    4. [erledigt] BackitUP keine Emailbenachrichtigung bei Komplettbackup
    SOLVED [erledigt] BackitUP keine Emailbenachrichtigung bei Komplettbackup
      sol21 last edited by
      Ja, Spam habe ich schon mehrfach überprüft.
        sol21 @simatec last edited by
        @simatec
        Super! Hat geklappt. -> Email kam sofort an.
        2019-03-05 15:43:09.736  - debug: backitup.0 statesDB connected
        2019-03-05 15:43:09.905  - info: backitup.0 starting. Version 1.1.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v8.11.1
        2019-03-05 15:43:09.975  - info: backitup.0 [minimal] backup was activated at 04:00 every 1 day(s)
        2019-03-05 15:43:10.012  - debug: backitup.0 [minimal] 10 00 04 */1 * *
        2019-03-05 15:43:10.013  - info: backitup.0 [total] backup was activated at 15:45:00 every 1 day(s)
        2019-03-05 15:43:10.019  - debug: backitup.0 [total] 10 45 15 */1 * *
        2019-03-05 15:43:14.240  - debug: backitup.0 system.adapter.admin.0: logging true
        2019-03-05 15:45:00.046  - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 9680
        2019-03-05 15:45:04.044  - info: daswetter.0 starting. Version 2.7.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v8.11.1
        2019-03-05 15:45:10.052  - debug: backitup.0 [total] exec: done
        2019-03-05 15:45:10.247  - info: admin.0 terminating http server on port 8081
        2019-03-05 15:45:10.248  - info: web.0 terminating http server on port 8082
        2019-03-05 15:45:10.249  - info: web.0 terminated http server on port 8082
        2019-03-05 15:45:10.257  - info: tr-064.0 terminating
        2019-03-05 15:45:10.259  - info: modbus.0 terminating
        2019-03-05 15:45:10.264  - info: javascript.0 terminating
        2019-03-05 15:45:10.272  - info: host.raspberrypi received SIGTERM
        2019-03-05 15:45:10.272  - info: admin.0 terminating
        2019-03-05 15:45:10.282  - info: web.0 terminating
        2019-03-05 15:45:10.300  - info: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 0 (OK)
        2019-03-05 15:45:10.323  - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 0 (OK)
        2019-03-05 15:45:10.324  - debug: backitup.0 system.adapter.admin.0: logging false
        2019-03-05 15:45:10.328  - info: host.raspberrypi instance system.adapter.web.0 terminated with code 0 (OK)
        2019-03-05 15:45:10.334  - info: host.raspberrypi instance system.adapter.javascript.0 terminated with code 0 (OK)
        2019-03-05 15:45:10.338  - info: host.raspberrypi instance system.adapter.modbus.0 terminated with code 0 (OK)
        2019-03-05 15:45:10.748  - info: email.0 terminating
        2019-03-05 15:45:10.755  - info: backitup.0 terminating
        2019-03-05 15:45:10.766  - info: daswetter.0 terminating
        2019-03-05 15:45:10.780  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 0 (OK)
        2019-03-05 15:45:10.810  - info: host.raspberrypi instance system.adapter.email.0 terminated with code 0 (OK)
        2019-03-05 15:45:10.810  - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (OK)
        2019-03-05 15:45:20.281  - info: host.raspberrypi force terminating
        2019-03-05 15:47:17.982  - info: host.raspberrypi iobroker.js-controller version 1.4.2 js-controller starting
        2019-03-05 15:47:17.991  - info: host.raspberrypi Copyright (c) 2014-2018 bluefox, 2014 hobbyquaker
        2019-03-05 15:47:17.992  - info: host.raspberrypi hostname: raspberrypi, node: v8.11.1
        2019-03-05 15:47:17.997  - info: host.raspberrypi ip addresses: 192.168.188.28 fe80::90f8:966e:754:6247
        2019-03-05 15:47:18.169  - info: host.raspberrypi  inMem-states listening on port 9000
        2019-03-05 15:47:18.709  - info: host.raspberrypi  inMem-objects listening on port 9001
        2019-03-05 15:47:18.740  - info: host.raspberrypi InMemoryDB connected
        2019-03-05 15:47:18.773  - info: host.raspberrypi 11 instances found
        2019-03-05 15:47:18.815  - info: host.raspberrypi starting 11 instances
        2019-03-05 15:47:18.880  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 9761
        2019-03-05 15:47:22.837  - info: host.raspberrypi instance system.adapter.web.0 started with pid 9767
        2019-03-05 15:47:23.536  - error: admin.0 setObject id missing!!
        2019-03-05 15:47:23.558  - info: admin.0 starting. Version 3.6.0 in /opt/iobroker/node_modules/iobroker.admin, node: v8.11.1
        2019-03-05 15:47:23.619  - info: admin.0 requesting all states
        2019-03-05 15:47:23.623  - info: admin.0 requesting all objects
        2019-03-05 15:47:23.626  - info: admin.0 Request actual repository...
        2019-03-05 15:47:25.711  - info: admin.0 received all states
        2019-03-05 15:47:27.022  - error: web.0 setObject id missing!!
        2019-03-05 15:47:27.045  - info: web.0 starting. Version 2.4.1 in /opt/iobroker/node_modules/iobroker.web, node: v8.11.1
        2019-03-05 15:47:27.682  - info: web.0 socket.io server listening on port 8082
        2019-03-05 15:47:27.688  - info: web.0 http server listening on port 8082
        2019-03-05 15:47:28.060  - info: admin.0 received all objects
        2019-03-05 15:47:28.208  - info: admin.0 http server listening on port 8081
        2019-03-05 15:47:28.208  - info: admin.0 Use link "http://localhost:8081" to configure.
        2019-03-05 15:47:28.332  - info: host.raspberrypi Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
        2019-03-05 15:47:30.838  - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 9789
        2019-03-05 15:47:31.225  - info: admin.0 Repository received successfully.
        2019-03-05 15:47:31.115  - info: vis.0 starting. Version 1.1.10 in /opt/iobroker/node_modules/iobroker.vis, node: v8.11.1
        2019-03-05 15:47:31.378  - info: vis.0 vis license is OK.
        2019-03-05 15:47:32.301  - info: host.raspberrypi instance system.adapter.vis.0 terminated while should be started once
        2019-03-05 15:47:36.480  - info: javascript.0 starting. Version 3.6.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v8.11.1
        2019-03-05 15:47:36.498  - info: javascript.0 requesting all states
        2019-03-05 15:47:36.501  - info: javascript.0 requesting all objects
        2019-03-05 15:47:37.650  - info: javascript.0 received all states
        2019-03-05 15:47:38.847  - info: host.raspberrypi instance system.adapter.modbus.0 started with pid 9803
        2019-03-05 15:47:39.841  - info: javascript.0 received all objects
        2019-03-05 15:47:39.961  - info: javascript.0 Start javascript script.js.Skalierung_PV_Leistung
        2019-03-05 15:47:40.061  - info: javascript.0 script.js.Skalierung_PV_Leistung: registered 0 subscriptions and 0 schedules
        2019-03-05 15:47:40.063  - info: javascript.0 Start javascript script.js.Skalierung_Meter_Leistung
        2019-03-05 15:47:40.137  - info: javascript.0 script.js.Skalierung_Meter_Leistung: registered 0 subscriptions and 0 schedules
        2019-03-05 15:47:40.138  - info: javascript.0 Start javascript script.js.Sonneuntergang
        2019-03-05 15:47:40.234  - info: javascript.0 script.js.Sonneuntergang: registered 0 subscriptions and 1 schedule
        2019-03-05 15:47:40.235  - info: javascript.0 Start javascript script.js.PV_Leistung_Durchschnitt
        2019-03-05 15:47:40.317  - info: javascript.0 script.js.PV_Leistung_Durchschnitt: registered 0 subscriptions and 1 schedule
        2019-03-05 15:47:40.318  - info: javascript.0 Start javascript script.js.eth002_R1
        2019-03-05 15:47:40.404  - info: javascript.0 script.js.eth002_R1: registered 1 subscription and 0 schedules
        2019-03-05 15:47:40.405  - info: javascript.0 Start javascript script.js.Steure_R1
        2019-03-05 15:47:40.486  - info: javascript.0 script.js.Steure_R1: registered 1 subscription and 0 schedules
        2019-03-05 15:47:40.487  - info: javascript.0 Start javascript script.js.Steure_R2
        2019-03-05 15:47:40.568  - info: javascript.0 script.js.Steure_R2: registered 2 subscriptions and 0 schedules
        2019-03-05 15:47:40.569  - info: javascript.0 Start javascript script.js.in_zeit_auto_R2
        2019-03-05 15:47:40.655  - info: javascript.0 script.js.in_zeit_auto_R2: registered 1 subscription and 1 schedule
        2019-03-05 15:47:40.656  - info: javascript.0 Start javascript script.js.eth002_R2
        2019-03-05 15:47:40.742  - info: javascript.0 script.js.eth002_R2: registered 1 subscription and 0 schedules
        2019-03-05 15:47:40.743  - info: javascript.0 Start javascript script.js.WLAN
        2019-03-05 15:47:40.829  - info: javascript.0 script.js.WLAN: registered 0 subscriptions and 1 schedule
        2019-03-05 15:47:40.830  - info: javascript.0 Start javascript script.js.Zeit_WP_Sperre_Ein_dynamisch
        2019-03-05 15:47:40.917  - info: javascript.0 script.js.Zeit_WP_Sperre_Ein_dynamisch: registered 0 subscriptions and 2 schedules
        2019-03-05 15:47:40.918  - info: javascript.0 Start javascript script.js.in_zeit_sperre_R1_mitWetter
        2019-03-05 15:47:41.006  - info: javascript.0 script.js.in_zeit_sperre_R1_mitWetter: registered 1 subscription and 1 schedule
        2019-03-05 15:47:41.006  - info: javascript.0 Start javascript script.js.Test_Ausgaben
        2019-03-05 15:47:41.095  - info: javascript.0 script.js.Test_Ausgaben: registered 0 subscriptions and 1 schedule
        2019-03-05 15:47:42.203  - info: modbus.0 starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.modbus, node: v8.11.1
        2019-03-05 15:47:42.256  - warn: modbus.0 Serial is not available
        2019-03-05 15:47:42.635  - info: modbus.0 Connected to slave 192.168.188.36
        2019-03-05 15:47:42.836  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 9813
        2019-03-05 15:47:46.789  - info: tr-064.0 starting. Version 0.4.18 in /opt/iobroker/node_modules/iobroker.tr-064, node: v8.11.1
        2019-03-05 15:47:49.302  - error: tr-064.0 forEachConfiguredDevice: in GetSpecificHostEntry 0(fritz.box/5C:49:79:3E:4C:24):Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
        2019-03-05 15:47:50.853  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 9823
        2019-03-05 15:47:54.128  - debug: backitup.0 objectDB connected
        2019-03-05 15:47:54.203  - debug: backitup.0 statesDB connected
        2019-03-05 15:47:54.379  - info: backitup.0 starting. Version 1.1.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v8.11.1
        2019-03-05 15:47:54.858  - info: host.raspberrypi instance scheduled system.adapter.daswetter.0 */15 * * * *
        2019-03-05 15:47:54.391  - debug: backitup.0 Printing logs of previous backup
        2019-03-05 15:47:54.395  - debug: backitup.0 [DEBUG] [total/mount] done
        2019-03-05 15:47:54.397  - debug: backitup.0 [DEBUG] [total/total] TAR started...
        2019-03-05 15:47:54.397  - debug: backitup.0 [DEBUG] [total/total] Ignore dir: /opt/iobroker/backups
        2019-03-05 15:47:54.398  - debug: backitup.0 [DEBUG] [total/total] done
        2019-03-05 15:47:54.398  - debug: backitup.0 [DEBUG] [total/cifs] done
        2019-03-05 15:47:54.398  - debug: backitup.0 [DEBUG] [total/clean] delete /opt/iobroker/backups/total_2019_01_11-04_15_33_backupiobroker.tar.gz
        2019-03-05 15:47:54.398  - debug: backitup.0 [DEBUG] [total/clean] done
        2019-03-05 15:47:54.399  - debug: backitup.0 [DEBUG] [total/start] done
        2019-03-05 15:47:54.399  - debug: backitup.0 [DEBUG] [total/start] IoBroker started ...
        2019-03-05 15:47:54.399  - debug: backitup.0 [DEBUG] [total/email] done
        2019-03-05 15:47:55.335  - info: backitup.0 [minimal] backup was activated at 04:00 every 1 day(s)
        2019-03-05 15:47:55.372  - debug: backitup.0 [minimal] 10 00 04 */1 * *
        2019-03-05 15:47:55.373  - info: backitup.0 [total] backup was activated at 15:45:00 every 1 day(s)
        2019-03-05 15:47:55.389  - debug: backitup.0 [total] 10 45 15 */1 * *
        2019-03-05 15:47:55.487  - debug: backitup.0 mount activ... umount in 2 Seconds!!
        2019-03-05 15:47:58.860  - info: host.raspberrypi instance system.adapter.email.0 started with pid 9846
        2019-03-05 15:48:02.166  - info: email.0 starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.email, node: v8.11.1
        2019-03-05 15:48:05.274  - debug: backitup.0 [total/email] [total] used E-Mail-Instance: email.0
        2019-03-05 15:48:05.281  - debug: backitup.0 sendTo "send" to system.adapter.email.0 from system.adapter.backitup.0
        2019-03-05 15:48:05.282  - debug: backitup.0 [total/email] done
        2019-03-05 15:48:05.316  - debug: backitup.0 [total/history] backitup.0.history.html
        2019-03-05 15:48:05.521  - info: email.0 Send email: {"text":"BackItUp:\nEin neues total Backup wurde am 05. Maerz 2019 um 15:47 Uhr erstellt, und unter 192.168.188.40/Backup/iobroker/komplett/ gespeichert.","to":"xx.yy@gmx.ch","subject":"Backitup","from":"jj@gmail.com"}
        2019-03-05 15:48:07.494  - info: email.0 sent to xx.yy@gmx.ch
        Nochmals herzlichen Dank für die tolle Unterstützung!
        • simatec
          simatec Developer Most Active @sol21 last edited by
          @sol21
          Wie sieht deine Installation genau aus?
          Node, Nodejs und nom Version?
          Kannst du bitte mal die Log-Ausgabe bei einem automatischen Backup posten.
          Email erfolgt immer nach dem Backup und dürfte absolut kein Rolle spielen, ob du iobroker stopst oder nicht.
            Habe nun ein Komplett-Backup um 13:45Uhr automatisch laufen lassen. Backup wurde erstellt aber keine Emailbenachrichtigung. Hier das Log:
            2019-03-04 13:43:41.179 - warn: modbus.0 Poll error count: 3 code: "App Timeout"
            2019-03-04 13:45:00.060 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 32060
            2019-03-04 13:45:10.059 - debug: backitup.0 [total] exec: done
            2019-03-04 13:45:10.252 - info: host.raspberrypi received SIGTERM
            2019-03-04 13:45:10.248 - info: web.0 terminating http server on port 8082
            2019-03-04 13:45:10.253 - info: web.0 terminated http server on port 8082
            2019-03-04 13:45:10.260 - info: modbus.0 terminating
            2019-03-04 13:45:10.269 - info: javascript.0 terminating
            2019-03-04 13:45:10.276 - info: web.0 terminating
            2019-03-04 13:45:10.298 - info: host.raspberrypi instance system.adapter.modbus.0 terminated with code 0 (OK)
            2019-03-04 13:45:10.317 - debug: backitup.0 system.adapter.admin.0: logging false
            2019-03-04 13:45:10.316 - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 0 (OK)
            2019-03-04 13:45:10.323 - info: host.raspberrypi instance system.adapter.web.0 terminated with code 0 (OK)
            2019-03-04 13:45:10.340 - info: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 0 (OK)
            2019-03-04 13:45:10.349 - info: host.raspberrypi instance system.adapter.javascript.0 terminated with code 0 (OK)
            2019-03-04 13:45:10.752 - info: email.0 terminating
            2019-03-04 13:45:10.768 - info: backitup.0 terminating
            2019-03-04 13:45:10.779 - info: host.raspberrypi instance system.adapter.email.0 terminated with code 0 (OK)
            2019-03-04 13:45:10.786 - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 0 (OK)
            2019-03-04 13:45:10.787 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (OK)
            2019-03-04 13:45:20.261 - info: host.raspberrypi force terminating
            2019-03-04 13:47:36.560 - info: host.raspberrypi iobroker.js-controller version 1.4.2 js-controller starting
            2019-03-04 13:47:36.569 - info: host.raspberrypi Copyright (c) 2014-2018 bluefox, 2014 hobbyquaker
            2019-03-04 13:47:36.570 - info: host.raspberrypi hostname: raspberrypi, node: v8.11.1
            2019-03-04 13:47:36.575 - info: host.raspberrypi ip addresses: 192.168.188.28 fe80::90f8:966e:754:6247
            2019-03-04 13:47:36.747 - info: host.raspberrypi inMem-states listening on port 9000
            2019-03-04 13:47:37.283 - info: host.raspberrypi inMem-objects listening on port 9001
            2019-03-04 13:47:37.314 - info: host.raspberrypi InMemoryDB connected
            2019-03-04 13:47:37.348 - info: host.raspberrypi 11 instances found
            2019-03-04 13:47:37.394 - info: host.raspberrypi starting 11 instances
            2019-03-04 13:47:37.459 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 32142
            2019-03-04 13:47:41.416 - info: host.raspberrypi instance system.adapter.web.0 started with pid 32148
            2019-03-04 13:47:42.118 - error: admin.0 setObject id missing!!
            2019-03-04 13:47:42.138 - info: admin.0 starting. Version 3.6.0 in /opt/iobroker/node_modules/iobroker.admin, node: v8.11.1
            2019-03-04 13:47:42.200 - info: admin.0 requesting all states
            2019-03-04 13:47:42.204 - info: admin.0 requesting all objects
            2019-03-04 13:47:42.207 - info: admin.0 Request actual repository...
            2019-03-04 13:47:44.096 - info: admin.0 received all states
            2019-03-04 13:47:45.599 - error: web.0 setObject id missing!!
            2019-03-04 13:47:45.621 - info: web.0 starting. Version 2.4.1 in /opt/iobroker/node_modules/iobroker.web, node: v8.11.1
            2019-03-04 13:47:46.258 - info: web.0 socket.io server listening on port 8082
            2019-03-04 13:47:46.264 - info: web.0 http server listening on port 8082
            2019-03-04 13:47:46.428 - info: admin.0 received all objects
            2019-03-04 13:47:46.577 - info: admin.0 http server listening on port 8081
            2019-03-04 13:47:46.577 - info: admin.0 Use link "http://localhost:8081" to configure.
            2019-03-04 13:47:46.704 - info: host.raspberrypi Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
            2019-03-04 13:47:49.417 - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 32169
            2019-03-04 13:47:49.714 - info: vis.0 starting. Version 1.1.10 in /opt/iobroker/node_modules/iobroker.vis, node: v8.11.1
            2019-03-04 13:47:49.877 - info: admin.0 Repository received successfully.
            2019-03-04 13:47:50.131 - info: vis.0 vis license is OK.
            2019-03-04 13:47:51.094 - info: host.raspberrypi instance system.adapter.vis.0 terminated while should be started once
            2019-03-04 13:47:55.297 - info: javascript.0 starting. Version 3.6.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v8.11.1
            2019-03-04 13:47:55.314 - info: javascript.0 requesting all states
            2019-03-04 13:47:55.326 - info: javascript.0 requesting all objects
            2019-03-04 13:47:56.505 - info: javascript.0 received all states
            2019-03-04 13:47:57.429 - info: host.raspberrypi instance system.adapter.modbus.0 started with pid 32183
            2019-03-04 13:47:58.807 - info: javascript.0 received all objects
            2019-03-04 13:47:58.967 - info: javascript.0 Start javascript script.js.Skalierung_PV_Leistung
            2019-03-04 13:47:59.087 - info: javascript.0 script.js.Skalierung_PV_Leistung: registered 0 subscriptions and 0 schedules
            2019-03-04 13:47:59.088 - info: javascript.0 Start javascript script.js.Skalierung_Meter_Leistung
            2019-03-04 13:47:59.162 - info: javascript.0 script.js.Skalierung_Meter_Leistung: registered 0 subscriptions and 0 schedules
            2019-03-04 13:47:59.163 - info: javascript.0 Start javascript script.js.Sonneuntergang
            2019-03-04 13:47:59.258 - info: javascript.0 script.js.Sonneuntergang: registered 0 subscriptions and 1 schedule
            2019-03-04 13:47:59.259 - info: javascript.0 Start javascript script.js.PV_Leistung_Durchschnitt
            2019-03-04 13:47:59.346 - info: javascript.0 script.js.PV_Leistung_Durchschnitt: registered 0 subscriptions and 1 schedule
            2019-03-04 13:47:59.347 - info: javascript.0 Start javascript script.js.eth002_R1
            2019-03-04 13:47:59.434 - info: javascript.0 script.js.eth002_R1: registered 1 subscription and 0 schedules
            2019-03-04 13:47:59.435 - info: javascript.0 Start javascript script.js.Steure_R1
            2019-03-04 13:47:59.516 - info: javascript.0 script.js.Steure_R1: registered 1 subscription and 0 schedules
            2019-03-04 13:47:59.517 - info: javascript.0 Start javascript script.js.Steure_R2
            2019-03-04 13:47:59.601 - info: javascript.0 script.js.Steure_R2: registered 2 subscriptions and 0 schedules
            2019-03-04 13:47:59.602 - info: javascript.0 Start javascript script.js.in_zeit_auto_R2
            2019-03-04 13:47:59.683 - info: javascript.0 script.js.in_zeit_auto_R2: registered 1 subscription and 1 schedule
            2019-03-04 13:47:59.685 - info: javascript.0 Start javascript script.js.eth002_R2
            2019-03-04 13:47:59.768 - info: javascript.0 script.js.eth002_R2: registered 1 subscription and 0 schedules
            2019-03-04 13:47:59.769 - info: javascript.0 Start javascript script.js.WLAN
            2019-03-04 13:47:59.850 - info: javascript.0 script.js.WLAN: registered 0 subscriptions and 1 schedule
            2019-03-04 13:47:59.851 - info: javascript.0 Start javascript script.js.Zeit_WP_Sperre_Ein_dynamisch
            2019-03-04 13:47:59.940 - info: javascript.0 script.js.Zeit_WP_Sperre_Ein_dynamisch: registered 0 subscriptions and 2 schedules
            2019-03-04 13:47:59.940 - info: javascript.0 Start javascript script.js.in_zeit_sperre_R1_mitWetter
            2019-03-04 13:48:00.027 - info: javascript.0 script.js.in_zeit_sperre_R1_mitWetter: registered 1 subscription and 1 schedule
            2019-03-04 13:48:00.028 - info: javascript.0 Start javascript script.js.Test_Ausgaben
            2019-03-04 13:48:00.117 - info: javascript.0 script.js.Test_Ausgaben: registered 0 subscriptions and 1 schedule
            2019-03-04 13:48:00.907 - info: modbus.0 starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.modbus, node: v8.11.1
            2019-03-04 13:48:00.961 - warn: modbus.0 Serial is not available
            2019-03-04 13:48:01.328 - info: modbus.0 Connected to slave 192.168.188.36
            2019-03-04 13:48:01.415 - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 32193
            2019-03-04 13:48:05.443 - info: tr-064.0 starting. Version 0.4.18 in /opt/iobroker/node_modules/iobroker.tr-064, node: v8.11.1
            2019-03-04 13:48:07.728 - error: tr-064.0 forEachConfiguredDevice: in GetSpecificHostEntry 0(fritz.box/5C:49:79:3E:4C:24):Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
            2019-03-04 13:48:09.430 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 32203
            2019-03-04 13:48:12.863 - debug: backitup.0 objectDB connected
            2019-03-04 13:48:12.936 - debug: backitup.0 statesDB connected
            2019-03-04 13:48:13.280 - info: backitup.0 starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v8.11.1
            2019-03-04 13:48:13.445 - info: host.raspberrypi instance scheduled system.adapter.daswetter.0 */15 * * * *
            2019-03-04 13:48:13.384 - debug: backitup.0 Printing logs of previous backup
            2019-03-04 13:48:13.388 - debug: backitup.0 [DEBUG] [total/mount] done
            2019-03-04 13:48:13.390 - debug: backitup.0 [DEBUG] [total/total] TAR started...
            2019-03-04 13:48:13.390 - debug: backitup.0 [DEBUG] [total/total] Ignore dir: /opt/iobroker/backups
            2019-03-04 13:48:13.391 - debug: backitup.0 [DEBUG] [total/total] done
            2019-03-04 13:48:13.391 - debug: backitup.0 [DEBUG] [total/cifs] done
            2019-03-04 13:48:13.391 - debug: backitup.0 [DEBUG] [total/clean] delete /opt/iobroker/backups/total_2018_12_01-04_15_30_backupiobroker.tar.gz
            2019-03-04 13:48:13.392 - debug: backitup.0 [DEBUG] [total/clean] done
            2019-03-04 13:48:13.392 - debug: backitup.0 [DEBUG] [total/start] done
            2019-03-04 13:48:13.392 - debug: backitup.0 [DEBUG] [total/email] done
            2019-03-04 13:48:13.392 - debug: backitup.0 [DEBUG] [total/start] IoBroker started ...
            2019-03-04 13:48:15.123 - debug: backitup.0 [total/email] [total] used E-Mail-Instance: email.0
            2019-03-04 13:48:15.127 - debug: backitup.0 sendTo "send" to system.adapter.email.0 from system.adapter.backitup.0
            2019-03-04 13:48:15.129 - debug: backitup.0 [total/email] done
            2019-03-04 13:48:15.299 - info: backitup.0 [minimal] backup was activated at 04:00 every 1 day(s)
            2019-03-04 13:48:15.351 - debug: backitup.0 [minimal] 10 00 04 */1 * *
            2019-03-04 13:48:15.352 - info: backitup.0 [total] backup was activated at 13:45 every 1 day(s)
            2019-03-04 13:48:15.367 - debug: backitup.0 [total] 10 45 13 */1 * *
            2019-03-04 13:48:15.393 - debug: backitup.0 mount activ... umount in 2 Seconds!!
            2019-03-04 13:48:15.420 - debug: backitup.0 [total/history] backitup.0.history.html
            2019-03-04 13:48:17.438 - info: host.raspberrypi instance system.adapter.email.0 started with pid 32218
            2019-03-04 13:48:20.704 - info: email.0 starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.email, node: v8.11.1
            2019-03-04 14:00:00.064 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 32263
            2019-03-04 14:00:14.221 - error: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 11 ()
            • simatec
              Kannst du mal testen, ob die Benachrichtigung ohne einen Stop bei einem Total kommt?
              So wie es aussieht startet dein Mail Adapter zu spät.
                Habe nun ein Backup auf 16:05 Uhr geplant (ohne Stop). Das Email wurde wunderbar verschickt.
                2019-03-04 16:01:28.538  - debug: backitup.0 system.adapter.admin.0: logging true
                2019-03-04 16:05:21.531  - debug: backitup.0 [total/mount] done
                2019-03-04 16:05:21.547  - debug: backitup.0 [total/total] TAR started...
                2019-03-04 16:05:21.549  - debug: backitup.0 [total/total] Ignore dir: /opt/iobroker/backups
                2019-03-04 16:05:31.548  - debug: backitup.0 [total/total] Packed 17MB so far...
                2019-03-04 16:05:41.550  - debug: backitup.0 [total/total] Packed 21MB so far...
                2019-03-04 16:05:51.552  - debug: backitup.0 [total/total] Packed 29MB so far...
                2019-03-04 16:06:01.556  - debug: backitup.0 [total/total] Packed 37MB so far...
                2019-03-04 16:06:11.577  - debug: backitup.0 [total/total] Packed 47MB so far...
                2019-03-04 16:06:21.686  - debug: backitup.0 [total/total] Packed 51MB so far...
                2019-03-04 16:06:31.688  - debug: backitup.0 [total/total] Packed 57MB so far...
                2019-03-04 16:06:41.693  - debug: backitup.0 [total/total] Packed 63MB so far...
                2019-03-04 16:06:51.787  - debug: backitup.0 [total/total] Packed 68MB so far...
                2019-03-04 16:07:01.789  - debug: backitup.0 [total/total] Packed 74MB so far...
                2019-03-04 16:07:11.791  - debug: backitup.0 [total/total] Packed 78MB so far...
                2019-03-04 16:07:19.873  - debug: backitup.0 [total/total] done
                2019-03-04 16:07:19.884  - debug: backitup.0 [total/cifs] done
                2019-03-04 16:07:19.913  - debug: backitup.0 [total/clean] delete /opt/iobroker/backups/total_2018_12_11-04_15_33_backupiobroker.tar.gz
                2019-03-04 16:07:19.944  - debug: backitup.0 [total/clean] done
                2019-03-04 16:07:19.954  - debug: backitup.0 [total/email] [total] used E-Mail-Instance: email.0
                2019-03-04 16:07:19.958  - debug: backitup.0 sendTo "send" to system.adapter.email.0 from system.adapter.backitup.0
                2019-03-04 16:07:19.959  - debug: backitup.0 [total/email] done
                2019-03-04 16:07:20.002  - debug: backitup.0 [total/history] backitup.0.history.html
                2019-03-04 16:07:20.047  - debug: backitup.0 [total/umount] mount activ... umount in 60 Seconds!!
                2019-03-04 16:07:20.170  - info: email.0 Send email: {"text":"BackItUp:\nEin neues total Backup wurde am 04. Maerz 2019 um 16:07 Uhr erstellt, und unter //192.168.188.40/Backup/iobroker/komplett/ gespeichert.","to":"xx.yy@gmx.ch","subject":"Backitup","from":"qq@gmail.com"}
                2019-03-04 16:07:21.931  - info: email.0 sent to xx.yy@gmx.ch
                2019-03-04 16:08:20.276  - debug: backitup.0 [total/umount] done
                2019-03-04 16:08:20.281  - debug: backitup.0 [total] exec: done
                • simatec
                  @sol21
                  Dann baue ich da mal eine Verzögerung ein, wenn iobroker gestoppt wird.
                    @simatec
                    Danke, kann ich dann wieder testen. Denke betrifft nicht nur mich...?
                    • simatec
                      @sol21
                      Hmmm das kann ich schwer beurteilen.
                      Ich habe auf allen Testsystemen diese Probleme nicht nachvollziehen können.
                      Was nutzt du für ein System? Eventuell ist die Hardware etwas zu schwach.
                      Normal wird die Mail erst nach iobroker Start versendet.
                      Aber deine Adapter brauchen anscheinend sehr lange zum starten.
                      Könnte an der Hardware liegen
                        @simatec
                        Habe einen RaspberryPi 3B. Läuft aber sehr wenig darauf.
                        Solange sich nicht mehr Leute mit dem gleichen Problem melden, kannst Du es so belassen. Ich weiss ja, dass das Backup erstellt wird und kann auf die Benachrichtigung verzichten. Ich werde es aber mal noch länger im Auge behalten.
                        Nochmals vielen herzlichen Dank!
                        • simatec
                          @sol21
                          Nutzt du redis? Wenn ja musst du nicht stoppen.
                          Auch ohne Redis musst du nicht stoppen.
                          Der stop ist nur dafür da, falls es Probleme beim erstellen des totals gibt.
                          Ich werde das aber fixen, damit die Meldung etwas zeitverzögert rausgeht
                          • simatec
                            simatec Developer Most Active last edited by simatec
                            Installiere mal die Version 1.1.3 vom Github und berichte mal bitte, ob deine Benachrichtigung per Mail jetzt kommt.
                              @simatec
                              habe nun mit der Version 1.1.3 getestet. Leider kam auch keine Email-Benachrichtigung.
                              Hatte das Komplett-Backup auf 14:00:00 eingeplant.
                              2019-03-05 13:57:12.261  - info: backitup.0 starting. Version 1.1.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v8.11.1
                              2019-03-05 13:57:12.337  - info: backitup.0 [minimal] backup was activated at 04:00 every 1 day(s)
                              2019-03-05 13:57:12.373  - debug: backitup.0 [minimal] 10 00 04 */1 * *
                              2019-03-05 13:57:12.373  - info: backitup.0 [total] backup was activated at 14:00:00 every 1 day(s)
                              2019-03-05 13:57:12.379  - debug: backitup.0 [total] 10 00 14 */1 * *
                              2019-03-05 13:57:12.923  - debug: backitup.0 system.adapter.admin.0: logging true
                              2019-03-05 13:58:08.082  - debug: backitup.0 system.adapter.admin.0: logging false
                              2019-03-05 13:58:16.367  - debug: backitup.0 system.adapter.admin.0: logging true
                              2019-03-05 14:00:00.057  - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 8859
                              2019-03-05 14:00:04.429  - info: daswetter.0 starting. Version 2.7.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v8.11.1
                              2019-03-05 14:00:10.080  - debug: backitup.0 [total] exec: done
                              2019-03-05 14:00:10.358  - info: host.raspberrypi received SIGTERM
                              2019-03-05 14:00:10.359  - info: web.0 terminating http server on port 8082
                              2019-03-05 14:00:10.367  - info: admin.0 terminating http server on port 8081
                              2019-03-05 14:00:10.372  - info: javascript.0 terminating
                              2019-03-05 14:00:10.380  - info: web.0 terminated http server on port 8082
                              2019-03-05 14:00:10.386  - info: admin.0 terminating
                              2019-03-05 14:00:10.386  - info: tr-064.0 terminating
                              2019-03-05 14:00:10.393  - info: modbus.0 terminating
                              2019-03-05 14:00:10.434  - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 0 (OK)
                              2019-03-05 14:00:10.435  - debug: backitup.0 system.adapter.admin.0: logging false
                              2019-03-05 14:00:10.439  - info: host.raspberrypi instance system.adapter.web.0 terminated with code 0 (OK)
                              2019-03-05 14:00:10.443  - info: host.raspberrypi instance system.adapter.javascript.0 terminated with code 0 (OK)
                              2019-03-05 14:00:10.447  - info: host.raspberrypi instance system.adapter.modbus.0 terminated with code 0 (OK)
                              2019-03-05 14:00:10.451  - info: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 0 (OK)
                              2019-03-05 14:00:10.875  - info: backitup.0 terminating
                              2019-03-05 14:00:10.874  - info: daswetter.0 terminating
                              2019-03-05 14:00:10.882  - info: email.0 terminating
                              2019-03-05 14:00:10.898  - info: host.raspberrypi instance system.adapter.email.0 terminated with code 0 (OK)
                              2019-03-05 14:00:10.906  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 0 (OK)
                              2019-03-05 14:00:10.908  - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (OK)
                              2019-03-05 14:00:20.368  - info: host.raspberrypi force terminating
                              2019-03-05 14:02:23.152  - info: host.raspberrypi iobroker.js-controller version 1.4.2 js-controller starting
                              2019-03-05 14:02:23.161  - info: host.raspberrypi Copyright (c) 2014-2018 bluefox, 2014 hobbyquaker
                              2019-03-05 14:02:23.162  - info: host.raspberrypi hostname: raspberrypi, node: v8.11.1
                              2019-03-05 14:02:23.167  - info: host.raspberrypi ip addresses: 192.168.188.28 fe80::90f8:966e:754:6247
                              2019-03-05 14:02:23.339  - info: host.raspberrypi  inMem-states listening on port 9000
                              2019-03-05 14:02:23.878  - info: host.raspberrypi  inMem-objects listening on port 9001
                              2019-03-05 14:02:23.909  - info: host.raspberrypi InMemoryDB connected
                              2019-03-05 14:02:23.943  - info: host.raspberrypi 11 instances found
                              2019-03-05 14:02:23.985  - info: host.raspberrypi starting 11 instances
                              2019-03-05 14:02:24.050  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 8960
                              2019-03-05 14:02:28.006  - info: host.raspberrypi instance system.adapter.web.0 started with pid 8967
                              2019-03-05 14:02:28.724  - error: admin.0 setObject id missing!!
                              2019-03-05 14:02:28.743  - info: admin.0 starting. Version 3.6.0 in /opt/iobroker/node_modules/iobroker.admin, node: v8.11.1
                              2019-03-05 14:02:28.806  - info: admin.0 requesting all states
                              2019-03-05 14:02:28.810  - info: admin.0 requesting all objects
                              2019-03-05 14:02:28.813  - info: admin.0 Request actual repository...
                              2019-03-05 14:02:30.631  - info: admin.0 received all states
                              2019-03-05 14:02:32.169  - error: web.0 setObject id missing!!
                              2019-03-05 14:02:32.191  - info: web.0 starting. Version 2.4.1 in /opt/iobroker/node_modules/iobroker.web, node: v8.11.1
                              2019-03-05 14:02:32.786  - info: web.0 socket.io server listening on port 8082
                              2019-03-05 14:02:32.792  - info: web.0 http server listening on port 8082
                              2019-03-05 14:02:33.034  - info: admin.0 received all objects
                              2019-03-05 14:02:33.191  - info: admin.0 http server listening on port 8081
                              2019-03-05 14:02:33.192  - info: admin.0 Use link "http://localhost:8081" to configure.
                              2019-03-05 14:02:33.318  - info: host.raspberrypi Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
                              2019-03-05 14:02:35.794  - info: vis.0 starting. Version 1.1.10 in /opt/iobroker/node_modules/iobroker.vis, node: v8.11.1
                              2019-03-05 14:02:35.935  - info: admin.0 Repository received successfully.
                              2019-03-05 14:02:36.007  - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 8991
                              2019-03-05 14:02:36.123  - info: vis.0 vis license is OK.
                              2019-03-05 14:02:37.084  - info: host.raspberrypi instance system.adapter.vis.0 terminated while should be started once
                              2019-03-05 14:02:41.450  - info: javascript.0 starting. Version 3.6.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v8.11.1
                              2019-03-05 14:02:41.467  - info: javascript.0 requesting all states
                              2019-03-05 14:02:41.470  - info: javascript.0 requesting all objects
                              2019-03-05 14:02:42.638  - info: javascript.0 received all states
                              2019-03-05 14:02:44.008  - info: host.raspberrypi instance system.adapter.modbus.0 started with pid 9001
                              2019-03-05 14:02:44.960  - info: javascript.0 received all objects
                              2019-03-05 14:02:45.083  - info: javascript.0 Start javascript script.js.Skalierung_PV_Leistung
                              2019-03-05 14:02:45.182  - info: javascript.0 script.js.Skalierung_PV_Leistung: registered 0 subscriptions and 0 schedules
                              2019-03-05 14:02:45.184  - info: javascript.0 Start javascript script.js.Skalierung_Meter_Leistung
                              2019-03-05 14:02:45.256  - info: javascript.0 script.js.Skalierung_Meter_Leistung: registered 0 subscriptions and 0 schedules
                              2019-03-05 14:02:45.257  - info: javascript.0 Start javascript script.js.Sonneuntergang
                              2019-03-05 14:02:45.351  - info: javascript.0 script.js.Sonneuntergang: registered 0 subscriptions and 1 schedule
                              2019-03-05 14:02:45.352  - info: javascript.0 Start javascript script.js.PV_Leistung_Durchschnitt
                              2019-03-05 14:02:45.432  - info: javascript.0 script.js.PV_Leistung_Durchschnitt: registered 0 subscriptions and 1 schedule
                              2019-03-05 14:02:45.433  - info: javascript.0 Start javascript script.js.eth002_R1
                              2019-03-05 14:02:45.514  - info: javascript.0 script.js.eth002_R1: registered 1 subscription and 0 schedules
                              2019-03-05 14:02:45.515  - info: javascript.0 Start javascript script.js.Steure_R1
                              2019-03-05 14:02:45.594  - info: javascript.0 script.js.Steure_R1: registered 1 subscription and 0 schedules
                              2019-03-05 14:02:45.595  - info: javascript.0 Start javascript script.js.Steure_R2
                              2019-03-05 14:02:45.674  - info: javascript.0 script.js.Steure_R2: registered 2 subscriptions and 0 schedules
                              2019-03-05 14:02:45.675  - info: javascript.0 Start javascript script.js.in_zeit_auto_R2
                              2019-03-05 14:02:45.758  - info: javascript.0 script.js.in_zeit_auto_R2: registered 1 subscription and 1 schedule
                              2019-03-05 14:02:45.759  - info: javascript.0 Start javascript script.js.eth002_R2
                              2019-03-05 14:02:45.843  - info: javascript.0 script.js.eth002_R2: registered 1 subscription and 0 schedules
                              2019-03-05 14:02:45.844  - info: javascript.0 Start javascript script.js.WLAN
                              2019-03-05 14:02:45.928  - info: javascript.0 script.js.WLAN: registered 0 subscriptions and 1 schedule
                              2019-03-05 14:02:45.929  - info: javascript.0 Start javascript script.js.Zeit_WP_Sperre_Ein_dynamisch
                              2019-03-05 14:02:46.017  - info: javascript.0 script.js.Zeit_WP_Sperre_Ein_dynamisch: registered 0 subscriptions and 2 schedules
                              2019-03-05 14:02:46.018  - info: javascript.0 Start javascript script.js.in_zeit_sperre_R1_mitWetter
                              2019-03-05 14:02:46.103  - info: javascript.0 script.js.in_zeit_sperre_R1_mitWetter: registered 1 subscription and 1 schedule
                              2019-03-05 14:02:46.104  - info: javascript.0 Start javascript script.js.Test_Ausgaben
                              2019-03-05 14:02:46.191  - info: javascript.0 script.js.Test_Ausgaben: registered 0 subscriptions and 1 schedule
                              2019-03-05 14:02:47.440  - info: modbus.0 starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.modbus, node: v8.11.1
                              2019-03-05 14:02:47.493  - warn: modbus.0 Serial is not available
                              2019-03-05 14:02:47.854  - info: modbus.0 Connected to slave 192.168.188.36
                              2019-03-05 14:02:48.007  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 9011
                              2019-03-05 14:02:52.017  - info: tr-064.0 starting. Version 0.4.18 in /opt/iobroker/node_modules/iobroker.tr-064, node: v8.11.1
                              2019-03-05 14:02:54.555  - error: tr-064.0 forEachConfiguredDevice: in GetSpecificHostEntry 0(fritz.box/5C:49:79:3E:4C:24):Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                              2019-03-05 14:02:56.025  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 9021
                              2019-03-05 14:02:59.341  - debug: backitup.0 objectDB connected
                              2019-03-05 14:02:59.416  - debug: backitup.0 statesDB connected
                              2019-03-05 14:02:59.599  - info: backitup.0 starting. Version 1.1.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v8.11.1
                              2019-03-05 14:03:00.121  - info: host.raspberrypi instance scheduled system.adapter.daswetter.0 */15 * * * *
                              2019-03-05 14:02:59.611  - debug: backitup.0 Printing logs of previous backup
                              2019-03-05 14:02:59.615  - debug: backitup.0 [DEBUG] [total/mount] done
                              2019-03-05 14:02:59.617  - debug: backitup.0 [DEBUG] [total/total] TAR started...
                              2019-03-05 14:02:59.617  - debug: backitup.0 [DEBUG] [total/total] Ignore dir: /opt/iobroker/backups
                              2019-03-05 14:02:59.618  - debug: backitup.0 [DEBUG] [total/total] done
                              2019-03-05 14:02:59.618  - debug: backitup.0 [DEBUG] [total/cifs] done
                              2019-03-05 14:02:59.618  - debug: backitup.0 [DEBUG] [total/clean] delete /opt/iobroker/backups/total_2019_01_01-04_15_33_backupiobroker.tar.gz
                              2019-03-05 14:02:59.619  - debug: backitup.0 [DEBUG] [total/clean] done
                              2019-03-05 14:02:59.619  - debug: backitup.0 [DEBUG] [total/start] done
                              2019-03-05 14:02:59.619  - debug: backitup.0 [DEBUG] [total/start] IoBroker started ...
                              2019-03-05 14:02:59.619  - debug: backitup.0 [DEBUG] [total/email] done
                              2019-03-05 14:03:00.598  - info: backitup.0 [minimal] backup was activated at 04:00 every 1 day(s)
                              2019-03-05 14:03:00.634  - debug: backitup.0 [minimal] 10 00 04 */1 * *
                              2019-03-05 14:03:00.634  - info: backitup.0 [total] backup was activated at 14:00:00 every 1 day(s)
                              2019-03-05 14:03:00.650  - debug: backitup.0 [total] 10 00 14 */1 * *
                              2019-03-05 14:03:00.737  - debug: backitup.0 mount activ... umount in 2 Seconds!!
                              2019-03-05 14:03:04.028  - info: host.raspberrypi instance system.adapter.email.0 started with pid 9044
                              2019-03-05 14:03:05.545  - debug: backitup.0 [total/email] [total] used E-Mail-Instance: email.0
                              2019-03-05 14:03:05.554  - debug: backitup.0 sendTo "send" to system.adapter.email.0 from system.adapter.backitup.0
                              2019-03-05 14:03:05.556  - debug: backitup.0 [total/email] done
                              2019-03-05 14:03:05.603  - debug: backitup.0 [total/history] backitup.0.history.html
                              2019-03-05 14:03:07.317  - info: email.0 starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.email, node: v8.11.1
                              2019-03-05 14:07:10.010  - debug: backitup.0 system.adapter.admin.0: logging false
                              2019-03-05 14:10:22.786  - debug: backitup.0 system.adapter.admin.0: logging true
                              • simatec
                                Hatte 5 Sekunden Verzögerung drin. Aber laut Log startet dein mail Adapter weitere 2 Sekunden später.
                                Ich habe nun die zeit auf 10 Sekunden angepasst. Probiere bitte noch einmal
                                  @simatec
                                  • simatec
                                    Ab Version 1.1.3 ist die Zeitverzögerung im Menü einstellbar.
                                    81.1k
                                    backitup email komplett nas
                                    1169
