    2. Русский
    3. ioBroker
    4. ioBroker драйвера
    5. Node red
    Node red
    • I
      instalator last edited by
      Не устанавливается обновление
      ! $ ./iobroker upgrade node-red
      ! npm install iobroker.node-red –production --prefix "c:/ioBroker" (System call)
      ! npm
      ! ERR!
      ! Error: EPERM, unlink 'c:\ioBroker\node_modules\iobroker.node-red\node_modules\node-red\node_modules\serialport\build\serialport\v1.4.10\Release\node-v11-win32-ia32\serialport.node'
      ! npm
      ! ERR!
      ! { [Error: EPERM, unlink 'c:\ioBroker\node_modules\iobroker.node-red\node_modules\node-red\node_modules\serialport\build\serialport\v1.4.10\Release\node-v11-win32-ia32\serialport.node']
      ! npm
      ! ERR!
      ! errno: 50,
      ! npm
      ! ERR!
      ! code: 'EPERM',
      ! npm
      ! ERR!
      ! path: 'c:\ioBroker\node_modules\iobroker.node-red\node_modules\node-red\node_modules\serialport\build\serialport\v1.4.10\Release\node-v11-win32-ia32\serialport.node' }
      ! npm
      ! ERR!
      ! npm
      ! ERR!
      ! Please try running this command again as root/Administrator.
      ! npm
      ! ERR!
      ! System
      ! Windows_NT 6.1.7601npm
      ! ERR!
      ! command
      ! "C:\Program Files\nodejs\\node.exe" "C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js" "install" "iobroker.node-red" "–production" "--prefix" "c:/ioBroker"
      ! npm
      ! ERR!
      ! cwd
      ! C:\Windows\system32
      ! npm
      ! ERR!
      ! node -v
      ! v0.10.36
      ! npm
      ! ERR!
      ! npm -v
      ! 1.4.28
      ! npm
      ! ERR!
      ! path
      ! c:\ioBroker\node_modules\iobroker.node-red\node_modules\node-red\node_modules\serialport\build\serialport\v1.4.10\Release\node-v11-win32-ia32\serialport.node
      ! npm
      ! ERR!
      ! code
      ! EPERM
      ! npm
      ! ERR!
      ! errno
      ! 50
      ! npm
      ! ERR!
      ! stack
      ! Error: EPERM, unlink 'c:\ioBroker\node_modules\iobroker.node-red\node_modules\node-red\node_modules\serialport\build\serialport\v1.4.10\Release\node-v11-win32-ia32\serialport.node'npm
      ! ERR!
      ! error rolling back Error: EPERM, unlink 'c:\ioBroker\node_modules\iobroker.node-red\node_modules\node-red\node_modules\serialport\build\serialport\v1.4.10\Release\node-v11-win32-ia32\serialport.node'npm
      ! ERR! error rolling back { [Error: EPERM, unlink 'c:\ioBroker\node_modules\iobroker.node-red\node_modules\node-red\node_modules\serialport\build\serialport\v1.4.10\Release\node-v11-win32-ia32\serialport.node']npm
      ! ERR! error rolling back errno: 50,npm ERR!
      ! error rolling back code: 'EPERM',npm ERR! error rolling back path: 'c:\ioBroker\node_modules\iobroker.node-red\node_modules\node-red\node_modules\serialport\build\serialport\v1.4.10\Release\node-v11-win32-ia32\serialport.node' }
      ! npm
      ! ERROR: process exited with code 25
      1547_main.js
      1547_mihomepacket.js
      • Bluefox
        Bluefox last edited by
        Интересно…
        Ты устанавливал serialport ручками?
        Удали папку 'c:\ioBroker\node_modules\iobroker.node-red\node_modules\node-red\node_modules\serialport' ручками или скорей всего просто деактивируй node-red и обнови.
        Я думаю, что бинарный файл 'c:\ioBroker\node_modules\iobroker.node-red\node_modules\node-red\node_modules\serialport\build\serialport\v1.4.10\Release\node-v11-win32-ia32\serialport.node в использовании и система не может его удалить.
        • aurodionov
          aurodionov last edited by
          Чего-то много ерор при обновлении
          ! 2015-05-17 13:22:12.380 - info: iobroker upgrade node-red
          ! 2015-05-17 13:22:13.178 - info: iobroker npm install iobroker.node-red –production --prefix "/opt/iobroker" (System call)
          ! 2015-05-17 13:22:45.762 - info: iobroker ../node-icu-charset-detector.cpp:5:28: fatal error: unicode/ucsdet.h: Нет такого файла или каталогаcompilation terminated.
          ! 2015-05-17 13:22:46.220 - info: iobroker make: *** [Release/obj.target/node-icu-charset-detector/node-icu-charset-detector.o] Ошибка 1
          ! 2015-05-17 13:22:46.230 - info: iobroker gyp
          ! 2015-05-17 13:22:46.237 - info: iobroker
          ! 2015-05-17 13:22:46.241 - info: iobroker ERR!
          ! 2015-05-17 13:22:46.250 - info: iobroker build error
          ! 2015-05-17 13:22:46.264 - info: iobroker gyp
          ! 2015-05-17 13:22:46.268 - info: iobroker
          ! 2015-05-17 13:22:46.273 - info: iobroker ERR!
          ! 2015-05-17 13:22:46.278 - info: iobroker stack
          ! 2015-05-17 13:22:46.291 - info: iobroker Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:267:23)
          ! gyp ERR! stack at ChildProcess.emit (events.js:98:17)
          ! 2015-05-17 13:22:46.294 - info: iobroker gyp ERR! stack at Process.ChildProcess._handle.onexit (child_process.js:809:12)
          ! 2015-05-17 13:22:46.321 - info: iobroker gyp ERR! System Linux 3.2.0-4-686-paegyp ERR! command "node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
          ! gyp ERR! cwd /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/irc/node_modules/node-icu-charset-detector
          ! gyp ERR! node -v v0.10.29
          ! gyp ERR! node-gyp -v v0.13.1
          ! gyp ERR! not ok
          ! 2015-05-17 13:22:55.479 - info: iobroker npm
          ! 2015-05-17 13:22:55.485 - info: iobroker WARN optional dep failed, continuing
          ! 2015-05-17 13:22:55.488 - info: iobroker node-icu-charset-detector@0.0.7
          ! 2015-05-17 13:24:24.671 - info: iobroker npm install –production --prefix "/opt/iobroker/node_modules/iobroker.node-red" (System call)
          ! 2015-05-17 13:24:29.783 - info: iobroker got /opt/iobroker/node_modules/iobroker.node-red/admin
          ! 2015-05-17 13:24:29.812 - info: host.SmartHome object change system.adapter.node-red.0
          ! 2015-05-17 13:24:29.812 - info: host.SmartHome stopInstance system.adapter.node-red.0
          ! 2015-05-17 13:24:29.821 - info: iobroker upload node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/node-red.png node-red.png image/png
          ! 2015-05-17 13:24:29.816 - info: node-red.0 kill node-red task
          ! 2015-05-17 13:24:29.900 - info: iobroker upload node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/index.html index.html text/html
          ! 2015-05-17 13:24:29.961 - info: iobroker Adapter "node-red" updated
          ! 2015-05-17 13:24:29.971 - info: iobroker exit 0
          ! 2015-05-17 13:24:30.348 - info: node-red.0 node-red exited with 0
          ! 2015-05-17 13:24:30.821 - info: host.SmartHome stopInstance system.adapter.node-red.0 killing pid 26077
          ! 2015-05-17 13:24:30.828 - info: node-red.0 terminating
          ! 2015-05-17 13:24:30.845 - info: host.SmartHome instance system.adapter.node-red.0 terminated with code 0 (OK)
          ! 2015-05-17 13:24:33.333 - info: host.SmartHome instance system.adapter.node-red.0 started with pid 28634
          ! 2015-05-17 13:24:34.197 - info: node-red.0 starting. Version 0.2.1 in /opt/iobroker/node_modules/iobroker.node-red
          ! 2015-05-17 13:24:34.319 - info: node-red.0 Starting node-red: /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/node_modules/iobroker.node-red/userdata/settings.js
          ! 2015-05-17 13:24:39.682 - warn: node-red.0 17 May 13:24:39 - [warn] –----------------------------------------
          ! 2015-05-17 13:24:39.684 - warn: node-red.0 17 May 13:24:39 - [warn] [arduino] Error: Cannot find module 'arduino-firmata'
          ! 2015-05-17 13:24:39.686 - warn: node-red.0 17 May 13:24:39 - [warn] [rpi-gpio] Info : Ignoring Raspberry Pi specific node.
          ! 17 May 13:24:39 - [warn] [redisout] Error: Cannot find module 'redis'
          ! 17 May 13:24:39 - [warn] –----------------------------------------
          Или это норма и не стоит паниковать.
          • Bluefox
            @aurodionov:
            ! gyp ERR! not ok
            Или это норма и не стоит паниковать. `
            Если работает, то не стоит 🙂
            • I
              @Bluefox:
              Интересно…
              Я думаю, что бинарный файл 'c:\ioBroker\node_modules\iobroker.node-red\node_modules\node-red\node_modules\serialport\build\serialport\v1.4.10\Release\node-v11-win32-ia32\serialport.node в использовании и система не может его удалить. `
              Руками не ставил, в ноде игрался с сериалом.
              Дело в том что у меня исчезла стрелка обновления, брокер пишет что нод не установлен (версию не отображает), хотя в списке установленых драйверов он есть. На вкладку нод ред нажимаю ругается на таймаут
              • Bluefox
                Напиши просто в 'c:\ioBroker\
                iobroker stop
                iobroker.start
                  electric69 last edited by
                  При обновлении в логе ошибки.
                  При этом адаптер уходит в циклицескую перезагрузку.
                  Даже плату вешает, ssh тормозит))
                  • Bluefox
                    @electric69:
                    Даже плату вешает, ssh тормозит)) `
                    Выполни
                    cd /opt/iobroker
                    Важно! Сохрани перед этим все свои flows!!!
                      @Bluefox:
                      @electric69:
                      Выполни
                      cd /opt/iobroker
                      Важно! Сохрани перед этим все свои flows!!! `
                      flows у меня не было пока никаких))
                      Не найду норм. примеров в инете, чтобы попробовать этот node-red.
                      Установка из консоли тоже дала ошибки, но прошла до завершения.
                      • Bluefox
                        node-red пытается установить несколько опциональных модулей (oprional dep) и не может.
                        Но это не страшно.
                        • I
                          @Bluefox:
                          iobroker stop
                          iobroker.start
                          Поставился, только все что было пропало.
                          @Bluefox:
                          А как их сохранить если Node-red перестал запускатся при предыдущей попытке обновить? Автоматически не бэкапятся?
                          • Bluefox
                            Ну на будущее:
                            /opt/iobroker/node_modules/iobroker.node-red/userdata/flows.json
                            Я, кстати, в новой версии убрал flows из папки, где они могут удалиться и переместил их в
                            /opt/iobroker/iobroker-data/node-red/flows.json
                            Можешь попробовать новую версию?
                            cd /opt/iobroker
                            ./iobroker stop node-red.0
                            npm install https://github.com/ioBroker/ioBroker.node-red/tarball/master
                            ./iobroker start node-red.0
                            • I
                              Не получается у меня вытянуть sessionid. Что я делаю не так? Где вообще почитать можно про нод ред? На каком языке пишутся функции?
                              ! [{"id":"b7d37336.482c9","type":"inject","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":86,"y":100,"z":"865a081c.79a5f8","wires":[["6368c27e.9c973c"]]},{"id":"62c44e09.9d3bb","type":"debug","name":"","active":true,"console":"false","complete":"false","x":597,"y":160,"z":"865a081c.79a5f8","wires":[]},{"id":"6368c27e.9c973c","type":"http request","name":"","method":"GET","ret":"txt","url":"https://www.sistemagorod.ru/lk/":[["f057ea4b.0fa818","3d13c92d.c2ec36"]]},{"id":"f057ea4b.0fa818","type":"function","name":"","func":"if (msg.payload.indexOf('")[1];\n\n return [msg];\n }\n","outputs":1,"valid":true,"x":415,"y":64,"z":"865a081c.79a5f8","wires":[["62c44e09.9d3bb"]]},{"id":"3d13c92d.c2ec36","type":"debug","name":"","active":true,"console":"false","complete":"false","x":429,"y":233,"z":"865a081c.79a5f8","wires":[]}]
                              Вроде что то получилось, но не знаю как избавиться от мусора в конце:
                              ! [{"id":"b7d37336.482c9","type":"inject","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":86,"y":100,"z":"865a081c.79a5f8","wires":[["6368c27e.9c973c"]]},{"id":"62c44e09.9d3bb","type":"debug","name":"","active":true,"console":"false","complete":"false","x":597,"y":160,"z":"865a081c.79a5f8","wires":[]},{"id":"6368c27e.9c973c","type":"http request","name":"","method":"GET","ret":"txt","url":"https://www.sistemagorod.ru/lk/":[["f057ea4b.0fa818","3d13c92d.c2ec36"]]},{"id":"f057ea4b.0fa818","type":"function","name":"","func":"if (~msg.payload.indexOf('")[0];\n// msg.payload.frequency = parseFloat(words[2].split(":")[1]);\n// msg.payload.time = words[1].split(">")[1];\n\n return [msg];\n }\n","outputs":1,"valid":true,"x":415,"y":64,"z":"865a081c.79a5f8","wires":[["62c44e09.9d3bb"]]},{"id":"3d13c92d.c2ec36","type":"debug","name":"","active":true,"console":"false","complete":"false","x":429,"y":233,"z":"865a081c.79a5f8","wires":[]}]
                              Победил):
                              ! [{"id":"b7d37336.482c9","type":"inject","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":94,"y":100,"z":"865a081c.79a5f8","wires":[["6368c27e.9c973c"]]},{"id":"62c44e09.9d3bb","type":"debug","name":"SessionId","active":true,"console":"false","complete":"payload","x":636,"y":99,"z":"865a081c.79a5f8","wires":[]},{"id":"6368c27e.9c973c","type":"http request","name":"","method":"GET","ret":"txt","url":"https://www.sistemagorod.ru/lk/":[["f057ea4b.0fa818"]]},{"id":"f057ea4b.0fa818","type":"function","name":"sessionid","func":"if (~msg.payload.indexOf('
                              Теперь как передать sessionid в пост запросе вообще не понятно.
                              • I
                                Передается ли заголовок?
                                ! [{"id":"b7d37336.482c9","type":"inject","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":94,"y":100,"z":"865a081c.79a5f8","wires":[["6368c27e.9c973c"]]},{"id":"6368c27e.9c973c","type":"http request","name":"","method":"GET","ret":"txt","url":"https://www.sistemagorod.ru/lk/":[["f057ea4b.0fa818"]]},{"id":"f057ea4b.0fa818","type":"function","name":"sessionid","func":"if (~msg.payload.indexOf('<link_text text="https://www.sistemagorod.ru/lk/auth?typ … pin=xxxx\n">https://www.sistemagorod.ru/lk/auth?type-auth=phone&answer-captcha=&phone=xxxx&pin=xxxx\n</link_text> msg.headers = {\n 'Origin': 'https://www.sistemagorod.ru',\n 'User-Agent': 'Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/42.0.2311.135 Safari/537.36',\n 'Content-Type': 'application/x-www-form-urlencoded',\n 'Referer': 'https://www.sistemagorod.ru/lk/%27,%5Cn 'Cookie': 'JSESSIONID=' + msg.sessionid\n }\n\n var url= "https://www.sistemagorod.ru/lk/auth?typ ... n\nmsg.url = url;\n\nreturn msg;","outputs":1,"valid":true,"x":93,"y":179,"z":"865a081c.79a5f8","wires":[["ef96486b.1069b8"]]},{"id":"ef96486b.1069b8","type":"http request","name":"","method":"POST","ret":"txt","url":"","x":232,"y":183,"z":"865a081c.79a5f8","wires":[["62c44e09.9d3bb","5bc33d6.fa43cc4"]]}]
                                авторизация вроде проходит <response><state>ok</state></response>
                                но на следующую страницу не пускает.
                                Продолжение…
                                Выводит в дебаг непонятную кодировку
                                ! [msg.payload] : string
                                ! ��<ko�v������cr�i*?��)��6�����apԕę"u��� ���/�����Τi��o���/cy�$�i�d�="��!">%%���L�����s���s��=sf���ܸ���?&�\������>�t�p|��ϋ��ū��%�X"WuQ5dS�TQ)>��#\�4[�BaggG�Y4�^��O���T� ��T��Un�<���G�����qf��{��[/spoiler]</ko�v������cr�i*?��)��6�����apԕę"u���>
                                • I
                                  Как распарсить заголовок ответа от сервера??? sessionid оказывается надо брать после авторизации из заголовка ответа.
                                  Получилось вытянть из заголовка Разные парраметры, но "set-cookie" никак не могу
                                  { "topic": "", "payload": "\r\n<response>\r\n <state>captcha-needed</state>\r\n</response>\r\n\r\n", "_msgid": "f9ba9259.06457", "sessionid": "6E14E8C7BF3AFDE8E63FBF0EA015BFB4", "headers": { "date": "Sun, 24 May 2015 13:07:42 GMT", "server": "Apache/2.4.7 (Ubuntu)", "content-length": "100", "set-cookie": [ "JSESSIONID=61D7BF78F3FBE2665E9FAF0AC2BA1F93; Path=/lk/; Secure; HttpOnly" ], "keep-alive": "timeout=5, max=100", "connection": "Keep-Alive", "content-type": "text/plain" }, "url": "https://www.sistemagorod.ru/lk/auth?typ … x&pin=xxxx", "statusCode": 200 }
                                  Bluefox выручай!!!
                                  • Bluefox
                                    @instalator:
                                    Продолжение…
                                    Я не нашел в твоём flow вывода в дебаг.
                                    Может стринг не в utf-8? При конвертировании в стринг можно указать кодировку.
                                    'ascii' - for 7 bit ASCII data only. This encoding method is very fast, and will strip the high bit if set.
                                    'utf8' - Multibyte encoded Unicode characters. Many web pages and other document formats use UTF-8.
                                    'utf16le' - 2 or 4 bytes, little endian encoded Unicode characters. Surrogate pairs (U+10000 to U+10FFFF) are supported.
                                    'ucs2' - Alias of 'utf16le'.
                                    'base64' - Base64 string encoding.
                                    'binary' -
                                    'hex' - Encode each byte as two hexadecimal characters. `
                                    • I
                                      Да проблема сейчас в другом. Я не могу получить sessionid из ответного заголовка от сервера. Авторизоваться у меня получилось в ответ приходит заголовок с sessionid вот его надо как то вырвать для дальнейшей навигации по страницам. Помогай, мозг кипит…
                                      Это ответ от сервера
                                      ! { "topic": "", "payload": "\r\n<response>\r\n <state>ok</state>\r\n</response>\r\n\r\n", "_msgid": "c27391e4.3d8c7", "sessionid": "6E14E8C7BF3AFDE8E63FBF0EA015BFB4", "headers": { "date": "Sun, 24 May 2015 17:59:17 GMT", "server": "Apache/2.4.7 (Ubuntu)", "content-length": "88", "set-cookie": [ "JSESSIONID=6385A1C965987A3FAA6131DD153D2EE1; Path=/lk/; Secure; HttpOnly" ], "keep-alive": "timeout=5, max=100", "connection": "Keep-Alive", "content-type": "text/plain" }, "url": "https://www.sistemagorod.ru/lk/auth?typ … x&pin=xxxx", "statusCode": 200 }
                                      Нужно как то получить JSESSIONID=6385A1C965987A3FAA6131DD153D2EE1 это валидный id
                                      • I
                                        [{"id":"b7d37336.482c9","type":"inject","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":92,"y":81,"z":"865a081c.79a5f8","wires":[["b614a670.49eb58"]]},{"id":"b614a670.49eb58","type":"function","name":"Авторизация","func":"msg.sessionid = context.global.sessionid;\n msg.headers = {\n            'Host': 'www.sistemagorod.ru',\n            'User-Agent': 'Mozilla/5.0 (Windows NT 6.1; WOW64; rv:38.0) Gecko/20100101 Firefox/38.0',\n            'Accept': '*/*',\n            'Accept-Language': 'ru-RU,ru;q=0.8,en-US;q=0.5,en;q=0.3',\n            'Accept-Encoding': 'gzip, deflate',\n            'Content-Type': 'application/x-www-form-urlencoded; charset=UTF-8',\n            'X-Requested-With': 'XMLHttpRequest',\n            'Referer': 'https://www.sistemagorod.ru/lk/',\n            'Cookie': 'JSESSIONID='+ msg.sessionid,\n            'Connection': 'keep-alive',\n            'Pragma': 'no-cache',\n            'Cache-Control': 'no-cache'\n        }\n        \n\n  var url= \"https://www.sistemagorod.ru/lk/auth?type-auth=phone&answer-captcha=&phone=xxxx&pin=xxxx\";\n\nmsg.url = url;\nreturn msg;","outputs":1,"valid":true,"x":132.55555725097656,"y":139.11111450195312,"z":"865a081c.79a5f8","wires":[["ef96486b.1069b8"]]},{"id":"ef96486b.1069b8","type":"http request","name":"","method":"POST","ret":"txt","url":"","x":309.7777900695801,"y":139.22221565246582,"z":"865a081c.79a5f8","wires":[["ad6096b4.529f68","62c44e09.9d3bb","a452cdcd.5bad3"]]},{"id":"ad6096b4.529f68","type":"debug","name":"","active":true,"console":"false","complete":"true","x":602.5555419921875,"y":209,"z":"865a081c.79a5f8","wires":[]}]
                                        • I
                                          Кто нибудь помоги мне 😢
                                          • Bluefox
                                            @instalator:
                                            Кто нибудь помоги мне 😢 `
                                            Я не могу помочь, т.к. мне не хватает информации.
                                            Что это такое?
                                            { "topic": "", "payload": "\r\n<response>\r\n <state>ok</state>\r\n</response>\r\n\r\n", "_msgid": "c27391e4.3d8c7", "sessionid": "6E14E8C7BF3AFDE8E63FBF0EA015BFB4", "headers": { "date": "Sun, 24 May 2015 17:59:17 GMT", "server": "Apache/2.4.7 (Ubuntu)", "content-length": "88", "set-cookie": [ "JSESSIONID=6385A1C965987A3FAA6131DD153D2EE1; Path=/lk/; Secure; HttpOnly" ], "keep-alive": "timeout=5, max=100", "connection": "Keep-Alive", "content-type": "text/plain" }, "url": "https://www.sistemagorod.ru/lk/auth?type-auth=phone&answer-captcha=&phone=xxxx&pin=xxxx", "statusCode": 200 }
                                            Ответ от чего? Откуда все эти цифры?
                                            Если это какой то объект, то JSESSIONID извлекается так:
                                            [{"id":"185e8fcd.e7a17","type":"function","name":"Extract SessionID","func":"\nvar obj = { \"topic\": \"\", \"payload\": \"\\r\\n<response>\\r\\n <state>ok</state>\\r\\n</response>\\r\\n\\r\\n\", \"_msgid\": \"c27391e4.3d8c7\", \"sessionid\": \"6E14E8C7BF3AFDE8E63FBF0EA015BFB4\", \"headers\": { \"date\": \"Sun, 24 May 2015 17:59:17 GMT\", \"server\": \"Apache/2.4.7 (Ubuntu)\", \"content-length\": \"88\", \"set-cookie\": [ \"JSESSIONID=6385A1C965987A3FAA6131DD153D2EE1; Path=/lk/; Secure; HttpOnly\" ], \"keep-alive\": \"timeout=5, max=100\", \"connection\": \"Keep-Alive\", \"content-type\": \"text/plain\" }, \"url\": \"https://www.sistemagorod.ru/lk/auth?type-auth=phone&answer-captcha=&phone=xxxx&pin=xxxx\", \"statusCode\": 200 };\n\nvar cookies = obj.headers[\"set-cookie\"][0];\nvar m = cookies.match(/JSESSIONID=([\\w\\d]*)/);\nif (m) {\n    msg.payload = m[1];\n    return msg;\n}\n\n\n","outputs":1,"x":372,"y":367,"z":"e90d20bf.16f2e","wires":[["35779b1d.ca8864"]]},{"id":"35779b1d.ca8864","type":"debug","name":"","active":true,"console":"false","complete":"false","x":546,"y":366,"z":"e90d20bf.16f2e","wires":[]},{"id":"89d64003.7629c","type":"inject","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":214,"y":368,"z":"e90d20bf.16f2e","wires":[["185e8fcd.e7a17"]]}]
                                            19460
