    2. Русский
    3. ioBroker
    4. ioBroker драйвера
    5. Драйвер Mqtt + Arduino
    • I
      instalator last edited by
      Это я так понимаю iobroker подписался, а как потом с брокера отправлять команды в ардуину? она тоже должна подписаться на изменения?
      • I
        В ардуину сыпиться все подряд, так и должно быть:
        ! start
        ! /myhome/out/Kitchen_light1 0
        ! /myhome/out/Kitchen_light2 0
        ! #mqtt/0/myhome/out/Kitchen_light1 0
        ! #mqtt/0/myhome/out/Kitchen_light2 0
        ! #system/adapter/web/0/alive true
        ! #system/adapter/web/0/connected true
        ! #system/adapter/web/0/memRss 41.54
        ! #system/adapter/web/0/memHeapTotal 30.46
        ! #system/adapter/web/0/memHeapUsed 10.36
        ! #system/adapter/web/0/uptime 783
        ! #system/adapter/node-red/0/alive true
        ! #system/adapter/node-red/0/connected true
        ! #system/adapter/node-red/0/memRss 9.02
        ! #system/adapter/node-red/0/memHeapTotal 16.66
        ! #system/adapter/node-red/0/memHeapUsed 6.12
        ! #system/adapter/node-red/0/uptime 78788
        ! #system/adapter/onkyo/0/alive true
        ! #system/adapter/onkyo/0/connected true
        ! #system/adapter/onkyo/0/memRss 8.79
        ! #system/adapter/onkyo/0/memHeapTotal 16.66
        ! #system/adapter/onkyo/0/memHeapUsed 8.11
        ! #system/adapter/onkyo/0/uptime 69650
        ! #system/adapter/example/0/alive true
        ! #system/adapter/example/0/connected true
        ! #system/adapter/example/0/memRss 9.52
        ! #system/adapter/example/0/memHeapTotal 16.66
        ! #system/adapter/example/0/memHeapUsed 6.09
        ! #system/adapter/example/0/uptime 78804
        ! mqtt/0/myhome/out/Kitchen_light1 0
        ! mqtt/0/myhome/out/Kitchen_light2 0
        ! system/adapter/simple-api/0/alive true
        ! system/adapter/simple-api/0/connected true
        ! system/adapter/simple-api/0/memRss 6.98
        ! system/adapter/simple-api/0/memHeapTotal 16.66
        ! system/adapter/simple-api/0/memHeapUsed 8.49
        ! system/adapter/simple-api/0/uptime 78867
        ! system/adapter/javascript/1/alive true
        ! system/adapter/javascript/1/connected true
        ! system/adapter/javascript/1/memRss 39.13
        ! system/adapter/javascript/1/memHeapTotal 36.19
        ! system/adapter/javascript/1/memHeapUsed 11.3
        ! system/adapter/javascript/1/uptime 76394
        ! system/adapter/sayit/0/alive true
        ! system/adapter/sayit/0/connected true
        ! system/adapter/sayit/0/memRss 9.98
        ! system/adapter/sayit/0/memHeapTotal 16.66
        ! system/adapter/sayit/0/memHeapUsed 7.11
        ! system/adapter/sayit/0/uptime 75208
        ! system/host/Server-PC/alive true
        ! system/host/Server-PC/load 0
        ! system/host/Server-PC/mem 34
        • aurodionov
          aurodionov last edited by
          типа броадкастом чтоль ,всем ->всё 🙂
          • I
            Ставлю в брокере переменую в 1
            В логе на ардуине:
            И переменная скидывается в 0
            И еще: Когда ставлю в 1 в логе вот что:
            mqtt-0 2015-05-12 19:28:53 debug Client [myhome-kitchen] pingreq
            • I
              Почему когда я изменяю состояние то в подтверждении false? так и должно быть или переменная меняется только на экране и скрипты не отрабатывают пока false?
              • Bluefox
                Bluefox last edited by
                @instalator:
                Почему когда я изменяю состояние то в подтверждении false? так и должно быть или переменная меняется только на экране и скрипты не отрабатывают пока false? `
                Где ты меняешь состояние? На arduino или в ioBroker?
                Если на arduino то подтверждение должно быть true, если в ioBroker, то подтверждение должно быть false.
                false означает, что это комманда и значение ещё не подтверждено конечным устройством.
                • I
                  @Bluefox:
                  @instalator:
                  false означает, что это комманда и значение ещё не подтверждено конечным устройством. `
                  Когда меняю на Ардуино то все ок. А вот в брокере не реагирует. Почему драйвер mqtt сыпит в проток все переменные iobrokera?
                  • I
                    Насколькор я понимаю этот участок окда отвечает за изменение параметров потупившых от iobrokera?
                    void callback(char* topic, byte* payload, unsigned int length) {
                      payload[length] = '\0';
                      Serial.print(topic);
                      Serial.print("  ");
                      String strTopic = String(topic);
                      String strPayload = String((char*)payload);
                      Serial.println(strPayload);
                      if (strTopic == "/myhome/in/Kitchen_light1") {
                        if (strPayload == "0")     digitalWrite(light1_pin, LOW);
                        else if (strPayload == "1") digitalWrite(light1_pin, HIGH);
                      else if (strTopic == "/myhome/in/Kitchen_light2") {
                        if (strPayload == "0") digitalWrite(light2_pin, LOW);
                        else if (strPayload == "1") digitalWrite(light2_pin, HIGH);
                    • I
                      Что шлет брокер после изменения функции?
                      /myhome/out/Kitchen_light2 1
                      mqtt/0/myhome/out/Kitchen_light2 1
                      Это от ардуино:?
                      Это от брокера:?
                      Почему в обоих случаях out?
                      На что влияют эти настройки драйвера?
                      Маска для собственных значений:
                      Сохранять только изменения:
                      Выдавать собственные значения при старте:
                      Префикс для всех значений:
                      Маска как я понял влияет на то что будет валится в протокол?
                      Если будет много устройств, а драйвер соответственно бутет слать все в куче то получается ардуина будет парсить весь лишний мусор пока не найдет то что предназначено именно ей? ИМХО все встанет при n'ом количестве устройств.
                      • I
                        Короче где то косяк в драйвере, он валит все подряд, только не то что надо, у меня mqtt например вываливает значение onkyo, которое меняется каждую секунду так как там идет время проигрования. И когда долетит команда для ардуины хз.
                        • I
                          Сработало!!!
                          ! start
                          ! system/adapter/admin/0/uptime 111
                          ! system/adapter/admin/0/memRss 41.3
                          ! system/adapter/admin/0/memHeapTotal 30.46
                          ! system/adapter/admin/0/memHeapUsed 18.6
                          ! system/adapter/admin/0/connected true
                          ! system/adapter/admin/0/alive true
                          ! system/host/Server-PC/mem 27
                          ! system/host/Server-PC/memHeapUsed 20.48
                          ! system/host/Server-PC/memHeapTotal 36.26
                          ! system/host/Server-PC/memRss 52.3
                          ! system/host/Server-PC/uptime 123
                          ! system/adapter/javascript/0/uptime undefined
                          ! system/adapter/javascript/0/memRss undefined
                          ! system/adapter/javascript/0/memHeapTotal undefined
                          ! system/adapter/javascript/0/memHeapUsed undefined
                          ! system/adapter/javascript/0/connected undefined
                          ! system/adapter/javascript/0/alive undefined
                          ! system/adapter/history/0/uptime 109
                          ! system/adapter/history/0/memRss 21.74
                          ! system/adapter/history/0/memHeapTotal 15.69
                          ! system/adapter/history/0/memHeapUsed 5.15
                          ! system/adapter/history/0/connected true
                          ! system/adapter/history/0/alive true
                          ! system/adapter/web/0/uptime 107
                          ! system/adapter/web/0/memRss 33.22
                          ! system/adapter/web/0/memHeapTotal 27.56
                          ! system/adapter/web/0/memHeapUsed 14.44
                          ! system/adapter/web/0/connected true
                          ! system/adapter/web/0/alive true
                          ! system/adapter/email/0/wakeup undefined
                          ! system/adapter/email/0/uptime 107
                          ! system/adapter/email/0/memRss 19.26
                          ! system/adapter/email/0/memHeapTotal 15.69
                          ! system/adapter/email/0/memHeapUsed 6.66
                          ! system/adapter/email/0/connected true
                          ! system/adapter/email/0/alive true
                          ! system/adapter/ping/0/uptime 43377
                          ! system/adapter/ping/0/memRss 18.78
                          ! system/adapter/ping/0/memHeapTotal 25.74
                          ! system/adapter/ping/0/memHeapUsed 13.87
                          ! system/adapter/ping/0/connected false
                          ! system/adapter/ping/0/alive false
                          ! vis/0/command undefined
                          ! system/adapter/example/0/memRss 19.38
                          ! system/adapter/example/0/memHeapTotal 15.69
                          ! system/adapter/example/0/memHeapUsed 7.73
                          ! system/adapter/example/0/uptime 527
                          ! onkyo/0/command NTM32:44/–:--
                          ! system/adapter/history/0/memRss 24.18
                          ! system/adapter/history/0/memHeapUsed 7.04
                          ! system/adapter/history/0/uptime 544
                          ! onkyo/0/command NTM32:45/--:--
                          ! onkyo/0/command NTM32:46/--:--
                          ! system/adapter/mqtt/0/alive true
                          ! system/adapter/mqtt/0/connected true
                          ! system/adapter/mqtt/0/memRss 26.16
                          ! system/adapter/mqtt/0/memHeapTotal 17.62
                          ! system/adapter/mqtt/0/memHeapUsed 10.38
                          ! system/adapter/mqtt/0/uptime 498
                          ! onkyo/0/command NTM32:47/--:--
                          ! system/adapter/web/0/memRss 37.13
                          ! system/adapter/web/0/memHeapUsed 11.12
                          ! system/adapter/web/0/uptime 543
                          ! onkyo/0/command NTM32:48/--:--
                          ! onkyo/0/command NTM32:49/--:--
                          ! onkyo/0/command NTM32:50/--:--
                          ! system/adapter/sayit/0/memRss 19.98
                          ! system/adapter/sayit/0/memHeapUsed 8.06
                          ! system/adapter/sayit/0/uptime 514
                          ! system/adapter/email/0/memRss 19.25
                          ! system/adapter/email/0/memHeapUsed 7.5
                          ! system/adapter/email/0/uptime 542
                          ! onkyo/0/command NTM32:51/--:--
                          ! onkyo/0/command NTM32:52/--:--
                          ! system/host/Server-PC/memRss 52.65
                          ! system/host/Server-PC/memHeapUsed 21.92
                          ! system/host/Server-PC/uptime 558
                          ! onkyo/0/command NTM32:53/--:--
                          ! system/adapter/javascript/1/memRss 41.27
                          ! system/adapter/javascript/1/memHeapTotal 32.37
                          ! system/adapter/javascript/1/memHeapUsed 18.1
                          ! system/adapter/javascript/1/uptime 529
                          ! system/adapter/pushover/0/alive true
                          ! system/adapter/pushover/0/connected true
                          ! system/adapter/pushover/0/memRss 19.11
                          ! system/adapter/pushover/0/memHeapTotal 15.69
                          ! system/adapter/pushover/0/memHeapUsed 7.26
                          ! system/adapter/pushover/0/uptime 513
                          ! onkyo/0/command NTM32:54/--:--
                          ! onkyo/0/command NTM32:55/--:--
                          ! system/adapter/node-red/0/alive true
                          ! system/adapter/node-red/0/connected true
                          ! system/adapter/node-red/0/memRss 20.77
                          ! system/adapter/node-red/0/memHeapTotal 15.69
                          ! system/adapter/node-red/0/memHeapUsed 8.85
                          ! system/adapter/node-red/0/uptime 527
                          ! onkyo/0/command NTM32:56/--:--
                          ! onkyo/0/command NTM32:57/--:--
                          ! system/adapter/onkyo/0/alive true
                          ! system/adapter/onkyo/0/connected true
                          ! system/adapter/onkyo/0/memRss 24.98
                          ! system/adapter/onkyo/0/memHeapTotal 16.66
                          ! system/adapter/onkyo/0/memHeapUsed 7.61
                          ! system/adapter/onkyo/0/uptime 513
                          ! onkyo/0/command NTM32:58/--:--
                          ! system/adapter/admin/0/memRss 41.81
                          ! system/adapter/admin/0/memHeapTotal 31.43
                          ! system/adapter/admin/0/memHeapUsed 17.49
                          ! system/adapter/admin/0/uptime 562
                          ! system/adapter/example/0/alive true
                          ! system/adapter/example/0/connected true
                          ! system/adapter/example/0/memRss 19.4
                          ! system/adapter/example/0/memHeapUsed 7.75
                          ! system/adapter/example/0/uptime 542
                          ! onkyo/0/command NTM32:59/--:--
                          ! system/adapter/history/0/memRss 24.2
                          ! system/adapter/history/0/memHeapUsed 7.5
                          ! system/adapter/history/0/uptime 559
                          ! onkyo/0/command NTM33:00/--:--
                          ! onkyo/0/command NTM33:01/--:--
                          ! system/adapter/mqtt/0/memRss 26.13
                          ! system/adapter/mqtt/0/memHeapUsed 7.68
                          ! system/adapter/mqtt/0/uptime 513
                          ! onkyo/0/command NTM33:02/--:--
                          ! system/adapter/web/0/memRss 37.16
                          ! system/adapter/web/0/memHeapUsed 11.83
                          ! system/adapter/web/0/uptime 558
                          ! onkyo/0/command NTM33:03/--:--
                          ! onkyo/0/command NTM33:04/--:--
                          ! onkyo/0/command NTM33:05/--:--
                          ! system/adapter/sayit/0/memRss 20
                          ! system/adapter/sayit/0/memHeapUsed 8.08
                          ! system/adapter/sayit/0/uptime 529
                          ! system/adapter/email/0/memHeapUsed 7.53
                          ! system/adapter/email/0/uptime 557
                          ! onkyo/0/command NTM33:06/--:--
                          ! onkyo/0/command NTM33:07/--:--
                          ! system/host/Server-PC/memRss 52.66
                          ! system/host/Server-PC/memHeapUsed 23.9
                          ! system/host/Server-PC/uptime 573
                          ! onkyo/0/command NTM33:08/--:--
                          ! system/adapter/javascript/1/memRss 41.46
                          ! system/adapter/javascript/1/memHeapUsed 18.87
                          ! system/adapter/javascript/1/uptime 544
                          ! system/adapter/pushover/0/memRss 19.12
                          ! system/adapter/pushover/0/memHeapUsed 7.29
                          ! system/adapter/pushover/0/uptime 528
                          ! onkyo/0/command NTM33:09/--:--
                          ! onkyo/0/command NTM33:10/--:--
                          ! system/adapter/node-red/0/memRss 20.79
                          ! system/adapter/node-red/0/memHeapUsed 8.87
                          ! system/adapter/node-red/0/uptime 542
                          ! onkyo/0/command NTM33:11/--:--
                          ! onkyo/0/command NTM33:12/--:--
                          ! system/adapter/onkyo/0/memRss 25.05
                          ! system/adapter/onkyo/0/memHeapUsed 8.04
                          ! system/adapter/onkyo/0/uptime 528
                          ! onkyo/0/command NTM33:13/--:--
                          ! system/adapter/admin/0/memRss 41.82
                          ! system/adapter/admin/0/memHeapUsed 18.15
                          ! system/adapter/admin/0/uptime 577
                          ! system/adapter/example/0/memRss 19.45
                          ! system/adapter/example/0/memHeapUsed 7.78
                          ! system/adapter/example/0/uptime 557
                          ! onkyo/0/command NTM33:14/--:--
                          ! system/adapter/history/0/memRss 24.21
                          ! system/adapter/history/0/memHeapUsed 7.95
                          ! system/adapter/history/0/uptime 574
                          ! onkyo/0/command NTM33:15/--:--
                          ! onkyo/0/command NTM33:16/--:--
                          ! system/adapter/mqtt/0/memRss 26.14
                          ! system/adapter/mqtt/0/memHeapUsed 8.82
                          ! system/adapter/mqtt/0/uptime 528
                          ! onkyo/0/command NTM33:17/--:--
                          ! system/adapter/web/0/memRss 37.17
                          ! system/adapter/web/0/memHeapUsed 12.51
                          ! system/adapter/web/0/uptime 573
                          ! onkyo/0/command NTM33:18/--:--
                          ! onkyo/0/command NTM33:19/--:--
                          ! onkyo/0/command NTM33:20/--:--
                          ! system/adapter/sayit/0/memRss 20.02
                          ! system/adapter/sayit/0/memHeapUsed 8.1
                          ! system/adapter/sayit/0/uptime 544
                          ! system/adapter/email/0/memHeapUsed 7.54
                          ! system/adapter/email/0/uptime 572
                          ! onkyo/0/command NTM33:21/--:--
                          ! onkyo/0/command NTM33:22/--:--
                          ! system/host/Server-PC/memRss 52.68
                          ! system/host/Server-PC/memHeapUsed 17.97
                          ! system/host/Server-PC/uptime 588
                          ! onkyo/0/command NTM33:23/--:--
                          ! system/adapter/javascript/1/memRss 41.64
                          ! system/adapter/javascript/1/memHeapUsed 19.65
                          ! system/adapter/javascript/1/uptime 559
                          ! system/adapter/pushover/0/memHeapUsed 7.31
                          ! system/adapter/pushover/0/uptime 543
                          ! onkyo/0/command NTM33:24/--:--
                          ! onkyo/0/command NTM33:25/--:--
                          ! system/adapter/node-red/0/memRss 20.82
                          ! system/adapter/node-red/0/memHeapUsed 8.89
                          ! system/adapter/node-red/0/uptime 557
                          ! onkyo/0/command NTM33:26/--:--
                          ! onkyo/0/command NTM33:27/--:--
                          ! system/adapter/onkyo/0/memHeapUsed 8.47
                          ! system/adapter/onkyo/0/uptime 543
                          ! onkyo/0/command NTM33:28/--:--
                          ! system/adapter/admin/0/memRss 41.85
                          ! system/adapter/admin/0/memHeapUsed 18.81
                          ! system/adapter/admin/0/uptime 592
                          ! system/adapter/example/0/memRss 19.46
                          ! system/adapter/example/0/memHeapUsed 7.8
                          ! system/adapter/example/0/uptime 572
                          ! onkyo/0/command NTM33:29/--:--
                          ! system/adapter/history/0/memRss 24.23
                          ! system/adapter/history/0/memHeapUsed 8.41
                          ! system/adapter/history/0/uptime 589
                          ! onkyo/0/command NTM33:30/--:--
                          ! onkyo/0/command NTM33:31/--:--
                          ! system/adapter/mqtt/0/memHeapUsed 9.98
                          ! system/adapter/mqtt/0/uptime 543
                          ! onkyo/0/command NTM33:32/--:--
                          ! system/adapter/web/0/memRss 37.18
                          ! system/adapter/web/0/memHeapUsed 13.2
                          ! system/adapter/web/0/uptime 588
                          ! onkyo/0/command NTM33:33/--:--
                          ! onkyo/0/command NTM33:34/--:--
                          ! onkyo/0/command NTM33:35/--:--
                          ! system/adapter/sayit/0/memRss 20.05
                          ! system/adapter/sayit/0/memHeapUsed 8.12
                          ! system/adapter/sayit/0/uptime 559
                          ! system/adapter/email/0/memHeapUsed 7.57
                          ! system/adapter/email/0/uptime 587
                          ! onkyo/0/command NTM33:36/--:--
                          ! onkyo/0/command NTM33:37/--:--
                          ! system/host/Server-PC/memRss 52.7
                          ! system/host/Server-PC/memHeapUsed 19.95
                          ! system/host/Server-PC/uptime 603
                          ! onkyo/0/command NTM33:38/--:--
                          ! system/adapter/javascript/1/memRss 41.88
                          ! system/adapter/javascript/1/memHeapTotal 33.32
                          ! system/adapter/javascript/1/memHeapUsed 20.42
                          ! system/adapter/javascript/1/uptime 574
                          ! system/adapter/pushover/0/memHeapUsed 7.33
                          ! system/adapter/pushover/0/uptime 558
                          ! onkyo/0/command NTM33:39/--:--
                          ! onkyo/0/command NTM33:40/--:--
                          ! system/adapter/node-red/0/memRss 20.84
                          ! system/adapter/node-red/0/memHeapUsed 8.91
                          ! system/adapter/node-red/0/uptime 572
                          ! onkyo/0/command NTM33:41/--:--
                          ! onkyo/0/command NTM33:42/--:--
                          ! system/adapter/onkyo/0/memRss 25.07
                          ! system/adapter/onkyo/0/memHeapUsed 8.92
                          ! system/adapter/onkyo/0/uptime 558
                          ! onkyo/0/command NTM33:43/--:--
                          ! system/adapter/admin/0/memRss 41.86
                          ! system/adapter/admin/0/memHeapUsed 19.47
                          ! system/adapter/admin/0/uptime 607
                          ! system/adapter/example/0/memRss 19.5
                          ! system/adapter/example/0/memHeapUsed 7.83
                          ! system/adapter/example/0/uptime 587
                          ! onkyo/0/command NTM33:44/--:--
                          ! system/adapter/history/0/memRss 24.24
                          ! system/adapter/history/0/memHeapUsed 5.01
                          ! system/adapter/history/0/uptime 604
                          ! onkyo/0/command NTM33:45/--:--
                          ! onkyo/0/command NTM33:46/--:--
                          ! system/adapter/mqtt/0/memRss 26.19
                          ! system/adapter/mqtt/0/memHeapUsed 7.29
                          ! system/adapter/mqtt/0/uptime 558
                          ! onkyo/0/command NTM33:47/--:--
                          ! system/adapter/web/0/memRss 37.19
                          ! system/adapter/web/0/memHeapUsed 13.88
                          ! system/adapter/web/0/uptime 603
                          ! onkyo/0/command NTM33:48/--:--
                          ! onkyo/0/command NTM33:49/--:--
                          ! onkyo/0/command NTM33:50/--:--
                          ! system/adapter/sayit/0/memRss 20.06
                          ! system/adapter/sayit/0/memHeapUsed 8.14
                          ! system/adapter/sayit/0/uptime 574
                          ! system/adapter/email/0/memHeapUsed 7.59
                          ! system/adapter/email/0/uptime 602
                          ! onkyo/0/command NTM33:51/--:--
                          ! onkyo/0/command NTM33:52/--:--
                          ! system/host/Server-PC/memRss 52.71
                          ! system/host/Server-PC/memHeapUsed 21.75
                          ! system/host/Server-PC/uptime 619
                          ! onkyo/0/command NTM33:53/--:--
                          ! system/adapter/javascript/1/memRss 42.06
                          ! system/adapter/javascript/1/memHeapUsed 21.2
                          ! system/adapter/javascript/1/uptime 589
                          ! system/adapter/pushover/0/memHeapUsed 7.35
                          ! system/adapter/pushover/0/uptime 573
                          ! onkyo/0/command NTM33:54/--:--
                          ! onkyo/0/command NTM33:55/--:--
                          ! system/adapter/node-red/0/memRss 20.87
                          ! system/adapter/node-red/0/memHeapUsed 8.95
                          ! system/adapter/node-red/0/uptime 587
                          ! onkyo/0/command NTM33:56/--:--
                          ! onkyo/0/command NTM33:57/--:--
                          ! system/adapter/onkyo/0/memHeapUsed 9.34
                          ! system/adapter/onkyo/0/uptime 573
                          ! onkyo/0/command NTM33:58/--:--
                          ! system/adapter/admin/0/memRss 41.88
                          ! system/adapter/admin/0/memHeapUsed 20.13
                          ! system/adapter/admin/0/uptime 622
                          ! system/adapter/example/0/memRss 19.52
                          ! system/adapter/example/0/memHeapUsed 7.86
                          ! system/adapter/example/0/uptime 602
                          ! onkyo/0/command NTM33:59/--:--
                          ! system/adapter/history/0/memRss 24.25
                          ! system/adapter/history/0/memHeapUsed 5.47
                          ! system/adapter/history/0/uptime 619
                          ! onkyo/0/command NTM34:00/--:--
                          ! onkyo/0/command NTM34:01/--:--
                          ! system/adapter/mqtt/0/memRss 26.21
                          ! system/adapter/mqtt/0/memHeapUsed 8.44
                          ! system/adapter/mqtt/0/uptime 573
                          ! onkyo/0/command NTM34:02/--:--
                          ! system/adapter/web/0/memRss 37.25
                          ! system/adapter/web/0/memHeapUsed 14.53
                          ! system/adapter/web/0/uptime 618
                          ! onkyo/0/command NTM34:03/--:--
                          ! onkyo/0/command NTM34:04/--:--
                          ! onkyo/0/command NTM34:05/--:--
                          ! system/adapter/sayit/0/memRss 20.11
                          ! system/adapter/sayit/0/memHeapUsed 8.18
                          ! system/adapter/sayit/0/uptime 589
                          ! system/adapter/email/0/memRss 19.27
                          ! system/adapter/email/0/memHeapUsed 7.61
                          ! system/adapter/email/0/uptime 617
                          ! onkyo/0/command NTM34:06/--:--
                          ! onkyo/0/command NTM34:07/--:--
                          ! system/host/Server-PC/memRss 52.72
                          ! system/host/Server-PC/memHeapUsed 23.72
                          ! system/host/Server-PC/uptime 634
                          ! onkyo/0/command NTM34:08/--:--
                          ! system/adapter/javascript/1/memRss 42.26
                          ! system/adapter/javascript/1/memHeapUsed 14.93
                          ! system/adapter/javascript/1/uptime 604
                          ! system/adapter/pushover/0/memHeapUsed 7.37
                          ! system/adapter/pushover/0/uptime 588
                          ! onkyo/0/command NTM34:09/--:--
                          ! onkyo/0/command NTM34:10/--:--
                          ! system/adapter/node-red/0/memRss 20.9
                          ! system/adapter/node-red/0/memHeapUsed 8.97
                          ! system/adapter/node-red/0/uptime 602
                          ! onkyo/0/command NTM34:11/--:--
                          ! onkyo/0/command NTM34:12/--:--
                          ! system/adapter/onkyo/0/memRss 25.08
                          ! system/adapter/onkyo/0/memHeapUsed 9.77
                          ! system/adapter/onkyo/0/uptime 588
                          ! onkyo/0/command NTM34:13/--:--
                          ! system/adapter/admin/0/memRss 41.89
                          ! system/adapter/admin/0/memHeapUsed 13.09
                          ! system/adapter/admin/0/uptime 637
                          ! system/adapter/example/0/memRss 19.54
                          ! system/adapter/example/0/memHeapUsed 7.88
                          ! system/adapter/example/0/uptime 617
                          ! onkyo/0/command NTM34:14/--:--
                          ! system/adapter/history/0/memRss 24.27
                          ! system/adapter/history/0/memHeapUsed 5.92
                          ! system/adapter/history/0/uptime 634
                          ! onkyo/0/command NTM34:15/--:--
                          ! onkyo/0/command NTM34:16/--:--
                          ! system/adapter/mqtt/0/memRss 26.23
                          ! system/adapter/mqtt/0/memHeapUsed 9.6
                          ! system/adapter/mqtt/0/uptime 588
                          ! onkyo/0/command NTM34:17/--:--
                          ! system/adapter/web/0/memRss 37.26
                          ! system/adapter/web/0/memHeapUsed 15.17
                          ! system/adapter/web/0/uptime 633
                          ! onkyo/0/command NTM34:18/--:--
                          ! onkyo/0/command NTM34:19/--:--
                          ! onkyo/0/command NTM34:20/--:--
                          ! system/adapter/sayit/0/memRss 20.13
                          ! system/adapter/sayit/0/memHeapUsed 8.2
                          ! system/adapter/sayit/0/uptime 604
                          ! system/adapter/email/0/memRss 19.29
                          ! system/adapter/email/0/memHeapUsed 7.63
                          ! system/adapter/email/0/uptime 632
                          ! onkyo/0/command NTM34:21/--:--
                          ! onkyo/0/command NTM34:22/--:--
                          ! system/host/Server-PC/memRss 52.75
                          ! system/host/Server-PC/memHeapUsed 17.81
                          ! system/host/Server-PC/uptime 649
                          ! onkyo/0/command NTM34:23/--:--
                          ! system/adapter/javascript/1/memRss 42.45
                          ! system/adapter/javascript/1/memHeapUsed 15.7
                          ! system/adapter/javascript/1/uptime 619
                          ! system/adapter/pushover/0/memRss 19.13
                          ! system/adapter/pushover/0/memHeapUsed 7.42
                          ! system/adapter/pushover/0/uptime 603
                          ! onkyo/0/command NTM34:24/--:--
                          ! onkyo/0/command NTM34:25/--:--
                          ! system/adapter/node-red/0/memRss 20.92
                          ! system/adapter/node-red/0/memHeapUsed 8.99
                          ! system/adapter/node-red/0/uptime 617
                          ! onkyo/0/command NTM34:26/--:--
                          ! onkyo/0/command NTM34:27/--:--
                          ! system/adapter/onkyo/0/memRss 25.09
                          ! system/adapter/onkyo/0/memHeapUsed 6.36
                          ! system/adapter/onkyo/0/uptime 603
                          ! onkyo/0/command NTM34:28/--:--
                          ! system/adapter/admin/0/memRss 41.9
                          ! system/adapter/admin/0/memHeapUsed 13.74
                          ! system/adapter/admin/0/uptime 652
                          ! system/adapter/example/0/memRss 19.57
                          ! system/adapter/example/0/memHeapUsed 7.91
                          ! system/adapter/example/0/uptime 632
                          ! onkyo/0/command NTM34:29/--:--
                          ! system/adapter/history/0/memRss 24.28
                          ! system/adapter/history/0/memHeapUsed 6.37
                          ! system/adapter/history/0/uptime 649
                          ! onkyo/0/command NTM34:30/--:--
                          ! onkyo/0/command NTM34:31/--:--
                          ! system/adapter/mqtt/0/memRss 26.26
                          ! system/adapter/mqtt/0/memHeapUsed 6.91
                          ! system/adapter/mqtt/0/uptime 603
                          ! onkyo/0/command NTM34:32/--:--
                          ! system/adapter/web/0/memRss 37.28
                          ! system/adapter/web/0/memHeapUsed 15.81
                          ! system/adapter/web/0/uptime 648
                          ! onkyo/0/command NTM34:33/--:--
                          ! onkyo/0/command NTM34:34/--:--
                          ! onkyo/0/command NTM34:35/--:--
                          ! system/adapter/sayit/0/memRss 20.14
                          ! system/adapter/sayit/0/memHeapUsed 8.22
                          ! system/adapter/sayit/0/uptime 619
                          ! system/adapter/email/0/memRss 19.31
                          ! system/adapter/email/0/memHeapUsed 7.65
                          ! system/adapter/email/0/uptime 647
                          ! onkyo/0/command NTM34:36/--:--
                          ! onkyo/0/command NTM34:37/--:--
                          ! system/host/Server-PC/memRss 52.76
                          ! system/host/Server-PC/memHeapUsed 19.8
                          ! system/host/Server-PC/uptime 664
                          ! onkyo/0/command NTM34:38/--:--
                          ! system/adapter/javascript/1/memRss 42.64
                          ! system/adapter/javascript/1/memHeapUsed 16.48
                          ! system/adapter/javascript/1/uptime 634
                          ! system/adapter/pushover/0/memHeapUsed 7.44
                          ! system/adapter/pushover/0/uptime 618
                          ! onkyo/0/command NTM34:39/--:--
                          ! onkyo/0/command NTM34:40/--:--
                          ! system/adapter/node-red/0/memRss 20.95
                          ! system/adapter/node-red/0/memHeapUsed 9.02
                          ! system/adapter/node-red/0/uptime 632
                          ! onkyo/0/command NTM34:41/--:--
                          ! onkyo/0/command NTM34:42/--:--
                          ! system/adapter/onkyo/0/memRss 25.1
                          ! system/adapter/onkyo/0/memHeapUsed 6.79
                          ! system/adapter/onkyo/0/uptime 618
                          ! onkyo/0/command NTM34:43/--:--
                          ! system/adapter/admin/0/memRss 41.92
                          ! system/adapter/admin/0/memHeapUsed 14.41
                          ! system/adapter/admin/0/uptime 667
                          ! system/adapter/example/0/memRss 19.59
                          ! system/adapter/example/0/memHeapUsed 7.93
                          ! system/adapter/example/0/uptime 647
                          ! onkyo/0/command NTM34:44/--:--
                          ! system/adapter/history/0/memRss 24.3
                          ! system/adapter/history/0/memHeapUsed 6.84
                          ! system/adapter/history/0/uptime 664
                          ! onkyo/0/command NTM34:45/--:--
                          ! onkyo/0/command NTM34:46/--:--
                          ! system/adapter/mqtt/0/memRss 26.27
                          ! system/adapter/mqtt/0/memHeapUsed 8.06
                          ! system/adapter/mqtt/0/uptime 618
                          ! onkyo/0/command NTM34:47/--:--
                          ! system/adapter/web/0/memRss 37.29
                          ! system/adapter/web/0/memHeapUsed 16.46
                          ! system/adapter/web/0/uptime 663
                          ! onkyo/0/command NTM34:48/--:--
                          ! onkyo/0/command NTM34:49/--:--
                          ! system/adapter/sayit/0/memRss 20.17
                          ! system/adapter/sayit/0/memHeapUsed 8.24
                          ! system/adapter/sayit/0/uptime 634
                          ! onkyo/0/command NTM34:50/--:--
                          ! system/adapter/email/0/memRss 19.34
                          ! system/adapter/email/0/memHeapUsed 7.68
                          ! system/adapter/email/0/uptime 662
                          ! onkyo/0/command NTM34:51/--:--
                          ! onkyo/0/command NTM34:52/--:--
                          ! system/host/Server-PC/mem 26
                          ! system/host/Server-PC/memRss 52.77
                          ! system/host/Server-PC/memHeapUsed 21.59
                          ! system/host/Server-PC/uptime 679
                          ! onkyo/0/command NTM34:53/--:--
                          ! system/adapter/javascript/1/memRss 42.84
                          ! system/adapter/javascript/1/memHeapUsed 17.25
                          ! system/adapter/javascript/1/uptime 649
                          ! system/adapter/pushover/0/memHeapUsed 7.46
                          ! system/adapter/pushover/0/uptime 633
                          ! onkyo/0/command NTM34:54/--:--
                          ! onkyo/0/command NTM34:55/--:--
                          ! system/adapter/node-red/0/memRss 20.98
                          ! system/adapter/node-red/0/memHeapUsed 9.05
                          ! system/adapter/node-red/0/uptime 647
                          ! onkyo/0/command NTM34:56/--:--
                          ! onkyo/0/command NTM34:57/--:--
                          ! system/adapter/onkyo/0/memHeapUsed 7.23
                          ! system/adapter/onkyo/0/uptime 633
                          ! onkyo/0/command NTM34:58/--:--
                          ! system/adapter/admin/0/memRss 41.93
                          ! system/adapter/admin/0/memHeapUsed 15.09
                          ! system/adapter/admin/0/uptime 682
                          ! system/adapter/example/0/memRss 19.63
                          ! system/adapter/example/0/memHeapUsed 7.96
                          ! system/adapter/example/0/uptime 662
                          ! onkyo/0/command NTM34:59/--:--
                          ! system/adapter/history/0/memRss 24.31
                          ! system/adapter/history/0/memHeapUsed 7.3
                          ! system/adapter/history/0/uptime 679
                          ! onkyo/0/command NTM35:00/--:--
                          ! onkyo/0/command NTM35:01/--:--
                          ! system/adapter/mqtt/0/memRss 26.29
                          ! system/adapter/mqtt/0/memHeapUsed 9.2
                          ! system/adapter/mqtt/0/uptime 633
                          ! onkyo/0/command NTM35:02/--:--
                          ! system/adapter/web/0/memRss 37.32
                          ! system/adapter/web/0/memHeapUsed 9.4
                          ! system/adapter/web/0/uptime 678
                          ! onkyo/0/command NTM35:03/--:--
                          ! onkyo/0/command NTM35:04/--:--
                          ! onkyo/0/command NTM35:05/--:--
                          ! system/adapter/sayit/0/memRss 20.19
                          ! system/adapter/sayit/0/memHeapUsed 8.26
                          ! system/adapter/sayit/0/uptime 649
                          ! system/adapter/email/0/memRss 19.37
                          ! system/adapter/email/0/memHeapUsed 7.71
                          ! system/adapter/email/0/uptime 677
                          ! onkyo/0/command NTM35:06/--:--
                          ! onkyo/0/command NTM35:07/--:--
                          ! system/host/Server-PC/memRss 52.78
                          ! system/host/Server-PC/memHeapUsed 23.56
                          ! system/host/Server-PC/uptime 694
                          ! onkyo/0/command NTM35:08/--:--
                          ! system/adapter/javascript/1/memRss 43.08
                          ! system/adapter/javascript/1/memHeapTotal 34.28
                          ! system/adapter/javascript/1/memHeapUsed 18.03
                          ! system/adapter/javascript/1/uptime 664
                          ! system/adapter/pushover/0/memRss 19.15
                          ! system/adapter/pushover/0/memHeapUsed 7.49
                          ! system/adapter/pushover/0/uptime 648
                          ! onkyo/0/command NTM35:09/--:--
                          ! onkyo/0/command NTM35:10/--:--
                          ! system/adapter/node-red/0/memRss 21.02
                          ! system/adapter/node-red/0/memHeapUsed 9.07
                          ! system/adapter/node-red/0/uptime 662
                          ! onkyo/0/command NTM35:11/--:--
                          ! onkyo/0/command NTM35:12/--:--
                          ! system/adapter/onkyo/0/memHeapUsed 7.67
                          ! system/adapter/onkyo/0/uptime 648
                          ! onkyo/0/command NTM35:13/--:--
                          ! system/adapter/admin/0/memRss 41.95
                          ! system/adapter/admin/0/memHeapUsed 15.74
                          ! system/adapter/admin/0/uptime 697
                          ! system/adapter/example/0/memRss 19.65
                          ! system/adapter/example/0/memHeapUsed 7.98
                          ! system/adapter/example/0/uptime 677
                          ! onkyo/0/command NTM35:14/--:--
                          ! system/adapter/history/0/memRss 24.32
                          ! system/adapter/history/0/memHeapUsed 7.76
                          ! system/adapter/history/0/uptime 694
                          ! onkyo/0/command NTM35:15/--:--
                          ! onkyo/0/command NTM35:16/--:--
                          ! system/adapter/mqtt/0/memRss 26.31
                          ! system/adapter/mqtt/0/memHeapUsed 10.35
                          ! system/adapter/mqtt/0/uptime 648
                          ! onkyo/0/command NTM35:17/--:--
                          ! system/adapter/web/0/memRss 37.33
                          ! system/adapter/web/0/memHeapUsed 10.05
                          ! system/adapter/web/0/uptime 693
                          ! onkyo/0/command NTM35:18/--:--
                          ! onkyo/0/command NTM35:19/--:--
                          ! onkyo/0/command NTM35:20/--:--
                          ! system/adapter/sayit/0/memRss 20.21
                          ! system/adapter/sayit/0/memHeapUsed 8.29
                          ! system/adapter/sayit/0/uptime 664
                          ! system/adapter/email/0/memRss 19.39
                          ! system/adapter/email/0/memHeapUsed 7.73
                          ! system/adapter/email/0/uptime 692
                          ! onkyo/0/command NTM35:21/--:--
                          ! onkyo/0/command NTM35:22/--:--
                          ! system/host/Server-PC/memRss 52.79
                          ! system/host/Server-PC/memHeapUsed 25.35
                          ! system/host/Server-PC/uptime 709
                          ! onkyo/0/command NTM35:23/--:--
                          ! system/adapter/javascript/1/memRss 43.28
                          ! system/adapter/javascript/1/memHeapUsed 18.81
                          ! system/adapter/javascript/1/uptime 679
                          ! system/adapter/pushover/0/memRss 19.16
                          ! system/adapter/pushover/0/memHeapUsed 7.52
                          ! system/adapter/pushover/0/uptime 663
                          ! onkyo/0/command NTM35:24/--:--
                          ! onkyo/0/command NTM35:25/--:--
                          ! system/adapter/node-red/0/memRss 21.04
                          ! system/adapter/node-red/0/memHeapUsed 9.1
                          ! system/adapter/node-red/0/uptime 677
                          ! onkyo/0/command NTM35:26/--:--
                          ! onkyo/0/command NTM35:27/--:--
                          ! system/adapter/onkyo/0/memRss 25.06
                          ! system/adapter/onkyo/0/memHeapUsed 8.1
                          ! system/adapter/onkyo/0/uptime 663
                          ! onkyo/0/command NTM35:28/--:--
                          ! system/adapter/admin/0/memRss 41.96
                          ! system/adapter/admin/0/memHeapUsed 16.41
                          ! system/adapter/admin/0/uptime 712
                          ! system/adapter/example/0/memRss 19.67
                          ! system/adapter/example/0/memHeapUsed 8
                          ! system/adapter/example/0/uptime 692
                          ! onkyo/0/command NTM35:29/--:--
                          ! system/adapter/history/0/memRss 24.34
                          ! system/adapter/history/0/memHeapUsed 8.21
                          ! system/adapter/history/0/uptime 709
                          ! onkyo/0/command NTM35:30/--:--
                          ! onkyo/0/command NTM35:31/--:--
                          ! system/adapter/mqtt/0/memRss 26.33
                          ! system/adapter/mqtt/0/memHeapUsed 7.66
                          ! system/adapter/mqtt/0/uptime 663
                          ! onkyo/0/command NTM35:32/--:--
                          ! system/adapter/web/0/memRss 37.34
                          ! system/adapter/web/0/memHeapUsed 10.69
                          ! system/adapter/web/0/uptime 708
                          ! onkyo/0/command NTM35:33/--:--
                          ! onkyo/0/command NTM35:34/--:--
                          ! onkyo/0/command NTM35:35/--:--
                          ! system/adapter/sayit/0/memRss 20.24
                          ! system/adapter/sayit/0/memHeapUsed 8.32
                          ! system/adapter/sayit/0/uptime 679
                          ! system/adapter/email/0/memRss 19.42
                          ! system/adapter/email/0/memHeapUsed 7.75
                          ! system/adapter/email/0/uptime 707
                          ! onkyo/0/command NTM35:36/--:--
                          ! onkyo/0/command NTM35:37/--:--
                          ! system/host/Server-PC/memRss 52.88
                          ! system/host/Server-PC/memHeapUsed 19.83
                          ! system/host/Server-PC/uptime 724
                          ! onkyo/0/command NTM35:38/--:--
                          ! system/adapter/javascript/1/memRss 43.47
                          ! system/adapter/javascript/1/memHeapUsed 19.59
                          ! system/adapter/javascript/1/uptime 694
                          ! system/adapter/pushover/0/memHeapUsed 7.54
                          ! system/adapter/pushover/0/uptime 678
                          ! onkyo/0/command NTM35:39/--:--
                          ! onkyo/0/command NTM35:40/--:--
                          ! system/adapter/node-red/0/memRss 21.06
                          ! system/adapter/node-red/0/memHeapUsed 9.12
                          ! system/adapter/node-red/0/uptime 692
                          ! onkyo/0/command NTM35:41/--:--
                          ! onkyo/0/command NTM35:42/--:--
                          ! system/adapter/onkyo/0/memHeapUsed 8.54
                          ! system/adapter/onkyo/0/uptime 678
                          ! onkyo/0/command NTM35:43/--:--
                          ! system/adapter/admin/0/memRss 42.12
                          ! system/adapter/admin/0/memHeapUsed 17.36
                          ! system/adapter/admin/0/uptime 727
                          ! system/adapter/example/0/memRss 19.7
                          ! system/adapter/example/0/memHeapUsed 8.03
                          ! system/adapter/example/0/uptime 707
                          ! onkyo/0/command NTM35:44/--:--
                          ! system/adapter/history/0/memRss 24.35
                          ! system/adapter/history/0/memHeapUsed 8.67
                          ! system/adapter/history/0/uptime 724
                          ! onkyo/0/command NTM35:45/--:--
                          ! onkyo/0/command NTM35:46/--:--
                          ! system/adapter/mqtt/0/memRss 26.34
                          ! system/adapter/mqtt/0/uptime 678
                          ! onkyo/0/command NTM35:47/--:--
                          ! system/adapter/web/0/memRss 37.36
                          ! system/adapter/web/0/memHeapUsed 11.33
                          ! system/adapter/web/0/uptime 723
                          ! onkyo/0/command NTM35:48/--:--
                          ! onkyo/0/command NTM35:49/--:--
                          ! onkyo/0/command NTM35:50/--:--
                          ! system/adapter/sayit/0/memRss 20.26
                          ! system/adapter/sayit/0/memHeapUsed 8.33
                          ! system/adapter/sayit/0/uptime 694
                          ! system/adapter/email/0/memRss 19.43
                          ! system/adapter/email/0/memHeapUsed 7.77
                          ! system/adapter/email/0/uptime 722
                          ! onkyo/0/command NTM35:51/--:--
                          ! onkyo/0/command NTM35:52/--:--
                          ! system/host/Server-PC/memRss 52.91
                          ! system/host/Server-PC/memHeapUsed 21.72
                          ! system/host/Server-PC/uptime 739
                          ! onkyo/0/command NTM35:53/--:--
                          ! system/adapter/javascript/1/memRss 43.67
                          ! system/adapter/javascript/1/memHeapUsed 20.37
                          ! system/adapter/javascript/1/uptime 709
                          ! system/adapter/pushover/0/memHeapUsed 7.56
                          ! system/adapter/pushover/0/uptime 693
                          ! onkyo/0/command NTM35:54/--:--
                          ! onkyo/0/command NTM35:55/--:--
                          ! system/adapter/node-red/0/memRss 21.09
                          ! system/adapter/node-red/0/memHeapUsed 9.14
                          ! system/adapter/node-red/0/uptime 707
                          ! onkyo/0/command NTM35:56/--:--
                          ! onkyo/0/command NTM35:57/--:--
                          ! system/adapter/onkyo/0/memRss 25.16
                          ! system/adapter/onkyo/0/memHeapUsed 8.98
                          ! system/adapter/onkyo/0/uptime 693
                          ! onkyo/0/command NTM35:58/--:--
                          ! system/adapter/admin/0/memRss 42.13
                          ! system/adapter/admin/0/memHeapUsed 18.04
                          ! system/adapter/admin/0/uptime 742
                          ! system/adapter/example/0/memRss 19.71
                          ! system/adapter/example/0/memHeapUsed 8.05
                          ! system/adapter/example/0/uptime 722
                          ! onkyo/0/command NTM35:59/--:--
                          ! system/adapter/history/0/memRss 24.36
                          ! system/adapter/history/0/memHeapUsed 5.28
                          ! system/adapter/history/0/uptime 739
                          ! onkyo/0/command NTM36:00/--:--
                          ! onkyo/0/command NTM36:01/--:--
                          ! system/adapter/mqtt/0/memRss 26.36
                          ! system/adapter/mqtt/0/memHeapUsed 9.95
                          ! system/adapter/mqtt/0/uptime 693
                          ! onkyo/0/command NTM36:02/--:--
                          ! system/adapter/web/0/memRss 37.37
                          ! system/adapter/web/0/memHeapUsed 11.98
                          ! system/adapter/web/0/uptime 738
                          ! onkyo/0/command NTM36:03/--:--
                          ! onkyo/0/command NTM36:04/--:--
                          ! onkyo/0/command NTM36:05/--:--
                          ! system/adapter/sayit/0/memRss 20.28
                          ! system/adapter/sayit/0/memHeapUsed 8.36
                          ! system/adapter/sayit/0/uptime 709
                          ! system/adapter/email/0/memRss 19.46
                          ! system/adapter/email/0/memHeapUsed 7.79
                          ! system/adapter/email/0/uptime 737
                          ! onkyo/0/command NTM36:06/--:--
                          ! onkyo/0/command NTM36:07/--:--
                          ! onkyo/0/command NTM36:08/--:--
                          ! system/host/Server-PC/memRss 52.92
                          ! system/host/Server-PC/memHeapUsed 23.74
                          ! system/host/Server-PC/uptime 754
                          ! system/adapter/javascript/1/memRss 43.88
                          ! system/adapter/javascript/1/memHeapUsed 21.15
                          ! system/adapter/javascript/1/uptime 724
                          ! system/adapter/pushover/0/memHeapUsed 7.59
                          ! system/adapter/pushover/0/uptime 708
                          ! onkyo/0/command NTM36:09/--:--
                          ! onkyo/0/command NTM36:10/--:--
                          ! system/adapter/node-red/0/memRss 21.1
                          ! system/adapter/node-red/0/memHeapUsed 9.16
                          ! system/adapter/node-red/0/uptime 722
                          ! onkyo/0/command NTM36:11/--:--
                          ! onkyo/0/command NTM36:12/--:--
                          ! system/adapter/onkyo/0/memHeapUsed 9.41
                          ! system/adapter/onkyo/0/uptime 708
                          ! onkyo/0/command NTM36:13/--:--
                          ! system/adapter/admin/0/memRss 42.14
                          ! system/adapter/admin/0/memHeapUsed 18.7
                          ! system/adapter/admin/0/uptime 757
                          ! system/adapter/example/0/memRss 19.75
                          ! system/adapter/example/0/memHeapUsed 8.09
                          ! system/adapter/example/0/uptime 737
                          ! onkyo/0/command NTM36:14/--:--
                          ! system/adapter/history/0/memRss 24.37
                          ! system/adapter/history/0/memHeapUsed 5.72
                          ! system/adapter/history/0/uptime 754
                          ! onkyo/0/command NTM36:15/--:--
                          ! onkyo/0/command NTM36:16/--:--
                          ! system/adapter/mqtt/0/memRss 26.38
                          ! system/adapter/mqtt/0/memHeapUsed 7.26
                          ! system/adapter/mqtt/0/uptime 708
                          ! onkyo/0/command NTM36:17/--:--
                          ! system/adapter/web/0/memRss 37.38
                          ! system/adapter/web/0/memHeapUsed 12.63
                          ! system/adapter/web/0/uptime 753
                          ! onkyo/0/command NTM36:18/--:--
                          ! onkyo/0/command NTM36:19/--:--
                          ! onkyo/0/command NTM36:20/--:--
                          ! system/adapter/sayit/0/memRss 20.3
                          ! system/adapter/sayit/0/memHeapUsed 8.37
                          ! system/adapter/sayit/0/uptime 724
                          ! system/adapter/email/0/memRss 19.48
                          ! system/adapter/email/0/memHeapUsed 7.82
                          ! system/adapter/email/0/uptime 752
                          ! onkyo/0/command NTM36:21/--:--
                          ! onkyo/0/command NTM36:22/--:--
                          ! onkyo/0/command NTM36:23/--:--
                          ! system/host/Server-PC/memRss 52.95
                          ! system/host/Server-PC/memHeapUsed 17.86
                          ! system/host/Server-PC/uptime 769
                          ! system/adapter/javascript/1/memRss 44.13
                          ! system/adapter/javascript/1/memHeapTotal 35.24
                          ! system/adapter/javascript/1/memHeapUsed 21.97
                          ! system/adapter/javascript/1/uptime 739
                          ! system/adapter/pushover/0/memRss 19.18
                          ! system/adapter/pushover/0/memHeapUsed 7.6
                          ! system/adapter/pushover/0/uptime 723
                          ! onkyo/0/command NTM36:24/--:--
                          ! onkyo/0/command NTM36:25/--:--
                          ! system/adapter/node-red/0/memRss 21.13
                          ! system/adapter/node-red/0/memHeapUsed 9.19
                          ! system/adapter/node-red/0/uptime 737
                          ! onkyo/0/command NTM36:26/--:--
                          ! onkyo/0/command NTM36:27/--:--
                          ! system/adapter/onkyo/0/memHeapUsed 9.83
                          ! system/adapter/onkyo/0/uptime 723
                          ! onkyo/0/command NTM36:28/--:--
                          ! system/adapter/admin/0/memRss 42.15
                          ! system/adapter/admin/0/memHeapUsed 19.36
                          ! system/adapter/admin/0/uptime 772
                          ! system/adapter/example/0/memRss 19.82
                          ! system/adapter/example/0/memHeapUsed 8.14
                          ! system/adapter/example/0/uptime 752
                          ! onkyo/0/command NTM36:29/--:--
                          ! system/adapter/history/0/memRss 24.39
                          ! system/adapter/history/0/memHeapUsed 6.2
                          ! system/adapter/history/0/uptime 769
                          ! onkyo/0/command NTM36:30/--:--
                          ! onkyo/0/command NTM36:31/--:--
                          ! system/adapter/mqtt/0/memRss 26.39
                          ! system/adapter/mqtt/0/memHeapUsed 8.41
                          ! system/adapter/mqtt/0/uptime 723
                          ! onkyo/0/command NTM36:32/--:--
                          ! system/adapter/web/0/memRss 37.4
                          ! system/adapter/web/0/memHeapUsed 13.27
                          ! system/adapter/web/0/uptime 768
                          ! onkyo/0/command NTM36:33/--:--
                          ! onkyo/0/command NTM36:34/--:--
                          ! system/host/Server-PC/memHeapUsed 20.08
                          ! system/host/Server-PC/memRss 52.98
                          ! system/host/Server-PC/uptime 784
                          ! system/adapter/email/0/uptime 767
                          ! system/adapter/email/0/memRss 19.52
                          ! system/adapter/email/0/memHeapUsed 7.85
                          ! vis/0/control/data main/Home
                          ! vis/0/control/command changedView
                          ! vis/0/control/instance fc79e8e0
                          ! ping/0/Server-PC/192_168_1_177 true
                          ! example/0/testVariable null
                          ! ping/0/Server-PC/192_168_1_140 true
                          ! ping/0/Server-PC/192_168_1_10 true
                          ! system/adapter/simple-api/0/uptime 32
                          ! system/adapter/simple-api/0/memRss 19.35
                          ! system/adapter/simple-api/0/memHeapTotal 15.69
                          ! system/adapter/simple-api/0/memHeapUsed 6.66
                          ! system/adapter/simple-api/0/connected false
                          ! system/adapter/simple-api/0/alive false
                          ! yr/0/forecast/diagram http://www.yr.no/place/Russland/Altaj-t ... eogram.png
                          ! yr/0/forecast/object [object Object],[object Object],[object Object]
                          ! yr/0/forecast/day2/pressure 1020
                          ! yr/0/forecast/day2/wind_speed 6.7
                          ! yr/0/forecast/day2/wind_direction CРЎР’
                          ! yr/0/forecast/day2/precipitation_chance null
                          ! yr/0/forecast/day2/precipitation_level 0
                          ! yr/0/forecast/day2/temperature_max 17
                          ! yr/0/forecast/day2/temperature_min 8
                          ! yr/0/forecast/day2/text Облачно
                          ! yr/0/forecast/day2/icon http://symbol.yr.no/grafikk/sym/b38/04.png
                          ! yr/0/forecast/day2/date 14.05.2015
                          ! yr/0/forecast/day1/pressure 1019
                          ! yr/0/forecast/day1/wind_speed 10.2
                          ! yr/0/forecast/day1/wind_direction C
                          ! yr/0/forecast/day1/precipitation_chance null
                          ! yr/0/forecast/day1/precipitation_level 0
                          ! yr/0/forecast/day1/temperature_max 15
                          ! yr/0/forecast/day1/temperature_min 7
                          ! yr/0/forecast/day1/text Переменная облачность
                          ! yr/0/forecast/day1/icon http://symbol.yr.no/grafikk/sym/b38/03d.png
                          ! yr/0/forecast/day1/date 13.05.2015
                          ! yr/0/forecast/day0/pressure 1015
                          ! yr/0/forecast/day0/wind_speed 15.8
                          ! yr/0/forecast/day0/wind_direction C
                          ! yr/0/forecast/day0/precipitation_chance null
                          ! yr/0/forecast/day0/precipitation_level 0
                          ! yr/0/forecast/day0/temperature_max 12
                          ! yr/0/forecast/day0/temperature_min 12
                          ! yr/0/forecast/day0/temperature_actual 12
                          ! yr/0/forecast/day0/humidity undefined
                          ! yr/0/forecast/day0/text Чистое небо
                          ! yr/0/forecast/day0/icon http://symbol.yr.no/grafikk/sym/b38/mf/01n.79.png
                          ! yr/0/forecast/day0/date 13.05.2015
                          ! system/adapter/yr/0/uptime 2
                          ! system/adapter/yr/0/memRss 21
                          ! system/adapter/yr/0/memHeapTotal 15.69
                          ! system/adapter/yr/0/memHeapUsed 6.78
                          ! system/adapter/yr/0/connected null
                          ! system/adapter/yr/0/alive false
                          ! ping/0/Server-PC/192_168_1_210 true
                          ! system/adapter/javascript/1/uptime 754
                          ! system/adapter/javascript/1/memRss 44.34
                          ! system/adapter/javascript/1/memHeapUsed 22.81
                          ! javascript/1/Light 1
                          ! javascript/1/arduinoButton false
                          ! javascript/1/arduinoButton2 false
                          ! javascript/1/arduinoButtontest false
                          ! javascript/1/arduinoButtonBedroom false
                          ! javascript/1/arduinoButtonBathroom false
                          ! javascript/1/arduinoButtonKitchen false
                          ! javascript/1/arduinoAngle 61.199999999999996
                          ! system/adapter/node-red/0/uptime 752
                          ! system/adapter/node-red/0/memRss 21.17
                          ! system/adapter/node-red/0/memHeapUsed 9.23
                          ! system/adapter/socketio/0/uptime 19
                          ! system/adapter/socketio/0/memRss 25
                          ! system/adapter/socketio/0/memHeapTotal 16.66
                          ! system/adapter/socketio/0/memHeapUsed 7.36
                          ! system/adapter/socketio/0/connected false
                          ! system/adapter/socketio/0/alive false
                          ! node-red/0/javascript/1/arduinoButtonBathroom undefined
                          ! node-red/0/sayit/0/tts/text undefined
                          ! sayit/0/tts/mp3 undefined
                          ! sayit/0/tts/playing false
                          ! sayit/0/tts/text Закрой окно
                          ! sayit/0/tts/volume 100
                          ! system/adapter/sayit/0/uptime 739
                          ! system/adapter/sayit/0/memRss 20.32
                          ! system/adapter/sayit/0/memHeapUsed 8.4
                          ! system/adapter/pushover/0/wakeup undefined
                          ! system/adapter/pushover/0/uptime 738
                          ! system/adapter/pushover/0/memRss 19.21
                          ! system/adapter/pushover/0/memHeapUsed 7.63
                          ! onkyo/0/connected true
                          ! onkyo/0/input dvd,bd,dvd
                          ! onkyo/0/power standby
                          ! onkyo/0/mute undefined
                          ! onkyo/0/volume 22
                          ! onkyo/0/master-volume 22
                          ! onkyo/0/command NTM36:41/–:--
                          ! javascript/1/arduinoButtonGuest false
                          ! node-red/0/javascript/1/arduinoButtonBedroom undefined
                          ! system/adapter/mqtt/0/uptime 3
                          ! system/adapter/mqtt/0/memRss 22.57
                          ! system/adapter/mqtt/0/memHeapTotal 15.69
                          ! system/adapter/mqtt/0/memHeapUsed 8.97
                          ! mqtt/0/myhome/out/Kitchen_light1 1
                          Ваше сообщение содержит слишком много знаков: 147573. Максимальное разрешённое количество: 60000.
                          • Bluefox
                            @instalator:
                            Короче где то косяк в драйвере, он валит все подряд, только не то что надо, у меня mqtt например вываливает значение onkyo, которое меняется каждую секунду так как там идет время проигрования. И когда долетит команда для ардуины хз. `
                            Да. Спасибо. Я уже нашел…
                            Можешь попробовать:
                            cd /opt/iobroker
                            npm install https://github.com/ioBroker/ioBroker.mqtt/tarball/master
                              electric69 last edited by
                              Что то я не могу понять логику работы этого MQTT…
                              Я правильно понимаю, что сервер iobroker у нас как брокер, ардуина - клиент.
                              Ардуина создает топик (в iobroker появляется переменная) и передает (публикует) в него через конкретный интервал времени значение.
                              Т.е. инициатива на обновление значения переменной исходит от Ардуины.
                              ioBroker может проявить инициативу и запросить у ардуины значение? Получается что нет))
                              Блин, документации на русском еще фиг найдешь...
                              • I
                                @electric69:
                                Блин, документации на русском еще фиг найдешь... `
                                Да помоему не очень протокол, получается адресации нет. драйвер шлет в сеть мусор, ардуниы его принимают, парсят и если что то прилетело определенной ардуине она обрабатывает распарсеный пакет.
                                Я и говорю что это телеметрия, для датчиков да пойдет, датчик с переодичностью шлет в сеть свои данные и все.
                                Плюс если устройств куча, каждый клиент шлет свои данные, в сети появляется много мусора. Представь что постоянно что то летит по протоколу и ардуина его парсит, она только и будет все время обрабатывать пакеты прилетающие а на другие операции процессорного времени не найдется
                                • I
                                  @Bluefox:
                                  Можешь попробовать:
                                  cd /opt/iobroker
                                  Обновил, изменений н езаметил. в брокере меняю переменную через vis в протокол ничего не шлется. Шлется только при перезапуске драйвера и при коннекте к клиенту
                                  • I
                                    Появилась куча непонятных переменных
                                      @instalator:
                                      Да помоему не очень протокол, получается `
                                      Да не. нормальный протокол, все больше мне начинает нравится, надо просто разобраться…
                                      @instalator:
                                      адресации нет. драйвер шлет в сеть мусор, ардуниы его принимают, парсят и если что то прилетело определенной ардуине она обрабатывает распарсеный пакет. `
                                      Скетч ардуины выложите пожалуйста… Ато не понятно кто кому как что шлет))
                                      @instalator:
                                      Я и говорю что это телеметрия, для датчиков да пойдет, датчик с переодичностью шлет в сеть свои данные и все. `
                                      Не, для управления тоже можно, примеров http://bogdanioanliviu.no-ip.org/part1-arduino-mqtt-web-socket-home-automation/, надо просто разобраться что куда.
                                      @instalator:
                                      Плюс если устройств куча, каждый клиент шлет свои данные, в сети появляется много мусора. Представь что постоянно что то летит по протоколу и ардуина его парсит, она только и будет все время обрабатывать пакеты прилетающие а на другие операции процессорного времени не найдется `
                                      Так вроде если клиент-ардуина подписана на топик - ей изменение параметра прилетит, если нет - то она ничего не получит…
                                      Немного отсебятинки - последняя строка настройки адаптера не переведа - на английском.
                                      • I
                                        @electric69:
                                        А как ардуина узнает что это именно ей прилетело? ей придется парсить весь мусор в протоколе
                                        Код переделывал отсюда http://habrahabr.ru/post/250833/
                                        Хотя ты прав, если только этому ip шлется. Видимо драйвер просто не шлет изменение статуса.
                                          @instalator:
                                          А как ардуина узнает что это именно ей прилетело? ей придется парсить весь мусор в протоколе `
                                          Есть такая настройка, clientID называется (ну или как назовешь сам), в этом https://github.com/knolleary/pubsubclient/blob/master/PubSubClient/examples/mqtt_auth/mqtt_auth.ino значение "arduinoClient" у нее.
                                          Вот тут клиент айди, и аутентификация
                                          client.connect("clientID", "mqtt_username", "mqtt_password");
                                          В примере с хабра - айди = "myhome-kitchen", аутентификации нет, может поэтому трабл?
                                          В настройках MQTT-адаптера указывал логин/пароль?
                                          client.connect("myhome-kitchen")
                                          • Bluefox
                                            Полностью поддерживаю electric69, что это очень простой и перспективный протокол.
                                            Ардуина должна подписатся на сообщения. Например subscribe("myhome/in/#"). Ты подписался?
                                            Советую в начале топика не писать "/", а сразу начинать с "myhome/…"
                                            Есть обновление. Сильно переработанное. Там есть новая настройка : Send commands (not ack) too
                                            Это если ты хочешь слать к ардуине статус... Хотя не понятно зачем. 😉
                                            Да забыл..
                                            Есть помощь по драйверу. Правда на аглицком. https://github.com/ioBroker/ioBroker.mqtt#configuration
                                            244
                                            65698
