    4. Adapter "smartmeter"
      backons last edited by
      ich habe heute meinen Adapter von Weidmann Elektronik bekommen und angeschlossen.
      Als Stromzähler habe ich einen MT175 und folgendes habe ich im Smartmeter eingestellt:
      wenn ich den Adapter starte kommt folgendes im LOG:
      host.rock64	2019-02-20 20:41:12.062	info	Restart adapter system.adapter.smartmeter.0 because enabled
      host.rock64	2019-02-20 20:41:12.062	error	instance system.adapter.smartmeter.0 terminated with code 1 ()
      Caught	2019-02-20 20:41:12.061	error	by controller[0]: at Object.Module._extensions..js (module.js:664:10)
      Caught	2019-02-20 20:41:12.061	error	by controller[0]: at Module._compile (module.js:653:30)
      Caught	2019-02-20 20:41:12.061	error	by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/serialport/lib/bindings/linux.js:2:36)
      Caught	2019-02-20 20:41:12.061	error	by controller[0]: at bindings (/opt/iobroker/node_modules/serialport/node_modules/bindings/bindings.js:81:44)
      Caught	2019-02-20 20:41:12.061	error	by controller[0]: at require (internal/module.js:11:18)
      Caught	2019-02-20 20:41:12.061	error	by controller[0]: at Module.require (module.js:597:17)
      Caught	2019-02-20 20:41:12.060	error	by controller[0]: at Function.Module._load (module.js:498:3)
      Caught	2019-02-20 20:41:12.060	error	by controller[0]: at tryModuleLoad (module.js:506:12)
      Caught	2019-02-20 20:41:12.060	error	by controller[0]: at Module.load (module.js:566:32)
      Caught	2019-02-20 20:41:12.060	error	by controller[0]: at Object.Module._extensions..node (module.js:682:18)
      Caught	2019-02-20 20:41:12.060	error	by controller[0]: Error: /opt/iobroker/node_modules/serialport/build/Release/serialport.node: wrong ELF class: ELFCLASS32
      Caught	2019-02-20 20:41:12.060	error	by controller[0]: ^
      Caught	2019-02-20 20:41:12.059	error	by controller[0]: throw e
      Caught	2019-02-20 20:41:12.059	error	by controller[0]: /opt/iobroker/node_modules/serialport/node_modules/bindings/bindings.js:88
      host.rock64	2019-02-20 20:41:10.699	info	instance system.adapter.smartmeter.0 started with pid 9496
      Kann mir jemand sagen was den Fehler auslöst ?
      • porty
        porty last edited by porty
        @backons
        warum hast du unter Datenprotokoll: D0 angegeben?
        Der MT175 nutzt die SML (SmartMeterLanguage)
        Dann ist schon mal die Hälfte der Settings weg.
        Dann trägst du den USb Port ein. Am besten als "/dev/serial/by-id/id_bzw_port_des_Adapters"
          digitalnaive last edited by
          Jetzt muss ich den Thread leider doch wieder aufgreifen. Aus dem nichts bekomme ich plötzlich keine Werte mehr von meinem Smartmeter. Und die Logfile wirft alt bekannte Probleme aus. Was kann denn dafür der Grund sein, dass ein vorher funktionierendes Setting plötzlich nicht mehr die gewünschten Daten liefert?
          smartmeter.0	2019-03-13 09:22:12.929	debug	SCHEDULE NEXT RUN IN 30000s
          smartmeter.0	2019-03-13 09:22:12.929	debug	DELETE rest of data (0) because new Message start with a new Request Message
          smartmeter.0	2019-03-13 09:22:12.929	debug	CURRENT SIGNON MESSAGE COUNTER 1 OF 1
          smartmeter.0	2019-03-13 09:22:12.929	debug	SERIALPORT REMOVE LISTENERS
          smartmeter.0	2019-03-13 09:22:12.929	debug	SERIALPORT CLOSE
          smartmeter.0	2019-03-13 09:22:12.929	debug	CLEAR MESSAGE TIMEOUT TIMER
          smartmeter.0	2019-03-13 09:22:12.928	debug	STOP
          smartmeter.0	2019-03-13 09:22:12.928	debug	Transport Reset!! Restart = true
          smartmeter.0	2019-03-13 09:22:12.928	debug	Error: No or too long answer from Serial Device after last request.
          smartmeter.0	2019-03-13 09:22:12.928	warn	No or too long answer from Serial Device after last request.
          smartmeter.0	2019-03-13 09:22:12.927	debug	MESSAGE TIMEOUT TRIGGERED
          smartmeter.0	2019-03-13 09:21:42.916	debug	SET MESSAGE TIMEOUT TIMER2: 30000
          smartmeter.0	2019-03-13 09:21:42.915	debug	DONE SEND 0
          smartmeter.0	2019-03-13 09:21:42.664	debug	DONE SEND 1
          smartmeter.0	2019-03-13 09:21:42.658	debug	TO SEND 1: /?!
          smartmeter.0	2019-03-13 09:21:42.657	debug	CURRENT PROCESS STEP 1 IN GETNEXTMESSAGE
          smartmeter.0	2019-03-13 09:21:42.657	debug	TO SEND 2:
          smartmeter.0	2019-03-13 09:21:42.656	debug	CURRENT PROCESS STEP 0 IN GETNEXTMESSAGE
          smartmeter.0	2019-03-13 09:21:42.655	debug	INITIAL MESSAGES TO SEND: 2
          smartmeter.0	2019-03-13 09:21:42.652	debug	SERIALPORT RESET BAUDRATE TO 300
          smartmeter.0	2019-03-13 09:21:42.644	debug	SERIALPORT OPEN
          smartmeter.0	2019-03-13 09:21:42.624	debug	CREATE SERIALPORT: 300 7 1 even
          smartmeter.0	2019-03-13 09:21:42.619	debug	SmartmeterObis options: {"debug":2,"protocol":"D0Protocol","transport":"SerialRequestResponseTransport","requestInterval":"30","transportSerialPort":"/dev/ttyUSB0","transportSerialB
          • wendy2702
            Pauschal würde ich sagen du hast das wieder geändert....
            @digitalnaive sagte in Adapter "smartmeter":
            @Röstkartoffel said in Adapter "smartmeter":
            Kannst du bitte mal in der SignOnMessage anstelle von /?! nur das ? eintragen?
            Und kannst du uns mal deine Adapter Versionsnummer nennen?
            Es geht!!! Sorry für die Ausrufezeichen aber das war der entscheidende Tipp!!!!
            zumindest laut deinem Logfile:
              digitalnaive @wendy2702 last edited by
              @wendy2702 said in Adapter "smartmeter":
              Siehe meinen Screenshot. Das ist der Screenshot von heute. Ich habe diese Config nicht eine Sekunde angefasst. Mir ist diese Zeile auch schon aufgefallen. Aber ich habe hier immernoch nur ein Fragezeichen drinnen stehen.
              • wendy2702
                Wurden sonst irgendwelche Upgrades am PI gemacht?
                Den PI mal neu gestartet?
                • Röstkartoffel
                  Röstkartoffel last edited by
                  Das / und das ! trägt der Adapter selbstständig ein, so dass im Log das dann so steht: /?!
                    digitalnaive @wendy2702 last edited by digitalnaive
                    Es gab ein Upgrade von JavaScript, Vis und Mobile. Beeinflusst JavaScript die Veränderung evtl?
                    Update javascript from @3.6.5 to @4.1.12
                    NPM version: 6.4.1
                      Homoran Global Moderator Administrators @digitalnaive last edited by
                      @digitalnaive
                      @wendy2702 sagte in Adapter "smartmeter":
                      Wendy meint den pi selber (denke ich), nicht iobroker
                      nein!
                      Das hast du aber inzwischen gemacht?
                        digitalnaive @Homoran last edited by digitalnaive
                        @Homoran Ja, hab ihn sicherheitshalber jetzt ein zweites mal restartet.
                        Folgende Meldung:
                        smartmeter.0	2019-03-13 09:54:07.177	debug	SCHEDULE NEXT RUN IN 30000s
                        smartmeter.0	2019-03-13 09:54:07.177	debug	DELETE rest of data (0) because new Message start with a new Request Message
                        smartmeter.0	2019-03-13 09:54:07.176	debug	CURRENT SIGNON MESSAGE COUNTER 1 OF 1
                        smartmeter.0	2019-03-13 09:54:07.176	debug	ERROR CLOSING SERIALPORT: Error: Port is not open
                        smartmeter.0	2019-03-13 09:54:07.176	debug	TO SEND 1: /?!
                        smartmeter.0	2019-03-13 09:54:07.176	debug	CURRENT PROCESS STEP 1 IN GETNEXTMESSAGE
                        smartmeter.0	2019-03-13 09:54:07.176	debug	TO SEND 2:
                        smartmeter.0	2019-03-13 09:54:07.176	debug	CURRENT PROCESS STEP 0 IN GETNEXTMESSAGE
                        smartmeter.0	2019-03-13 09:54:07.176	debug	INITIAL MESSAGES TO SEND: 2
                        smartmeter.0	2019-03-13 09:54:07.176	debug	CLEAR MESSAGE TIMEOUT TIMER
                        smartmeter.0	2019-03-13 09:54:07.176	debug	STOP
                        smartmeter.0	2019-03-13 09:54:07.176	debug	Transport Reset!! Restart = true
                        smartmeter.0	2019-03-13 09:54:07.176	debug	Error: Error on Baudrate changeover: Error: Port is not open
                        smartmeter.0	2019-03-13 09:54:07.176	warn	Error on Baudrate changeover: Error: Port is not open
                        Ergänzung. Mir wirft ls l /dev/ttyUSB* folgendes aus?! Auch daran habe ich nichts verändert. Heißt das auf gut deutsch, dass mein USB Gerät nicht mehr "eingehängt" ist?
                        digitalnaive@asrock:~$ ls -l /dev/ttyUSB*
                        ls: cannot access '/dev/ttyUSB*': No such file or directory
                        • wendy2702
                          Was kommt denn hier:
                          sudo dmesg | grep tty
                          Um festzustellen ob es etwas mit den Updates zu tun hat, könntest du mal downgrades machen... einem nach dem anderen und dazwischen immer schauen ob sich etwas geändert hat.
                          Node/NPM hast du nicht zufällig auch upgedated?
                            @wendy2702
                            digitalnaive@asrock:/dev$ sudo dmesg | grep tty
                            [    0.000000] console [tty0] enabled
                            Nein da hab ich keine Updates gemacht. Ich hatte lediglich eine zusätzliche USB Festplatte angeschlossen. Das dürfte doch aber die bestehende Konfiguration nicht beeinträchtigen. Oder denke ich da zu naiv?
                            • wendy2702
                              Pauschal würde ich sagen das deine USB Device nicht erkannt werden.
                              Mal alle USB Device abstecken.
                              Dann
                              dmesg
                              Lesekopf anstecken und erneut dmesg, ist der jetzt sichtbar in der Ausgabe?
                                Kann ich leider erst heute Abend machen.
                                Aktuelles DMESG liefert keinerlei Werte zu FTDI. Das ist schon mal kein gutes Zeichen.
                                • U
                                  uschi08 @jedo last edited by uschi08
                                  @jedo said in Adapter "smartmeter":
                                  Hast du schon mal bei Volkszähler die https://wiki.volkszaehler.org/hardware/channels/meters/power/edl-ehz/elster_as1440 studiert?
                                  ich habe auch die Kombi aus Weidmann IR Leser und AS1440, komme nicht weiter.
                                  • Lesekopf wird erkannt mit grep ....und als ich es schrieb sehe ich, dass es nicht mehr /dev/ttyUSB1 sondern wieder 0 ist..4 Stunden später...
                                    läuft danke für die Einstellungen - die funktionieren !
                                    steini87 @Stabilostick last edited by
                                    @Stabilostick Hallo zusammen und danke für eure Hilfe. Ich kann nun endlich Erfolg vermelden und der Adapter liest nach Aktivierung des langen Datentelegramms sauber Daten aus.
                                    Ich bin durch einen anderen Nutzer noch einmal an eine aktuellere Bedienanleitung vom Zähler gekommen. Darin kam dann zum Vorschein, dass für Zähler vom Typ OD: 7, even, 1 gilt und für Zähler vom Typ SM (meiner): 8, none, 1 gilt. Das Ganze mit einer Baudrate von 9600 Baud. Damit lief es bei mir auf Anhieb.
                                    @Appollon: Kannst du eBZ mit in die Liste der unterstützten Zähler aufnehmen?
                                    • Elektroniker86
                                      Elektroniker86 last edited by
                                      ich will hier nur meine Erfahrung mit Smartmeter und meinem Stromzähler teilen. Vielleicht hilft es ja dem einen oder anderen weiter.
                                      Und zwar geht es um den ISKRA MT 681 -D4A51-K0p dieser sendet jede Sekunde ein Datenpaket mit dem aktuellen Zählerstand ohne Nachkommastellen. Und das wars dann auch schon.
                                      Um weitere Datenpunkte zu erhalten kommt man um den PIN Code leider nicht drumrum. Aber wenn dieser beim EVU angefordert dann spuckt der Zähler mehr aus.
                                      Nach dem "einleuchten" der Pin mit der Taschenlampe kommen automatisch folgende Datenpunkte im Smartmeter / ioBroker an:
                                      • Aktueller Zählerstand bis auf die 4. Nachkommastelle in kWh
                                      • Momentanverbrauch je einzelner Phase (L1, L2, und L3) in Watt
                                      • Momentanverbrauch gesamt (L1+L2+L3) ebenfalls in Watt
                                      Der Zähler bleibt freigeschaltet, außer bei einem Stromausfall, dann muss der Pin erneut eingeleuchtet werden.
                                      Ich habe euch noch ein Screenshot von den Einstellungen und den Objekten gemacht.
                                        martinschm @Matthias I last edited by
                                        @Matthias-I said in Adapter "smartmeter":
                                        Meine Situation:
                                        • Stromzähler: 2 Zweirichtungszähler (EMH eHZ-IW8E2A5L0EQ2P) und einen Einrichtungszähler (EMH eHZ-IW8E2A5L0EL2P)
                                        Vielen Dank für Eure Meinung / Hilfe!!!!
                                        Matthias
                                        Hi Matthias, hab auch den ehz-iw8e2a5l0eq2p, hast du ihn alsn Laufen bekommen ? Welche Parameter hast du im Smartmeter Adapter eingetragen ?
                                          martinschm last edited by martinschm
                                          hab wie @Matthias-I einen ehz-iw8e2a5l0eq2p Zähler. Als Lesekopf habe ich einen Volkszähler mit RS232 Schnittstelle. Ich hab mir einen USB Konverter (Datasheet) geholt und damit an einen Raspberry angeschlossen.
                                          Stehe jetzt vor zwei Fragen, a) wie muß ich den Smartmeter Adapter konfigurieren bzw wo kann ich die Infos finden und b) wie kann ich testen ob die Hardware richtig funktioniert?
                                          Achso, bisher kommt nur das im Log
                                          smartmeter.0	2019-07-27 23:45:35.013	debug	SCHEDULE NEXT RUN IN 300s
                                          smartmeter.0	2019-07-27 23:45:35.011	debug	SERIALPORT CLOSE
                                          smartmeter.0	2019-07-27 23:45:34.955	debug	Transport Reset!! Restart = true
                                          smartmeter.0	2019-07-27 23:45:34.954	debug	Error: No or too long answer from Serial Device after last request.
                                          smartmeter.0	2019-07-27 23:45:34.954	warn	No or too long answer from Serial Device after last request.
                                          smartmeter.0	2019-07-27 23:45:34.953	debug	Error: No or too long answer from Serial Device after last request.
                                          smartmeter.0	2019-07-27 23:45:34.951	debug	MESSAGE TIMEOUT TRIGGERED
                                          smartmeter.0	2019-07-27 23:45:32.943	debug	SET MESSAGE TIMEOUT TIMER: 2000
                                          smartmeter.0	2019-07-27 23:45:32.934	debug	SERIALPORT OPEN
                                          smartmeter.0	2019-07-27 23:45:32.928	debug	CREATE SERIALPORT: 9600 8 1 none
                                          smartmeter.0	2019-07-27 23:45:32.928	debug	SmartmeterObis options: {"debug":2,"protocol":"D0Protocol","transport":"SerialResponseTransport","requestInterval":"300","anotherQueryDelay":"1000","transportSerialPort":"/dev/ttyUSB0","transportSeria
                                          smartmeter.0	2019-07-27 23:45:32.928	info	starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v8.16.0
                                          Wenn ich SML wähle kommt das gleiche. Hatte damals von Netzbetreiber noch ein Pin bekommen, wo/wie gebe ich den eigentlich ein ?
                                          Ciao
                                          Martin
                                            toki1973 @martinschm last edited by
                                            @martinschm said in Adapter "smartmeter":
                                            hab wie @Matthias-I einen ehz-iw8e2a5l0eq2p Zähler. Als Lesekopf habe ich einen Volkszähler mit RS232 Schnittstelle. Ich hab mir einen [USB Konverter](https://www.ebay.de/itm/3-3V-5V-Typ-A-USB-to-TTL-
                                            Ciao
                                            Martin
                                            Das schreibt doch elektroniker86 in seinem post:
                                            "Nach dem "einleuchten" der Pin mit der Taschenlampe kommen automatisch folgende Datenpunkte im Smartmeter / ioBroker an:"
                                            3625
                                            2286988
