sind die Backups mit nur einem installierten Adapter wieder ~1500KB 🤔
                              Nach dem Restore auf dem Testrechner habe ich nun beim milight-smart-light Adapter bereits ein "File index_m.html not found" wenn ich in die Einstellung der Instanz gehe. Sonst kann ich nicht 100% beurteilen ob alles läuft, das zeigt sich wohl mit der Zeit
                              Hier noch der Log vom produktiven System:
                              backitup.0 2019-03-10 00:30:26.168 debug [minimal] exec: done
                              backitup.0 2019-03-10 00:30:26.160 debug [minimal/umount] done
                              backitup.0 2019-03-10 00:30:18.385 debug system.adapter.admin.0: logging true
                              backitup.0 2019-03-10 00:29:26.066 debug [minimal/umount] mount activ... umount in 60 Seconds!!
                              backitup.0 2019-03-10 00:29:26.033 debug [minimal/history] backitup.0.history.html
                              backitup.0 2019-03-10 00:29:25.988 debug [minimal/clean] done
                              backitup.0 2019-03-10 00:29:25.977 debug [minimal/cifs] done
                              backitup.0 2019-03-10 00:29:25.967 debug [minimal/minimal] done
                              backitup.0 2019-03-10 00:29:25.948 debug [minimal/minimal] Backup created: /opt/iobroker/backups/minimal_2019_03_10-00_29_22_backupiobroker.tar.gz
                              backitup.0 2019-03-10 00:29:22.518 debug [minimal/mount] done
                              backitup.0 2019-03-10 00:17:54.369 debug [total] 10 30 04 */5 * *
                              backitup.0 2019-03-10 00:17:54.356 info [total] backup was activated at 04:30 every 5 day(s)
                              backitup.0 2019-03-10 00:17:54.355 debug [minimal] 10 00 04 */1 * *
                              backitup.0 2019-03-10 00:17:54.308 info [minimal] backup was activated at 04:00 every 1 day(s)
                              backitup.0 2019-03-10 00:17:54.200 info starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v8.15.0
                              backitup.0 2019-03-10 00:17:54.034 debug statesDB connected
                              backitup.0 2019-03-10 00:17:53.962 debug objectDB connected
                              backitup.0 2019-03-10 00:17:45.065 info [total] backup was activated at 04:30 every 5 day(s)
                              backitup.0 2019-03-10 00:17:45.000 info [minimal] backup was activated at 04:00 every 1 day(s)
                              backitup.0 2019-03-10 00:17:44.873 info starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v8.15.0
                              backitup.0 2019-03-10 00:30:18.386 debug system.adapter.admin.0: logging true
                              • simatec
                                simatec Developer Most Active @tripper last edited by
                                @tripper
                                Hast du den js-Controller 1.5.7 laufen?
                                tripper 1 Reply Last reply Reply Quote 0
                                • tripper
                                  tripper @simatec last edited by
                                  @simatec
                                  Ja, ist 1.5.7
                                  • simatec
                                    @tripper
                                    File index_m.html not found kann daher kommen, dass alle Adapter erst neu installiert werden und der Adapter noch nicht installiert ist.
                                    Da brauchst du ne Weile Geduld.
                                    • tripper
                                      @simatec
                                      Das dachte ich auch. Aber nach 14 Stunden warten kam immer noch das gleiche 🙂
                                      • simatec
                                        Ja das kann passieren ... Hatte ich auch einmal.
                                        Solange es nur ein Adapter ist, geht es ja ... installiere ihn dann einfach neu.
                                        • overfl0w
                                          overfl0w last edited by
                                          Hallo Zusammen,
                                          ich wollte mir so langsam auch mal ein regelmäßiges backup meiner iobroker Instanz anlegen und bin auf den tollen Adapter gestoßen. Ich möchte gern die Backups auf mein Nas speichern, nur leider kriege ich es nicht so auf Anhieb zum laufen. Hier ein Auszug aus de LOG:
                                          Gestartet...
                                          [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"Local","mount":"192.168.23.2","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":false,"bkpType":"Minimal","dir":"iobrokerbackup","dirMinimal":"sharename/backupDir","dirTotal":"sharename/backupDir","user":"backup","pass":"****"}
                                          [ERROR] [mount] - [undefined mount error(112): Host is down
                                          Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
                                          [ERROR] [mount] - [IGNORED] Error: Command failed: sudo mount -t cifs -o username=backup,password=***********,rw,file_mode=0777,dir_mode=0777 //192.168.23.2/iobrokerbackup /opt/iobroker/backups
                                          Hier steht, dass der Host down ist, aber ich kann ihn erreichen.. Hat jemand nen Tipp für mich?
                                          Hier meine Konfiguration:
                                          Danke im Voraus
                                          LG
                                          Segway simatec 2 Replies Last reply Reply Quote 0
                                          • Segway
                                            Segway @overfl0w last edited by
                                            @overfl0w
                                            Host down kann auch heißen:
                                            • Freigabeordner nicht vorhanden
                                            • user hat keine Rechte auf diesen Ordner
                                            Hier könnte es noch sein, dass unten der Ordner mit einem vorangestellten "/" (ohne ") sein muss - siehe auch Doku des Adapters unter cifs mount
                                            adapter backitup backup iobroker backup iobroker.backitup
                                            185
                                            2335
                                            1199544
