    4. Diskussion zum neuen Installation-Fixer
    • Dr. Bakterius
      Dr. Bakterius Most Active @apollon77 last edited by
      @apollon77 Leider geht es auch mit dem Fixer vom 5.3. noch nicht. Vom rpi2-Adapter kommen immer noch Fehlermeldungen bezüglich Zugriffsrechte. Zuerst vier, nach einer Neuinstallation des Adapters nur noch die cpu_frequency.
      Hier das Log:
      2019-03-06 09:15:37.833 - info: host.raspberrypi object change system.adapter.rpi2.0
      2019-03-06 09:15:37.834 - info: host.raspberrypi stopInstance system.adapter.rpi2.0
      2019-03-06 09:15:37.835 - info: host.raspberrypi stopInstance system.adapter.rpi2.0 killing pid 3674
      2019-03-06 09:15:37.881 - error: Caught by controller[0]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
      2019-03-06 09:15:37.882 - info: host.raspberrypi instance system.adapter.rpi2.0 terminated with code 0 (OK)
      2019-03-06 09:15:40.407 - info: host.raspberrypi instance system.adapter.rpi2.0 started with pid 3808
      2019-03-06 09:15:41.862 - info: rpi2.0 starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.rpi2, node: v8.15.1
      2019-03-06 09:15:49.243 - error: rpi2.0 No Value found for cpu_frequency
      2019-03-06 09:15:52.870 - info: host.raspberrypi object change system.adapter.rpi2.0
      2019-03-06 09:15:52.871 - info: host.raspberrypi "system.adapter.rpi2.0" disabled
      2019-03-06 09:15:52.871 - info: host.raspberrypi stopInstance system.adapter.rpi2.0
      2019-03-06 09:15:52.871 - info: host.raspberrypi stopInstance system.adapter.rpi2.0 killing pid 3808
      2019-03-06 09:15:52.939 - error: Caught by controller[0]: cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: Keine Berechtigung
      2019-03-06 09:15:52.940 - info: host.raspberrypi instance system.adapter.rpi2.0 terminated with code 0 (OK)
      2019-03-06 09:15:57.717 - info: host.raspberrypi object change system.adapter.rpi2.0
      2019-03-06 09:16:04.987 - info: host.raspberrypi object change system.adapter.rpi2.0
      2019-03-06 09:16:04.987 - info: host.raspberrypi "system.adapter.rpi2.0" enabled
      2019-03-06 09:16:05.011 - info: host.raspberrypi instance system.adapter.rpi2.0 started with pid 3948
      2019-03-06 09:16:06.057 - debug: rpi2.0 objectDB connected
      2019-03-06 09:16:06.129 - debug: rpi2.0 statesDB connected
      2019-03-06 09:16:06.256 - info: rpi2.0 starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.rpi2, node: v8.15.1
      2019-03-06 09:16:08.258 - debug: rpi2.0 system.adapter.admin.0: logging true
      2019-03-06 09:16:13.059 - debug: rpi2.0 received all objects
      2019-03-06 09:16:13.060 - debug: rpi2.0 NODE Version = v8.15.1, we need new execSync
      2019-03-06 09:16:13.063 - debug: rpi2.0 start parsing
      2019-03-06 09:16:13.063 - debug: rpi2.0 PARSING: c_cpu
      2019-03-06 09:16:13.064 - debug: rpi2.0 PARSING: c_raspberry
      2019-03-06 09:16:13.064 - debug: rpi2.0 PARSING: c_memory
      2019-03-06 09:16:13.064 - debug: rpi2.0 PARSING: c_network
      2019-03-06 09:16:13.064 - debug: rpi2.0 PARSING: c_sdcard
      2019-03-06 09:16:13.064 - debug: rpi2.0 PARSING: c_swap
      2019-03-06 09:16:13.065 - debug: rpi2.0 PARSING: c_temperature
      2019-03-06 09:16:13.065 - debug: rpi2.0 PARSING: c_uptime
      2019-03-06 09:16:13.065 - debug: rpi2.0 PARSING: c_wlan
      2019-03-06 09:16:13.065 - debug: rpi2.0 PARSING: interval
      2019-03-06 09:16:13.065 - debug: rpi2.0 PARSING: cpu
      2019-03-06 09:16:13.066 - debug: rpi2.0 PARSING: cpu_frequency
      2019-03-06 09:16:13.066 - debug: rpi2.0 ---> cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq
      2019-03-06 09:16:13.105 - debug: rpi2.0 Error: Command failed: cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq
      at checkExecSyncError (child_process.js:607:13)
      at execSync (child_process.js:647:13)
      at parser (/opt/iobroker/node_modules/iobroker.rpi2/main.js:160:34)
      at main (/opt/iobroker/node_modules/iobroker.rpi2/main.js:120:5)
      at Socket. (/opt/iobroker/node_modules/iobroker.rpi2/main.js:43:13)
      at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
      at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
      at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
      at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
      2019-03-06 09:16:13.107 - debug: rpi2.0 PARSING: load1,load5,load15
      2019-03-06 09:16:13.108 - debug: rpi2.0 ---> cat /proc/loadavg
      2019-03-06 09:16:13.133 - debug: rpi2.0 ------------- 1.04 1.27 0.83 1/463 4004
      2019-03-06 09:16:13.134 - debug: rpi2.0 ---> REGEXP: /^(\S+)\s(\S+)\s(\S+)/
      2019-03-06 09:16:13.134 - debug: rpi2.0 GROUPS: 4
      2019-03-06 09:16:13.134 - debug: rpi2.0 MATCHING: 1.04
      2019-03-06 09:16:13.134 - debug: rpi2.0 NAME: load1, VALULE: 1.04
      2019-03-06 09:16:13.135 - debug: rpi2.0 MATCHING: 1.27
      2019-03-06 09:16:13.135 - debug: rpi2.0 NAME: load5, VALULE: 1.27
      2019-03-06 09:16:13.135 - debug: rpi2.0 MATCHING: 0.83
      2019-03-06 09:16:13.135 - debug: rpi2.0 NAME: load15, VALULE: 0.83
      2019-03-06 09:16:13.136 - debug: rpi2.0 PARSING: scaling_governor
      2019-03-06 09:16:13.136 - debug: rpi2.0 ---> cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
      2019-03-06 09:16:13.168 - debug: rpi2.0 ------------- ondemand
      2019-03-06 09:16:13.168 - debug: rpi2.0 ---> REGEXP: /(.)/
      2019-03-06 09:16:13.169 - debug: rpi2.0 GROUPS: 2
      2019-03-06 09:16:13.169 - debug: rpi2.0 ---> POST:
      2019-03-06 09:16:13.169 - debug: rpi2.0 PARSING: raspberry
      2019-03-06 09:16:13.169 - debug: rpi2.0 PARSING: memory
      2019-03-06 09:16:13.169 - debug: rpi2.0 PARSING: memory_total
      2019-03-06 09:16:13.170 - debug: rpi2.0 ---> cat /proc/meminfo
      2019-03-06 09:16:13.196 - debug: rpi2.0 ------------- MemTotal: 1000180 kB
      MemFree: 54192 kB
      MemAvailable: 103508 kB
      Buffers: 7108 kB
      Cached: 86912 kB
      SwapCached: 28160 kB
      Active: 437552 kB
      Inactive: 442192 kB
      Active(anon): 389080 kB
      Inactive(anon): 404552 kB
      Active(file): 48472 kB
      Inactive(file): 37640 kB
      Unevictable: 0 kB
      Mlocked: 0 kB
      SwapTotal: 1048572 kB
      SwapFree: 762672 kB
      Dirty: 220 kB
      Writeback: 0 kB
      AnonPages: 779648 kB
      Mapped: 61192 kB
      Shmem: 7908 kB
      Slab: 30288 kB
      SReclaimable: 16456 kB
      SUnreclaim: 13832 kB
      KernelStack: 3768 kB
      PageTables: 10472 kB
      NFS_Unstable: 0 kB
      Bounce: 0 kB
      WritebackTmp: 0 kB
      CommitLimit: 1548660 kB
      Committed_AS: 3330324 kB
      VmallocTotal: 1064960 kB
      VmallocUsed: 0 kB
      VmallocChunk: 0 kB
      CmaTotal: 8192 kB
      CmaFree: 6724 kB
      2019-03-06 09:16:13.197 - debug: rpi2.0 ---> REGEXP: /MemTotal:\s+(\d+)/
      2019-03-06 09:16:13.198 - debug: rpi2.0 GROUPS: 2
      2019-03-06 09:16:13.198 - debug: rpi2.0 ---> POST: $1/1024
      2019-03-06 09:16:13.198 - debug: rpi2.0 PARSING: memory_free
      2019-03-06 09:16:13.199 - debug: rpi2.0 ---> cat /proc/meminfo
      2019-03-06 09:16:13.227 - debug: rpi2.0 ------------- MemTotal: 1000180 kB
      MemFree: 54092 kB
      MemAvailable: 103408 kB
      Buffers: 7108 kB
      Cached: 86912 kB
      Active: 437668 kB
      Inactive: 442192 kB
      Active(anon): 389196 kB
      Unevictable: 0 kB
      Mlocked: 0 kB
      SwapFree: 762672 kB
      Dirty: 220 kB
      Writeback: 0 kB
      AnonPages: 779768 kB
      Mapped: 61192 kB
      Shmem: 7908 kB
      Slab: 30288 kB
      KernelStack: 3744 kB
      PageTables: 10468 kB
      NFS_Unstable: 0 kB
      Bounce: 0 kB
      WritebackTmp: 0 kB
      Committed_AS: 3330296 kB
      VmallocUsed: 0 kB
      VmallocChunk: 0 kB
      CmaTotal: 8192 kB
      CmaFree: 6724 kB
      2019-03-06 09:16:13.234 - debug: rpi2.0 ---> REGEXP: /MemFree:\s+(\d+)/
      2019-03-06 09:16:13.235 - debug: rpi2.0 GROUPS: 2
      2019-03-06 09:16:13.235 - debug: rpi2.0 ---> POST: $1/1024
      2019-03-06 09:16:13.235 - debug: rpi2.0 PARSING: memory_available
      2019-03-06 09:16:13.236 - debug: rpi2.0 ---> cat /proc/meminfo
      2019-03-06 09:16:13.260 - debug: rpi2.0 ------------- MemTotal: 1000180 kB
      MemFree: 54108 kB
      MemAvailable: 103424 kB
      Buffers: 7108 kB
      Cached: 86912 kB
      Active: 437636 kB
      Inactive: 442192 kB
      Active(anon): 389164 kB
      Unevictable: 0 kB
      Mlocked: 0 kB
      SwapFree: 762672 kB
      Dirty: 220 kB
      Writeback: 0 kB
      AnonPages: 779796 kB
      Mapped: 61192 kB
      Shmem: 7908 kB
      Slab: 30288 kB
      PageTables: 10476 kB
      NFS_Unstable: 0 kB
      Bounce: 0 kB
      WritebackTmp: 0 kB
      Committed_AS: 3330644 kB
      VmallocUsed: 0 kB
      VmallocChunk: 0 kB
      CmaTotal: 8192 kB
      CmaFree: 6724 kB
      2019-03-06 09:16:13.261 - debug: rpi2.0 ---> REGEXP: /MemAvailable:\s+(\d+)/m
      2019-03-06 09:16:13.261 - debug: rpi2.0 GROUPS: 2
      2019-03-06 09:16:13.262 - debug: rpi2.0 ---> POST: $1/1024
      2019-03-06 09:16:13.262 - debug: rpi2.0 PARSING: network
      2019-03-06 09:16:13.262 - debug: rpi2.0 PARSING: net_received
      2019-03-06 09:16:13.262 - debug: rpi2.0 ---> cat /sys/class/net/eth0/statistics/rx_bytes
      2019-03-06 09:16:13.288 - debug: rpi2.0 ------------- 5844530
      2019-03-06 09:16:13.288 - debug: rpi2.0 ---> REGEXP: /(.
      2019-03-06 09:16:13.288 - debug: rpi2.0 GROUPS: 2
      2019-03-06 09:16:13.289 - debug: rpi2.0 ---> POST: $1*-1
      2019-03-06 09:16:13.289 - debug: rpi2.0 PARSING: net_send
      2019-03-06 09:16:13.295 - debug: rpi2.0 ---> cat /sys/class/net/eth0/statistics/tx_bytes
      2019-03-06 09:16:13.320 - debug: rpi2.0 ------------- 7502954
      2019-03-06 09:16:13.321 - debug: rpi2.0 ---> REGEXP: /(.)/
      2019-03-06 09:16:13.321 - debug: rpi2.0 GROUPS: 2
      2019-03-06 09:16:13.321 - debug: rpi2.0 ---> POST:
      2019-03-06 09:16:13.321 - debug: rpi2.0 PARSING: sdcard
      2019-03-06 09:16:13.322 - debug: rpi2.0 PARSING: sdcard_root_total
      2019-03-06 09:16:13.322 - debug: rpi2.0 ---> df /
      2019-03-06 09:16:13.348 - debug: rpi2.0 ------------- Dateisystem 1K-Blöcke Benutzt Verfügbar Verw% Eingehängt auf
      /dev/root 8058996 6368196 1342008 83% /
      2019-03-06 09:16:13.350 - debug: rpi2.0 ---> REGEXP: /\S+\s+(\d+).
      /$/m
      2019-03-06 09:16:13.350 - debug: rpi2.0 GROUPS: 2
      2019-03-06 09:16:13.350 - debug: rpi2.0 ---> POST: $1/1024
      2019-03-06 09:16:13.351 - debug: rpi2.0 PARSING: sdcard_boot_total
      2019-03-06 09:16:13.351 - debug: rpi2.0 ---> df /boot
      2019-03-06 09:16:13.380 - debug: rpi2.0 ------------- Dateisystem 1K-Blöcke Benutzt Verfügbar Verw% Eingehängt auf
      /dev/sda1 42131 22390 19741 54% /boot
      2019-03-06 09:16:13.381 - debug: rpi2.0 ---> REGEXP: /\S+\s+(\d+)./boot$/m
      2019-03-06 09:16:13.387 - debug: rpi2.0 GROUPS: 2
      2019-03-06 09:16:13.387 - debug: rpi2.0 ---> POST: $1/1024
      2019-03-06 09:16:13.388 - debug: rpi2.0 PARSING: sdcard_root_used
      2019-03-06 09:16:13.388 - debug: rpi2.0 ---> df /
      2019-03-06 09:16:13.414 - debug: rpi2.0 ------------- Dateisystem 1K-Blöcke Benutzt Verfügbar Verw% Eingehängt auf
      2019-03-06 09:16:13.415 - debug: rpi2.0 ---> REGEXP: /\S+\s+\d+\s+(\d+).
      /$/m
      2019-03-06 09:16:13.416 - debug: rpi2.0 GROUPS: 2
      2019-03-06 09:16:13.416 - debug: rpi2.0 ---> POST: $1/1024
      2019-03-06 09:16:13.416 - debug: rpi2.0 PARSING: sdcard_boot_used
      2019-03-06 09:16:13.416 - debug: rpi2.0 ---> df /boot
      2019-03-06 09:16:13.443 - debug: rpi2.0 ------------- Dateisystem 1K-Blöcke Benutzt Verfügbar Verw% Eingehängt auf
      2019-03-06 09:16:13.444 - debug: rpi2.0 ---> REGEXP: /\S+\s+\d+\s+(\d+)./boot$/m
      2019-03-06 09:16:13.444 - debug: rpi2.0 GROUPS: 2
      2019-03-06 09:16:13.444 - debug: rpi2.0 ---> POST: $1/1024
      2019-03-06 09:16:13.445 - debug: rpi2.0 PARSING: swap
      2019-03-06 09:16:13.445 - debug: rpi2.0 PARSING: swap_total
      2019-03-06 09:16:13.445 - debug: rpi2.0 ---> cat /proc/meminfo
      2019-03-06 09:16:13.476 - debug: rpi2.0 ------------- MemTotal: 1000180 kB
      MemFree: 53348 kB
      MemAvailable: 102664 kB
      Buffers: 7108 kB
      Cached: 86912 kB
      Active: 437892 kB
      Inactive: 442192 kB
      Active(anon): 389420 kB
      Unevictable: 0 kB
      Mlocked: 0 kB
      SwapFree: 762672 kB
      Dirty: 220 kB
      Writeback: 0 kB
      AnonPages: 779984 kB
      Mapped: 61192 kB
      Shmem: 7908 kB
      Slab: 30288 kB
      NFS_Unstable: 0 kB
      Bounce: 0 kB
      WritebackTmp: 0 kB
      Committed_AS: 3329604 kB
      VmallocUsed: 0 kB
      VmallocChunk: 0 kB
      CmaTotal: 8192 kB
      CmaFree: 6724 kB
      2019-03-06 09:16:13.477 - debug: rpi2.0 ---> REGEXP: /SwapTotal:\s+(\d+)/m
      2019-03-06 09:16:13.477 - debug: rpi2.0 GROUPS: 2
      2019-03-06 09:16:13.477 - debug: rpi2.0 ---> POST: $1/1024
      2019-03-06 09:16:13.478 - debug: rpi2.0 PARSING: swap_used
      2019-03-06 09:16:13.478 - debug: rpi2.0 ---> cat /proc/meminfo
      2019-03-06 09:16:13.503 - debug: rpi2.0 ------------- MemTotal: 1000180 kB
      MemFree: 53488 kB
      MemAvailable: 102804 kB
      Buffers: 7108 kB
      Cached: 86912 kB
      Active: 437908 kB
      Inactive: 442192 kB
      Active(anon): 389436 kB
      Unevictable: 0 kB
      Mlocked: 0 kB
      SwapFree: 762672 kB
      Dirty: 220 kB
      Writeback: 0 kB
      AnonPages: 780008 kB
      Mapped: 61192 kB
      Shmem: 7908 kB
      Slab: 30288 kB
      NFS_Unstable: 0 kB
      Bounce: 0 kB
      WritebackTmp: 0 kB
      VmallocUsed: 0 kB
      VmallocChunk: 0 kB
      CmaTotal: 8192 kB
      CmaFree: 6724 kB
      2019-03-06 09:16:13.504 - debug: rpi2.0 ---> REGEXP: /SwapFree:\s+(\d+)/m
      2019-03-06 09:16:13.505 - debug: rpi2.0 GROUPS: 2
      2019-03-06 09:16:13.505 - debug: rpi2.0 ---> POST: (rpi.swap_total - $1)/1024
      2019-03-06 09:16:13.505 - debug: rpi2.0 PARSING: temperature
      2019-03-06 09:16:13.506 - debug: rpi2.0 PARSING: soc_temp
      2019-03-06 09:16:13.506 - debug: rpi2.0 ---> cat /sys/devices/virtual/thermal/thermal_zone0/temp
      2019-03-06 09:16:13.539 - debug: rpi2.0 ------------- 47236
      2019-03-06 09:16:13.540 - debug: rpi2.0 ---> REGEXP: /(.
      2019-03-06 09:16:13.548 - debug: rpi2.0 GROUPS: 2
      2019-03-06 09:16:13.548 - debug: rpi2.0 ---> POST: $1/1000
      2019-03-06 09:16:13.549 - debug: rpi2.0 PARSING: uptime
      2019-03-06 09:16:13.550 - debug: rpi2.0 ---> cat /proc/uptime
      2019-03-06 09:16:13.575 - debug: rpi2.0 ------------- 677.80 1853.58
      2019-03-06 09:16:13.575 - debug: rpi2.0 ---> REGEXP: /(^\S+)/
      2019-03-06 09:16:13.576 - debug: rpi2.0 GROUPS: 2
      2019-03-06 09:16:13.576 - debug: rpi2.0 ---> POST:
      2019-03-06 09:16:13.576 - debug: rpi2.0 PARSING: wlan
      2019-03-06 09:16:13.576 - debug: rpi2.0 PARSING: wifi_received
      2019-03-06 09:16:13.577 - debug: rpi2.0 ---> cat /sys/class/net/wlan0/statistics/rx_bytes
      2019-03-06 09:16:13.604 - debug: rpi2.0 ------------- 4194354
      2019-03-06 09:16:13.605 - debug: rpi2.0 ---> REGEXP: /(.)/
      2019-03-06 09:16:13.605 - debug: rpi2.0 GROUPS: 2
      2019-03-06 09:16:13.606 - debug: rpi2.0 ---> POST: $1
      -1
      2019-03-06 09:16:13.606 - debug: rpi2.0 PARSING: wifi_send
      2019-03-06 09:16:13.607 - debug: rpi2.0 ---> cat /sys/class/net/wlan0/statistics/tx_bytes
      2019-03-06 09:16:13.643 - debug: rpi2.0 ------------- 2306717
      2019-03-06 09:16:13.643 - debug: rpi2.0 ---> REGEXP: /(.)/
      2019-03-06 09:16:13.644 - debug: rpi2.0 GROUPS: 2
      2019-03-06 09:16:13.644 - debug: rpi2.0 ---> POST:
      2019-03-06 09:16:13.645 - debug: rpi2.0 PARSING: gpios
      2019-03-06 09:16:13.645 - debug: rpi2.0 CURRENT = c_cpu undefined
      2019-03-06 09:16:13.680 - debug: rpi2.0 0
      2019-03-06 09:16:13.680 - debug: rpi2.0 CURRENT = c_raspberry undefined
      2019-03-06 09:16:13.681 - debug: rpi2.0 0
      2019-03-06 09:16:13.681 - debug: rpi2.0 CURRENT = c_memory undefined
      2019-03-06 09:16:13.682 - debug: rpi2.0 0
      2019-03-06 09:16:13.682 - debug: rpi2.0 CURRENT = c_network undefined
      2019-03-06 09:16:13.682 - debug: rpi2.0 CURRENT = c_sdcard undefined
      2019-03-06 09:16:13.683 - debug: rpi2.0 0
      2019-03-06 09:16:13.683 - debug: rpi2.0 CURRENT = c_swap undefined
      2019-03-06 09:16:13.683 - debug: rpi2.0 CURRENT = c_temperature undefined
      2019-03-06 09:16:13.684 - debug: rpi2.0 0
      2019-03-06 09:16:13.684 - debug: rpi2.0 CURRENT = c_uptime undefined
      2019-03-06 09:16:13.695 - debug: rpi2.0 0
      2019-03-06 09:16:13.695 - debug: rpi2.0 CURRENT = c_wlan undefined
      2019-03-06 09:16:13.696 - debug: rpi2.0 0
      2019-03-06 09:16:13.696 - debug: rpi2.0 CURRENT = interval undefined
      2019-03-06 09:16:13.696 - debug: rpi2.0 -1
      2019-03-06 09:16:13.697 - debug: rpi2.0 CURRENT = cpu true
      2019-03-06 09:16:13.697 - debug: rpi2.0 -1
      2019-03-06 09:16:13.701 - debug: rpi2.0 ---> POST: $1/1000 for cpu_frequency in [object Object]
      2019-03-06 09:16:13.702 - error: rpi2.0 No Value found for cpu_frequency
      2019-03-06 09:16:13.703 - debug: rpi2.0 ---> POST: for load1,load5,load15 in [object Object]
      2019-03-06 09:16:13.704 - debug: rpi2.0 MATCHING: 1.04
      2019-03-06 09:16:13.704 - debug: rpi2.0 NAME: load1 VALULE: 1.04
      2019-03-06 09:16:13.705 - debug: rpi2.0 SETSTATE FOR rpi2.0.cpu.load1 VALUE = 1.04
      2019-03-06 09:16:13.707 - debug: rpi2.0 MATCHING: 1.27
      2019-03-06 09:16:13.707 - debug: rpi2.0 NAME: load5 VALULE: 1.27
      2019-03-06 09:16:13.708 - debug: rpi2.0 SETSTATE FOR rpi2.0.cpu.load5 VALUE = 1.27
      2019-03-06 09:16:13.709 - debug: rpi2.0 MATCHING: 0.83
      2019-03-06 09:16:13.713 - debug: rpi2.0 NAME: load15 VALULE: 0.83
      2019-03-06 09:16:13.714 - debug: rpi2.0 SETSTATE FOR rpi2.0.cpu.load15 VALUE = 0.83
      2019-03-06 09:16:13.714 - debug: rpi2.0 ---> POST: for scaling_governor in [object Object]
      2019-03-06 09:16:13.715 - debug: rpi2.0 SETSTATE FOR rpi2.0.cpu.scaling_governor VALUE = ondemand
      2019-03-06 09:16:13.715 - debug: rpi2.0 CURRENT = raspberry false
      2019-03-06 09:16:13.716 - debug: rpi2.0 -1
      2019-03-06 09:16:13.716 - debug: rpi2.0 CURRENT = memory true
      2019-03-06 09:16:13.717 - debug: rpi2.0 -1
      2019-03-06 09:16:13.718 - debug: rpi2.0 ---> POST: $1/1024 for memory_total in [object Object]
      2019-03-06 09:16:13.718 - debug: rpi2.0 VALUE: 1000180 POST: $1/1024
      2019-03-06 09:16:13.719 - debug: rpi2.0 SETSTATE FOR rpi2.0.memory.memory_total VALUE = 976.74
      2019-03-06 09:16:13.720 - debug: rpi2.0 ---> POST: $1/1024 for memory_free in [object Object]
      2019-03-06 09:16:13.720 - debug: rpi2.0 VALUE: 54092 POST: $1/1024
      2019-03-06 09:16:13.721 - debug: rpi2.0 SETSTATE FOR rpi2.0.memory.memory_free VALUE = 52.82
      2019-03-06 09:16:13.722 - debug: rpi2.0 ---> POST: $1/1024 for memory_available in [object Object]
      2019-03-06 09:16:13.722 - debug: rpi2.0 VALUE: 103424 POST: $1/1024
      2019-03-06 09:16:13.726 - debug: rpi2.0 SETSTATE FOR rpi2.0.memory.memory_available VALUE = 101
      2019-03-06 09:16:13.727 - debug: rpi2.0 CURRENT = network true
      2019-03-06 09:16:13.727 - debug: rpi2.0 -1
      2019-03-06 09:16:13.728 - debug: rpi2.0 ---> POST: $1
      -1 for net_received in [object Object]
      2019-03-06 09:16:13.729 - debug: rpi2.0 VALUE: 5844530 POST: $1*-1
      2019-03-06 09:16:13.729 - debug: rpi2.0 SETSTATE FOR rpi2.0.network.net_received VALUE = -5844530
      2019-03-06 09:16:13.730 - debug: rpi2.0 ---> POST: for net_send in [object Object]
      2019-03-06 09:16:13.731 - debug: rpi2.0 SETSTATE FOR rpi2.0.network.net_send VALUE = 7502954
      2019-03-06 09:16:13.731 - debug: rpi2.0 CURRENT = sdcard true
      2019-03-06 09:16:13.731 - debug: rpi2.0 -1
      2019-03-06 09:16:13.732 - debug: rpi2.0 ---> POST: $1/1024 for sdcard_root_total in [object Object]
      2019-03-06 09:16:13.733 - debug: rpi2.0 VALUE: 8058996 POST: $1/1024
      2019-03-06 09:16:13.733 - debug: rpi2.0 SETSTATE FOR rpi2.0.sdcard.sdcard_root_total VALUE = 7870.11
      2019-03-06 09:16:13.734 - debug: rpi2.0 ---> POST: $1/1024 for sdcard_boot_total in [object Object]
      2019-03-06 09:16:13.734 - debug: rpi2.0 VALUE: 42131 POST: $1/1024
      2019-03-06 09:16:13.735 - debug: rpi2.0 SETSTATE FOR rpi2.0.sdcard.sdcard_boot_total VALUE = 41.14
      2019-03-06 09:16:13.740 - debug: rpi2.0 ---> POST: $1/1024 for sdcard_root_used in [object Object]
      2019-03-06 09:16:13.740 - debug: rpi2.0 VALUE: 6368196 POST: $1/1024
      2019-03-06 09:16:13.741 - debug: rpi2.0 SETSTATE FOR rpi2.0.sdcard.sdcard_root_used VALUE = 6218.94
      2019-03-06 09:16:13.741 - debug: rpi2.0 ---> POST: $1/1024 for sdcard_boot_used in [object Object]
      2019-03-06 09:16:13.742 - debug: rpi2.0 VALUE: 22390 POST: $1/1024
      2019-03-06 09:16:13.742 - debug: rpi2.0 SETSTATE FOR rpi2.0.sdcard.sdcard_boot_used VALUE = 21.87
      2019-03-06 09:16:13.743 - debug: rpi2.0 CURRENT = swap true
      2019-03-06 09:16:13.744 - debug: rpi2.0 -1
      2019-03-06 09:16:13.744 - debug: rpi2.0 ---> POST: $1/1024 for swap_total in [object Object]
      2019-03-06 09:16:13.745 - debug: rpi2.0 VALUE: 1048572 POST: $1/1024
      2019-03-06 09:16:13.745 - debug: rpi2.0 SETSTATE FOR rpi2.0.swap.swap_total VALUE = 1024.00
      2019-03-06 09:16:13.746 - debug: rpi2.0 ---> POST: (rpi.swap_total - $1)/1024 for swap_used in [object Object]
      2019-03-06 09:16:13.746 - debug: rpi2.0 VALUE: 762672 POST: (rpi.swap_total - $1)/1024
      2019-03-06 09:16:13.747 - debug: rpi2.0 SETSTATE FOR rpi2.0.swap.swap_used VALUE = 279.20
      2019-03-06 09:16:13.748 - debug: rpi2.0 CURRENT = temperature true
      2019-03-06 09:16:13.752 - debug: rpi2.0 -1
      2019-03-06 09:16:13.753 - debug: rpi2.0 ---> POST: $1/1000 for soc_temp in [object Object]
      2019-03-06 09:16:13.753 - debug: rpi2.0 VALUE: 47236 POST: $1/1000
      2019-03-06 09:16:13.754 - debug: rpi2.0 SETSTATE FOR rpi2.0.temperature.soc_temp VALUE = 47.24
      2019-03-06 09:16:13.754 - debug: rpi2.0 CURRENT = uptime true
      2019-03-06 09:16:13.755 - debug: rpi2.0 -1
      2019-03-06 09:16:13.756 - debug: rpi2.0 ---> POST: for uptime in [object Object]
      2019-03-06 09:16:13.756 - debug: rpi2.0 SETSTATE FOR rpi2.0.uptime.uptime VALUE = 677.80
      2019-03-06 09:16:13.757 - debug: rpi2.0 CURRENT = wlan true
      2019-03-06 09:16:13.757 - debug: rpi2.0 -1
      2019-03-06 09:16:13.758 - debug: rpi2.0 ---> POST: $1*-1 for wifi_received in [object Object]
      2019-03-06 09:16:13.758 - debug: rpi2.0 VALUE: 4194354 POST: $1*-1
      2019-03-06 09:16:13.759 - debug: rpi2.0 SETSTATE FOR rpi2.0.wlan.wifi_received VALUE = -4194354
      2019-03-06 09:16:13.759 - debug: rpi2.0 ---> POST: for wifi_send in [object Object]
      2019-03-06 09:16:13.760 - debug: rpi2.0 SETSTATE FOR rpi2.0.wlan.wifi_send VALUE = 2306717
      2019-03-06 09:16:13.760 - debug: rpi2.0 CURRENT = gpios undefined
      2019-03-06 09:16:13.766 - debug: rpi2.0 -1
      2019-03-06 09:16:13.870 - debug: rpi2.0 stateChange for rpi2.0.cpu.load1 found state = {"val":"1.04","ack":true,"ts":1551860173707,"q":0,"from":"system.adapter.rpi2.0","lc":1551860173707}
      2019-03-06 09:16:13.874 - debug: rpi2.0 stateChange for rpi2.0.cpu.load5 found state = {"val":"1.27","ack":true,"ts":1551860173847,"q":0,"from":"system.adapter.rpi2.0","lc":1551860173847}
      2019-03-06 09:16:13.875 - debug: rpi2.0 stateChange for rpi2.0.cpu.load15 found state = {"val":"0.83","ack":true,"ts":1551860173849,"q":0,"from":"system.adapter.rpi2.0","lc":1551860173849}
      2019-03-06 09:16:13.876 - debug: rpi2.0 stateChange for rpi2.0.cpu.scaling_governor found state = {"val":"ondemand","ack":true,"ts":1551860173854,"q":0,"from":"system.adapter.rpi2.0","lc":1551860119837}
      2019-03-06 09:16:13.881 - debug: rpi2.0 stateChange for rpi2.0.memory.memory_total found state = {"val":"976.74","ack":true,"ts":1551860173856,"q":0,"from":"system.adapter.rpi2.0","lc":1551860119838}
      2019-03-06 09:16:13.883 - debug: rpi2.0 stateChange for rpi2.0.memory.memory_free found state = {"val":"52.82","ack":true,"ts":1551860173856,"q":0,"from":"system.adapter.rpi2.0","lc":1551860173856}
      2019-03-06 09:16:13.884 - debug: rpi2.0 stateChange for rpi2.0.memory.memory_available found state = {"val":101,"ack":true,"ts":1551860173857,"q":0,"from":"system.adapter.rpi2.0","lc":1551860173857}
      2019-03-06 09:16:13.885 - debug: rpi2.0 stateChange for rpi2.0.network.net_received found state = {"val":-5844530,"ack":true,"ts":1551860173858,"q":0,"from":"system.adapter.rpi2.0","lc":1551860173858}
      2019-03-06 09:16:13.887 - debug: rpi2.0 stateChange for rpi2.0.network.net_send found state = {"val":7502954,"ack":true,"ts":1551860173864,"q":0,"from":"system.adapter.rpi2.0","lc":1551860173864}
      2019-03-06 09:16:13.916 - debug: rpi2.0 stateChange for rpi2.0.sdcard.sdcard_root_total found state = {"val":"7870.11","ack":true,"ts":1551860173866,"q":0,"from":"system.adapter.rpi2.0","lc":1551860119841}
      2019-03-06 09:16:13.917 - debug: rpi2.0 stateChange for rpi2.0.sdcard.sdcard_boot_total found state = {"val":"41.14","ack":true,"ts":1551860173867,"q":0,"from":"system.adapter.rpi2.0","lc":1551860119842}
      2019-03-06 09:16:13.918 - debug: rpi2.0 stateChange for rpi2.0.sdcard.sdcard_root_used found state = {"val":"6218.94","ack":true,"ts":1551860173868,"q":0,"from":"system.adapter.rpi2.0","lc":1551860173868}
      2019-03-06 09:16:13.918 - debug: rpi2.0 stateChange for rpi2.0.sdcard.sdcard_boot_used found state = {"val":"21.87","ack":true,"ts":1551860173869,"q":0,"from":"system.adapter.rpi2.0","lc":1551860119843}
      2019-03-06 09:16:13.919 - debug: rpi2.0 stateChange for rpi2.0.swap.swap_total found state = {"val":"1024.00","ack":true,"ts":1551860173869,"q":0,"from":"system.adapter.rpi2.0","lc":1551860119844}
      2019-03-06 09:16:13.919 - debug: rpi2.0 stateChange for rpi2.0.swap.swap_used found state = {"val":"279.20","ack":true,"ts":1551860173870,"q":0,"from":"system.adapter.rpi2.0","lc":1551860173870}
      2019-03-06 09:16:13.920 - debug: rpi2.0 stateChange for rpi2.0.temperature.soc_temp found state = {"val":"47.24","ack":true,"ts":1551860173871,"q":0,"from":"system.adapter.rpi2.0","lc":1551860173871}
      2019-03-06 09:16:13.920 - debug: rpi2.0 stateChange for rpi2.0.uptime.uptime found state = {"val":"677.80","ack":true,"ts":1551860173872,"q":0,"from":"system.adapter.rpi2.0","lc":1551860173872}
      2019-03-06 09:16:13.921 - debug: rpi2.0 stateChange for rpi2.0.wlan.wifi_received found state = {"val":-4194354,"ack":true,"ts":1551860173873,"q":0,"from":"system.adapter.rpi2.0","lc":1551860173873}
      2019-03-06 09:16:13.922 - debug: rpi2.0 stateChange for rpi2.0.wlan.wifi_send found state = {"val":2306717,"ack":true,"ts":1551860173874,"q":0,"from":"system.adapter.rpi2.0","lc":1551860173874}
      AlCalzone Homoran 2 Replies Last reply Reply Quote 0
      • AlCalzone
        AlCalzone Developer @Dr. Bakterius last edited by
        @Dr-Bakterius Kannst du mal folgenden Fork des RPI2-Adapters von Github installieren? Da scheint ein Fix für dein Problem enthalten zu sein:
        Installation aus eigener Quelle -> https://github.com/asgothian/ioBroker.rpi2/tarball/master
        • Dr. Bakterius
          Dr. Bakterius Most Active @AlCalzone last edited by
          @AlCalzone Ändert leider nichts. ☹
          • AlCalzone
            Adapter-Upload und -Neustart durchgeführt? Würde mich schwer wundern, wenn der Fehler exakt identisch ist, da das Kommando ganz anders aussieht.
            • Dr. Bakterius
              @AlCalzone Upload und Neustart natürlich durchgeführt.
              Ich habe kein Log erstellt, aber es kam auch diesmal wieder:
              No Value found for mem_gpu
              No Value found for mem_arm
              No Value found for cpu_voltage
              Man muss in den Instanzen-Einstellungen 'CPU' und 'Raspberry' deaktivieren um diese Fehler zu eliminieren.
                Homoran Global Moderator Administrators @Dr. Bakterius last edited by
                @Dr-Bakterius sagte in Diskussion zum neuen Installation-Fixer:
                Das ist leider so.
                Da haben wir viel dran herumprobiert,aber es geht definitiv nicht.
                Es gäbe eine Möglichkeit diese Problem von Linux (!) zu umgehen, das hält aber nur bis zum nächsten reboot.
                Linux (und damit Raspbian) haben den Zugriff auf cpu-frequency (auch lesend) verboten. Nur noch der echte Root kann das.
                • Dr. Bakterius
                  Dr. Bakterius Most Active @Homoran last edited by
                  @Homoran Danke für die Info. Für mich nicht tragisch, aber ein Hinweis hätte mir (und vielleicht auch anderen) einiges an Zeit erspart...
                    @Dr-Bakterius
                    Sorry - ich hatte darüber (auch auf anderen Kanaälen) geschrieben, dass ich mir sicher war es auch hier im Forum geschrieben zu haben.
                    ich könnte ja mal suchen 😉 ...
                      sigi234 Forum Testing Most Active last edited by sigi234
                      Mal ein Vorteil von Windows....mit Node Red.
                      Wobei die CPU Temperatur mir zu wenig vorkommt.....
                      • Dr. Bakterius
                        @Homoran Ganz verwirrend war da natürlich die Meldung von @apollon77. Er schrieb hier:
                        Neue Version 2019-03-03 vom Installations-Fixer erlaubt dem iobroker User jetzt den Zugriff auf die rpi2 Kommandos... sollte jetzt tun.
                        Noch etwas ist mir aufgefallen: Mit dem 'exec'-Blockly-Modul können keine Befehle mehr als 'sudo' ausgeführt werden. Das macht diverse Systemaufrufe umständlich (über bash-Skripte) oder gar unmöglich. Gibt es dafür eine Lösung?
                        • Dr. Bakterius
                          Dr. Bakterius Most Active @sigi234 last edited by
                          @sigi234 sagte in Diskussion zum neuen Installation-Fixer:
                          Hast du auch bei rpi2.0.wlan.wifi_received ein MINUS davor?
                          Ja, ist aber nicht unlogisch. Kann jetzt gar nicht sagen wie es davor war.
                          • AlCalzone
                            Ja, welche Systemaufrufe sind nötig?
                            • Dr. Bakterius
                              @AlCalzone Ich frage z.B. die Ordnergröße meiner Datenbank per Skript ab. Dazu verwende ich folgenden Befehl:
                              sudo du -h /var/lib/mysql/iobroker
                              Seit dem Fixer bekomme ich kein Ergebnis mehr weil 'sudo' offensichtlich nicht mehr klappt. Ohne 'sudo' will 'du' in diesem Ordner aber auch nicht.
                              • AlCalzone
                                @Dr-Bakterius Das bekommen wir gelöst. Musst nur wenn es eingebaut ist, den neuesten Fixer nochmal ausführen. Poste mal eine Liste mit allen Befehlen, dann schaue ich was davon "safe" für den allgemeinen Gebrauch ist.
                                df ist z.B. schon erlaubt.
                                Dr. Bakterius ? 2 Replies Last reply Reply Quote 0
                                • Dr. Bakterius
                                  @AlCalzone Meine Liste ist schon komplett. 😉 Derzeit verwende ich nur diesen Befehl. Aber vielleicht haben andere auch ein ähnliches Problem - dann bitte hier posten!
                                    A Former User @AlCalzone last edited by
                                    @AlCalzone ich verwende in einem Javascript mv um das Backup zu kopieren..dazu hat er seit dem fixer ( vor zwei Wochen drüber laufen lassen) keine Rechte mehr.
                                    • AlCalzone
                                      AlCalzone Developer @Guest last edited by
                                      @ilovegym Von wo nach wo kopierst du? Wie sehen die Berechtigungen dieser Dateien/Ordner aus? ls -la
                                        @AlCalzone vergiss es, hab selbst vergessen, dass ich ja den fixer drueber hab laufen lassen und er jetzt unter anderem Namen kopiert, den gabs beim NAS natuerlich nicht ... User auf dem Nas angelegt, jetzt gehts.
                                        • Steff
                                          Steff last edited by
                                          Wollte mal danke sagen!
                                          Habe das Installation-Fixer Script in der Version vom 06.03.2019 heute angewendet und muss sagen das es ohne Probleme durchgelaufen ist.
                                          Gruß Steffen
                                          • Steff
                                            Hab nun doch noch eine Kleinigkeit.
                                            Auf meinem IntelNUC auf dem ioBroker rennt habe ich TeamViewer laufen. Den TV habe ich vor dem Fixer per bash-Script und exec-Aufruf neu starten können (falls sich TV einmal aufhängen würde) dies funktioniert nun nicht mehr mangels Berechtigung - oder ich sehe den Wald vor lauter Bäumen nicht! Was müsste ich ändern damit das wieder geht, evtl. ist das mit dem basc-Script ja viel zu kompliziert.
                                            Hier das bash-Script:
                                            #!/bin/bash
                                            # teamviewer_restart.sh
                                            # Neustart des TeamViewer daemons
                                            # chmod +x
                                            sleep 2
                                            sudo teamviewer daemon stop
                                            sleep 5
                                            sudo teamviewer daemon start
                                            sleep 2
                                            exit 0
                                            Und hier der exec-Aufruf aus dem ioBroker Script:
                                            	exec('bash /opt/iobroker/teamviewer_restart.sh', function (error, stdout, stderr) {
                                            		log('stdout: ' + stdout);
                                            Gruß Steffen
                                            fixer installation linux
                                            51
                                            296
                                            48596
