    4. [Aufruf] Neuer Adaper Google-Sharedlocations
      clabbo last edited by
      Hi
      The adapter worked perfectly for me until the evening on Dec 27:th. The adapter is now yellow. I have checked the Google account I use (no warnings, no two factor authentication). I have also tried another Google account (which used to work earlier).
      My log looks slightly different from others as my adapter doesn't seem to try a second and third connection.
      google-sharedlocations.0	2019-01-14 18:37:30.055	debug	stateChange google-sharedlocations.0.info.connection {"val":false,"ack":false,"ts":1547487450055,"q":0,"from":"system.adapter.google-sharedlocations.0","lc":1546132595870}
      google-sharedlocations.0	2019-01-14 18:37:30.051	error	First connection failed (1). Error: options.uri is a required argument
      google-sharedlocations.0	2019-01-14 18:37:22.353	info	Starting google shared locations adapter
      google-sharedlocations.0	2019-01-14 18:37:22.353	info	starting. Version 1.5.2 in C:/ioBroker/node_modules/iobroker.google-sharedlocations, node: v10.15.0
      google-sharedlocations.0	2019-01-14 18:37:22.189	debug	statesDB connected
      google-sharedlocations.0	2019-01-14 18:37:22.179	debug	objectDB connected
      google-sharedlocations.0	2019-01-14 18:36:58.067	debug	sendTo "getUsersFromDB" to system.adapter.admin.0 from system.adapter.google-sharedlocations.0
      I hope you can solve this, it is a super good adapter!
      /Claes
      • N
        NetFritz last edited by
        Hallo
        Habe Heute mal den Adapter installiert. Version 1.5.2
        Wenn ich in der Adapterkonfiguration alles eingegeben habe
        und dann auf Speichern drücke kommt folgende Meldung.
        One description is empty!
        Habe Nutzername , Passwort und Email zur Kontowiederherstellung eingegeben.
        Was kann ich machen?
        • X
          x4tlaoguo last edited by
          In die Description für die Fences einen Wert eintragen, oder den leeren Wert löschen.
          Gesendet von meinem SM-G950F mit Tapatalk
          • siggi85
            siggi85 last edited by
            @siggi85:
            Ich wollte den Adapter gerade einrichten, aber kann mich auch nicht initial einloggen. 😞
            Aber jetzt steht erst Mal Weihnachten vor der Tür, also schöne und erholsame Feiertage, vielleicht hat der Entwickler ja nach den Feiertagen Zeit sich das Mal anzuschauen. 🙂 `
            Ich habe den Adaper seit damals deaktiviert aber konfiguriert in meinem ioBroker liegen. Leider funktioniert die Verbindung immer noch nicht. Ist damit zu rechnen, dass der Adapter in absehbarer Zeit wieder funktioniert? Die Idee dahinter finde ich nämlich ziemlich genial, da ich sowieso bereits meine Standortdaten an Google gebe (da ich Android nutze, wahrscheinlich sogar ob ich will oder nicht :lol: ). 🙂
            siggi85 1 Reply Last reply Reply Quote 0
            • Negalein
              hab heute den Adapter mit 1.5.2 installiert.
              Komisch war, dass ich ihn nur über GIT installieren konnte.
              Er scheint zwar als installiert auf, aber nicht in der Spalte "Verfügbar" steht nicht.
              Mein System ist so extrem langsam dadurch geworden, dass ich ihn wieder deinstalliert habe.
              System hängt immer noch sehr. Werde ioBroker jetzt mal neu starten.
              PS: verbinden konnte er sich auch nicht
              google-sharedlocations.0	2019-02-06 23:05:10.475	error	First connection failed.
              google-sharedlocations.0	2019-02-06 23:05:09.261	info	Starting google shared locations adapter
              google-sharedlocations.0	2019-02-06 23:05:09.252	info	starting. Version 1.5.2 in /opt/iobroker/node_modules/iobroker.google-sharedlocations, node: v6.14.4
              host.ioBroker	2019-02-06 23:05:07.823	info	instance system.adapter.google-sharedlocations.0 started with pid 13325
              host.ioBroker	2019-02-06 23:05:05.831	info	instance system.adapter.google-sharedlocations.0 terminated with code 0 (OK)
              google-sharedlocations.0	2019-02-06 23:05:05.810	info	terminating
              google-sharedlocations.0	2019-02-06 23:05:05.305	info	cleaned everything up...
                Jan1 last edited by
                Du hast Deine Frage teils selbst beantwortet 😉
                Das nichts angezeigt wird, liegt daran dass dieser Adapter nicht eingepglegt ist.
                Das Verbindungsproblem kann bei Google liegen. Hier gibts mit dem Adapter ab und zu noch Probleme.
                • Negalein
                  @Jan1:
                  Das Verbindungsproblem kann bei Google liegen. Hier gibts mit dem Adapter ab und zu noch Probleme. `
                  Ja, aber warum machte der mein IOB so extrem träge?
                    Jan1 last edited by
                    Das ist ne gute Frage.
                    Schalt den Adapter auf Debug und schau was im Log steht.
                    • siggi85
                      siggi85 @siggi85 last edited by
                      @siggi85 sagte in [Aufruf] Neuer Adaper Google-Sharedlocations:
                      @siggi85:
                      Wird dieser Adapter noch weiter entwickelt? Ich frage nur ob es sich noch lohnt darauf zu warten oder ich demnächst planen sollte, mir andere Lösungswege hierfür zu suchen. 🤔
                        Jan1 @siggi85 last edited by
                        @siggi85
                        Der Adapter läuft generell. Was ab und an nicht funktiniert ist das Login bei Google und dafür hab ich mir ein Blockly gebastelt, das den Adapter deaktiviert falls das auftritt und 30 Minuten später wieder einschaltet. Damit läuft das ganz gut.
                        • siggi85
                          siggi85 @Jan1 last edited by
                          @Jan1 sagte in [Aufruf] Neuer Adaper Google-Sharedlocations:
                          @siggi85
                          Achso. Bei mir hat es noch nie funktioniert obwohl mehrfach getestet. Habe das so verstanden, dass der Login in der Vergangenheit mal funktioniert haben muss, damit ein Cookie gespeichert wurde und dass seit einer Änderung bei Google der Adapter angepasst werden muss, damit dieser Cookie neu gezogen werden kann. 🤔
                          Morgen wird Internet bei mir zu Hause wieder geschaltet (gerade umgezogen), dann werde ich mal testen. ☺
                          • bahnuhr
                            Ich bekomme die Instanz auch nicht grün.
                            Im debug-log steht:
                            google-sharedlocations.0	2019-03-05 20:24:46.046	debug	stateChange google-sharedlocations.0.info.connection {"val":false,"ack":false,"ts":1551813886042,"q":0,"from":"system.adapter.google-sharedlocations.0","lc":1551813766795}
                            google-sharedlocations.0	2019-03-05 20:24:46.043	error	First connection failed.
                            google-sharedlocations.0	2019-03-05 20:24:46.043	debug	[google auth] Connection third stage failed due to an additional verification that could not be identified!
                            google-sharedlocations.0	2019-03-05 20:24:46.043	debug	[google auth] connectEnterVerificationEmail failed, error:Error: options.uri is a required argument
                            google-sharedlocations.0	2019-03-05 20:24:46.042	debug	[google auth] connectEnterVerificationEmail
                            google-sharedlocations.0	2019-03-05 20:24:45.977	debug	[google auth] Connection third stage additional verification needed.
                            google-sharedlocations.0	2019-03-05 20:24:45.867	debug	[google auth] Connection third stage
                            google-sharedlocations.0	2019-03-05 20:24:45.867	debug	[google auth] Connection second stage successful
                            google-sharedlocations.0	2019-03-05 20:24:45.712	debug	[google auth] Connection second State
                            google-sharedlocations.0	2019-03-05 20:24:45.712	debug	[google auth] Connection first stage successfull
                            google-sharedlocations.0	2019-03-05 20:24:45.387	debug	[google auth] Connection First State
                            google-sharedlocations.0	2019-03-05 20:24:45.387	info	Starting google shared locations adapter
                            google-sharedlocations.0	2019-03-05 20:24:45.387	info	starting. Version 1.5.2 in C:/ioBroker/node_modules/iobroker.google-sharedlocations, node: v8.12.0
                            • bahnuhr
                              tut sich hier noch was ?
                              Oder soll ich die Instanz wieder löschen ?
                                Jan1 last edited by Jan1
                                Bei Google müssen auch "unsichere APPs" zugelassen werden.
                                • bahnuhr
                                  bahnuhr Forum Testing Most Active @Jan1 last edited by
                                  Und wie/wo mache ich das ?
                                    Jan1 @bahnuhr last edited by
                                    @bahnuhr
                                    • bahnuhr
                                      ok, hab ich gefunden und auf "an" gestellt.
                                      Die Instanz bleibt aber gelb:
                                      Auch wenn ich in die Konfiguration gehe, dann kommt "connectin failed" bei klick auf Verbindung prüfen:
                                      Was muss denn oben bei Nutzername hin; ich hab dort den Google Account eingegeben, richtig ?
                                        @bahnuhr
                                        na das was Du beim Login auf der Google Seite auch ein gibts. Bei Dir stimmt das Login schon nicht und hat deshalb mit dem Adapter an sich nichts zu tun. Selbst wenn der Adapter gelb ist, muss die Verbindungsprüfung funktionieren.
                                        • bahnuhr
                                          Mensch Jan,
                                          genau das mache ich doch die ganze Zeit.
                                          habe auch schon alle möglichen Konstellationen probiert.
                                          Und nun zuletzt zeitgleich:
                                          chrome Browser bei google angemeldet.
                                          mailadresse und passwort
                                          und daneben die Daten im Adapter eingetragen.
                                          Im Browser Fenster werde ich angemeldet.
                                          Im Tab Instanzen kommt aber nur "connection failed"
                                          Folgender screenshot:
                                          Also hier stimmt etwas nicht.
                                          Ich raff es nicht oder bei dem Adapter stimmt etwas nicht.
                                          Anbei auch mal das log:
                                            Jan1 @bahnuhr last edited by Jan1
                                            @bahnuhr
                                            Das was jetzt dort steht, sieht aber auch schon anders aus, als auf Deinem ersten Screenshot. Trag mal bei Kontowiederherstellung eine andere E-Mail ein und am besten die, die Du auch bei Google dafür hinterlegt hast.
                                            51
                                            496
                                            110481
