    4. Node-Red
    5. [gelöst] Hue Bewegungsmelder probleme mit lux
      Torsten_MG last edited by Homoran
      Hallo, ich habe 2 Bewegungsmelder von Philips hue.
      Motion und Battery werden problemlos übertragen. Nur LUX klappt bei mir leider nicht.
      Kann da jemand weiterhelfen?
              "id": "a9bdd812.d66708",
              "type": "tab",
              "label": "Flow 1",
              "disabled": false,
              "info": ""
              "id": "3cddc4e4.0314fc",
              "type": "ioBroker out",
              "z": "a9bdd812.d66708",
              "name": "BWM Flur",
              "topic": "Hue-Sensor-Flur",
              "ack": "true",
              "autoCreate": "true",
              "x": 641,
              "y": 80,
              "wires": []
              "id": "91c192e1.5280a",
              "type": "function",
              "name": "Motion",
              "func": "var newMsg = { payload: msg.payload.motion };\nreturn newMsg;",
              "outputs": 1,
              "noerr": 0,
              "x": 374,
              "y": 79,
              "wires": [
                      "3cddc4e4.0314fc"
              "id": "dd6e07ca.2251c8",
              "type": "hue-motion",
              "name": "Flur Sensor",
              "bridge": "7e9e53cb.178d2c",
              "sensorid": "3",
              "x": 106,
              "y": 79,
              "wires": [
                      "91c192e1.5280a",
                      "d7b6b979.cde3f8",
                      "b9f74ec1.e2a9e"
              "id": "d758a409.245f68",
              "name": "BWM Balkon",
              "topic": "Hue-Sensor-Balkon",
              "ack": "true",
              "x": 655,
              "y": 413,
              "wires": []
              "id": "1bf3e2d1.ff9d8d",
              "type": "function",
              "name": "motion",
              "outputs": 1,
              "noerr": 0,
              "x": 384,
              "y": 412,
              "wires": [
                      "d758a409.245f68"
              "id": "b36a28b0.30eee8",
              "name": "Balkon Bewegungsmelder",
              "sensorid": "12",
              "x": 115,
              "y": 461,
              "wires": [
                      "1bf3e2d1.ff9d8d",
                      "284edda7.86fe22",
                      "d842c5c6.3c1d38"
              "id": "d7b6b979.cde3f8",
              "type": "function",
              "name": "Battery",
              "func": "var newMsg = { payload: msg.info.battery };\nreturn newMsg;",
              "outputs": 1,
              "noerr": 0,
              "x": 378,
              "y": 133,
              "wires": [
                      "4eb19cf3.3f9864"
              "id": "4eb19cf3.3f9864",
              "name": "Batterie BWM Flur",
              "topic": "Batterie-BWM-Flur",
              "ack": "true",
              "x": 669,
              "y": 133,
              "wires": []
              "id": "284edda7.86fe22",
              "type": "function",
              "name": "Battery",
              "outputs": 1,
              "noerr": 0,
              "x": 395,
              "y": 460,
              "wires": [
                      "f331bd30.806f8"
              "id": "f331bd30.806f8",
              "name": "Batterie BWM Balkon",
              "topic": "Batterie-BWM_Balkon",
              "ack": "true",
              "x": 688,
              "y": 459,
              "wires": []
              "id": "b9f74ec1.e2a9e",
              "type": "function",
              "name": "lux",
              "func": "var newMsg = { payload: msg.payload.lux };\nreturn newMsg;\n",
              "outputs": 1,
              "noerr": 0,
              "x": 372,
              "y": 186,
              "wires": [
                      "eeac0ca5.58dad"
              "id": "eeac0ca5.58dad",
              "name": "LUX-BWM-Flur",
              "topic": "LUX-BWM-Flur",
              "ack": "true",
              "x": 661,
              "y": 186,
              "wires": []
              "id": "d842c5c6.3c1d38",
              "type": "function",
              "name": "lux",
              "outputs": 1,
              "noerr": 0,
              "x": 384,
              "y": 365,
              "wires": [
                      "88abe831.c03c38"
              "id": "88abe831.c03c38",
              "name": "LUX-BWM-Balkon",
              "topic": "LUX-BWM-Balkon",
              "ack": "true",
              "x": 679,
              "y": 362,
              "wires": []
              "id": "7e9e53cb.178d2c",
              "type": "hue-bridge",
              "z": "",
              "name": "Philips hue",
              "bridge": "192.168.178.41",
              "key": "gelöscht; Homoran (Admin)",
              "interval": "1000"
        sigi234 Forum Testing Most Active last edited by sigi234
          Vielen DANK!!
            sigi234 Forum Testing Most Active @Torsten_MG last edited by
            @Torsten_MG
            Bitte sehr, du solltes den bridge key löschen.....
              Homoran Global Moderator Administrators @sigi234 last edited by
              @sigi234
              ich hoffe ich habe das jetzt gemacht
                sigi234 Forum Testing Most Active @Homoran last edited by
                @Homoran
                Bist ja schneller als die Feuerwehr..........☺
                  @sigi234 🚒
                    Nochmals Danke ☺
                      @Torsten_MG sagte in [gelöst] Hue Bewegungsmelder probleme mit lux:
                      Nochmals Danke ☺
                      Benutzt das Voting rechts unten im Beitrag wenn er euch geholfen hat.😉
                      81.1k
