    4. FHEM Adapter
    FHEM Adapter
      Einklaus last edited by
      Hallo LausiD,
      Adapter sicherheitshalber nochmal Neu installiert (über GIT)
      Adapter lief nicht mehr hoch. Nach Step3 gab es Probleme
      fhem.0 2019-02-15 11:29:35.385 debug statesDB connected
      fhem.0 2019-02-15 11:29:34.711 silly transport error
      fhem.0 2019-02-15 11:29:34.711 error Error: server error at Socket.onPacket (D:\ioBroker\node_modules\iobroker.js-controller\node_modules\engine.io-client\lib\socket.js:450:19) at WS.<anonymous> (D:\ioBroker\node_modules\iobroker
      fhem.0 2019-02-15 11:29:34.711 error server error
      fhem.0 2019-02-15 11:29:34.711 error TypeError: Cannot read property 'write' of null at Timeout.setTimeout [as _onTimeout] (D:\ioBroker\node_modules\iobroker.fhem\lib\telnet.js:128:60) at ontimeout (timers.js:436:11) at tryOn
      fhem.0 2019-02-15 11:29:34.711 error uncaught exception: Cannot read property 'write' of null
      fhem.0 2019-02-15 11:29:34.695 error uncaught exception: Cannot read property 'split' of undefined
      fhem.0 2019-02-15 11:29:34.695 info > FUNCTION delete unused objects automatically - info.Configurations.deleteUnusedObjects (true)
      fhem.0 2019-02-15 11:29:34.695 info > FUNCTION if fhem.0 set smartName automatically (Adapter Cloud) - info.Configurations.autoSmartName (true)
      fhem.0 2019-02-15 11:29:34.695 info > FUNCTION allow special configurations FHEM - info.Configurations.autoConfigFHEM (true)
      fhem.0 2019-02-15 11:29:34.677 debug [getConfig] info.Configurations.onlySyncRoomioBroker,ioB_OUT
      fhem.0 2019-02-15 11:29:34.677 debug [getConfig] info.Configurations.onlySyncNAME
      fhem.0 2019-02-15 11:29:34.677 debug [getConfig] info.Configurations.ignorePossibleSetsgetConfig,etRegRaw,egBulk,regSet,deviceMsg,CommandAccepted
      fhem.0 2019-02-15 11:29:34.677 debug [getConfig] info.Configurations.ignoreReadingscurrentTrackPositionSimulated,currentTrackPositionSimulatedSec
      fhem.0 2019-02-15 11:29:34.677 debug [getConfig] info.Configurations.allowedInternalsTYPE,NAME
      fhem.0 2019-02-15 11:29:34.677 debug [getConfig] info.Configurations.allowedAttributesroom,alias,comment
      fhem.0 2019-02-15 11:29:34.677 debug [getConfig] info.Configurations.ignoreObjectsInternalsTYPE
      fhem.0 2019-02-15 11:29:34.677 debug [getConfig] info.Configurations.ignoreObjectsInternalsNAMEinfo
      fhem.0 2019-02-15 11:29:34.677 debug [getConfig] info.Configurations.ignoreObjectsAttributesroom
      fhem.0 2019-02-15 11:29:34.677 debug [getConfig] info.Configurations.allowedIOBin
      fhem.0 2019-02-15 11:29:34.677 debug [getSetting] info.Configurations.oldState false
      fhem.0 2019-02-15 11:29:34.677 debug [getSetting] info.Configurations.deleteUnusedObjects true
      fhem.0 2019-02-15 11:29:34.677 debug [getSetting] info.Configurations.autoSmartName true
      fhem.0 2019-02-15 11:29:34.676 debug [getSetting] info.Configurations.autoConfigFHEM false
      fhem.0 2019-02-15 11:29:34.676 debug [getSetting] info.Configurations.autoFunction false
      fhem.0 2019-02-15 11:29:34.676 debug [getSetting] info.Configurations.autoRole false
      fhem.0 2019-02-15 11:29:34.676 debug [getConfigurations] start
      fhem.0 2019-02-15 11:29:34.676 info STEP 03 ===== select function of Adapter (FUNCTION) and Devices to sync (SYNC) - check fhem.0.info.Configurations (true or value)
        Habe ihn Neu installiert und die autoconfFHEM auf true gesetzt
        Denke mal so soll es auch sein
        • LausiD
          LausiD last edited by
          Genau so soll es aussehen 🙂
          Vielleicht kann am WE noch Version 1.2 an den Start gehen
          Vielen Dank Klaus für deine Mitarbeit
          LausiD
            Einklaus last edited by Einklaus
            Hallo LausiD
            habe noch folgende Meldung im Log (Debug = Info Meldung) die alle paar Sekunden wieder kommt..
            event ioBroker "fhem.0.info.Commands.sendFHEM set fhem.0.alive on-for-timer 70" > set fhem.0.alive on-for-timer 70
            Sieht so aus, als ob das so sein soll (nehme an ein Lebensbit das gesendet wird) .
            Schreibe es nur sicherheitshalber, falls nicht so sein sollte.
            Klaus
            • LausiD
              Hallo Klaus,
              vielen Dank für den Hinweis.
              Stimmt genau was du schreibst, alle 60 Sek wird "set fhem.x.alive on-for-timer 70" an FHEM geschickt.
              Falls dies ausbleibt wechselt fhem.x.alive spätestens nach 70 Sek auf off.
              Somit kann in FHEM die Funktion FHEM Adapter/iobroker überwacht werden.
              Eigentlich kann die Zeit auf 5 Min verlängert werden, oder ?
              Unter fhem.x.info.Settings können die gewünschten Meldungen mit true/false ausgewählt werden.
              Keine Meldungen "event ioBroker ......"
              fhem.0.info.Settings.logEventIOB= false
              Gruß und Danke
              LausiD
              • LausiD
                Nabend zusammen,
                auf github steht Version 1.2.0 zum Testen bereit.
                Bei entsprechenden Rückmeldungen kann Version in latest übernommen werden.
                Vielen Dank und Gruß
                LausiD
                  Scheint alles i.O. zu sein
                    Domoe last edited by
                    Moin zusammen,
                    ich habe ein kleines Problem vielleicht ist es aber auch nur eine Einstellungssache.
                    Ich habe an Fhem nur EnOcean Geräte. Diese über den Adapter in ioBroker.
                    Wenn ich ioBroker Neustarte dann reagieren diverse Schalter als ob man selber auf den Schalter gedrückt hat.
                    Beispiel:
                    Fernseher an Z-Wave Steckdose.
                    Enocean Wandschalter.
                    Beide über ein Blockly Script verbunden.
                    Wenn der Fernseher an ist und ich ioBroker neu starte geht der Fernseher aus.
                    Im Logbuch sind keine Fehler zu finden.
                    Hatte jemand schonmal dieses Problem?
                    Vielen Dank im voraus.
                    • LausiD
                      Hallo ﹰDomoe,
                      ﹰﹰbei einem ﹰNeustart ioBroker wird natürlich auch der FHEM Adapter neu gestartet.
                      Dabei werden alle Devices aus FHEM neu eingelesen und die jeweiligen States im ioBroker neu gesetzt.
                      Vermutlich tritt das Verhalten auch nur bei einem Neustart FHEM Adapter auf, oder?
                      Daher vermute ich den Fehler eher im Blocky Script.....
                      LausiD
                        Moin Lausi,
                        ja bis jetzt konnte ich das verhalten nur beim Neustart feststellen.
                        Ich guck mir meine Scripte nochmal an vielleicht habe ich da ja ein Fehler gemacht.
                        Danke für deine Antwort
                          hippoo last edited by
                          Hallo ich habe seit dem Update auf 1.20, alle 60 sek. folgende warning im iobroker:
                          warn	detect detect: missing "set fhem.0.alive on-for-timer 70" > set manuelly in FHEM or automatically with "fhem.0.info.Configuration.autoConfigFhem" = true | more info README.md
                          Der room "IoB_System" wird wohl korrekt angelegt in fhem.
                          Was ist da los?!
                          • LausiD
                            Hi Hippoo,
                            vielen Dank für die Rückmeldung.
                            fhem.0.info.Configurations.autoConfigFHEM auf true und Meldung ist weg.
                            Sonst kann in FHEM Raum ioB_System fhem.0.alive nicht gesetzt werden.
                            Mehr dazu README.md vom FHEM Adapter.
                            Muss ich noch ändern...sollte unabhängig von Zustand autoConfigFHEM funktionieren
                            Gruß LausiD
                              hippoo @LausiD last edited by
                              @LausiD
                              Oh mann, bin ich doof. 😖
                              vielen Dank für die schnelle Hilfe.
                              Da hab ich die ganze Zeit versucht das Problem bei fhem, statt bei iobroker zu lösen ...🙄
                              Aber ein Fehler ist mir auch noch aufgefallen: der "Pfad" bei iobroker heisst nicht
                              sondern
                              fhem.0.info.ConfigurationS.autoConfigFhem
                              zumindest bei mir hier 😉
                              Danke nochmals für den tollen Adapter! Läuft bei mir seit Monaten stabil in Kombination mit Rademacher DuoFern-Geräten.
                              • LausiD
                                @hippoo
                                Vielen Dank für die weitere Rückmeldung.
                                Da hast du Recht in der warn Meldung muss es noch auf "fhem.0.info.Configurations.autoConfigFHEM" geändert werden.
                                Danke......mehere Augen sehen halt mehr als nur meine 2 🙂
                                Mal schauen ob ich am WE die 2 Punkte ändern kann und auf github Version 1.2.1 legen kann.......
                                Hast du mal mit mit dem ioBroker Adapter Material UI beschäftigt?
                                Würde mich interessieren ob deine FHEM Geräte zur Anzeige kommen?
                                Gruß und schönes WE
                                LausiD
                                • LausiD
                                  über github kann 1.2.0 jetzt mit folgenden Änderungen aktualisiert werden.
                                  1. fhem.x.alive im Raum ioB_Sytem wird auch ohne fhem.x.info.Configurations.autoConfigFHEM=true gesetzt.
                                  2. fhem.x.alive wird nicht mehr alle 60 sec getriggert, sondern alle 300 sec = 5 Minuten. Das reicht, oder?
                                  3. Korrektur Text warn "....set manually in FHEM or automatically "fhem.0.info.Configurations.autoConfigFhem" = true | more info README.md"
                                  @hippoo
                                  Kannst du nochmal testen? Danke 🙂
                                  Gruß und viel Spaß mit ioBroker und FHEM
                                  LausiD
                                  • LausiD
                                    Sorry auf github war noch ein kleiner Fehler drin. Gestern aktualisiert 🙂
                                    Hat schon jemand 1.2.0 von github im Einsatz?
                                    LausiD
                                    • LausiD
                                      Zur Info:
                                      Node-red in Verbindung mit FHEM Adapter.
                                      Fehlermeldung "state does not exist" bei Verwendung PossibleSets wie zB. on-for-timer
                                      https://forum.iobroker.net/topic/21080/node-red-state-does-not-exist-in-iobroker
                                      • LausiD
                                        Aufruf zum Test FHEM Adapter in Zukunft hier:
                                        https://forum.iobroker.net/topic/21551
                                        Danke und Gruß
                                        LausiD
                                        • Ralf Aniol
                                          Ralf Aniol last edited by
                                          ich habe ein Problem mit der Synchronisation von iobroker nach fhem und komme mit dem Fehlerbild absolut nicht klar...
                                          Vorgehensweise:
                                          Ich lege in fhem ein dummy Device an und packe es in den Raum ioBroker:
                                          define V_Test dummy
                                          attr V_Test room ioBroker
                                          Device ist in iobroker zu sehen. Ich füge ich ein Reading hinzu:
                                          attr V_Test readingList test1
                                          setreading V_Test test1 123
                                          Variable ist in iobroker angelegt (fhem.0.V_Test.test1), Wert "123" ist zugewiesen.
                                          Mit iobroker mache ich jetzt ein
                                          iobroker state set fhem.0.V_Test.test1 hallo
                                          Klappt! Sowohl in iobroker als auch in fhem hat "test1" jetzt den Wert "hallo".
                                          Jetzt erweitere ich die readingsList in fhem:
                                          attr V_Test readingList test1,test2
                                          setreading V_Test test2 456
                                          Alles mapped schön nach iobroker (Variable fhem.0.V_Test.test2 ist angelegt und hat den Wert "456")... aber:
                                          Mache ich jetzt ein
                                          iobroker state set fhem.0.V_Test.test1 hallo2
                                          ändert sich der Wert von test1 zwar in iobroker, aber nicht mehr in fhem, dort wird im Device V_Test eine Reading "state" angelegt, das den Wert "test1 hallo" zugewiesen bekommen hat, das Reading "test1" selbst bleibt unverändert. Das gleiche passiert bei Zuweisung eines Wertes nach "test2".
                                          Lösche ich das 2. Reading mit
                                          deletereading V_Test test2
                                          klappt die Zuweisung nach test1 wieder wie gewünscht.
                                          Interessanterweise ist in iobroker die Variable "test2" immer noch vorhanden, eine Wert-Zuweisung spiegelt sich in fhem durch setzen des "state" Readings wider:
                                          iobroker state set fhem.0.V_Test.test2 hallo3
                                          in fhem:
                                          state: test2 hallo3
                                          Was mache ich falsch? Was fehlt?
                                          LausiD 1 Reply Last reply Reply Quote 0
                                          • LausiD
                                            LausiD @Ralf Aniol last edited by LausiD
                                            @Ralf-Aniol
                                            Danke für die ausführliche Beschreibung.
                                            Schau ich mir heute abend mal an.
                                            Welche Version FHEM Adapter hast du?
                                            Mal kurz nachgestellt:
                                            Die Readings werden im ioBroker nur mit Leserechte angelegt, hast du Schreibrechte manuell zugefügt?
                                            fhem.0.info.Commands.sendFHEM entspricht der Befehlszeile in FHEM. Hier kannst du direkt 'setreading Test Test1 lala" eingeben
                                            LausiD
                                            81.1k
                                            adapter fhem
                                            82
                                            676
                                            194262
