    3. Entwicklung
    4. ZigBee CC253x Adapter - nur neue/unbekannte Geräte Version 0.9.x
    • Asgothian
      Asgothian Developer @MyzerAT last edited by
      @MyzerAT du musst erst einmal sicher stellen das er komplett weg ist.
      MyzerAT 2 Replies Last reply Reply Quote 0
      • MyzerAT
        MyzerAT @Asgothian last edited by MyzerAT
        @Asgothian
        mach ich eh per killall -q io.zigbee
        jetzt bekomme ich das
        host.RDJL_Home	2019-03-18 23:41:22.782	info	Do not restart adapter system.adapter.zigbee.0 because disabled or deleted
        host.RDJL_Home	2019-03-18 23:41:22.780	error	instance system.adapter.zigbee.0 terminated with code 7 (Adapter already running)
        • MyzerAT
          @Asgothian sagte in ZigBee CC253x Adapter - nur neue/unbekannte Geräte:
          wie überprüfe ich das, so?
          • Asgothian
            @MyzerAT ja
            • MyzerAT
              5 Aktoren hab ich raus geschmissen, will noch 2 Thermostate rein bekommen sinnlos
              zigbee.0	2019-03-18 23:54:07.566	error	Cannot get the Node Descriptor of the Device: 0x00158d000192d245 (Error: Timed out after 10000 ms)
              zigbee.0	2019-03-18 23:53:47.559	error	Cannot get the Node Descriptor of the Device: 0x00158d000192d245 (Error: Timed out after 10000 ms)
              zigbee.0	2019-03-18 23:53:27.552	error	Cannot get the Node Descriptor of the Device: 0x00158d000192d245 (Error: Timed out after 10000 ms)
              sonoff.0	2019-03-18 23:53:07.765	info	Client [DVES_3E4B4242] connected with secret 1552949587763_8968
              zigbee.0	2019-03-18 23:53:07.550	error	Cannot get the Node Descriptor of the Device: 0x00158d000192d245 (Error: Timed out after 10000 ms)
              sonoff.0	2019-03-18 23:53:07.493	info	Client [DVES_3E4B4242] connection closed: closed
              zigbee.0	2019-03-18 23:52:47.543	error	Cannot get the Node Descriptor of the Device: 0x00158d000192d245 (Error: Timed out after 10000 ms)
              zigbee.0	2019-03-18 23:52:43.794	info	Zigbee: allowing new devices to join.
              zigbee.0	2019-03-18 23:52:27.539	error	Cannot get the Node Descriptor of the Device: 0x00158d000192d245 (Error: Timed out after 10000 ms)
              zigbee.0	2019-03-18 23:52:07.535	error	Cannot get the Node Descriptor of the Device: 0x00158d000192d245 (Error: Timed out after 10000 ms)
              zigbee.0	2019-03-18 23:51:47.532	error	Cannot get the Node Descriptor of the Device: 0x00158d000192d245 (Error: Timed out after 10000 ms)
              zigbee.0	2019-03-18 23:51:27.528	error	Cannot get the Node Descriptor of the Device: 0x00158d000192d245 (Error: Timed out after 10000 ms)
              zigbee.0	2019-03-18 23:51:27.150	info	Zigbee: allowing new devices to join.
              zigbee.0	2019-03-18 23:51:07.522	error	Cannot get the Node Descriptor of the Device: 0x00158d000192d245 (Error: Timed out after 10000 ms)
              zigbee.0	2019-03-18 23:50:47.519	error	Cannot get the Node Descriptor of the Device: 0x00158d000192d245 (Error: Timed out after 10000 ms)
              zigbee.0	2019-03-18 23:50:38.629	warn	Failed to configure 0x7cb03eaa00b1d521 Plug 01, try again in 300 sec
              zigbee.0	2019-03-18 23:50:38.611	warn	Failed to configure 0x84182600000ff39d Plug 01, try again in 300 sec
              zigbee.0	2019-03-18 23:50:38.592	warn	Failed to configure 0x7cb03eaa00b0a6f0 Plug 01, try again in 300 sec
              zigbee.0	2019-03-18 23:50:38.573	warn	Failed to configure 0x7cb03eaa00b09a56 Plug 01, try again in 300 sec
              zigbee.0	2019-03-18 23:50:29.472	warn	Failed to configure 0x00158d0001922cdf SPZB0001, try again in 300 sec
              zigbee.0	2019-03-18 23:50:27.052	info	Successfully configured 0x00158d0001922dcd
              • MyzerAT
                ich gebs auf, sitze sicher seit einer woche an dem und es wird immer schlimmer statt besser, hab ein haufen geld ausgegeben für was was nicht funktioniert, das ärgert mich schon sehr !
                  Wildbill @Asgothian last edited by
                  https://github.com/asgothian/ioBroker.zigbee/tarball/Admin_changes
                  auch heute morgen noch keine einzige Meldung von zigbee im Log. Lampen haben ganz normal funktioniert.
                  In welchem Thread auf Github wird über Deine Anpassung diskutiert? Finde irgendwie nichts. In Deinem Repo sind ja keine Issues. Beim iobroker-Github oder bei Koenkk?
                  Gruss, Jürgen
                  • Asgothian
                    Asgothian Developer @Wildbill last edited by
                    @Wildbill
                    Die Diskussion ist am offiziellen repo: Hier
                    • Asgothian
                      @MyzerAT die Frage war nicht ob du noch was rein bekommst sondern ob das netz dann stabil ist.
                      Du bist mit deinen geräten nah am Limit dessen was der Stick verträgt. Da wir den Speicher des Stick nicht abfragen können müssen wir das durch versuche heraus bekommen.
                        @Wildbill
                        Danke, habe es eben mal durchgelesen. Ich befürchtete schon, dass irgendeine Anpassung dafür sorgt, dass der Adapter oder der Stick sich nach einer bestimmten Zeit automatisch abschiesst, löscht oder so etwas. 😁
                        Ich lasse mal weiter laufen und wenn bis heute Abend keine größeren Probleme aufgetaucht sind, dann werde ich noch ein paar Geräte anlernen. 4 IKEA-Birnen, 3 IKEA-BWMs, 2 IKEA Remote und 1 Hue-Dimmer-Switch warten noch auf den Einsatz.
                        Zumindest den IKEA-Gateway konnte ich gestern Abend mal abklemmen. Der muss ja nicht auch noch rumfunken, wenn auch auf Kanal 15, den Stick habe ich auf 25 und die WLANS auf 1 und 7 mit jeweils 20MHz.
                        @MyzerAT Das wäre vielleicht etwas, was Du bei Dir noch checken könntest. Wie sieht es funkmäßig generell auf dem von Dir für den Stick gewählten Adapter aus? Wenn Du den Standardkanal 11 übernommen hast und ein WLAN auf Kanal 1 in der Nähe, dann sind die beide auf der gleichen Frequenz und stören sich womöglich auch schon...
                        Gruss, Jürgen
                          hier gehts weiter
                          https://forum.iobroker.net/topic/21136/zigbee-cc253x-adapter-nur-neue-unbekannte-geräte-ab-adapter-0-10-x
                          894
                          230266
