    2. Русский
    3. ioBroker
    4. ioBroker драйвера
    5. Onkyo
    Onkyo
    • I
      instalator last edited by
      Вот появилось предупреждение в логе
      ! onkyo-0 2015-05-08 18:18:05 debug Received: command[NTM10:49/–:--]
      ! onkyo-0 2015-05-08 18:18:05 debug Received: net-usb-time-info[undefined]
      ! onkyo-0 2015-05-08 18:18:05 info Got message: {"command":"net-usb-time-info","iscp_command":"NTM10:49/–:--"}
      ! onkyo-0 2015-05-08 18:18:04 warn non controllable state: onkyo.0.master-volume
      ! onkyo-0 2015-05-08 18:18:04 info stateChange onkyo.0.master-volume {"val":15,"ack":false,"ts":1431083885,"from":"system.adapter.web.0","lc":1431083885}
      ! inMem 2015-05-08 18:18:04 debug message onkyo.0.* onkyo.0.master-volume val=15, ack=false, ts=1431083885, from=system.adapter.web.0, lc=1431083885
      ! onkyo-0 2015-05-08 18:18:04 info stateChange onkyo.0.command {"val":"NTM10:48/--:--","ack":true,"ts":1431083885,"from":"system.adapter.onkyo.0","lc":1431083885}
      ! inMem 2015-05-08 18:18:04 debug message onkyo.0.* onkyo.0.command val=NTM10:48/--:--, ack=true, ts=1431083885, from=system.adapter.onkyo.0, lc=1431083885
      ! onkyo-0 2015-05-08 18:18:04 debug Received: command[NTM10:48/–:--]
      ! onkyo-0 2015-05-08 18:18:04 debug Received: net-usb-time-info[undefined]
      ! onkyo-0 2015-05-08 18:18:04 info Got message: {"command":"net-usb-time-info","iscp_command":"NTM10:48/–:--"}
      ! onkyo-0 2015-05-08 18:18:04 warn non controllable state: onkyo.0.volume
      Могу дать доступ через тимвьювер
      • I
        Переустановил еще раз драйвер онки, вообще не работает.
        ! Server-PC 2015-05-08 22:56:46 info host.Server-PC Restart adapter system.adapter.onkyo.0 because enabled
        ! Server-PC 2015-05-08 22:56:46 error host.Server-PC instance system.adapter.onkyo.0 terminated with code 6 (uncaught exception)
        ! Server-PC 2015-05-08 22:56:43 info host.Server-PC instance system.adapter.onkyo.0 started with pid 4852
        ! Server-PC 2015-05-08 22:56:31 info host.Server-PC Restart adapter system.adapter.onkyo.0 because enabled
        ! Server-PC 2015-05-08 22:56:31 error host.Server-PC instance system.adapter.onkyo.0 terminated with code 6 (uncaught exception)
        ! Server-PC 2015-05-08 22:56:28 info host.Server-PC instance system.adapter.onkyo.0 started with pid 4772
        ! host-Server-PC 2015-05-08 23:56:13 info Restart adapter system.adapter.onkyo.0 because enabled
        ! host-Server-PC 2015-05-08 23:56:13 error instance system.adapter.onkyo.0 terminated with code 6 (uncaught exception)
        ! onkyo-0 2015-05-08 23:56:12 info stateChange onkyo.0.connected {"val":true,"ack":true,"ts":1431104173,"from":"system.adapter.onkyo.0","lc":1431103712}
        ! inMem 2015-05-08 23:56:12 debug message onkyo.0.* onkyo.0.connected val=true, ack=true, ts=1431104173, from=system.adapter.onkyo.0, lc=1431103712
        ! TypeError: 2015-05-08 23:56:12 error at readableAddChunk (_stream_readable.js:166:9)
        ! TypeError: 2015-05-08 23:56:12 error at emitReadable (stream_readable.js:423:5)
        (_stream_readable.js:427:10)
        ! TypeError: 2015-05-08 23:56:12 error at Socket.emit (events.js:92:17)
        ! TypeError: 2015-05-08 23:56:12 error at Socket. (_stream_readable.js:765:14)
        ! TypeError: 2015-05-08 23:56:12 error at Socket.emit (events.js:95:17)
        ! TypeError: 2015-05-08 23:56:12 error at Socket. (c:\ioBroker\node_modules\iobroker.onkyo\node_modules\eiscp\eiscp.js:369:8)
        ! TypeError: 2015-05-08 23:56:12 error at EventEmitter.emit (events.js:95:17)
        ! TypeError: 2015-05-08 23:56:12 error at EventEmitter. (c:\ioBroker\node_modules\iobroker.onkyo\onkyo.js:189:13)
        ! TypeError: 2015-05-08 23:56:12 error at notifyCommand (c:\ioBroker\node_modules\iobroker.onkyo\onkyo.js:88:31)
        ! TypeError: 2015-05-08 23:56:12 error Cannot read property 'command' of undefined
        ! uncaught 2015-05-08 23:56:12 error exception: Cannot read property 'command' of undefined
        • Bluefox
          Bluefox last edited by
          @instalator:
          почему по громкости 2 переменные?
          onkyo.0.master-volume Master volume Master volume 44 true onkyo.0 2015-05-08 17:16:22 2015-05-08 17:16:22
          onkyo.0.volume Volume Volume 44 true onkyo.0 2015-05-08 17:16:22 2015-05-08 17:16:22 `
          Это мне у тебя надо спросить 😄 Чем отличаются volume От Master volume?
          • Bluefox
            Можешь ещё попробовать?
            cd /opt/iobroker
            ./iobroker del onkyo
            npm install https://github.com/ioBroker/ioBroker.onkyo/tarball/master
            ./iobroker add onkyo
            Потом снова IP настроить.
            Терпение. Мы уже близко к решению 😉
            • I
              @Bluefox:
              cd /opt/iobroker
              Терпение. Мы уже близко к решению 😉 `
              Да я терплю) новый лог:
              ! onkyo-0 2015-05-09 11:48:49 warn non controllable state: onkyo.0.volume
              ! onkyo-0 2015-05-09 11:48:49 info stateChange onkyo.0.volume {'val':43,'ack':false,'ts':1431146929,'from':'system.adapter.web.0','lc':1431146929}
              ! onkyo-0 2015-05-09 11:48:48 warn non controllable state: onkyo.0.volume
              ! onkyo-0 2015-05-09 11:48:48 info stateChange onkyo.0.volume {'val':0,'ack':false,'ts':1431146928,'from':'system.adapter.web.0','lc':1431146928}
              ! onkyo-0 2015-05-09 11:48:46 warn non controllable state: onkyo.0.master-volume
              ! onkyo-0 2015-05-09 11:48:46 info stateChange onkyo.0.master-volume {'val':30,'ack':false,'ts':1431146926,'from':'system.adapter.web.0','lc':1431146926}
              ! onkyo-0 2015-05-09 11:48:45 warn non controllable state: onkyo.0.master-volume
              ! onkyo-0 2015-05-09 11:48:45 info stateChange onkyo.0.master-volume {'val':0,'ack':false,'ts':1431146925,'from':'system.adapter.web.0','lc':1431146925}
              ! onkyo-0 2015-05-09 11:47:05 info stateChange onkyo.0.command {'val':'SLI05','ack':true,'ts':1431146825,'from':'system.adapter.onkyo.0','lc':1431146825}
              ! onkyo-0 2015-05-09 11:47:05 info stateChange onkyo.0.input {'val':['video6','pc'],'ack':true,'ts':1431146825,'from':'system.adapter.onkyo.0','lc':1431146825}
              ! onkyo-0 2015-05-09 11:47:05 info Got message: {'command':'input-selector','argument':['video6','pc'],'iscp_command':'SLI05'}
              ! onkyo-0 2015-05-09 11:47:05 info stateChange onkyo.0.listening-mode {'val':'all-ch-stereo','ack':true,'ts':1431146825,'from':'system.adapter.onkyo.0','lc':1431146825}
              ! onkyo-0 2015-05-09 11:47:05 info stateChange onkyo.0.command {'val':'LMD0C','ack':true,'ts':1431146825,'from':'system.adapter.onkyo.0','lc':1431146825}
              ! onkyo-0 2015-05-09 11:47:05 info Create new object: onkyo.0.listening-mode, type = media
              ! onkyo-0 2015-05-09 11:47:05 info Got message: {'command':'listening-mode','argument':'all-ch-stereo','iscp_command':'LMD0C'}
              ! onkyo-0 2015-05-09 11:47:04 info stateChange onkyo.0.command {'val':'NLTF300000000090000FFFF00NE\u001a\r\nISCP\u0000\u0000\u0000\u0010\u0000\u0000\u0000\u000b\u0001\u0000\u0000\u0000!1NLSC0C','ack':true,'ts':1431146825,'from':'system.adapter.onkyo.0','lc':1431146825}
              ! onkyo-0 2015-05-09 11:47:04 error Empty command string! (value: undefined
              ! onkyo-0 2015-05-09 11:47:04 info Got message: {'iscp_command':'NLTF300000000090000FFFF00NE\u001a\r\nISCP\u0000\u0000\u0000\u0010\u0000\u0000\u0000\u000b\u0001\u0000\u0000\u0000!1NLSC0C'}
              ! onkyo-0 2015-05-09 11:47:04 info stateChange onkyo.0.command {'val':'NLSC-P','ack':true,'ts':1431146825,'from':'system.adapter.onkyo.0','lc':1431146825}
              ! onkyo-0 2015-05-09 11:47:04 info Got message: {'command':'net-usb-list-info','iscp_command':'NLSC-P'}
              ! onkyo-0 2015-05-09 11:45:32 info Error: ERROR (cmd_not_supported) Command master-volume in zone main is not supported on this model.
              ! onkyo-0 2015-05-09 11:45:32 info Initial query: master-volume
              ! onkyo-0 2015-05-09 11:45:32 info Error: ERROR (cmd_not_supported) Command volume in zone main is not supported on this model.
              ! onkyo-0 2015-05-09 11:45:32 info Initial query: volume
              ! onkyo-0 2015-05-09 11:45:32 info Error: ERROR (cmd_not_supported) Command audio-muting in zone main is not supported on this model.
              ! onkyo-0 2015-05-09 11:45:32 info Initial query: audio-muting
              ! onkyo-0 2015-05-09 11:45:32 info Error: ERROR (cmd_not_supported) Command system-power in zone main is not supported on this model.
              ! onkyo-0 2015-05-09 11:45:32 info Initial query: system-power
              ! onkyo-0 2015-05-09 11:45:32 info Error: ERROR (cmd_not_supported) Command input-selector in zone main is not supported on this model.
              ! onkyo-0 2015-05-09 11:45:32 info Initial query: input-selector
              ! onkyo-0 2015-05-09 11:45:28 info stateChange onkyo.0.command {'val':'NLSU8-My Favorites','ack':true,'ts':1431146728,'from':'system.adapter.onkyo.0','lc':1431146728}
              ! onkyo-0 2015-05-09 11:45:28 info Got message: {'command':'net-usb-list-info','iscp_command':'NLSU8-My Favorites'}
              ! onkyo-0 2015-05-09 11:45:28 info stateChange onkyo.0.command {'val':'NLSU6-Spotify\u001a\r\nISCP\u0000\u0000\u0000\u0010\u0000\u0000\u0000\u0010\u0001\u0000\u0000\u0000!1NLSU7-simfy','ack':true,'ts':1431146728,'from':'system.adapter.onkyo.0','lc':1431146728}
              ! onkyo-0 2015-05-09 11:45:28 info Got message: {'command':'net-usb-list-info','iscp_command':'NLSU6-Spotify\u001a\r\nISCP\u0000\u0000\u0000\u0010\u0000\u0000\u0000\u0010\u0001\u0000\u0000\u0000!1NLSU7-simfy'}
              ! onkyo-0 2015-05-09 11:45:27 info stateChange onkyo.0.command {'val':'NLSU5-MP3tunes','ack':true,'ts':1431146728,'from':'system.adapter.onkyo.0','lc':1431146728}
              ! onkyo-0 2015-05-09 11:45:27 info Got message: {'command':'net-usb-list-info','iscp_command':'NLSU5-MP3tunes'}
              ! onkyo-0 2015-05-09 11:45:27 info stateChange onkyo.0.command {'val':'NLSU2-DLNA\u001a\r\nISCP\u0000\u0000\u0000\u0010\u0000\u0000\u0000 \u0001\u0000\u0000\u0000!1NLSU3-AUPEO! PERSONAL RADIO\u001a\r\nISCP\u0000\u0000\u0000\u0010\u0000\u0000\u0000\u0015\u0001\u0000\u0000\u0000!1NLSU4-Home Media','ack':true,'ts':1431146728,'from':'system.adapter.onkyo.0','lc':1431146728}
              ! onkyo-0 2015-05-09 11:45:27 info Got message: {'command':'net-usb-list-info','iscp_command':'NLSU2-DLNA\u001a\r\nISCP\u0000\u0000\u0000\u0010\u0000\u0000\u0000 \u0001\u0000\u0000\u0000!1NLSU3-AUPEO! PERSONAL RADIO\u001a\r\nISCP\u0000\u0000\u0000\u0010\u0000\u0000\u0000\u0015\u0001\u0000\u0000\u0000!1NLSU4-Home Media'}
              ! onkyo-0 2015-05-09 11:45:27 info stateChange onkyo.0.command {'val':'NLSC0P\u001a\r\nISCP\u0000\u0000\u0000\u0010\u0000\u0000\u0000 \u0001\u0000\u0000\u0000!1NLSU0-vTuner Internet Radio\u001a\r\nISCP\u0000\u0000\u0000\u0010\u0000\u0000\u0000!\u0001\u0000\u0000\u0000!1NLSU1-Last.fm Internet Radio','ack':true,'ts':1431146728,'from':'system.adapter.onkyo.0','lc':1431146728}
              ! onkyo-0 2015-05-09 11:45:27 info Create new object: onkyo.0.net-usb-list-info, type = media
              ! onkyo-0 2015-05-09 11:45:27 info Got message: {'command':'net-usb-list-info','iscp_command':'NLSC0P\u001a\r\nISCP\u0000\u0000\u0000\u0010\u0000\u0000\u0000 \u0001\u0000\u0000\u0000!1NLSU0-vTuner Internet Radio\u001a\r\nISCP\u0000\u0000\u0000\u0010\u0000\u0000\u0000!\u0001\u0000\u0000\u0000!1NLSU1-Last.fm Internet Radio'}
              ! onkyo-0 2015-05-09 11:45:27 info stateChange onkyo.0.command {'val':'NLTF300000000090000FFFF00NE','ack':true,'ts':1431146727,'from':'system.adapter.onkyo.0','lc':1431146727}
              ! onkyo-0 2015-05-09 11:45:27 error Empty command string! (value: undefined
              ! onkyo-0 2015-05-09 11:45:27 info Got message: {'iscp_command':'NLTF300000000090000FFFF00NE'}
              ! onkyo-0 2015-05-09 11:45:27 info stateChange onkyo.0.connected {'val':true,'ack':true,'ts':1431146727,'from':'system.adapter.onkyo.0','lc':1431146727}
              ! onkyo-0 2015-05-09 11:45:27 info Successfully connected to AVR
              После регулировки громкости на ресивере:
              ! onkyo-0 2015-05-09 11:52:38 info stateChange onkyo.0.command {'val':'MVL24','ack':true,'ts':1431147159,'from':'system.adapter.onkyo.0','lc':1431147159}
              ! onkyo-0 2015-05-09 11:52:38 info stateChange onkyo.0.volume {'val':36,'ack':true,'ts':1431147159,'from':'system.adapter.onkyo.0','lc':1431147159}
              ! onkyo-0 2015-05-09 11:52:38 info stateChange onkyo.0.master-volume {'val':36,'ack':true,'ts':1431147159,'from':'system.adapter.onkyo.0','lc':1431147159}
              ! onkyo-0 2015-05-09 11:52:38 info Got message: {'command':['master-volume','volume'],'argument':36,'iscp_command':'MVL24'}
              ! onkyo-0 2015-05-09 11:52:38 info stateChange onkyo.0.command {'val':'MVL25','ack':true,'ts':1431147158,'from':'system.adapter.onkyo.0','lc':1431147158}
              ! onkyo-0 2015-05-09 11:52:38 info stateChange onkyo.0.volume {'val':37,'ack':true,'ts':1431147158,'from':'system.adapter.onkyo.0','lc':1431147158}
              ! onkyo-0 2015-05-09 11:52:38 info stateChange onkyo.0.master-volume {'val':37,'ack':true,'ts':1431147158,'from':'system.adapter.onkyo.0','lc':1431147158}
              ! onkyo-0 2015-05-09 11:52:38 info Got message: {'command':['master-volume','volume'],'argument':37,'iscp_command':'MVL25'}
              ! onkyo-0 2015-05-09 11:52:37 info stateChange onkyo.0.command {'val':'MVL26','ack':true,'ts':1431147157,'from':'system.adapter.onkyo.0','lc':1431147157}
              ! onkyo-0 2015-05-09 11:52:37 info stateChange onkyo.0.volume {'val':38,'ack':true,'ts':1431147157,'from':'system.adapter.onkyo.0','lc':1431147157}
              ! onkyo-0 2015-05-09 11:52:37 info stateChange onkyo.0.master-volume {'val':38,'ack':true,'ts':1431147157,'from':'system.adapter.onkyo.0','lc':1431147157}
              ! onkyo-0 2015-05-09 11:52:37 info Got message: {'command':['master-volume','volume'],'argument':38,'iscp_command':'MVL26'}
              ! onkyo-0 2015-05-09 11:52:36 info stateChange onkyo.0.command {'val':'MVL25','ack':true,'ts':1431147157,'from':'system.adapter.onkyo.0','lc':1431147157}
              ! onkyo-0 2015-05-09 11:52:36 info stateChange onkyo.0.volume {'val':37,'ack':true,'ts':1431147157,'from':'system.adapter.onkyo.0','lc':1431147157}
              ! onkyo-0 2015-05-09 11:52:36 info stateChange onkyo.0.master-volume {'val':37,'ack':true,'ts':1431147157,'from':'system.adapter.onkyo.0','lc':1431147157}
              ! onkyo-0 2015-05-09 11:52:36 info Got message: {'command':['master-volume','volume'],'argument':37,'iscp_command':'MVL25'}
              ! onkyo-0 2015-05-09 11:52:36 info stateChange onkyo.0.command {'val':'MVL22','ack':true,'ts':1431147156,'from':'system.adapter.onkyo.0','lc':1431147156}
              ! onkyo-0 2015-05-09 11:52:36 info stateChange onkyo.0.volume {'val':34,'ack':true,'ts':1431147156,'from':'system.adapter.onkyo.0','lc':1431147156}
              ! onkyo-0 2015-05-09 11:52:36 info stateChange onkyo.0.master-volume {'val':34,'ack':true,'ts':1431147156,'from':'system.adapter.onkyo.0','lc':1431147156}
              ! onkyo-0 2015-05-09 11:52:36 info Got message: {'command':['master-volume','volume'],'argument':34,'iscp_command':'MVL22'}
              ! onkyo-0 2015-05-09 11:52:35 info stateChange onkyo.0.command {'val':'MVL1D','ack':true,'ts':1431147156,'from':'system.adapter.onkyo.0','lc':1431147156}
              ! onkyo-0 2015-05-09 11:52:35 info stateChange onkyo.0.volume {'val':29,'ack':true,'ts':1431147156,'from':'system.adapter.onkyo.0','lc':1431147156}
              ! onkyo-0 2015-05-09 11:52:35 info stateChange onkyo.0.master-volume {'val':29,'ack':true,'ts':1431147156,'from':'system.adapter.onkyo.0','lc':1431147156}
              ! onkyo-0 2015-05-09 11:52:35 info Got message: {'command':['master-volume','volume'],'argument':29,'iscp_command':'MVL1D'}
              ! onkyo-0 2015-05-09 11:52:35 info stateChange onkyo.0.command {'val':'MVL15','ack':true,'ts':1431147155,'from':'system.adapter.onkyo.0','lc':1431147155}
              ! onkyo-0 2015-05-09 11:52:35 info stateChange onkyo.0.volume {'val':21,'ack':true,'ts':1431147155,'from':'system.adapter.onkyo.0','lc':1431147155}
              ! onkyo-0 2015-05-09 11:52:35 info stateChange onkyo.0.master-volume {'val':21,'ack':true,'ts':1431147155,'from':'system.adapter.onkyo.0','lc':1431147155}
              ! onkyo-0 2015-05-09 11:52:35 info Got message: {'command':['master-volume','volume'],'argument':21,'iscp_command':'MVL15'}
              ! onkyo-0 2015-05-09 11:52:34 info stateChange onkyo.0.command {'val':'MVL11','ack':true,'ts':1431147155,'from':'system.adapter.onkyo.0','lc':1431147155}
              ! onkyo-0 2015-05-09 11:52:34 info stateChange onkyo.0.volume {'val':17,'ack':true,'ts':1431147155,'from':'system.adapter.onkyo.0','lc':1431147155}
              ! onkyo-0 2015-05-09 11:52:34 info stateChange onkyo.0.master-volume {'val':17,'ack':true,'ts':1431147155,'from':'system.adapter.onkyo.0','lc':1431147155}
              Если через брокера отправить команду MVL24 уровень на ресивере и в переменной 36. При изменении то самой переменной значения правильные формирует? (если переменная 36 то в команде идет 24? там же фроде как 16тиричный код должен быть).
              Не понятно что говорит эта строчка в логе onkyo-0 2015-05-09 11:48:46 warn non controllable state: onkyo.0.master-volume т.е. переменная не контролируемая?
              • Bluefox
                Можешь показать инфу по объекту master-volume?
                • I
                  • Bluefox
                    И перезапустить драйвер.
                    • I
                      @Bluefox:
                      И перезапустить драйвер. `
                      Непомогло, сервер исчез из списка
                      ! Server-PC 2015-05-09 21:47:52 error host.Server-PC Invalid request getInstalled. "callback" or "from" is null
                      ! Server-PC 2015-05-09 21:47:52 error host.Server-PC Invalid request getRepository. "callback" or "from" is null
                      ! Server-PC 2015-05-09 21:47:43 error host.Server-PC Invalid request getInstalled. "callback" or "from" is null
                      ! Server-PC 2015-05-09 21:47:43 error host.Server-PC Invalid request getRepository. "callback" or "from" is null
                      • I
                        Рестартанул полностью брокер
                        onkyo-0 2015-05-09 21:55:00 info Error: ERROR (arg_not_in_range) Command volume=29 is not available on this model
                        onkyo-0 2015-05-09 21:55:00 info stateChange onkyo.0.volume {"val":29,"ack":false,"ts":1431186901,"from":"system.adapter.web.0","lc":1431186901}
                        inMem 2015-05-09 21:55:00 debug message onkyo.0.* onkyo.0.volume val=29, ack=false, ts=1431186901, from=system.adapter.web.0, lc=1431186901
                        Какую команду отправляешь при регулировке?
                        "MVL" - Master Volume Command
                        "00"-"64" Volume Level 0 – 100 ( In hexadecimal representation)
                        "00"-"50" Volume Level 0 – 80 ( In hexadecimal representation)
                        "UP" sets Volume Level Up
                        "DOWN" sets Volume Level Down
                        "UP1" sets Volume Level Up 1dB Step
                        "DOWN1" sets Volume Level Down 1dB Step
                        "QSTN" gets the Volume Level
                        • I
                          Повесил в vis две кнопки с командами MVLUP1 и MVLDOWN1 громкость регулирует, ползунки переменных перемещяются, единственный момент, переменная volume и master volume имеют одно значение.
                          • I
                            Ипсправлений не будет?
                              electric69 last edited by
                              Я попробовал управлять громкостью моего ресивера - просто передаю нужный уровень в переменную "onkyo.0.master-volume", громкость меняется, все ОК.
                              • Bluefox
                                Да блин у вас ресиверы не той системы. 🙂
                                Я использовал стандартный пакет https://github.com/tillbaks/node-eiscp
                                Вероятно, что у человека, который этот пакет создал ресивер немного отличается.
                                "main" : {
                                "system-power" : "PWR",
                                "audio-muting" : "AMT",
                                "speaker-a" : "SPA",
                                "speaker-b" : "SPB",
                                "speaker-layout" : "SPL",
                                "master-volume" : "MVL",
                                "volume" : "MVL",
                                "tone-front" : "TFR",
                                "tone-front-wide" : "TFW",
                                "tone-front-high" : "TFH",
                                "tone-center" : "TCT",
                                "tone-surround" : "TSR",
                                "tone-surround-back" : "TSB",
                                "tone-subwoofer" : "TSW",
                                "sleep-set" : "SLP",
                                "speaker-level-calibration" : "SLC",
                                "subwoofer-temporary-level" : "SWL",
                                "center-temporary-level" : "CTL",
                                "display-mode" : "DIF",
                                "dimmer-level" : "DIM",
                                "setup" : "OSD",
                                "memory-setup" : "MEM",
                                "audio-infomation" : "IFA",
                                "video-infomation" : "IFV",
                                "input-selector" : "SLI",
                                "recout-selector" : "SLR",
                                "audio-selector" : "SLA",
                                "12v-trigger-a" : "TGA",
                                "12v-trigger-b" : "TGB",
                                "12v-trigger-c" : "TGC",
                                "video-output-selector" : "VOS",
                                "hdmi-output-selector" : "HDO",
                                "hdmi-audio-out" : "HAO",
                                "monitor-out-resolution" : "RES",
                                "isf-mode" : "ISF",
                                "video-wide-mode" : "VWM",
                                "video-picture-mode" : "VPM",
                                "listening-mode" : "LMD",
                                "late-night" : "LTN",
                                "cinema-filter" : "RAS",
                                "audyssey-2eq-multeq-multeq-xt" : "ADY",
                                "audyssey-dynamic-eq" : "ADQ",
                                "audyssey-dynamic-volume" : "ADV",
                                "dolby-volume" : "DVL",
                                "music-optimizer" : "MOT",
                                "tuning" : "UTN",
                                "preset" : "PRS",
                                "preset-memory" : "UPM",
                                "rds-information" : "RDS",
                                "pty-scan" : "PTS",
                                "tp-scan" : "TPS",
                                "xm-channel-name-info" : "XCN",
                                "xm-artist-name-info" : "XAT",
                                "xm-title-info" : "XTI",
                                "xm-channel-number" : "XCH",
                                "xm-category" : "XCT",
                                "sirius-channel-name-info" : "SCN",
                                "sirius-artist-name-info" : "SAT",
                                "sirius-title-info" : "STI",
                                "sirius-channel-number" : "SCH",
                                "sirius-category" : "SCT",
                                "sirius-parental-lock" : "SLK",
                                "hd-radio-artist-name-info" : "UHA",
                                "hd-radio-channel-name-info" : "UHC",
                                "hd-radio-title-info" : "UHT",
                                "hd-radio-detail-info" : "UHD",
                                "hd-radio-channel-program" : "UHP",
                                "hd-radio-blend-mode" : "UHB",
                                "hd-radio-tuner-status" : "UHS",
                                "network-usb" : "NTC",
                                "net-usb-artist-name-info" : "NAT",
                                "net-usb-album-name-info" : "NAL",
                                "net-usb-title-name" : "NTI",
                                "net-usb-time-info" : "NTM",
                                "net-usb-track-info" : "NTR",
                                "net-usb-play-status" : "NST",
                                "internet-radio-preset" : "NPR",
                                "net-usb-list-info" : "NLS",
                                "net-usb-jacket-art" : "NJA",
                                "net-service" : "NSV",
                                "net-keyboard" : "NKY",
                                "net-popup-message" : "NPU",
                                "ipod-mode-change" : "IMD",
                                "cd-player" : "CCD",
                                "tape1-a" : "CT1",
                                "tape2-b" : "CT2",
                                "graphics-equalizer" : "CEQ",
                                "dat-recorder" : "CDT",
                                "dvd-player" : "CDV",
                                "md-recorder" : "CMD",
                                "cd-r-recorder" : "CCR",
                                "universal-port" : "CPT",
                                "ipod-artist-name-info" : "IAT",
                                "ipod-album-name-info" : "IAL",
                                "ipod-title-name" : "ITI",
                                "ipod-time-info" : "ITM",
                                "ipod-track-info" : "ITR",
                                "ipod-play-status" : "IST",
                                "ipod-list-info" : "ILS",
                                "dab-preset" : "UPR",
                                "dab-sation-name" : "UDS",
                                "dab-display-info" : "UDD"
                                "zone2" : {
                                "power" : "ZPW",
                                "muting" : "ZMT",
                                "volume" : "ZVL",
                                "tone" : "ZTN",
                                "balance" : "ZBL",
                                "selector" : "SLZ",
                                "tuning" : "TUZ",
                                "preset" : "PRZ",
                                "net-tune-network" : "NTZ",
                                "internet-radio-preset" : "NPZ",
                                "listening-mode" : "LMZ",
                                "late-night" : "LTZ",
                                "re-eq-academy-filter" : "RAZ"
                                "zone3" : {
                                "power" : "PW3",
                                "muting" : "MT3",
                                "volume" : "VL3",
                                "tone" : "TN3",
                                "balance" : "BL3",
                                "selector" : "SL3",
                                "tuning" : "TU3",
                                "preset" : "PR3",
                                "net-tune-network" : "NT3",
                                "internet-radio-preset" : "NP3"
                                "zone4" : {
                                "power" : "PW4",
                                "muting" : "MT4",
                                "volume" : "VL4",
                                "selector" : "SL4",
                                "tuning" : "TU4",
                                "preset" : "PR4",
                                "net-tune-network" : "NT4",
                                "internet-radio-preset" : "NP4"
                                "dock" : {
                                "command-for-docking-station-via-ri" : "CDS"
                                • Bluefox
                                  Нашел пару ошибок в подгружаемом пакете node-eiscp. Пока что форкнул и исправил.
                                  Надо включить debug level и посмотреть, что выдает.
                                  Например у меня на power=true выдает:
                                  2015-05-13 22:06:04.397  - info: onkyo.0 stateChange onkyo.0.power {"val":"true","ack":false,"ts":1431547564,"lc":1431545330}
                                  2015-05-13 22:06:04.397  - debug: inMem message  onkyo.0.* onkyo.0.power val=true, ack=false, ts=1431547564, lc=1431545330
                                  2015-05-13 22:06:04.397  - debug: onkyo.0 DEBUG (command_to_iscp) Zone: main | Command: system-power | Argument: on
                                  2015-05-13 22:06:04.397  - debug: onkyo.0 DEBUG (command_to_iscp) raw command "PWR01"
                                  Но проверить это я не могу.
                                  Если заработает, то надо подумать, какие ещё комманды необходимы, кроме громкости и вкл/выкл.
                                  • I
                                    @Bluefox:
                                    onkyo-0 2015-05-14 18:44:00 info Got message: {"command":"net-usb-time-info","iscp_command":"NTM01:15/–:--"}
                                    onkyo-0 2015-05-14 18:44:00 info Error: ERROR (arg_not_in_range) Command master-volume=46 is not available on this model
                                    Если заработает, то надо подумать, какие ещё комманды необходимы, кроме громкости и вкл/выкл. `
                                    onkyo-0 2015-05-14 18:41:58 info stateChange onkyo.0.command {"val":"PWR00","ack":true,"ts":1431607319,"from":"system.adapter.onkyo.0","lc":1431607318}
                                    onkyo-0 2015-05-14 18:41:58 info stateChange onkyo.0.power {"val":"standby","ack":true,"ts":1431607319,"from":"system.adapter.onkyo.0","lc":1431607319}
                                    onkyo-0 2015-05-14 18:41:58 debug Received: command[PWR00]
                                    onkyo-0 2015-05-14 18:41:58 debug Received: system-power[standby]
                                    ! onkyo-0 2015-05-14 18:42:43 info stateChange onkyo.0.command {"val":"NJA01FDFDFDFDFDFDFDFDFD1A64D560D5FDFDFD64C464FDFD1A1AFD1A1AC41A754C4C75C0C0C0D8D8C0696969C069C075757538C438BCD5C4C4D5D5C4FD6460D5D56064FDFDFDFDFDFDFDFDFDFDFDFDFDFD
                                    ! onkyo-0 2015-05-14 18:42:43 debug ISCP!1NJA01F7F7F7F7F7F7F7F7F7F7641A64D560F7C4D804293B3B3B3B3B3B4444581D44443B4444443B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B443B3B3B3B3B443B3B6239066906C0387564F71AF7F7F7F7F7F7F7F
                                    ! onkyo-0 2015-05-14 18:42:43 debug ISCP!1NJA01F7F7F7F7F7F7F7F764F7F7F7F760F7BCBCC406E01C3B3B44444444444444443B1D4444443B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B443B3B3B444444443BD222ED0606697538D5D5F7C48A8AD5D5F7F7F7F7D5D
                                    ! onkyo-0 2015-05-14 18:42:43 debug ISCP!1NJA01F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7D5C46460ED049E3B3B3B3B3B3B443B3B4444443B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B2D49150606066938D5D5F7F7F7F7F7F7F7F7F7F7F7F7F7F7F
                                    ! onkyo-0 2015-05-14 18:42:43 debug ISCP!1NJA01F7F7F7F7F7F7F7F7F7F7F7F7F7F7C4F7F71AC460D149B21C3B3B443B3B443B3B3B3B443B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B443B3B3B3B3B3B441C968E67690669386057F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F
                                    ! onkyo-0 2015-05-14 18:42:43 debug ISCP!1NJA01F7F7F7F7F7F7F7F7F7F7F7F7F7C464F7F760C41A1A1AED399329443B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B443BE49EB240ED06066902C0751A1A1AF7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F
                                    ! onkyo-0 2015-05-14 18:42:43 debug ISCP!1NJA01F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F76464F7C438383806493F314DE4443B3B3B3B3B3B3B3B3B3B3B3B3B443B3B3B3B3B1D9AEF96406706060606C0D838F7F764F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7FDFDFDFDFDFDF
                                    ! onkyo-0 2015-05-14 18:42:43 debug ISCP!1NJA01FDFDFDFDFDFDFDFDFDFDFD6464C41A64FDFD601AFD6475751A7569ED2422E0989F62EBE41D444444441D4D29D23F987122246706C0C06906C07575C4FDFD64C4C4FDFD1AFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF
                                    ! onkyo-0 2015-05-14 18:42:43 debug ISCP!1NJA01FDFDFDFDFDFDFDFDFDFDFDFDFDFDFD1A57FDFDFDFDFDD51A1A1A757563D8D869066767676767671F1F67ED066969690669696969637538C4BCD5D56460FDFDFD64FDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF
                                    ! onkyo-0 2015-05-14 18:42:43 debug Received: command[NJA01FDFDFDFDFDFDFDFDFD1A64D560D5FDFDFD64C464FDFD1A1AFD1A1AC41A754C4C75C0C0C0D8D8C0696969C069C075757538C438BCD5C4C4D5D5C4FD6460D5D56064FDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFD
                                    ! onkyo-0 2015-05-14 18:42:43 debug Received: net-usb-jacket-art[undefined]
                                    ! onkyo-0 2015-05-14 18:42:43 info Got message: {"command":"net-usb-jacket-art","iscp_command":"NJA01FDFDFDFDFDFDFDFDFD1A64D560D5FDFDFD64C464FDFD1A1AFD1A1AC41A754C4C75C0C0C0D8D8C0696969C069C075757538C438BCD5C4C4D5D5C4FD6460D5D56064FDF
                                    ! onkyo-0 2015-05-14 18:42:43 info stateChange onkyo.0.command {"val":"CBCBCC4D5BCD5D5D5D564FDFD64FDFDD564FDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFD8A8A8A8A8A8A8A8A8A8A8A8A000000FDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFD","ack":true
                                    ! onkyo-0 2015-05-14 18:42:43 info stateChange onkyo.0.command {"val":"NJA015AFF594843FF953B21FF181717FFE5BAADFFD5D5D6FFEEC1B5FF3C3C3CFF3E3C3BFF78716FFF87594AFF8B4835FFDFA699FF3E4040FF943B21FFFEFFFFFFC8C0B3FF88695AFF785D60FF6C4D3EFF7C
                                    ! onkyo-0 2015-05-14 18:42:43 info stateChange onkyo.0.command {"val":"F6A321BFF8C3E23FF72331AFF994130FFAD8F83FFFEFEFFFF3E2113FFE9CAC0FFD5A699FFE8E7E9FFBCB7B2FF752B16FFB68A78FFFCFAFCFF8E7B73FF605D5BFF3F0B00FFE4B2A5FF515051\u001a\r\nIS
                                    ! onkyo-0 2015-05-14 18:42:43 info stateChange onkyo.0.command {"val":"NJA01433EFF804E3AFF973D22FFF3D9CCFFDBD9D7FF9D432AFFA03922FF935845FF624F41FFF7F8F8FFC19C8DFF2C2A2CFF090506FF93604FFFC5C6C5FFFDFFFBFFF5EAEAFFA4A2A0FFC8C0BEFFBEBBBBFF
                                    ! onkyo-0 2015-05-14 18:42:43 info stateChange onkyo.0.command {"val":"NJA00424D36F60000000000003604000028000000790000008000000001000800000000000000000000000000000000000001000000010000DFCDC4FFFDFDF6FFEAE9E6FF878584FF808081FFF9C9BCFFDC
                                    ! onkyo-0 2015-05-14 18:42:43 debug Received: command[CBCBCC4D5BCD5D5D5D564FDFD64FDFDD564FDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFD8A8A8A8A8A8A8A8A8A8A8A8A000000FDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFD]
                                    ! onkyo-0 2015-05-14 18:42:43 error Empty command string! (value: undefined
                                    ! onkyo-0 2015-05-14 18:42:43 info Got message: {"iscp_command":"CBCBCC4D5BCD5D5D5D564FDFD64FDFDD564FDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFD8A8A8A8A8A8A8A8A8A8A8A8A000000FDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFD"}
                                    ! onkyo-0 2015-05-14 18:42:43 debug ISCP!1NJA01FDFDFDFDFDFDFDFDFDFDFDFDD560D5FDFDFDFD6060FDFDFDFDFD606064FD60C4FD1A383838]
                                    ! onkyo-0 2015-05-14 18:42:43 debug ISCP!1NJA018A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8AF7F7F7F7F7F7F7F7F7F7F7F7F7FD8A8A8A8A8AF7F7F7F78A8A8AF7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7FDFDFDFDFDF
                                    ! onkyo-0 2015-05-14 18:42:43 debug ISCP!1NJA01FDFDFDFDFDFDFDFDFDFDFDFDF7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F
                                    ! onkyo-0 2015-05-14 18:42:43 debug ISCP!1NJA01FDFD8A8A8A8A8A8A8A8A8A8A8AFDFDFDFD8A8A8A8A8AFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDFDF
                                    ! onkyo-0 2015-05-14 18:42:43 debug ISCP!1NJA018A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A8A6B6B6B6B6B6B6B6B6B6B6B6B6B6B6B6B6B6B6B6B6B6B6B6B6B6B6B6B6B6
                                    ! onkyo-0 2015-05-14 18:42:43 debug Received: command[NJA015AFF594843FF953B21FF181717FFE5BAADFFD5D5D6FFEEC1B5FF3C3C3CFF3E3C3BFF78716FFF87594AFF8B4835FFDFA699FF3E4040FF943B21FFFEFFFFFFC8C0B3FF88695AFF785D60FF6C4D3EFF7C4A33FFFFFFFFFF886D
                                    Вообще чудеса какието. На команды то он реагирует, а вот на переменную громкости нет.
                                    • I
                                      Выложил список команд.
                                      У меня Onkyo 818
                                      266_tx-nr616_latest_232_codes.rar
                                      • I
                                        После обновления вообще не работает, постоянно переподключается
                                        ! onkyo-0 2015-05-14 19:06:01 debug statesDB connected
                                        ! onkyo-0 2015-05-14 19:06:01 debug objectDB connected
                                        ! onkyo-0 2015-05-14 19:05:39 debug statesDB connected
                                        ! onkyo-0 2015-05-14 19:05:39 debug objectDB connected
                                        ! onkyo-0 2015-05-14 19:05:27 debug statesDB connected
                                        ! onkyo-0 2015-05-14 19:05:27 debug objectDB connected
                                        ! onkyo-0 2015-05-14 19:05:17 debug statesDB connected
                                        ! onkyo-0 2015-05-14 19:05:17 debug objectDB connected
                                        ! onkyo-0 2015-05-14 19:05:04 info Connecting to AVR 192.168.1.210:60128
                                        ! onkyo-0 2015-05-14 19:05:04 info starting. Version 0.1.3 in c:/ioBroker/node_modules/iobroker.onkyo
                                        ! onkyo-0 2015-05-14 19:05:03 debug statesDB connected
                                        ! onkyo-0 2015-05-14 19:05:03 debug objectDB connected
                                        ! onkyo-0 2015-05-14 19:04:51 info Connecting to AVR 192.168.1.210:60128
                                        ! onkyo-0 2015-05-14 19:04:51 info starting. Version 0.1.3 in c:/ioBroker/node_modules/iobroker.onkyo
                                        ! onkyo-0 2015-05-14 19:04:50 debug statesDB connected
                                        ! onkyo-0 2015-05-14 19:04:50 debug objectDB connected
                                        ! onkyo-0 2015-05-14 19:04:37 debug statesDB connected
                                        ! onkyo-0 2015-05-14 19:04:37 debug objectDB connected
                                        ! onkyo-0 2015-05-14 19:04:27 info Connecting to AVR 192.168.1.210:60128
                                        ! onkyo-0 2015-05-14 19:04:27 info starting. Version 0.1.3 in c:/ioBroker/node_modules/iobroker.onkyo
                                        ! onkyo-0 2015-05-14 19:04:27 debug statesDB connected
                                        ! onkyo-0 2015-05-14 19:04:27 debug objectDB connected
                                        ! onkyo-0 2015-05-14 19:04:12 info Connecting to AVR 192.168.1.210:60128
                                        ! onkyo-0 2015-05-14 19:04:12 info starting. Version 0.1.3 in c:/ioBroker/node_modules/iobroker.onkyo
                                        ! onkyo-0 2015-05-14 19:04:12 debug statesDB connected
                                        ! onkyo-0 2015-05-14 19:04:12 debug objectDB connected
                                        ! onkyo-0 2015-05-14 19:03:58 info Connecting to AVR 192.168.1.210:60128
                                        ! onkyo-0 2015-05-14 19:03:58 info starting. Version 0.1.3 in c:/ioBroker/node_modules/iobroker.onkyo
                                        ! onkyo-0 2015-05-14 19:03:58 debug statesDB connected
                                        ! onkyo-0 2015-05-14 19:03:58 debug objectDB connected
                                        host-Server-PC 2015-05-14 19:08:29 info Restart adapter system.adapter.onkyo.0 because enabled
                                        host-Server-PC 2015-05-14 19:08:29 error instance system.adapter.onkyo.0 terminated with code 6 (uncaught exception)
                                        386_discovery_-_fronius.txt
                                        • I
                                          Так и не работает драйвер вообще, постоянно перезапускается, пока отключил вообще.
                                            @instalator:
                                            Так и не работает драйвер вообще, постоянно перезапускается, пока отключил вообще. `
                                            Тоже адаптер не стартует, в логе ошибки:
                                            21937
