    4. Test Adapter SourceAnalytix v0.2.x
      sigi234 Forum Testing Most Active @Dutchman last edited by
      @Dutchman
      Super, bei mir geht auch Alles.....Ein Debug Log... vielleicht interessiert er dich ja.
      sourceanalytix.0	2019-03-21 22:06:19.313	debug	Test unit : kwh
      sourceanalytix.0	2019-03-21 22:06:19.313	debug	State value input for unit factore calculation : 2.218
      sourceanalytix.0	2019-03-21 22:06:19.313	debug	Object array input for unit factore calculation : {"type":"state","common":{"name":"Strom Drucker","type":"string","role":"value","desc":"totalMonthNow","unit":"kWh","def":0,"read":true,"write":true,
      sourceanalytix.0	2019-03-21 22:06:19.313	debug	Case result : Electricity consumption
      sourceanalytix.0	2019-03-21 22:06:19.313	debug	State object custom content: {"enabled":true,"alias":"","state_type":"kWh_consumption","costs":true,"consumption":true,"meter_values":true,"start_meassure":0,"start_day":2.136,"start_week":1.746,"sta
      sourceanalytix.0	2019-03-21 22:06:19.313	debug	State object content: {"type":"state","common":{"name":"Strom Drucker","type":"string","role":"value","desc":"totalMonthNow","unit":"kWh","def":0,"read":true,"write":true,"custom":{"history.0":{"enab
      sourceanalytix.0	2019-03-21 22:06:19.313	debug	Calc obj root sourceanalytix.0.hs100__0__192_168_178_43__totalMonthNow
      sourceanalytix.0	2019-03-21 22:06:19.313	debug	Write calculations for : hs100.0.192_168_178_43.totalMonthNow
      sourceanalytix.0	2019-03-21 22:06:19.313	debug	Instance name : sourceanalytix.0
      sourceanalytix.0	2019-03-21 22:06:19.313	info	state hs100.0.192_168_178_43.totalMonthNow changed : 2.218 SourceAnalytix calculation executed
      sourceanalytix.0	2019-03-21 22:06:14.293	debug	Meter Calculation executed
      sourceanalytix.0	2019-03-21 22:06:14.293	debug	calculated cost year : 0.15
      sourceanalytix.0	2019-03-21 22:06:14.293	debug	calculated cost quarter : 0.15
      sourceanalytix.0	2019-03-21 22:06:14.293	debug	calculated cost month : -0.04
      sourceanalytix.0	2019-03-21 22:06:14.293	debug	calculated cost week : 0.03
      sourceanalytix.0	2019-03-21 22:06:14.293	debug	calculated cost day : 0.01
      sourceanalytix.0	2019-03-21 22:06:14.293	debug	example state string : sourceanalytix.0.hs100__0__192_168_178_43__totalMonthNow.cost.01_current_day
      sourceanalytix.0	2019-03-21 22:06:14.293	debug	delivery type .consumption.
      sourceanalytix.0	2019-03-21 22:06:14.293	debug	cost type .cost.
      sourceanalytix.0	2019-03-21 22:06:14.293	debug	objroot sourceanalytix.0.hs100__0__192_168_178_43__totalMonthNow
      sourceanalytix.0	2019-03-21 22:06:14.293	debug	year consumed 2.218
      sourceanalytix.0	2019-03-21 22:06:14.293	debug	quarter consumed 2.218
      sourceanalytix.0	2019-03-21 22:06:14.293	debug	month consumed -0.6320000000000001
      sourceanalytix.0	2019-03-21 22:06:14.293	debug	week consumed 0.472
      sourceanalytix.0	2019-03-21 22:06:14.293	debug	day consumed 0.08199999999999985
      sourceanalytix.0	2019-03-21 22:06:14.293	debug	calculated reading day : 2.218
      sourceanalytix.0	2019-03-21 22:06:14.293	debug	calculated reading quarter : 2.218
      sourceanalytix.0	2019-03-21 22:06:14.293	debug	calculated reading month : -0.632
      sourceanalytix.0	2019-03-21 22:06:14.293	debug	calculated reading week : 0.472
      sourceanalytix.0	2019-03-21 22:06:14.293	debug	calculated reading day : 0.082
      sourceanalytix.0	2019-03-21 22:06:14.293	debug	Start consumption calculations
      sourceanalytix.0	2019-03-21 22:06:14.293	debug	Delivery state set to : .consumption.
      sourceanalytix.0	2019-03-21 22:06:14.293	debug	year start : 0
      sourceanalytix.0	2019-03-21 22:06:14.293	debug	quarter start 0
      sourceanalytix.0	2019-03-21 22:06:14.293	debug	month start 2.85
      sourceanalytix.0	2019-03-21 22:06:14.293	debug	week start : 1.746
      sourceanalytix.0	2019-03-21 22:06:14.293	debug	day start : 2.136
      sourceanalytix.0	2019-03-21 22:06:14.293	debug	reading_start : 0
      sourceanalytix.0	2019-03-21 22:06:14.293	debug	Handle meter history : true
      sourceanalytix.0	2019-03-21 22:06:14.293	debug	Handle consumption calculations : true
      sourceanalytix.0	2019-03-21 22:06:14.293	debug	Cost unit : 0.067
      sourceanalytix.0	2019-03-21 22:06:14.293	debug	Cost basic : 4
      sourceanalytix.0	2019-03-21 22:06:14.293	debug	Calculation Factor : 0.067
      sourceanalytix.0	2019-03-21 22:06:14.293	debug	Handle cost calculations : true
      sourceanalytix.0	2019-03-21 22:06:14.293	debug	Meter calculated reading : 2.218
      sourceanalytix.0	2019-03-21 22:06:14.293	debug	Meter current reading : 2.218
      sourceanalytix.0	2019-03-21 22:06:14.293	debug	State value output of unit factore calculation : 2.218
      sourceanalytix.0	2019-03-21 22:06:14.293	debug	Test unit : kwh
      sourceanalytix.0	2019-03-21 22:06:14.293	debug	State value input for unit factore calculation : 2.218
      • Dutchman
        Dutchman Developer Most Active Administrators @sigi234 last edited by
        @sigi234 sagte in [Neuer Adapter Beta 0.2.227] SourceAnalytix (Verbrauch Protokollierung von Strom/Gas/Flüssigkeiten):
        danke! sehr sogar das hilft bei optimalisierung !
        eine Sache fällt mir bei dir auf :
        stimmt dein startwert Monat ?
          sigi234 Forum Testing Most Active @Dutchman last edited by sigi234
          @Dutchman
          Hm.. ich habe 2 Geräte, einmal eine Homematic Funksteckdose (Geschirrspüler) und einmal eine TP-Link Funksteckdose ( Drucker)
          • Dutchman
            Dutchman Developer Most Active Administrators @sigi234 last edited by Dutchman
            @sigi234
            wie kan der Zählerstand vom Anfang des Monats hoeher sein als dieser Woche 😀
              @Dutchman
              Ich hab da nichts eingetragen soweit ich weis.........
              Ist sowieso ein Problem-Gerät in der App sehe ich alle Werte in ioBroker nicht .
              Werde ich wieder deaktivieren.
              • Dutchman
                wie lange läuft der adapter bei dir ?
                  @Dutchman sagte in [Neuer Adapter Beta 0.2.227] SourceAnalytix (Verbrauch Protokollierung von Strom/Gas/Flüssigkeiten):
                  Deiner? Schon ewig.......
                  • Dutchman
                    cool 😀
                    dan die frage ob der wert vom gerät sich geändert hat oder mein adapter n Fehler hat 😡
                      @Dutchman
                      Also habe ein neues Handy und die App erst vor kurzen wieder installiert. Zeichnet immer nur 1 Monat auf.........
                      • Homer.J.
                        Homer.J. last edited by Homer.J.
                        Morgen Dutchman,
                        Hab den Adapter gestern nochmal komplett neu installiert seid dem läuft er,
                        was mir nur auffällt ist das er die Tageswerte nicht mehr löscht, diese werden weiter gezählt.
                        Und bei Homematic PSM geht er ins minus.
                        • hg6806
                          hg6806 Most Active last edited by
                          Moin!
                          Ich hatte auch gestern 2.272 installiert.
                          Jetzt stehen in "heute" aber noch die Werte vom gestrigen Tag drin.
                          Also hat der Adapter den Tageswechsel nicht mitbekommen.
                          • Dutchman
                            Dutchman Developer Most Active Administrators @hg6806 last edited by
                            @hg6806 sagte in [Neuer Adapter Beta 0.2.227] SourceAnalytix (Verbrauch Protokollierung von Strom/Gas/Flüssigkeiten):
                            waehre es möglich das du mir deine log-files zukommen lässt ?
                            Ich bin vor allem interessiert an allem zwischen 23.58 und 00.02 heute nacht
                            Homer.J. 1 Reply Last reply Reply Quote 0
                            • Homer.J.
                              Homer.J. @Dutchman last edited by Homer.J.
                              @Dutchman Hier mal mein Auszug
                              2019-03-21 23:58:00.015 - info: host.iobroker object change system.adapter.hpcontrol.0
                              2019-03-21 23:58:00.017 - info: hpcontrol.0 cleaned everything up...
                              2019-03-21 23:58:00.016 - info: host.iobroker stopInstance system.adapter.hpcontrol.0
                              2019-03-21 23:58:00.016 - info: host.iobroker stopInstance system.adapter.hpcontrol.0 killing pid 9391
                              2019-03-21 23:58:00.026 - info: hpcontrol.0 cleaned everything up...
                              2019-03-21 23:58:00.066 - info: host.iobroker instance system.adapter.hpcontrol.0 terminated with code 0 (OK)
                              2019-03-21 23:58:02.543 - info: host.iobroker instance system.adapter.hpcontrol.0 started with pid 9531
                              2019-03-21 23:58:03.191 - info: hpcontrol.0 starting. Version 0.0.8 in /opt/iobroker/node_modules/iobroker.hpcontrol, node: v8.15.1
                              2019-03-21 23:58:03.222 - info: hpcontrol.0 ioBroker.hpcontrol started
                              2019-03-21 23:58:03.267 - info: hpcontrol.0 Values received
                              2019-03-21 23:59:00.016 - info: host.iobroker object change system.adapter.hpcontrol.0
                              2019-03-21 23:59:00.018 - info: hpcontrol.0 cleaned everything up...
                              2019-03-21 23:59:00.016 - info: host.iobroker stopInstance system.adapter.hpcontrol.0
                              2019-03-21 23:59:00.016 - info: host.iobroker stopInstance system.adapter.hpcontrol.0 killing pid 9531
                              2019-03-21 23:59:00.020 - info: javascript.0 script.js.common.Stromzähler.Strom_Verbrauchzähler_Täglich: telegram: Du hast gestern 12.430 kW/h Energie für 3.44 € , und 20.320 kW/h Energie Heizung für 3.78 € verbraucht.
                              2019-03-21 23:59:00.023 - info: hpcontrol.0 cleaned everything up...
                              2019-03-21 23:59:00.105 - info: host.iobroker instance system.adapter.hpcontrol.0 terminated with code 0 (OK)
                              2019-03-21 23:59:02.545 - info: host.iobroker instance system.adapter.hpcontrol.0 started with pid 9672
                              2019-03-21 23:59:03.194 - info: hpcontrol.0 starting. Version 0.0.8 in /opt/iobroker/node_modules/iobroker.hpcontrol, node: v8.15.1
                              2019-03-21 23:59:03.225 - info: hpcontrol.0 ioBroker.hpcontrol started
                              2019-03-21 23:59:03.272 - info: hpcontrol.0 Values received
                              2019-03-22 00:00:00.023 - info: javascript.0 script.js.common.Fenster.Skript1: Ausgelöst bei Timer
                              2019-03-22 00:00:00.024 - info: javascript.0 script.js.common.Fenster.Skript1: Geräte Nr. 0: Fensterkontakt Flur:0.LOW_BAT: false
                              2019-03-22 00:00:00.024 - info: javascript.0 script.js.common.Fenster.Skript1: Geräte Nr. 1: Fensterkontakt Balkontür:0.LOW_BAT: false
                              2019-03-22 00:00:00.024 - info: javascript.0 script.js.common.Fenster.Skript1: Geräte Nr. 2: Fensterkontakt Bad:0.LOW_BAT: false
                              2019-03-22 00:00:00.025 - info: javascript.0 script.js.common.Fenster.Skript1: Geräte Nr. 3: Thermostat Bad:0.LOW_BAT: false
                              2019-03-22 00:00:00.025 - info: javascript.0 script.js.common.Fenster.Skript1: Geräte Nr. 4: Bewegungsmelder HWR:0.LOW_BAT: false
                              2019-03-22 00:00:00.025 - info: javascript.0 script.js.common.Fenster.Skript1: Geräte Nr. 5: Fensterkontakt KZ:0.LOW_BAT: false
                              2019-03-22 00:00:00.025 - info: javascript.0 script.js.common.Fenster.Skript1: Geräte Nr. 6: Licht TV:0.LOW_BAT: false
                              2019-03-22 00:00:00.025 - info: javascript.0 script.js.common.Fenster.Skript1: Geräte Nr. 7: Fenstergriff Küche:0.LOW_BAT: false
                              2019-03-22 00:00:00.025 - info: javascript.0 script.js.common.Fenster.Skript1: Geräte Nr. 8: Bewegungsmelder Bad:0.LOW_BAT: false
                              2019-03-22 00:00:00.026 - info: javascript.0 script.js.common.Fenster.Skript1: Geräte Nr. 9: Fensterkontakt SZ:0.LOW_BAT: false
                              2019-03-22 00:00:00.026 - info: javascript.0 script.js.common.Fenster.Skript1: Geräte Nr. 10: Bewegungsmelder WZ:0.LOW_BAT: false
                              2019-03-22 00:00:00.026 - info: javascript.0 script.js.common.Fenster.Skript1: Geräte Nr. 11: Fenstergriff Flur:0.LOW_BAT: false
                              2019-03-22 00:00:00.026 - info: javascript.0 script.js.common.Fenster.Skript1: Geräte Nr. 12: Bewegungsmelder Flur:0.LOW_BAT: false
                              2019-03-22 00:00:00.026 - info: javascript.0 script.js.common.Fenster.Skript1: Geräte Nr. 13: Bewegungsmelder SZ:0.LOW_BAT: false
                              2019-03-22 00:00:00.026 - info: javascript.0 script.js.common.Fenster.Skript1: Geräte Nr. 14: Fensterkontakt WZ:0.LOW_BAT: false
                              2019-03-22 00:00:00.026 - info: javascript.0 script.js.common.Fenster.Skript1: Text:
                              2019-03-22 00:00:00.026 - info: javascript.0 script.js.common.Fenster.Skript1: Anzahl Geräte: 15 # davon LOW_BAT erkannt: 0
                              2019-03-22 00:00:00.044 - warn: javascript.0 Object "javascript.0.Verbrauchszaehler.Stromzähler_Zählerstand.Verbrauch._Tag.Tag_8" does not exist
                              2019-03-22 00:00:00.045 - warn: javascript.0 Object "javascript.0.Verbrauchszaehler.Stromzähler_Zählerstand.Kosten._Tag.Tag_8" does not exist
                              2019-03-22 00:00:00.047 - warn: javascript.0 Object "javascript.0.Verbrauchszaehler.Stromzähler_Mietwohnung.Verbrauch._Tag.Tag_8" does not exist
                              2019-03-22 00:00:00.048 - warn: javascript.0 Object "javascript.0.Verbrauchszaehler.Stromzähler_Mietwohnung.Kosten._Tag.Tag_8" does not exist
                              2019-03-22 00:00:00.049 - warn: javascript.0 Object "javascript.0.Verbrauchszaehler.Stromzähler_Wärmepumpe.Verbrauch._Tag.Tag_8" does not exist
                              2019-03-22 00:00:00.050 - warn: javascript.0 Object "javascript.0.Verbrauchszaehler.Stromzähler_Wärmepumpe.Kosten._Tag.Tag_8" does not exist
                              2019-03-22 00:00:00.051 - warn: javascript.0 Object "javascript.0.Verbrauchszaehler.Stromzähler_Waschmaschine.Verbrauch._Tag.Tag_8" does not exist
                              2019-03-22 00:00:00.052 - warn: javascript.0 Object "javascript.0.Verbrauchszaehler.Stromzähler_Waschmaschine.Kosten._Tag.Tag_8" does not exist
                              2019-03-22 00:00:00.028 - info: host.iobroker instance system.adapter.dwd.0 started with pid 9801
                              2019-03-22 00:00:00.058 - info: host.iobroker instance system.adapter.daswetter.0 started with pid 9807
                              2019-03-22 00:00:00.520 - info: hpcontrol.0 cleaned everything up...
                              2019-03-22 00:00:00.167 - info: host.iobroker instance system.adapter.ical.0 started with pid 9813
                              2019-03-22 00:00:00.773 - info: hpcontrol.0 cleaned everything up...
                              2019-03-22 00:00:00.374 - info: host.iobroker instance system.adapter.ical.1 started with pid 9821
                              2019-03-22 00:00:00.518 - info: host.iobroker object change system.adapter.hpcontrol.0
                              2019-03-22 00:00:00.519 - info: host.iobroker stopInstance system.adapter.hpcontrol.0
                              2019-03-22 00:00:00.519 - info: host.iobroker stopInstance system.adapter.hpcontrol.0 killing pid 9672
                              2019-03-22 00:00:00.573 - info: host.iobroker instance system.adapter.ical.2 started with pid 9827
                              2019-03-22 00:00:00.874 - info: host.iobroker instance system.adapter.ical.3 started with pid 9834
                              2019-03-22 00:00:01.035 - info: host.iobroker instance system.adapter.hpcontrol.0 terminated with code 0 (OK)
                              2019-03-22 00:00:01.123 - info: host.iobroker instance system.adapter.feiertage.0 started with pid 9843
                              2019-03-22 00:00:01.518 - info: dwd.0 starting. Version 2.4.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v8.15.1
                              2019-03-22 00:00:02.132 - info: daswetter.0 starting. Version 2.8.0 in /opt/iobroker/node_modules/iobroker.daswetter, node: v8.15.1
                              2019-03-22 00:00:02.565 - info: ical.1 starting. Version 1.7.0 in /opt/iobroker/node_modules/iobroker.ical, node: v8.15.1
                              2019-03-22 00:00:03.714 - info: host.iobroker instance system.adapter.hpcontrol.0 started with pid 9879
                              2019-03-22 00:00:03.837 - info: host.iobroker instance system.adapter.dwd.0 terminated with code 0 (OK)
                              2019-03-22 00:00:03.955 - info: ical.0 starting. Version 1.7.0 in /opt/iobroker/node_modules/iobroker.ical, node: v8.15.1
                              2019-03-22 00:00:04.326 - info: ical.2 starting. Version 1.7.0 in /opt/iobroker/node_modules/iobroker.ical, node: v8.15.1
                              2019-03-22 00:00:04.687 - info: ical.3 starting. Version 1.7.0 in /opt/iobroker/node_modules/iobroker.ical, node: v8.15.1
                              2019-03-22 00:00:04.693 - info: feiertage.0 starting. Version 1.0.11 in /opt/iobroker/node_modules/iobroker.feiertage, node: v8.15.1
                              2019-03-22 00:00:04.935 - info: ical.1 processing URL: calendar1 http://p18-calendars.icloud.com/published/2/qc0xx1mqQjY2I8rOiXoENZ9mOXeEWmMtB6ahaEmfdsmBYAqHlDIlsg_bysIrkM0wJziUuQC0B4qR9e5jJ1wwgy11OBWfwkXiwxEP8naEmLk
                              2019-03-22 00:00:05.130 - info: ical.0 processing URL: calendar1 http://p18-calendars.icloud.com/published/2/_xd1v5iM7YSKfsX8I_QgN15Fpo_3Op7-WrSIyuvL55uZ1mYD8PADFUNtQmu5ztA22gsve-sil8Um3SNXqZyaT64_UZ0mm2gweehbKJXU_mQ
                              2019-03-22 00:00:05.193 - info: feiertage.0 Next holiday: Karfreitag is in 28 days on 19.04.2019
                              2019-03-22 00:00:05.197 - info: feiertage.0 adapter feiertage objects written
                              2019-03-22 00:00:05.538 - info: daswetter.0 got wrong data structure! trying to repair...
                              2019-03-22 00:00:06.456 - info: host.iobroker instance system.adapter.feiertage.0 terminated with code 0 (OK)
                              2019-03-22 00:00:06.555 - info: hpcontrol.0 starting. Version 0.0.8 in /opt/iobroker/node_modules/iobroker.hpcontrol, node: v8.15.1
                              2019-03-22 00:00:06.589 - info: hpcontrol.0 ioBroker.hpcontrol started
                              2019-03-22 00:00:06.639 - info: hpcontrol.0 Values received
                              2019-03-22 00:00:06.741 - info: ical.2 processing URL: Ferien https://www.schulferien.org/media/ical/deutschland/ferien_sachsen-anhalt_2019.ics?k=fdMJJtP-ePIynaQ0xI4EhH7uGu027M9QQLxUeUpGciJnCmnm81k6G5j-JuTfdVU6WHl-CMnEBlmzR8WvsVAo79Gk8DbvGZx2VI4uh-K6qiI
                              2019-03-22 00:00:06.780 - info: ical.3 processing URL: Feiertage https://www.schulferien.org/media/ical/deutschland/feiertage_sachsen-anhalt_2019.ics?k=OVrJlUsyaaQh2bqxoQjXo0HoCGJRnWM6pdu1IMTEGbWorSMEqEf9vA-gEwRO4EXWI88cFLSJdgNRuhErZcfd73SwfJpVf9XplvURvT9P0A8
                              2019-03-22 00:00:10.706 - info: host.iobroker instance system.adapter.ical.1 terminated with code 0 (OK)
                              2019-03-22 00:00:10.968 - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (OK)
                              2019-03-22 00:00:12.427 - info: host.iobroker instance system.adapter.ical.2 terminated with code 0 (OK)
                              2019-03-22 00:00:12.432 - info: host.iobroker instance system.adapter.ical.3 terminated with code 0 (OK)
                              2019-03-22 00:00:18.211 - info: host.iobroker instance system.adapter.daswetter.0 terminated with code 11 (Desired termination)
                              2019-03-22 00:01:00.015 - info: host.iobroker object change system.adapter.hpcontrol.0
                              2019-03-22 00:01:00.017 - info: hpcontrol.0 cleaned everything up...
                              2019-03-22 00:01:00.016 - info: host.iobroker stopInstance system.adapter.hpcontrol.0
                              2019-03-22 00:01:00.016 - info: host.iobroker stopInstance system.adapter.hpcontrol.0 killing pid 9879
                              2019-03-22 00:01:00.023 - info: hpcontrol.0 cleaned everything up...
                              2019-03-22 00:01:00.088 - info: host.iobroker instance system.adapter.hpcontrol.0 terminated with code 0 (OK)
                              2019-03-22 00:01:02.548 - info: host.iobroker instance system.adapter.hpcontrol.0 started with pid 10075
                              2019-03-22 00:01:03.185 - info: hpcontrol.0 starting. Version 0.0.8 in /opt/iobroker/node_modules/iobroker.hpcontrol, node: v8.15.1
                              2019-03-22 00:01:03.215 - info: hpcontrol.0 ioBroker.hpcontrol started
                              2019-03-22 00:01:03.260 - info: hpcontrol.0 Values received
                              2019-03-22 00:01:23.285 - info: tankerkoenig.0 Reading data from tankerkoenig ...
                              2019-03-22 00:02:00.022 - info: host.iobroker object change system.adapter.hpcontrol.0
                              2019-03-22 00:02:00.024 - info: hpcontrol.0 cleaned everything up...
                              2019-03-22 00:02:00.022 - info: host.iobroker stopInstance system.adapter.hpcontrol.0
                              2019-03-22 00:02:00.022 - info: host.iobroker stopInstance system.adapter.hpcontrol.0 killing pid 10075
                              2019-03-22 00:02:00.033 - info: hpcontrol.0 cleaned everything up...
                              2019-03-22 00:02:00.061 - info: host.iobroker instance system.adapter.hpcontrol.0 terminated with code 0 (OK)
                              2019-03-22 00:02:02.552 - info: host.iobroker instance system.adapter.hpcontrol.0 started with pid 10204
                              2019-03-22 00:02:03.213 - info: hpcontrol.0 starting. Version 0.0.8 in /opt/iobroker/node_modules/iobroker.hpcontrol, node: v8.15.1
                              2019-03-22 00:02:03.243 - info: hpcontrol.0 ioBroker.hpcontrol started
                              2019-03-22 00:02:03.288 - info: hpcontrol.0 Values received
                              • Dutchman
                                Danke ! Ich kan den Fehler reproduzieren und werde ihn im laufe des morgens fixen
                                • hg6806
                                  OK, brauchst du mein Log dann nicht mehr?
                                  • Dutchman
                                    doch bitte jede extra information hilft.
                                    Meine Vermutung um moment is das der umbau nach compact mode die Funktion zerschossen hat um die tageswerte zu resetten.
                                      @Dutchman
                                      So ein neuer Debug Log, habe jetzt nur mehr Die Homematic Funksteckdose..........
                                      sourceanalytix.0	2019-03-22 09:54:21.086	debug	Meter Calculation executed
                                      sourceanalytix.0	2019-03-22 09:54:21.086	debug	calculated cost year : 0.67
                                      sourceanalytix.0	2019-03-22 09:54:21.086	debug	calculated cost quarter : 0.67
                                      sourceanalytix.0	2019-03-22 09:54:21.086	debug	calculated cost month : 0.67
                                      sourceanalytix.0	2019-03-22 09:54:21.086	debug	calculated cost week : 0.22
                                      sourceanalytix.0	2019-03-22 09:54:21.086	debug	calculated cost day : 0.07
                                      sourceanalytix.0	2019-03-22 09:54:21.086	debug	example state string : sourceanalytix.0.hm-rpc__1__NEQ1662322__2__ENERGY_COUNTER.cost.01_current_day
                                      sourceanalytix.0	2019-03-22 09:54:21.086	debug	delivery type .consumption.
                                      sourceanalytix.0	2019-03-22 09:54:21.086	debug	cost type .cost.
                                      sourceanalytix.0	2019-03-22 09:54:21.086	debug	objroot sourceanalytix.0.hm-rpc__1__NEQ1662322__2__ENERGY_COUNTER
                                      sourceanalytix.0	2019-03-22 09:54:21.086	debug	year consumed 9.9656
                                      sourceanalytix.0	2019-03-22 09:54:21.085	debug	quarter consumed 9.9656
                                      sourceanalytix.0	2019-03-22 09:54:21.085	debug	month consumed 9.9656
                                      sourceanalytix.0	2019-03-22 09:54:21.085	debug	week consumed 3.3359000000000005
                                      sourceanalytix.0	2019-03-22 09:54:21.085	debug	day consumed 1.038499999999999
                                      sourceanalytix.0	2019-03-22 09:54:21.085	debug	calculated reading day : 9.966
                                      sourceanalytix.0	2019-03-22 09:54:21.085	debug	calculated reading quarter : 9.966
                                      sourceanalytix.0	2019-03-22 09:54:21.085	debug	calculated reading month : 9.966
                                      sourceanalytix.0	2019-03-22 09:54:21.085	debug	calculated reading week : 3.336
                                      sourceanalytix.0	2019-03-22 09:54:21.085	debug	calculated reading day : 1.038
                                      sourceanalytix.0	2019-03-22 09:54:21.085	debug	Start consumption calculations
                                      sourceanalytix.0	2019-03-22 09:54:21.085	debug	Delivery state set to : .consumption.
                                      sourceanalytix.0	2019-03-22 09:54:21.085	debug	year start : 0
                                      sourceanalytix.0	2019-03-22 09:54:21.085	debug	quarter start 0
                                      sourceanalytix.0	2019-03-22 09:54:21.085	debug	month start 0
                                      sourceanalytix.0	2019-03-22 09:54:21.085	debug	week start : 6.6297
                                      sourceanalytix.0	2019-03-22 09:54:21.085	debug	day start : 8.927100000000001
                                      sourceanalytix.0	2019-03-22 09:54:21.085	debug	reading_start : 0
                                      sourceanalytix.0	2019-03-22 09:54:21.085	debug	Handle meter history : true
                                      sourceanalytix.0	2019-03-22 09:54:21.085	debug	Handle consumption calculations : true
                                      sourceanalytix.0	2019-03-22 09:54:21.085	debug	Cost unit : 0.067
                                      sourceanalytix.0	2019-03-22 09:54:21.085	debug	Cost basic : 4
                                      sourceanalytix.0	2019-03-22 09:54:21.085	debug	Calculation Factor : 0.067
                                      sourceanalytix.0	2019-03-22 09:54:21.085	debug	Handle cost calculations : true
                                      sourceanalytix.0	2019-03-22 09:54:21.085	debug	Meter calculated reading : 9.9656
                                      sourceanalytix.0	2019-03-22 09:54:21.085	debug	Meter current reading : 9965.6
                                      sourceanalytix.0	2019-03-22 09:54:21.085	debug	State value output of unit factore calculation : 9.9656
                                      sourceanalytix.0	2019-03-22 09:54:21.085	debug	Test unit : wh
                                      sourceanalytix.0	2019-03-22 09:54:21.085	debug	State value input for unit factore calculation : 9965.6
                                      sourceanalytix.0	2019-03-22 09:54:21.085	debug	Object array input for unit factore calculation : {"type":"state","common":{"def":0,"type":"number","read":true,"write":false,"min":0,"max":838860.7,"unit":"Wh","name":"Steckdose Geschirrspüler Messwe
                                      sourceanalytix.0	2019-03-22 09:54:21.085	debug	Case result : Electricity consumption
                                      sourceanalytix.0	2019-03-22 09:54:21.085	debug	State object custom content: {"enabled":true,"alias":"","state_type":"kWh_consumption","state_unit":"automatically","costs":true,"consumption":true,"meter_values":true,"start_day":8.927100000000001,"s
                                      sourceanalytix.0	2019-03-22 09:54:21.085	debug	State object content: {"type":"state","common":{"def":0,"type":"number","read":true,"write":false,"min":0,"max":838860.7,"unit":"Wh","name":"Steckdose Geschirrspüler Messwert.ENERGY_COUNTER","custom":
                                      sourceanalytix.0	2019-03-22 09:54:20.972	debug	Object array of all activated states : ["hm-rpc.1.NEQ1662322.2.ENERGY_COUNTER"]
                                      sourceanalytix.0	2019-03-22 09:54:20.972	debug	Object array : ["hm-rpc.1.NEQ1662322.2.ENERGY_COUNTER"]
                                      sourceanalytix.0	2019-03-22 09:54:20.972	debug	Calc obj root sourceanalytix.0.hm-rpc__1__NEQ1662322__2__ENERGY_COUNTER
                                      sourceanalytix.0	2019-03-22 09:54:20.972	debug	Write calculations for : hm-rpc.1.NEQ1662322.2.ENERGY_COUNTER
                                      sourceanalytix.0	2019-03-22 09:54:20.972	debug	Instance name : sourceanalytix.0
                                      sourceanalytix.0	2019-03-22 09:54:20.972	debug	Initialization finished for : hm-rpc__1__NEQ1662322__2__ENERGY_COUNTER
                                      sourceanalytix.0	2019-03-22 09:54:20.972	debug	Create channel name : Meter_Readings
                                      sourceanalytix.0	2019-03-22 09:54:20.972	debug	Create channel id : Meter_Readings
                                      sourceanalytix.0	2019-03-22 09:54:20.972	debug	Parent device : hm-rpc__1__NEQ1662322__2__ENERGY_COUNTER
                                      sourceanalytix.0	2019-03-22 09:54:20.972	debug	Create channel name : cost
                                      sourceanalytix.0	2019-03-22 09:54:20.972	debug	Create channel id : cost
                                      • Dutchman
                                        das sieht alles sehr gut aus danke !
                                        @all
                                        Ich habe soeben version 0.2.273 veröffentlicht, hierin ist der bug behoben fuer den täglichen reset.
                                        Wer gestern 0.2.272 installiert hat sollte heute einmalig den Tages startwert Manuel eintragen damit die Berechnungen stimmen
                                        Changelog:
                                        0.2.273
                                        • (Dutchman) fix issue in daily reset of start values
                                        • (Dutchman) Fix badges in readme
                                        • (Dutchman) exclude calculations of w from current routines (will be implemented in next version(s)
                                        Palm_Maniac 1 Reply Last reply Reply Quote 0
                                        • Palm_Maniac
                                          Palm_Maniac @Dutchman last edited by
                                          @Dutchman Hi. Über Admin wird mir jetzt die 0.2.272 angeboten. Ist das trotzdem schon die 0.2.273 oder soll ich mit dem Update noch warten?
                                          • Dutchman
                                            Dutchman Developer Most Active Administrators @Palm_Maniac last edited by Dutchman
                                            @Palm_Maniac sagte in [Neuer Adapter Beta 0.2.273] SourceAnalytix (Verbrauch Protokollierung von Strom/Gas/Flüssigkeiten):
                                            du kannst entweder direkt über git installieren, oder bis heute mittag (so ungefähr 14.30) warten.
                                            Unsere repositorys werden 2-mal am tag neu gebaut, 14.00 und 02.00 danach werden neue Versionen im admin angeboten.
                                            oder, das würde auch gehen, auf der console (im iobroker Verzeichnis!) das hier eingeben :
                                            npm i iobroker.sourceanalytix@latest
                                            adapter test
                                            103
                                            958
                                            285756
