    4. Test Adapter SourceAnalytix v0.2.x
      Camuri last edited by
      Hier geht auch nichts.
        Stormbringer @porty last edited by
        @porty
        Danke bei mir hilft das leider nichts
          Fuga last edited by
          gleich thema bei mir auch:
          Fertig mit Fehler: /opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:799 if (adapter.substring(0, appName.length + 1) === appName + '.') { ^ TypeError: Cannot read property 'substring' of undefined at Object.getAdapterDir (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:799:16) at Install.createInstance (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:683:34) at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:529:34) at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9) at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12) at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15) at Manager.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20) at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8) at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15) at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
          • Palm_Maniac
            Palm_Maniac last edited by
            Tut sich hier noch was? Wird der Adapter noch weiter entwickelt oder muß auf was anderes ausgewichen werden? Welche Adapter wären denn eine Alternative?
            sigi234 Dutchman 2 Replies Last reply Reply Quote 0
              sigi234 Forum Testing Most Active @Palm_Maniac last edited by
              @Palm_Maniac
              ioBroker.statistics
              Palm_Maniac 1 Reply Last reply Reply Quote 0
                PrinzEisenherz1 last edited by
                Ich persönlich hoffe das Dutchman an diesem super Projekt noch weiterarbeitet denn dieser Adapter würde so ziemlich alle eine Skripte für Energieverbrauchsauswertung ablösen.
                Im statistic-Adapter fehlen mir einfach n paar wichtige Dinge.
                Johnny
                P.S. Vielleicht kann sich ja mal Dutchman dazu äussern?
                • Palm_Maniac
                  Palm_Maniac @sigi234 last edited by
                  @sigi234 Den Adapter lasse ich schon parallel laufen, damit eventuell keine Lücken entstehen beim Erfassen der Daten aus der PV-Anlage und dem Bezug. Ich hoffe mal, es geht bald weiter mit neuen Versionen.
                  • Dutchman
                    Dutchman Developer Most Active Administrators @Palm_Maniac last edited by
                    @Palm_Maniac sagte in [Neuer Adapter Beta 0.2.21] SourceAnalytix (Verbrauch Protokollierung von Strom/Gas/Flüssigkeiten):
                    working on it, test laufen fast wieder adapter wird gerade umgebaut nach compact mode und die Fehler mit undefined beseitigt.
                    Naeste beta am Wochenende zu erwarten
                    PS: sorry hatte par andere Sachen um die Ohren ✌
                    Palm_Maniac 1 Reply Last reply Reply Quote 2
                    • hg6806
                      hg6806 Most Active last edited by hg6806
                      Klasse, Dutchmann!!!
                      Ich habe mir einen Wasserzähler gebaut.
                      Sobald ich denn aber zu Soureceanalytix hinzufüge bekomme ich den gleichen Fehler wie @Creator
                      sourceanalytix.0	2019-03-18 20:41:58.723	info	terminating
                      sourceanalytix.0	2019-03-18 20:41:57.525	warn	Adapter SourceAnalytix stopped !
                      sourceanalytix.0	2019-03-18 20:41:57.523	error	at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-parser/index.js:251:12)
                      sourceanalytix.0	2019-03-18 20:41:57.523	error	at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
                      sourceanalytix.0	2019-03-18 20:41:57.523	error	at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                      sourceanalytix.0	2019-03-18 20:41:57.523	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
                      sourceanalytix.0	2019-03-18 20:41:57.523	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
                      sourceanalytix.0	2019-03-18 20:41:57.523	error	at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                      sourceanalytix.0	2019-03-18 20:41:57.523	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
                      sourceanalytix.0	2019-03-18 20:41:57.523	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
                      sourceanalytix.0	2019-03-18 20:41:57.523	error	at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.sourceanalytix/main.js:150:9)
                      sourceanalytix.0	2019-03-18 20:41:57.523	error	at initialize (/opt/iobroker/node_modules/iobroker.sourceanalytix/main.js:171:29)
                      sourceanalytix.0	2019-03-18 20:41:57.523	error	TypeError: Cannot read property 'toLowerCase' of undefined
                      sourceanalytix.0	2019-03-18 20:41:57.522	error	uncaught exception: Cannot read property 'toLowerCase' of undefined
                      Braucht das Objekt einen bestimmten Typ?
                      • Dutchman
                        Dutchman Developer Most Active Administrators @hg6806 last edited by
                        @hg6806 sagte in [Neuer Adapter Beta 0.2.21] SourceAnalytix (Verbrauch Protokollierung von Strom/Gas/Flüssigkeiten):
                        die unit dieses states ist sicher lehr ?
                        • hg6806
                          hg6806 Most Active @Dutchman last edited by
                          @Dutchman
                          Hier mal die RAW Daten des Objektes, vielleicht hilft das:
                            "ts": 1552935260328,
                            "common": {
                              "name": "Wasserzaehler.Zaehlerstand",
                              "role": "",
                              "type": "number",
                              "desc": "Manuell erzeugt",
                              "read": true,
                              "write": true,
                              "def": false,
                              "custom": {
                                "history.0": {
                                  "enabled": true,
                                  "changesOnly": true,
                                  "debounce": 0,
                                  "maxLength": "10",
                                  "retention": "31536000",
                                  "changesRelogInterval": 0,
                                  "changesMinDelta": 0,
                                  "aliasId": ""
                                "sourceanalytix.0": {
                                  "enabled": true,
                                  "alias": "Wasserzaehler",
                                  "state_type": "water_m3",
                                  "state_unit": "l",
                                  "costs": false,
                                  "consumption": true,
                                  "meter_values": true,
                                  "start_day": "330980",
                                  "start_week": "330900",
                                  "start_month": "330500",
                                  "start_quarter": "330000",
                                  "start_year": "330000"
                            "native": {},
                            "acl": {
                              "object": 1636,
                              "owner": "system.user.admin",
                              "state": 1636
                            "_id": "javascript.0.Wasserzaehler.Zaehlerstand",
                            "type": "state"
                          • Dutchman
                            Dutchman Developer Most Active Administrators @hg6806 last edited by Dutchman
                            jup ! genau das ist das problem womit mein code im moment noch nicht umgehen kan er erwartet einen unit in diesem state.
                            also um das mal als workaround zu lösen könntest du :
                              "common": {
                                "role": "",
                                "type": "number",
                                "read": true,
                                "write": true,
                                "def": false,
                            in
                              "common": {
                                "role": "",
                                "type": "number",
                                "read": true,
                                "write": true,
                                "unit" : "m3",
                                "def": false,
                            in der naesten version wird er die Einstellungen beim state nemen wen die unit nicht definiert ist.
                            Der Fehler entsteht weil er diese unit erwartet, da diese nicht existiert kommt ein undefined und Crash der adapter.
                            (wird am wochenende gefixt sein)
                            • hg6806
                              OK, da ich in Litern messe, habe ich "l" (kleines L) eingetragen.
                              Zumindest kommen keine Fehlermeldungen.
                              In den Objekten von SourceAnalytix wird aber nur ein Objekt eingetragen und keinen Ordner.
                              Vielleicht weil im Moment noch der Verbrauch fehlt?
                              • Dutchman
                                sollte eigentlich kommen, Seite mal refresht ?
                                richtigen Sachen eingetragen beim schraubschluessel (was er Protokollieren soll) ?
                                • Palm_Maniac
                                  Palm_Maniac @Dutchman last edited by
                                  @Dutchman Spitze das es weiter geht. Ich freue mich auf die nächsten Updates. 🙂
                                  • hg6806
                                    Läuft jetzt. Es war ausgehakte was protokolliert werden soll.
                                    Zudem wird manchmal automatisch umgeswitched zwischen Wasser und Stromverbrauch.
                                    • Peoples
                                      Peoples last edited by
                                      Leider lässt sich das gute Stück bei mir nicht installieren aber das wird bestimmt mit den nächsten Updates behoben sein
                                      • Dutchman
                                        Dutchman Developer Most Active Administrators @Peoples last edited by
                                        @Peoples sagte in [Neuer Adapter Beta 0.2.21] SourceAnalytix (Verbrauch Protokollierung von Strom/Gas/Flüssigkeiten):
                                        kommt drauf an 🙂 wie lautet die Fehlermeldung ?
                                        Peoples 1 Reply Last reply Reply Quote 0
                                        • Peoples
                                          Peoples @Dutchman last edited by
                                          @Dutchman
                                          Hey, bei der Installation kommt kein Fehler, erst beim anlegen der Instanz.
                                          Hab dir auch ein issue auf Git erstellt.
                                          • Dutchman
                                            was passiert wen du ihn über den admin installierst ?
                                            also repository auf latest und dan aus dem admin raus anstatt GitHub
                                            adapter test
                                            103
                                            958
                                            285221
