    3. Entwicklung
    4. ZigBee CC253x Adapter - nur neue/unbekannte Geräte Version 0.9.x
    • MyzerAT
      MyzerAT last edited by MyzerAT
      @Asgothian
      hab ich gemacht bekomme ihn aber nicht mehr zum laufen
      host.RDJL_Home	2019-03-18 23:36:44.545	info	Restart adapter system.adapter.zigbee.0 because enabled
      host.RDJL_Home	2019-03-18 23:36:44.543	error	instance system.adapter.zigbee.0 terminated with code 7 (Adapter already running)
      host.RDJL_Home	2019-03-18 23:36:42.861	info	instance system.adapter.zigbee.0 started with pid 15542
      host.RDJL_Home	2019-03-18 23:36:42.859	info	object change system.adapter.zigbee.0
      host.RDJL_Home	2019-03-18 23:36:23.961	info	Do not restart adapter system.adapter.zigbee.0 because disabled or deleted
      host.RDJL_Home	2019-03-18 23:36:23.958	error	instance system.adapter.zigbee.0 terminated with code 7 (Adapter already running)
      host.RDJL_Home	2019-03-18 23:36:21.230	info	object change system.adapter.zigbee.0
      host.RDJL_Home	2019-03-18 23:35:52.794	info	Restart adapter system.adapter.zigbee.0 because enabled
      host.RDJL_Home	2019-03-18 23:35:52.792	error	instance system.adapter.zigbee.0 terminated with code 7 (Adapter already running)
      host.RDJL_Home	2019-03-18 23:35:51.537	info	instance system.adapter.zigbee.0 started with pid 15437
      host.RDJL_Home	2019-03-18 23:35:51.534	info	object change system.adapter.zigbee.0
      zigbee.0	2019-03-18 23:35:37.161	error	Error: spawn udevadm ENOENT
      admin.0	2019-03-18 23:35:37.009	info	successful connection to socket.io from ::ffff:192.168.0.2
      host.RDJL_Home	2019-03-18 23:35:32.507	info	Restart adapter system.adapter.zigbee.0 because enabled
      host.RDJL_Home	2019-03-18 23:35:32.506	error	instance system.adapter.zigbee.0 terminated with code 7 (Adapter already running)
      host.RDJL_Home	2019-03-18 23:35:31.094	info	instance system.adapter.zigbee.0 started with pid 15367
      host.RDJL_Home	2019-03-18 23:35:31.091	info	object change system.adapter.zigbee.0
      zigbee.0	2019-03-18 23:35:15.105	error	Error: spawn udevadm ENOENT
      admin.0	2019-03-18 23:35:14.859	info	successful connection to socket.io from ::ffff:192.168.0.2
      host.RDJL_Home	2019-03-18 23:35:13.221	info	object change system.adapter.zigbee.0
      host.RDJL_Home	2019-03-18 23:35:08.468	info	Restart adapter system.adapter.zigbee.0 because enabled
      host.RDJL_Home	2019-03-18 23:35:08.467	error	instance system.adapter.zigbee.0 terminated with code 7 (Adapter already running)
      host.RDJL_Home	2019-03-18 23:35:07.169	info	instance system.adapter.zigbee.0 started with pid 15318
      zigbee.0	2019-03-18 23:35:04.161	error	Error: spawn udevadm ENOENT
      admin.0	2019-03-18 23:35:04.012	info	successful connection to socket.io from ::ffff:192.168.0.2
      host.RDJL_Home	2019-03-18 23:34:37.162	info	Restart adapter system.adapter.zigbee.0 because enabled
      host.RDJL_Home	2019-03-18 23:34:37.160	error	instance system.adapter.zigbee.0 terminated with code 7 (Adapter already running)
      host.RDJL_Home	2019-03-18 23:34:35.774	info	instance system.adapter.zigbee.0 started with pid 15268
      host.RDJL_Home	2019-03-18 23:34:35.774	info	object change system.adapter.zigbee.0
      host.RDJL_Home	2019-03-18 23:34:17.327	info	Restart adapter system.adapter.zigbee.0 because enabled
      host.RDJL_Home	2019-03-18 23:34:17.327	error	instance system.adapter.zigbee.0 terminated with code 7 (Adapter already running)
      ich kanns nimmer lesen, er läuft nicht und dennoch bekomme ich die meldung
      • Asgothian
        Asgothian Developer @MyzerAT last edited by
        @MyzerAT du musst erst einmal sicher stellen das er komplett weg ist.
        MyzerAT 2 Replies Last reply Reply Quote 0
        • MyzerAT
          MyzerAT @Asgothian last edited by MyzerAT
          @Asgothian
          mach ich eh per killall -q io.zigbee
          jetzt bekomme ich das
          host.RDJL_Home	2019-03-18 23:41:22.782	info	Do not restart adapter system.adapter.zigbee.0 because disabled or deleted
          host.RDJL_Home	2019-03-18 23:41:22.780	error	instance system.adapter.zigbee.0 terminated with code 7 (Adapter already running)
          • MyzerAT
            @Asgothian sagte in ZigBee CC253x Adapter - nur neue/unbekannte Geräte:
            wie überprüfe ich das, so?
            • Asgothian
              @MyzerAT ja
              • MyzerAT
                5 Aktoren hab ich raus geschmissen, will noch 2 Thermostate rein bekommen sinnlos
                zigbee.0	2019-03-18 23:54:07.566	error	Cannot get the Node Descriptor of the Device: 0x00158d000192d245 (Error: Timed out after 10000 ms)
                zigbee.0	2019-03-18 23:53:47.559	error	Cannot get the Node Descriptor of the Device: 0x00158d000192d245 (Error: Timed out after 10000 ms)
                zigbee.0	2019-03-18 23:53:27.552	error	Cannot get the Node Descriptor of the Device: 0x00158d000192d245 (Error: Timed out after 10000 ms)
                sonoff.0	2019-03-18 23:53:07.765	info	Client [DVES_3E4B4242] connected with secret 1552949587763_8968
                zigbee.0	2019-03-18 23:53:07.550	error	Cannot get the Node Descriptor of the Device: 0x00158d000192d245 (Error: Timed out after 10000 ms)
                sonoff.0	2019-03-18 23:53:07.493	info	Client [DVES_3E4B4242] connection closed: closed
                zigbee.0	2019-03-18 23:52:47.543	error	Cannot get the Node Descriptor of the Device: 0x00158d000192d245 (Error: Timed out after 10000 ms)
                zigbee.0	2019-03-18 23:52:43.794	info	Zigbee: allowing new devices to join.
                zigbee.0	2019-03-18 23:52:27.539	error	Cannot get the Node Descriptor of the Device: 0x00158d000192d245 (Error: Timed out after 10000 ms)
                zigbee.0	2019-03-18 23:52:07.535	error	Cannot get the Node Descriptor of the Device: 0x00158d000192d245 (Error: Timed out after 10000 ms)
                zigbee.0	2019-03-18 23:51:47.532	error	Cannot get the Node Descriptor of the Device: 0x00158d000192d245 (Error: Timed out after 10000 ms)
                zigbee.0	2019-03-18 23:51:27.528	error	Cannot get the Node Descriptor of the Device: 0x00158d000192d245 (Error: Timed out after 10000 ms)
                zigbee.0	2019-03-18 23:51:27.150	info	Zigbee: allowing new devices to join.
                zigbee.0	2019-03-18 23:51:07.522	error	Cannot get the Node Descriptor of the Device: 0x00158d000192d245 (Error: Timed out after 10000 ms)
                zigbee.0	2019-03-18 23:50:47.519	error	Cannot get the Node Descriptor of the Device: 0x00158d000192d245 (Error: Timed out after 10000 ms)
                zigbee.0	2019-03-18 23:50:38.629	warn	Failed to configure 0x7cb03eaa00b1d521 Plug 01, try again in 300 sec
                zigbee.0	2019-03-18 23:50:38.611	warn	Failed to configure 0x84182600000ff39d Plug 01, try again in 300 sec
                zigbee.0	2019-03-18 23:50:38.592	warn	Failed to configure 0x7cb03eaa00b0a6f0 Plug 01, try again in 300 sec
                zigbee.0	2019-03-18 23:50:38.573	warn	Failed to configure 0x7cb03eaa00b09a56 Plug 01, try again in 300 sec
                zigbee.0	2019-03-18 23:50:29.472	warn	Failed to configure 0x00158d0001922cdf SPZB0001, try again in 300 sec
                zigbee.0	2019-03-18 23:50:27.052	info	Successfully configured 0x00158d0001922dcd
                • MyzerAT
                  ich gebs auf, sitze sicher seit einer woche an dem und es wird immer schlimmer statt besser, hab ein haufen geld ausgegeben für was was nicht funktioniert, das ärgert mich schon sehr !
                    Wildbill @Asgothian last edited by
                    https://github.com/asgothian/ioBroker.zigbee/tarball/Admin_changes
                    auch heute morgen noch keine einzige Meldung von zigbee im Log. Lampen haben ganz normal funktioniert.
                    In welchem Thread auf Github wird über Deine Anpassung diskutiert? Finde irgendwie nichts. In Deinem Repo sind ja keine Issues. Beim iobroker-Github oder bei Koenkk?
                    Gruss, Jürgen
                    • Asgothian
                      Asgothian Developer @Wildbill last edited by
                      @Wildbill
                      Die Diskussion ist am offiziellen repo: Hier
                      • Asgothian
                        @MyzerAT die Frage war nicht ob du noch was rein bekommst sondern ob das netz dann stabil ist.
                        Du bist mit deinen geräten nah am Limit dessen was der Stick verträgt. Da wir den Speicher des Stick nicht abfragen können müssen wir das durch versuche heraus bekommen.
                          @Wildbill
                          Danke, habe es eben mal durchgelesen. Ich befürchtete schon, dass irgendeine Anpassung dafür sorgt, dass der Adapter oder der Stick sich nach einer bestimmten Zeit automatisch abschiesst, löscht oder so etwas. 😁
                          Ich lasse mal weiter laufen und wenn bis heute Abend keine größeren Probleme aufgetaucht sind, dann werde ich noch ein paar Geräte anlernen. 4 IKEA-Birnen, 3 IKEA-BWMs, 2 IKEA Remote und 1 Hue-Dimmer-Switch warten noch auf den Einsatz.
                          Zumindest den IKEA-Gateway konnte ich gestern Abend mal abklemmen. Der muss ja nicht auch noch rumfunken, wenn auch auf Kanal 15, den Stick habe ich auf 25 und die WLANS auf 1 und 7 mit jeweils 20MHz.
                          @MyzerAT Das wäre vielleicht etwas, was Du bei Dir noch checken könntest. Wie sieht es funkmäßig generell auf dem von Dir für den Stick gewählten Adapter aus? Wenn Du den Standardkanal 11 übernommen hast und ein WLAN auf Kanal 1 in der Nähe, dann sind die beide auf der gleichen Frequenz und stören sich womöglich auch schon...
                          Gruss, Jürgen
                            hier gehts weiter
                            https://forum.iobroker.net/topic/21136/zigbee-cc253x-adapter-nur-neue-unbekannte-geräte-ab-adapter-0-10-x
                            894
                            230265
