    4. [erledigt] BackitUP keine Emailbenachrichtigung bei Komplettbackup
    SOLVED [erledigt] BackitUP keine Emailbenachrichtigung bei Komplettbackup
      sol21 last edited by
      Hier die Fenster wenn ich das Backup manuel anstosse (über die Taste "jetzt sichern"). Zuerst ein komplett Backup und dann noch ein minimal Backup. (Bei Komplett bekam ich kein Email, bei Minimal bekam ich das Email)
      Auf dem NAS wurden beide Backups erstellt.
      Gestartet...
      [DEBUG] [total/mount] done
      [DEBUG] [total/total] TAR started...
      [DEBUG] [total/total] Ignore dir: /opt/iobroker/backups
      [DEBUG] [total/total] done
      [DEBUG] [total/cifs] done
      [DEBUG] [total/clean] done
      [DEBUG] [total/start] done
      [DEBUG] [total/email] done
      [DEBUG] [total/start] IoBroker started ...
      [EXIT] 0
      [DEBUG] [email] start with {"type":"creator","time":"04:15","debugging":true,"everyXDays":"10","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"192.168.188.40","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/Backup/iobroker/komplett/","dirMinimal":"/Backup/iobroker/standard/","dirTotal":"/Backup/iobroker/komplett/","user":"raspberry","pass":"****"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":null,"onlyError":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"email.0","NoticeType":"longEmailNotice","emailReceiver":"xx.yy@gmx.ch","emailSender":"xx@gmail.com","onlyError":false,"systemLang":"de","time":"03. Maerz 2019 um 20:07 Uhr"},"pushover":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"systemLang":"de"},"dir":"/opt/iobroker","redis":{"enabled":false,"ftp":{"enabled":false,"type":"storage","source":"Local","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"192.168.188.40","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/Backup/iobroker/komplett/","dirMinimal":"/Backup/iobroker/standard/","dirTotal":"/Backup/iobroker/komplett/","user":"raspberry","pass":"xx"},"dropbox":{"enabled":false,"type":"storage","source":"Local","deleteOldBackup":false,"accessToken":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"path":"/var/lib/redis"},"stopIoB":true,"afterBackup":true,"backupDir":"/opt/iobroker/backups"}
      [DEBUG] [email] - [total] used E-Mail-Instance: email.0
      [DEBUG] [email] - done
      [DEBUG] [history] start with {"type":"creator","time":"04:15","debugging":true,"everyXDays":"10","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"192.168.188.40","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/Backup/iobroker/komplett/","dirMinimal":"/Backup/iobroker/standard/","dirTotal":"/Backup/iobroker/komplett/","user":"raspberry","pass":"****"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de","time":"03. Maerz 2019 um 20:07 Uhr"},"telegram":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":null,"onlyError":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"email.0","NoticeType":"longEmailNotice","emailReceiver":"xx.jj@gmx.ch","emailSender":"xx@gmail.com","onlyError":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"systemLang":"de"},"dir":"/opt/iobroker","redis":{"enabled":false,"ftp":{"enabled":false,"type":"storage","source":"Local","host":"","deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total","user":"","pass":"","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"192.168.188.40","fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/Backup/iobroker/komplett/","dirMinimal":"/Backup/iobroker/standard/","dirTotal":"/Backup/iobroker/komplett/","user":"raspberry","pass":"xx"},"dropbox":{"enabled":false,"type":"storage","source":"Local","deleteOldBackup":false,"accessToken":"","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","dirTotal":"/backupDir/total"},"path":"/var/lib/redis"},"stopIoB":true,"afterBackup":true,"backupDir":"/opt/iobroker/backups"}
      [DEBUG] [history] - backitup.0.history.html
      [EXIT] 0
      Hier aus dem Logfile:
      2019-03-03 20:03:22.338  - info: host.raspberrypi object change system.adapter.backitup.0
      2019-03-03 20:03:22.341  - info: host.raspberrypi stopInstance system.adapter.backitup.0
      2019-03-03 20:03:22.341  - info: host.raspberrypi stopInstance system.adapter.backitup.0 killing pid 5475
      2019-03-03 20:03:22.877  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 0 (OK)
      2019-03-03 20:03:24.872  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 26067
      2019-03-03 20:03:28.199  - debug: backitup.0 objectDB connected
      2019-03-03 20:03:28.273  - debug: backitup.0 statesDB connected
      2019-03-03 20:03:28.441  - info: backitup.0 starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v8.11.1
      2019-03-03 20:03:28.510  - info: backitup.0 [minimal] backup was activated at 04:00 every 1 day(s)
      2019-03-03 20:03:28.545  - debug: backitup.0 [minimal] 10 00 04 */1 * *
      2019-03-03 20:03:28.546  - info: backitup.0 [total] backup was activated at 04:15 every 10 day(s)
      2019-03-03 20:03:28.554  - debug: backitup.0 [total] 10 15 04 */10 * *
      2019-03-03 20:03:43.110  - debug: backitup.0 [total] exec: done
      2019-03-03 20:03:43.266  - info: host.raspberrypi received SIGTERM
      2019-03-03 20:03:43.269  - info: admin.0 terminating http server on port 8081
      2019-03-03 20:03:43.268  - info: web.0 terminating http server on port 8082
      2019-03-03 20:03:43.270  - info: web.0 terminated http server on port 8082
      2019-03-03 20:03:43.281  - info: javascript.0 terminating
      2019-03-03 20:03:43.290  - info: admin.0 terminating
      2019-03-03 20:03:43.288  - info: web.0 terminating
      2019-03-03 20:03:43.296  - info: modbus.0 terminating
      2019-03-03 20:03:43.349  - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 0 (OK)
      2019-03-03 20:03:43.350  - debug: backitup.0 system.adapter.admin.0: logging false
      2019-03-03 20:03:43.354  - info: host.raspberrypi instance system.adapter.web.0 terminated with code 0 (OK)
      2019-03-03 20:03:43.358  - info: host.raspberrypi instance system.adapter.javascript.0 terminated with code 0 (OK)
      2019-03-03 20:03:43.361  - info: host.raspberrypi instance system.adapter.modbus.0 terminated with code 0 (OK)
      2019-03-03 20:03:43.365  - info: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 0 (OK)
      2019-03-03 20:03:43.778  - info: email.0 terminating
      2019-03-03 20:03:43.782  - info: backitup.0 terminating
      2019-03-03 20:03:43.797  - info: host.raspberrypi instance system.adapter.email.0 terminated with code 0 (OK)
      2019-03-03 20:03:43.801  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 0 (OK)
      2019-03-03 20:03:43.801  - info: host.raspberrypi All instances are stopped.
      2019-03-03 20:03:43.882  - info: host.raspberrypi terminated
      2019-03-03 20:06:32.127  - info: host.raspberrypi iobroker.js-controller version 1.4.2 js-controller starting
      2019-03-03 20:06:32.136  - info: host.raspberrypi Copyright (c) 2014-2018 bluefox, 2014 hobbyquaker
      2019-03-03 20:06:32.136  - info: host.raspberrypi hostname: raspberrypi, node: v8.11.1
      2019-03-03 20:06:32.142  - info: host.raspberrypi ip addresses: 192.168.188.28 fe80::90f8:966e:754:6247
      2019-03-03 20:06:32.314  - info: host.raspberrypi  inMem-states listening on port 9000
      2019-03-03 20:06:32.849  - info: host.raspberrypi  inMem-objects listening on port 9001
      2019-03-03 20:06:32.880  - info: host.raspberrypi InMemoryDB connected
      2019-03-03 20:06:32.913  - info: host.raspberrypi 11 instances found
      2019-03-03 20:06:32.956  - info: host.raspberrypi starting 11 instances
      2019-03-03 20:06:33.021  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 26149
      2019-03-03 20:06:36.977  - info: host.raspberrypi instance system.adapter.web.0 started with pid 26155
      2019-03-03 20:06:37.669  - error: admin.0 setObject id missing!!
      2019-03-03 20:06:37.690  - info: admin.0 starting. Version 3.6.0 in /opt/iobroker/node_modules/iobroker.admin, node: v8.11.1
      2019-03-03 20:06:37.752  - info: admin.0 requesting all states
      2019-03-03 20:06:37.756  - info: admin.0 requesting all objects
      2019-03-03 20:06:37.758  - info: admin.0 Request actual repository...
      2019-03-03 20:06:39.587  - info: admin.0 received all states
      2019-03-03 20:06:41.076  - error: web.0 setObject id missing!!
      2019-03-03 20:06:41.098  - info: web.0 starting. Version 2.4.1 in /opt/iobroker/node_modules/iobroker.web, node: v8.11.1
      2019-03-03 20:06:41.703  - info: web.0 socket.io server listening on port 8082
      2019-03-03 20:06:41.709  - info: web.0 http server listening on port 8082
      2019-03-03 20:06:41.932  - info: admin.0 received all objects
      2019-03-03 20:06:42.081  - info: admin.0 http server listening on port 8081
      2019-03-03 20:06:42.082  - info: admin.0 Use link "http://localhost:8081" to configure.
      2019-03-03 20:06:42.208  - info: host.raspberrypi Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
      2019-03-03 20:06:44.979  - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 26175
      2019-03-03 20:06:45.148  - info: vis.0 starting. Version 1.1.10 in /opt/iobroker/node_modules/iobroker.vis, node: v8.11.1
      2019-03-03 20:06:45.380  - info: admin.0 Repository received successfully.
      2019-03-03 20:06:45.461  - info: vis.0 vis license is OK.
      2019-03-03 20:06:46.406  - info: host.raspberrypi instance system.adapter.vis.0 terminated while should be started once
      2019-03-03 20:06:50.913  - info: javascript.0 starting. Version 3.6.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v8.11.1
      2019-03-03 20:06:50.934  - info: javascript.0 requesting all states
      2019-03-03 20:06:50.946  - info: javascript.0 requesting all objects
      2019-03-03 20:06:52.130  - info: javascript.0 received all states
      2019-03-03 20:06:52.979  - info: host.raspberrypi instance system.adapter.modbus.0 started with pid 26189
      2019-03-03 20:06:54.377  - info: javascript.0 received all objects
      2019-03-03 20:06:54.694  - info: javascript.0 Start javascript script.js.Skalierung_PV_Leistung
      2019-03-03 20:06:54.796  - info: javascript.0 script.js.Skalierung_PV_Leistung: registered 0 subscriptions and 0 schedules
      2019-03-03 20:06:54.797  - info: javascript.0 Start javascript script.js.Skalierung_Meter_Leistung
      2019-03-03 20:06:54.869  - info: javascript.0 script.js.Skalierung_Meter_Leistung: registered 0 subscriptions and 0 schedules
      2019-03-03 20:06:54.870  - info: javascript.0 Start javascript script.js.Sonneuntergang
      2019-03-03 20:06:54.964  - info: javascript.0 script.js.Sonneuntergang: registered 0 subscriptions and 1 schedule
      2019-03-03 20:06:54.965  - info: javascript.0 Start javascript script.js.PV_Leistung_Durchschnitt
      2019-03-03 20:06:55.045  - info: javascript.0 script.js.PV_Leistung_Durchschnitt: registered 0 subscriptions and 1 schedule
      2019-03-03 20:06:55.046  - info: javascript.0 Start javascript script.js.eth002_R1
      2019-03-03 20:06:55.128  - info: javascript.0 script.js.eth002_R1: registered 1 subscription and 0 schedules
      2019-03-03 20:06:55.129  - info: javascript.0 Start javascript script.js.Steure_R1
      2019-03-03 20:06:55.206  - info: javascript.0 script.js.Steure_R1: registered 1 subscription and 0 schedules
      2019-03-03 20:06:55.206  - info: javascript.0 Start javascript script.js.Steure_R2
      2019-03-03 20:06:55.285  - info: javascript.0 script.js.Steure_R2: registered 2 subscriptions and 0 schedules
      2019-03-03 20:06:55.286  - info: javascript.0 Start javascript script.js.in_zeit_auto_R2
      2019-03-03 20:06:55.367  - info: javascript.0 script.js.in_zeit_auto_R2: registered 1 subscription and 1 schedule
      2019-03-03 20:06:55.369  - info: javascript.0 Start javascript script.js.eth002_R2
      2019-03-03 20:06:55.453  - info: javascript.0 script.js.eth002_R2: registered 1 subscription and 0 schedules
      2019-03-03 20:06:55.454  - info: javascript.0 Start javascript script.js.WLAN
      2019-03-03 20:06:55.542  - info: javascript.0 script.js.WLAN: registered 0 subscriptions and 1 schedule
      2019-03-03 20:06:55.543  - info: javascript.0 Start javascript script.js.Zeit_WP_Sperre_Ein_dynamisch
      2019-03-03 20:06:55.642  - info: javascript.0 script.js.Zeit_WP_Sperre_Ein_dynamisch: registered 0 subscriptions and 2 schedules
      2019-03-03 20:06:55.643  - info: javascript.0 Start javascript script.js.in_zeit_sperre_R1_mitWetter
      2019-03-03 20:06:55.736  - info: javascript.0 script.js.in_zeit_sperre_R1_mitWetter: registered 1 subscription and 1 schedule
      2019-03-03 20:06:55.737  - info: javascript.0 Start javascript script.js.Test_Ausgaben
      2019-03-03 20:06:55.826  - info: javascript.0 script.js.Test_Ausgaben: registered 0 subscriptions and 1 schedule
      2019-03-03 20:06:56.491  - info: modbus.0 starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.modbus, node: v8.11.1
      2019-03-03 20:06:56.558  - warn: modbus.0 Serial is not available
      2019-03-03 20:06:56.938  - info: modbus.0 Connected to slave 192.168.188.36
      2019-03-03 20:06:56.977  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 26199
      2019-03-03 20:07:00.951  - info: tr-064.0 starting. Version 0.4.18 in /opt/iobroker/node_modules/iobroker.tr-064, node: v8.11.1
      2019-03-03 20:07:03.260  - error: tr-064.0 forEachConfiguredDevice: in GetSpecificHostEntry 0(fritz.box/5C:49:79:3E:4C:24):Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
      2019-03-03 20:07:04.990  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 26210
      2019-03-03 20:07:08.414  - debug: backitup.0 objectDB connected
      2019-03-03 20:07:08.720  - debug: backitup.0 statesDB connected
      2019-03-03 20:07:08.951  - info: backitup.0 starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v8.11.1
      2019-03-03 20:07:08.994  - info: host.raspberrypi instance scheduled system.adapter.daswetter.0 */15 * * * *
      2019-03-03 20:07:08.962  - debug: backitup.0 Printing logs of previous backup
      2019-03-03 20:07:08.966  - debug: backitup.0 [DEBUG] [total/mount] done
      2019-03-03 20:07:08.968  - debug: backitup.0 [DEBUG] [total/total] TAR started...
      2019-03-03 20:07:08.968  - debug: backitup.0 [DEBUG] [total/total] Ignore dir: /opt/iobroker/backups
      2019-03-03 20:07:08.969  - debug: backitup.0 [DEBUG] [total/total] done
      2019-03-03 20:07:08.969  - debug: backitup.0 [DEBUG] [total/cifs] done
      2019-03-03 20:07:08.970  - debug: backitup.0 [DEBUG] [total/clean] done
      2019-03-03 20:07:08.970  - debug: backitup.0 [DEBUG] [total/start] done
      2019-03-03 20:07:08.971  - debug: backitup.0 [DEBUG] [total/email] done
      2019-03-03 20:07:08.971  - debug: backitup.0 [DEBUG] [total/start] IoBroker started ...
      2019-03-03 20:07:10.630  - debug: backitup.0 [total/email] [total] used E-Mail-Instance: email.0
      2019-03-03 20:07:10.634  - debug: backitup.0 sendTo "send" to system.adapter.email.0 from system.adapter.backitup.0
      2019-03-03 20:07:10.636  - debug: backitup.0 [total/email] done
      2019-03-03 20:07:10.799  - info: backitup.0 [minimal] backup was activated at 04:00 every 1 day(s)
      2019-03-03 20:07:10.836  - debug: backitup.0 [minimal] 10 00 04 */1 * *
      2019-03-03 20:07:10.837  - info: backitup.0 [total] backup was activated at 04:15 every 10 day(s)
      2019-03-03 20:07:10.847  - debug: backitup.0 [total] 10 15 04 */10 * *
      2019-03-03 20:07:10.858  - debug: backitup.0 mount activ... umount in 2 Seconds!!
      2019-03-03 20:07:10.920  - debug: backitup.0 [total/history] backitup.0.history.html
      2019-03-03 20:07:12.988  - info: host.raspberrypi instance system.adapter.email.0 started with pid 26229
      2019-03-03 20:07:16.228  - info: email.0 starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.email, node: v8.11.1
      2019-03-03 20:15:00.067  - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 26318
      2019-03-03 20:15:14.731  - error: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 11 ()
      2019-03-03 20:19:47.353  - debug: backitup.0 [minimal/mount] done
      2019-03-03 20:19:54.933  - debug: backitup.0 [minimal/minimal] Backup created: /opt/iobroker/backups/minimal_2019_03_03-20_19_47_backupiobroker.tar.gz
      2019-03-03 20:19:55.070  - debug: backitup.0 [minimal/minimal] done
      2019-03-03 20:19:55.080  - debug: backitup.0 [minimal/cifs] done
      2019-03-03 20:19:55.085  - debug: backitup.0 [minimal/clean] done
      2019-03-03 20:19:55.092  - debug: backitup.0 [minimal/email] [minimal] used E-Mail-Instance: email.0
      2019-03-03 20:19:55.094  - debug: backitup.0 sendTo "send" to system.adapter.email.0 from system.adapter.backitup.0
      2019-03-03 20:19:55.094  - debug: backitup.0 [minimal/email] done
      2019-03-03 20:19:55.129  - debug: backitup.0 [minimal/history] backitup.0.history.html
      2019-03-03 20:19:55.169  - debug: backitup.0 [minimal/umount] mount activ... umount in 60 Seconds!!
      2019-03-03 20:19:55.376  - info: email.0 Send email: {"text":"BackItUp:\nEin neues minimal Backup wurde am 03. Maerz 2019 um 20:19 Uhr erstellt, und unter //192.168.188.40/Backup/iobroker/standard/ gespeichert.","to":"xx.jj@gmx.ch","subject":"Backitup","from":"xx@gmail.com"}
      2019-03-03 20:19:57.743  - info: email.0 sent to xx.jj@gmx.ch
      2019-03-03 20:20:55.343  - debug: backitup.0 [minimal/umount] done
      2019-03-03 20:20:55.349  - debug: backitup.0 [minimal] exec: done
      2019-03-03 20:21:13.547  - debug: backitup.0 system.adapter.admin.0: logging true
      ```[/s]
        sol21 @simatec last edited by
        @simatec
        Super! Hat geklappt. -> Email kam sofort an.
        2019-03-05 15:43:09.736  - debug: backitup.0 statesDB connected
        2019-03-05 15:43:09.905  - info: backitup.0 starting. Version 1.1.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v8.11.1
        2019-03-05 15:43:09.975  - info: backitup.0 [minimal] backup was activated at 04:00 every 1 day(s)
        2019-03-05 15:43:10.012  - debug: backitup.0 [minimal] 10 00 04 */1 * *
        2019-03-05 15:43:10.013  - info: backitup.0 [total] backup was activated at 15:45:00 every 1 day(s)
        2019-03-05 15:43:10.019  - debug: backitup.0 [total] 10 45 15 */1 * *
        2019-03-05 15:43:14.240  - debug: backitup.0 system.adapter.admin.0: logging true
        2019-03-05 15:45:00.046  - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 9680
        2019-03-05 15:45:04.044  - info: daswetter.0 starting. Version 2.7.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v8.11.1
        2019-03-05 15:45:10.052  - debug: backitup.0 [total] exec: done
        2019-03-05 15:45:10.247  - info: admin.0 terminating http server on port 8081
        2019-03-05 15:45:10.248  - info: web.0 terminating http server on port 8082
        2019-03-05 15:45:10.249  - info: web.0 terminated http server on port 8082
        2019-03-05 15:45:10.257  - info: tr-064.0 terminating
        2019-03-05 15:45:10.259  - info: modbus.0 terminating
        2019-03-05 15:45:10.264  - info: javascript.0 terminating
        2019-03-05 15:45:10.272  - info: host.raspberrypi received SIGTERM
        2019-03-05 15:45:10.272  - info: admin.0 terminating
        2019-03-05 15:45:10.282  - info: web.0 terminating
        2019-03-05 15:45:10.300  - info: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 0 (OK)
        2019-03-05 15:45:10.323  - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 0 (OK)
        2019-03-05 15:45:10.324  - debug: backitup.0 system.adapter.admin.0: logging false
        2019-03-05 15:45:10.328  - info: host.raspberrypi instance system.adapter.web.0 terminated with code 0 (OK)
        2019-03-05 15:45:10.334  - info: host.raspberrypi instance system.adapter.javascript.0 terminated with code 0 (OK)
        2019-03-05 15:45:10.338  - info: host.raspberrypi instance system.adapter.modbus.0 terminated with code 0 (OK)
        2019-03-05 15:45:10.748  - info: email.0 terminating
        2019-03-05 15:45:10.755  - info: backitup.0 terminating
        2019-03-05 15:45:10.766  - info: daswetter.0 terminating
        2019-03-05 15:45:10.780  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 0 (OK)
        2019-03-05 15:45:10.810  - info: host.raspberrypi instance system.adapter.email.0 terminated with code 0 (OK)
        2019-03-05 15:45:10.810  - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (OK)
        2019-03-05 15:45:20.281  - info: host.raspberrypi force terminating
        2019-03-05 15:47:17.982  - info: host.raspberrypi iobroker.js-controller version 1.4.2 js-controller starting
        2019-03-05 15:47:17.991  - info: host.raspberrypi Copyright (c) 2014-2018 bluefox, 2014 hobbyquaker
        2019-03-05 15:47:17.992  - info: host.raspberrypi hostname: raspberrypi, node: v8.11.1
        2019-03-05 15:47:17.997  - info: host.raspberrypi ip addresses: 192.168.188.28 fe80::90f8:966e:754:6247
        2019-03-05 15:47:18.169  - info: host.raspberrypi  inMem-states listening on port 9000
        2019-03-05 15:47:18.709  - info: host.raspberrypi  inMem-objects listening on port 9001
        2019-03-05 15:47:18.740  - info: host.raspberrypi InMemoryDB connected
        2019-03-05 15:47:18.773  - info: host.raspberrypi 11 instances found
        2019-03-05 15:47:18.815  - info: host.raspberrypi starting 11 instances
        2019-03-05 15:47:18.880  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 9761
        2019-03-05 15:47:22.837  - info: host.raspberrypi instance system.adapter.web.0 started with pid 9767
        2019-03-05 15:47:23.536  - error: admin.0 setObject id missing!!
        2019-03-05 15:47:23.558  - info: admin.0 starting. Version 3.6.0 in /opt/iobroker/node_modules/iobroker.admin, node: v8.11.1
        2019-03-05 15:47:23.619  - info: admin.0 requesting all states
        2019-03-05 15:47:23.623  - info: admin.0 requesting all objects
        2019-03-05 15:47:23.626  - info: admin.0 Request actual repository...
        2019-03-05 15:47:25.711  - info: admin.0 received all states
        2019-03-05 15:47:27.022  - error: web.0 setObject id missing!!
        2019-03-05 15:47:27.045  - info: web.0 starting. Version 2.4.1 in /opt/iobroker/node_modules/iobroker.web, node: v8.11.1
        2019-03-05 15:47:27.682  - info: web.0 socket.io server listening on port 8082
        2019-03-05 15:47:27.688  - info: web.0 http server listening on port 8082
        2019-03-05 15:47:28.060  - info: admin.0 received all objects
        2019-03-05 15:47:28.208  - info: admin.0 http server listening on port 8081
        2019-03-05 15:47:28.208  - info: admin.0 Use link "http://localhost:8081" to configure.
        2019-03-05 15:47:28.332  - info: host.raspberrypi Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
        2019-03-05 15:47:30.838  - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 9789
        2019-03-05 15:47:31.225  - info: admin.0 Repository received successfully.
        2019-03-05 15:47:31.115  - info: vis.0 starting. Version 1.1.10 in /opt/iobroker/node_modules/iobroker.vis, node: v8.11.1
        2019-03-05 15:47:31.378  - info: vis.0 vis license is OK.
        2019-03-05 15:47:32.301  - info: host.raspberrypi instance system.adapter.vis.0 terminated while should be started once
        2019-03-05 15:47:36.480  - info: javascript.0 starting. Version 3.6.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v8.11.1
        2019-03-05 15:47:36.498  - info: javascript.0 requesting all states
        2019-03-05 15:47:36.501  - info: javascript.0 requesting all objects
        2019-03-05 15:47:37.650  - info: javascript.0 received all states
        2019-03-05 15:47:38.847  - info: host.raspberrypi instance system.adapter.modbus.0 started with pid 9803
        2019-03-05 15:47:39.841  - info: javascript.0 received all objects
        2019-03-05 15:47:39.961  - info: javascript.0 Start javascript script.js.Skalierung_PV_Leistung
        2019-03-05 15:47:40.061  - info: javascript.0 script.js.Skalierung_PV_Leistung: registered 0 subscriptions and 0 schedules
        2019-03-05 15:47:40.063  - info: javascript.0 Start javascript script.js.Skalierung_Meter_Leistung
        2019-03-05 15:47:40.137  - info: javascript.0 script.js.Skalierung_Meter_Leistung: registered 0 subscriptions and 0 schedules
        2019-03-05 15:47:40.138  - info: javascript.0 Start javascript script.js.Sonneuntergang
        2019-03-05 15:47:40.234  - info: javascript.0 script.js.Sonneuntergang: registered 0 subscriptions and 1 schedule
        2019-03-05 15:47:40.235  - info: javascript.0 Start javascript script.js.PV_Leistung_Durchschnitt
        2019-03-05 15:47:40.317  - info: javascript.0 script.js.PV_Leistung_Durchschnitt: registered 0 subscriptions and 1 schedule
        2019-03-05 15:47:40.318  - info: javascript.0 Start javascript script.js.eth002_R1
        2019-03-05 15:47:40.404  - info: javascript.0 script.js.eth002_R1: registered 1 subscription and 0 schedules
        2019-03-05 15:47:40.405  - info: javascript.0 Start javascript script.js.Steure_R1
        2019-03-05 15:47:40.486  - info: javascript.0 script.js.Steure_R1: registered 1 subscription and 0 schedules
        2019-03-05 15:47:40.487  - info: javascript.0 Start javascript script.js.Steure_R2
        2019-03-05 15:47:40.568  - info: javascript.0 script.js.Steure_R2: registered 2 subscriptions and 0 schedules
        2019-03-05 15:47:40.569  - info: javascript.0 Start javascript script.js.in_zeit_auto_R2
        2019-03-05 15:47:40.655  - info: javascript.0 script.js.in_zeit_auto_R2: registered 1 subscription and 1 schedule
        2019-03-05 15:47:40.656  - info: javascript.0 Start javascript script.js.eth002_R2
        2019-03-05 15:47:40.742  - info: javascript.0 script.js.eth002_R2: registered 1 subscription and 0 schedules
        2019-03-05 15:47:40.743  - info: javascript.0 Start javascript script.js.WLAN
        2019-03-05 15:47:40.829  - info: javascript.0 script.js.WLAN: registered 0 subscriptions and 1 schedule
        2019-03-05 15:47:40.830  - info: javascript.0 Start javascript script.js.Zeit_WP_Sperre_Ein_dynamisch
        2019-03-05 15:47:40.917  - info: javascript.0 script.js.Zeit_WP_Sperre_Ein_dynamisch: registered 0 subscriptions and 2 schedules
        2019-03-05 15:47:40.918  - info: javascript.0 Start javascript script.js.in_zeit_sperre_R1_mitWetter
        2019-03-05 15:47:41.006  - info: javascript.0 script.js.in_zeit_sperre_R1_mitWetter: registered 1 subscription and 1 schedule
        2019-03-05 15:47:41.006  - info: javascript.0 Start javascript script.js.Test_Ausgaben
        2019-03-05 15:47:41.095  - info: javascript.0 script.js.Test_Ausgaben: registered 0 subscriptions and 1 schedule
        2019-03-05 15:47:42.203  - info: modbus.0 starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.modbus, node: v8.11.1
        2019-03-05 15:47:42.256  - warn: modbus.0 Serial is not available
        2019-03-05 15:47:42.635  - info: modbus.0 Connected to slave 192.168.188.36
        2019-03-05 15:47:42.836  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 9813
        2019-03-05 15:47:46.789  - info: tr-064.0 starting. Version 0.4.18 in /opt/iobroker/node_modules/iobroker.tr-064, node: v8.11.1
        2019-03-05 15:47:49.302  - error: tr-064.0 forEachConfiguredDevice: in GetSpecificHostEntry 0(fritz.box/5C:49:79:3E:4C:24):Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
        2019-03-05 15:47:50.853  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 9823
        2019-03-05 15:47:54.128  - debug: backitup.0 objectDB connected
        2019-03-05 15:47:54.203  - debug: backitup.0 statesDB connected
        2019-03-05 15:47:54.379  - info: backitup.0 starting. Version 1.1.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v8.11.1
        2019-03-05 15:47:54.858  - info: host.raspberrypi instance scheduled system.adapter.daswetter.0 */15 * * * *
        2019-03-05 15:47:54.391  - debug: backitup.0 Printing logs of previous backup
        2019-03-05 15:47:54.395  - debug: backitup.0 [DEBUG] [total/mount] done
        2019-03-05 15:47:54.397  - debug: backitup.0 [DEBUG] [total/total] TAR started...
        2019-03-05 15:47:54.397  - debug: backitup.0 [DEBUG] [total/total] Ignore dir: /opt/iobroker/backups
        2019-03-05 15:47:54.398  - debug: backitup.0 [DEBUG] [total/total] done
        2019-03-05 15:47:54.398  - debug: backitup.0 [DEBUG] [total/cifs] done
        2019-03-05 15:47:54.398  - debug: backitup.0 [DEBUG] [total/clean] delete /opt/iobroker/backups/total_2019_01_11-04_15_33_backupiobroker.tar.gz
        2019-03-05 15:47:54.398  - debug: backitup.0 [DEBUG] [total/clean] done
        2019-03-05 15:47:54.399  - debug: backitup.0 [DEBUG] [total/start] done
        2019-03-05 15:47:54.399  - debug: backitup.0 [DEBUG] [total/start] IoBroker started ...
        2019-03-05 15:47:54.399  - debug: backitup.0 [DEBUG] [total/email] done
        2019-03-05 15:47:55.335  - info: backitup.0 [minimal] backup was activated at 04:00 every 1 day(s)
        2019-03-05 15:47:55.372  - debug: backitup.0 [minimal] 10 00 04 */1 * *
        2019-03-05 15:47:55.373  - info: backitup.0 [total] backup was activated at 15:45:00 every 1 day(s)
        2019-03-05 15:47:55.389  - debug: backitup.0 [total] 10 45 15 */1 * *
        2019-03-05 15:47:55.487  - debug: backitup.0 mount activ... umount in 2 Seconds!!
        2019-03-05 15:47:58.860  - info: host.raspberrypi instance system.adapter.email.0 started with pid 9846
        2019-03-05 15:48:02.166  - info: email.0 starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.email, node: v8.11.1
        2019-03-05 15:48:05.274  - debug: backitup.0 [total/email] [total] used E-Mail-Instance: email.0
        2019-03-05 15:48:05.281  - debug: backitup.0 sendTo "send" to system.adapter.email.0 from system.adapter.backitup.0
        2019-03-05 15:48:05.282  - debug: backitup.0 [total/email] done
        2019-03-05 15:48:05.316  - debug: backitup.0 [total/history] backitup.0.history.html
        2019-03-05 15:48:05.521  - info: email.0 Send email: {"text":"BackItUp:\nEin neues total Backup wurde am 05. Maerz 2019 um 15:47 Uhr erstellt, und unter 192.168.188.40/Backup/iobroker/komplett/ gespeichert.","to":"xx.yy@gmx.ch","subject":"Backitup","from":"jj@gmail.com"}
        2019-03-05 15:48:07.494  - info: email.0 sent to xx.yy@gmx.ch
        Nochmals herzlichen Dank für die tolle Unterstützung!
        • simatec
          simatec Developer Most Active @sol21 last edited by
          @sol21
          Gast du schon im Spam geschaut?
          Emails werden unabhängig vom backuptyp versendet.
            Ja, Spam habe ich schon mehrfach überprüft.
            • simatec
              @sol21
              Wie sieht deine Installation genau aus?
              Node, Nodejs und nom Version?
              Kannst du bitte mal die Log-Ausgabe bei einem automatischen Backup posten.
              Email erfolgt immer nach dem Backup und dürfte absolut kein Rolle spielen, ob du iobroker stopst oder nicht.
                Habe nun ein Komplett-Backup um 13:45Uhr automatisch laufen lassen. Backup wurde erstellt aber keine Emailbenachrichtigung. Hier das Log:
                2019-03-04 13:43:41.179 - warn: modbus.0 Poll error count: 3 code: "App Timeout"
                2019-03-04 13:45:00.060 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 32060
                2019-03-04 13:45:10.059 - debug: backitup.0 [total] exec: done
                2019-03-04 13:45:10.252 - info: host.raspberrypi received SIGTERM
                2019-03-04 13:45:10.248 - info: web.0 terminating http server on port 8082
                2019-03-04 13:45:10.253 - info: web.0 terminated http server on port 8082
                2019-03-04 13:45:10.260 - info: modbus.0 terminating
                2019-03-04 13:45:10.269 - info: javascript.0 terminating
                2019-03-04 13:45:10.276 - info: web.0 terminating
                2019-03-04 13:45:10.298 - info: host.raspberrypi instance system.adapter.modbus.0 terminated with code 0 (OK)
                2019-03-04 13:45:10.317 - debug: backitup.0 system.adapter.admin.0: logging false
                2019-03-04 13:45:10.316 - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 0 (OK)
                2019-03-04 13:45:10.323 - info: host.raspberrypi instance system.adapter.web.0 terminated with code 0 (OK)
                2019-03-04 13:45:10.340 - info: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 0 (OK)
                2019-03-04 13:45:10.349 - info: host.raspberrypi instance system.adapter.javascript.0 terminated with code 0 (OK)
                2019-03-04 13:45:10.752 - info: email.0 terminating
                2019-03-04 13:45:10.768 - info: backitup.0 terminating
                2019-03-04 13:45:10.779 - info: host.raspberrypi instance system.adapter.email.0 terminated with code 0 (OK)
                2019-03-04 13:45:10.786 - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 0 (OK)
                2019-03-04 13:45:10.787 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (OK)
                2019-03-04 13:45:20.261 - info: host.raspberrypi force terminating
                2019-03-04 13:47:36.560 - info: host.raspberrypi iobroker.js-controller version 1.4.2 js-controller starting
                2019-03-04 13:47:36.569 - info: host.raspberrypi Copyright (c) 2014-2018 bluefox, 2014 hobbyquaker
                2019-03-04 13:47:36.570 - info: host.raspberrypi hostname: raspberrypi, node: v8.11.1
                2019-03-04 13:47:36.575 - info: host.raspberrypi ip addresses: 192.168.188.28 fe80::90f8:966e:754:6247
                2019-03-04 13:47:36.747 - info: host.raspberrypi inMem-states listening on port 9000
                2019-03-04 13:47:37.283 - info: host.raspberrypi inMem-objects listening on port 9001
                2019-03-04 13:47:37.314 - info: host.raspberrypi InMemoryDB connected
                2019-03-04 13:47:37.348 - info: host.raspberrypi 11 instances found
                2019-03-04 13:47:37.394 - info: host.raspberrypi starting 11 instances
                2019-03-04 13:47:37.459 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 32142
                2019-03-04 13:47:41.416 - info: host.raspberrypi instance system.adapter.web.0 started with pid 32148
                2019-03-04 13:47:42.118 - error: admin.0 setObject id missing!!
                2019-03-04 13:47:42.138 - info: admin.0 starting. Version 3.6.0 in /opt/iobroker/node_modules/iobroker.admin, node: v8.11.1
                2019-03-04 13:47:42.200 - info: admin.0 requesting all states
                2019-03-04 13:47:42.204 - info: admin.0 requesting all objects
                2019-03-04 13:47:42.207 - info: admin.0 Request actual repository...
                2019-03-04 13:47:44.096 - info: admin.0 received all states
                2019-03-04 13:47:45.599 - error: web.0 setObject id missing!!
                2019-03-04 13:47:45.621 - info: web.0 starting. Version 2.4.1 in /opt/iobroker/node_modules/iobroker.web, node: v8.11.1
                2019-03-04 13:47:46.258 - info: web.0 socket.io server listening on port 8082
                2019-03-04 13:47:46.264 - info: web.0 http server listening on port 8082
                2019-03-04 13:47:46.428 - info: admin.0 received all objects
                2019-03-04 13:47:46.577 - info: admin.0 http server listening on port 8081
                2019-03-04 13:47:46.577 - info: admin.0 Use link "http://localhost:8081" to configure.
                2019-03-04 13:47:46.704 - info: host.raspberrypi Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
                2019-03-04 13:47:49.417 - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 32169
                2019-03-04 13:47:49.714 - info: vis.0 starting. Version 1.1.10 in /opt/iobroker/node_modules/iobroker.vis, node: v8.11.1
                2019-03-04 13:47:49.877 - info: admin.0 Repository received successfully.
                2019-03-04 13:47:50.131 - info: vis.0 vis license is OK.
                2019-03-04 13:47:51.094 - info: host.raspberrypi instance system.adapter.vis.0 terminated while should be started once
                2019-03-04 13:47:55.297 - info: javascript.0 starting. Version 3.6.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v8.11.1
                2019-03-04 13:47:55.314 - info: javascript.0 requesting all states
                2019-03-04 13:47:55.326 - info: javascript.0 requesting all objects
                2019-03-04 13:47:56.505 - info: javascript.0 received all states
                2019-03-04 13:47:57.429 - info: host.raspberrypi instance system.adapter.modbus.0 started with pid 32183
                2019-03-04 13:47:58.807 - info: javascript.0 received all objects
                2019-03-04 13:47:58.967 - info: javascript.0 Start javascript script.js.Skalierung_PV_Leistung
                2019-03-04 13:47:59.087 - info: javascript.0 script.js.Skalierung_PV_Leistung: registered 0 subscriptions and 0 schedules
                2019-03-04 13:47:59.088 - info: javascript.0 Start javascript script.js.Skalierung_Meter_Leistung
                2019-03-04 13:47:59.162 - info: javascript.0 script.js.Skalierung_Meter_Leistung: registered 0 subscriptions and 0 schedules
                2019-03-04 13:47:59.163 - info: javascript.0 Start javascript script.js.Sonneuntergang
                2019-03-04 13:47:59.258 - info: javascript.0 script.js.Sonneuntergang: registered 0 subscriptions and 1 schedule
                2019-03-04 13:47:59.259 - info: javascript.0 Start javascript script.js.PV_Leistung_Durchschnitt
                2019-03-04 13:47:59.346 - info: javascript.0 script.js.PV_Leistung_Durchschnitt: registered 0 subscriptions and 1 schedule
                2019-03-04 13:47:59.347 - info: javascript.0 Start javascript script.js.eth002_R1
                2019-03-04 13:47:59.434 - info: javascript.0 script.js.eth002_R1: registered 1 subscription and 0 schedules
                2019-03-04 13:47:59.435 - info: javascript.0 Start javascript script.js.Steure_R1
                2019-03-04 13:47:59.516 - info: javascript.0 script.js.Steure_R1: registered 1 subscription and 0 schedules
                2019-03-04 13:47:59.517 - info: javascript.0 Start javascript script.js.Steure_R2
                2019-03-04 13:47:59.601 - info: javascript.0 script.js.Steure_R2: registered 2 subscriptions and 0 schedules
                2019-03-04 13:47:59.602 - info: javascript.0 Start javascript script.js.in_zeit_auto_R2
                2019-03-04 13:47:59.683 - info: javascript.0 script.js.in_zeit_auto_R2: registered 1 subscription and 1 schedule
                2019-03-04 13:47:59.685 - info: javascript.0 Start javascript script.js.eth002_R2
                2019-03-04 13:47:59.768 - info: javascript.0 script.js.eth002_R2: registered 1 subscription and 0 schedules
                2019-03-04 13:47:59.769 - info: javascript.0 Start javascript script.js.WLAN
                2019-03-04 13:47:59.850 - info: javascript.0 script.js.WLAN: registered 0 subscriptions and 1 schedule
                2019-03-04 13:47:59.851 - info: javascript.0 Start javascript script.js.Zeit_WP_Sperre_Ein_dynamisch
                2019-03-04 13:47:59.940 - info: javascript.0 script.js.Zeit_WP_Sperre_Ein_dynamisch: registered 0 subscriptions and 2 schedules
                2019-03-04 13:47:59.940 - info: javascript.0 Start javascript script.js.in_zeit_sperre_R1_mitWetter
                2019-03-04 13:48:00.027 - info: javascript.0 script.js.in_zeit_sperre_R1_mitWetter: registered 1 subscription and 1 schedule
                2019-03-04 13:48:00.028 - info: javascript.0 Start javascript script.js.Test_Ausgaben
                2019-03-04 13:48:00.117 - info: javascript.0 script.js.Test_Ausgaben: registered 0 subscriptions and 1 schedule
                2019-03-04 13:48:00.907 - info: modbus.0 starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.modbus, node: v8.11.1
                2019-03-04 13:48:00.961 - warn: modbus.0 Serial is not available
                2019-03-04 13:48:01.328 - info: modbus.0 Connected to slave 192.168.188.36
                2019-03-04 13:48:01.415 - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 32193
                2019-03-04 13:48:05.443 - info: tr-064.0 starting. Version 0.4.18 in /opt/iobroker/node_modules/iobroker.tr-064, node: v8.11.1
                2019-03-04 13:48:07.728 - error: tr-064.0 forEachConfiguredDevice: in GetSpecificHostEntry 0(fritz.box/5C:49:79:3E:4C:24):Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                2019-03-04 13:48:09.430 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 32203
                2019-03-04 13:48:12.863 - debug: backitup.0 objectDB connected
                2019-03-04 13:48:12.936 - debug: backitup.0 statesDB connected
                2019-03-04 13:48:13.280 - info: backitup.0 starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v8.11.1
                2019-03-04 13:48:13.445 - info: host.raspberrypi instance scheduled system.adapter.daswetter.0 */15 * * * *
                2019-03-04 13:48:13.384 - debug: backitup.0 Printing logs of previous backup
                2019-03-04 13:48:13.388 - debug: backitup.0 [DEBUG] [total/mount] done
                2019-03-04 13:48:13.390 - debug: backitup.0 [DEBUG] [total/total] TAR started...
                2019-03-04 13:48:13.390 - debug: backitup.0 [DEBUG] [total/total] Ignore dir: /opt/iobroker/backups
                2019-03-04 13:48:13.391 - debug: backitup.0 [DEBUG] [total/total] done
                2019-03-04 13:48:13.391 - debug: backitup.0 [DEBUG] [total/cifs] done
                2019-03-04 13:48:13.391 - debug: backitup.0 [DEBUG] [total/clean] delete /opt/iobroker/backups/total_2018_12_01-04_15_30_backupiobroker.tar.gz
                2019-03-04 13:48:13.392 - debug: backitup.0 [DEBUG] [total/clean] done
                2019-03-04 13:48:13.392 - debug: backitup.0 [DEBUG] [total/start] done
                2019-03-04 13:48:13.392 - debug: backitup.0 [DEBUG] [total/email] done
                2019-03-04 13:48:13.392 - debug: backitup.0 [DEBUG] [total/start] IoBroker started ...
                2019-03-04 13:48:15.123 - debug: backitup.0 [total/email] [total] used E-Mail-Instance: email.0
                2019-03-04 13:48:15.127 - debug: backitup.0 sendTo "send" to system.adapter.email.0 from system.adapter.backitup.0
                2019-03-04 13:48:15.129 - debug: backitup.0 [total/email] done
                2019-03-04 13:48:15.299 - info: backitup.0 [minimal] backup was activated at 04:00 every 1 day(s)
                2019-03-04 13:48:15.351 - debug: backitup.0 [minimal] 10 00 04 */1 * *
                2019-03-04 13:48:15.352 - info: backitup.0 [total] backup was activated at 13:45 every 1 day(s)
                2019-03-04 13:48:15.367 - debug: backitup.0 [total] 10 45 13 */1 * *
                2019-03-04 13:48:15.393 - debug: backitup.0 mount activ... umount in 2 Seconds!!
                2019-03-04 13:48:15.420 - debug: backitup.0 [total/history] backitup.0.history.html
                2019-03-04 13:48:17.438 - info: host.raspberrypi instance system.adapter.email.0 started with pid 32218
                2019-03-04 13:48:20.704 - info: email.0 starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.email, node: v8.11.1
                2019-03-04 14:00:00.064 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 32263
                2019-03-04 14:00:14.221 - error: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 11 ()
                • simatec
                  Kannst du mal testen, ob die Benachrichtigung ohne einen Stop bei einem Total kommt?
                  So wie es aussieht startet dein Mail Adapter zu spät.
                    Habe nun ein Backup auf 16:05 Uhr geplant (ohne Stop). Das Email wurde wunderbar verschickt.
                    2019-03-04 16:01:28.538  - debug: backitup.0 system.adapter.admin.0: logging true
                    2019-03-04 16:05:21.531  - debug: backitup.0 [total/mount] done
                    2019-03-04 16:05:21.547  - debug: backitup.0 [total/total] TAR started...
                    2019-03-04 16:05:21.549  - debug: backitup.0 [total/total] Ignore dir: /opt/iobroker/backups
                    2019-03-04 16:05:31.548  - debug: backitup.0 [total/total] Packed 17MB so far...
                    2019-03-04 16:05:41.550  - debug: backitup.0 [total/total] Packed 21MB so far...
                    2019-03-04 16:05:51.552  - debug: backitup.0 [total/total] Packed 29MB so far...
                    2019-03-04 16:06:01.556  - debug: backitup.0 [total/total] Packed 37MB so far...
                    2019-03-04 16:06:11.577  - debug: backitup.0 [total/total] Packed 47MB so far...
                    2019-03-04 16:06:21.686  - debug: backitup.0 [total/total] Packed 51MB so far...
                    2019-03-04 16:06:31.688  - debug: backitup.0 [total/total] Packed 57MB so far...
                    2019-03-04 16:06:41.693  - debug: backitup.0 [total/total] Packed 63MB so far...
                    2019-03-04 16:06:51.787  - debug: backitup.0 [total/total] Packed 68MB so far...
                    2019-03-04 16:07:01.789  - debug: backitup.0 [total/total] Packed 74MB so far...
                    2019-03-04 16:07:11.791  - debug: backitup.0 [total/total] Packed 78MB so far...
                    2019-03-04 16:07:19.873  - debug: backitup.0 [total/total] done
                    2019-03-04 16:07:19.884  - debug: backitup.0 [total/cifs] done
                    2019-03-04 16:07:19.913  - debug: backitup.0 [total/clean] delete /opt/iobroker/backups/total_2018_12_11-04_15_33_backupiobroker.tar.gz
                    2019-03-04 16:07:19.944  - debug: backitup.0 [total/clean] done
                    2019-03-04 16:07:19.954  - debug: backitup.0 [total/email] [total] used E-Mail-Instance: email.0
                    2019-03-04 16:07:19.958  - debug: backitup.0 sendTo "send" to system.adapter.email.0 from system.adapter.backitup.0
                    2019-03-04 16:07:19.959  - debug: backitup.0 [total/email] done
                    2019-03-04 16:07:20.002  - debug: backitup.0 [total/history] backitup.0.history.html
                    2019-03-04 16:07:20.047  - debug: backitup.0 [total/umount] mount activ... umount in 60 Seconds!!
                    2019-03-04 16:07:20.170  - info: email.0 Send email: {"text":"BackItUp:\nEin neues total Backup wurde am 04. Maerz 2019 um 16:07 Uhr erstellt, und unter //192.168.188.40/Backup/iobroker/komplett/ gespeichert.","to":"xx.yy@gmx.ch","subject":"Backitup","from":"qq@gmail.com"}
                    2019-03-04 16:07:21.931  - info: email.0 sent to xx.yy@gmx.ch
                    2019-03-04 16:08:20.276  - debug: backitup.0 [total/umount] done
                    2019-03-04 16:08:20.281  - debug: backitup.0 [total] exec: done
                    • simatec
                      @sol21
                      Dann baue ich da mal eine Verzögerung ein, wenn iobroker gestoppt wird.
                        @simatec
                        Danke, kann ich dann wieder testen. Denke betrifft nicht nur mich...?
                        • simatec
                          @sol21
                          Hmmm das kann ich schwer beurteilen.
                          Ich habe auf allen Testsystemen diese Probleme nicht nachvollziehen können.
                          Was nutzt du für ein System? Eventuell ist die Hardware etwas zu schwach.
                          Normal wird die Mail erst nach iobroker Start versendet.
                          Aber deine Adapter brauchen anscheinend sehr lange zum starten.
                          Könnte an der Hardware liegen
                            @simatec
                            Habe einen RaspberryPi 3B. Läuft aber sehr wenig darauf.
                            Solange sich nicht mehr Leute mit dem gleichen Problem melden, kannst Du es so belassen. Ich weiss ja, dass das Backup erstellt wird und kann auf die Benachrichtigung verzichten. Ich werde es aber mal noch länger im Auge behalten.
                            Nochmals vielen herzlichen Dank!
                            • simatec
                              @sol21
                              Nutzt du redis? Wenn ja musst du nicht stoppen.
                              Auch ohne Redis musst du nicht stoppen.
                              Der stop ist nur dafür da, falls es Probleme beim erstellen des totals gibt.
                              Ich werde das aber fixen, damit die Meldung etwas zeitverzögert rausgeht
                              • simatec
                                simatec Developer Most Active last edited by simatec
                                Installiere mal die Version 1.1.3 vom Github und berichte mal bitte, ob deine Benachrichtigung per Mail jetzt kommt.
                                  @simatec
                                  habe nun mit der Version 1.1.3 getestet. Leider kam auch keine Email-Benachrichtigung.
                                  Hatte das Komplett-Backup auf 14:00:00 eingeplant.
                                  2019-03-05 13:57:12.261  - info: backitup.0 starting. Version 1.1.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v8.11.1
                                  2019-03-05 13:57:12.337  - info: backitup.0 [minimal] backup was activated at 04:00 every 1 day(s)
                                  2019-03-05 13:57:12.373  - debug: backitup.0 [minimal] 10 00 04 */1 * *
                                  2019-03-05 13:57:12.373  - info: backitup.0 [total] backup was activated at 14:00:00 every 1 day(s)
                                  2019-03-05 13:57:12.379  - debug: backitup.0 [total] 10 00 14 */1 * *
                                  2019-03-05 13:57:12.923  - debug: backitup.0 system.adapter.admin.0: logging true
                                  2019-03-05 13:58:08.082  - debug: backitup.0 system.adapter.admin.0: logging false
                                  2019-03-05 13:58:16.367  - debug: backitup.0 system.adapter.admin.0: logging true
                                  2019-03-05 14:00:00.057  - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 8859
                                  2019-03-05 14:00:04.429  - info: daswetter.0 starting. Version 2.7.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v8.11.1
                                  2019-03-05 14:00:10.080  - debug: backitup.0 [total] exec: done
                                  2019-03-05 14:00:10.358  - info: host.raspberrypi received SIGTERM
                                  2019-03-05 14:00:10.359  - info: web.0 terminating http server on port 8082
                                  2019-03-05 14:00:10.367  - info: admin.0 terminating http server on port 8081
                                  2019-03-05 14:00:10.372  - info: javascript.0 terminating
                                  2019-03-05 14:00:10.380  - info: web.0 terminated http server on port 8082
                                  2019-03-05 14:00:10.386  - info: admin.0 terminating
                                  2019-03-05 14:00:10.386  - info: tr-064.0 terminating
                                  2019-03-05 14:00:10.393  - info: modbus.0 terminating
                                  2019-03-05 14:00:10.434  - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 0 (OK)
                                  2019-03-05 14:00:10.435  - debug: backitup.0 system.adapter.admin.0: logging false
                                  2019-03-05 14:00:10.439  - info: host.raspberrypi instance system.adapter.web.0 terminated with code 0 (OK)
                                  2019-03-05 14:00:10.443  - info: host.raspberrypi instance system.adapter.javascript.0 terminated with code 0 (OK)
                                  2019-03-05 14:00:10.447  - info: host.raspberrypi instance system.adapter.modbus.0 terminated with code 0 (OK)
                                  2019-03-05 14:00:10.451  - info: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 0 (OK)
                                  2019-03-05 14:00:10.875  - info: backitup.0 terminating
                                  2019-03-05 14:00:10.874  - info: daswetter.0 terminating
                                  2019-03-05 14:00:10.882  - info: email.0 terminating
                                  2019-03-05 14:00:10.898  - info: host.raspberrypi instance system.adapter.email.0 terminated with code 0 (OK)
                                  2019-03-05 14:00:10.906  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 0 (OK)
                                  2019-03-05 14:00:10.908  - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (OK)
                                  2019-03-05 14:00:20.368  - info: host.raspberrypi force terminating
                                  2019-03-05 14:02:23.152  - info: host.raspberrypi iobroker.js-controller version 1.4.2 js-controller starting
                                  2019-03-05 14:02:23.161  - info: host.raspberrypi Copyright (c) 2014-2018 bluefox, 2014 hobbyquaker
                                  2019-03-05 14:02:23.162  - info: host.raspberrypi hostname: raspberrypi, node: v8.11.1
                                  2019-03-05 14:02:23.167  - info: host.raspberrypi ip addresses: 192.168.188.28 fe80::90f8:966e:754:6247
                                  2019-03-05 14:02:23.339  - info: host.raspberrypi  inMem-states listening on port 9000
                                  2019-03-05 14:02:23.878  - info: host.raspberrypi  inMem-objects listening on port 9001
                                  2019-03-05 14:02:23.909  - info: host.raspberrypi InMemoryDB connected
                                  2019-03-05 14:02:23.943  - info: host.raspberrypi 11 instances found
                                  2019-03-05 14:02:23.985  - info: host.raspberrypi starting 11 instances
                                  2019-03-05 14:02:24.050  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 8960
                                  2019-03-05 14:02:28.006  - info: host.raspberrypi instance system.adapter.web.0 started with pid 8967
                                  2019-03-05 14:02:28.724  - error: admin.0 setObject id missing!!
                                  2019-03-05 14:02:28.743  - info: admin.0 starting. Version 3.6.0 in /opt/iobroker/node_modules/iobroker.admin, node: v8.11.1
                                  2019-03-05 14:02:28.806  - info: admin.0 requesting all states
                                  2019-03-05 14:02:28.810  - info: admin.0 requesting all objects
                                  2019-03-05 14:02:28.813  - info: admin.0 Request actual repository...
                                  2019-03-05 14:02:30.631  - info: admin.0 received all states
                                  2019-03-05 14:02:32.169  - error: web.0 setObject id missing!!
                                  2019-03-05 14:02:32.191  - info: web.0 starting. Version 2.4.1 in /opt/iobroker/node_modules/iobroker.web, node: v8.11.1
                                  2019-03-05 14:02:32.786  - info: web.0 socket.io server listening on port 8082
                                  2019-03-05 14:02:32.792  - info: web.0 http server listening on port 8082
                                  2019-03-05 14:02:33.034  - info: admin.0 received all objects
                                  2019-03-05 14:02:33.191  - info: admin.0 http server listening on port 8081
                                  2019-03-05 14:02:33.192  - info: admin.0 Use link "http://localhost:8081" to configure.
                                  2019-03-05 14:02:33.318  - info: host.raspberrypi Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
                                  2019-03-05 14:02:35.794  - info: vis.0 starting. Version 1.1.10 in /opt/iobroker/node_modules/iobroker.vis, node: v8.11.1
                                  2019-03-05 14:02:35.935  - info: admin.0 Repository received successfully.
                                  2019-03-05 14:02:36.007  - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 8991
                                  2019-03-05 14:02:36.123  - info: vis.0 vis license is OK.
                                  2019-03-05 14:02:37.084  - info: host.raspberrypi instance system.adapter.vis.0 terminated while should be started once
                                  2019-03-05 14:02:41.450  - info: javascript.0 starting. Version 3.6.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v8.11.1
                                  2019-03-05 14:02:41.467  - info: javascript.0 requesting all states
                                  2019-03-05 14:02:41.470  - info: javascript.0 requesting all objects
                                  2019-03-05 14:02:42.638  - info: javascript.0 received all states
                                  2019-03-05 14:02:44.008  - info: host.raspberrypi instance system.adapter.modbus.0 started with pid 9001
                                  2019-03-05 14:02:44.960  - info: javascript.0 received all objects
                                  2019-03-05 14:02:45.083  - info: javascript.0 Start javascript script.js.Skalierung_PV_Leistung
                                  2019-03-05 14:02:45.182  - info: javascript.0 script.js.Skalierung_PV_Leistung: registered 0 subscriptions and 0 schedules
                                  2019-03-05 14:02:45.184  - info: javascript.0 Start javascript script.js.Skalierung_Meter_Leistung
                                  2019-03-05 14:02:45.256  - info: javascript.0 script.js.Skalierung_Meter_Leistung: registered 0 subscriptions and 0 schedules
                                  2019-03-05 14:02:45.257  - info: javascript.0 Start javascript script.js.Sonneuntergang
                                  2019-03-05 14:02:45.351  - info: javascript.0 script.js.Sonneuntergang: registered 0 subscriptions and 1 schedule
                                  2019-03-05 14:02:45.352  - info: javascript.0 Start javascript script.js.PV_Leistung_Durchschnitt
                                  2019-03-05 14:02:45.432  - info: javascript.0 script.js.PV_Leistung_Durchschnitt: registered 0 subscriptions and 1 schedule
                                  2019-03-05 14:02:45.433  - info: javascript.0 Start javascript script.js.eth002_R1
                                  2019-03-05 14:02:45.514  - info: javascript.0 script.js.eth002_R1: registered 1 subscription and 0 schedules
                                  2019-03-05 14:02:45.515  - info: javascript.0 Start javascript script.js.Steure_R1
                                  2019-03-05 14:02:45.594  - info: javascript.0 script.js.Steure_R1: registered 1 subscription and 0 schedules
                                  2019-03-05 14:02:45.595  - info: javascript.0 Start javascript script.js.Steure_R2
                                  2019-03-05 14:02:45.674  - info: javascript.0 script.js.Steure_R2: registered 2 subscriptions and 0 schedules
                                  2019-03-05 14:02:45.675  - info: javascript.0 Start javascript script.js.in_zeit_auto_R2
                                  2019-03-05 14:02:45.758  - info: javascript.0 script.js.in_zeit_auto_R2: registered 1 subscription and 1 schedule
                                  2019-03-05 14:02:45.759  - info: javascript.0 Start javascript script.js.eth002_R2
                                  2019-03-05 14:02:45.843  - info: javascript.0 script.js.eth002_R2: registered 1 subscription and 0 schedules
                                  2019-03-05 14:02:45.844  - info: javascript.0 Start javascript script.js.WLAN
                                  2019-03-05 14:02:45.928  - info: javascript.0 script.js.WLAN: registered 0 subscriptions and 1 schedule
                                  2019-03-05 14:02:45.929  - info: javascript.0 Start javascript script.js.Zeit_WP_Sperre_Ein_dynamisch
                                  2019-03-05 14:02:46.017  - info: javascript.0 script.js.Zeit_WP_Sperre_Ein_dynamisch: registered 0 subscriptions and 2 schedules
                                  2019-03-05 14:02:46.018  - info: javascript.0 Start javascript script.js.in_zeit_sperre_R1_mitWetter
                                  2019-03-05 14:02:46.103  - info: javascript.0 script.js.in_zeit_sperre_R1_mitWetter: registered 1 subscription and 1 schedule
                                  2019-03-05 14:02:46.104  - info: javascript.0 Start javascript script.js.Test_Ausgaben
                                  2019-03-05 14:02:46.191  - info: javascript.0 script.js.Test_Ausgaben: registered 0 subscriptions and 1 schedule
                                  2019-03-05 14:02:47.440  - info: modbus.0 starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.modbus, node: v8.11.1
                                  2019-03-05 14:02:47.493  - warn: modbus.0 Serial is not available
                                  2019-03-05 14:02:47.854  - info: modbus.0 Connected to slave 192.168.188.36
                                  2019-03-05 14:02:48.007  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 9011
                                  2019-03-05 14:02:52.017  - info: tr-064.0 starting. Version 0.4.18 in /opt/iobroker/node_modules/iobroker.tr-064, node: v8.11.1
                                  2019-03-05 14:02:54.555  - error: tr-064.0 forEachConfiguredDevice: in GetSpecificHostEntry 0(fritz.box/5C:49:79:3E:4C:24):Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                  2019-03-05 14:02:56.025  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 9021
                                  2019-03-05 14:02:59.341  - debug: backitup.0 objectDB connected
                                  2019-03-05 14:02:59.416  - debug: backitup.0 statesDB connected
                                  2019-03-05 14:02:59.599  - info: backitup.0 starting. Version 1.1.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v8.11.1
                                  2019-03-05 14:03:00.121  - info: host.raspberrypi instance scheduled system.adapter.daswetter.0 */15 * * * *
                                  2019-03-05 14:02:59.611  - debug: backitup.0 Printing logs of previous backup
                                  2019-03-05 14:02:59.615  - debug: backitup.0 [DEBUG] [total/mount] done
                                  2019-03-05 14:02:59.617  - debug: backitup.0 [DEBUG] [total/total] TAR started...
                                  2019-03-05 14:02:59.617  - debug: backitup.0 [DEBUG] [total/total] Ignore dir: /opt/iobroker/backups
                                  2019-03-05 14:02:59.618  - debug: backitup.0 [DEBUG] [total/total] done
                                  2019-03-05 14:02:59.618  - debug: backitup.0 [DEBUG] [total/cifs] done
                                  2019-03-05 14:02:59.618  - debug: backitup.0 [DEBUG] [total/clean] delete /opt/iobroker/backups/total_2019_01_01-04_15_33_backupiobroker.tar.gz
                                  2019-03-05 14:02:59.619  - debug: backitup.0 [DEBUG] [total/clean] done
                                  2019-03-05 14:02:59.619  - debug: backitup.0 [DEBUG] [total/start] done
                                  2019-03-05 14:02:59.619  - debug: backitup.0 [DEBUG] [total/start] IoBroker started ...
                                  2019-03-05 14:02:59.619  - debug: backitup.0 [DEBUG] [total/email] done
                                  2019-03-05 14:03:00.598  - info: backitup.0 [minimal] backup was activated at 04:00 every 1 day(s)
                                  2019-03-05 14:03:00.634  - debug: backitup.0 [minimal] 10 00 04 */1 * *
                                  2019-03-05 14:03:00.634  - info: backitup.0 [total] backup was activated at 14:00:00 every 1 day(s)
                                  2019-03-05 14:03:00.650  - debug: backitup.0 [total] 10 00 14 */1 * *
                                  2019-03-05 14:03:00.737  - debug: backitup.0 mount activ... umount in 2 Seconds!!
                                  2019-03-05 14:03:04.028  - info: host.raspberrypi instance system.adapter.email.0 started with pid 9044
                                  2019-03-05 14:03:05.545  - debug: backitup.0 [total/email] [total] used E-Mail-Instance: email.0
                                  2019-03-05 14:03:05.554  - debug: backitup.0 sendTo "send" to system.adapter.email.0 from system.adapter.backitup.0
                                  2019-03-05 14:03:05.556  - debug: backitup.0 [total/email] done
                                  2019-03-05 14:03:05.603  - debug: backitup.0 [total/history] backitup.0.history.html
                                  2019-03-05 14:03:07.317  - info: email.0 starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.email, node: v8.11.1
                                  2019-03-05 14:07:10.010  - debug: backitup.0 system.adapter.admin.0: logging false
                                  2019-03-05 14:10:22.786  - debug: backitup.0 system.adapter.admin.0: logging true
                                  • simatec
                                    Hatte 5 Sekunden Verzögerung drin. Aber laut Log startet dein mail Adapter weitere 2 Sekunden später.
                                    Ich habe nun die zeit auf 10 Sekunden angepasst. Probiere bitte noch einmal
                                      @simatec
                                      • simatec
                                        Ab Version 1.1.3 ist die Zeitverzögerung im Menü einstellbar.
                                        81.1k
                                        backitup email komplett nas
                                        1169
