    2. English
    3. Visualization
    4. getting started with visualisations
      Taragorm last edited by
      Thanks, I will do some more reading.
      What do you mean with custom editor? Custom editor of the parameter field, like color picker or OID Selector?
      Yes. Probably won't need it right away, but I like to know "how stuff works".
      -T
      Bluefox 1 Reply Last reply Reply Quote 0
      • Bluefox
        Bluefox @Taragorm last edited by Bluefox
        @Taragorm There is no easy possibility for that, but your callback will be called after the value set:
        if you define the attribute like attrName[defaultValue]/type/callbackName
        Example: https://github.com/ioBroker/ioBroker.vis-hqwidgets/blob/master/widgets/hqwidgets.html#L41
        So the callback must exists vis.binds.evohome.callbackName, like here:
        https://github.com/ioBroker/ioBroker.vis-hqwidgets/blob/master/widgets/hqwidgets/js/hqwidgets.js#L3069
        Of course you can overload the code and bind your own click handler on the button, but for that you must know, how vis editor works, and jquery.... and naming.
          Thanks. I'll leave that alone for now then. 🙂
            Another question - what is the best procedure for visualisation development?
            I have a local project (under home) that contains the development package; I can install that using the customURL function.
            So far, so good.
            After I've changed the package, and re-installed, nothing seems to change, so there must be more to it.
            • Bluefox
              @Taragorm Have you seen that? https://github.com/ioBroker/ioBroker/wiki/How-to-debug-vis-and-to-write-own-widget-set
              T S 2 Replies Last reply Reply Quote 0
                Taragorm @Bluefox last edited by
                @Bluefox I have, and I think I followed the instructions, but if I reinstall my adaptor using "from custom URL", nothing much seems to change, even if I restart iobroker.
                Clearly I'm doing something wrong?
                • Bluefox
                  @Taragorm I do it like this.
                  My folder structure is like this one:
                  /opt/iobroker
                          iobroker.my-new-adapter
                          node_modules
                                 iobroker.js-controle
                                 iobroker.xxxx
                  Then I install my new adapter by writing npm i iobroker.my-new-adapter in /opt/iobroker.
                  As result the npm creates a sym-link to my developer folder:
                  /opt/iobroker
                          node_modules
                                 iobroker.my-new-adapter (symlink)
                                 iobroker.xxxx
                  after that I develop my adapter as usual in /opt/iobroker/iobroker.my-new-adapter even as a git repo.
                  after every change I write iobroker r vis && iobroker u vis This should work 100%.
                  Additionally I can write iobroker visdebug my-new-adapter and if I see the output
                  Disable cache I restart the iobroker (only for the first time).
                  After that I can directly modify the file /opt/iobroker/iobroker-data/files/vis/widgets/my-new-adapter.html and after every browser refresh it will be loaded anew from disk. So you can fast see your changes.
                  But, the changes in /opt/iobroker/iobroker-data/files/vis/widgets/my-new-adapter.html must be copied to /opt/iobroker/iobroker.my-new-adapter/widgets/ manually and you may not call iobroker u vis till you do that, else they will be overwritten
                    Thanks - that's exactly what I needed to know
                      Hmm.
                      The module is iobroker.vis-taragorm
                      iobroker@iobrokerdev /o/iobroker> iobroker visdebug vis-taragorm
                      /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupVisDebug.js:64
                                  if (!adapterDir) throw 'Adapter not found. Tried: ' + adapterNames2Try.join(', ');
                      Adapter not found. Tried: vis-vis-taragorm, vis-taragorm
                      however, vis-taragorm.html does exist in widgets, and there is an instance installed ok. I can't see my widget in the list though.
                      Possiby unrelated, I should also note that I got some errors installing (and many warnings, but I didn't include those):
                      unix_dgram.target.mk:101: recipe for target 'Release/obj.target/unix_dgram/src/unix_dgram.o' failed
                      make: *** [Release/obj.target/unix_dgram/src/unix_dgram.o] Error 1
                      make: Leaving directory '/opt/iobroker/node_modules/unix-dgram/build'
                      gyp ERR! build error
                      gyp ERR! stack Error: `make` failed with exit code: 2
                      gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
                      gyp ERR! stack     at ChildProcess.emit (events.js:197:13)
                      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:254:12)
                      gyp ERR! System Linux 4.9.0-8-amd64
                      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                      gyp ERR! cwd /opt/iobroker/node_modules/unix-dgram
                      gyp ERR! node -v v11.10.1
                      gyp ERR! node-gyp -v v3.8.0
                      gyp ERR! not ok
                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 (node_modules/unix-dgram):
                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 install: `node-gyp rebuild`
                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                      The last message implies this isn't fatal, but I'm new to NodeJS...
                      The dev env is Debian Stretch
                      iobroker@iobrokerdev ~/projects> uname -a
                      Linux iobrokerdev 4.9.0-8-amd64 #1 SMP Debian 4.9.130-2 (2018-10-27) x86_64 GNU/Linux
                      • Bluefox
                        Участник @Taragorm написал в getting started with visualisations:
                        It would be easier, if I can see the repo on github.
                        Do you have file /opt/iobroker/node_modules/iobroker.vis-taragorm/widgets/taragorm.html ?
                        • Bluefox
                          BTW, you can deliver in your adapter https://github.com/Taragorm/ioBroker.evohome the widgets too. It is even better.
                            Thanks for the quick response!
                            The repo is up at: https://github.com/Taragorm/ioBroker.vis-taragorm
                            It's mostly template right now.
                            This is intended for some generic visualisations (and to practice in) so I didn't include it in the evohome repo. I'll add some specific visualisations there once I know what I'm doing.
                              @Bluefox
                              iobroker@iobrokerdev ~/projects> ls -l /opt/iobroker/node_modules/iobroker.vis-taragorm/widgets
                              total 12
                              drwxrwxrwx+ 4 iobroker iobroker 4096 Mar  2 10:26 vis-taragorm/
                              -rw-r--r--+ 1 iobroker iobroker 6521 Mar  2 11:47 vis-taragorm.html
                              Seems to be there...
                              • Bluefox
                                @Taragorm No matter. With iobroker r vis && iobroker u vis it should work.
                                Not Fast, but work.
                                Just tried to execute (windows):
                                and cannot see any errors
                                  Something broken with my install, maybe?
                                  I added a bit of logging to the empty catch block (line 24 here):
                                      this.enableDebug = function (widgetset) {
                                          console.log( "widgetset=" + widgetset );
                                          if (widgetset) {
                                              // Try to find out the adapter directory out of a list of options
                                              var adapterDir;
                                              var adapterNames2Try = ['vis-' + widgetset, widgetset];
                                              if (adapterNames2Try[0] === adapterNames2Try[1]) adapterNames2Try.splice(1, 1);
                                              for (var i = 0; i < adapterNames2Try.length; i++) {
                                                  try {
                                                      var adapterDir2Try = tools.getAdapterDir(adapterNames2Try[i]);
                                                      // Query the entry
                                                      var stats = fs.lstatSync(adapterDir2Try);
                                                      console.log(stats.toString() );
                                                      // Is it a directory?
                                                      if (stats.isDirectory()) {
                                                          //found it!
                                                          adapterDir = adapterDir2Try;
                                                          break;
                                                  } catch (e) {
                                                      console.error(e);
                                  and got this:
                                  widgetset=vis-taragorm
                                  TypeError [ERR_INVALID_ARG_TYPE]: The "path" argument must be one of type string, Buffer, or URL. Received type object
                                      at Object.lstatSync (fs.js:857:3)
                                      at VisDebug.enableDebug (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupVisDebug.js:52:36)
                                      at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2464:30
                                      at Object.connected (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3145:70)
                                      at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:87:68)
                                      at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
                                      at Socket.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:138:10)
                                      at Socket.onconnect (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:335:8)
                                      at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:232:12)
                                      at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                                  [object Object]
                                  /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupVisDebug.js:67
                                  • Bluefox
                                    @Taragorm Can it be, that you have js-controller 1.4.2? Please update to 1.5.7
                                      Certainly looks to be 1.4.2
                                      iobroker@iobrokerdev /o/iobroker> npm outdated
                                      Package                 Current  Wanted  Latest  Location
                                      iobroker.js-controller    1.4.2   1.4.2   1.5.7  iobroker.inst
                                      yargs                     7.1.0   7.1.0  13.2.2  iobroker.inst
                                      main iobroker package calls for "stable", rather than a particular rev - do I just alter the depend there and npm update - or is there a "proper" way to do it?
                                      • Bluefox
                                        @Taragorm via npm is ok. Just stop iob before update
                                          Update
                                          Reloaded iobroker from scratch, just to be sure
                                          Updated iob.js-controller to 1.5.7
                                          iobroker@iobrokerdev /o/iobroker> npm list iobroker.js-controller
                                          iobroker.inst@2.0.2 /opt/iobroker
                                          └── iobroker.js-controller@1.5.7
                                          Same error on iob visdebug
                                          Also
                                          Lots of warnings caused by this:
                                          └─┬ iobroker.js-controller@1.5.7
                                            └─┬ winston-syslog@1.2.6
                                              └── UNMET OPTIONAL DEPENDENCY unix-dgram@~0.2.1
                                          Is there any way to suppress it? I hate clutter in the logfiles!
                                          Also2
                                          I can't see my widget in the vis builder. There's no obvious error in the log tho.
                                            done a bit more digging into the visdebug error, and it seems like the project folder isn't being recognised as a directory:
                                            Trying:/opt/iobroker/iobroker.vis-taragorm
                                            Got stats:{"dev":2049,"mode":41471,"nlink":1,"uid":1001,"gid":1001,"rdev":0,"blksize":4096,"ino":792374,"size":24,"blocks":0,"atimeMs":1552471012718.894,"mtimeMs":1552471012714.892,"ctimeMs":1552471012714.892,"birthtimeMs":1552471012714.892,"atime":"2019-03-13T09:56:52.719Z","mtime":"2019-03-13T09:56:52.715Z","ctime":"2019-03-13T09:56:52.715Z","birthtime":"2019-03-13T09:56:52.715Z"}  isDir=false
                                            trace code:
        console.log("Trying:" + process.cwd() + "/" + adapterNames2Try[i]);
        // Query the entry
        console.log("Got stats:" + JSON.stringify(stats) + "  isDir=" + stats.isDirectory());
                                            But it surely is a dir:
                                            iobroker@iobrokerdev /o/iobroker> ls -l
                                            total 248
                                            -rw-rwxr--+   1 iobroker iobroker   1474 Mar 13 09:40 CHANGELOG_INSTALLER_LINUX.md*
                                            drwxrwxr-x+   3 iobroker iobroker   4096 Mar 13 09:40 install/
                                            -rwxrwxrwx+   1 iobroker iobroker    169 Mar 13 09:41 INSTALLER_INFO.txt*
                                            lrwxrwxrwx    1 iobroker iobroker     22 Mar 13 09:41 iob -> /opt/iobroker/iobroker*
                                            -rwxrwxr-x+   1 iobroker iobroker    209 Mar 13 09:41 iobroker*
                                            drwxrwxrwx+   4 iobroker iobroker   4096 Mar 13 09:42 iobroker-data/
                                            drwxrwxrwx+   8 iobroker iobroker   4096 Mar 13 09:59 iobroker.vis-taragorm/
                                            -rw-rwxrw-+   1 iobroker iobroker     92 Mar 13 09:41 killall.sh*
                                            drwxrwxr-x+   2 iobroker iobroker   4096 Mar 13 09:40 lib/
                                            -rw-rwxr--+   1 iobroker iobroker   1137 Mar 13 09:40 LICENSE*
                                            drwxrwxrwx+   2 iobroker iobroker   4096 Mar 13 09:41 log/
                                            drwxrwxr-x+ 451 iobroker iobroker  20480 Mar 13 09:56 node_modules/
                                            -rw-rwxrw-+   1 iobroker iobroker    658 Mar 13 09:56 package.json*
                                            -rw-rwxrw-+   1 iobroker iobroker 166878 Mar 13 09:41 package-lock.json*
                                            -rw-rwxr--+   1 iobroker iobroker   6101 Mar 13 09:40 README.md*
                                            -rw-rw-rw-+   1 iobroker iobroker   5868 Mar 13 09:51 reinstall.js
                                            -rw-rwxrw-+   1 iobroker iobroker    709 Mar 13 09:41 reinstall.sh*
                                            it's as if fs is misbehaving?
                                            vis
                                            5539
