    4. [Aufruf] iobroker.link Test
      sigi234 Forum Testing Most Active last edited by sigi234
      Ok, teste ich was ist der erlaubte Benutzer?
      link.0	2019-03-12 12:11:25.151	error	AccessClient: error getting connection requests: Bad Gateway
      link.0	2019-03-12 12:15:48.542	debug	AccessClient: Registered agent xxxx@xxxx.xx with 2 devices
      link.0	2019-03-12 12:15:48.419	debug	AccessClient: registering agent at https://iobroker.link/
      link.0	2019-03-12 12:15:48.317	debug	AccessClient: no connection requests found
      link.0	2019-03-12 12:15:38.235	debug	AccessClient: no connection requests found
      link.0	2019-03-12 12:15:28.158	debug	AccessClient: no connection requests found
      link.0	2019-03-12 12:15:18.079	debug	AccessClient: no connection requests found
      link.0	2019-03-12 12:15:08.004	debug	AccessClient: no connection requests found
      link.0	2019-03-12 12:14:57.934	debug	AccessClient: no connection requests found
      link.0	2019-03-12 12:14:47.837	debug	AccessClient: no connection requests found
      link.0	2019-03-12 12:14:37.757	debug	AccessClient: no connection requests found
      link.0	2019-03-12 12:14:37.757	info	Connected to https://iobroker.link
      link.0	2019-03-12 12:14:27.692	error	AccessClient: error getting connection requests: Bad Gateway
      link.0	2019-03-12 12:14:19.994	debug	system.adapter.admin.0: logging true
      link.0	2019-03-12 12:14:17.621	error	AccessClient: error getting connection requests: Bad Gateway
      link.0	2019-03-12 12:14:17.621	info	Disconnected to https://iobroker.link
      link.0	2019-03-12 12:14:07.542	debug	AccessClient: no connection requests found
      link.0	2019-03-12 12:13:57.470	debug	AccessClient: no connection requests found
      link.0	2019-03-12 12:13:57.469	info	Connected to https://iobroker.link
      Ok, besser:
      Bluefox 2 Replies Last reply Reply Quote 0
      • Bluefox
        Bluefox @sigi234 last edited by
        @sigi234 Danke. Ich werde suchen.
        • Bluefox
          @sigi234 Und konntest du deine Instanz erreichen?
            sigi234 Forum Testing Most Active @Bluefox last edited by
            @Bluefox sagte in [Aufruf] iobroker.link Test:
            Leider nein:
            • BBTown
              BBTown last edited by BBTown
              Ich habe nicht einmal Ansatzweise verstanden welche Informationen wo eingtragen werden sollen/müssen.
              Was um aller Welt ist ein "Kundenname"?
              Was gehört in den Bereich "Benutzer" rein? Der App-Key "@pro_xxxxx" wie er auch im Cloud-Adapter eingtragen ist?
              Nachtrag:
              Auch auf der GitHub Seite findet man diesbezüglich keine Informationen 😞
              • N
                nureintechniker @BBTown last edited by
                @BBTown "Kundenname" - das ist ein Name unter dem Deine iobroker Installation auf https://iobroker.link auftauchen wird. Wenn Du mehrere iobroker Installationen hast, dann wird dieser Name helfen die zu unterscheiden. Der "Benutzer" ist der login, den Du auf iobroker.pro anlegen kannst und dem Du erlaubst auf Deine iobroker Installationen remote zu zugreifen. Normalerweise würdest Du hier Deinen eigenen Login (e-mail) eintragen. Mit diesem Login meldest Du Dich auch auf iobroker.link an.
                BBTown 1 Reply Last reply Reply Quote 1
                • N
                  nureintechniker @sigi234 last edited by
                  @sigi234 Hast Du auch die richtige Portnummer für "iobroker_admin" konfiguriert?
                    sigi234 Forum Testing Most Active @nureintechniker last edited by
                    @nureintechniker
                    • BBTown
                      BBTown @nureintechniker last edited by
                      @nureintechniker sagte in [Aufruf] iobroker.link Test:
                      Ok - also der Log-In-Benutzer, den ich ursprünglich bei der Registrierung bei iobroker.pro verwendet habe ... da hatte ich zu kompliziert gedacht, danke Dir!
                      Soweit so gut, allerdings erhalten ich anschließend beim Klick auf Links unter "Geräte" ebenfalls den Hinweis "Not Found"
                      sigi234 N 2 Replies Last reply Reply Quote 0
                      • N
                        @sigi234 hm... komisch. Da taucht ja "iobroker<blank>admin" gar nicht auf. Ist es eine "default" Konfiguration?
                          sigi234 Forum Testing Most Active @BBTown last edited by
                          @BBTown sagte in [Aufruf] iobroker.link Test:
                          Das ist ja dann die E-Mail Adresse.......oder?
                          N BBTown 2 Replies Last reply Reply Quote 0
                          • N
                            @sigi234 richtig. Deine e-mail Adresse
                            • BBTown
                              BBTown @sigi234 last edited by
                              @sigi234 ja, die email adresse
                              • N
                                nureintechniker @BBTown last edited by nureintechniker
                                @BBTown said in [Aufruf] iobroker.link Test:
                                Geräte
                                Beim Klick auf die "Geräte" in Adapter-Konfiguration oder auf https://iobroker.link nach dem Du eine Verbindung hergestellt hast?
                                • BBTown
                                  BBTown @nureintechniker last edited by BBTown
                                  @nureintechniker
                                  1. auf https://iobroker.link
                                  2. Anmeldung
                                  3. Im Dashboard kann ich sehen:
                                  • Verfügbare Server: 1
                                  • Server Online: 1
                                  • Verbindungen insgesamt: 2
                                  1. Ich wechsel auf "Server" (unterhalb von "Dashboard")
                                  2. Klick auf den grünen Telefonhörer (starten/einwählen)
                                  3. Ich sehe unter "Akzeptiert" eine grüne Darstellung von Datum/Uhrzeit
                                  4. Klick auf "Geräte"
                                  5. es öffnet sich ein "Seitenfenster" mit 2 Links zu "ioBroker Admin" und "ioBroker Web"
                                  • in diesem Link ist wohl eine mir zugeordnete eindeutige ID enthalten (?)
                                  1. nach Klick auf den Link erscheint nach einer Weile im Browserfenster "Not Found"
                                  • BBTown
                                    Ich habe noch ein paar Verständnisfragen
                                    Gibt es Voraussetzungen?
                                    • Ports in Firewall öffnen? - nein, nicht notwendig
                                    • wird der cloud-adapter benötigt? - nein, der muss nicht parallel laufen
                                    • sind die Ports (80, 9082, 3001 (UDP) vorgegeben? - nein, die eigenen Ports verwenden
                                    • auch wenn ich lokal nicht mit Port 80 sondern 8081 auf Admin und mit 8082 statt 9082 auf Web/VIS? zugreife?- genau diese Ports müssen verwendet werden
                                      Funktioniert jetzt...........
                                        sigi234 Forum Testing Most Active @BBTown last edited by sigi234
                                        @BBTown
                                        Man muss DIE EIGENEN Ports eintragen! UDP muss ich noch rausfinden......
                                        PORT rausfinden:
                                        • N
                                          @BBTown könntest Du die "Geräte"-Seite deiner Adapter-Konfiguration in iobroker hier posten? Was die Ports angeht, die gesamte Kommunikation geht über SSH-Tunnel, den Dein Adapter zu iobroker.link aufbaut. Die Geräte sollten aber tatsächlichen Ports konfiguriert bekommen, da der Adapter sonst den Traffic nicht korrekt umleiten kann.
                                          • Bluefox
                                            Läuft dein admin auch wie bei mir unter port 80 und nicht wie default unter 8081??
                                            31.7k
                                            79.8k
                                            test
                                            11
                                            112
                                            6741
