    4. [Aufruf] ZigBee CC253x Adapter 0.9
      @Saiz
      wenn du das so machst musst du den manuell dazu adden
        Saiz @arteck last edited by Saiz
        @arteck
        Gibt es ein Tutorial wie man das manuell hinzufügt? Sorry bin ganz frisch im iobroker
        Ahh habe ich selber gefunden. Das ist mit dem Punkt "Upload" gemeint.
        Screenshots
        Ich kriege dabei aber einen Fehler:
        system.adapter.zigbee does not exist
        upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/admin.js admin.js application/javascript
        upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/de/translations.json i18n/de/translations.json application/json
        upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/en/translations.json i18n/en/translations.json application/json
        upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/es/translations.json i18n/es/translations.json application/json
        upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
        upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/it/translations.json i18n/it/translations.json application/json
        upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
        upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
        upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
        upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
        upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
        upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86plug.png img/86plug.png image/png
        upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw1.png img/86sw1.png image/png
        upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw2.png img/86sw2.png image/png
        upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Eurotronic_Spirit_04.png img/Eurotronic_Spirit_04.png image/png
        upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/FLOALT.panel.WS.png img/FLOALT.panel.WS.png image/png
        upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TRADFRI.bulb.E27.png img/TRADFRI.bulb.E27.png image/png
        upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TRADFRI.remote.control.png img/TRADFRI.remote.control.png image/png
        upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/aqara.switch.png img/aqara.switch.png image/png
        upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/aqara_bulb.png img/aqara_bulb.png image/png
        upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/aqara_numan_body_sensor.png img/aqara_numan_body_sensor.png image/png
        upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/cube.png img/cube.png image/png
        upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/gledopto_bulb.png img/gledopto_bulb.png image/png
        upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/innr.png img/innr.png image/png
        upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lightify-plug.png img/lightify-plug.png image/png
        upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/osram_ceiling_tw.png img/osram_ceiling_tw.png image/png
        upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_lightbar.png img/philips_hue_lightbar.png image/png
        upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/sensor_ht.png img/sensor_ht.png image/png
        upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/tradfri-control-outlet.png img/tradfri-control-outlet.png image/png
        got /opt/iobroker/node_modules/iobroker.zigbee/admin
        upload zigbee
          Sinalco @Saiz last edited by
          @Saiz Du musst dann manuell eine Instanz anlegen:
            Saiz last edited by Saiz
            Super vielen Dank, jetzt ist es drin. Meine Lampe ist jetzt auch verbunden. Aber leider die gleichen Probleme wie mit dem Original Adapter. Lampe geht einfach aus wenn man irgendwas schickt:
            zigbee.0 error Zigbee publish to '0x00158d000360455a', genLevelCtrl - moveToLevelWithOnOff - {"level":0,"transtime":0} - 1 failed with error Error: AF data request fails, status code: 233. MAC no ack.
            zigbee.0 error Zigbee publish to '0x00158d000360455a', lightingColorCtrl - moveToColorTemp - {"colortemp":0,"transtime":0} - 1 failed with error Error: AF data request fails, status code: 233. MAC no ack.
            zigbee.0 error Zigbee publish to '0x00158d000360455a', lightingColorCtrl - moveToColorTemp - {"colortemp":390,"transtime":0} - 1 failed with error Error: Timed out after 30000 ms
            zigbee.0 error No state available for '404000/404005/404012' with key 'groups'
            zigbee.0 error Zigbee publish to '0x00158d000360455a', lightingColorCtrl - moveToColor - {"transtime":0,"colorx":45914,"colory":19615} - 1 failed with error Error: AF data request fails, status code: 233. MAC no ac
            zigbee.0 error Zigbee publish to '0x00158d000360455a', genLevelCtrl - moveToLevelWithOnOff - {"level":381,"transtime":0} - 1 failed with error TypeError: "value" argument is out of bounds
            Link quality steht bei 28 ... könnte das, das Problem sein?
              flubb last edited by flubb
              habe leider auch das Problem das meine GU10-Tradfri nicht mehr richtig funktioniert.
              Habe jetzt schon vieles ausprobiert aber ich komme leider nicht wirklich weiter. Installiert ist aktuell das Repo von Arteck und auf dem CC2531 ist die Firmware vom 23.02.19:
              2019-03-09 22:20:49.244 - info: zigbee.0 zigbee-shepherd ready. version: 2.6.3 rev 20190223
              2019-03-09 22:20:49.244 - info: zigbee.0 arteck sonderversion zigbee-shepherd 7.1.3
              In dieser Kombination geht die Lampe sogar kurz an sobald ich "Brightness" ansteuere, leider geht sie dann jedoch sofort wieder aus. Die Objekte im iobroker (Brightness & Switch state) bleiben jedoch so als ob die Lampe an wäre.
              Im log taucht zeitweise folgendes immer wieder auf:
              error
              Zigbee publish to '0x000b57fffed83611', genLevelCtrl - moveToLevelWithOnOff - {"level":0,"transtime":0} - 1 failed with error Error: AF data request fails, status code: 233. MAC no ack.
              Wie finde ich denn die shepherd-converter Version heraus?
              Ansonsten jmd. eine Idee was ich machen könnte? Habe sogar bereits ein Full-Backup von letzter Woche eingespielt, als die Lampe noch funktionierte, jedoch hat das auch nicht geholfen 😞
              Oder ist vielleicht meine Tradfri-Birne kaputt? Ist leider die einzige bei mir, somit kann ich hier natürlich einen Defekt auch nicht zu 100% ausschließen...
                Saiz @flubb last edited by
                @flubb
                Wie weit ist der Stick von der Lampe entfernt? Ich hatte die gleiche Fehlermeldung. Die link Qualität war bei 25. Habe die Lampe näher gestellt und dann ging es.
                  @Saiz ja Link Qualität ist nur um die 20. ok, dann kommen die Fehlermeldungen wohl wenn die Lampe nicht erreichbar ist. Teilweise scheint es aber ja zu gehen, wie gesagt, die LEDs gehen kurz an. Habe es sicherheitshalber aber gerade auch mal direkt neben dem Stick probiert, da geht die Lampe auch nur kurz an und dann wieder aus 😞
                    der PR ist noch nicht durch deshalb bekommst du die Lampe nicht an
                    nimm mal bis dahin mein repo
                    https://github.com/arteck/ioBroker.zigbee/tarball/713
                      @arteck
                      Top! jetzt geht's wieder 😉
                      mal kurz zum Verständnis: spielt es eine Rolle ob ich das Repo
                      installiere oder das Repo
                      Nur mit dem 2. Link hat es nämlich bei mir jetzt funktioniert ?!
                        ja ist eine andere Softwareversion.. die leben aber immer nur solange bis ich die wieder lösche..
                        normalerweise nimmst du immer das orignale
                          piscator83 last edited by
                          bitte entschuldigt falls ich was frage was schon behandelt wurde, gefunden hab ichs nicht...
                          Hab in einem Raum eine Zeitschaltung mit Bewegungsmelder mit einer Osram GU10 RGB realisiert. Sas ganze lief auch eine Zeit lang eigentlich recht stabil. Neuerdings kann ich die Birne wenn ich sie mit dem Lichtschalter einschalte genau einmal über iobroker ausschalten. Sonst gar nichts. Vor allem eben nicht einschalten.
                          War früher (glaub ich) auf der 0.86b von Arteck, dann mal aktualisiert automatisch auf 0.92. Ich bilde mir ein seit dem gehts nicht mehr. Vllt täusch ich mich auch, wüsste aber keinen anderen Auslöser.
                          Jemand einen Ansatzpunkt? Thx
                          • Asgothian
                            Asgothian Developer @piscator83 last edited by
                            @piscator83
                            Kannst du bitte mal schauen welche Versionen vom zigbee-shepherd-converters du hast ? (console auf den Rechner, in den Verzeichnissen /opt/iobroker/node_modules/zigbee-shepherd-converters und ggf. auch /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-shepherd-converters ein tail ./package.json, da müsste die Versionsnummer drin stehen ?
                            A.
                              piscator83 @Asgothian last edited by
                              @Asgothian
                              Also in der ersten steht 4.0.12
                              in der zweiten 7.1.13
                              kann das sein?
                                der_maik last edited by
                                bisher hab ich immer alles durch fleißiges Suchen und/oder mitlesen lösen können, nun aber aktuell nicht. Ich bin mir auch nicht sicher ob ich ein Problem mit dem Adapter habe, oder nur ein Verständnisproblem. Ich habe diverse Geräte angelernt, ein paar Xiaomi Sensoren, Ikea Lampen und zwei von Müller Licht. Nun ist es so das ich über ein Skript hier aus dem Forum mit der Tradfri Remote eine Gruppe schalte. Das Skript ändert entsprechend die Werte der Helligkeit, was allerdings nicht aktualisiert wird ist der State der Gruppe und gar kein veränderter Wert beim einzelnen Mitglied der Gruppe. Was etwas schade ist da dadurch die Anzeigen in Visualisierungen oder auch Homekit nicht stimmen.
                                Was mir zum Beispiel jetzt aufgefallen ist "/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-shepherd-converters" gibt es bei mir gar nicht. Was ja auch nicht richtig ist, oder?
                                Installiert habe ich die Adapterversion 0.9.2, zigbee-shepherd version: 2.6.3 rev 20190223, arteck sonderversion zigbee-shepherd 7.1.3.
                                Die Firmware hab ich ganz frisch geflasht, war vorher die 20181024 drauf, kein Unterschied für mich zwischen den beiden.
                                  bigtwinch last edited by
                                  Hallo
                                  Habe viele syslog einträge von zigbee.
                                  System ist ein NUC6CAYH
                                  8GB 240GB SSD PROXMOX
                                  ioBroker auf VM
                                  cc2531 mit firmware CC2531ZNP-Prod_20190223
                                  zigbee adapter = 0.9.2
                                  /opt/iobroker/node_modules/zigbee-shepherd-converters$ = 7.2.8
                                  node v8.15.1
                                  nodejs v8.15.1
                                  npm 6.4.1
                                  ist das normal? !
                                  iobroker@iobroker:~$ sudo tail -f /var/log/syslog
                                  Mar 14 18:28:15 iobroker bash[722]: onZclFunctional: null,
                                  Mar 14 18:28:15 iobroker bash[722]: foundation: [Function],
                                  Mar 14 18:28:15 iobroker bash[722]: functional: [Function],
                                  Mar 14 18:28:15 iobroker bash[722]: bind: [Function],
                                  Mar 14 18:28:15 iobroker bash[722]: unbind: [Function],
                                  Mar 14 18:28:15 iobroker bash[722]: read: [Function],
                                  Mar 14 18:28:15 iobroker bash[722]: write: [Function],
                                  Mar 14 18:28:15 iobroker bash[722]: report: [Function] } ],
                                  Mar 14 18:28:15 iobroker bash[722]: data: { cid: 'genOnOff', data: { onOff: 1 } },
                                  Mar 14 18:28:15 iobroker bash[722]: linkquality: 36 } { cid: 'genOnOff', modelId: 'lumi.router' }
                                  Mar 14 18:28:25 iobroker bash[722]: Thu, 14 Mar 2019 17:28:25 GMT cc-znp:AREQ <-- AF:incomingMsg, { groupid: 0, clusterid: 1030, srcaddr: 37726, srcendpoint: 1, dstendpoint: 1, wasbroadcast: 0, linkquality: 47, securityuse: 0, timestamp: 5713323, transseqnumber: 0, len: 7, data: <Buffer 18 30 0a 00 00 18 01> }
                                  Mar 14 18:28:25 iobroker bash[722]: 2019-03-14T17:28:25.694Z zigbee-shepherd:af dispatchIncomingMsg(): type: incomingMsg, msg: [object Object]
                                  Mar 14 18:28:25 iobroker bash[722]: 2019-03-14T17:28:25.695Z zigbee-shepherd:msgHdlr IND <-- AF:incomingMsg, transId: 0
                                  Mar 14 18:28:25 iobroker bash[722]: 2019-03-14T17:28:25.696Z zigbee:controller event msg { groupid: 0,
                                  Mar 14 18:28:25 iobroker bash[722]: clusterid: 1030,
                                  Mar 14 18:28:25 iobroker bash[722]: srcaddr: 37726,
                                  Mar 14 18:28:25 iobroker bash[722]: srcendpoint: 1,
                                  Mar 14 18:28:25 iobroker bash[722]: dstendpoint: 1,
                                  Mar 14 18:28:25 iobroker bash[722]: wasbroadcast: 0,
                                  Mar 14 18:28:25 iobroker bash[722]: linkquality: 47,
                                  Mar 14 18:28:25 iobroker bash[722]: securityuse: 0,
                                  Mar 14 18:28:25 iobroker bash[722]: timestamp: 5713323,
                                  Mar 14 18:28:25 iobroker bash[722]: transseqnumber: 0,
                                  Mar 14 18:28:25 iobroker bash[722]: len: 7,
                                  Mar 14 18:28:25 iobroker bash[722]: data: { '0': 24, '1': 48, '2': 10, '3': 0, '4': 0, '5': 24, '6': 1 },
                                  Mar 14 18:28:25 iobroker bash[722]: zclMsg:
                                  Mar 14 18:28:25 iobroker bash[722]: { frameCntl: { frameType: 0, manufSpec: 0, direction: 1, disDefaultRsp: 1 },
                                  Mar 14 18:28:25 iobroker bash[722]: manufCode: 0,
                                  Mar 14 18:28:25 iobroker bash[722]: seqNum: 48,
                                  Mar 14 18:28:25 iobroker bash[722]: cmdId: 'report',
                                  Mar 14 18:28:25 iobroker bash[722]: payload: [ [Object] ] } } { modelId: 'lumi.sensor_motion.aq2' }
                                  Mar 14 18:28:25 iobroker bash[722]: 2019-03-14T17:28:25.697Z zigbee-shepherd:af dispatchIncomingMsg(): type: zclIncomingMsg, msg: [object Object]
                                  Mar 14 18:28:25 iobroker bash[722]: 2019-03-14T17:28:25.698Z zigbee:controller debug handleMessage { type: 'attReport',
                                  Mar 14 18:28:25 iobroker bash[722]: endpoints:
                                  Mar 14 18:28:25 iobroker bash[722]: [ Endpoint {
                                  Mar 14 18:28:25 iobroker bash[722]: isLocal: [Function],
                                  Mar 14 18:28:25 iobroker bash[722]: device: [Object],
                                  Mar 14 18:28:25 iobroker bash[722]: profId: 260,
                                  Mar 14 18:28:25 iobroker bash[722]: epId: 1,
                                  Mar 14 18:28:25 iobroker bash[722]: devId: 263,
                                  Mar 14 18:28:25 iobroker bash[722]: inClusterList: [Array],
                                  Mar 14 18:28:25 iobroker bash[722]: outClusterList: [Array],
                                  Mar 14 18:28:25 iobroker bash[722]: clusters: [Object],
                                  Mar 14 18:28:25 iobroker bash[722]: onAfDataConfirm: null,
                                  Mar 14 18:28:25 iobroker bash[722]: onAfReflectError: null,
                                  Mar 14 18:28:25 iobroker bash[722]: onAfIncomingMsg: null,
                                  Mar 14 18:28:25 iobroker bash[722]: onAfIncomingMsgExt: null,
                                  Mar 14 18:28:25 iobroker bash[722]: onZclFoundation: null,
                                  Mar 14 18:28:25 iobroker bash[722]: onZclFunctional: null,
                                  Mar 14 18:28:25 iobroker bash[722]: foundation: [Function],
                                  Mar 14 18:28:25 iobroker bash[722]: functional: [Function],
                                  Mar 14 18:28:25 iobroker bash[722]: bind: [Function],
                                  Mar 14 18:28:25 iobroker bash[722]: unbind: [Function],
                                  Mar 14 18:28:25 iobroker bash[722]: read: [Function],
                                  Mar 14 18:28:25 iobroker bash[722]: write: [Function],
                                  Mar 14 18:28:25 iobroker bash[722]: report: [Function] } ],
                                  Mar 14 18:28:25 iobroker bash[722]: data: { cid: 'msOccupancySensing', data: { occupancy: 1 } },
                                  Mar 14 18:28:25 iobroker bash[722]: linkquality: 47 }
                                  Mar 14 18:28:25 iobroker bash[722]: 2019-03-14T17:28:25.699Z zigbee:controller event attReport { type: 'attReport',
                                  Mar 14 18:28:25 iobroker bash[722]: linkquality: 47 } { cid: 'msOccupancySensing', modelId: 'lumi.sensor_motion.aq2' }
                                  Mar 14 18:28:25 iobroker bash[722]: Thu, 14 Mar 2019 17:28:25 GMT cc-znp:AREQ <-- AF:incomingMsg, { groupid: 0, clusterid: 1024, srcaddr: 37726, srcendpoint: 1, dstendpoint: 1, wasbroadcast: 0, linkquality: 44, securityuse: 0, timestamp: 5713684, transseqnumber: 0, len: 8, data: <Buffer 18 2f 0a 00 00 21 07 00> }
                                  Mar 14 18:28:25 iobroker bash[722]: 2019-03-14T17:28:25.809Z zigbee-shepherd:af dispatchIncomingMsg(): type: incomingMsg, msg: [object Object]
                                  Mar 14 18:28:25 iobroker bash[722]: 2019-03-14T17:28:25.810Z zigbee-shepherd:msgHdlr IND <-- AF:incomingMsg, transId: 0
                                  Mar 14 18:28:25 iobroker bash[722]: 2019-03-14T17:28:25.811Z zigbee:controller event msg { groupid: 0,
                                  Mar 14 18:28:25 iobroker bash[722]: clusterid: 1024,
                                  Mar 14 18:28:25 iobroker bash[722]: linkquality: 44,
                                  Mar 14 18:28:25 iobroker bash[722]: timestamp: 5713684,
                                  Mar 14 18:28:25 iobroker bash[722]: len: 8,
                                  Mar 14 18:28:25 iobroker bash[722]: data: { '0': 24, '1': 47, '2': 10, '3': 0, '4': 0, '5': 33, '6': 7, '7': 0 },
                                  Mar 14 18:28:25 iobroker bash[722]: seqNum: 47,
                                  Mar 14 18:28:25 iobroker bash[722]: 2019-03-14T17:28:25.812Z zigbee-shepherd:af dispatchIncomingMsg(): type: zclIncomingMsg, msg: [object Object]
                                  Mar 14 18:28:25 iobroker bash[722]: 2019-03-14T17:28:25.813Z zigbee:controller debug handleMessage { type: 'attReport',
                                  Mar 14 18:28:25 iobroker bash[722]: data: { cid: 'msIlluminanceMeasurement', data: { measuredValue: 7 } },
                                  Mar 14 18:28:25 iobroker bash[722]: linkquality: 44 }
                                  Mar 14 18:28:25 iobroker bash[722]: 2019-03-14T17:28:25.814Z zigbee:controller event attReport { type: 'attReport',
                                  Mar 14 18:28:25 iobroker bash[722]: linkquality: 44 } { cid: 'msIlluminanceMeasurement',
                                  Mar 14 18:28:25 iobroker bash[722]: modelId: 'lumi.sensor_motion.aq2' }
                                  Mar 14 18:28:25 iobroker bash[722]: 2019-03-14T17:28:25.815Z zigbee:controller debug handleMessage { type: 'devChange',
                                  Mar 14 18:28:25 iobroker bash[722]: data: { cid: 'msIlluminanceMeasurement', data: { measuredValue: 7 } } }
                                  Mar 14 18:28:25 iobroker bash[722]: 2019-03-14T17:28:25.818Z zigbee:controller event devChange { type: 'devChange',
                                  Mar 14 18:28:25 iobroker bash[722]: data: { cid: 'msIlluminanceMeasurement', data: { measuredValue: 7 } } } { cid: 'msIlluminanceMeasurement',
                                  Mar 14 18:28:28 iobroker bash[722]: Thu, 14 Mar 2019 17:28:28 GMT cc-znp:AREQ <-- ZDO:srcRtgInd, { dstaddr: 2488, relaycount: 1, relaylist: <Buffer 18 f8> }
                                  Mar 14 18:28:28 iobroker bash[722]: 2019-03-14T17:28:28.706Z zigbee-shepherd:msgHdlr IND <-- ZDO:srcRtgInd
                                  Mar 14 18:28:28 iobroker bash[722]: Thu, 14 Mar 2019 17:28:28 GMT cc-znp:AREQ <-- AF:incomingMsg, { groupid: 0, clusterid: 0, srcaddr: 2488, srcendpoint: 1, dstendpoint: 1, wasbroadcast: 0, linkquality: 39, securityuse: 0, timestamp: 5722885, transseqnumber: 0, len: 44, data: <Buffer 18 84 0a 01 ff 42 25 01 21 bd 0b 04 21 a8 43 05 21 0c 00 06 24 01 00 00 00 00 64 29 6c 07 65 21 57 0d 66 2b 90 75 01 00 0a 21 18 f8> }
                                  Mar 14 18:28:28 iobroker bash[722]: 2019-03-14T17:28:28.757Z zigbee-shepherd:af dispatchIncomingMsg(): type: incomingMsg, msg: [object Object]
                                  Mar 14 18:28:28 iobroker bash[722]: 2019-03-14T17:28:28.761Z zigbee-shepherd:msgHdlr IND <-- AF:incomingMsg, transId: 0
                                  Mar 14 18:28:28 iobroker bash[722]: 2019-03-14T17:28:28.761Z zigbee:controller event msg { groupid: 0,
                                  Mar 14 18:28:28 iobroker bash[722]: clusterid: 0,
                                  Mar 14 18:28:28 iobroker bash[722]: srcaddr: 2488,
                                  Mar 14 18:28:28 iobroker bash[722]: srcendpoint: 1,
                                  Mar 14 18:28:28 iobroker bash[722]: dstendpoint: 1,
                                  Mar 14 18:28:28 iobroker bash[722]: wasbroadcast: 0,
                                  Mar 14 18:28:28 iobroker bash[722]: linkquality: 39,
                                  Mar 14 18:28:28 iobroker bash[722]: securityuse: 0,
                                  Mar 14 18:28:28 iobroker bash[722]: timestamp: 5722885,
                                  Mar 14 18:28:28 iobroker bash[722]: transseqnumber: 0,
                                  Mar 14 18:28:28 iobroker bash[722]: len: 44,
                                  Mar 14 18:28:28 iobroker bash[722]: data:
                                  Mar 14 18:28:28 iobroker bash[722]: { '0': 24,
                                  Mar 14 18:28:28 iobroker bash[722]: '1': 132,
                                  Mar 14 18:28:28 iobroker bash[722]: '2': 10,
                                  Mar 14 18:28:28 iobroker bash[722]: '3': 1,
                                  Mar 14 18:28:28 iobroker bash[722]: '4': 255,
                                  Mar 14 18:28:28 iobroker bash[722]: '5': 66,
                                  Mar 14 18:28:28 iobroker bash[722]: '6': 37,
                                  Mar 14 18:28:28 iobroker bash[722]: '7': 1,
                                  Mar 14 18:28:28 iobroker bash[722]: '8': 33,
                                  Mar 14 18:28:28 iobroker bash[722]: '9': 189,
                                  Mar 14 18:28:28 iobroker bash[722]: '10': 11,
                                  Mar 14 18:28:28 iobroker bash[722]: '11': 4,
                                  Mar 14 18:28:28 iobroker bash[722]: '12': 33,
                                  Mar 14 18:28:28 iobroker bash[722]: '13': 168,
                                  Mar 14 18:28:28 iobroker bash[722]: '14': 67,
                                  Mar 14 18:28:28 iobroker bash[722]: '15': 5,
                                  Mar 14 18:28:28 iobroker bash[722]: '16': 33,
                                  Mar 14 18:28:28 iobroker bash[722]: '17': 12,
                                  Mar 14 18:28:28 iobroker bash[722]: '18': 0,
                                  Mar 14 18:28:28 iobroker bash[722]: '19': 6,
                                  Mar 14 18:28:28 iobroker bash[722]: '20': 36,
                                  Mar 14 18:28:28 iobroker bash[722]: '21': 1,
                                  Mar 14 18:28:28 iobroker bash[722]: '22': 0,
                                  Mar 14 18:28:28 iobroker bash[722]: '23': 0,
                                  Mar 14 18:28:28 iobroker bash[722]: '24': 0,
                                  Mar 14 18:28:28 iobroker bash[722]: '25': 0,
                                  Mar 14 18:28:28 iobroker bash[722]: '26': 100,
                                  Mar 14 18:28:28 iobroker bash[722]: '27': 41,
                                  Mar 14 18:28:28 iobroker bash[722]: '28': 108,
                                  Mar 14 18:28:28 iobroker bash[722]: '29': 7,
                                  Mar 14 18:28:28 iobroker bash[722]: '30': 101,
                                  Mar 14 18:28:28 iobroker bash[722]: '31': 33,
                                  Mar 14 18:28:28 iobroker bash[722]: '32': 87,
                                  Mar 14 18:28:28 iobroker bash[722]: '33': 13,
                                  Mar 14 18:28:28 iobroker bash[722]: '34': 102,
                                  Mar 14 18:28:28 iobroker bash[722]: '35': 43,
                                  Mar 14 18:28:28 iobroker bash[722]: '36': 144,
                                  Mar 14 18:28:28 iobroker bash[722]: '37': 117,
                                  Mar 14 18:28:28 iobroker bash[722]: '38': 1,
                                  Mar 14 18:28:28 iobroker bash[722]: '39': 0,
                                  Mar 14 18:28:28 iobroker bash[722]: '40': 10,
                                  Mar 14 18:28:28 iobroker bash[722]: '41': 33,
                                  Mar 14 18:28:28 iobroker bash[722]: '42': 24,
                                  Mar 14 18:28:28 iobroker bash[722]: '43': 248 },
                                  Mar 14 18:28:28 iobroker bash[722]: zclMsg:
                                  Mar 14 18:28:28 iobroker bash[722]: { frameCntl: { frameType: 0, manufSpec: 0, direction: 1, disDefaultRsp: 1 },
                                  Mar 14 18:28:28 iobroker bash[722]: manufCode: 0,
                                  Mar 14 18:28:28 iobroker bash[722]: seqNum: 132,
                                  Mar 14 18:28:28 iobroker bash[722]: cmdId: 'report',
                                  Mar 14 18:28:28 iobroker bash[722]: payload: [ [Object] ] } } { modelId: 'lumi.weather' }
                                  Mar 14 18:28:28 iobroker bash[722]: 2019-03-14T17:28:28.762Z zigbee-shepherd:af dispatchIncomingMsg(): type: zclIncomingMsg, msg: [object Object]
                                  Mar 14 18:28:28 iobroker bash[722]: 2019-03-14T17:28:28.763Z zigbee:controller debug handleMessage { type: 'attReport',
                                  Mar 14 18:28:28 iobroker bash[722]: endpoints:
                                  Mar 14 18:28:28 iobroker bash[722]: [ Endpoint {
                                  Mar 14 18:28:28 iobroker bash[722]: isLocal: [Function],
                                  Mar 14 18:28:28 iobroker bash[722]: device: [Object],
                                  Mar 14 18:28:28 iobroker bash[722]: profId: 260,
                                  Mar 14 18:28:28 iobroker bash[722]: epId: 1,
                                  Mar 14 18:28:28 iobroker bash[722]: devId: 24321,
                                  Mar 14 18:28:28 iobroker bash[722]: inClusterList: [Array],
                                  Mar 14 18:28:28 iobroker bash[722]: outClusterList: [Array],
                                  Mar 14 18:28:28 iobroker bash[722]: clusters: [Object],
                                  Mar 14 18:28:28 iobroker bash[722]: onAfDataConfirm: null,
                                  Mar 14 18:28:28 iobroker bash[722]: onAfReflectError: null,
                                  Mar 14 18:28:28 iobroker bash[722]: onAfIncomingMsg: null,
                                  Mar 14 18:28:28 iobroker bash[722]: onAfIncomingMsgExt: null,
                                  Mar 14 18:28:28 iobroker bash[722]: onZclFoundation: null,
                                  Mar 14 18:28:28 iobroker bash[722]: onZclFunctional: null,
                                  Mar 14 18:28:28 iobroker bash[722]: foundation: [Function],
                                  Mar 14 18:28:28 iobroker bash[722]: functional: [Function],
                                  Mar 14 18:28:28 iobroker bash[722]: bind: [Function],
                                  Mar 14 18:28:28 iobroker bash[722]: unbind: [Function],
                                  Mar 14 18:28:28 iobroker bash[722]: read: [Function],
                                  Mar 14 18:28:28 iobroker bash[722]: write: [Function],
                                  Mar 14 18:28:28 iobroker bash[722]: report: [Function] } ],
                                  Mar 14 18:28:28 iobroker bash[722]: data: { cid: 'genBasic', data: { '65281': [Object] } },
                                  Mar 14 18:28:28 iobroker bash[722]: linkquality: 39 }
                                  Mar 14 18:28:28 iobroker bash[722]: 2019-03-14T17:28:28.764Z zigbee:controller event attReport { type: 'attReport',
                                  Mar 14 18:28:28 iobroker bash[722]: linkquality: 39 } { cid: 'genBasic', modelId: 'lumi.weather' }
                                  Mar 14 18:28:28 iobroker bash[722]: 2019-03-14T17:28:28.767Z zigbee:controller debug handleMessage { type: 'devChange',
                                  Mar 14 18:28:28 iobroker bash[722]: data: { cid: 'genBasic', data: { '65281': [Array] } } }
                                  Mar 14 18:28:28 iobroker bash[722]: 2019-03-14T17:28:28.768Z zigbee:controller event devChange { type: 'devChange',
                                  Mar 14 18:28:28 iobroker bash[722]: data: { cid: 'genBasic', data: { '65281': [Array] } } } { cid: 'genBasic', modelId: 'lumi.weather' }
                                  Mar 14 18:28:50 iobroker bash[722]: Thu, 14 Mar 2019 17:28:50 GMT cc-znp:AREQ <-- AF:incomingMsg, { groupid: 0, clusterid: 257, srcaddr: 33792, srcendpoint: 1, dstendpoint: 1, wasbroadcast: 0, linkquality: 118, securityuse: 0, timestamp: 5790789, transseqnumber: 0, len: 10, data: <Buffer 18 cb 0a 05 05 23 00 00 1b 00> }
                                  Mar 14 18:28:50 iobroker bash[722]: 2019-03-14T17:28:50.482Z zigbee-shepherd:af dispatchIncomingMsg(): type: incomingMsg, msg: [object Object]
                                  Mar 14 18:28:50 iobroker bash[722]: 2019-03-14T17:28:50.484Z zigbee-shepherd:msgHdlr IND <-- AF:incomingMsg, transId: 0
                                  Mar 14 18:28:50 iobroker bash[722]: 2019-03-14T17:28:50.484Z zigbee:controller event msg { groupid: 0,
                                  Mar 14 18:28:50 iobroker bash[722]: clusterid: 257,
                                  Mar 14 18:28:50 iobroker bash[722]: srcaddr: 33792,
                                  Mar 14 18:28:50 iobroker bash[722]: srcendpoint: 1,
                                  Mar 14 18:28:50 iobroker bash[722]: dstendpoint: 1,
                                  Mar 14 18:28:50 iobroker bash[722]: wasbroadcast: 0,
                                  Mar 14 18:28:50 iobroker bash[722]: linkquality: 118,
                                  Mar 14 18:28:50 iobroker bash[722]: securityuse: 0,
                                  Mar 14 18:28:50 iobroker bash[722]: timestamp: 5790789,
                                  Mar 14 18:28:50 iobroker bash[722]: transseqnumber: 0,
                                  Mar 14 18:28:50 iobroker bash[722]: len: 10,
                                  Mar 14 18:28:50 iobroker bash[722]: data:
                                  Mar 14 18:28:50 iobroker bash[722]: { '0': 24,
                                  Mar 14 18:28:50 iobroker bash[722]: '1': 203,
                                  Mar 14 18:28:50 iobroker bash[722]: '2': 10,
                                  Mar 14 18:28:50 iobroker bash[722]: '3': 5,
                                  Mar 14 18:28:50 iobroker bash[722]: '4': 5,
                                  Mar 14 18:28:50 iobroker bash[722]: '5': 35,
                                  Mar 14 18:28:50 iobroker bash[722]: '6': 0,
                                  Mar 14 18:28:50 iobroker bash[722]: '7': 0,
                                  Mar 14 18:28:50 iobroker bash[722]: '8': 27,
                                  Mar 14 18:28:50 iobroker bash[722]: '9': 0 },
                                  Mar 14 18:28:50 iobroker bash[722]: zclMsg:
                                  Mar 14 18:28:50 iobroker bash[722]: { frameCntl: { frameType: 0, manufSpec: 0, direction: 1, disDefaultRsp: 1 },
                                  Mar 14 18:28:50 iobroker bash[722]: manufCode: 0,
                                  Mar 14 18:28:50 iobroker bash[722]: seqNum: 203,
                                  Mar 14 18:28:50 iobroker bash[722]: cmdId: 'report',
                                  Mar 14 18:28:50 iobroker bash[722]: payload: [ [Object] ] } } { modelId: 'lumi.vibration.aq1' }
                                  Mar 14 18:28:50 iobroker bash[722]: 2019-03-14T17:28:50.485Z zigbee-shepherd:af dispatchIncomingMsg(): type: zclIncomingMsg, msg: [object Object]
                                  Mar 14 18:28:50 iobroker bash[722]: 2019-03-14T17:28:50.486Z zigbee:controller debug handleMessage { type: 'attReport',
                                  Mar 14 18:28:50 iobroker bash[722]: endpoints:
                                  Mar 14 18:28:50 iobroker bash[722]: [ Endpoint {
                                  Mar 14 18:28:50 iobroker bash[722]: isLocal: [Function],
                                  Mar 14 18:28:50 iobroker bash[722]: device: [Object],
                                  Mar 14 18:28:50 iobroker bash[722]: profId: 260,
                                  Mar 14 18:28:50 iobroker bash[722]: epId: 1,
                                  Mar 14 18:28:50 iobroker bash[722]: devId: 10,
                                  Mar 14 18:28:50 iobroker bash[722]: inClusterList: [Array],
                                  Mar 14 18:28:50 iobroker bash[722]: outClusterList: [Array],
                                  Mar 14 18:28:50 iobroker bash[722]: clusters: [Object],
                                  Mar 14 18:28:50 iobroker bash[722]: onAfDataConfirm: null,
                                  Mar 14 18:28:50 iobroker bash[722]: onAfReflectError: null,
                                  Mar 14 18:28:50 iobroker bash[722]: onAfIncomingMsg: null,
                                  Mar 14 18:28:50 iobroker bash[722]: onAfIncomingMsgExt: null,
                                  Mar 14 18:28:50 iobroker bash[722]: onZclFoundation: null,
                                  Mar 14 18:28:50 iobroker bash[722]: onZclFunctional: null,
                                  Mar 14 18:28:50 iobroker bash[722]: foundation: [Function],
                                  Mar 14 18:28:50 iobroker bash[722]: functional: [Function],
                                  Mar 14 18:28:50 iobroker bash[722]: bind: [Function],
                                  Mar 14 18:28:50 iobroker bash[722]: unbind: [Function],
                                  Mar 14 18:28:50 iobroker bash[722]: read: [Function],
                                  Mar 14 18:28:50 iobroker bash[722]: write: [Function],
                                  Mar 14 18:28:50 iobroker bash[722]: report: [Function] } ],
                                  Mar 14 18:28:50 iobroker bash[722]: data: { cid: 'closuresDoorLock', data: { '1285': 1769472 } },
                                  Mar 14 18:28:50 iobroker bash[722]: linkquality: 118 }
                                  Mar 14 18:28:50 iobroker bash[722]: 2019-03-14T17:28:50.487Z zigbee:controller event attReport { type: 'attReport',
                                  Mar 14 18:28:50 iobroker bash[722]: linkquality: 118 } { cid: 'closuresDoorLock', modelId: 'lumi.vibration.aq1' }
                                  Mar 14 18:28:50 iobroker bash[722]: 2019-03-14T17:28:50.489Z zigbee:controller debug handleMessage { type: 'devChange',
                                  Mar 14 18:28:50 iobroker bash[722]: data: { cid: 'closuresDoorLock', data: { '1285': 1769472 } } }
                                  Mar 14 18:28:50 iobroker bash[722]: 2019-03-14T17:28:50.491Z zigbee:controller event devChange { type: 'devChange',
                                  Mar 14 18:28:50 iobroker bash[722]: data: { cid: 'closuresDoorLock', data: { '1285': 1769472 } } } { cid: 'closuresDoorLock', modelId: 'lumi.vibration.aq1' }
                                  Mar 14 18:29:05 iobroker bash[722]: 2019-03-14T17:29:05.772Z zigbee:controller debug Check online 0xd0cf5efffe212f9c 0xd0cf5efffe212f9c
                                  Mar 14 18:29:05 iobroker bash[722]: 2019-03-14T17:29:05.772Z zigbee:controller debug Check online 0x00124b001b7b302e 0x00124b001b7b302e
                                  Mar 14 18:29:05 iobroker bash[722]: 2019-03-14T17:29:05.772Z zigbee:controller debug Check online 0x000b57fffe395926 0x000b57fffe395926
                                  Mar 14 18:29:05 iobroker bash[722]: 2019-03-14T17:29:05.773Z zigbee:controller debug Check online 0x90fd9ffffe0facaa 0x90fd9ffffe0facaa
                                  Mar 14 18:29:05 iobroker bash[722]: 2019-03-14T17:29:05.773Z zigbee-shepherd:request REQ --> ZDO:nodeDescReq
                                  Mar 14 18:29:05 iobroker bash[722]: Thu, 14 Mar 2019 17:29:05 GMT cc-znp:SREQ --> ZDO:nodeDescReq, { dstaddr: 31855, nwkaddrofinterest: 31855 }
                                  Mar 14 18:29:05 iobroker bash[722]: 2019-03-14T17:29:05.774Z zigbee-shepherd:request REQ --> ZDO:nodeDescReq
                                  Mar 14 18:29:05 iobroker bash[722]: 2019-03-14T17:29:05.775Z zigbee-shepherd:request REQ --> ZDO:nodeDescReq
                                  Mar 14 18:29:05 iobroker bash[722]: Thu, 14 Mar 2019 17:29:05 GMT cc-znp:SRSP <-- ZDO:nodeDescReq, { status: 0 }
                                  Mar 14 18:29:05 iobroker bash[722]: Thu, 14 Mar 2019 17:29:05 GMT cc-znp:SREQ --> ZDO:nodeDescReq, { dstaddr: 46194, nwkaddrofinterest: 46194 }
                                  Mar 14 18:29:05 iobroker bash[722]: Thu, 14 Mar 2019 17:29:05 GMT cc-znp:SREQ --> ZDO:nodeDescReq, { dstaddr: 11267, nwkaddrofinterest: 11267 }
                                  Mar 14 18:29:05 iobroker bash[722]: Thu, 14 Mar 2019 17:29:05 GMT cc-znp:SREQ --> ZDO:nodeDescReq, { dstaddr: 63512, nwkaddrofinterest: 63512 }
                                  Mar 14 18:29:05 iobroker bash[722]: Thu, 14 Mar 2019 17:29:05 GMT cc-znp:AREQ <-- ZDO:srcRtgInd, { dstaddr: 46194, relaycount: 1, relaylist: <Buffer 18 f8> }
                                  Mar 14 18:29:05 iobroker bash[722]: 2019-03-14T17:29:05.844Z zigbee-shepherd:msgHdlr IND <-- ZDO:srcRtgInd
                                  Mar 14 18:29:05 iobroker bash[722]: Thu, 14 Mar 2019 17:29:05 GMT cc-znp:AREQ <-- ZDO:srcRtgInd, { dstaddr: 11267, relaycount: 1, relaylist: <Buffer 18 f8> }
                                  Mar 14 18:29:05 iobroker bash[722]: 2019-03-14T17:29:05.861Z zigbee-shepherd:msgHdlr IND <-- ZDO:srcRtgInd
                                  Mar 14 18:29:05 iobroker bash[722]: Thu, 14 Mar 2019 17:29:05 GMT cc-znp:AREQ <-- ZDO:srcRtgInd, { dstaddr: 63512, relaycount: 0, relaylist: <Buffer > }
                                  Mar 14 18:29:05 iobroker bash[722]: 2019-03-14T17:29:05.867Z zigbee-shepherd:msgHdlr IND <-- ZDO:srcRtgInd
                                  Mar 14 18:29:05 iobroker bash[722]: Thu, 14 Mar 2019 17:29:05 GMT cc-znp:AREQ <-- ZDO:nodeDescRsp, { srcaddr: 11267, status: 0, nwkaddr: 11267, logicaltype_cmplxdescavai_userdescavai: 1, apsflags_freqband: 64, maccapflags: 142, manufacturercode: 4476, maxbuffersize: 82, maxintransfersize: 82, servermask: 0, maxouttransfersize: 82, descriptorcap: 0 }
                                  Mar 14 18:29:05 iobroker bash[722]: 2019-03-14T17:29:05.895Z zigbee-shepherd:msgHdlr IND <-- ZDO:nodeDescRsp
                                  Mar 14 18:29:05 iobroker bash[722]: Thu, 14 Mar 2019 17:29:05 GMT cc-znp:AREQ <-- ZDO:nodeDescRsp, { srcaddr: 63512, status: 0, nwkaddr: 63512, logicaltype_cmplxdescavai_userdescavai: 1, apsflags_freqband: 64, maccapflags: 142, manufacturercode: 4476, maxbuffersize: 82, maxintransfersize: 82, servermask: 0, maxouttransfersize: 82, descriptorcap: 0 }
                                  Mar 14 18:29:05 iobroker bash[722]: 2019-03-14T17:29:05.908Z zigbee-shepherd:msgHdlr IND <-- ZDO:nodeDescRsp
                                  Mar 14 18:29:06 iobroker bash[722]: Thu, 14 Mar 2019 17:29:06 GMT cc-znp:AREQ <-- ZDO:nodeDescRsp, { srcaddr: 46194, status: 0, nwkaddr: 46194, logicaltype_cmplxdescavai_userdescavai: 1, apsflags_freqband: 64, maccapflags: 142, manufacturercode: 4447, maxbuffersize: 80, maxintransfersize: 160, servermask: 0, maxouttransfersize: 160, descriptorcap: 0 }
                                  Mar 14 18:29:06 iobroker bash[722]: 2019-03-14T17:29:06.127Z zigbee-shepherd:msgHdlr IND <-- ZDO:nodeDescRsp
                                  Mar 14 18:29:10 iobroker bash[722]: 2019-03-14T17:29:10.776Z zigbee-shepherd:request REQ --> ZDO:nodeDescReq
                                  Mar 14 18:29:10 iobroker bash[722]: Thu, 14 Mar 2019 17:29:10 GMT cc-znp:SREQ --> ZDO:nodeDescReq, { dstaddr: 31855, nwkaddrofinterest: 31855 }
                                  Mar 14 18:29:10 iobroker bash[722]: Thu, 14 Mar 2019 17:29:10 GMT cc-znp:SRSP <-- ZDO:nodeDescReq, { status: 0 }
                                  Mar 14 18:29:15 iobroker bash[722]: Thu, 14 Mar 2019 17:29:15 GMT cc-znp:AREQ <-- AF:incomingMsg, { groupid: 0, clusterid: 6, srcaddr: 46194, srcendpoint: 8, dstendpoint: 1, wasbroadcast: 0, linkquality: 60, securityuse: 0, timestamp: 5868666, transseqnumber: 0, len: 7, data: <Buffer 00 83 0a 00 00 20 01> }
                                  Mar 14 18:29:15 iobroker bash[722]: 2019-03-14T17:29:15.401Z zigbee-shepherd:af dispatchIncomingMsg(): type: incomingMsg, msg: [object Object]
                                  Mar 14 18:29:15 iobroker bash[722]: 2019-03-14T17:29:15.405Z zigbee-shepherd:msgHdlr IND <-- AF:incomingMsg, transId: 0
                                  Mar 14 18:29:15 iobroker bash[722]: 2019-03-14T17:29:15.406Z zigbee:controller event msg { groupid: 0,
                                  Mar 14 18:29:15 iobroker bash[722]: clusterid: 6,
                                  Mar 14 18:29:15 iobroker bash[722]: srcaddr: 46194,
                                  Mar 14 18:29:15 iobroker bash[722]: srcendpoint: 8,
                                  Mar 14 18:29:15 iobroker bash[722]: dstendpoint: 1,
                                  Mar 14 18:29:15 iobroker bash[722]: wasbroadcast: 0,
                                  Mar 14 18:29:15 iobroker bash[722]: linkquality: 60,
                                  Mar 14 18:29:15 iobroker bash[722]: securityuse: 0,
                                  Mar 14 18:29:15 iobroker bash[722]: timestamp: 5868666,
                                  Mar 14 18:29:15 iobroker bash[722]: transseqnumber: 0,
                                  Mar 14 18:29:15 iobroker bash[722]: len: 7,
                                  Mar 14 18:29:15 iobroker bash[722]: data: { '0': 0, '1': 131, '2': 10, '3': 0, '4': 0, '5': 32, '6': 1 },
                                  Mar 14 18:29:15 iobroker bash[722]: zclMsg:
                                  Mar 14 18:29:15 iobroker bash[722]: { frameCntl: { frameType: 0, manufSpec: 0, direction: 0, disDefaultRsp: 0 },
                                  Mar 14 18:29:15 iobroker bash[722]: manufCode: 0,
                                  Mar 14 18:29:15 iobroker bash[722]: seqNum: 131,
                                  Mar 14 18:29:15 iobroker bash[722]: cmdId: 'report',
                                  Mar 14 18:29:15 iobroker bash[722]: payload: [ [Object] ] } } { modelId: 'lumi.router' }
                                  Mar 14 18:29:15 iobroker bash[722]: 2019-03-14T17:29:15.407Z zigbee-shepherd:af dispatchIncomingMsg(): type: zclIncomingMsg, msg: [object Object]
                                  Mar 14 18:29:15 iobroker bash[722]: 2019-03-14T17:29:15.408Z zigbee:controller debug handleMessage { type: 'attReport',
                                  ^C
                                  Wer hat einen Tip....
                                  Gruss
                                  Christian
                                  • Asgothian
                                    Asgothian Developer @der_maik last edited by Asgothian
                                    @der_maik sagte in [Aufruf] ZigBee CC253x Adapter 0.9:
                                    Doch, das ist soweit ok. Es darf immer nur einen geben. Die Mischung die @piscator83 oben beschrieben hat ist schon schlechter. Es sollte immer nur einen geben.
                                    Wie das mit den Gruppen über den Zigbee-Adapter gelöst ist weiss ich nicht - da bin ich gerade dabei mich einzulesen - eigentlich müssten die Lampen die geänderte Helligkeit zurück melden. Aber der gesamte Group-Support ist noch neu, und wohl auch noch nicht 100%ig ok.
                                    Unabhängig davon kann ich euch (und auch @bigtwinch) nur empfehlen bis morgen auszuharren, und dann die (hoffentlich) bereit stehende neue Version von Github zu installieren. Es gab in den letzten Tagen einiges an Problemen durch Änderungen am Unterbau (Siehe auch @arteck's Post dazu.)
                                    Heute Abend soll eine neue Version gebaut werden.
                                    @piscator83 sagte in [Aufruf] ZigBee CC253x Adapter 0.9:
                                    @Asgothian
                                    kann das sein?
                                    Das kann sein, soll aber so nicht sein. Lösch doch bitte die 4.0.12 (das ganze Verzeichnis), um die alten Sachen los zu werden, bevor Du morgen die neue Version (s.o.) installierst.
                                    @bigtwinch sagte in [Aufruf] ZigBee CC253x Adapter 0.9:
                                    ist das normal? !
                                    Nein - das sollte nicht so sein. Da sind in einer der genutzten Bibliotheken noch log-ausgaben aktiv, die eigentlich raus sein sollten.
                                    A.
                                      Danke für die fixe Rückmeldung. Bitte keine Hektik, so wie es momentan läuft bin ich schon sehr zufrieden, das kleine bisschen sehe ich als Schönheitsfehler. An der Stelle auch noch mal Lob und Anerkennung an alle die ihre Zeit in die Entwicklung stecken!
                                        @Asgothian
                                        Vielen Dank schon mal. Spitzensupport!
                                        Hab den Ordner jetzt gelöscht. Der Ordner zigbee-shepherd kann/soll aber bleiben?
                                        Ich warte dann mal hoffnungsvoll auf morgen...
                                        • Asgothian
                                          @piscator83
                                          Ja.. einen brauchst du, sonst geht es nicht.
                                            @Asgothian
                                            Ich meinte den ordner opt/iobroker/node_modules/zigbee-shepherd Zignee-shepherd-converters hab ich dort gelöscht
                                            Unter opt/iobroker/node_modules/iobroker.zigbee/node_modules/ gibt es auch beide ordner...
                                            297
                                            44717
