    4. [Aufruf] fullyBrowser Adapter
      liv-in-sky last edited by liv-in-sky
      ja ich - habe es vor 15 minuten probiert - geht nicht
      er funktioniert auch nicht mehr
      ERROR : TypeError: Cannot read property 'statusCode' of undefined
      • Chaot
        Chaot last edited by
        Bei mir genauso.
        Es scheint vollständig installiert zu werden:
        iobroker	2019-03-01 20:16:11.171	info	exit 0
        iobroker	2019-03-01 20:16:11.161	info	Adapter "fullybrowser" updated
        iobroker	2019-03-01 20:16:11.102	info	upload [0] fullybrowser.admin /opt/iobroker/node_modules/iobroker.fullybrowser/admin/fully.png fully.png image/png
        iobroker	2019-03-01 20:16:11.040	info	upload [1] fullybrowser.admin /opt/iobroker/node_modules/iobroker.fullybrowser/admin/index_m.html index_m.html text/html
        iobroker	2019-03-01 20:16:10.974	info	got /opt/iobroker/node_modules/iobroker.fullybrowser/adminupload [2] fullybrowser.admin /opt/iobroker/node_modules/iobroker.fullybrowser/admin/words.js words.js application/javascript
        iobroker	2019-03-01 20:16:10.863	info	npm notice created a lockfile as package-lock.json. You should commit this file.
        iobroker	2019-03-01 20:16:04.516	info	npm WARN deprecated graceful-fs@1.2.3: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
        iobroker	2019-03-01 20:16:03.817	info	npm WARN deprecated minimatch@0.2.14: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
        iobroker	2019-03-01 20:16:00.667	info	npm WARN deprecated minimatch@2.0.10: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
        iobroker	2019-03-01 20:15:58.885	info	npm WARN deprecated graceful-fs@3.0.11: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
        iobroker	2019-03-01 20:15:55.263	info	npm WARN deprecated gulp-util@3.0.8: gulp-util is deprecated - replace it, following the guidelines at https://medium.com/gulpjs/gulp-util-ca3b1f9f9ac5
        iobroker	2019-03-01 20:15:52.099	info	npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.fullybrowser"
        iobroker	2019-03-01 20:15:51.861	info	npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
        iobroker	2019-03-01 20:15:51.861	info	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.7 (node_modules/fsevents):
        iobroker	2019-03-01 20:15:51.861	info	npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
        iobroker	2019-03-01 20:15:51.861	info	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):
        iobroker	2019-03-01 20:15:51.861	info	npm WARN svg-inline-react@1.0.3 requires a peer of react@^0.14.0 || ^15.0.0 but none is installed. You must install peer dependencies yourself.
        iobroker	2019-03-01 20:15:51.861	info	npm WARN svg-inline-react@1.0.3 requires a peer of react@^0.14.0 || ^15.0.0 but none is installed. You must install peer dependencies yourself.npm WARN onvif-snapshot@1.0.2 requires a peer of onvif@^
        iobroker	2019-03-01 20:14:08.015	info	npm install iobroker.fullybrowser@0.0.15 --unsafe-perm --production --save --prefix "/opt/iobroker" (System call)
        iobroker	2019-03-01 20:14:07.592	info	NPM version: 6.4.1
        iobroker	2019-03-01 20:14:07.019	info	Update fullybrowser from @0.0.13 to @0.0.15
        iobroker	2019-03-01 20:14:05.686	info	upgrade fullybrowser
        Aber die Version bleibt bei 0.0.13 stehen.
        Auch über Git direkt das gleiche Ergebnis
          hmm ich schaumal .. jo fehler gefunden hab vergessen die Version nazuheben...
          0.0.16 sollte gehen
            Allodo last edited by
            nachdem sich der Akku meines Fird HD verabschiedet hat, habe ich mir ein Medion Lifetab zugelegt.
            FullyKioskBrowser installiert und die Lizenz aktualisiert. Läuft.
            Eine Verbindung zwischen iobroker und dem FullyKioskBrowser scheint zu bestehen, jedoch habe ich ein Problem, und zwar steht unter status "Error" und unter statusText "Please login".
            In den Einstellungen des Adapter habe ich das Passwort eingetragen, welches ich im FullyKioskBrowser unter RemoteAdministration eingetragen habe.
            Somit kann ich den Browser leider gar nicht fernsteueren 😞
            Dabei hatte alles auf dem FireHD so hervorragend funktioniert.
            Muss evtl. irgendwo der Port manuell angepasst werden? Dieser stand vorher auf 2323.
              2323 ist standard .. bist dir sicher das die Logindaten stimmen.. das riecht nach .. klein gross schriebung oder so
                @arteck
                Danke 🙂
                Ich habe jetzt einfach mal ein anderes Passwort versucht, ohne Sonderzeichen und dann hat's sofort geklappt. Kann es vielleicht an den Sonderzeichen liegen?
                  wirds wohl so sein..
                  installiere mal diese version...
                  https://github.com/arteck/ioBroker.fullybrowser/tarball/psw_special
                  da wird das psw mit encoded
                    ahfreezer last edited by
                    @arteck sagte in [Aufruf] fullyBrowser Adapter:
                    Hi Arteck,
                    vlt. kannst du mir auch helfen.
                    Den Adapter habe ich manuell installiert.
                    IP vom Tablet mit Standardport 2323 und Standardpasswort hinterlegt.
                    Adapter ist "grün"
                    Dennoch bekomme ich keinen "Zugriff" auf den Fully
                    State von isFullyalive bleibt bei false.
                    Hast du einen Tipp? Liegt es daran, dass ich noch nicht die PLUS Version habe?
                    Habe ein älteres Samsung Tab A 10.1 (gerootet)
                    Danke u. Gruß
                    André
                      hmm gute frage .. ich weiss nicht ob man dafür die Kaufversion haben muss...
                      du kannst ja den Admin Bereich im FullyBrowser einschalten... und schauen ob du so per Browser drauf kommst
                      A 2 Replies Last reply Reply Quote 0
                        ahfreezer @arteck last edited by
                        @arteck
                        Alles klar. Versuche ich morgen mal.
                        Danke dir für die schnelle Antwort!
                          @arteck
                          Problem saß vor dem Rechner.
                          Danke @arteck und @Kueppert 👍🏻
                            skokarl last edited by
                            Moin,
                            erstmal Danke für einen Fully Adapter, wenngleich ich noch nicht einschätzen kann welchen
                            Nutzen das haben könnte, also Anwendungsbeispiele.
                            Was mir aber sofort in den Sinn kam, wäre die Frage, ob es möglich sein könnte damit eine App über den IOBroker starten zu können ?
                            Ich denke dabei immer noch an Spotify ...😇
                              hmm da sagst du was... ich schau mal
                                skokarl @arteck last edited by
                                hat sich gestern erledigt, kann den link gerade nicht kopieren, sitze am Handy.
                                Spotify mit Fully geht einfach nur genial 😀😀😀
                                  skokarl @arteck last edited by skokarl
                                  jetzt:
                                  und Danke für den tollen Adapter.
                                  Thread
                                    Herzog97944 @arteck last edited by
                                    @arteck said in [Aufruf] fullyBrowser Adapter:
                                    mit hilfe von User Mic habe ich einen Fully KioskBrowser Adapter erstellt.
                                    ausgehen von https://github.com/Mic-M/iobroker.fully-kiosk-browser-script (vielen Dank dafür)
                                    erstmal nur auf GIT
                                    installierbar über die Katze
                                    https://github.com/arteck/iobroker.fullyBrowser
                                    verwaltbar sind mehrere Browser Instanzen…. ich habe eine Limitierung des polling Intervals auf min. 5 Sec gesetzt..
                                    ich Persönlich habe 5 min (300000).. eingetellt
                                    aber schaut selbst
                                    Feedback bitte
                                    Hallo, habe mir die neuste Version gestern installiert. Was muß man den bei Port und Passwort eingeben?
                                    Ganz gleich was ich reinschreibe. Instanz geht immer auf grün. Ist das so okay?
                                    Über eine Rückmeldung freue ich mich.
                                    Michael
                                    • N
                                      Nordischerjung last edited by
                                      Moin,
                                      ich habe über Backup von Tinkerboard auf Beeling und dadrauf proxmox mit Dembian gewechselt.
                                      Soweit hat alles geklappt, nur der Fully Adapter hatte ein fehler. Ich habe ihn dann deinstalliert und über die Katze neu installiert, dabei bekomme ich folgenden Fehler.
                                      $ ./iobroker url "https://github.com/arteck/ioBroker.fullybrowser.git" --debug
                                      install https://github.com/arteck/ioBroker.fullybrowser/tarball/master
                                      npm install https://github.com/arteck/ioBroker.fullybrowser/tarball/master --production --save --prefix "/opt/iobroker" (System call)
                                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                                      + iobroker.fullybrowser@0.0.16
                                      updated 1 package and audited 5765 packages in 36.843s
                                      found 54 vulnerabilities (38 low, 1 moderate, 15 high)  run `npm audit fix` to fix them, or `npm audit` for details
                                      process exited with code 0
                                      Kann ich das iwie beheben?
                                        arteck Developer Most Active @Nordischerjung last edited by arteck
                                        @Nordischerjung und wo ist deiner Meinung nach der Fehler ???
                                          arteck Developer Most Active @Herzog97944 last edited by
                                          @Herzog97944 schon mal sich das WIKI angeschaut
                                          • N
                                            Nordischerjung @arteck last edited by
                                            @arteck Ja hab ich, hab ich etwas übersehen?
                                            meinst du des wegen? Ich hatte nichts gelesen wegen dem System.
                                            Sorry wenn ich das übersehen habe.
                                            Ich benötige lediglich den Akkustand, das kann ich dann über das Script lösen
                                            fullybrowser fullybrowser adapter
                                            45
                                            289
                                            43563
