    4. [Frage] [Blockly/JavaScript] v.4.1.12 Alles etwas langsamer?
    • rantanplan
      rantanplan last edited by
      Hallo Zusammen
      Ich teste gerade die v4.1.12 etwas.
      Beim Testen setze ich auch mal bewust falsche Werte ein. Bei einem "Fehler" gibt es nun Seitenweise Log-Einträge.
      Hier mal ein kleiner Auszug.
      javascript.0	2019-03-10 12:12:39.930	warn	at TCP.onread (net.js:548:20)
      javascript.0	2019-03-10 12:12:39.930	warn	at readableAddChunk (_stream_readable.js:176:18)
      javascript.0	2019-03-10 12:12:39.930	warn	at Socket.emit (events.js:188:7)
      javascript.0	2019-03-10 12:12:39.930	warn	at emitOne (events.js:96:13)
      javascript.0	2019-03-10 12:12:39.930	warn	at Socket.realHandler (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\ws\lib\WebSocket.js:825:20)
      javascript.0	2019-03-10 12:12:39.930	warn	at Receiver.add (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\ws\lib\Receiver.js:103:24)
      javascript.0	2019-03-10 12:12:39.930	warn	at Receiver.expectHandler (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\ws\lib\Receiver.js:499:31)
      javascript.0	2019-03-10 12:12:39.930	warn	at Receiver.finish (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\ws\lib\Receiver.js:541:12)
      javascript.0	2019-03-10 12:12:39.930	warn	at Receiver.flush (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\ws\lib\Receiver.js:347:3)
      javascript.0	2019-03-10 12:12:39.930	warn	at C:\ioBroker\node_modules\iobroker.js-controller\node_modules\ws\lib\Receiver.js:508:14
      javascript.0	2019-03-10 12:12:39.930	warn	at Receiver.applyExtensions (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\ws\lib\Receiver.js:371:5)
      javascript.0	2019-03-10 12:12:39.930	warn	at C:\ioBroker\node_modules\iobroker.js-controller\node_modules\ws\lib\Receiver.js:536:18
      javascript.0	2019-03-10 12:12:39.930	warn	at Receiver.ontext (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\ws\lib\WebSocket.js:841:10)
      javascript.0	2019-03-10 12:12:39.930	warn	at WebSocket.emit (events.js:191:7)
      javascript.0	2019-03-10 12:12:39.930	warn	at emitTwo (events.js:106:13)
      javascript.0	2019-03-10 12:12:39.930	warn	at WebSocket.onMessage (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\ws\lib\WebSocket.js:442:14)
      javascript.0	2019-03-10 12:12:39.930	warn	at WebSocket.ws.onmessage (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\engine.io-client\lib\transports\websocket.js:146:10)
      javascript.0	2019-03-10 12:12:39.930	warn	at WS.Transport.onData (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\engine.io-client\lib\transport.js:137:8)
      javascript.0	2019-03-10 12:12:39.930	warn	at WS.Transport.onPacket (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\engine.io-client\lib\transport.js:145:8)
      javascript.0	2019-03-10 12:12:39.930	warn	at WS.Emitter.emit (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\engine.io-client\node_modules\component-emitter\index.js:133:20)
      javascript.0	2019-03-10 12:12:39.930	warn	at WS.<anonymous> (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\engine.io-client\lib\socket.js:268:10)
      javascript.0	2019-03-10 12:12:39.930	warn	at Socket.onPacket (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\engine.io-client\lib\socket.js:451:14)
      javascript.0	2019-03-10 12:12:39.930	warn	at Socket.Emitter.emit (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\engine.io-client\node_modules\component-emitter\index.js:133:20)
      javascript.0	2019-03-10 12:12:39.930	warn	at Socket.<anonymous> (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\component-bind\index.js:21:15)
      javascript.0	2019-03-10 12:12:39.930	warn	at Manager.ondata (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\lib\manager.js:322:16)
      javascript.0	2019-03-10 12:12:39.930	warn	at Decoder.add (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io-parser\index.js:246:12)
      javascript.0	2019-03-10 12:12:39.930	warn	at Decoder.Emitter.emit (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\component-emitter\index.js:134:20)
      javascript.0	2019-03-10 12:12:39.930	warn	at Decoder.<anonymous> (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\component-bind\index.js:21:15)
      javascript.0	2019-03-10 12:12:39.930	warn	at Manager.ondecoded (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\lib\manager.js:332:8)
      javascript.0	2019-03-10 12:12:39.930	warn	at Manager.Emitter.emit (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\node_modules\component-emitter\index.js:133:20)
      javascript.0	2019-03-10 12:12:39.930	warn	at Manager.<anonymous> (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\component-bind\index.js:21:15)
      javascript.0	2019-03-10 12:12:39.930	warn	at Socket.onpacket (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\lib\socket.js:236:12)
      javascript.0	2019-03-10 12:12:39.930	warn	at Socket.onack (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\lib\socket.js:312:9)
      javascript.0	2019-03-10 12:12:39.930	warn	at Socket.adapter.getForeignState (C:\ioBroker\node_modules\iobroker.javascript\main.js:745:17)
      javascript.0	2019-03-10 12:12:39.930	warn	at prepareScript (C:\ioBroker\node_modules\iobroker.javascript\main.js:1071:38)
      javascript.0	2019-03-10 12:12:39.930	warn	at execute (C:\ioBroker\node_modules\iobroker.javascript\main.js:918:27)
      javascript.0	2019-03-10 12:12:39.930	warn	at script.js.Test.TestVarIdBlock:6:1
      javascript.0	2019-03-10 12:12:39.930	warn	at setStateDelayed (C:\ioBroker\node_modules\iobroker.javascript\lib\sandbox.js:1302:25)
      javascript.0	2019-03-10 12:12:39.914	warn	State "0" not found
      javascript.0	2019-03-10 12:12:39.914	info	script.js.Test.TestVarIdBlock: 0
      javascript.0	2019-03-10 12:12:39.914	info	Start javascript script.js.Test.TestVarIdBlock
      Da passiert, neuerdings, einiges im Hintergrund.
      Ich habe aber nun das Gefühl, dass sich die Probleme mit der asynchronen Scriptabarbeitung häufen.
      Ein simples "aktualisiere Datenpunkt mit xy" und danach den Wert ausgeben ist nicht mehr möglich.
      Der Datenpunkt wird aktualisiert, aber die Ausgabe bringt den alten Wert. (Das war mal anders)
      Wenn da bei jeder Aktion ein "Debug-Prozess" gestartet wird, würde mich das nicht verwundern.
      Oder ist das alles nur ein subjektives Empfinden von mir?
        Homoran Global Moderator Administrators @rantanplan last edited by
        @rantanplan sagte in [Frage] [Blockly/JavaScript] v.4.1.12 Alles etwas langsamer?:
        Ja!
        es wurde ein neuer Namespace "ScriptProblem" anglegt, in dem Fehler in Scripten einen Datenpunkt auf true setzen um die Fehlersuche bei Abstürzen zu erleichtern.
        Dies ist in den Objekten in der Expertenansicht zu sehen
          paul53 @rantanplan last edited by paul53
          @rantanplan sagte:
          Das war in Blockly noch nie anders. Die Wertausgabe "danach" muss in der Callback-Funktion erfolgen, was funktioniert.
          Der Wert war voher 2.
          rantanplan 1 Reply Last reply Reply Quote 0
          • rantanplan
            Na, das kann aber "lustig" werden. Gerade bei "Anfängern" werden da einige Scripts in die Hose gehen, die vorher problemlos gelaufen sind. (Meine Scripts werde ich wohl auch noch mal durchschauen)
            Und die LOG-Ausgabe sagt MIR auch nichts.
            Die Ausgabe, die ich gepostet habe, erfolgte als ich einer boolschen Variable einen nummerischen Wert zugewiesen habe.
            Über 20 Einträge ohne einen konkreten Fehlerhinweis. Für mich also völlig sinnlos.
            Ich wäre dafür diese Option schaltbar zu machen. Am besten pro Script.
            Wenn dann eins Probleme macht, kann man es ja dafür einschalten. Wem auch immer dann die Log-Einträge etwas sagen.
            Aber dieses Szenario default mäßig zu aktivieren, bringt wahrscheinlich mehr Probleme als es löst.
            Sehe gerade in meinem Log, das es da wohl noch mehr Probleme gibt.
            javascript.0	2019-03-10 12:13:38.539	info	Start javascript script.js.Test.TestVarIdBlock
            javascript.0	2019-03-10 12:14:11.585	info	Stop script script.js.Test.TestVarIdBlock
            javascript.1	2019-03-10 12:14:11.585	info	Stop script script.js.Test.TestVarIdBlock
            Script arbeitet definitiev nur in javascript.0
            Werde ich mal beobachten und gegebenenfalls ein issue aufmachen.
            • rantanplan
              rantanplan @paul53 last edited by
              @paul53 sagte in [Frage] [Blockly/JavaScript] v.4.1.12 Alles etwas langsamer?:
              @rantanplan sagte:
              Bei "steuere" kann ich das bestätigen(Ack). Aber bei "aktualisiere" funktionierte es.
                Das war dann Zufall !
                79.9k
                blockly javascript
