    4. ioBroker.upnp - please test
    • I
      I-Punkt last edited by I-Punkt
      bei mir scheint die Version 1.0.7 doch noch nicht so rund zu laufen. Nach der Installation lief alles erstmal gut. Dann tauchte im Abstand von 30 min folgende Warnung auf:
      2019-03-05 16:57:52.717 - info: upnp.0 Found new device: http://0.0.0.0/upnp/basic_dev.cgi
      2019-03-05 16:57:53.018 - warn: upnp.0 Error: Error: Invalid character in entity name
      Line: 81
      Column: 88
      Char: =
      Dann kam aber noch folgendes hinzu ...
      2019-03-05 17:14:41.379 - info: upnp.0 Found new device: http://192.168.2.1:49000/igddesc.xml
      2019-03-05 17:14:47.881 - error: uncaught exception: Maximum call stack size exceeded
      2019-03-05 17:14:47.882 - error: RangeError: Maximum call stack size exceeded
      at Sender.frameAndSend (/opt/iobroker/node_modules/ws/lib/Sender.js:139:41)
      at /opt/iobroker/node_modules/ws/lib/Sender.js:126:12
      at Sender.applyExtensions (/opt/iobroker/node_modules/ws/lib/Sender.js:287:5)
      at /opt/iobroker/node_modules/ws/lib/Sender.js:120:10
      at Sender.flush (/opt/iobroker/node_modules/ws/lib/Sender.js:268:3)
      at /opt/iobroker/node_modules/ws/lib/Sender.js:270:10
      at /opt/iobroker/node_modules/ws/lib/Sender.js:127:7
      2019-03-05 17:14:47.884 - info: iobroker _restart
      2019-03-05 17:14:48.288 - info: iobroker Starting node restart.js
      2019-03-05 17:14:48.302 - info: iobroker exit 0
      2019-03-05 17:14:50.466 - info: host.ioBroker iobroker.js-controller version 1.5.7 js-controller starting
      2019-03-05 17:14:50.474 - info: host.ioBroker Copyright (c) 2014-2018 bluefox, 2014 hobbyquaker
      2019-03-05 17:14:50.475 - info: host.ioBroker hostname: ioBroker, node: v8.15.0
      2019-03-05 17:14:50.478 - info: host.ioBroker ip addresses: 192.168.2.27 2003:ce:9f15:c200:211:32ff:fe59:cb8d fe80::211:32ff:fe59:cb8d
      2019-03-05 17:14:50.598 - info: host.ioBroker inMem-states listening on port 9000
      2019-03-05 17:14:51.430 - info: host.ioBroker inMem-objects listening on port 9001
      2019-03-05 17:14:51.442 - info: host.ioBroker InMemoryDB connected
      2019-03-05 17:14:51.490 - info: host.ioBroker 41 instances found
      2019-03-05 17:14:51.520 - info: host.ioBroker starting 28 instances
      2019-03-05 17:14:51.628 - info: host.ioBroker instance system.adapter.admin.0 started with pid 12481
      2019-03-05 17:14:54.905 - info: admin.0 starting. Version 3.6.0 in /opt/iobroker/node_modules/iobroker.admin, node: v8.15.0
      ...und der iobroker ging von allein in den Restart.
      Iobroker läuft bei mir im Docker auf einer Synology. Seit Tagen keine Fehler o.ä., so daß ich denke, daß es am frisch installierten UPNP-Adapter liegt.
      • Bluefox
        Bluefox last edited by
        Участник @I-Punkt написал в ioBroker.upnp - please test:
        Kannst du diese Datei teilen?
        • I
          I-Punkt @Bluefox last edited by
          @Bluefox
          igddesc.xml
          • JohGre
            JohGre last edited by
            Hab jetzt die 1.0.8 installiert und bekommen folgendes warnings
            2019-03-07 06:57:55.964 - info: host.ioBroker instance system.adapter.upnp.0 started with pid 4784
            2019-03-07 06:57:59.727 - warn: upnp.0 Error: Error: Text data outside of root node.
            Line: 0
            Column: 44
            Char: \
            2019-03-07 06:57:59.785 - warn: upnp.0 Error: Error: Text data outside of root node.
            Line: 0
            Column: 22
            Char: \
            2019-03-07 06:58:00.521 - warn: upnp.0 Error: Error: Text data outside of root node.
            Line: 0
            Column: 22
            Char: \
            2019-03-07 06:58:55.662 - info: host.ioBroker object change system.adapter.upnp.0
            2019-03-07 06:58:55.665 - info: host.ioBroker stopInstance system.adapter.upnp.0
            2019-03-07 06:58:55.665 - info: host.ioBroker stopInstance system.adapter.upnp.0 killing pid 4784
            2019-03-07 06:58:55.718 - info: host.ioBroker instance system.adapter.upnp.0 terminated with code 0 (OK)
            2019-03-07 06:58:58.208 - info: host.ioBroker instance system.adapter.upnp.0 started with pid 4857
            2019-03-07 06:59:01.570 - warn: upnp.0 Error: Error: Text data outside of root node.
            Line: 0
            Column: 44
            Char: \
            2019-03-07 06:59:01.592 - warn: upnp.0 Error: Error: Text data outside of root node.
            Line: 0
            Column: 22
            Char: \
            2019-03-07 06:59:04.253 - warn: upnp.0 Error: Error: Text data outside of root node.
            Line: 0
            Column: 22
            Char: \
            und es werden auch keine Objekte angelegt.
            Bluefox 1 Reply Last reply Reply Quote 0
            • Bluefox
              Bluefox @JohGre last edited by
              @JohGre probiere 1.0.9
              JohGre 1 Reply Last reply Reply Quote 0
              • JohGre
                JohGre @Bluefox last edited by
                @Bluefox sagte in ioBroker.upnp - please test:
                Läuft nun
                • I
                  Danke erstmal an Bluefox für die Unterstützung!
                  Habe auch die 1.0.10 installiert und bekomme noch folgende Fehler:
                  2019-03-07 07:59:54.284 - info: upnp.0 Auto discover: true
                  2019-03-07 07:59:55.524 - warn: upnp.0 Error: Error: Invalid character in tag name
                  Line: 183
                  Column: 20
                  Char: &
                  2019-03-07 07:59:55.624 - warn: upnp.0 Error: Error: Invalid character in tag name
                  Line: 183
                  Column: 20
                  Char: &
                  2019-03-07 08:01:12.961 - info: upnp.0 Found new device: http://0.0.0.0/upnp/basic_dev.cgi
                  2019-03-07 08:01:13.251 - warn: upnp.0 Error: Error: Invalid attribute name
                  Line: 3
                  Column: 11
                  Char: &
                  2019-03-07 08:01:14.167 - info: upnp.0 Found new device: http://192.168.2.51:1400/xml/device_description.xml
                  2019-03-07 08:01:14.203 - warn: upnp.0 Error: Error: Invalid character in tag name
                  Line: 183
                  Column: 20
                  Char: &
                  2019-03-07 08:01:14.420 - info: upnp.0 Found new device: http://192.168.2.51:1400/xml/device_description.xml
                  2019-03-07 08:01:14.466 - warn: upnp.0 Error: Error: Invalid character in tag name
                  Line: 183
                  Column: 20
                  Char: &
                  2019-03-07 08:01:14.669 - info: upnp.0 Found new device: http://192.168.2.51:1400/xml/device_description.xml
                  2019-03-07 08:01:14.690 - warn: upnp.0 Error: Error: Invalid character in tag name
                  Line: 183
                  Column: 20
                  Char: &
                  Ergänzung:
                  Abgesehen von den Meldungen und den (dadurch?) nicht gefundenen Sonos scheint es aber zu funktionieren.
                  • I
                    1.0.11 läuft hier jetzt problemlos. Danke!
                    • Neuschwansteini
                      Neuschwansteini last edited by
                      @Bluefox
                      2019-03-08 05:47:26.601  - info: upnp.0 starting. Version 1.0.11 in /opt/iobroker/node_modules/iobroker.upnp, node: v8.15.0
                      2019-03-08 05:47:26.620  - info: upnp.0 Auto discover: true
                      2019-03-08 05:48:21.158  - warn: upnp.0 Error sending SOAP request: Error: connect EHOSTUNREACH 192.168.178.82:1079
                      2019-03-08 05:49:03.400  - warn: upnp.0 Unexpected answer from upnp service: {"statusCode":500,"body":"<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s:Body>\n<s:Fault>\n<faultcode>s:Client</faultcode>\n<faultstring>UPnPError</faultstring>\n<detail>\n<UPnPError xmlns=\"urn:schemas-upnp-org:control-1-0\">\n<errorCode>401</errorCode>\n<errorDescription>invalid action</errorDescription>\n</UPnPError>\n</detail>\n</s:Fault>\n</s:Body>\n</s:Envelope>","headers":{"date":"Fri, 08 Mar 2019 04:49:03 GMT","server":"FRITZ!Box 7590 UPnP/1.0 AVM FRITZ!Box 7590 154.07.01","connection":"close","content-length":"433","content-type":"text/xml; charset=\"utf-8\""},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"192.168.178.1:49000","port":"49000","hostname":"192.168.178.1","hash":null,"search":null,"query":null,"pathname":"/MediaServer/ServerStatus/Control","path":"/MediaServer/ServerStatus/Control","href":"http://192.168.178.1:49000/MediaServer/ServerStatus/Control"},"method":"POST","headers":{"Content-Type":"text/xml; charset=\"utf-8\"","SOAPAction":"\"urn:avm.de:service:AVM_ServerStatus:1#ScanInfo\"","USER-AGENT":"UPnP/1.0, ioBroker.upnp","content-length":234}}}
                       Sent message: {"uri":"http://192.168.178.1:49000/MediaServer/ServerStatus/Control","headers":{"Content-Type":"text/xml; charset=\"utf-8\"","SOAPAction":"\"urn:avm.de:service:AVM_ServerStatus:1#ScanInfo\"","USER-AGENT":"UPnP/1.0, ioBroker.upnp"},"method":"POST","body":"\n<s:Envelope s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\" xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\">\n    <s:Body><u:ScanInfo xmlns:u=\"urn:avm.de:service:AVM_ServerStatus:1\"></u:ScanInfo></s:Body>\n</s:Envelope>"}
                      2019-03-08 05:49:34.865  - warn: upnp.0 Unexpected answer from upnp service: {"statusCode":500,"body":"<?xml version=\"1.0\"?>\r\n<SOAP-ENV:Envelope xmlns:SOAP-ENV=\"http://schemas.xmlsoap.org/soap/envelope/\" SOAP-ENV:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\"><SOAP-ENV:Body><SOAP-ENV:Fault><faultcode>SOAP-ENV:Client</faultcode><faultstring>UPnPError</faultstring><detail><u:UPnPError xmlns:u=\"urn:schemas-upnp-org:control-1-0\"><u:errorCode>501</u:errorCode><u:errorDescription>Action Failed</u:errorDescription></u:UPnPError></detail></SOAP-ENV:Fault></SOAP-ENV:Body></SOAP-ENV:Envelope>\r\n","headers":{"content-length":"499","content-type":"text/xml; charset=\"utf-8\"","server":"Microsoft-Windows-NT/5.1 UPnP/1.0 UPnP-Device-Host/1.0 Microsoft-HTTPAPI/2.0","date":"Fri, 08 Mar 2019 04:49:06 GMT","connection":"close"},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"192.168.178.39:2869","port":"2869","hostname":"192.168.178.39","hash":null,"search":"?control=uuid:d025603c-1641-42b5-bccd-a3375e87ee37+urn:upnp-org:serviceId:ConnectionManager","query":"control=uuid:d025603c-1641-42b5-bccd-a3375e87ee37+urn:upnp-org:serviceId:ConnectionManager","pathname":"/upnphost/udhisapi.dll","path":"/upnphost/udhisapi.dll?control=uuid:d025603c-1641-42b5-bccd-a3375e87ee37+urn:upnp-org:serviceId:ConnectionManager","href":"http://192.168.178.39:2869/upnphost/udhisapi.dll?control=uuid:d025603c-1641-42b5-bccd-a3375e87ee37+urn:upnp-org:serviceId:ConnectionManager"},"method":"POST","headers":{"Content-Type":"text/xml; charset=\"utf-8\"","SOAPAction":"\"urn:schemas-upnp-org:service:ConnectionManager:1#GetProtocolInfo\"","USER-AGENT":"UPnP/1.0, ioBroker.upnp","content-length":259}}}
                       Sent message: {"uri":"http://192.168.178.39:2869/upnphost/udhisapi.dll?control=uuid:d025603c-1641-42b5-bccd-a3375e87ee37+urn:upnp-org:serviceId:ConnectionManager","headers":{"Content-Type":"text/xml; charset=\"utf-8\"","SOAPAction":"\"urn:schemas-upnp-org:service:ConnectionManager:1#GetProtocolInfo\"","USER-AGENT":"UPnP/1.0, ioBroker.upnp"},"method":"POST","body":"\n<s:Envelope s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\" xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\">\n    <s:Body><u:GetProtocolInfo xmlns:u=\"urn:schemas-upnp-org:service:ConnectionManager:1\"></u:GetProtocolInfo></s:Body>\n</s:Envelope>"}
                      2019-03-08 05:49:42.824  - warn: upnp.0 Unexpected answer from upnp service: {"statusCode":500,"body":"<?xml version=\"1.0\"?>\r\n<SOAP-ENV:Envelope xmlns:SOAP-ENV=\"http://schemas.xmlsoap.org/soap/envelope/\" SOAP-ENV:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\"><SOAP-ENV:Body><SOAP-ENV:Fault><faultcode>SOAP-ENV:Client</faultcode><faultstring>UPnPError</faultstring><detail><u:UPnPError xmlns:u=\"urn:schemas-upnp-org:control-1-0\"><u:errorCode>402</u:errorCode><u:errorDescription>Invalid Args</u:errorDescription></u:UPnPError></detail></SOAP-ENV:Fault></SOAP-ENV:Body></SOAP-ENV:Envelope>\r\n","headers":{"content-length":"498","content-type":"text/xml; charset=\"utf-8\"","server":"Microsoft-Windows-NT/5.1 UPnP/1.0 UPnP-Device-Host/1.0 Microsoft-HTTPAPI/2.0","date":"Fri, 08 Mar 2019 04:49:14 GMT","connection":"close"},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"192.168.178.39:2869","port":"2869","hostname":"192.168.178.39","hash":null,"search":"?control=uuid:d025603c-1641-42b5-bccd-a3375e87ee37+urn:upnp-org:serviceId:ConnectionManager","query":"control=uuid:d025603c-1641-42b5-bccd-a3375e87ee37+urn:upnp-org:serviceId:ConnectionManager","pathname":"/upnphost/udhisapi.dll","path":"/upnphost/udhisapi.dll?control=uuid:d025603c-1641-42b5-bccd-a3375e87ee37+urn:upnp-org:serviceId:ConnectionManager","href":"http://192.168.178.39:2869/upnphost/udhisapi.dll?control=uuid:d025603c-1641-42b5-bccd-a3375e87ee37+urn:upnp-org:serviceId:ConnectionManager"},"method":"POST","headers":{"Content-Type":"text/xml; charset=\"utf-8\"","SOAPAction":"\"urn:schemas-upnp-org:service:ConnectionManager:1#GetCurrentConnectionInfo\"","USER-AGENT":"UPnP/1.0, ioBroker.upnp","content-length":277}}}
                       Sent message: {"uri":"http://192.168.178.39:2869/upnphost/udhisapi.dll?control=uuid:d025603c-1641-42b5-bccd-a3375e87ee37+urn:upnp-org:serviceId:ConnectionManager","headers":{"Content-Type":"text/xml; charset=\"utf-8\"","SOAPAction":"\"urn:schemas-upnp-org:service:ConnectionManager:1#GetCurrentConnectionInfo\"","USER-AGENT":"UPnP/1.0, ioBroker.upnp"},"method":"POST","body":"\n<s:Envelope s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\" xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\">\n    <s:Body><u:GetCurrentConnectionInfo xmlns:u=\"urn:schemas-upnp-org:service:ConnectionManager:1\"></u:GetCurrentConnectionInfo></s:Body>\n</s:Envelope>"}
                      2019-03-08 05:50:17.177  - warn: upnp.0 Unexpected answer from upnp service: {"statusCode":500,"body":"<?xml version=\"1.0\" encoding=\"utf-8\"?><s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns=\"urn:schemas-upnp-org:control-1-0\"><errorCode>402</errorCode><errorDescription>Invalid Args</errorDescription></UPnPError></detail></s:Fault></s:Body></s:Envelope>\r\n","headers":{"content-length":"436","content-type":"text/xml; charset=\"utf-8\"","connection":"close","ext":"","server":"Canon IJ-UPnP/1.0 UPnP/1.0 UPnP-Device-Host/1.0"},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"192.168.178.29:80","port":"80","hostname":"192.168.178.29","hash":null,"search":null,"query":null,"pathname":"/upnp/control/DPSConnectionManager","path":"/upnp/control/DPSConnectionManager","href":"http://192.168.178.29:80/upnp/control/DPSConnectionManager"},"method":"POST","headers":{"Content-Type":"text/xml; charset=\"utf-8\"","SOAPAction":"\"urn:schemas-cipa-jp:service:DPSConnectionManager:1#ConnectionRequest\"","USER-AGENT":"UPnP/1.0, ioBroker.upnp","content-length":265}}}
                       Sent message: {"uri":"http://192.168.178.29:80/upnp/control/DPSConnectionManager","headers":{"Content-Type":"text/xml; charset=\"utf-8\"","SOAPAction":"\"urn:schemas-cipa-jp:service:DPSConnectionManager:1#ConnectionRequest\"","USER-AGENT":"UPnP/1.0, ioBroker.upnp"},"method":"POST","body":"\n<s:Envelope s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\" xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\">\n    <s:Body><u:ConnectionRequest xmlns:u=\"urn:schemas-cipa-jp:service:DPSConnectionManager:1\"></u:ConnectionRequest></s:Body>\n</s:Envelope>"}
                      2019-03-08 05:58:35.649  - info: upnp.0 Found new device: http://169.254.47.245:2870/dmr_bdp5510.xml
                      2019-03-08 05:58:36.178  - info: upnp.0 Found new device: http://169.254.47.245:51000/config.xml
                      2019-03-08 05:59:16.074  - info: upnp.0 Found new device: http://192.168.178.3:49000/igddesc.xml
                      2019-03-08 06:01:17.441  - info: upnp.0 Found new device: http://192.168.178.1:49000/igd2desc.xml
                      2019-03-08 06:07:14.984  - info: upnp.0 Found new device: http://192.168.178.4:49000/igd2desc.xml
                      2019-03-08 06:13:05.656  - info: upnp.0 Found new device: http://169.254.47.245:2870/dmr_bdp5510.xml
                      2019-03-08 06:13:06.203  - info: upnp.0 Found new device: http://169.254.47.245:51000/config.xml
                      2019-03-08 06:27:35.662  - info: upnp.0 Found new device: http://169.254.47.245:2870/dmr_bdp5510.xml
                      2019-03-08 06:27:36.175  - info: upnp.0 Found new device: http://169.254.47.245:51000/config.xml
                      2019-03-08 06:29:16.078  - info: upnp.0 Found new device: http://192.168.178.3:49000/igddesc.xml
                      2019-03-08 06:31:17.448  - info: upnp.0 Found new device: http://192.168.178.1:49000/igd2desc.xml
                      2019-03-08 06:32:14.060  - warn: upnp.0 Unexpected answer from upnp service: {"statusCode":500,"body":"<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s:Body>\n<s:Fault>\n<faultcode>s:Client</faultcode>\n<faultstring>UPnPError</faultstring>\n<detail>\n<UPnPError xmlns=\"urn:schemas-upnp-org:control-1-0\">\n<errorCode>401</errorCode>\n<errorDescription>invalid action</errorDescription>\n</UPnPError>\n</detail>\n</s:Fault>\n</s:Body>\n</s:Envelope>","headers":{"date":"Fri, 08 Mar 2019 05:32:14 GMT","server":"FRITZ!Box 7590 UPnP/1.0 AVM FRITZ!Box 7590 154.07.01","connection":"close","content-length":"433","content-type":"text/xml; charset=\"utf-8\""},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"192.168.178.1:49000","port":"49000","hostname":"192.168.178.1","hash":null,"search":null,"query":null,"pathname":"/MediaServer/ServerStatus/Control","path":"/MediaServer/ServerStatus/Control","href":"http://192.168.178.1:49000/MediaServer/ServerStatus/Control"},"method":"POST","headers":{"Content-Type":"text/xml; charset=\"utf-8\"","SOAPAction":"\"urn:avm.de:service:AVM_ServerStatus:1#ScanInfo\"","USER-AGENT":"UPnP/1.0, ioBroker.upnp","content-length":234}}}
                      2019-03-08 06:32:14.330  - warn: upnp.0 Unexpected answer from upnp service: {"statusCode":500,"body":"<?xml version=\"1.0\" encoding=\"utf-8\"?><s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns=\"urn:schemas-upnp-org:control-1-0\"><errorCode>402</errorCode><errorDescription>Invalid Args</errorDescription></UPnPError></detail></s:Fault></s:Body></s:Envelope>\r\n","headers":{"content-length":"436","content-type":"text/xml; charset=\"utf-8\"","connection":"close","ext":"","server":"Canon IJ-UPnP/1.0 UPnP/1.0 UPnP-Device-Host/1.0"},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"192.168.178.29:80","port":"80","hostname":"192.168.178.29","hash":null,"search":null,"query":null,"pathname":"/upnp/control/DPSConnectionManager","path":"/upnp/control/DPSConnectionManager","href":"http://192.168.178.29:80/upnp/control/DPSConnectionManager"},"method":"POST","headers":{"Content-Type":"text/xml; charset=\"utf-8\"","SOAPAction":"\"urn:schemas-cipa-jp:service:DPSConnectionManager:1#ConnectionRequest\"","USER-AGENT":"UPnP/1.0, ioBroker.upnp","content-length":265}}}
                      2019-03-08 06:39:16.071  - info: upnp.0 Found new device: http://192.168.178.3:49000/igddesc.xml
                      2019-03-08 06:41:17.440  - info: upnp.0 Found new device: http://192.168.178.1:49000/igd2desc.xml
                      2019-03-08 06:42:05.664  - info: upnp.0 Found new device: http://169.254.47.245:2870/dmr_bdp5510.xml
                      2019-03-08 06:42:06.285  - info: upnp.0 Found new device: http://169.254.47.245:51000/config.xml
                      2019-03-08 06:51:17.441  - info: upnp.0 Found new device: http://192.168.178.1:49000/igd2desc.xml
                      2019-03-08 06:56:35.676  - info: upnp.0 Found new device: http://169.254.47.245:2870/dmr_bdp5510.xml
                      2019-03-08 06:56:36.234  - info: upnp.0 Found new device: http://169.254.47.245:51000/config.xml
                      2019-03-08 06:59:16.073  - info: upnp.0 Found new device: http://192.168.178.3:49000/igddesc.xml
                      2019-03-08 07:01:17.444  - info: upnp.0 Found new device: http://192.168.178.1:49000/igd2desc.xml
                      2019-03-08 07:07:14.984  - info: upnp.0 Found new device: http://192.168.178.4:49000/igd2desc.xml
                      2019-03-08 07:11:05.723  - info: upnp.0 Found new device: http://169.254.47.245:2870/dmr_bdp5510.xml
                      2019-03-08 07:11:06.240  - info: upnp.0 Found new device: http://169.254.47.245:51000/config.xml
                      2019-03-08 07:19:16.074  - info: upnp.0 Found new device: http://192.168.178.3:49000/igddesc.xml
                      2019-03-08 07:25:35.681  - info: upnp.0 Found new device: http://169.254.47.245:2870/dmr_bdp5510.xml
                      2019-03-08 07:25:36.230  - info: upnp.0 Found new device: http://169.254.47.245:51000/config.xml
                      2019-03-08 07:29:16.072  - info: upnp.0 Found new device: http://192.168.178.3:49000/igddesc.xml
                      2019-03-08 07:30:00.722  - warn: upnp.0 Unexpected answer from upnp service: {"statusCode":500,"body":"<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s:Body>\n<s:Fault>\n<faultcode>s:Client</faultcode>\n<faultstring>UPnPError</faultstring>\n<detail>\n<UPnPError xmlns=\"urn:schemas-upnp-org:control-1-0\">\n<errorCode>401</errorCode>\n<errorDescription>invalid action</errorDescription>\n</UPnPError>\n</detail>\n</s:Fault>\n</s:Body>\n</s:Envelope>","headers":{"date":"Fri, 08 Mar 2019 06:30:00 GMT","server":"FRITZ!Box 7590 UPnP/1.0 AVM FRITZ!Box 7590 154.07.01","connection":"close","content-length":"433","content-type":"text/xml; charset=\"utf-8\""},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"192.168.178.1:49000","port":"49000","hostname":"192.168.178.1","hash":null,"search":null,"query":null,"pathname":"/MediaServer/ServerStatus/Control","path":"/MediaServer/ServerStatus/Control","href":"http://192.168.178.1:49000/MediaServer/ServerStatus/Control"},"method":"POST","headers":{"Content-Type":"text/xml; charset=\"utf-8\"","SOAPAction":"\"urn:avm.de:service:AVM_ServerStatus:1#ScanInfo\"","USER-AGENT":"UPnP/1.0, ioBroker.upnp","content-length":234}}}
                      2019-03-08 07:30:00.984  - warn: upnp.0 Unexpected answer from upnp service: {"statusCode":500,"body":"<?xml version=\"1.0\" encoding=\"utf-8\"?><s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns=\"urn:schemas-upnp-org:control-1-0\"><errorCode>402</errorCode><errorDescription>Invalid Args</errorDescription></UPnPError></detail></s:Fault></s:Body></s:Envelope>\r\n","headers":{"content-length":"436","content-type":"text/xml; charset=\"utf-8\"","connection":"close","ext":"","server":"Canon IJ-UPnP/1.0 UPnP/1.0 UPnP-Device-Host/1.0"},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"192.168.178.29:80","port":"80","hostname":"192.168.178.29","hash":null,"search":null,"query":null,"pathname":"/upnp/control/DPSConnectionManager","path":"/upnp/control/DPSConnectionManager","href":"http://192.168.178.29:80/upnp/control/DPSConnectionManager"},"method":"POST","headers":{"Content-Type":"text/xml; charset=\"utf-8\"","SOAPAction":"\"urn:schemas-cipa-jp:service:DPSConnectionManager:1#ConnectionRequest\"","USER-AGENT":"UPnP/1.0, ioBroker.upnp","content-length":265}}}
                      2019-03-08 07:40:05.686  - info: upnp.0 Found new device: http://169.254.47.245:2870/dmr_bdp5510.xml
                      2019-03-08 07:40:06.201  - info: upnp.0 Found new device: http://169.254.47.245:51000/config.xml
                      2019-03-08 07:41:17.451  - info: upnp.0 Found new device: http://192.168.178.1:49000/igd2desc.xml
                      2019-03-08 07:49:16.074  - info: upnp.0 Found new device: http://192.168.178.3:49000/igddesc.xml
                      2019-03-08 07:54:36.949  - info: upnp.0 Found new device: http://169.254.47.245:2870/dmr_bdp5510.xml
                      2019-03-08 07:54:36.957  - info: upnp.0 Found new device: http://169.254.47.245:51000/config.xml
                      2019-03-08 07:59:16.077  - info: upnp.0 Found new device: http://192.168.178.3:49000/igddesc.xml
                      2019-03-08 08:01:17.440  - info: upnp.0 Found new device: http://192.168.178.1:49000/igd2desc.xml
                      • Bluefox
                        Bluefox @Neuschwansteini last edited by
                        @ilovegym 401 Error weist auf Authentifizierungproblem bei Fritzbox zu.
                        Keine Ahnung wie es richtig sein soll
                        Neuschwansteini 1 Reply Last reply Reply Quote 0
                        • Neuschwansteini
                          Neuschwansteini @Bluefox last edited by
                          @Bluefox ah, okay, also bei den Fritzboxen ( hab 4 und ein Repeater ) da funktioniert ja alles, soweit ich das sehe. ( oder das, was ich davon brauche)
                          Bei anderen Geraeten gibts keine Antwort, also beim Canon-Drucker, da werden Verzeichnisse angelegt und ein Request-Button, aber passieren tut nix.
                          Gleiches beim LG TV, jede Menge Verzeichnisse aber keine Antwort.
                          Bluefox 2 Replies Last reply Reply Quote 0
                          • Bluefox
                            @ilovegym zu FritzBoxen
                            https://kb.paessler.com/en/topic/59909-fritz-box-sensor-shows-401
                            • Bluefox
                              Bluefox @Neuschwansteini last edited by Bluefox
                              @ilovegym gab was früher bei LG drin?
                              Ich habe den Adapter nicht entwickelt, sondern nur modifiziert so, dass der nicht zu viele parallele Requests sendet
                              • SBorg
                                Außer in der FritzBox habe ich eigentlich nirgends etwas verwertbares drin.
                                • I
                                  same here. War aber auch noch nie anders bei mir. Sonos, Hisense, LG .... werden gefunden, zeigen aber in den Objekten nix bzw. nur sehr wenig an und lassen sich auch nicht steuern.
                                  • Neuschwansteini
                                    @Bluefox ich weiss, verfolge auf Git so einiges 🙂
                                    Nee, war noch nie was bei LG drin, den LG hat er auch erst seit Version 1.0.3 oder so gefunden..
                                      Ja, das ist bei mir auch so.
                                      Meine Meinung und Beobachtungen:
                                      Die FritzBox zeigt die Werte an weil es ja erlaubt wurde (in der FritzBox upnp erlauben angehakt) und diese auch zur Verfügung stellt.
                                      Angezeigt wird auch nur was wenn auch ein Stream statt findet und es auf dem jeweiligen Gerät erlaubt bzw. vorgesehen ist.
                                      • Neuschwansteini
                                        @Bluefox nach einem Reboot der Fritzboxen sind mehr Einträge, die ausgewertet werden können.
                                        Hatte schon lange keinen Reboot der ganzen Router gemacht, musste jetzt aber, weil die IP-Range Zuhause voll 🤦 war und ich jetzt mit Subnetting erweitert hab... 🤷
                                        • SBorg
                                          Schade, eben läuft mein Log voll, kommen stellenweise im ms-Takt...
                                          Sind aber nur die beiden Geräte.
                                          upnp.0	2019-03-08 20:25:31.877	warn	Subscription error: {"errno":"ECONNREFUSED","code":"ECONNREFUSED","syscall":"connect","address":"192.168.1.221","port":1137}
                                          upnp.0	2019-03-08 20:25:31.876	warn	Subscription error: {"errno":"ECONNREFUSED","code":"ECONNREFUSED","syscall":"connect","address":"192.168.1.221","port":1137}
                                          upnp.0	2019-03-08 20:25:31.875	warn	Subscription error: {"errno":"ECONNREFUSED","code":"ECONNREFUSED","syscall":"connect","address":"192.168.1.221","port":1137}
                                          upnp.0	2019-03-08 20:25:31.873	warn	Subscription error: {"errno":"ECONNREFUSED","code":"ECONNREFUSED","syscall":"connect","address":"192.168.1.221","port":1137}
                                          upnp.0	2019-03-08 20:24:05.345	warn	Subscription error: {"errno":"ECONNREFUSED","code":"ECONNREFUSED","syscall":"connect","address":"192.168.1.120","port":40894}
                                          upnp.0	2019-03-08 20:24:05.344	warn	Subscription error: {"errno":"ECONNREFUSED","code":"ECONNREFUSED","syscall":"connect","address":"192.168.1.120","port":40894}
                                          upnp.0	2019-03-08 20:24:05.343	warn	Subscription error: {"errno":"ECONNREFUSED","code":"ECONNREFUSED","syscall":"connect","address":"192.168.1.120","port":40894}
                                          • Bluefox
                                            Ich sehe nichts mehr, was ich noch verbessern kann. Ich würde die Entwicklung jetzt abschließen und an Author den Adapter übergeben.
                                            Da den Fehler mit max_call stack nicht mehr da ist.
                                            Neuschwansteini 1 Reply Last reply Reply Quote 3
                                            31.7k
                                            79.8k
                                            adapter test
                                            18
                                            196
                                            19480
