    4. Node-Red
    5. Sonoff Steckdosen schalten
    • Z
      Zerpmaster last edited by
      ich habe vom MQTT Adapter umgestellt auf den Sonoff Adapter aber nun kann ich meine Steckdosen nicht mehr schalten.
      kann mir vielleicht jemand weiterhelfen und sagen wo mein fehler besteht?
      Sonoff Steckdosen Verbinden sich zum Iobroker Sonoff Adapter per Port 1883 MQTT Adapter ist deaktiviert.
              "id": "b79115d.e7a89e8",
              "type": "change",
              "z": "63e0e477.2b8f9c",
              "name": "Geraet an",
              "rules": [
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "to": "true",
                      "tot": "bool"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 500,
              "y": 280,
              "wires": [
                      "9ede7d17.58391",
                      "2dc29852.09e408"
              "id": "c7167023.db59a",
              "type": "change",
              "rules": [
                      "to": "true",
                      "pt": "msg",
                      "tot": "bool",
                      "p": "payload",
                      "t": "set"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 670,
              "y": 160,
              "wires": [
                      "38676452.08146c"
              "id": "392e7feb.49c2a",
              "type": "mqtt in",
              "name": "",
              "topic": "stat/sonoff.0.DeckenfluterStube.POWER",
              "qos": "2",
              "broker": "ca82f012.f428d",
              "x": 180,
              "y": 120,
              "wires": [
                      "3d3e2df6.c1c932"
              "id": "49bf896f.c633d8",
              "type": "change",
              "name": "Geraet aus",
              "rules": [
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "to": "false",
                      "tot": "bool"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 510,
              "y": 340,
              "wires": [
                      "9ede7d17.58391",
                      "2dc29852.09e408"
              "id": "fab68914.53d908",
              "type": "switch",
              "name": "",
              "property": "payload",
              "propertyType": "msg",
              "rules": [
                      "t": "eq",
                      "v": "true",
                      "vt": "str"
                      "t": "eq",
                      "v": "false",
                      "vt": "str"
              "checkall": "true",
              "repair": false,
              "outputs": 2,
              "x": 510,
              "y": 180,
              "wires": [
                      "c7167023.db59a"
                      "ea38b18b.f51a6"
              "id": "d56186cc.fc5c88",
              "type": "switch",
              "name": "",
              "rules": [
                      "t": "eq",
                      "v": "true",
                      "vt": "str"
                      "t": "eq",
                      "v": "false",
                      "vt": "str"
              "checkall": "true",
              "repair": false,
              "outputs": 2,
              "x": 350,
              "y": 300,
              "wires": [
                      "b79115d.e7a89e8"
                      "49bf896f.c633d8"
              "id": "ea38b18b.f51a6",
              "type": "change",
              "rules": [
                      "to": "false",
                      "pt": "msg",
                      "tot": "bool",
                      "p": "payload",
                      "t": "set"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 670,
              "y": 200,
              "wires": [
                      "38676452.08146c"
              "id": "2df97c26.12b064",
              "type": "ioBroker in",
              "name": "Wohnzimmer DeckenfluterStube Status",
              "topic": "node-red.0.Wohnzimmer.Deckenfluter.Status",
              "payloadType": "value",
              "onlyack": "",
              "func": "all",
              "gap": "",
              "x": 170,
              "y": 240,
              "wires": [
                      "d56186cc.fc5c88"
              "id": "3d3e2df6.c1c932",
              "type": "rbe",
              "name": "",
              "func": "rbe",
              "gap": "",
              "start": "",
              "inout": "out",
              "x": 350,
              "y": 180,
              "wires": [
                      "fab68914.53d908"
              "id": "38676452.08146c",
              "type": "ioBroker out",
              "ack": "true",
              "autoCreate": "true",
              "x": 980,
              "y": 120,
              "wires": []
              "id": "2dc29852.09e408",
              "type": "mqtt out",
              "name": "",
              "topic": "cmd/sonoff.0.DeckenfluterStube.POWER",
              "qos": "",
              "retain": "",
              "x": 1040,
              "y": 300,
              "wires": []
              "id": "9ede7d17.58391",
              "type": "ui_switch",
              "name": "DeckenfluterStube",
              "label": "DeckenfluterStube",
              "tooltip": "",
              "group": "ad37f86d.c06528",
              "order": 0,
              "width": 0,
              "height": 0,
              "passthru": false,
              "decouple": "false",
              "topic": "",
              "style": "",
              "onvalue": "true",
              "onvalueType": "str",
              "onicon": "",
              "oncolor": "",
              "offvalue": "false",
              "offvalueType": "str",
              "officon": "",
              "offcolor": "",
              "x": 710,
              "y": 260,
              "wires": [
                      "fab68914.53d908",
                      "2dc29852.09e408"
              "id": "ca82f012.f428d",
              "type": "mqtt-broker",
              "z": "",
              "name": "",
              "broker": "192.168.178.42",
              "port": "1883",
              "clientid": "",
              "usetls": false,
              "compatmode": true,
              "keepalive": "60",
              "cleansession": true,
              "birthTopic": "",
              "birthQos": "0",
              "birthPayload": "",
              "closeTopic": "",
              "closePayload": "",
              "willTopic": "",
              "willQos": "0",
              "willPayload": ""
              "id": "ad37f86d.c06528",
              "type": "ui_group",
              "z": "",
              "name": "Wohnzimmer",
              "tab": "78bee128.522f9",
              "disp": true,
              "width": "6",
              "collapse": false
              "id": "78bee128.522f9",
              "type": "ui_tab",
              "z": "",
              "name": "Steckdosen Haus",
              "icon": "dashboard",
              "order": 3
      81.1k
