    2. English
    3. Visualization
    4. getting started with visualisations
      Taragorm last edited by
      Another question - what is the best procedure for visualisation development?
      I have a local project (under home) that contains the development package; I can install that using the customURL function.
      So far, so good.
      After I've changed the package, and re-installed, nothing seems to change, so there must be more to it.
      Bluefox 1 Reply Last reply Reply Quote 0
      • Bluefox
        Bluefox @Taragorm last edited by
        @Taragorm Have you seen that? https://github.com/ioBroker/ioBroker/wiki/How-to-debug-vis-and-to-write-own-widget-set
        T S 2 Replies Last reply Reply Quote 0
          Taragorm @Bluefox last edited by
          @Bluefox I have, and I think I followed the instructions, but if I reinstall my adaptor using "from custom URL", nothing much seems to change, even if I restart iobroker.
          Clearly I'm doing something wrong?
          • Bluefox
            Bluefox @Taragorm last edited by Bluefox
            @Taragorm I do it like this.
            My folder structure is like this one:
            /opt/iobroker
                    iobroker.my-new-adapter
                    node_modules
                           iobroker.js-controle
                           iobroker.xxxx
            Then I install my new adapter by writing npm i iobroker.my-new-adapter in /opt/iobroker.
            As result the npm creates a sym-link to my developer folder:
            /opt/iobroker
                    node_modules
                           iobroker.my-new-adapter (symlink)
                           iobroker.xxxx
            after that I develop my adapter as usual in /opt/iobroker/iobroker.my-new-adapter even as a git repo.
            after every change I write iobroker r vis && iobroker u vis This should work 100%.
            Additionally I can write iobroker visdebug my-new-adapter and if I see the output
            Disable cache I restart the iobroker (only for the first time).
            After that I can directly modify the file /opt/iobroker/iobroker-data/files/vis/widgets/my-new-adapter.html and after every browser refresh it will be loaded anew from disk. So you can fast see your changes.
            But, the changes in /opt/iobroker/iobroker-data/files/vis/widgets/my-new-adapter.html must be copied to /opt/iobroker/iobroker.my-new-adapter/widgets/ manually and you may not call iobroker u vis till you do that, else they will be overwritten
              Thanks - that's exactly what I needed to know
                Hmm.
                The module is iobroker.vis-taragorm
                iobroker@iobrokerdev /o/iobroker> iobroker visdebug vis-taragorm
                /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupVisDebug.js:64
                            if (!adapterDir) throw 'Adapter not found. Tried: ' + adapterNames2Try.join(', ');
                Adapter not found. Tried: vis-vis-taragorm, vis-taragorm
                however, vis-taragorm.html does exist in widgets, and there is an instance installed ok. I can't see my widget in the list though.
                Possiby unrelated, I should also note that I got some errors installing (and many warnings, but I didn't include those):
                unix_dgram.target.mk:101: recipe for target 'Release/obj.target/unix_dgram/src/unix_dgram.o' failed
                make: *** [Release/obj.target/unix_dgram/src/unix_dgram.o] Error 1
                make: Leaving directory '/opt/iobroker/node_modules/unix-dgram/build'
                gyp ERR! build error
                gyp ERR! stack Error: `make` failed with exit code: 2
                gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
                gyp ERR! stack     at ChildProcess.emit (events.js:197:13)
                gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:254:12)
                gyp ERR! System Linux 4.9.0-8-amd64
                gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                gyp ERR! cwd /opt/iobroker/node_modules/unix-dgram
                gyp ERR! node -v v11.10.1
                gyp ERR! node-gyp -v v3.8.0
                gyp ERR! not ok
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 (node_modules/unix-dgram):
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 install: `node-gyp rebuild`
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                The last message implies this isn't fatal, but I'm new to NodeJS...
                The dev env is Debian Stretch
                iobroker@iobrokerdev ~/projects> uname -a
                Linux iobrokerdev 4.9.0-8-amd64 #1 SMP Debian 4.9.130-2 (2018-10-27) x86_64 GNU/Linux
                • Bluefox
                  Участник @Taragorm написал в getting started with visualisations:
                  It would be easier, if I can see the repo on github.
                  Do you have file /opt/iobroker/node_modules/iobroker.vis-taragorm/widgets/taragorm.html ?
                  • Bluefox
                    BTW, you can deliver in your adapter https://github.com/Taragorm/ioBroker.evohome the widgets too. It is even better.
                      Thanks for the quick response!
                      The repo is up at: https://github.com/Taragorm/ioBroker.vis-taragorm
                      It's mostly template right now.
                      This is intended for some generic visualisations (and to practice in) so I didn't include it in the evohome repo. I'll add some specific visualisations there once I know what I'm doing.
                        @Bluefox
                        iobroker@iobrokerdev ~/projects> ls -l /opt/iobroker/node_modules/iobroker.vis-taragorm/widgets
                        total 12
                        drwxrwxrwx+ 4 iobroker iobroker 4096 Mar  2 10:26 vis-taragorm/
                        -rw-r--r--+ 1 iobroker iobroker 6521 Mar  2 11:47 vis-taragorm.html
                        Seems to be there...
                        • Bluefox
                          @Taragorm No matter. With iobroker r vis && iobroker u vis it should work.
                          Not Fast, but work.
                          Just tried to execute (windows):
                          and cannot see any errors
                            Something broken with my install, maybe?
                            I added a bit of logging to the empty catch block (line 24 here):
                                this.enableDebug = function (widgetset) {
                                    console.log( "widgetset=" + widgetset );
                                    if (widgetset) {
                                        // Try to find out the adapter directory out of a list of options
                                        var adapterDir;
                                        var adapterNames2Try = ['vis-' + widgetset, widgetset];
                                        if (adapterNames2Try[0] === adapterNames2Try[1]) adapterNames2Try.splice(1, 1);
                                        for (var i = 0; i < adapterNames2Try.length; i++) {
                                            try {
                                                var adapterDir2Try = tools.getAdapterDir(adapterNames2Try[i]);
                                                // Query the entry
                                                var stats = fs.lstatSync(adapterDir2Try);
                                                console.log(stats.toString() );
                                                // Is it a directory?
                                                if (stats.isDirectory()) {
                                                    //found it!
                                                    adapterDir = adapterDir2Try;
                                                    break;
                                            } catch (e) {
                                                console.error(e);
                            and got this:
                            widgetset=vis-taragorm
                            TypeError [ERR_INVALID_ARG_TYPE]: The "path" argument must be one of type string, Buffer, or URL. Received type object
                                at Object.lstatSync (fs.js:857:3)
                                at VisDebug.enableDebug (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupVisDebug.js:52:36)
                                at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2464:30
                                at Object.connected (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3145:70)
                                at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:87:68)
                                at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
                                at Socket.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:138:10)
                                at Socket.onconnect (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:335:8)
                                at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:232:12)
                                at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                            [object Object]
                            /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupVisDebug.js:67
                            • Bluefox
                              @Taragorm Can it be, that you have js-controller 1.4.2? Please update to 1.5.7
                                Certainly looks to be 1.4.2
                                iobroker@iobrokerdev /o/iobroker> npm outdated
                                Package                 Current  Wanted  Latest  Location
                                iobroker.js-controller    1.4.2   1.4.2   1.5.7  iobroker.inst
                                yargs                     7.1.0   7.1.0  13.2.2  iobroker.inst
                                main iobroker package calls for "stable", rather than a particular rev - do I just alter the depend there and npm update - or is there a "proper" way to do it?
                                • Bluefox
                                  @Taragorm via npm is ok. Just stop iob before update
                                    Update
                                    Reloaded iobroker from scratch, just to be sure
                                    Updated iob.js-controller to 1.5.7
                                    iobroker@iobrokerdev /o/iobroker> npm list iobroker.js-controller
                                    iobroker.inst@2.0.2 /opt/iobroker
                                    └── iobroker.js-controller@1.5.7
                                    Same error on iob visdebug
                                    Also
                                    Lots of warnings caused by this:
                                    └─┬ iobroker.js-controller@1.5.7
                                      └─┬ winston-syslog@1.2.6
                                        └── UNMET OPTIONAL DEPENDENCY unix-dgram@~0.2.1
                                    Is there any way to suppress it? I hate clutter in the logfiles!
                                    Also2
                                    I can't see my widget in the vis builder. There's no obvious error in the log tho.
                                      done a bit more digging into the visdebug error, and it seems like the project folder isn't being recognised as a directory:
                                      Trying:/opt/iobroker/iobroker.vis-taragorm
                                      Got stats:{"dev":2049,"mode":41471,"nlink":1,"uid":1001,"gid":1001,"rdev":0,"blksize":4096,"ino":792374,"size":24,"blocks":0,"atimeMs":1552471012718.894,"mtimeMs":1552471012714.892,"ctimeMs":1552471012714.892,"birthtimeMs":1552471012714.892,"atime":"2019-03-13T09:56:52.719Z","mtime":"2019-03-13T09:56:52.715Z","ctime":"2019-03-13T09:56:52.715Z","birthtime":"2019-03-13T09:56:52.715Z"}  isDir=false
                                      trace code:
                                                          console.log("Trying:" + process.cwd() + "/" + adapterNames2Try[i]);
                                                          // Query the entry
                                                          console.log("Got stats:" + JSON.stringify(stats) + "  isDir=" + stats.isDirectory());
                                      But it surely is a dir:
                                      iobroker@iobrokerdev /o/iobroker> ls -l
                                      total 248
                                      -rw-rwxr--+   1 iobroker iobroker   1474 Mar 13 09:40 CHANGELOG_INSTALLER_LINUX.md*
                                      drwxrwxr-x+   3 iobroker iobroker   4096 Mar 13 09:40 install/
                                      -rwxrwxrwx+   1 iobroker iobroker    169 Mar 13 09:41 INSTALLER_INFO.txt*
                                      lrwxrwxrwx    1 iobroker iobroker     22 Mar 13 09:41 iob -> /opt/iobroker/iobroker*
                                      -rwxrwxr-x+   1 iobroker iobroker    209 Mar 13 09:41 iobroker*
                                      drwxrwxrwx+   4 iobroker iobroker   4096 Mar 13 09:42 iobroker-data/
                                      drwxrwxrwx+   8 iobroker iobroker   4096 Mar 13 09:59 iobroker.vis-taragorm/
                                      -rw-rwxrw-+   1 iobroker iobroker     92 Mar 13 09:41 killall.sh*
                                      drwxrwxr-x+   2 iobroker iobroker   4096 Mar 13 09:40 lib/
                                      -rw-rwxr--+   1 iobroker iobroker   1137 Mar 13 09:40 LICENSE*
                                      drwxrwxrwx+   2 iobroker iobroker   4096 Mar 13 09:41 log/
                                      drwxrwxr-x+ 451 iobroker iobroker  20480 Mar 13 09:56 node_modules/
                                      -rw-rwxrw-+   1 iobroker iobroker    658 Mar 13 09:56 package.json*
                                      -rw-rwxrw-+   1 iobroker iobroker 166878 Mar 13 09:41 package-lock.json*
                                      -rw-rwxr--+   1 iobroker iobroker   6101 Mar 13 09:40 README.md*
                                      -rw-rw-rw-+   1 iobroker iobroker   5868 Mar 13 09:51 reinstall.js
                                      -rw-rwxrw-+   1 iobroker iobroker    709 Mar 13 09:41 reinstall.sh*
                                      it's as if fs is misbehaving?
                                      • Bluefox
                                        @Taragorm is the normal iobroker upload vis does not work?
                                        You can force all the steps manually.
                                        1. Copy your widgets files into /opt/iobroker/node_modules/iobroker.vis/www/widgets directory.
                                        2. Change /opt/iobroker/node_modules/iobroker.vis/www/js/config.js
                                        3. Change /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest (just add/change some char to change the hash)
                                        4. iobroker u vis
                                        5. To be sure clear the browser cache
                                          fyi, in enableDebug I think:
                                          maybe should be
                                          var stats = fs.statSync(adapterDir2Try);
                                          As diagnostics suggest we're finding the link, and lstatSync() returns the link itself, rather than the target of the link.
                                          Changing it, lets things go a bit further, but it still fails somewhat messily:
                                          Got stats:{"dev":2049,"mode":16895,"nlink":8,"uid":1001,"gid":1001,"rdev":0,"blksize":4096,"ino":791105,"size":4096,"blocks":8,"atimeMs":1552471286715.824,"mtimeMs":1552471172270.63,"ctimeMs":1552471172270.63,"birthtimeMs":1552471172270.63,"atime":"2019-03-13T10:01:26.716Z","mtime":"2019-03-13T09:59:32.271Z","ctime":"2019-03-13T09:59:32.271Z","birthtime":"2019-03-13T09:59:32.271Z"}  isDir=true isLink=false
                                          Upload "/opt/iobroker/node_modules/iobroker.vis/www/index.html.original"
                                          fs.js:119
                                              throw err;
                                          Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../../iobroker.vis/www/index.html.original'
                                              at Object.openSync (fs.js:448:3)
                                              at Object.readFileSync (fs.js:348:35)
                                              at VisDebug.enableDebug (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupVisDebug.js:91:23)
                                              at _objects (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2460:30)
                                              at Object.connected (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3133:17)
                                              at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                                              at Socket.emit (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:136:10)
                                              at Socket.onconnect (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:328:8)
                                              at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:224:12)
                                          For now, I'm going to switch my development environment to Windows, as that seems to be working for you.
                                          • Bluefox
                                            @Taragorm It is very well, that you want to get the visbebug runnnig, but
                                            I don't understand, why you ignore my other suggestions:
                                            • https://forum.iobroker.net/topic/19929/getting-started-with-visualisations/15
                                            • https://forum.iobroker.net/topic/19929/getting-started-with-visualisations/8
                                            The problem with non existing index.html.original is fixed only on github.
                                            vis
                                            5539
