    3. Entwicklung
    4. [Adapter] Neuer radar2-Adapter
      crunchip Forum Testing Most Active @crunchip last edited by
      @crunchip heute nochmal versucht von git
      adapter läuft nicht
      host.IoBroker	2019-03-11 11:19:33.576	error	instance system.adapter.radar2.0 terminated with code 0 (OK)
      Caught	2019-03-11 11:19:33.576	error	by controller[0]: spawnargs: [ '-n', '192.168.178.32' ] }
      Caught	2019-03-11 11:19:33.576	error	by controller[0]: path: 'arp',
      Caught	2019-03-11 11:19:33.576	error	by controller[0]: syscall: 'spawn arp',
      Caught	2019-03-11 11:19:33.576	error	by controller[0]: code: 'ENOENT',
      Caught	2019-03-11 11:19:33.576	error	by controller[0]: errno: 'ENOENT',
      Caught	2019-03-11 11:19:33.575	error	by controller[0]: at process._tickCallback (internal/process/next_tick.js:181:9)
      Caught	2019-03-11 11:19:33.575	error	by controller[0]: at _combinedTickCallback (internal/process/next_tick.js:139:11)
      Caught	2019-03-11 11:19:33.575	error	by controller[0]: at onErrorNT (internal/child_process.js:362:16)
      Caught	2019-03-11 11:19:33.575	error	by controller[0]: at Process.ChildProcess._handle.onexit (internal/child_process.js:190:19)
      Caught	2019-03-11 11:19:33.575	error	by controller[0]: { Error: spawn arp ENOENT
      radar2.0	2019-03-11 11:19:33.532	info	Adapter disconnected and stopped with dostop(false) and callback(true)
      radar2.0	2019-03-11 11:19:33.531	error	at process._tickCallback (internal/process/next_tick.js:181:9)
      radar2.0	2019-03-11 11:19:33.531	error	at _combinedTickCallback (internal/process/next_tick.js:139:11)
      radar2.0	2019-03-11 11:19:33.531	error	at onErrorNT (internal/child_process.js:362:16)
      radar2.0	2019-03-11 11:19:33.531	error	at Process.ChildProcess._handle.onexit (internal/child_process.js:190:19)
      radar2.0	2019-03-11 11:19:33.531	error	Error: spawn arp ENOENT
      radar2.0	2019-03-11 11:19:33.530	error	uncaught exception: spawn arp ENOENT
      • TheDuke
        TheDuke last edited by
        kommt mir bekannt vor ---> klickme
          crunchip Forum Testing Most Active @TheDuke last edited by
          @TheDuke guck ich mir heute Abend nochmal genauer an, hatte Version 0.1.2 laufen und auf die schnelle 1.0 von git drüber installiert.
            crunchip Forum Testing Most Active last edited by crunchip
            ich habe nun nochmal alles de/installliert, immer noch der selbe Fehler
            habe Anschliessend ein
            apt-get install net-tools
            durchgeführt und Fehler waren beseitigt 👌
            Was ich aber noch nicht hinbekommen habe
            	Connected with '0.0.0.0' for DHCP Scan
            	MyIP Error { Error: connect ECONNREFUSED 0.0.0.0:80at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1191:14)errno: 'ECONNREFUSED',code: 'ECONNREFUSED',syscall: 'connect',address: '0.0.0.0',port
            das dieses mit Pihole zusammen hängt, weiss ich mittlerweile, aber was ich da einstellen müsste, ist mir nicht klar
            Pihole Upstream-DNS_ Server /IPv4) 127.0.0.1#5353
            DHCP-Server ist die Fritzbox, also bei Pihole DHCP-Server aktiviert ist nicht angeklickt
            IP´s sind alle fest vergeben
            oder hängt das mit einem Eintrag in einer Blockliste zusammen
            frankjoke 1 Reply Last reply Reply Quote 0
              radar.0 habe ich anschliessend, gelöscht, leider wurde dabei auch die Instanz des radar2.0 mit gelöscht
              musste danach die Instanz neu hinzufügen und dementsprechend wieder alles einstellen
              • frankjoke
                frankjoke @crunchip last edited by
                @crunchip sagte in [Adapter] Neuer radar2-Adapter:
                Ja, das Problem hatte ich auch!Das ist ein Problem vom js-controller welches bei bald erscheinender V2.0.0 behoben werden wird laut @AlCalzone .
                An Alle, bitte alte instanz nicht löschen sondern nur ausschalten!
                • frankjoke
                  @crunchip , hast du die Installationsbefehle in der Adapter-readme (scah mal auf git) vor der Installation durchgeführt? dort ist auch das apt-get install net-tools drinnen!
                  Wenn du das nicht gemacht hast (oder in einer alten Version ohne net-tools/arp) kann die Funktion nicht garantiert werden.
                  • MathiasJ
                    MathiasJ last edited by
                    Eigenartig!
                    Ich habe die Instanz Radar gelöscht (allerdings beim.Rock64) alle Einstellungen vin Radar2 blieben erhalten
                      crunchip Forum Testing Most Active @frankjoke last edited by
                      @frankjoke dann war das wahrscheinlich die alte Version, ist schon ne weile her, wie gesagt, installiert hatte ich damals v0.1.2
                      zumindest läuft es ja jetzt, bis auf mein external IP address Problem
                        deta Most Active last edited by
                        ich habe gerade den alten Radar deinstalliert und den neuen Radar2 von Git.
                        Hab einen Rock64 und nach doku installiert.
                        Er ist grün, doch findet er keine anderen IpAdressen, Handys etc.. Er hat in die Liste nur diese eingetragen.
                        Wo hab ich was vergessen?
                        Im Log kommen noch diese Fehler zwischendrinnen:
                        host.rock 2019-03-12 18:33:41.408 error instance system.adapter.radar2.0 terminated with code null ()
                        host.rock 2019-03-12 18:33:41.407 warn instance system.adapter.radar2.0 terminated due to SIGSEGV
                        radar2.0 2019-03-12 18:34:18.382 warn ip address 192.168.178.1 in Fritzbox was used already for another device Fritzbox, this is forbidden!
                        Ich hab noch eine andere Fritte als WLAN und DECT Verstärker laufen.
                        cu Deta
                        MathiasJ crunchip 2 Replies Last reply Reply Quote 0
                        • MathiasJ
                          MathiasJ @deta last edited by
                          Hast Du auch die andere Python Version installiert?
                          Das gleiche Problem hatte ich auch, bis mir gesagt wurde, daß eine falsche Python-Version drauf ist.
                            deta Most Active @MathiasJ last edited by
                            @MathiasJ sagte in [Adapter] Neuer radar2-Adapter:
                            Welches wie ??
                            • MathiasJ
                              Mach mal
                              apt-get install python-dev
                              apt-get install libpcap-dev
                              danach mußt Du den Adapter reparieren
                              Gruß,
                              Mathias
                              • MathiasJ
                                MathiasJ last edited by MathiasJ
                                Danach mußt Du per terminal in den ordner
                                /opt/iobroker/node_modules/iobroker.radar2
                                gehen und
                                npm install
                                ausführen.
                                Dann muß es gehen.
                                Guckst Du, ich hatte das gleiche Problem:
                                https://forum.iobroker.net/topic/20663/ble-und-radar2-rot
                                Gruß,
                                Mathias
                                  Hab alles gemacht. Leider nix verändert. Hab sogar den Rock komplett neu gestartet. Die selben Fehler und keine weiteren IPs gefunden.
                                  MathiasJ 1 Reply Last reply Reply Quote 0
                                  • MathiasJ
                                    MathiasJ @deta last edited by MathiasJ
                                    Arp-Scan und net-scan installiert?
                                    Wobei ich nicht sagen kann, waas da zu machen ist.
                                    ich lasse den kompletten IP-Scan außen vor.
                                    ich nutze da nur BLE.
                                    Gruß,
                                    Mathias
                                      ja beides installiert.
                                      • MathiasJ
                                        @deta
                                        Frag mal @AlCalzone
                                        Er hat mir auch weiter geholfen.
                                        Wie bereits geschrieben, ich nutze kein IP Scan, nur G-Tags, weil alle Telefone nachts eh in den deep-sleep fallen
                                          crunchip Forum Testing Most Active @deta last edited by
                                          @deta die Einträge sind doch nur Beispiele,musst noch selbst deine eigenen anlegen
                                            deta Most Active last edited by deta
                                            Ich denke er Scant selber?
                                            Mh, ich hab alles gerade noch mal runtergeschmissen und versucht neu zu installieren, da ist immer was von Write Access. das heist ich habe irgendwo keine Schreibrechte bei der Install..
                                            Unter bei mir Zeigt er Version 1.0.0
                                            B frankjoke 2 Replies Last reply Reply Quote 0
                                            adapter radar2 adapter
                                            80
                                            840
                                            232414
