    4. Wunsch: Pollenflug-(Adapter/wasauchimmer)
      Homoran Global Moderator Administrators @SBorg last edited by
      @SBorg sagte in Wunsch: Pollenflug-(Adapter/wasauchimmer):
      ^^ Solange man es anscheinend kpl. in Ruhe lässt funktioniert es...
      Das ist genau das was ich beobachte und NICHT verstehe
        Homoran Global Moderator Administrators @AlCalzone last edited by
        @AlCalzone
        läuft wunderbar:
        14:03:36.927	info	javascript.1 Stop script script.js.Wetter_und_Klima.request_test
        14:03:36.929	info	javascript.0 Stop script script.js.Wetter_und_Klima.request_test
        14:03:40.311	info	javascript.0 script.js.Wetter_und_Klima.request_test: compiling TypeScript source...
        14:03:40.311	info	javascript.0 script.js.Wetter_und_Klima.request_test: TypeScript compilation successful
        14:03:40.311	info	javascript.0 script.js.Wetter_und_Klima.request_test: registered 0 subscriptions and 0 schedules
        14:03:41.180	info	javascript.0 script.js.Wetter_und_Klima.request_test: https://apod.nasa.gov/apod/image/1903/M82Magnet_SOFIA_960.jpg
        14:03:41.180	info	javascript.0 script.js.Wetter_und_Klima.request_test: Are galaxies giant magnets? Yes, but the magnetic fields in galaxies are typically much weaker than on Earth's surface, as well as more complex and harder to measure. Recently, though, the HAWC+ instrument onboard the airborne (747) SOFIA observatory has been successful in detailing distant magnetic fields by observing infrared light polarized by reflection from dust grains. Featured here, HAWC+ observations of the M82, the Cigar galaxy, show that the central magnetic field is perpendicular to the disk and parallel to the strong supergalactic wind. This observation bolsters the hypothesis that M82's central magnetic field helps its wind transport the mass of millions of stars out from the central star-burst region. The featured image shows magnetic field lines superposed on top of an optical light (gray) and hydrogen gas (red) image from Kitt Peak National Observatory, further combined with infrared images (yellow) from SOFIA and the Spitzer Space Telescope. The Cigar Galaxy is about 12 million light years distant and visible with binoculars towards the constellation of the Great Bear.
        • Nashra
          Habe gerade mal versucht im js Request einzutragen. Kleingeschrieben steht es schon drin
          aber ich dachte, nachdem was ich hier gelesen habe, versuch es mal mit Großschreibung
          also so: Request
          Ergebnis:
          javascript.0	2019-03-11 14:04:32.312	info	npm install Request --production --prefix "/opt/iobroker/node_modules/iobroker.javascript" (System call)
          javascript.0	2019-03-11 14:04:32.309	error	Cannot install Request: 1
          javascript.0	2019-03-11 14:04:32.251	error	npm ERR! A complete log of this run can be found in: npm ERR! /home/iobroker/.npm/_logs/2019-03-11T13_04_32_241Z-debug.log
          javascript.0	2019-03-11 14:04:32.249	error
          javascript.0	2019-03-11 14:04:32.235	error	ERR! 404 Not Found: Request@latest
          javascript.0	2019-03-11 14:04:32.233	error
          javascript.0	2019-03-11 14:04:32.230	error	npm
          javascript.0	2019-03-11 14:04:32.224	error	ERR! code E404
          javascript.0	2019-03-11 14:04:32.223	error	npm
          javascript.0	2019-03-11 14:04:27.455	info	npm install Request --production --prefix "/opt/iobroker/node_modules/iobroker.javascript" (System call)
            Homoran Global Moderator Administrators @Nashra last edited by
            @Nashra
            ich habe jetzt beide wieder rausgenommen, da request ja schon im js-Adapter integriert sein soll.
            Hilft auch nicht
            • SBorg
              Danke @AlCalzone
              Ich debuge es gerade, Daten kommen, aber nicht so wie sie wohl waren/sollen.
              ...und fragt nicht warum es mal ging, oder jetzt nicht geht, oder... 😉
              • Nashra
                Nachtrag noch von mir...
                Fehlermeldungen ohne Ende aber Datenpunkte sind angelegt und werden auch gefüllt.
                  Homoran Global Moderator Administrators @SBorg last edited by Homoran
                  @SBorg
                  ich hatte mal den Quelltext heruntergelden und bei regex101 getestet.
                  Das klappte ganz gut.
                  Im Parser Adapter bekam ich dann live eine 503 forbidden
                  Da kann ich ja keinen useragent eingeben
                    Mir fällt gerade die Meldung auf:
                    Das heisst doch:
                    sobald man das Skript anfasst wird es neu kompiliert!
                    ...und dann läuft es nicht mehr
                    • SBorg
                      Wie heißt es immer so schön: ich habe eine gute und eine schlechte Nachricht...
                      Die "gute": ich weiß woran es liegt...
                      die "schlechte": ich bin dann mal raus...
                      Eigentlich sollte es mit aktuellen Werten bei keinem mehr funktionieren, außer Wetteronline macht noch was anderes bei einigen URLs. Bei "meiner" ist es eindeutig so, dass der Webseiten-Parser nicht mehr zum Inhalt der Seite passt. Somit kann, wie schon @AlCalzone schrieb, er keine Daten mehr von der Seite verarbeiten. Er müsste also neu geschrieben werden. Ob ich das hin bekäme weiß ich nicht, aber ich habe für mich schon eine funktionsfähige andere Variante, so dass die Priorität hinter meinen eigenen derzeitigen Projekten läge. Sieht also von meiner Seite eher schlecht aus 😞
                      Nashra 1 Reply Last reply Reply Quote 1
                      • Nashra
                        Nashra Most Active Forum Testing @SBorg last edited by
                        Schade aber trotzdem vielen Dank für die Mühe die Du dir gemacht hast 👍
                        • AlCalzone
                          AlCalzone Developer @Homoran last edited by
                          @Homoran sagte in Wunsch: Pollenflug-(Adapter/wasauchimmer):
                          Das macht der Adapter bei jedem Start eines TypeScripts (also bei Änderung und bei Adapterstart).
                          • Segway
                            Segway @Homoran last edited by
                            ob ich das mal machen sollte?
                            Hattest du das mal bei dir gemacht ? Habe das mal installiert allerdings zeigte das Debian nach einem Neustart wieder die alte 6.4.1 bei mir an ... weiss immer noch nicht wodran das liegt
                              Homoran Global Moderator Administrators @Segway last edited by
                              @Segway sagte in Wunsch: Pollenflug-(Adapter/wasauchimmer):
                              Ja!
                              und npm -v ergibt auch brav 6.9.0
                              • Segway
                                Ja!
                                mit --> npm install -g npm ?
                                  Homoran Global Moderator Administrators @Segway last edited by Homoran
                                  @Segway nein als user pi mit
                                  sudo -H npm install -g npm
                                  • Segway
                                    Segway @Homoran last edited by Segway
                                    @Homoran
                                    Update hm-rega from @2.3.1 to @2.3.2
                                    NPM version: 6.9.0
                                    • SmarthomeMF
                                      SmarthomeMF last edited by
                                      Hallo
                                      Hatte das Skript das ganze letzte Jahr am laufen
                                      // Polleninfo auswerten heute und die nächsten Tage
                                      // Version 1.4
                                      • Initiale Optionen
                                        interface iRequestOptions {
                                        url: string;
                                        headers: any;
                                      var baseUrl: string = "https://www.wetteronline.de/pollen/perg";
                                      var baseObjPath: string = 'wetter.pollenvorhersage';
                                      • Globale TypeScript Definitionen
                                        Die folgenden Funktionen sind bei mir in einem globalen script.
                                        Wenn man diese global definieren will, muss man das lokal referenzieren mit:
                                        declare function isPrimitive(obj:any):boolean
                                        declare function logDebug(...param: any[]):void;
                                        declare function logInfo(...param: any[]):void;
                                        declare function logWarning(...param: any[]):void;
                                        declare function logError(...param: any[]):void;
                                      • Function for check if a object is a primitive object (string, number, etc)
                                      • @param obj any object to check if it is a primitive object
                                      • @returns boolean which is true if object in parameter is a primitive object
                                        function isPrimitive(obj:any):boolean {
                                        return (obj !== Object(obj));
                                      • write any objects given as parameter to log as debug
                                      • @param param a nist of different objects
                                        function logDebug(...param: any[]):void {
                                        if (arguments.length > 0) {
                                        var text:string[] = [];
                                        for (var i = 0; i < arguments.length; i++) {
                                        if (typeof arguments[i] === 'string' || arguments[i] instanceof String) {
                                        text.push(arguments[i]);
                                        } else if(arguments[i] === null) {
                                        text.push('null');
                                        } else if(arguments[i] === undefined) {
                                        text.push('undefined');
                                        } else if (isPrimitive(arguments[i])) {
                                        } else {
                                        text.push(JSON.stringify(arguments[i]));
                                        //enum close bracket cannot be found in "channel[state.id=
                                        .TEMPERATURE](rooms=WZ|Wohnung|Wohnzimmer"
                                        log(text.join(' '), 'debug');
                                      • write any objects given as parameter to log as Information
                                        function logInfo(...param: any[]):void {
                                        text.push('null');
                                        } else {
                                        log(text.join(' '), 'info');
                                        setState("javascript.0.Ereignisliste.event",'INFO|'+text.join(' '));
                                        //logEnhanced(logtext, 'info');
                                        //console.debug(p);
                                        //logs(logtext,loglevels.debug);
                                      • write any objects given as parameter to log as warning
                                        function logWarning(...param: any[]):void {
                                        text.push('null');
                                        } else {
                                        log(text.join(' '), 'warn');
                                        setState("javascript.0.Ereignisliste.event",'WARN|'+text.join(' '));
                                        //logEnhanced(logtext, 'warn');
                                        //console.warn(p);
                                        //logs(logtext,loglevels.warn);
                                      • write any objects given as parameter to log as error
                                        function logError(...param: any[]):void {
                                        text.push('null');
                                        } else {
                                        log(text.join(' '), 'error');
                                        setState("javascript.0.Ereignisliste.event",'ERROR|'+text.join(' '));
                                        // Lokale TypeScript Definitionen
                                        import request = require("request");
                                      var Pollenarten:string[] = ['Erle','Hasel','Pappel','Weide','Ulme','Birke','Buche','Ampfer','Roggen','Gräser','Eiche','Wegerich','Beifuß','Ambrosia'];
                                      var tageVorhersage = ['d0','d1','d2','d3','d4','d5'];
                                      var tageVorhersageName = ['heute','morgen','übermorgen','heute + 3','heute + 4','heute + 5'];
                                      function stripTags(data:string):string {
                                      return data.replace(/( |<([^>]+)>)/ig, "");
                                      function getDate(days: number): string { // Eingabe 0, 1, 2, ...
                                      var jetzt = new Date();
                                      jetzt.setHours(0);
                                      jetzt.setMinutes(0);
                                      jetzt.setSeconds(0);
                                      jetzt.setMilliseconds(0);
                                      var newdate = new Date();
                                      newdate.setTime(jetzt.getTime() + (24 * 60 * 60 * 1000 * days) ); // heute + anzahl tage ins Millisekunden
                                      var date :string = newdate.getDate().toString();
                                      var month: string = (newdate.getMonth()+1).toString();
                                      var year: string = newdate.getFullYear().toString();
                                      date = (date.length < 2) ? '0' + date : date;
                                      month = (month.length < 2) ? '0' + month : month;
                                      var result:string = year+month+date;
                                      logDebug('Datum in Link: ', result);
                                      return (result); // Ausgabe z.B. 20160506
                                      function GetPollenIndex(pflanze:string, html:string):number {
                                      var code ={'kein':0, 'schwach':1, 'mäßig':2, 'stark':3};
                                      var result:string= "";
                                      var start:number =html.indexOf(pflanze)+pflanze.length;
                                      result=html.slice(start);
                                      result=result.trim();
                                      //logDebug('result for ',pflanze,html.slice(0,600));
                                      var stop:number =result.indexOf(' ');
                                      result=result.slice(0,stop);
                                      logDebug('pflanze=',pflanze,'code=',result);
                                      return code[result];
                                      function initializePollenwetter(baseObj:string, name:string):void {
                                      createState(baseObj,0,false, {
                                      type: "string",
                                      role: 'json',
                                      read: true,
                                      write: false});
                                      for(var i=0;i<Pollenarten.length;i++) {
                                        createState(baseObj + '.' + Pollenarten[i].toLowerCase(),0,false, {
                                           name: 'Pollenart '+ Pollenarten[i],
                                           type: "number",
                                           role: 'value',
                                           read: true,
                                           write: false});
                                      function removeOldPollenwetter():void {
                                      deleteState(baseObjPath + '.' + Pollenarten[i].toLowerCase());
                                      function readPollenwetterForDay(day:number, baseObj:string):void {
                                      logDebug("Start");
                                      try {
                                      var options:iRequestOptions = {
                                      url: ((day>0) ? baseUrl + '?fcdatstr=' + getDate(day) : baseUrl), // korrekten Link erstellen ,
                                      headers: {
                                      'User-Agent': 'Mozilla/5.0 (Windows NT 6.1; WOW64; rv:40.0) Gecko/20100101 Firefox/40.1'
                                      request(options, function (error, response, body):void {
                                      if (!error && response.statusCode == 200) { // kein Fehler, Inhalt in body
                                      body=body.replace(/\t/g, ' ');
                                      body=body.replace(/(\n|\r)/g, '');
                                      var start:number =body.indexOf('<ul id="pollentable">');
                                      if (start>-1) { body=body.slice(start); }
                                      body=stripTags(body);
                                      //logDebug('body',body);
                                      let pobj:any = {};
                                      for(let i=0;i<Pollenarten.length;i++) {
                                      let pi:number = GetPollenIndex(Pollenarten[i],body);
                                      pobj[Pollenarten[i].toLowerCase()] = pi;
                                      setState(baseObj+'.'+Pollenarten[i].toLowerCase(),pi);
                                      setState(baseObj,JSON.stringify(pobj));
                                      } else {
                                      logInfo("StatusCode="+response.statusCode);
                                      logError(error); // Error beim Einlesen
                                      } catch (e) {
                                      logError('Fehler (try) leseWebseite: ' + e);
                                      function readPollenwetter() {
                                      for (let d:number = 0; d < tageVorhersage.length; d++) {
                                      let path: string = baseObjPath + '.' + tageVorhersage[d];
                                      initializePollenwetter(path, tageVorhersageName[d]);
                                      readPollenwetterForDay(d, path);
                                      removeOldPollenwetter();
                                      readPollenwetter();
                                      schedule("5 0 * * *", readPollenwetter);
                                      nun nach dem Winter habe ich es wieder gestartet!
                                      nun gleich einen ERROR
                                      [s=]```
                                      20:20:23.749	error	javascript.0 script.js.common.Polleninfo compile failed:
                                       at script.js.common.Polleninfo:9
                                      ```[/s]
                                      Das ich gerade gesehen habe das es auch bereits einen Adapter gibt habe ich ihn probiert.
                                      Nur geht das nicht weil ich aus österreich bin und dafür keine Eonstellungen giebt.
                                      Was bedeutet der Error.
                                      • SmarthomeMF
                                        • SBorg
                                          Du kannst die letzten ~50 Posts bei Interesse dazu lesen, oder kurz und schmerzlos: der Aufbau der Seite hat sich geändert und der Parser funktioniert nicht mehr...
                                            @SBorg
                                            und wenn jemand Zeit, Lust und die Fähigkeit hat das Skript zu modifizieren (mir fehlt vor allem letzteres), habe ich schon mal etwas vorbereitet
                                            Mit dem Regex
                                            day0="(\w+)
                                            erhält man für die 14 Pollenarten die heutige Warnstufe
                                            Ändert man day0 auf day1 ist das die morgige Warnstufe, day2 übermorgen usw.
                                            Als Ergebnis kommen vier verschiedene Worte heraus: noburden, weakburden, moderateburden und strongborden, was den Intensitäten 0-3 entspricht, was dann noch umgerechnet werden muss.
                                            Mit dem Parser geht es leider nicht, da kommt 503-forbidden.
                                            (Oder kann man im Aufruf der Adresse einen Useragent mitgeben?)
                                            Die entsprechenden Pollenarten erhält man mit
                                            xt">(\w+)
                                            Wobei ich davon ausgehe, dass sich die Reihenfolge nicht ändert und man einfach 0=Erle, 1=Hasel usw. festlegen kännte
                                            SBorg AlCalzone 2 Replies Last reply Reply Quote 0
                                            266
                                            44140
