    4. Wunsch: Pollenflug-(Adapter/wasauchimmer)
      Homoran Global Moderator Administrators @Nashra last edited by Homoran
      @Nashra
      Das Script läuft bei mir ohne Fehler
      Welche wirft es denn bei dir ?
      Du hast es aber als Ts Importiert
      • Nashra
        Nashra Most Active Forum Testing @Homoran last edited by
        @Homoran sagte in Wunsch: Pollenflug-(Adapter/wasauchimmer):
        @Nashra
        Ein kleiner Auszug...
        javascript.0 2019-03-02 08:43:47.045 warn at process._tickCallback (internal/process/next_tick.js:181:9)
        javascript.0 2019-03-02 08:43:47.045 warn at _combinedTickCallback (internal/process/next_tick.js:139:11)
        javascript.0 2019-03-02 08:43:47.044 warn at endReadableNT (_stream_readable.js:1064:12)
        javascript.0 2019-03-02 08:43:47.044 warn at IncomingMessage.emit (events.js:208:7)
        javascript.0 2019-03-02 08:43:47.044 warn at emitNone (events.js:111:20)
        javascript.0 2019-03-02 08:43:47.044 warn at Object.onceWrapper (events.js:313:30)
        javascript.0 2019-03-02 08:43:47.044 warn at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:1083:12)
        javascript.0 2019-03-02 08:43:47.044 warn at Request.emit (events.js:211:7)
        javascript.0 2019-03-02 08:43:47.044 warn at emitOne (events.js:116:13)
        javascript.0 2019-03-02 08:43:47.044 warn at Request.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:1161:10)
        javascript.0 2019-03-02 08:43:47.043 warn at Request.emit (events.js:214:7)
        javascript.0 2019-03-02 08:43:47.043 warn at emitTwo (events.js:126:13)
        javascript.0 2019-03-02 08:43:47.043 warn at Request.self.callback (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:185:22)
        javascript.0 2019-03-02 08:43:47.043 warn at Request._callback (script.js.Meine_Geräte.Pollenflug:276:21)
        javascript.0 2019-03-02 08:43:47.043 warn at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1258:20)
        javascript.0 2019-03-02 08:43:47.042 warn Wrong type of javascript.0.wetter.pollenvorhersage.d5.ambrosia: "undefined". Please fix, while deprecated and will not work in next versions.
        javascript.0 2019-03-02 08:43:47.041 warn at process._tickCallback (internal/process/next_tick.js:181:9)
        javascript.0 2019-03-02 08:43:47.041 warn at _combinedTickCallback (internal/process/next_tick.js:139:11)
        javascript.0 2019-03-02 08:43:47.041 warn at endReadableNT (_stream_readable.js:1064:12)
        javascript.0 2019-03-02 08:43:47.041 warn at IncomingMessage.emit (events.js:208:7)
        javascript.0 2019-03-02 08:43:47.041 warn at emitNone (events.js:111:20)
        javascript.0 2019-03-02 08:43:47.040 warn at Object.onceWrapper (events.js:313:30)
        javascript.0 2019-03-02 08:43:47.040 warn at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:1083:12)
        javascript.0 2019-03-02 08:43:47.040 warn at Request.emit (events.js:211:7)
        javascript.0 2019-03-02 08:43:47.040 warn at emitOne (events.js:116:13)
        javascript.0 2019-03-02 08:43:47.040 warn at Request.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:1161:10)
        javascript.0 2019-03-02 08:43:47.040 warn at Request.emit (events.js:214:7)
        javascript.0 2019-03-02 08:43:47.040 warn at emitTwo (events.js:126:13)
        javascript.0 2019-03-02 08:43:47.040 warn at Request.self.callback (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:185:22)
        javascript.0 2019-03-02 08:43:47.039 warn at Request._callback (script.js.Meine_Geräte.Pollenflug:276:21)
        Ja, als TS importiert
          @Nashra sagte in Wunsch: Pollenflug-(Adapter/wasauchimmer):
          Welche Datenpunkte hat das Skript bei dir angelegt?
          • Nashra
            Von d0 bis d6, Inhalt gleich
              @Nashra
              Ohne inhalt?
              • Nashra
                @Nashra
                Ohne inhalt?
                Doch doch, Inhalt ist vorhanden und im VIS wird auch alles angezeigt. Nur eben die Warnungen wenn
                es die Daten abfragt. Also es wird zwar alles geholt aber eben mit Warn im Log.
                • SBorg
                  An welchem Adapter (Version) es liegt kann ich nicht mehr genau sagen, aber anscheinend wird da "request" nicht mehr richtig registriert. Mit einem Adapter aus dem "latest" geht es dann gar nicht mehr 😉
                    ich habe es nicht mehr ans laufen bekommen.
                    So lange ich nichts geändert hatte lief es auch bei mir.
                    Ich denke es liegt am redesign der Website.
                    da ich nicht skripten kann habe ich es heute vor der Installation des Adapters noch mit dem Parser versucht. klappte auch ganz gut mit dem Quelltext, "in echt" kam dann aber eine "forbidden"
                    Wetter-online schiebt da den robots wohl einen Riegel vor
                    • Segway
                      Segway @SBorg last edited by
                      @SBorg sagte in Wunsch: Pollenflug-(Adapter/wasauchimmer):
                      Ich müsst bei mir folgende Zeile auskommentieren - seitdem läuft das Skript einwandfrei:
                      // import request = require("request");
                      • Stuebi
                        Stuebi last edited by
                        so würde es jetzt aussehen:
                        • SBorg
                          SBorg Forum Testing Most Active @Homoran last edited by
                          Jepp, deswegen bin ich auf die bash ausgewichen. Mittels wget kann man sich als "normaler Browser" tarnen 🙂
                            Homoran Global Moderator Administrators @Stuebi last edited by
                            @Stuebi Jetzt bist du im falschen Thread 😂
                            und der screenshot ist arg klein für meine alten Augen
                            Stuebi 1 Reply Last reply Reply Quote 0
                            • Stuebi
                              Stuebi @Homoran last edited by
                              @Homoran, mal auf den Screenshot klicken. Dann wird der größer. Eben viele Infos jetzt die zur Verfügung gestellt werden.
                                @Stuebi sagte in Wunsch: Pollenflug-(Adapter/wasauchimmer):
                                klar - aber nicht groß genug
                                  Homoran Global Moderator Administrators @Segway last edited by
                                  @Segway
                                  Das nutzt auch nichts 😞
                                  • Stuebi
                                    Okay, dann könnt Ihr jetzt Testen wenn Ihr wollt. Entweder bis Morgen warten, dann sollte der Adapter als Update auftauchen oder Ihr könnt ihn jetzt über Adapter -> Katze oben (beliebiger Link) und dann https://github.com/schmupu/ioBroker.pollenflug einfügen.
                                    • Segway
                                      Segway @Homoran last edited by
                                      Welche Version hast du vom Skript ? Bei mir gings nur mit der 1.51
                                        Homoran Global Moderator Administrators @Segway last edited by Homoran
                                        @Segway
                                        und genau die habe ich
                                        Aber ich bilde mir ein jemand hätte hier eine 1.6.0 gehabt
                                        • Segway
                                          @Homoran
                                          Ich kann es ja mal hier rein stellen, dann kannste es mal vergleichen ? Mit WInMerge oder so ob was anders ist ?
                                            @Segway
                                            Es ist schon seltsam.
                                            ich bin habe einer Installation auf dem Tinkerboard, die ich schon lange mitschleppe auf eine nagelneue in einer Proxmox-VM auf einem NUC gewechselt und sukzessive alles mögliche dahinkopiert.
                                            Bis dahin lief das Skript noch auf dem Tinker, auf dem NUC nicht.
                                            Ich habe alle Versionen (admin/js-Adapter) gleich gehabt.
                                            Dann habe ich auch am Tinker irgendwas verändert, ab da lief auch dort das Skript nicht mehr.
                                            Jetzt habe ich heute auf dem NUC das Skript komplett gelöscht und von hier aus dem Forum
                                            Kann gut möglich sein, k.A. was da ggf. Markup veranstaltet 😉
                                            Nochmal als Datei: Pollenflug.ts
                                            neu eingearbeitet.
                                            Ort eingegeben - Nur Fehler, alle die gleiche Zeile betreffend:
                                            11:57:38.194	warn	javascript.0 at Request._callback (script.js.Wetter_und_Klima.Pollenskript:276:21)
                                            Habe das
                                            auskommentiert - noch mehr Fehler
                                            Jetzt werden nicht einmal mehr die States angelegt.
                                            Ich habe keine Ahnung woran das liegt
                                            EDIT:
                                            States ware warum auch immer ausgefiltert - ein refresh hat sie weider hervorgeholt, aber leer, bzw. 0
                                            Habe noch zwei weitere Installationen "gefunden" auf denen noch das uralte Skript von Steinwedel/pix und das Summenskript von der_Auge läuft.
                                            Werte bis jetzt aktuell (zumindest der Timestamp)
                                            Auch dieses Skript habe ich nicht mehr ans Laufen bekommen. 1:1 kopiert
                                            266
                                            44117
