    3. Entwicklung
    4. [Adapter] Neuer radar2-Adapter
      sveni_lee last edited by
      ich hab auch grad versucht den Adapter manuell zu installieren aber beim upload kommt dann der Fehler..
      svenilee@Gotham-City:/opt/iobroker$ iobroker u radar2
      got /opt/iobroker/node_modules/iobroker.radar2/admin
      upload [13] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/words.js words.js application/javascript
      upload [12] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/radar2.png radar2.png image/png
      upload [11] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/index_m.html index_m.html text/html
      upload [10] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/index.html index.html text/html
      upload [9] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [8] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [7] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [6] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [5] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [4] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [3] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [2] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [1] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [0] radar2.admin /opt/iobroker/node_modules/iobroker.radar2/admin/i18n/de/translations.json i18n/de/translations.json application/json
      Cannot find io-package.json in /opt/iobroker/node_modules/iobroker.radar2
      module.js:675
          throw err;
      SyntaxError: /opt/iobroker/node_modules/iobroker.radar2/io-package.json: Unexpected end of JSON input
          at JSON.parse (<anonymous>)
          at Object.Module._extensions..json (module.js:672:27)
          at Module.load (module.js:566:32)
          at tryModuleLoad (module.js:506:12)
          at Function.Module._load (module.js:498:3)
          at Module.require (module.js:597:17)
          at require (internal/module.js:11:18)
          at Upload.uploadAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:219:23)
          at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:890:52
          at Upload.upgradeAdapterObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:464:13)
      • MathiasJ
        MathiasJ last edited by
        so, das Paket installiert.
        Nun folgendes Problem bein Installieren am Termninal, anders geht es trotzdem nicht.
        npm ERR! path /root/.npm/_logs
        npm ERR! code EACCES
        npm ERR! errno -13
        npm ERR! syscall scandir
        npm ERR! Error: EACCES: permission denied, scandir '/root/.npm/_logs'
        npm ERR!  { Error: EACCES: permission denied, scandir '/root/.npm/_logs'
        npm ERR!   stack: 'Error: EACCES: permission denied, scandir \'/root/.npm/_logs\        '',
        npm ERR!   errno: -13,
        npm ERR!   code: 'EACCES',
        npm ERR!   syscall: 'scandir',
        npm ERR!   path: '/root/.npm/_logs' }
        npm ERR!
        npm ERR! The operation was rejected by your operating system.
        npm ERR! It is likely you do not have the permissions to access this file as the        current user
        npm ERR!
        npm ERR! If you believe this might be a permissions issue, please double-check t        he
        npm ERR! permissions of the file and its containing directories, or try running
        npm ERR! the command again as root/Administrator (though this is not recommended        ).
        glob error { Error: EACCES: permission denied, scandir '/root/.npm/_logs'
          stack: 'Error: EACCES: permission denied, scandir \'/root/.npm/_logs\'',
          errno: -13,
          code: 'EACCES',
          syscall: 'scandir',
        npm ERR! path /root/.npm/_cacache/index-v5/f6/d3/856f4e146dc3e8cb995652c4d6a1e16        806d6bca7e87878fd9046e55ea74f
        npm ERR! errno -13
        npm ERR! syscall open
        npm ERR! Error: EACCES: permission denied, open '/root/.npm/_cacache/index-v5/f6        /d3/856f4e146dc3e8cb995652c4d6a1e16806d6bca7e87878fd9046e55ea74f'
        npm ERR!  { Error: EACCES: permission denied, open '/root/.npm/_cacache/index-v5        /f6/d3/856f4e146dc3e8cb995652c4d6a1e16806d6bca7e87878fd9046e55ea74f'
        npm ERR!   cause:
        npm ERR!    { Error: EACCES: permission denied, open '/root/.npm/_cacache/index-        v5/f6/d3/856f4e146dc3e8cb995652c4d6a1e16806d6bca7e87878fd9046e55ea74f'
        npm ERR!      syscall: 'open',
        npm ERR!      path: '/root/.npm/_cacache/index-v5/f6/d3/856f4e146dc3e8cb995652c4        d6a1e16806d6bca7e87878fd9046e55ea74f' },
        npm ERR!   isOperational: true,
        npm ERR!   stack: 'Error: EACCES: permission denied, open \'/root/.npm/_cacache/        index-v5/f6/d3/856f4e146dc3e8cb995652c4d6a1e16806d6bca7e87878fd9046e55ea74f\'',
        npm ERR!   path: '/root/.npm/_cacache/index-v5/f6/d3/856f4e146dc3e8cb995652c4d6a        1e16806d6bca7e87878fd9046e55ea74f' }
        npm ERR!
        npm ERR!
        > raw-socket@1.6.4 install /home/mzaspel/node_modules/raw-socket
        > node-gyp rebuild
        gyp WARN EACCES user "root" does not have permission to access the dev dir "/roo        t/.node-gyp/8.15.1"
        gyp WARN EACCES attempting to reinstall using temporary dev dir "/tmp/.node-gyp"
        gyp ERR! configure error
        gyp ERR! stack Error: EACCES: permission denied, mkdir '/home/mzaspel/node_modul        es/raw-socket/build'
        gyp ERR! System Linux 4.15.0-45-generic
        gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gy        p/bin/node-gyp.js" "rebuild"
        gyp ERR! cwd /home/mzaspel/node_modules/raw-socket
        gyp ERR! node -v v8.15.1
        gyp ERR! node-gyp -v v3.8.0
        gyp ERR! not ok
        npm WARN enoent ENOENT: no such file or directory, open '/home/mzaspel/package.j        son'
        npm WARN mzaspel No description
        npm WARN mzaspel No repository field.
        npm WARN mzaspel No README data
        npm WARN mzaspel No license field.
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modul        es/xpc-connection):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-conne        ction@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":        "x64"})
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: @abandonware/bluetooth-hci-socke        t@0.5.3-1 (node_modules/@abandonware/bluetooth-hci-socket):
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: @abandonware/bluetooth-hci-socke        t@0.5.3-1 preinstall: `npm install node-pre-gyp`
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 243
        npm ERR! code ELIFECYCLE
        npm ERR! errno 1
        npm ERR! raw-socket@1.6.4 install: `node-gyp rebuild`
        npm ERR! Exit status 1
        npm ERR!
        npm ERR! Failed at the raw-socket@1.6.4 install script.
        npm ERR! This is probably not a problem with npm. There is likely additional log        ging output above.
        npm ERR!     /root/.npm/_logs/2019-03-05T15_12_20_047Z-debug.log
        nächste Meldung:
        root@iobroker:/home/mzaspel# sudo apt-get install libcap2-bin arp-scan bluetooth        bluez libbluetooth-dev libudev-dev
        E: Paket arp-scan kann nicht gefunden werden.
        ich arbeite mit einer Beebox, I5, als OS ist Ubuntu Server 18.04 installiert.
        Gruß,
        Mathias
          muckel @frankjoke last edited by
          @frankjoke
          ja, alles richtig eingegeben. ich sehe ja auch alles auf der map.
          die alternative zum eingeben der ID gefällt dir nicht?
            einen Fehler habe ich gefunden...
            in der io-package.json fehlt im Bereich "news" eine geschweifte Klammer. danach lässt sich der Adapter problemlos installieren.
            frankjoke 1 Reply Last reply Reply Quote 0
            • MathiasJ
              Kann ich es dann nochmal versuchen, oder wird dadurch ein anderes Problem gelöst?
              Und wann ist die Klammer drin?
              • frankjoke
                frankjoke @sveni_lee last edited by
                @sveni_lee sagte in [Adapter] Neuer radar2-Adapter:
                Das Problem ist korrigiert und V 0.1.6 ist auf Git!
                Sorry
                  sveni_lee @frankjoke last edited by
                  @frankjoke
                  kein Problem...
                  gibt es eigendlich ein Problem mit einem Echo, der wird bei mir nicht gefunden.
                  und der Server auf dem iobroker läuft auch nicht...
                  • frankjoke
                    @frankjoke
                    kein Problem...
                    Sven,
                    hast in der Konfig den Netzwerknamen ( und die mac) angegeben? Das solltest du. Meine Alexas heißen z.b amazon-xxxxxxxxx.
                    Wenn du nur mac angibst wird nur arp-scan verwendet, dann solltest du die retry auf 7 setzten damit auch ' unwillige' Geräte öfter gefunden werden.
                    Wenn du eine fixe IP oder den Netzwerknamen angibst dann wird neben Arp-Scan auch ping verwendet falls arp-scan nicht findet.
                    Der Vorteil von der Angabe des Netwerknamens ist dass alle Verbindungen gepingt werden (also IPv4 und IPv6).
                    Somit finde ich meine immer.
                    p.s.: Den eigenen Server kannst sicher mit 127.0.0.1 abfragen, aber der ist ja sowieso immer da....
                      sveni_lee @frankjoke last edited by sveni_lee
                      @frankjoke
                      hmm bei mir findet erbeides nicht bzw zeigt sie offline an...
                      EDIT: den ECHO hat er nun gefunden, fehlt nur noch der Server... obwohl der ja selbsterklärend ist...
                      EDIT": der Echo ist wie ein Blinklicht... geht, geht nicht ist online, ist nicht online
                      • MathiasJ
                        Nun habe ich Radar2 auch installieren können. Nur ist er ca 1 bis 2 Minuten grün, danach rot.
                        Mir kommt nur der Verdacht auf, daß die Beebox dafür nicht geeignet ist.
                        Ich kann tun und lassen was ich will. Ich bekomme den USB-Dongle einfach nicht zum laufen.
                        Ich wollte mir den Multihost-Betrieb eigentlich sparen........
                        Gruß,
                        Mathias
                        • frankjoke
                          frankjoke @MathiasJ last edited by
                          @MathiasJ
                          Kannst einen debug-log generieren von diesen 1-2 Minuten?
                          Dann kann ich das weiter sehen wo der Grund liegt.
                          • MathiasJ
                            MathiasJ last edited by MathiasJ
                            Hier st er:
                            radar2.0	2019-03-06 09:37:33.865	warn	radar initialization finished with error TypeError: Cannot read property 'push' of nullat A.Ptime.then.ms (/opt/iobroker/node_modules/iobroker.radar2/radar2.js:595:29)at <anonymous>at process._tickCal
                            radar2.0	2019-03-06 09:37:33.865	info	first scan took 16.118 seconds
                            radar2.0	2019-03-06 09:37:33.851	info	debug: Make State ack:true _uIPs = '[]'
                            radar2.0	2019-03-06 09:37:33.843	info	debug: Make State ack:true _uBTs = '[]'
                            radar2.0	2019-03-06 09:37:33.843	info	debug: radar2 found uBT's:
                            radar2.0	2019-03-06 09:37:33.842	info	debug: radar2 found uIP's:
                            radar2.0	2019-03-06 09:37:33.828	info	debug: Make State ack:true _isHere = ''
                            radar2.0	2019-03-06 09:37:33.817	info	debug: Make State ack:true _notHere = 'Familie, Mathias, Mieter'
                            radar2.0	2019-03-06 09:37:33.806	info	debug: Make State ack:true _allHere = ''
                            radar2.0	2019-03-06 09:37:33.797	info	debug: Make State ack:true _nHere = 1
                            radar2.0	2019-03-06 09:37:33.796	info	debug: radar found here (), who here () and not here (Familie, Mathias, Mieter)
                            radar2.0	2019-03-06 09:37:33.779	info	debug: Make State ack:true Mieter = false
                            radar2.0	2019-03-06 09:37:33.766	info	debug: Make State ack:true Mathias = false
                            radar2.0	2019-03-06 09:37:33.751	info	debug: Make State ack:true Familie = false
                            es kommt immer wieder ein loop:
                            host.iobroker-rock64	2019-03-06 10:49:35.676	info	Restart adapter system.adapter.radar2.0 because enabled
                            host.iobroker-rock64	2019-03-06 10:49:35.676	error	instance system.adapter.radar2.0 terminated with code 1 ()
                            host.iobroker-rock64	2019-03-06 10:49:35.676	error	Caught by controller[0]: at Function.Module._load (module.js:498:3)
                            host.iobroker-rock64	2019-03-06 10:49:35.676	error	Caught by controller[0]: at tryModuleLoad (module.js:506:12)
                            host.iobroker-rock64	2019-03-06 10:49:35.676	error	Caught by controller[0]: at Module.load (module.js:566:32)
                            host.iobroker-rock64	2019-03-06 10:49:35.676	error	Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
                            host.iobroker-rock64	2019-03-06 10:49:35.676	error	Caught by controller[0]: at Module._compile (module.js:653:30)
                            host.iobroker-rock64	2019-03-06 10:49:35.675	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.radar2/myNetworks.js:7:16)
                            host.iobroker-rock64	2019-03-06 10:49:35.675	error	Caught by controller[0]: at require (internal/module.js:11:18)
                            host.iobroker-rock64	2019-03-06 10:49:35.673	error	Caught by controller[0]: at Module.require (module.js:597:17)
                            host.iobroker-rock64	2019-03-06 10:49:35.673	error	Caught by controller[0]: at Function.Module._load (module.js:475:25)
                            host.iobroker-rock64	2019-03-06 10:49:35.673	error	Caught by controller[0]: at Function.Module._resolveFilename (module.js:548:15)
                            host.iobroker-rock64	2019-03-06 10:49:35.673	error	Caught by controller[0]: Error: Cannot find module 'net-ping'
                            host.iobroker-rock64	2019-03-06 10:49:35.673	error	Caught by controller[0]: ^
                            host.iobroker-rock64	2019-03-06 10:49:35.673	error	Caught by controller[0]: throw err;
                            host.iobroker-rock64	2019-03-06 10:49:35.668	error	Caught by controller[0]: module.js:550
                            host.iobroker-rock64	2019-03-06 10:49:35.151	info	instance system.adapter.radar2.0 started with pid 2612
                            host.iobroker-rock64	2019-03-06 10:49:05.132	info	Restart adapter system.adapter.radar2.0 because enabled
                            ich habe die IObroker-Installation auf der Beebox aufgegeben, da der USB-Dongle nicht erkant wird, egal was ich tue.
                            Gruß,
                            Mathias
                            • frankjoke
                              @MathiasJ
                              Habe meinem meiner Ubuntu 18.04.2 LTS VM einen BT stick im QNAP verpasst und bin auf die Suche gegangen.
                              • sudu ap-get update/upgrade u.s.w., wie schon früher gesagt geht das nach ca 30 Minuten nach Start da ubunto selbst einige Dinge nach Start updated, aber eben nicht alles!
                              • iobroker war schon drauf da ich broadlink2 getestet habe.
                              • Die notwendigen Pakete für radar2 installiert und probiuert ob ich auf der Kommandozeile arp-scan und hcitool laufen lassen kann was beides ging.
                              • Radar2 installiert, hatte da drauf node v10.xxxx laufen.
                              • Wie du beschreibst, nach dem Start kam beim ersten scan ein SEGVAULT und der Adapter restartete als er erstmals auf bluetooth zugreifen wollte.
                              Nun habe ich gecheckt was der Unterschied zu meinem Entwicklungs-VM mit Stretch, welches am selben QNAP lief und wo radar2 normal funktioniert, ist: Es war node V10!
                              Auf meinen Entwicklungssystemen und meinem Produktionssystem läuft nodeV8 und zum Testen hatte ich aber node V10 auf Ubuntu installiert.
                              Nun hab ich:
                              • iobroker gestoppt, dann das /opt/iobroker-Verzeichnis umbenannt (man muss allses neu installieren wenn man node downgraded).
                              • nodejs de-installiert und neu installiert (wie da beschieben: http://www.iobroker.net/docu/?page_id=8323&lang=de)
                              • node V8.x installiert
                              • die apps und radar2-notwendigkeiten installiert.
                              • iobroker laut oben installiert
                              • radar2 vom git installiert und
                                es läuft!!!!
                              Also, bitte nicht nodejs V10.
                              V10 ist zwar etwas schneller aber hat ein neues System zur Anbindung vonlibraries. Leider sind verwenden alle Module noch nicht diesen neuen Weg (der ja nicht auf v6 und v8 funktioniert) und leider scheint die Rückwärtskompatibilität von V10 nicht 100% gegeben.
                              Hast du auch V10 installiert?
                              • MathiasJ
                                Das kann ich ja wohl dann vernachlässigen.
                                Auf meinem System war nie Node v10 bzw nodejs v10 installiert.
                                Gruß,
                                Mathias
                                • frankjoke
                                  @MathiasJ
                                  Dann fällt mir auch nichts mehr ein, mit einer Ausnahme was mir heute beim update eines meiner Testsysteme passiert ist:
                                  Ich habe mit apt-get upgrade die SW upgegraded, dabei ist node von 8.15.0 auf 8.15.1 upgedated worden.
                                  Hab das nicht bemerkt und radar2 gestartet welches dann einen Fehler generiert hat!
                                  Wenn man node ändert muss man auch
                                   sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which node`)
                                  wieder neu ausführen.
                                  Sonst liegts an einem anderen Spezialproblem auf deinem Rechner 😞
                                  • MathiasJ
                                    Ich möchte mich für's erste bei @AlCalzone bedanken!
                                    Es war eine falsche Python-Version schuld.
                                    Radar2 läuft nun, nachdem ich die richtige Python-Version installiert und Radar2
                                    durch eine Reparatur-Installation neu installiert habe.
                                    Nun gehts zur nächsten Baustelle..........
                                    Gruß,
                                    Mathias
                                    • frankjoke
                                      @MathiasJ
                                      Super!
                                      @sveni_lee
                                      Meine Echo (dots) werden fast immer von arp-scan, und wenn nicht da dann von Ping erkannt.
                                      Bezüglich dem Server, ist das der auf dem radar2 auch läuft (a) oder ein anderes Gerät (b)?
                                      Wenn a)
                                      Warum willst du wissen ob du selbst läufst?
                                      Wenn b) Hast mal probiert den Server aus der Liste herauszunehmen und zu schauen ob er irgendwann auf den unknown auftaucht?
                                      Da drinnen sihst du dann auch was radar2 and namen und ip-adressen bzw mac-adressen für das Gerät findet.
                                      Wenn es auch nicht in den unknown auftaucht dann verstehe ich es nicht wenn er über Kommandozeilen-ping erreichbar ist.
                                      @alle
                                      Habe gerade eine Version 0.1.7 auf git gepostet.
                                      Die Änderungen sind hauptsächlich net-ping, es ist jetz nur noch optional, also wenn npm es nicht installieren kann dann stürtzt radar nicht ab sondern verwendet radar2 das Kommandozeilen-ping.
                                      Das hat auch den Vorteil dass radar2 jetzt auf linux/windows und osx laufen sollte, im schlimmstenfall ohne Bluetooth und nur mit ping.
                                      LG Frank!
                                      • MathiasJ
                                        ich habe es schon drauf, wenn auch auf dem System, wo Radar2 nie laufen wird.
                                        ich werde die beebox dann als Linux-Rechner mißbrauchen.
                                        Auf dem Testsystem (und hoffentlich baldigem produktiven System) installiere ich es dann morgen.
                                        es wird dann ein Rock64 mit 4GB RAM sein.
                                          @frankjoke said in [Adapter] Neuer radar2-Adapter:
                                          @sveni_lee
                                          mein Echo lässt sich vom Linux rechner auch nicht anpingen
                                          Wenn a)
                                          a) läuft auf dem selben system. Ich wollte es der Vollständigkeit halber haben.
                                          die IP, localhost und 127.0.0.1 gehen nicht...
                                          • MathiasJ
                                            auf dem Rock64 läßt es sich nicht installieren.
                                            Fertig mit Fehler: host.iobroker-rock64 Cannot install https://github.com/frankjoke/ioBroker.radar2/tarball/master: 243
                                            Gruß,
                                            Mathias
                                            adapter radar2 adapter
                                            80
                                            840
                                            217060
